Pipo M6 pro wifi and bluetooth problem
phil12623
Forum Posts: 16
2015/12/06 - 15:32
Thanks, i enabled local terminal. but how do i open it? cant find it
phil12623
Forum Posts: 16
2015/12/06 - 15:34
Oh i found it, its an app 😀
phil12623
Forum Posts: 16
2015/12/06 - 15:36
it says RK901u0_a55@rk31board:/ $
2015/12/06 - 15:40
Reboot tab and try to enable wifi a few times.
Open terminal and type:
su
dmesg >/mnt/sdcard/dmesg.txt
Upload the logs (you will find them on internal sdcard).
phil12623
Forum Posts: 16
2015/12/06 - 16:03
dmesg.txt
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #227 SMP PREEMPT Tue Feb 25 14:30:59 CST 2014
[ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: RK30board
[ 0.000000] memory reserve: Memory(base:0x86800000 size:256M) reserved for
[ 0.000000] memory reserve: Memory(base:0x81800000 size:80M) reserved for
[ 0.000000] memory reserve: Memory(base:0x7f400000 size:36M) reserved for
[ 0.000000] memory reserve: Memory(base:0x7ec00000 size:8M) reserved for
[ 0.000000] memory reserve: Total reserved 380M
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] CPU SRAM: copied sram code from c0e1d000 to fef00100 - fef02080
[ 0.000000] CPU SRAM: copied sram data from c0e1ef80 to fef02080 - fef027fc
[ 0.000000] sram_log: 4q ?& : 4q ?) !?, # 0q *! ! 3q @ 3q
[ 0.000000] CLKDATA_MSG: pll_flag = 0x00
[ 0.000000] L310 cache controller enabled
[ 0.000000] l2x0: 16 ways, CACHE_ID 0x4100c0c8, AUX_CTRL 0x76050001, Cache size: 524288 B
[ 0.000000] DDR DEBUG: version 1.00 20130601
[ 0.000000] DDR DEBUG: DDR3 Device
[ 0.000000] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Total Capability=2048MB
[ 0.000000] DDR DEBUG: init success!!! freq=300MHz
[ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=0 extra clock, DGPS=360
[ 0.000000] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.000000] DDR DEBUG: DRV Pull-Up=0xb, DRV Pull-Dwn=0xb
[ 0.000000] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.000000] Boot mode: REBOOT (6) flag: NORMAL (0xc3524200)
[ 0.000000] On node 0 totalpages: 427008
[ 0.000000] free_area_init_node: node 0, pgdat c0e1a380, node_mem_map c2140000
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 124208 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2352 pages used for memmap
[ 0.000000] HighMem zone: 298704 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 7 pages/cpu @c314f000 s6976 r8192 d13504 u32768
[ 0.000000] pcpu-alloc: s6976 r8192 d13504 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 422912
[ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00140000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00008000@0x00004000(kernel),0x00008000@0x0000C000(boot),0x00010000@0x00014000(recovery),0x00020000@0x00024000(backup),0x00040000@0x00044000(cache),0x01BBB000@0x00084000(userdata),0x00002000@0x01C3F000(kpanic),0x00200000@0x01C41000(system),-@0x01E41000(user) bootver=2013-11-14#1.27 firmware_ver=5.0.2
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 492MB 1176MB = 1668MB total
[ 0.000000] Memory: 1668508k/1668508k available, 428644k reserved, 1204224K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xff600000 - 0xffe00000 ( 8 MB)
[ 0.000000] vmalloc : 0xf7000000 - 0xfe800000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf6800000 ( 872 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .init : 0xc0408000 - 0xc0732000 (3240 kB)
[ 0.000000] .text : 0xc0732000 - 0xc0da39dc (6599 kB)
[ 0.000000] .data : 0xc0da4000 - 0xc0e1c1e8 ( 481 kB)
[ 0.000000] .bss : 0xc0e20024 - 0xc18c5e18 (10904 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:352
[ 0.000000] rk30_gpio_init: 128 gpio irqs in 4 banks
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] rk_timer: version 1.2
[ 0.000000] Console: colour dummy device 80x30
[ 0.008761] Calibrating delay loop (skipped) preset value.. 1631.46 BogoMIPS (lpj=8157341)
[ 0.017930] pid_max: default: 32768 minimum: 301
[ 0.023261] Mount-cache hash table entries: 512
[ 0.028824] Initializing cgroup subsys debug
[ 0.033603] Initializing cgroup subsys cpuacct
[ 0.038593] Initializing cgroup subsys freezer
[ 0.043579] CPU: Testing write buffer coherency: ok
[ 0.129832] CPU1: Booted secondary processor
[ 0.169824] CPU2: Booted secondary processor
[ 0.209822] CPU3: Booted secondary processor
[ 0.209853] Brought up 4 CPUs
[ 0.227517] SMP: Total of 4 processors activated (6525.87 BogoMIPS).
