2013/12/05
hey everybody!
just got my new m9 pro 3g+wifi yesterday. the only change i planned for was to activate the multi user. so i rooted it and changed build.prop to include fw.max_users=5.
since the following reboot it is stuck in bootloop.
I tried to boot it into recovery by pressing ESC + reset, but it did not work.
Is there a way to really reset it to factory?
Thanks alot!
Ha,ha,ha dont mess around with the build.prop next time if you dont read through the whole M9pro forum thread.! Multiuser is not just a statement in the build.prop.
There is a way to recover the the device either through reading the "softbrick recovery" section or "worst case "hardbrick recovery" thread some where here - search for it.But there is another way to recover if it is only due to the wrong build.prop . I have attached it here for you and it will also improve your gps fix at the same time I modified the GPS installation for you. But after the installation you will have to seek for your country gps. settings somewhere within the PipO forums where I have deposited.Dont ask unless your country is not not listed in my list.
To recover - First thing is your device recognised by the PC?? The attched file will install through adb to correct the build.prop and ONLY IF YOUR DEVICE IS RECOGNISED BY THE PC.Then if it is recognised all you do is to run the installGPS.bat and the build.prop for this current version (with modifications that is accepted by M9Pro) will be installed(attch the USB cable from Pc to device).Then download the attached file unzipped and run the InstallGPS.bat.
If it cannot be recognised by your PC then I suggest you do a "softbrick recovery" method (search within the PiPo forum. Then if you had done and nandroid backu I suggest you do a restore.
THIS WILL RESTORE A FRESH COPY OF "BUILD.PROP" To GET OUT OF BOOTLOOP.(Since the obvious thing is bcoz you modified the build.prop and not due anything else.) AFTER THIS I RECOMMEND YOU DO REFLASH OF YOUR ROM.
About Me  LENOVO S939 MTK6592 Vibe 2.0 - 1507,LENOVO A8-A5500 KitKat MTK8382 S029,Lenovo Tab2 A7-30HC MT8382 Lollipop,LENOVO A880 S027 MTK6582 (JB),ONDA V975m V3 AMLOGIC M802 (KitKat), PiPo M9Pro RK3188 KASTY ROM (KitKat # 407 Mod), ZENITHINK ZTPAD:C93 Duo Core AMX CM10.2_rc-3, Z102 And. 4.0.4, C91 And. 4.0.4,AIGO M60 Android 4.04 6" A13 (rooted).Lenovo A369i 4.2.2 S011 ROW
2013/12/05
thanks for your reply. this is what i tried:
turned the tablet on, there are two different splashscreens coming up subsequently. I connected the tablet via usb to pc. i can hear the typical windows "usb device recognized and ready for use" sound.
I started your .bat, see the attached screenshot. it did not help.
Tried to softbrick, but iam not able to get it into recovery mode. I tried:
- simple reset
- reset pushed/hold with power
- reset pushed/hold with esc
- reset pushed/hold with esc and power
Is there a guide you could point me to? something obvious iam missing?
Thanks!
"reset pushed/hold with esc and power" is for the hardbricked method and it for you to reflash the firmware again it doesnt do anything with the key combination (but it is good that the PC recognised the device) itself.
That method is to get it to be ready for a reflash. I guess you have to reflash the firmware again. Since you only just updated the firmware.Run the RKBatch Tool with your firmware loaded and ready on the PC and do the softbrick method to reflash. Forget about "recovery" our CWM is only good for backup and restore nothing else. Even a factory reset will not do anything since the buld.prop is considered a "factory setting" it is in the /system folder so everything else will be deleted except whats in the /system folder icluding the build.prop.
It just another reflash, dont be worried about losing data, be worried if you turn it into an expensive paperweight.
After that dont run the GPS and build.prop file I attached unless you know what to edit in the batch file to delete out the reference to install busybox and then you can use as the normal GPs HELP file.Â
zeromancer said
Cool, thanks.Â
So if "rest pushed/hold with esc and power" is hardbricking, then how do I do a softbrick?
Please read through this thread froms start to finish. You will find your answer there. ust to be sure your device is being recognised by the PC? Then if it is you are good to go if failwith the "softbrick" then try the "hardbrick" method.(IF your device is recognised by the PC)
Read this thread : http://www.arctablet.com/blog/forum/pipo-max-m9/need-help-with-bricked-pipo-m9-pro/page-2/
Read through this thread front start to finish and all the answer is here.Dont expect us to repeat the whole thing again.All the software links are there and if ever the link is down you can request for a new link thats all we can say.
 Find for the part where it is using HARDWARE key combination for getting the device to be ready for flashing somewhere in the "softbricking" recovery method.
You will have to reflash the whole firmware again, please use the latest Dec release (build 398)Â from KASTY to reflash. Please remember NOT,DO NOT to use the UPGRADE button, use RESTORE button.
2013/11/25
thanks for the quick response, I've followed all the instructions in http://www.arctablet.com/blog/forum/pipo-max-m9/need-help-with-bricked-pipo-m9-pro/page-2/, but my tablet still can not be detected by windows xp, windows 7 or windows 8
Currently Online: yuuuurtrtr
72 Guest(s)
Devices in use: Desktop (63), Phone (10)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
