2013/09/03
Dear friends, please, help.
Accidentally i've flashed Pipo M9 (not Pro) firmware for my M9 Pro. The tablet didn’t load.
The correct firmware, which I’ve installed after that, fixed the problem with loading of android, but did not fix problem with touch screen.
Now I have fully working android and reverted/reversed touch screen (for example, if I slide up it works left to right). I need to turn tablet’s x-axis to y-axis.
Any ideas? Thanks in advance.
I am assuming that one of you have installed a replacement screen? It is hardware related and it is very hard to correct this problems by software alone (maybe OMA can help if he has solved this problems for any users in the past before, but dont count on it, he has other things to do)
Even if you think you got the right replacement parts, it is sometimes not the exact parts. The picture below illustrates the problems based on my personal experience.The usual reference to replacement screen P/N is the main interface cable but it is paired to different interface circuit for different brand/devices/revision. You might get ALL the P/N right but lets say it for another hardware revision (might work, might not work)
107 Guest(s)
Devices in use: Desktop (104), Phone (3)