[ 0.234904] devtmpfs: initialized
[ 0.244488] NET: Registered protocol family 16
[ 0.249565] last_log: 0xde500000 map to 0xf7004000 and copy to 0xc0e241a0 (version 2.1)
[ 0.273221] lcdc0 is used as primary display device contoller!
[ 0.279767] lcdc1 is used as external display device controller!
[ 0.386709] rk29sdk_wifi_bt_gpio_control_init: init finished
[ 0.394302] console [ttyFIQ0] enabled, bootconsole disabled
[ 0.403455] Registered FIQ tty driver de43dcc0
[ 0.414694] bio: create slab at 0
[ 0.418927] wm831x_dcdc_init
[ 0.419120] wm831x_ldo_init
[ 0.419503] SCSI subsystem initialized
[ 0.419698] usbcore: registered new interface driver usbfs
[ 0.419807] usbcore: registered new interface driver hub
[ 0.421969] usbcore: registered new device driver usb
[ 0.422359] rk30_i2c rk30_i2c.0: i2c-0: RK30 I2C adapter
[ 0.422703] rk30_i2c rk30_i2c.1: i2c-1: RK30 I2C adapter
[ 0.422882] rk30_i2c rk30_i2c.2: i2c-2: RK30 I2C adapter
[ 0.423013] rk30_i2c rk30_i2c.3: i2c-3: RK30 I2C adapter
[ 0.423238] rk30_i2c rk30_i2c.4: i2c-4: RK30 I2C adapter
[ 0.470886] rk30-adc rk30-adc: rk30 adc: driver initialized
[ 0.592142] regbase f7100000 0x0, otg_phy_confed08114, 0xda8
[ 0.597856] rk30_adc_battery: driver initialized
[ 0.598053] timed-gpio: probe of timed-gpio failed with error -22
[ 0.598170] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.598597] Bluetooth: Core ver 2.16
[ 0.598666] NET: Registered protocol family 31
[ 0.598701] Bluetooth: HCI device and connection manager initialized
[ 0.598749] Bluetooth: HCI socket layer initialized
[ 0.598786] Bluetooth: L2CAP socket layer initialized
[ 0.598835] Bluetooth: SCO socket layer initialized
[ 0.599070] cfg80211: Calling CRDA to update world regulatory domain
[ 0.650999] rk fb probe ok!
[ 0.655844] act8846_set_init,line=17
[ 0.655878] act8846_set_init:g_pmic_type=3
[ 0.657672] act8846_set_init act_dcdc1 =1200000mV end
[ 0.659547] act8846_set_init vdd_core =1000000mV end
[ 0.661420] act8846_set_init vdd_cpu =1000000mV end
[ 0.663291] act8846_set_init act_dcdc4 =3300000mV end
[ 0.664531] act8846_set_init act_ldo1 =1000000mV end
[ 0.665668] act8846_set_init act_ldo2 =1200000mV end
[ 0.667439] act8846_set_init act_ldo3 =1800000mV end
[ 0.668577] act8846_set_init act_ldo4 =3300000mV end
[ 0.669716] act8846_set_init act_ldo5 =3300000mV end
[ 0.670854] act8846_set_init act_ldo6 =1800000mV end
[ 0.671992] act8846_set_init act_ldo7 =1800000mV end
[ 0.673761] act8846_set_init act_ldo8 =2800000mV end
[ 0.673806] act8846_set_init,line=78 END
[ 0.673872] i2c-core: driver [act8846] using legacy suspend method
[ 0.673916] i2c-core: driver [act8846] using legacy resume method
[ 0.673968] wm831x_i2c_init
[ 0.674337] i2c i2c-1: No ack, Maybe slave(addr: 0x34) not exist or abnormal power-on, retry 2...
[ 0.674712] i2c i2c-1: No ack, Maybe slave(addr: 0x34) not exist or abnormal power-on, retry 1...
[ 0.675084] i2c i2c-1: No ack, Maybe slave(addr: 0x34) not exist or abnormal power-on, retry 0...
