2014/11/23
Hi Guys,
I am a newnbie here and having a problem. My Pipo M9 Pro 32gb Wifi is bricked. Don't know what happened but my friend returned it to me in this state. I don't even know if he rooted the device or tried installing the updated version and now I need help with it. I will be thankful to all of the experts here for helping me out.
The device shows pipo starting logo when plugged in and then shows the battery sign and that is all. I already had Android SDK installed on my computer and then I downloaded the required drivers for the device from the forum plus i downloaded RK_Driver Assistant and installed that. After that when i connected my device to the computer the device installed by itself and I didn't even had to use the drivers manually. The Driver assistant did its job. Now my bricked tablet is connected with my computer as ''Android ADB Interface''. I dont know if it is right driver for the device or not?
I have attached few photos of the driver installed on my computer for the device. Can somebody please confirm if it is the right one and thats how it inormally looks like as it is not showing any device name or chip name?
I have tried all the Esc+Power+Reset button procedures which I read from previous posts and Rockchip_batch_tool_v1.7 and Rk_android_tool_v1.37 both are not detecting the device as its probably not going into fastboot mode by doing the three button procedure.
What can I do now to recover my device?? Am I pressing the three buttons properly?
Help please?
There is another driver : RockChip Driver Installer : can download from here : https://mega.co.nz/#!yxYDjYDS!5M7P5lBchBdTcPIiKevmGY8IKeCLLa9ZpQu8o4Sm8sQ
ADb Driver : Super ADB Driver : https://mega.co.nz/#!noxGEJbB!NkK4n62rd11yDIWu5GfbjDvXP3qIJrhi7726m2OI3_Q
Did you follow the Power+ESC +Reset key properly?? You must do it while attaching the USB cable (PC to M9Pro) and starting the RK Batch Tool at the same time , that is why I recommend to have another person person help you with the flashing. This was told end of last year unless you are confident enough to do it alone. (while you press the 3-buttons combination (till you see the pink square appears on the RKbatchTool) somebody should help you with the "starting of RKbatch Tool and then clicking download once the pink square >>green square appears , there is no other way! It takes many , many tries to get it going.
53 Guest(s)
Devices in use: Desktop (41), Phone (12)
hellander
elousstad
relaytester
revoltown
tdomnic024
