[ ROM ] Pipo M6 pro custom root Android 4.2.2 firmware (OTA_1.0.7 - 2013/10/15)
Mr-Kev
Forum Posts: 21
2013/10/21 - 14:14
Cannot flash this rom the connected devices light on the rockchip batch tool is pink and will not go green when i try to flash it turns off my tablet and i have to do a pinhole reset? what the hell is going on...HELP (please).
Mr-Kev
Forum Posts: 21
2013/10/21 - 21:19
I have completed all the steps upto flashing the rom Rockchip batch tool is loaded with new fw and when i plug in my pipo the first light #1 turns pink then i press switch and i get "switch done success <1> fail<1> and then i need to restart my tablet once i unplug it from the pc ? And the cycle goes on ???
Freaka87
Sydney, Australia
Forum Posts: 22
2013/10/22 - 03:21
If you are having this many problems with it & have no idea how to repair it, send it back.
I haven't experienced this problem so I couldn't help you.
Freaka87
Sydney, Australia
Forum Posts: 22
2013/10/22 - 10:13
Is there a way to use a wireless xbox 360 dongle on this tablet with this firmware? ArcTools has the drivers for it but for RK3066 only. Anything available for the RK3188?
Thanks Received: 3171
2013/10/22 - 12:24
Freaka87,
Kernel modules for xbox 360 dongle support should be included in our custom firmware. I'll check why ArcTools is not finding/loading them.
Freaka87
Sydney, Australia
Forum Posts: 22
2013/10/22 - 12:32
I tried using the RK3066 drivers but it was very glitchy & would only work when it wanted to.
Philooo
2013/10/24 - 18:59
I'd like to know if this firmware is wifi, 3G or both ?
By the way, in the Pipo.com BBS (thanks Google Translate, but the post is in chinese and part in english) they say for the last firmware :
1 Support external TF card, & in exFAT format when USB drive connected
2 Added feature for camera (& lighting effect)
3 Newly added support for H265 media format
4 Upgrade new launcher interface
5 After this OTA upgrade, future upgrade can be done via Wifi to update the new firmware over the air (i.e. no need to connect to computer)
http://www.pipo.cn/bbs/forum.php?mod=redirect&goto=findpost&ptid=5896&pid=29582&fromuid=2608
Thanks for your answer, and your work
Philippe
2013/10/24 - 19:24
Thanks for the revision history, I'll add it to post #1.
On the PiPO M9 pro, the OTA firmware published in October has been confirmed to work on both WiFI and 3G models, it's possibility the same here.
Philooo
2013/10/26 - 02:07
Thanks a lot for this ROM. Easy to install, and work find (after 30 minutes testing ...).
The OTA ask almost immediately for a firmware update, that I accepted (without risk, RochshipTool was still open). But the upgrade (something like pinyin.apr) aborted, because he did not find the file to flash.
Just one remark : when I try to open Pipo Launcher, a product license number is required.
Philippe
valerima
2013/10/27 - 07:57
Thanks a lot for this ROM. Easy to install, and work find (after 30 minutes testing ...). The OTA ask almost immediately for a firmware update, that I accepted (without risk, RochshipTool was still open). But the upgrade (something like pinyin.apr) aborted, because he did not find the file to flash. Just one remark : when I try to open Pipo Launcher, a product license number is required. Philippe
anyone can report about battery life of this build?
David
2013/10/29 - 14:22
Thanks for this ROM.
After 2 days testing, it is stable and faster than original Pipo ROM from september (from 16100 to 18000 in Antutu), but there are still some slowdowns while entering text for example...
Got the same problem with serial number for pipo launcher, so I am using the other one.
Any chances that pipo increase the rk3188 frequency to 1.8 GHz by firmware soon?
Pipo Max M6 Pro Wifi 32 GB
Freaka87
Sydney, Australia
Forum Posts: 22
2013/10/29 - 15:07
Increasing the CPU to 1.8Ghz would make this one killer tablet! Any progress on this Admin? Thanks!
2013/10/29 - 15:13
I have some interesting leads, based on the existing overclocked kernel for the Cube U30GT2, I'll post when something is ready to be tested (at your own risk !)
Freaka87
guidoaush
2013/10/30 - 12:31
Thanks for this perfect ROM.
Pipo M6 pro / 3G
All features works fine !
It is the first rom that works with multiuser accounts.
edit build.prop   :
fw.max_users=5
I work with 5 accounts. ( My wife, 3 childs and I )   perfect :-)
valerima
2013/10/30 - 13:15
Dear what batter life at build, please?
previously I have seen reports that battery at kasty fw drains quite fast?
97 Guest(s)
Devices in use: Desktop (90), Phone (7)
swan12
heftpflaster