[ 0.675148] wm831x 1-0034: Failed to read parent ID: -11
[ 0.675194] wm831x: probe of 1-0034 failed with error -11
[ 0.675625] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
[ 0.675917] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
[ 0.676206] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
[ 0.676270] tps65910 1-002d: tps65910_set_bits:read from reg 3f failed
[ 0.676547] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
[ 0.676836] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
[ 0.677124] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
[ 0.677187] tps65910 1-002d: read from reg 46 failed
[ 0.677225] tps65910 1-002d: Error in configuring external control EN1
[ 0.677272] tps65910 1-002d: Failed to initialise ext control config
[ 0.677626] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
[ 0.677917] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
[ 0.678204] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
[ 0.678268] tps65910 1-002d: tps65910_set_bits:read from reg 20 failed
[ 0.678315] set_machine_constraints: VIO: failed to enable
[ 0.678403] tps65910 1-002d: failed to register tps65910-pmic regulator
[ 0.678458] tps65910-pmic: probe of tps65910-pmic failed with error -11
[ 0.678867] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
[ 0.679158] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
[ 0.679463] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
[ 0.679527] tps65910 1-002d: Read from reg 0x22 failed
[ 0.679564] The device is not tps65910
[ 0.679711] tps65910: probe of 1-002d failed with error -11
[ 0.679938] Switching to clocksource rk_timer
[ 0.686805] lcdc0:reg_phy_base = 0x1010c000,reg_vir_base:0xf70a0000
[ 0.686887] fb0:win0
[ 0.686892] fb1:win1
[ 0.686897] fb2:win2
[ 0.687034] rk3188 lcdc0 clk enable...
[ 0.689213] Switched to NOHz mode on CPU #0
[ 0.689854] Switched to NOHz mode on CPU #3
[ 0.689866] Switched to NOHz mode on CPU #2
[ 0.689877] Switched to NOHz mode on CPU #1
[ 0.745112] rk3188 lcdc0 clk disable...
[ 0.833880] fb0:phy:7f400000>>vir:f8000000>>len:0x2400000
[ 0.834145] rk_fb_register>>>>>fb0
[ 1.000096] rk_fb_register>>>>>fb1
[ 1.000198] rk3188 lcdc0 clk enable...
[ 1.000238] lcdc0: dclk:192000000>>fps:56
[ 1.000272] rk30-lcdc rk30-lcdc.0: rk3188_load_screen for lcdc0 ok!
[ 1.025354] lcdc0 wakeup from standby!
[ 1.025386] lcdc0 win0 open,atv layer:1
[ 1.073089] rk3188 lcdc0 probe ok!
[ 1.073190] lcdc1:reg_phy_base = 0x1010e000,reg_vir_base:0xf70a4000
[ 1.073261] fb0:win0
[ 1.073266] fb1:win1
[ 1.073271] fb2:win2
[ 1.073352] rk3188 lcdc1 clk enable...
[ 1.098436] rk3188 lcdc1 clk disable...
[ 1.098477] fb2:phy:7f400000>>vir:f8000000>>len:0x2400000
[ 1.098731] rk_fb_register>>>>>fb2
[ 1.111247] rk_fb_register>>>>>fb3
[ 1.111281] rk3188 lcdc1 probe ok!
[ 1.118189] NET: Registered protocol family 2
[ 1.118339] IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 1.118695] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.119694] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[ 1.120857] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.120905] TCP reno registered
[ 1.120937] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 1.120995] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 1.121314] NET: Registered protocol family 1
[ 1.121417] 123456hkw7890
[ 1.121554] RK29 Backlight Driver Initialized.
[ 1.201239] 000 clock detected by anx6345
[ 1.212465] HW LT Success>>:times:1
[ 1.221822] anx6345_init..lc:2--bw:10
[ 1.222726] edp anx6345 probe ok
[ 1.222929] Unpacking initramfs...
