(M6_3G&WiFi_update_20131227.img / M6_3G&WiFi_chinese version_update_20131227)
Build information:
Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #217 SMP PREEMPT Fri Dec 27 12:10:08 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20131227.121238:eng/opinions-on-teclast-p90hdst-keys
Manufacturer's revision history (translated from Chinese) :
Update: 3G and WiFi version GM, optimize system stability
- root with latest SuperSU version 1.86 (free version)
- increased space for applications (/data partition) to 4 GB
- kernel modules (cifs, tun, lan, serial, xpad) compiled by Oma &Â Crew RKTablets, thank guys!
- optional ClockworkMod (CWM) Recovery easy install package
- NEW! optional Deep Sleep fix for some Rockchip RK3188 based tablets ArcTools package
Notes:Â
-Â Certificate Center and original PiPO launchers have been kept in the firmware
- to hide the status bar, press the last button on the right from the status bar
From the hidden status bar to show it again: slide from bottom of the screen to the top.
- we have posted a short video about the Quick Boot feature
Download: kasty-pipo-m6-422-20131227-rooted4.zip
Jammy007, Balrog, eurnun04, algenist If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/08/04
Hi there,
Great job. I 've a question. Is it possible to use a OC Kernel like Kernel_cpu1704_gpu660_ddr720 v4 from other post with this firmware?
Thanks in advance
Edit 2013/01/06: I discovered ArcTools into my tablet. It's awesome. The Stock kernel and OC kernel v4 (2013/08/14) will be updated to a newer version?
The following users say thank you to desUBIKado for this useful post:
manolaarr
2013/08/04
Thanks a lot for your fast response.
kernel_cpu1704_gpu660_ddr800_v4.1_(kasty-pipo-m6-422-20131227-rooted4).img is for use with Rockchip Batch Tool version 1.7?
2013/04/28
No it isn't. The Rockchip Batch Tool only flashes whole roms.
The fastest way is to use a cwm-version:
- first you need the custom cwm: http://www.arctablet.com/blog/forum/arctools-application/clockworkmod-cwm-recovery-easy-install-on-rk3066-and-rk3188-devices/
- after you have a working custom cwm download a cwm-version of the kernel (either v4 or v4.1) and save it on your sd-card.
- reboot into recovery
- select "install zip from sdcard" and choose the downloaded cwm-version of the kernel
The other versions are used to flash with other tools or for the admin if he wants to add the kernels into Arc Tools.
I can add the kernels in ArcTools like I did before but I rely on users feedback to make sure these work fine and ideally find the best match in term of performance/stability/battery life, if it case be enhanced compared to stock kernel.
So feedback is welcomeÂ
2013/10/22
First of all, thanks for the awesome ROM. You do great work and it's much appreciated! As usual, flashing this was easy and everything seems to work perfectly except one thing. I have no sound. Not sure if I should just re-flash the ROM or if there is something else I can look for, but I'd appreciate any tips you might have.
The ROM is otherwise super smooth and works flawlessly.
2014/05/16
I want to be kasty-Pipo-M6-422-20131227-rooted4.zip Pipo M6 but it fails.
Installed CWM v.6.0.3.1
When installed, this display:
- Installing: / sdcard/kasty-Pipo-M6-422-20131227-rooted4.zip
Finding update package ...
Opening Update package ...
Intalling update ...
Installation aborted.
Sdcard and external_sd also writes out.
When I turn on the check (signature check:enabled) says this:
E:signaure verification failed
I've downloaded the package several times but always type this out.
What could be the problem?
45 Guest(s)
Devices in use: Desktop (40), Phone (5)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
