Here is an Android 4.2.2 Jelly Bean rooted firmware for the PiPO M6 PRO (aka Max-M6pro) new tablet hardware that is equipped with a GPS. This firmware is designed for the model without 3G module, it is based a latest official update dated 2013/08/23.
( M6pro_NO 3G_update_chinese_20130823.img )
Build information:
Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #91 SMP PREEMPT Tue Aug 20 15:05:29 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20130820.103934:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU version 1.60 (free version)
- removed most Chinese and unnecessary applications, removed Certificate Center asking for product key
- NEW! kernel modules (cifs, tun, lan, serial, xpad) compiled by Oma & Crew RKTablets, thank guys!
Download: kasty-pipo-m6_pro-422-20130823-rooted4b.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a PIPO M6pro tablet to test the custom firmware.
Pinoy2dBone If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
You said you can't connect, does that apply only to your WiFI access point or any WiFI network ?
Have you flashed using Restore button in Rockchip Batch Tool ?
You can try flashing again with the Restore button, make sure you are using the right firmware for your model (M6 pro or just regular M6 version).
2013/09/22
Dear admin, I liked Your firmware. Thank you for your work. There is a request to add the firmware Multi-user support. If possible of course. Your competitor asserts that it has achieved http://www.freaktab.com/showthread.php?7229-Pipo-M6-Pro-RileyROM-1-2
Our firmware does not offer multi-user by default because I think Pipo may have good reasons not to enable it, maybe it's not stable with their current firmwares.
Still, there is an easy way to enable it with your custom firmware in a minute and just a few clicks, see here:
2013/11/22
Thanks alot for the firmware. Now my new M6pro is rooted and a bit more snappy. Ota disabled in apps/all apps/disabling firmwareupdate. Looks OK now.
There is one problem for me when trying to use the new Pipo home: It keeps asking for product key, so i cannot try Pipo home and children home. But that is not a dealbreaker. So thanks a lot.
Normally there is no product key to enter, from what I understand the tablet somehow gets verified by Pipo servers once it's going online, that's why you need to activate WiFI for this message to disappear.
I'm not yet very familiar with that weird registration process for Pipo tablets and I'll try to check again on next firmware reflash.
61 Guest(s)
Devices in use: Desktop (51), Phone (10)