[ 1.284123] Freeing initrd memory: 1280K
[ 1.284247] PMU: registered new PMU device of type 0
[ 1.284371] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 0
[ 1.284431] Get nandc rate = 96000 KHz
[ 1.284463] This chip no leakage msg, use delayline instead, val = 0.(HDL=193, LDL=170)
[ 1.284522] Delayline TOO LOW, high voltage request
[ 1.284560] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 0
[ 1.284619] Get nandc rate = 96000 KHz
[ 1.284649] This chip no leakage msg, use delayline instead, val = 0.(HDL=193, LDL=170)
[ 1.284707] Delayline TOO LOW, high voltage request
[ 1.347145] rk3188 cpufreq version 2.0, suspend freq 816 MHz
[ 1.347797] Loaded driver for PL330 DMAC-1 rk29-pl330
[ 1.347843] DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.348041] Loaded driver for PL330 DMAC-2 rk29-pl330
[ 1.348083] DBUFF-64x8bytes Num_Chans-7 Num_Peri-20 Num_Events-14
[ 1.375371] highmem bounce pool size: 64 pages
[ 1.375561] ashmem: initialized
[ 1.384144] fuse init (API version 7.16)
[ 1.388788] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.388844] io scheduler noop registered
[ 1.388881] io scheduler deadline registered
[ 1.388948] io scheduler cfq registered (default)
[ 1.409224] rga: Driver loaded succesfully
[ 1.409448] rk_serial.c v1.4 2013-04-16
[ 1.409550] rk_serial.0: ttyS0 at MMIO 0x10124000 (irq = 66) is a rk29_serial.0
[ 1.560022] rk_serial rk_serial.0: membase 0xf70bc000
[ 1.560089] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3
[ 1.720018] rk_serial rk_serial.3: membase 0xf70c0000
[ 1.720237] Rockchip ion module(version: 1.0) is successfully loaded
[ 1.721653] loop: module loaded
[ 1.721701] Android kernel panic handler initialized (bind=kpanic)
[ 1.721786] mt6229 probe
[ 2.730570] PPP generic driver version 2.4.2
[ 2.730722] PPP Deflate Compression module registered
[ 2.730754] PPP BSD Compression module registered
[ 2.744962] PPP MPPE Compression module registered
[ 2.744998] NET: Registered protocol family 24
[ 2.745082] usbcore: registered new interface driver asix
[ 2.745146] usbcore: registered new interface driver cdc_ether
[ 2.745197] usbcore: registered new interface driver dm9620
[ 2.745246] usbcore: registered new interface driver SR9700_android
[ 2.745301] usbcore: registered new interface driver net1080
[ 2.745349] usbcore: registered new interface driver cdc_subset
[ 2.745410] usbcore: registered new interface driver zaurus
[ 2.745448] cdc_ncm: 04-Aug-2011
[ 2.745489] usbcore: registered new interface driver cdc_ncm
[ 2.745520] Rockchip WiFi SYS interface (V1.00) ...
[ 2.745570] Initializing USB Mass Storage driver...
[ 2.745621] usbcore: registered new interface driver usb-storage
[ 2.745654] USB Mass Storage support registered.
[ 2.745738] usbcore: registered new interface driver usbserial
[ 2.745793] USB Serial support registered for generic
[ 2.745840] usbcore: registered new interface driver usbserial_generic
[ 2.745876] usbserial: USB Serial Driver core
[ 2.745913] USB Serial support registered for GSM modem (1-port)
[ 2.746005] usbcore: registered new interface driver option
[ 2.746035] option: v0.7.2:USB Driver for GSM modems
[ 2.957852] DWC_OTG: ^^^^^^^^^^^^^^^^^Device Mode
[ 2.957895] usb20_otg usb20_otg: DWC OTG Controller
[ 2.958004] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
[ 2.958070] usb20_otg usb20_otg: irq 48, io mem 0x00000000
[ 2.958103] DWC_OTG: dwc_otg_hcd_start controller in device mode,everest
[ 2.958180] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.958221] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.958264] usb usb1: Product: DWC OTG Controller
[ 2.958292] usb usb1: Manufacturer: Linux 3.0.36+ dwc_otg_hcd
[ 2.958328] usb usb1: SerialNumber: usb20_otg
[ 2.958619] hub 1-0:1.0: USB hub found
[ 2.958650] hub 1-0:1.0: 1 port detected
[ 2.963519] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xf7200000
[ 3.174126] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.174148] usb20_host usb20_host: DWC OTG Controller
[ 3.174189] usb20_host usb20_host: new USB bus registered, assigned bus number 2
[ 3.174232] usb20_host usb20_host: irq 49, io mem 0x00000000
[ 3.174281] DWC_OTG: Init: Port Power? op_state=1
[ 3.174295] DWC_OTG: Init: Power Port (0)
[ 3.174334] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.174356] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.174376] usb usb2: Product: DWC OTG Controller
[ 3.174390] usb usb2: Manufacturer: Linux 3.0.36+ host20_hcd
[ 3.174406] usb usb2: SerialNumber: usb20_host
[ 3.174653] hub 2-0:1.0: USB hub found
[ 3.174671] hub 2-0:1.0: 1 port detected
[ 3.175582] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 3.175603] android_usb gadget: Number of LUNs=2
[ 3.175618] lun0: LUN: removable file: (no medium)
[ 3.175636] lun1: LUN: removable file: (no medium)
[ 3.175789] android_usb gadget: android_usb ready
[ 3.175944] input: rk29-keypad as /devices/platform/rk29-keypad/input/input0
[ 3.176137] usbcore: registered new interface driver xpad
[ 3.176188] usbcore: registered new interface driver usb_acecad
[ 3.176204] acecad: v3.2:USB Acecad Flair tablet driver
[ 3.176242] usbcore: registered new interface driver aiptek
[ 3.176257] aiptek: v2.3 (May 2, 2007):Aiptek HyperPen USB Tablet Driver (Linux 2.6.x)
[ 3.176281] aiptek: Bryan W. Headley/Chris Atenasio/Cedric Brun/Rene van Paassen
[ 3.176321] usbcore: registered new interface driver gtco
[ 3.176336] GTCO usb driver version: 2.00.0006
[ 3.176368] usbcore: registered new interface driver hanwang
[ 3.176403] usbcore: registered new interface driver kbtab
[ 3.176418] kbtab: v0.0.2:USB KB Gear JamStudio Tablet driver
[ 3.176457] usbcore: registered new interface driver wacom
[ 3.176474] wacom: v1.52:USB Wacom tablet driver
[ 3.176486] VTL ct36x TouchScreen driver, <george.chen@vtl.com.cn>.
