2013/09/27
darevil102 said
xocolocoxoco said
xocolocoxoco said nop....really is dead! Brick. Equals you call a cell phone is on and the usb without the battery. The computer will not identify anything. Equal to pipo :'(
See my forum post #144 for you to try. it is sad to see a good device dead but as far as we know this thing is hard to brick.
sorry but could not find the post 144 :/
Post #20 in this page
yes, already tried. Gives no sign of life.
cracktech said
Use RkAndroid Tools and erase INAND before doing that using your mouse go into sdcard (internal sdcard) and erase everything inside there, this is to be done JUST before reflashing the firmware. Then you can use RkBatchTool (factory Rk Tools)to reflash the correct firmware back onto the M9Pro everything is to be "scrubbed" clean before reflashing of new firmware.
or if you have CWM recovery installed use format "cache", format data "factory reset" to"scrubbed" clean your device before reflashing firmware.Since you can use mouse download CWM recovery first.or else flash the RILEY ROM first with the first box ticked (#1 box is default to NOt Tick) then reflash using RKbatch Tool for KASTY ROM
I did Deletes through recovery but when I go to flashes to go to recovery and can not connect with rockhip while I've put adb drives, one which notice is that when you connect the tablet to my pc and not showed rk3066 rk3188, Has instead rk3066 rk3188?
www.madradio107.net
Just hang on in there for a while need to rewrite the config file in the RK Android tool to change from loader version 1.20 to version 1.24. But you see it is not totally bricked if you can attempt to flash it. hang on in there for a bit more.
Spaceboy try to do the "hardbrick" recovery method but use instead the RK batch Tool to flash KASTY ROM and dont go through the Rk Android tool method already since you already erase INAND. see my post #20
I do what I write the post but does not see the tablet in arkandroid while the computer is normally seen drivers adb, when you open the tablet to go directly to cwm, I did format in everything from cwm,
www.madradio107.net
No SpaceBoy!
You cant flash M9pro ROM from any forum (yet) using CWM. So far I have not come across any M9Pro ROm that is able to be flashed through CWM. So dont try it!
xocolocoxoco said
the problem of my tablet, is that he does not care. Since the computer will do the repair if it does not turn on? There's something that I can do on the motherboard to force the start of it or something?
The hardbrick recovery is the use of "reset" + "esc" +"power" button combination but this time try to use the RKbatchTool (KASTY firmware)instead of RkAndroid Tool.
You have to keep trying to do that until it will begin to be able to flash, one time try is not enough try many times.This is te only way to recover from hardbick RK31Xx device. No shorting of pins inside will do the trick.
cracktech said
cracktech said
No SpaceBoy!You cant flash M9pro ROM from any forum (yet) using CWM. So far I have not come across any M9Pro ROm that is able to be flashed through CWM. So dont try it!
No SpaceBoy!
the problem is that when when power to go to cwm 6.0.3.1kai that and I do not associate with rockchip tool usb, I've done exactly the steps from Post # 20 but not syndeeati
Is there a solution;
Assay apeires times but does not connect with the rockchip, abideth in cwm v6.0.3.1
how to restore
www.madradio107.net
2013/10/01
But can I can take a CWM backup of a Kasty rom on one M9 Pro and use it to CWM flash upgrade the Kasty rom of another M9 Pro?
Any advice would be appreciated.
When you open the tablet to go to kom,
that and I do not post lit the pink box at the rokkchip to flashes Roma
I've done format system, format boot, format sd, format ex sd, format data,
all these formats was made by cwm
Ti should I do to be switched;
knows someone tell me;
backup could not get because the tablet has deleted everything from format to have done
www.madradio107.net
Igor101 said
cracktech said
No SpaceBoy!
Yes I guess so.(not sure) But after you have make the device alive, please reflash it through RkBatchTool the KASTY firmware again. This is to ensure that you do not have any corrupted restore files its better that you reflash it clean because you just recovered from a failure.
But the restore means that all the other M9Pro details will be duplicated onto your device.
that and I do not post lit the pink box at the rokkchip to flashes RomaI've done format system, format boot, format sd, format ex sd, format data,
all these formats was made by cwmTi should I do to be switched;
If you managed to get to the point seeing the #1 box showing you PINK color then it is good , just click "switch" and when the #1 box turn green "click "RESTORE" not upgrade.
cracktech said
Igor101 said
cracktech said
No SpaceBoy!
probably do not understand what problem I have in Tablets
When you open the tablet sees only the cwm and nothing else
only the menu of cwm enters anywhere else
I changed 3 pc and in no way affiliated with rockchip not lit pink BOX
How can I do to see the tablet rockchip?
I have done all that you told me and does nothing
it's probably time to break it and throw it in the trash
I have 3 days trying and nothing happens
I'm doing the right thing but does not want to work
There is a solution to the fly
www.madradio107.net
40 Guest(s)
Devices in use: Desktop (37), Phone (3)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
