[ ROM ] Pipo M6 pro custom root Android 4.2.2 firmware (OTA_1.1.2 - 2013/12/04)
SPbMonster
46
2014/02/01 - 14:58
Here is an Android 4.2.2 Jelly Bean rooted firmware for the PiPO M6 PRO (aka Max-M6pro) for both WiFI and 3G models. This custom firmware is based on new official update version 1.1.2 dated 2013/12/04. This firmware integrates latest features such has status bar hiding and QuickBoot, see below.
(M6pro_OTA_1.1.2_update_20131204.img / M6pro_OTA_software_20131204)
Build information:
Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #211 SMP PREEMPT Thu Nov 28 16:51:58 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20131204.093214:eng/opinions-on-teclast-p90hdst-keys
  • root with latest SuperSU version 1.80 (free version)
Notes:
- Certificate Center and original PiPO launchers have been kept in the firmware
- to hide the status bar, press the last button on the right from the status bar
From the hidden status bar to show it again: slide from bottom of the screen to the top.
- we have posted a short video about the Quick Boot feature
Download: kasty-pipo-m6_pro-422-ota_112_20131204-rooted4.zip
Hi
After flashing this one to my Pipo Max-M6Pro - GPS isn't working :( Doesn't see satelites.
Is it the way it designed?
Otherwise nice build - like it!
o/
[EDITED 2 hours later]
GPS actually works!
GPS Test Tool didn't find satelites when holding tablet by the window for long time. But once I took it outside - satelites are visible.
Also checked that Google navigation works.
Sorry for false alarm!
cf67
47
2014/02/15 - 14:04
moved post to new version
Wo0ki3
48
2014/03/19 - 01:20
I just flashed my CV2 to this and im getting product activation every 5 mins, can anyone help please?
JEssicannn
Forum Posts: 252
49
2019/10/23 - 01:50
70 Guest(s)
Devices in use: Desktop (58), Phone (12)
jacksonrid