[ 3.176575] No platform data for device ct36x_ts.
[ 3.690023] usb 2-1: new high speed USB device number 2 using usb20_host
[ 3.900713] usb 2-1: New USB device found, idVendor=0e8d, idProduct=00a2
[ 3.900733] usb 2-1: New USB device strings: Mfr=4, Product=5, SerialNumber=0
[ 3.900754] usb 2-1: Product: MT6229
[ 3.900765] usb 2-1: Manufacturer: MediaTek Inc
[ 3.901336] option 2-1:1.0: GSM modem (1-port) converter detected
[ 3.901498] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 3.901757] option 2-1:1.1: GSM modem (1-port) converter detected
[ 3.901885] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 3.902188] option 2-1:1.2: GSM modem (1-port) converter detected
[ 3.902318] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 4.251217] >>>>> ct36x_chip_get_binchksum() called <<<<<
[ 4.251371] >>>>> ct36x_chip_get_fwchksum() called <<<<<
[ 4.830555] >>>>> ct36x_chip_rst_offset() called <<<<<
[ 4.862939] Fw update Success. 0xe9d2, 0xe9d2
[ 5.988349] input: ct36x_ts as /devices/virtual/input/input1
[ 5.988561] >>>>> ct36x_chip_set_adapter_off() called <<<<<
[ 5.995286] i2c-core: driver [ct36x_ts] using legacy suspend method
[ 5.995311] i2c-core: driver [ct36x_ts] using legacy resume method
[ 5.995473] sensor_register_slave:lis3dh,id=4
[ 5.995488] sensor_register_slave:akm8975,id=19
[ 5.995501] sensor_register_slave:l3g4200d,id=34
[ 6.003359] using rtc device, rtc_hym8563, for alarms
[ 6.003397] rtc_hym8563 1-0051: rtc core: registered rtc_hym8563 as rtc0
[ 6.003457] i2c /dev entries driver
[ 6.004024] lirc_dev: IR Remote Control driver registered, major 250
[ 6.004056] IR NEC protocol handler initialized
[ 6.004075] IR RC5(x) protocol handler initialized
[ 6.004090] IR RC6 protocol handler initialized
[ 6.004105] IR JVC protocol handler initialized
[ 6.004120] IR Sony protocol handler initialized
[ 6.004135] IR RC5 (streamzap) protocol handler initialized
[ 6.004153] IR LIRC bridge handler initialized
[ 6.004178] Linux video capture interface: v2.00
[ 6.004361] def_ref_volt: 1800mV, curr_ref_volt: 1800mV
[ 6.004379] start_charge_logo_display
[ 6.004720] device-mapper: uevent: version 1.0.3
[ 6.004954] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[ 6.005094] Bluetooth: HCI UART driver ver 2.2
[ 6.005112] Bluetooth: HCI H4 protocol initialized
[ 6.005128] Bluetooth: HCILL protocol initialized
[ 6.005193] cpuidle: using governor ladder
[ 6.005209] cpuidle: using governor menu
[ 6.054192]
[ 6.054196] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc0]
[ 6.054225]
[ 6.054228] =================
[ 6.054233] mmc_rescan..1831.. ====find no SDMMC host. [mmc0]
[ 6.054309] .Line3981..The End of SDMMC-probe Ver.5.05 The last modify date is 2013-05-08. [sd_mmc]
[ 6.054478]
[ 6.054481] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 6.054559] .Line3981..The End of SDMMC-probe Ver.5.05 The last modify date is 2013-05-08. [sdio]
[ 6.056099] usbcore: registered new interface driver usbhid
[ 6.056118] usbhid: USB HID core driver
[ 6.056539] logger: created 256K log 'log_main'
[ 6.056639] logger: created 256K log 'log_events'
[ 6.056764] logger: created 256K log 'log_radio'
[ 6.056851] logger: created 256K log 'log_system'
[ 6.078950] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 6.204645] RT5631 4-001a: dapm: unknown pin HP_L
[ 6.204663] RT5631 4-001a: dapm: unknown pin HP_R
[ 6.221274] asoc: RT5631 HiFi rk29_i2s.1 mapping ok
[ 6.221611] ALSA device list:
[ 6.221622] #0: RK29_RT5631
[ 6.221729] GACT probability NOT on
[ 6.221747] Mirror/redirect action on
[ 6.221761] u32 classifier
[ 6.221770] Actions configured
[ 6.221783] Netfilter messages via NETLINK v0.30.
