For those that is having problem flashing their "softbrick" M9Pro. Tyr this method to upgrade
(DO NOT ATTaCH IT THROUGH A USB HUB!)
1. The M9Pro must be in the "off" condition.
2. then Run RkbatchTool with the correct firmware loaded.
3. Attached the USB cable between the PC and M9pro
4. Then press the "esc" + "power" button at the same time.(IF drivers are not correctly loaded it will try to load drivers before it gets to #5)
5. Watch the #1 box turn to "Green" color
6. Do not press the switch button , just press the "Restore" button.
 If "hardbrick" please ask for further instructions. it will have the "reset pin"+" esc" + "power" button combination to flash the firmware , you might need and extra pair of hands to help you achieve that.
RK devices are nearly impossible to "hardbrick"
At this point in time there is no option to flash it via CWM, admin hasnt completed his devlopment as promised.
admin, --k0l0kaust0--, hbalint1About Me  LENOVO S939 MTK6592 Vibe 2.0 - 1507,LENOVO A8-A5500 KitKat MTK8382 S029,Lenovo Tab2 A7-30HC MT8382 Lollipop,LENOVO A880 S027 MTK6582 (JB),ONDA V975m V3 AMLOGIC M802 (KitKat), PiPo M9Pro RK3188 KASTY ROM (KitKat # 407 Mod), ZENITHINK ZTPAD:C93 Duo Core AMX CM10.2_rc-3, Z102 And. 4.0.4, C91 And. 4.0.4,AIGO M60 Android 4.04 6" A13 (rooted).Lenovo A369i 4.2.2 S011 ROW
2013/09/27
I'll explain what happened. I tried to install kitkat, but with the tablet rk3188 88 Chuwi this site here http://crewrktablets.arctablet.com/?p=2343, but not as the first installation worked, because it was wrong "LOADER" option (RK3188Loader(L)_V1.24.bin) I put what was available along with the file (RK3188Loader(L)_V2.07.bin) installed, operated, my tablet was running kitkat, but was very slow, and has error rotation (90°) yes, I used the "kernel" of the pipo. So when I saw the new update, I downloaded here and went to install using the RKBatchTool 1.7, accused error. And my tablet died. I found odd, because it's not the first time I do it.
Is there any program that resurrect it? Because it really does not give any sign of life. Died brick. Just turn on the light when I connect the charger.
Or something that would be necessary to stir the motherboard.
For HARDBRICKED" RECOVERY to flash, you need the RKAndroid Tool from RILEY ROM Forum (FREAKTAB Forum)
First you need to install the RK Driver_Asistance installer from Rockchip factory : http://www.arctablet.com/blog/forum/firmware-development/rockchip-released-an-easy-driver-installer/
 Then Download the latest Riley ROM for M9Pro at least version 2.0. then run the RkAndroid tool. then in the first line #1 (0x00000000) Loader box tick the #1 box ( default NOT tick). (This is because you use the wrong loader.bin file to flash) Normally this is left NOT TICK.
Connect via USB to your PC
Start the Flash app RKAndroid Tool NOT the RKBatchTool on your PC
(the device should be in OFF condition!! )
Press and hold the ESC button for 5 seconds
While holding the ESC button put a paperclip in the reset hole and press and hold it for 5 seconds.
While still holding the Esc button and the Reset button, press the power button and hold.
You will see the flash tool recognize your device in loader mode.
Release the ESC key
Release the Reset button
Keep holding the power button with your thumb (if you let go, it will go out of loader mode and you will have to start over).
Click Erase IDB, let it finish
Click Flash ROM, keep holding the power button until it is done flashing the ROM.
Disconnect from the PC and press the power button again until the device powers up.
(this method , thanks to members on SLATEDROID Forum).
You will have to do some finger gymnastics here or get another hand to help you! This instruction is included in the ROM package so is the tools needed to Flash the ROM it is called the RKAndroid Tools vs the stock (from factory tools) RK Batch Tool only after this you can use the normal RkBatchTool to flash KASTY ROM.
This is not in anyway promoting RILEYS ROM but it has the tools required/opinions-on-teclast-p90hdsted to unbricked an M9Pro/M8/M9 (RK3188).
If you are succesful in resuscitating your device after this , please dont try this foolish thing again without working with a guru like OMA or gurus on XDA or SLATEDROID.
(I was an advanced member on SLATEDROID working on ZENITHINK ROM until mid this year when I dropped ZENITHINK device and entered into RK3188 and Exynos 5410 Octa Core on XDA forum)
admin, pipotablet, derricktanyz, hbalint1About Me  LENOVO S939 MTK6592 Vibe 2.0 - 1507,LENOVO A8-A5500 KitKat MTK8382 S029,Lenovo Tab2 A7-30HC MT8382 Lollipop,LENOVO A880 S027 MTK6582 (JB),ONDA V975m V3 AMLOGIC M802 (KitKat), PiPo M9Pro RK3188 KASTY ROM (KitKat # 407 Mod), ZENITHINK ZTPAD:C93 Duo Core AMX CM10.2_rc-3, Z102 And. 4.0.4, C91 And. 4.0.4,AIGO M60 Android 4.04 6" A13 (rooted).Lenovo A369i 4.2.2 S011 ROW
I the problem I have is that after a mistake that puts the Rim pipi m9 and not the pipo m9 pro3g that is my own, so it worked Conversely the screen and only the third displays work, see para xato video by Users on youtube that has exactly the same problem as me.
www.madradio107.net
Use RkAndroid Tools and erase INAND before doing that using your mouse go into sdcard (internal sdcard) and erase everything inside there, this is to be done JUST before reflashing the firmware. Then you can use RkBatchTool (factory Rk Tools)to reflash the correct firmware back onto the M9Pro everything is to be "scrubbed" clean before reflashing of new firmware.
or if you have CWM recovery installed use format "cache", format data "factory reset" to"scrubbed" clean your device before reflashing firmware.Since you can use mouse download CWM recovery first.or else flash the RILEY ROM first with the first box ticked (#1 box is default to NOt Tick) then reflash using RKbatch Tool for KASTY ROM
xocolocoxoco said
nop....really is dead! Brick. Equals you call a cell phone is on and the usb without the battery. The computer will not identify anything. Equal to pipo :'(
See my forum post #144 for you to try. it is sad to see a good device dead but as far as we know this thing is hard to brick.
I've done everything but the displays work vice versa in the third, they just did not do is to rkdroid to check the first BOX when I checked my writes loaded wrong and not flashescracktech said
Use RkAndroid Tools and erase INAND before doing that using your mouse go into sdcard (internal sdcard) and erase everything inside there, this is to be done JUST before reflashing the firmware. Then you can use RkBatchTool (factory Rk Tools)to reflash the correct firmware back onto the M9Pro everything is to be "scrubbed" clean before reflashing of new firmware.Â
www.madradio107.net
2013/09/27
xocolocoxoco said nop....really is dead! Brick. Equals you call a cell phone is on and the usb without the battery. The computer will not identify anything. Equal to pipo :'(
See my forum post #144 for you to try. it is sad to see a good device dead but as far as we know this thing is hard to brick. Â
sorry but could not find the post 144 :/
2013/12/10
Post #20 in this page
74 Guest(s)
Devices in use: Desktop (58), Phone (16)
Kaydc__
jessicapeterson
Riki111
andre92
firmwarefile
mongol
