[ ROM ] Pipo M6 pro custom root Android 4.2.2 firmware (OTA_1.0.7 - 2013/10/15)
tfcw2000
31
2013/10/30 - 17:45
Flashed ROM : all ok
But : With Arctools, I try to install the default apps (Youtube,maps,...) but even after restart, they simply do not appear.
Any idea ?
Regards
Pipo Max M6 Pro
Yarvik Tab461
Thanks Received: 3171
32
2013/10/30 - 17:57
tfcw2000, the feature you just tried is made for old Archos tablets, it won't work on other models.
tfcw2000
33
2013/10/30 - 17:59
aahh ok.
Thanks !
Is there a way then to install the youtube app ?
All is ok with this rom ! I really appreciate the hard work.
I too am intersted in the overclock feature. Just let me know when I have to test something.
Regards
Pipo Max M6 Pro
Yarvik Tab461
34
2013/10/30 - 18:03
Youtube can be installed just like any other application from Google Play Store.
tfcw2000
35
2013/10/30 - 18:14
euhm.... its simply not there ? Nowhere to be found if searched  : youtube within playstore
I still have an older youtube apk somewhere on a drive...
Pipo Max M6 Pro
Yarvik Tab461
Philooo
tfcw2000
37
2013/10/30 - 20:00
Thanks ! But why isn't this listed on the tablet itself in the playstore ?
Mhm...same thing for adaway or adblocker...seems they are no longer availble ?
**EDIT**
mhm..ok, just noticed something : My language is set to Nederlands(België) wich is correct ofcourse but then when I try to download/install the youtube app, the store is telling me that this is not availble for my country/ or my device is not compatible for this app due to selected country for this device.
I'm going to wipe everything and start over again... will set country to US and see what happens, or is there a way out ?
**END EDIT**
Nevertheless this rom is really good...Antutu score in HD mode : 18189
Battery related :
I left my tablet with 61% remaining in battery and left it for about 1h30'.
On return the battery was at : 61% . So battery drain is close to 0 when in stand-by.(or deep sleep, althow how can i tell if the tablet went to deep sleep mode ?)
I'll test again overnight and will post results tomorrow
Please keep in mind that i have the wifi only version, not the 3G version!
Pipo Max M6 Pro
Yarvik Tab461
David
38
2013/10/30 - 23:06
guidoaush said
Thanks for this perfect ROM.
Pipo M6 pro / 3G
All features works fine !
It is the first rom that works with multiuser accounts.
edit build.prop   :
fw.max_users=5
I work with 5 accounts. ( My wife, 3 childs and I )   perfect :-)
guidoaush,
could you please tell us more on this?
I tried editing build.prop and adding the line you mention (there was no fw.max_users before, so I added one line) I saved the file and rebooted but without success. Any steps I missed?
Thanks,
Pipo Max M6 Pro Wifi 32 GB
39
2013/10/30 - 23:23
David
edgertop
40
2013/10/31 - 14:29
Hi
Just flashed the custome firmware and the PIPO family launcher always asks for a licence key. As soon as you connect to the network an OTA upgrade is reported to version 1.0.8 if you download and install. The installation fails and you have to reset the tablet via the reset on the back. Next time it boots it prompts again for the 1.0.8 download. Not sure if you have got any ideas. I am downloading the stock firmware at the moment and plan to flash back to that for now.
Peggy_zhou
Forum Posts: 15
41
2013/11/01 - 14:07
My experience is that notes are not always enough for everyone and it's always good to have some extra protection when possible Wink
Thank you! I am agree with you. My M6pro is an excellent, even perfect tablet now!
Freaka87
Sydney, Australia
Forum Posts: 22
42
2013/11/01 - 14:45
If you know how to flash a tablet then you know how to disable OTA update manually.
giouncino
Forum Posts: 18
Thanks Received: 6
43
2013/11/03 - 21:49
You can use CPU spy or battery stat pro to see if the tablet goes in deep sleep mode.
As far as I know even this kasty firmware does not support deep sleep, unfortunately...(tested personally)
If you leave the tablet in stand-by overnight, in the morning you will see a battery drain of at least 10-15%. Other tablets with deep sleep active drains 0-1%...So the difference is HUGE!
This is still a bad issue.
What I would like to see AS SOON AS POSSIBLE for the M6pro is the multi-window feature and the deep sleep function active. I'm continuing asking this to pipo customer care. If someone of you can ask it too, we will probably have more chances to see these features for our good tablet.
**EDIT**
**END EDIT**
Battery related :
tfcw2000
44
2013/11/04 - 20:10
Strange... i think that the Kasty ROM does go in deep sleep mode :
battok_zpsf1e207a0.pngImage Enlarger
I will however install CPU spy for you and will post results tomorrow.
I started with a fully charged battery at +/- 8pm. Did some benchmarks and then watched a movie on the talbet. I left my tablet yesterday at +/- 11pm and woke the tablet today at +/- 6pm and the screenshot is the result. So....for me battery drain is nearly zero during night.
BUT : My tablet is the WIFI ONLY version. I do not have the 3G version as I understand that the 3G module is the battery drain problem.
Pipo Max M6 Pro
Yarvik Tab461
tfcw2000
45
2013/11/04 - 22:15
Proof that deep sleep does work on Kasty ROM, M6Pro Wifi only version !
proof deep sleepImage Enlarger
Pipo Max M6 Pro
Yarvik Tab461
63 Guest(s)
Devices in use: Desktop (58), Phone (5)
swan12
heftpflaster
