Need help with bricked PiPO M9 pro
xocolocoxoco
Forum Posts: 54
2013/12/10 - 18:13
my tablet died. Can anyone help me fix?
darevil102
Forum Posts: 35
2013/12/10 - 18:22
Explain us the steps you did, and what's wrong. What's tour tablet model?
xocolocoxoco
Forum Posts: 54
2013/12/10 - 18:27
I have the M9 PIPO PRO 3G. And did the usual procedures. But before I tried installing kitkat http://crewrktablets.arctablet.com/?p=2343, and how not got much success, I installed this version, and the program accused mistake and now the tablet not connecting, nor the computer no longer recognizes.
darevil102
Forum Posts: 35
2013/12/10 - 18:37
Try to enter in recovery mode with esc + power several secs conected vĂ­a USB to pc and check in system administrator if drivers are ok
darevil102
Forum Posts: 35
2013/12/10 - 18:41
Did you uncheck depure USB mode before the instalation? Did you press restore buttom?
xocolocoxoco
Forum Posts: 54
2013/12/10 - 19:29
the computer does not accuse anything, I press reset, power + esc, I was already in "my computer", manage, and does not recognize the usb. Nothing, nothing, nothing. I believe it died, and the tablet is my father: '(
spaceboy1
Forum Posts: 30
2013/12/10 - 21:03
Good evening, I switched the upgrade but the tablet just opened the displays work vice versa and only goes to 1/3 of the screen, in a nutshell aposynchronistike before the upgrade I had made a mistake and put the rom from pipo m9 and thereafter created the problem, the existing solution is to fly
www.madradio107.net
spaceboy1
Forum Posts: 30
2013/12/10 - 21:17
Do not worry he was not hurt, the first spring the rockchip 1.7 and put the rom file, after connect the tablet and press power, just see a pink box at the rockchip tapped the switch rockchip and after a while you can see the box is done green, turn green when press restore from rockchips and expect to make the installation process, you just finished your turn green the bar. That is're ready, do not worry everything is done.
http://www.madradio107.net
www.madradio107.net
darevil102
Forum Posts: 35
2013/12/10 - 21:29
Quick boot is really awesome
--k0l0kaust0--
2013/12/10 - 23:13
Nice work like always, this new CF works like charm ;)
xocolocoxoco
Forum Posts: 54
2013/12/10 - 23:13
this is the problem. It no power, and the computer does not accuse you have something plugged into the usb. Have the option to manage the hardware devices or computer, and there does not appear anything.
manuelr
2013/12/11 - 00:05
@xocolocoxoco did you try all the usb port on your computer ?
I had have the same problem with 2 usb port and when i plug on the third the computer reach to connect the tab.
spaceboy1
Forum Posts: 30
2013/12/11 - 00:10
connect the tablet to another port usb and tell me lit pink BOX; PATA if not reset and esc together, ERA tells you not adb drive?
www.madradio107.net
agaam
2013/12/11 - 00:49
@xocolocoxoco USBDeview is a small utility that lists all USB devices that currently
connected to your computer, as well as all USB devices that you
previously used.
also allows you to uninstall USB devices that you previously
used, and disconnect USB devices that are currently connected to your
computer.
--k0l0kaust0--
2013/12/11 - 04:10
Can i flash it vĂ­a CWM?
Or you think its better use RKBT?
80 Guest(s)
Devices in use: Desktop (73), Phone (6), Tablet (1)
StatusQ
helloyuen
melcis
nelcis
sophiajohnson87
Brainticket
