Here is an Android 4.2.2 Jelly Bean rooted firmware for the PiPO M6 PRO (aka Max-M6pro) for both WiFI and 3G models. This custom firmware is based on new official update version 1.1.2 dated 2013/12/04. This firmware integrates latest features such has status bar hiding and QuickBoot, see below.
(M6pro_OTA_1.1.2_update_20131204.img /Â M6pro_OTA_software_20131204)
Build information:
Kernel:Â Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #211 SMP PREEMPT Thu Nov 28 16:51:58 CST 2013
Android 4.2.2 JB:Â rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20131204.093214:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU version 1.80 (free version)
- increased space for applications (/data partition) to 4 GB
- kernel modules (cifs, tun, lan, serial, xpad) compiled by Oma &Â Crew RKTablets, thank guys!
- optional ClockworkMod (CWM) Recovery easy install package
- NEW! optional Deep Sleep fix for some Rockchip RK3188 based tablets ArcTools package
Notes:Â
-Â Certificate Center and original PiPO launchers have been kept in the firmware
- to hide the status bar, press the last button on the right from the status bar
From the hidden status bar to show it again: slide from bottom of the screen to the top.
- we have posted a short video about the Quick Boot feature
Download:Â kasty-pipo-m6_pro-422-ota_112_20131204-rooted4.zip
Kikko2000, AnnaBanana, --k0l0kaust0--, R4cOOn, kajdum, aceventuracz If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/09/20
the deep sleep fix is NO MORE necessary, we have found a libril file that is able to enable deep sleep also for 3G models.
take a look here on post #292:
http://www.freaktab.com/showthread.php?7871-Binary-patched-kernels-for-Pipo-models/page15
The following users say thank you to giouncino for this useful post:
mihail nikeshin, jamicI believe the fix in your link is similar to the one we have included in our ArcTools package.
We prefer to offer the fix as an option (for the M6 pro and other RK3188 tablets) so users can choose if they want to use it or prefer keeping the default file from the manufacturer. There should be no need to use a fix if the tablet doesn't show Deep Sleep problems.Â
2013/09/20
Why someone should use the original file?
On 3G models deep sleep NEVER works with original libril file
On wifi only models this file is completely useless, so a change of that file doesn't make any collateral effect.
I think that the original file is a BIG problem and completely useless. But this is my personal opinion...
2013/12/02
If I previously installed kasty-pipo-m6_pro-422-ota_107_20131015-rooted4, can I update to this one using CWM, not Rockchip Batch Tool?
SwInDaMix,
I'm afraid not, you'll have to flash with Rockchip Batch Tool.
We're are working on converting future updates in CWM format for easier upgrades.
SwInDaMix If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/04/15
Thank you for the new firmware it appears to work really well. The one thing I don’t get is the Deep Sleep fix for some Rockchip RK3188 based tablets ArcTools package option in the Arctools app, am I missing something? Thanks for any advice.
As post #1 mentions, this update should work for both WiFI and 3G models.
2013/11/13
ROM seems to work quite well and stable. However, it seems the menu entry in the settings to change display mode is no longer available.
I prefer "Normal Mode", as the M6 is somewhat challenged in "HD Mode" (and I cannot really see a big difference).Â
Anyone know how to how to change to "Normal Mode" wo. this option available in the menu?
75 Guest(s)
Devices in use: Desktop (66), Phone (7), Tablet (2)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
