[ ROM ] Pipo M6 pro custom root Android 4.2.2 firmware (v1.1.3 - 2013/12/09)
Thanks Received: 3177
2014/01/01 - 21:15
Here is an Android 4.2.2 Jelly Bean rooted firmware for the PiPO M6 PRO (aka Max-M6pro) for both WiFI and 3G models. This custom firmware is based on new PiPO official update version 1.1.3 dated 2013/12/09, published 2013/12/31.
(M6pro_1.1.3_update_20131209.img / M6pro_3G&WiFi_chinese version_update_20131209)
Build information:
Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #213 SMP PREEMPT Mon Dec 9 12:28:51 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20131209.122904:eng/opinions-on-teclast-p90hdst-keys
  • root with latest SuperSU version 1.86 (free version)
  • optional ClockworkMod (CWM) Recovery easy install package
  • optional Deep Sleep fix for some Rockchip RK3188 based tablets ArcTools package (should not be necessary as Deep Sleep issue is expected to be fixed in this update)
Notes:
- Certificate Center and original PiPO launchers have been kept in the firmware
- to hide the status bar, press the last button on the right from the status bar
From the hidden status bar to show it again: slide from bottom of the screen to the top.
Pipo_M9_pro_firmware_20131120_hide_bar2.pngImage Enlarger
- we have posted a short video about the Quick Boot feature
Download: kasty-pipo-m6_pro-422-113_20131209-rooted4.zip
dudu.amorim, letuss, fjclmovil
dudu.amorim
2014/01/02 - 02:40
Work fine, thanks!
The following users say thank you to dudu.amorim for this useful post:
mihail nikeshin, manolaarr
vitfain
Forum Posts: 14
2014/01/02 - 15:11
Could you tell me if you have tested the GPS  as well ,how it works in this FW ?
The following users say thank you to vitfain for this useful post:
mihail nikeshin
dudu.amorim
2014/01/02 - 16:41
The GPS is working well.
mihail nikeshin
bittobyte
2014/01/03 - 18:00
For wich countries is GPS setted? I'm in Europe zone - Italy.
vitfain
Forum Posts: 14
2014/01/03 - 19:43
Hello guys. I'm going to upgrade the FW first time .And upgrade procedure in PIPO site has some confusing information. I mean they tell it need enter the device to upgrae mode by pressing Volume + and ESC keys before upgrade.But if I follow the link to video ,guy tells nothing about it . Could someone explain what exactly the procedure???
vitfain
Forum Posts: 14
2014/01/03 - 19:46
Thank you very much ! As far as I understand you tested it in Israel ,right ?How about browsing ,is it fast ?
gwn_rick101
2014/01/05 - 13:28
hi, great firmware works great. Is is running in hd mode? and how can i switch it off? this option is gone from the display options.
thnks
2014/01/05 - 21:13
sany
2014/01/11 - 12:13
Dear Admin, Thank you very much for your hard work. I have installed this rom on my pipo m6 pro. Its runs smoothly without any problem, but 'I'm having aa problem with pipo launcher, it keep asking for a serial number. I connected to the internet and cancelled it many times but it still asking for the selial number. I've been using this tablet for a long time and I'm used to the pipo launcher. Is there any other way you can fix it ? because I love pipo launcher. Thank you !
kuperrr
2014/01/12 - 00:00
Hi. I installed this firmware. VPN not working. No tun.ko?
kuperrr
2014/01/12 - 00:09
busybox lsmod:
wlan
vpu_service
rk2_ipp
mali
umprk30xxnand_ko
2014/01/12 - 01:12
kuperrr,
The mentioned kernel modules are included in the firmware but not loaded at boot.
You should be able to load them thru a terminal/adb command, using an init.d script or ArcTools (for some of the modules)
kuperrr
2014/01/12 - 07:58
Thank you very much
cf67
2014/02/15 - 14:11
Hello, I have a M6 Pro, your rom is perfect but I have a bigger problem, maybe I could find a solution here.
The on/off button is broken. There's no way to make it work. As soon as I flash any rom it starts up regularly as it reboots. If it goes off for any reason it doesn't start up anymore and I have to flash it once again. Since it's a lot annoying I hoped to find a rom that if you plug in the charger it starts up. But none I tried does so.
For the wake up of the screen I have no problem since I use "Auto Screen On"
44 Guest(s)
Devices in use: Desktop (41), Phone (3)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
