cracktech said
spaceboy1 said
When you open the tablet to go to kom,
that and I do not post lit the pink box at the rokkchip to flashes RomaI've done format system, format boot, format sd, format ex sd, format data,
all these formats was made by cwmTi should I do to be switched;
knows someone tell me;
backup could not get because the tablet has deleted everything from format to have doneIf you managed to get to the point seeing the #1 box showing you PINK color then it is good , just click "switch" and when the #1 box turn green "click "RESTORE" not upgrade.
I know I upgrade I have done many times but not lit pink BOX THAT and do
stays where it says kom anywhere else
Rather spoil the tablet
Because when you go to see adv drivvers writes me and not rk3188 rk3066;
www.madradio107.net
Ooops sorry spaceboy I didnt understand your English!.
Since it can enter CWM it means it is not totally dead.
Please try the hardbrick recovery method (reset+esc+power) key combination further down the thread that I posted. Another guru taught us this method on Slatedroid forum when he was testing his modified ROM (when he bricked his device he uses this method to recover)
keep on trying to recover your bricked device using "hardbrick" recovery method . You can download it from this link RkAndroidTool (Finless flashing method) : http://www.mediafire.com/download/g9i91j45utt8zce/Pipo_M9_Pro_RileyROM_2.0.zip
As for the loader from "V1.20.bin" change the details to loader "V1.24" as described in the following pictures.
By default the Loader box is always uncheck(not tick) but since you guys have loaded the wrong loader in the first place you need to have the correct Loader flash onto your device. So right click the letter V1.20.bin and change that to V1.24.bin and then check (tick) the box. remember the hardbrick button combination (reset+esc+power) button.Try to flash even if it says No found RKAndroid rock usb, please read the instructions inside the folder carefully..
--k0l0kaust0--About Me LENOVO S939 MTK6592 Vibe 2.0 - 1507,LENOVO A8-A5500 KitKat MTK8382 S029,Lenovo Tab2 A7-30HC MT8382 Lollipop,LENOVO A880 S027 MTK6582 (JB),ONDA V975m V3 AMLOGIC M802 (KitKat), PiPo M9Pro RK3188 KASTY ROM (KitKat # 407 Mod), ZENITHINK ZTPAD:C93 Duo Core AMX CM10.2_rc-3, Z102 And. 4.0.4, C91 And. 4.0.4,AIGO M60 Android 4.04 6" A13 (rooted).Lenovo A369i 4.2.2 S011 ROW
cracktech said
Ooops sorry spaceboy I didnt understand your English!.Since it can enter CWM it means it is not totally dead.
I've done this many times with the esc reset power but the problem is not linked to the pc to make pink the checkbox rockchip, the steps to do it right but does not connect, I've done the same and the y rkandroid other graphics no found devices, I can make some adjustments from cwm to connect with pc
www.madradio107.net
xocolocoxoco said
got it! just do the same as post 20. The computer takes a while to recognize
Hooray, I am so happy for you xocolocoxoco. Now I can sleep soundly at nite. Time to help SPaceBoy.
Please give me a thanks .
2013/09/27
cracktech said
xocolocoxoco said
got it! just do the same as post 20. The computer takes a while to recognizeHooray, I am so happy for you xocolocoxoco. Now I can sleep soundly at nite. Time to help SPaceBoy.
thank you very much! I am very happy for scoring. Even my father was happy that I could fix the tablet him and said stop keep doing these updates ... hahahaha.
If I can help the SPaceBoy I am willing. Not afraid to tinker with electronics, I have some years of experience and always researching firmware, already killed a motorola v3 and I will still researching and trying to fix. 😛
2013/09/27
and I've done many upgrades to tablets and mobile but not lit pink batterie, I've done an upgrade again and lit pink but since I did format from the cwm is not communicating with you pc, 3 computers try other anything, windows xp I have
I plugged into the outlet. And did those procedures, I pressed "reset" after ESC and POWER (all together) then let the "reset" and I was pressing ESC + POWER, and waited a minute or so, the computer recognized al.
xocolocoxoco has done it and he unbricked his "hardbrick" device yours is only only softbrick but you should try the hardbrick recovery method because you said the PC dont recognised the device. Please ask xocolocoxoco for his help as he experience it first hand.
ok guys I'll try again, the truth is that not perinena Newsflash for recognition by the pc, I have to bug computers Tin win32 sality, once removed will I do the test, will update, http://www.madradio107.net
www.madradio107.net
I've done everything not linked, the step I take is the following: reset 5 sec esc 5sec power, and puts me in a little luminous screen, fastboot I think, but wait for it to nothing, then presses esc + reset + power but nothing Association Wait 5 minutes other graphics not found rk android rock usb, adb driver have passed without a problem, do something wrong;
www.madradio107.net
2013/09/27
Your tablet is brick? Try to make it plugged in together. The reset button is more in case the reset fails. Leave plugged in, press "reset" then ESC + POWER, and wait. In my case it worked well.
39 Guest(s)
Devices in use: Desktop (36), Phone (3)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
