[ ROM ] Pipo M6 pro custom root Android 4.2.2 firmware (OTA_1.1.2 - 2013/12/04)
todguy
Forum Posts: 11
31
2013/12/28 - 12:40
I've worked out how to edit the build.prop file so I can now see normal mode switch in the custom ROM by following the instructions below.
There is an issue though that the Pipo family launcher screens will then no longer fit the full screen so I switched back to HD
Now to access this file, you will need a File Manager, you can use the stock manager but I recommend using ES File Explorer. It is free on the Play Store and I will put a link below to download it.https://play.google.com/store/apps/d...roid.pop&hl=en
Once downloaded and installed, Open the application and hit Menu, then tap "Settings", this will bring you to the apps Settings Menu. Once in the Settings Menu, scroll all the way down to Root Settings. In Root Settings, "check" Root Explorerand Mount File System
Once that is done, go back to the main part of the app that shows all the folders. On that page in the TOP RIGHT you should see a little window like icon, tap that and a set of icons should appear..on the left, there will be an icon that has a star and says Favorites...hit that please. When you hit favorites, it will display the directories on your device, such as Internal Storage, SD CARD, etc. Please tap the icon that shows your device. It can also be distinguished by a "/". By tapping that we have gone into our Devices Internal Storage. The next step is to navigate the system file...it should be towards the bottom. Now enter the system file and scroll to the bottom..at the bottom there will be your build.prop. Be aware that there is also a file namedbuild.prop.bak, we are not using that file so just leave it alone..and enter the regular build.prop. Open the build.prop, the device will prompt you to ask what editor you would like to use to view/edit the build.prop...just use the ES Note Editor.
vitfain
Forum Posts: 14
32
2013/12/28 - 19:38
Tank you for use full information.could you tell me please if you have faced the GPS problem and flash player problem as it was reported here before .
todguy
Forum Posts: 11
33
2013/12/28 - 19:56
Not tested gps yet. But im installing sygic tomorrow so will let you know. I'll also check flash.
vitfain
Forum Posts: 14
34
2013/12/28 - 20:00
Thank you very mach .Will be waiting for your answer.To test flash you just need open some online video e.g YouTube
todguy
Forum Posts: 11
35
2013/12/29 - 12:42
Ive tried various flash sites and there is no issue playing flash both inline or fullscreen.
There does appear an issue with satellites though. It does see some, but when I try my sygic it says not acurate signal for navigation, even when stood outside my front door. Seems this needs fixing as I use my pipo as a satnav.. Downloaded GPS status and toolbox whch finds a number of satellites and gets fixes on a number of them. So seems GPS works but may need tweeking.
Im going to try the fix I found later on.  GPS FIX
vitfain
Forum Posts: 14
36
2013/12/29 - 15:11
Thank you for update . The GPS is important for me .So i'll be waiting for your additional test . Did you tried to drive with ? Probably it needs some time to lock on the satellites .Actually I'm using the official FW (seems it is latest -got my tablet 3 days ago ) and the GPS works fine .In case it doesn't work in rooted FW I doubt if I want to flash it . Could you tell me how other functions work ? Did you see any other problem .What your impression about this rom ?
todguy
Forum Posts: 11
37
2013/12/30 - 15:14
Im gong back to stock ROM. Since flashing with this firmware Ive had to use the reset pin 3 times to be able to start my tablet.
vitfain
Forum Posts: 14
38
2013/12/30 - 16:11
It is really sad to hear that . Meanwhile I found something that sounds good . Please see this one :
http://www.freaktab.com/showthread.php?8912-Pipo-M6-Pro-RileyROM-1-5/page1
Seems it is stable ,but need to check it out
39
2013/12/30 - 17:26
Can you describe precisely what happened to force you to reset the tablet, which app were you using ?
I used the firmware from post #1 for several days without problems.
todguy
Forum Posts: 11
40
2013/12/30 - 17:40
todguy said Im gong back to stock ROM. Since flashing with this firmware Ive had to use the reset pin 3 times to be able to start my tablet.
Can you describe precisely what happened to force you to reset the tablet, which app were you using ? I used the firmware from post #1 for several days without problems. Cheers.
The issues have been when trying to come back out of sleep/standby mode. So there wasn't any aps running
41
2013/12/30 - 17:56
Have you been using the fix below ?
  optional Deep Sleep fix for some Rockchip RK3188 based tablets ArcTools package
todguy
Forum Posts: 11
42
2013/12/30 - 20:07
I havent, but I will give it a go before going back to stock..
todguy
Forum Posts: 11
43
2013/12/31 - 12:06
I went into arctoolsapp and installed the deep sleep fix. Seems more stble now, not had to reset it yet. I thought that fix only applied to the 3g m6's as I dont have the 3G version. Seems to work though. Just need to tr and get ITV player to work now and remove all traces of root so I can get SKY Go to work.
todguy
Forum Posts: 11
44
2014/01/01 - 20:02
Spoke too soon. Had to reset twice since last post. Have now gone back to stock. Only problem is that stock is still considered as rooted by sky go, and itv player states not compatible. grrr.
45
2014/01/01 - 21:19
66 Guest(s)
Devices in use: Desktop (62), Phone (4)
jacksonrid
usdown
ibob64
kawi
vetBro
