[ ROM ] Pipo M6 pro custom root Android 4.2.2 firmware (OTA_1.0.7 - 2013/10/15)
Freaka87
Sydney, Australia
Forum Posts: 22
76
2013/11/13 - 23:49
Freaka87 said
I have just tried using the RK Android Tool to update my kernel & I'm having a problem with the tool recognizing it when it is in boot-loader mode after I press switch. Rockchip Batch Tool has no problems recongnising  that it is in boot-loader mode though. Any idea's?
Can anyone help me with my problem that is at hand? I would really like to flash my kernel.
connectandroid
77
2013/11/15 - 02:42
i had same problem had to do it a few times before it recognised
Now i have my own problem after flashing to this thread's first post ROM, for M6 Pro when it goes to sleep over night, it doesn't turn back on anymore - hitting power button does nothing. Only way to start is pin the reset hole on back of the unit ? Anyone got ideas ?
PIPO M6 Pro Wifi
Freaka87
Sydney, Australia
Forum Posts: 22
78
2013/11/15 - 04:54
connectandroid said
Well I have tried 3 different computers running XP, Vista x64 & Win7 x64. Still no success. Man this sucks hard!
Freaka87
Sydney, Australia
Forum Posts: 22
79
2013/11/15 - 04:56
I have tried it on three different computers running three different operating systems. Same problem.
Disregard above post.
valerima
80
2013/11/18 - 07:32
Dears, today is a month when this Kasty ROM was released.
Anyone can report how long use his ROM and if soemthing was OK, or some problems were noticed.
...What about battery stats so far? Any freezes?
micmicmic
81
2013/11/18 - 21:01
Hello
I´m new in this forum. I will receive my Pipo M6 Pro 3G 16G in 2 weeks (it´s already delivered but i´m outside and i can´t go home to take it until two weeks.. Grrrr).
I´m sure that the tablet will come with old firmware and the first thing i will have to do is updating with last OTA pipo firmware. I think that i already have the program to do it (RK tool 1.7) and the firmware (OTA.15.10.13) from Pipo. Wait and see...
I have seen a lot of things on internet but i´m very confuse on what i have to do exactly. Some people are speeking about flash Rom (riley and kasty...) but i don´t realy understand how it works. We can´t install apps with the oficial firmware or what? If i install one of these rom, i can go back to the oficial firmware if it doesn´t work...?
I have an iphone 4 and jailbreak and it´s just easier to understand and only with one program you can do everything but with android (it´s my first item with this SO) it´s just like jungle for me....
Someone can try to give me informations about Roms, SuperUser and just a procedure of "how to install all free apps for beginners".
Thanks a lot for all your works. Best regards
micmicmic
82
2013/11/18 - 21:05
An other thing : i´m trying to take the file (kasty-pipo-m6_pro-422-ota_107_20131015-rooted4.zip) but it´s just to slow :( ((  less than 1kB/s and it´s not my internet access.... Do you have an other link or torrent to download this file ?
Thanks a lot
It´s Ok. I just had some problems of internet connections. Sorry for the first message. i already download the file. Waiting for explications... please.
Bye
mattiesrag
Forum Posts: 39
Thanks Received: 5
83
2013/11/20 - 08:44
Hi all, I've just purchased a PIPO M6 Pro 3G tablet for $195 with free UPS shipping. Outstanding value!
Here's the link for all interested parties.
http://www.dhgate.com/wholesale/PIPO...22.html#search
Kind regards
giouncino
Forum Posts: 18
Thanks Received: 6
84
2013/11/20 - 22:27
Kind regards
You're writing this also on other forums...
Are you paid by them that you make this kind of promotion??
mattiesrag
Forum Posts: 39
Thanks Received: 5
85
2013/11/20 - 22:41
How the hell would I be paid by a Chinese web-store. I'm merely passing on the info to anyone wanting a good deal. If you don't want it don't get it.
giouncino
Forum Posts: 18
Thanks Received: 6
86
2013/11/21 - 11:33
This is a FIRMWARE thread, so it is supposed that we already have this tablet....
In any case it was only a question.... It is not necessary that you feel so angry...
vandish
87
2013/11/21 - 22:26
Hi!!!
Thanks you for all works!! It is great
And i have a question, how can I change this "increased space for applications (/data partition) to 4 GB", if i want 8gb or 16gb for example?
Thank you again
P.D: I installed this rom, i have a problem , pipo laucher always ask me product license, how do i solve it?
Pascalun
88
2013/11/23 - 19:18
Hi everyone,
launcher ask me too my licencse number.
What can we do ?
rruzsi
89
2013/11/26 - 13:04
tfcw2000 said
Nope...Kasty ROM and thats it.
Some other apps like newspaper readers, some games, Antutu benchmark,
But no tools regarding to control anything.(like battery,cpu,....)
I think that the 3G module prevent the tablet to go into deepsleep.
Thats a ROM issue and i hope for you it will be solved with a new ROM...
Hi everyone!
I am nearly noobe to this all You doing, firstly Big thank for Your works, but I would like to share with You my experience, maybe helpful. When i got my Pipo m6 pro maybe 3 weeks ago, i read your forums so i decided to flash my tab, with, rileyrom 1.3a , before i did a backup(accidentaly on builtin card) a noticed Deep sleep is working if i removed the sim card, thats it. Was enough. After flashing rileyrom and recognize that deep sleep cant work, i would want to flash back my original fw, but i lost it, (builtin backup Surprised ). Sadly i can remember only this data from my original version, 2013.08.24 #91, sorry, i think this firmware was good by the deep sleep issue.
Sorry for my long and bad english, hope i can help and proof can do something with this information.
Best regards!
rruzsi
90
2013/11/26 - 23:56
Please someone look my post #89, I would very curios!
Thanks!
Currently Online: run2droi
82 Guest(s)
Devices in use: Desktop (54), Phone (29)
roro17920
anbague
run2droi
iceman14
AnyFox
BAMHAB82
