[ ROM ] Pipo M6 pro Android 4.4.2 KitKat custom root firmware (2014/01/03)
pavelu
2014/01/13 - 16:49
 Hi
I got few days ago a M6pro with 4.2.2. It looks fine and behaves not that bad, but looks it goes slow many times. I haven't installed any app yet and is already using 1Gb RAM memory, is that normal? I guess not. Do you know what could it be? Maybe that PipoLaunch?
The point is I would like to upgrade  it to this 4.4.2. Do you think it will improve the slow behaviour? And somebody posted some issues, are they really issues or just and isolated case? What do you recommend me to do?
Million thanks in advance for your support!!!
vitfain
Forum Posts: 14
2014/01/14 - 10:13
Hello .I got my Pipo (wi-fi 32G pro version ) a month ago and was exactly in same situation . In the beginning all went well but the Wi-fi was slow ,what I mean the browsing was slow . But it was about the router encryption.The second problem that I faced it is deep sleep mode .Sometimes after long not using   I haven't been able to wake the device up . Yesterday I flashed my Pipo ,but with other Rom. I don't want  make any advertisement here hence I can't provide you the name and the link . If you want to discuss it you can skype me "vitfain" of write to email vitfain@gmail.com
spidermagicat
2014/01/14 - 18:32
A very nice ROM.
I've had a small number of issues.
1. GPS not working
2. Auto Brightness not working
3. Camera auto flash missing
4. Will not stay off if plugged into charger
Apparently the alarm should activate the tablet even if it's off but I didn't try it before so I don't know, if it's meant to do that, then there's 5.
Everything else seems pretty stable.
Unfortunately I need GPS tomorrow so I can't stick with it and help troubleshoot but the effort is very much appreciated. I'll look forward to updates :-)
pavelu
2014/01/15 - 17:37
In mine installation Google calendars and contacts are not present even though it is connected with my account and the rest of cloud stuff shows up.
2014/01/15 - 17:53
pavelu,
I have prepared a fix for that problem, it's working on the M9 pro and Ifive X2, I'll do it for the M6 pro soon.
zigerniger
zigerniger
2014/01/15 - 20:32
THX
2014/01/15 - 23:38
I have published the update, see post #1.
  • Edit 2014/01/15: updated SuperSU to latest version 1.89 (free version)
  • Edit 2014/01/15: added Google Experience Launcher (GEL) in addition to PiPO's stock launcher
  • Edit 2014/01/15: use optional package to fix broken apps (Contacts/People and Calendar sync)
pavelu
janaarnoutfaber
2014/01/20 - 08:56
I have the same issues as spidermagicat , i think.
Also I have put a large number of music files on the storage and some of them are indexed with all titles having  'rkutf8'  appended at the beginnig ?
no auto brightness
no gps........ I will try more.
Very fast ... it feels very fast in everything I do :)
pavelu
2014/01/22 - 07:57
I'm not sure whether the following system error is related to the release but here it is:
In ArcTools I installed "clocked CPU something" from the menu (dated 08/2013) and after a restart I got stuck on ArcTablet logo. Yes it was stupid to try this without backup and it was also meant for older version 4.2 I guess.
After that I installed this firmware again with Android 4.4.2 and after that I installed CWM from ArcTools menu.In CWM recovery however I get errors like E:Can't mount ... and quite few items are listed (log, cache, etc.).
The point is no memory is mounted and I can't do a backup in CWM.
Can anyone confirm whether it is related to the release and regardless of this: how to fix it? I did not yet try installing the firmware again. I have seen some manual CWM installation guides. Would that help?
Thanks,
Pavel
stassen
Sweden
Forum Posts: 62
Thanks Received: 43
2014/01/30 - 11:08
admin: can you fix Enable multi-user on this rom two? i can test it!
2014/01/30 - 11:26
I have a lot of other firmwares in the works, I'll eventually make the multi-user fix for the M6 pro if there is enough demand, let's say at least 4 request for it.
Geniustyle
2014/01/30 - 15:24
you will manage to solve the problem of gps that does not work? and also to recharge the battery that stays on?
egonzalez
2014/01/31 - 13:57
excelente versión, gracias, quedo a la espera de la actualización para usar el gps.
excellent version, thanks, I look forward to the update to use the gps.
bossito
2014/01/31 - 18:53
I am interested :) it would be great to have.
Please please please please :)
ivp71
2014/02/02 - 08:34
Known when the GPS will work?
70 Guest(s)
Devices in use: Desktop (63), Phone (7)