[ 6.221836] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 6.222132] ctnetlink v0.93: registering with nfnetlink.
[ 6.222180] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 6.222199] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 6.222486] xt_time: kernel timezone is -0000
[ 6.222640] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.222772] arp_tables: (C) 2002 David S. Miller
[ 6.222830] TCP cubic registered
[ 6.222841] Initializing XFRM netlink socket
[ 6.223198] NET: Registered protocol family 10
[ 6.223711] Mobile IPv6
[ 6.223738] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 6.223849] IPv6 over IPv4 tunneling driver
[ 6.224354] NET: Registered protocol family 17
[ 6.224390] NET: Registered protocol family 15
[ 6.224603] Bluetooth: RFCOMM TTY layer initialized
[ 6.224647] Bluetooth: RFCOMM socket layer initialized
[ 6.224663] Bluetooth: RFCOMM ver 1.11
[ 6.224686] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.224702] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.224822] NET: Registered protocol family 35
[ 6.224968] [BT_RFKILL]: Enter rfkill_rk_init
[ 6.225067] [BT_RFKILL]: Request irq for bt wakeup host
[ 6.225096] [BT_RFKILL]: ** disable irq
[ 6.250051] [BT_RFKILL]: bt shut off power
[ 6.250069] [BT_RFKILL]: ap6476 device registered.
[ 6.250155] func rk_hdmi_power_init, line 767: request gpio success
[ 6.422560] CAT66121: Reg[0-3] = 0x[54].[49].[12].[16]
[ 6.510964] cat66121_hdmi 4-004c: cat66121 hdmi i2c probe ok
[ 6.511114] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 6.511176] rk3066b-camera version: v0.2.31 Zoom by ipp
[ 6.511186] Registering SWP/SWPB emulation handler
[ 6.511714] ddrfreq: verion 2.4 20130427
[ 6.511729] ddrfreq: normal 576MHz video 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 300MHz
[ 6.513695] ddrfreq: change freq to 576 MHz when normal
[ 6.514555] i2c i2c-0: sensor_probe: gs_lis3dh,0xde60ca00
[ 6.514809] sensor_chip_init:gs_lis3dh:devid=0x33,ops=0xc0dfb9a4
[ 6.528674] input: gsensor as /devices/platform/rk30_i2c.0/i2c-0/0-0019/input/input2
[ 6.528867] sensor_irq_init:use irq=175
[ 6.528953] sensor_misc_device_register:miscdevice: mma8452_daemon
[ 6.528968] sensor_probe:initialized ok,sensor name:lis3dh,type:1,id=4
[ 6.528975]
[ 6.528996] i2c i2c-0: sensor_probe: ak8975,0xde60cc00
[ 6.529242] sensor_chip_init:ak8975:devid=0x48,ops=0xc0dfba00
[ 6.529826] input: compass as /devices/platform/rk30_i2c.0/i2c-0/0-000d/input/input3
[ 6.529950] sensor_irq_init:use irq=287
[ 6.530037] sensor_misc_device_register:miscdevice: compass
[ 6.530060] sensor_probe:initialized ok,sensor name:akm8975,type:2,id=19
[ 6.530066]
[ 6.530095] i2c i2c-0: sensor_probe: l3g4200d_gryo,0xde60ce00
[ 6.530343] sensor_chip_init:l3g4200d_gryo:devid=0xd3,ops=0xc0dfbae8
[ 6.534252] input: gyro as /devices/platform/rk30_i2c.0/i2c-0/0-0069/input/input4
[ 6.534407] sensor_irq_init:use irq=199
[ 6.534492] sensor_misc_device_register:miscdevice: gyrosensor
[ 6.534506] sensor_probe:initialized ok,sensor name:l3g4200d,type:3,id=34
[ 6.534512]
[ 6.534564] sensor_init: Probe name sensors
[ 6.534585] sensor-dev.c v1.3 add sensor debug support 2013-3-15
[ 6.535602] rtc_hym8563 1-0051: setting system clock to 2011-01-03 17:22:30 UTC (1294075350)
[ 6.536017] Freeing init memory: 3240K
[ 6.538818] init: /init.rk30board.rc: 61: invalid command '   '
[ 6.539836] init: /init.cm.rc: 200: ignored duplicate definition of service 'bugreport'
[ 6.591526] init: /dev/hw_random not found
[ 6.591589] keychord: using input dev rk29-keypad for fevent
[ 6.667414] Probe ov5640_back success
[ 6.722983] Probe ov2659_front success
[ 6.741818] init: /dev/hw_random not found
[ 6.745146] gp_rknand_info = : 0xdd47e200
[ 6.745189] rk30_chip_set:1
[ 6.745213] request IRQ_NANDC irq , ret=0.........
