[ ROM ] Pipo M6 rooted Android 4.2.2 custom firmware (release 2013/08/14)
2013/08/21 - 18:31
Here is an Android 4.2.2 Jelly Bean rooted firmware for the PIPO M6 (model without 3G) tablet based on latest official update from Pipo released 2013/08/14
( update_M6_NO 3G_20130814.img )
Build information:
Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #81 SMP PREEMPT Wed Aug 14 14:33:30 CST 2013
Android 4.2.2 JB: rk30sdk-eng 4.2.2 JDQ39 eng.root.20130814.154159 test-keys
  • root with latest SuperSU version 1.51 (free version)
  • removed most Chinese and unnecessary applications, removed Certificate Center asking for product key
Download: kasty-pipo-m6-422-20130814-rooted4.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a PIPO M6 tablet to test the custom firmware.
cryolynx, pedrova, Landor, clckristians, Balrog
walterLTrapa
2013/08/22 - 23:23
Can I ask why not use the Upgrade button?
Have they only changed the Android Partition? No new kernel?
Just asking because I took a look to the restore/upgrade scripts
Thank you
The following users say thank you to walterLTrapa for this useful post:
blacais, mihail nikeshin
Thanks Received: 264
2013/08/23 - 11:38
We advise the people to use the Restore option when they come from a 2GB version firmware because corruption data and bootloops can appear otherwise.
You can use the upgrade option on your own risk.
The increased partition size is made by admin, not by Pipo
mihail nikeshin
b_force
2013/08/26 - 22:50
Is it also possible to overclock to 1.8GHz with this ROM?
Do you have an indication when version 4.3 will arrive?
Dvalin21
Midwest City, OK
Forum Posts: 41
Thanks Received: 10
2013/08/26 - 23:33
Arc,
   Its been while, I don't know if you remember me or not but I was have over on the Onda 972 thread.  Anyway, I'm looking at picking up this tablet.  I believe it to better fit my needs than the 9pro.  Especially with the bigger battery life that it has.  Anyway, I was hoping that someone could do a side by side comparison of the two before I made my final decision. Anyway, if you see anything like that let me know.  Thanks.
2013/08/26 - 23:40
b_force, to my knowledge no vendor currently offer 1.8 GHz on their RK3188 tablets.
Same for Android 4.3, it hasn't yet landed in Rockchip RK3188 devices.
Dvalin21, I can't help much with the comparison, the only Pipo model I own is an old S1.
b_force
2013/08/27 - 00:14
b_force, to my knowledge no vendor currently offer 1.8 GHz on their RK3188 tablets. Same for Android 4.3, it hasn't yet landed in Rockchip RK3188 devices.
OK, But can I use another ROM to get to the 1.8GHz, or are there to many differences?
@Dvalin21
My colleague owns the Onda 972 I think (or it was the 973...)
Anyhow, the sound is really bad!
I think all other things are not really different.
The RK3188 is just a little faster than the A31.
On the other hand the A31's GPU is better.
Really depends on your needs.
boudersa
2013/12/18 - 02:15
think,s
2013/12/30 - 15:09
Currently Online: roro17920
75 Guest(s)
Devices in use: Desktop (67), Phone (9)
roro17920
anbague
run2droi
iceman14
AnyFox
BAMHAB82
