I just tried and have no problem. Which link are you using, which error are you getting ?
Well, you should be logged since you are able to post on the forum. Can you try to log again at:
http://www.arctablet.com/blog/wp-login.php
Then retry the download page.
Not much progress yet, I still have a lot of work on ArcTools and other custom firmwares, I'll post in the forum when something is ready on overclocked kernels.
2013/12/02
oxnalt said
ROM seems to work quite well and stable. However, it seems the menu entry in the settings to change display mode is no longer available.Â
I prefer "Normal Mode", as the M6 is somewhat challenged in "HD Mode" (and I cannot really see a big difference).Â
Anyone know how to how to change to "Normal Mode" wo. this option available in the menu?
I found that thing pretty wierd too. So where has display mode gone, and how to change it?
2013/12/21
This custom Kasty rom is faster and smoother than stock as stock was lagging a bit.... Now my only problem that I incounter and its very annoying has to do with Flash Player.... When I try to watch a movie online it starts playing without me doing anything normaly but the moment I "Maximize" the video to full screen it goes dark and it crashes the browser by freezing it a few seconds but then nothing happens when I click other tabs or links... its just freezed... No matter what browser I use, Chrome, Firefox, etc... I can't watch online movies at full screen! Seems your rom can't support Flash that well..
Any clues? Has anybody has this problem as well...Â
I'll install the stock rom which dates 12.09.2013 and root it through CWM via SuperUser Pro... and test Flash becuase from I can remember when I first got my M6, flash was working good in stock at full screen!
SwInDaMix said
For missing display mode option (HD or Normal), people on 4pda found a solution:in build.prop find ro.rk.resolution_enable=false and change it to true.
How do I edit this?
P.S most of the widgets in the family launcher have been removed. Is there any way I can get some back?
65 Guest(s)
Devices in use: Desktop (61), Phone (4)
jacksonrid
usdown
ibob64
kawi
vetBro
