[ ROM ] Pipo M6 rooted Android 4.2.2 firmware (release 2013/05/30)
dgaid
Forum Posts: 40
Thanks Received: 9
2013/06/22 - 22:19
I could not find any multiuser options, but I did not want it.
Dgaid
dgaid
Forum Posts: 40
Thanks Received: 9
2013/06/24 - 09:51
Installed a lot of applications, everything works fine.
I am surprised that not so many Pipo M6 users have found this forum.
Dgaid
fakeplasticme
2013/06/24 - 09:59
Yeah I agree, we need to build it up
 anyone recommend a custom Rom for my m6? It needs to have android 4.2 and have multiple users enabled, wanna set up a separate user for my wife.
2013/06/24 - 10:08
You have a custom firmware in post #1, multi-user support will be added soon.
In the meantime you can also add it on your own like described here:
http://www.arctablet.com/blog/forum/cube-u30gt2/cube-u30gt2-android-4-2-2-custom-root-firmware-beta-version-20130425/#p21808
matnl
fakeplasticme
2013/06/24 - 10:18
Thanks I will take a look
bunneh
2013/06/24 - 10:27
New firmware version is released, any plans to update?
2013/06/24 - 10:38
Sure, a custom firmware update should be published today.
fakeplasticme, bunneh
2013/06/24 - 14:34
dgaid
Forum Posts: 40
Thanks Received: 9
2013/06/24 - 17:30
What is the difference in this updated firmware?
Is it possible to install it and not to loose all the applications and settings?
Thanks,
Dgaid
2013/06/24 - 17:38
The differences are listed in the link I mentioned in post #23.
I'm afraid you'll have to format your tablet and loose data while upgrading, but you can easily backup your apps and data before upgrading, then restore. Titanium backup application in Google Play Store works fine for that.
fakeplasticme
2013/06/25 - 12:24
I can't get this to work -
"windows encountered a prolem installing the driver software for your device....found software for your device but encountered an error while attempting to install it".
Then agin it did the same thing using the offical one on their website... dunno want I'm doing wrong
matnl
2013/06/25 - 12:57
look here for guidance http://www.flashmyandroid.com/forum/showthread.php?4364-Rockchip-RK3066-RK3188-Tools-and-Stuff
Also, I found that when I tried to access the tablet through ADB, it would not be listed. To remedy that, I had to add 0x2207 to adb_usb.inf in the C:user[youruser].android directory
dgaid
Forum Posts: 40
Thanks Received: 9
2013/06/25 - 17:10
Installed the new firmware update this night - works fine so far, thanks, admin.
The Titanium Backup worked not as I expected, had to do a lot  manual work.  May be, I did not do it right, but now I've got all my applications back.
Dgaid
akincube
Forum Posts: 13
Thanks Received: 9
2013/07/03 - 10:58
Hello People:
Please what is the Battery Performance of Pipo M6?
How long does the battery last under heavy use with internet connection?
Does the tablet has option to choose between the Retina Screen display and any other alternative resolution?
Is the battery capacity really 10000mah as claimed by sellers?
Can somebody please compare/review Pipo M6 with Onda V972?
I need to make a decision. Your fair response will be highly appreciated.
Thanks all.
64 Guest(s)
Devices in use: Desktop (60), Phone (4)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
