cyclone voyager 2 10.1 need kitkat
Kitkat for voyager 2
cypher007
Forum Posts: 14
2014/12/22 - 01:42
I know this is a pipo forum but I've got a cyclone voyager 2 10.1, which is a pipo m9 max I think. I'm after a kitkat ROM as I'm trying to get a bit more speed out of this tablet. At the moment world of tanks blitz is unplayable. Would one of the pipo m9 max ROMs work? Or does anyone know where I can get ROM for the voyager. It seems the cyclone has very low support compared tothe m9.
2014/12/26 - 13:16
Pls provide a dmesg log.
cypher007
cypher007
Forum Posts: 14
2014/12/27 - 11:48
im a bit of a noob on this one. ive flashed roms before but logging isn't something ive done before. I tend to just use what someone else has sorted.
2014/12/27 - 15:02
Device must be rooted. Download a Terminal Emulator from Play Store. Boot the tab fresh and type:
su
dmesg >/mnt/sdcard/dmesg.txt
Upload the file here.
cypher007
cypher007
Forum Posts: 14
2014/12/28 - 01:24
Hope this is enough data. The main lag on the device seems to ocure on WiFi access. Which if play store is updating or I'm trying world of tanks means periods where the tab is non responsive.
2014/12/28 - 09:22
<5>[    0.000000] Linux version 3.0.36+ (root@lzj-desktop) #93 SMP PREEMPT Sat Jun 15 15:16:15 CST 2013
<4>[ 23.292869] Current WiFi chip is MT5931.
JK build: http://crewrktablets.arctablet.com/?p=3052
KK build: http://crewrktablets.arctablet.com/?p=2736
Kernel is already in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=741
Just change the kernel in folder rockdev/Images before flash. For the KK build use the Ceros Revolution model fix as a first guess.
cypher007
cypher007
Forum Posts: 14
2014/12/30 - 21:13
ok downloaded all of the files. how do I go about flashing the tab? sorry I need noob guides.
2014/12/31 - 09:37
See included instructions.txt & additional advise in post #6.
cypher007
Forum Posts: 14
2015/10/28 - 18:03
tried the instructions but I haven't got a volume up. so I tried power esc and power esc reset. both times I either got cwm menu up or windows found an unknown device. I have run the driver installer.
I'm running win10 x64.
so I cant run the erase idb.
cypher007
Forum Posts: 14
2015/10/29 - 17:05
ok finally got things working, had to install win 7 to an old laptop, but the rotation is messed up. ill try and find a fix. I tried the pipo m9 max fix but it didn't work.
2015/10/29 - 17:39
That's great news. Can you please describe more precisely what is messed up with the rotation, Oma may be able to help.
He usually requests to load Androsensor from Google Play-Store and post axis with highest value (9.x) for:
- tab vertical, landscape (y=)
- turn left to portrait (x=)
- turn right to portrait (x=)
- tab horizontal screen up (z=)
cypher007
Forum Posts: 14
2015/10/29 - 18:50
ive managed to fix it.
I changed the hwrotation=270 to hwrotation=0
using es file explorer.
the tab still seems almost unusable for a few mins after a cold boot. lots of lag.
76 Guest(s)
Devices in use: Desktop (52), Phone (24)
Kaka88
Donalbert
halum
BlackCero044
BlackCero04
taylordahmer
