It seems hardware problem and not problem that caused after firmware update.
This symptom occurred from the inner lcd panel (no communication with video chip) and not the digitizer (outer touch panel).
I had faced many similar problems in many tablet, pc and also Lcd tv.
And this is the Lcd type that use in pipo max m9 : 10.1'' HannStar HSD101PWW2 REV.0 LCD LED .
2014/04/15
mexas59 said
It seems hardware problem and not problem that caused after firmware update.This symptom occurred from the inner lcd panel (no communication with video chip) and not the digitizer (outer touch panel).
hola nexas that I have to do to repair?
2014/04/15
Problema En Una tableta de mi hijo .se callos y el desarme Sigue Siendo El Mismo y Encontró El que Problema Tienen augerito ONU pinchazo en La instancia de parte posterior De La Pantalla de Dos En El Mismo LUGAR SE VE la Luz Donde los cables se sueldan Do Batería Creo Dębe Que Ser El Problema problem in a tablet of my son .se callus and the disarmament remained the same and found the problem they have augerito a puncture in the rear the two screen in the same place looks light where wires are welded its battery pack I think that must be the problem
56 Guest(s)
Devices in use: Desktop (53), Phone (3)
VMILCINOV