[ 6.745234] FTL INFO:Version = 438,Date = 20130620
[ 6.745288] FlashCopyProgBuf1=0xc176a000
[ 6.745320] ATime: 40 ns AHB: 140 timming: 1081
[ 6.745336] No.1 FLASH INFO:45 de 94 93 76
[ 6.745353] No.3 FLASH INFO:45 de 94 93 76
[ 6.756083] ATime: 44 ns AHB: 140 timming: 1082
[ 6.758817] FlashReadRetry error!!,row = 40000
[ 6.758827] NAND INFO DUMP....ZYF
[ 6.758835] AHB CLK: 96000
[ 6.758843] FMCTL: 0x300 ; FMWAIT: 0x1082
[ 6.758854] FLCTL: 0x100438 ; BCHCTL: 0x10 ; MTRANS_CFG: 0x1d0
[ 6.758867] MTRANS_SADDR0: 0x0 ; MTRANS_SADDR1: 0x0
[ 6.758878] MTRANS_STAT: 0x0 ; RANDMZ_CFG: 0x576a
[ 6.758889] BCHST[0]: 0x400e007
[ 6.758897] BCHST[1]: 0xe007
[ 6.758905] BCHST[2]: 0xe007
[ 6.758912] BCHST[3]: 0xe007
[ 6.758920] BCHST[4]: 0xe007
[ 6.758928] BCHST[5]: 0xe007
[ 6.758935] BCHST[6]: 0xe007
[ 6.758944] BCHST[7]: 0xe007
[ 6.758997] [] (unwind_backtrace+0x0/0xf8) from [] (FlashReadErrorDump+0xb0/0xe4 [rk30xxnand_ko])
[ 6.759058] [] (FlashReadErrorDump+0xb0/0xe4 [rk30xxnand_ko]) from [] (FlashReadEnhanced+0x238/0x270 [rk30xxnand_ko])
[ 6.759117] [] (FlashReadEnhanced+0x238/0x270 [rk30xxnand_ko]) from [] (FlashTimmingCheck+0x9c/0x104 [rk30xxnand_ko])
[ 6.759180] [] (FlashTimmingCheck+0x9c/0x104 [rk30xxnand_ko]) from [] (FlashInit+0x704/0xfa4 [rk30xxnand_ko])
[ 6.759240] [] (FlashInit+0x704/0xfa4 [rk30xxnand_ko]) from [] (FtlInit+0x8c/0x16c [rk30xxnand_ko])
[ 6.759296] [] (FtlInit+0x8c/0x16c [rk30xxnand_ko]) from [] (NandInit+0x19c/0x2f8 [rk30xxnand_ko])
[ 6.759351] [] (NandInit+0x19c/0x2f8 [rk30xxnand_ko]) from [] (rk29nand_probe+0x74/0x224 [rk30xxnand_ko])
[ 6.759394] [] (rk29nand_probe+0x74/0x224 [rk30xxnand_ko]) from [] (do_one_initcall+0xfc/0x164)
[ 6.759424] [] (do_one_initcall+0xfc/0x164) from [] (sys_init_module+0xcd0/0x1a68)
[ 6.759448] [] (sys_init_module+0xcd0/0x1a68) from [] (ret_fast_syscall+0x0/0x30)
[ 6.759468] ATime: 50 ns AHB: 140 timming: 10a2
[ 6.762390] FlashReadRetry error!!,row = 40000
[ 6.762402] ATime: 56 ns AHB: 140 timming: 10a2
[ 6.762414] randomizer = 0 , EccBits = 28 pSpec->pReadRetrial = bf009fd0
[ 6.931162] totalLogicBlkRaw = 3937
[ 6.931189] gBootMedia = 1 gSdmmcFwPartOffset =0!
[ 6.931202] rknand_buffer.c version: 4.38 20121130!
[ 6.931318] 10 cmdlinepart partitions found on MTD device rk29xxnand
[ 6.931335] Creating 10 MTD partitions on "rk29xxnand":
[ 6.931350] 0x000000400000-0x000000800000 : "misc"
[ 6.932827] 0x000000800000-0x000001800000 : "kernel"
[ 6.934058] 0x000001800000-0x000002800000 : "boot"
[ 6.935310] 0x000002800000-0x000004800000 : "recovery"
[ 6.936526] 0x000004800000-0x000008800000 : "backup"
[ 6.937772] 0x000008800000-0x000010800000 : "cache"
[ 6.939060] 0x000010800000-0x000387e00000 : "userdata"
[ 6.949306] 0x000387e00000-0x000388200000 : "kpanic"
[ 6.952370] apanic: Bound to mtd partition 'kpanic'
[ 6.952385] apanic: No panic data available
[ 6.952399] 0x000388200000-0x0003c8200000 : "system"
[ 6.954594] 0x0003c8200000-0x0003d8400000 : "user"
[ 6.955939] startBlk = 50 sysProtAddr = 49
[ 6.956998] fs_mgr: Warning: unknown flag encryptable
[ 6.976947] EXT4-fs (mtdblock8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 6.977013] fs_mgr: __mount(source=/dev/block/mtd/by-name/system,target=/system,type=ext4)=0
[ 6.996903] EXT4-fs (mtdblock5): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 6.996957] fs_mgr: __mount(source=/dev/block/mtd/by-name/cache,target=/cache,type=ext4)=0
[ 7.016890] EXT4-fs (mtdblock6): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.016941] fs_mgr: __mount(source=/dev/block/mtd/by-name/userdata,target=/data,type=ext4)=0
[ 7.100949] UMP: Using OS memory backend, allocation limit: 1073741824
[ 7.100994] UMP: UMP device driver -e1a6a37 loaded
[ 7.157886] Mali: Mali400 inside of rk3188!
[ 7.157909] Mali: mali freq table num : 6
[ 7.157939] Mali: mali freq table :Mali: 128,Mali: 198,Mali: 256,Mali: 297,Mali: 384,Mali: 594,Mali:
[ 7.158001] Mali: init mali clock success
[ 7.159742] Mali: Mali device driver loaded
[ 7.163634] rk30_mirroring: Unknown symbol video_data_to_mirroring (err 0)
[ 7.163688] rk30_mirroring: Unknown symbol audio_data_to_mirroring (err 0)
[ 7.165780] rk29_ipp: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.166349] ipp irq 47
[ 7.166852] IPP init, version rk30-ipp 1.003
[ 7.637268] binder: 99:99 transaction failed 29189, size 0-0
[ 7.966202] VPU_SERVICE: failed on clk_get pd_video
[ 7.966258] vpu: power on
[ 7.966320] VPU_SERVICE: checking hw id 4831
[ 7.967115] vpu: power off...done
[ 7.967149] VPU_SERVICE: init success
[ 7.974257] rtk_btusb: Realtek Bluetooth USB driver ver 0.9
[ 7.974408] usbcore: registered new interface driver rtk_btusb
[ 7.975452] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[ 7.975534] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial'
[ 7.976132] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
[ 7.976209] init: property 'ro.product.usbfactory' doesn't exist while expanding '$ro.product.usbfactory'
[ 7.976273] init: cannot expand '$ro.product.usbfactory' while writing to '/sys/class/android_usb/android0/f_mass_storage/inquiry_string'
[ 8.027778] init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64'
[ 8.036690] init: cannot find '/system/bin/chrome.sh', disabling 'chrome'
[ 8.036844] init: cannot find '/system/bin/akmd', disabling 'akmd'
[ 8.036962] init: cannot find '/system/bin/bplus_helper', disabling 'bplus_helper'
[ 8.637799] healthd: wakealarm_init: timerfd_create failed
[ 8.638629] healthd: BatteryTemperaturePath not found
[ 8.735143] android_usb: already disabled
[ 8.741701] adb_open
[ 8.874214] EXT4-fs (mtdblock8): re-mounted. Opts: barrier=1,data=ordered,noauto_da_alloc,discard
[ 9.020325] logd.auditd: start
[ 9.122161] Loading Chuwi V88 HUB access mod
[ 9.122189] Greetings from crewrktablets 😉
[ 9.122215] HUBaccess mod addres check failed [09 00 00 1a]
[ 9.270806] fs_mgr: Warning: unknown flag encryptable
[ 9.874676] rk fb use 3 buffers
[ 9.884164] tun: Universal TUN/TAP device driver, 1.6
[ 9.884202] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 9.900996] TCP veno registered
[ 9.933200] usbcore: registered new interface driver dm9601
[ 9.998522] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 10.062878] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
[ 10.063043] usbcore: registered new interface driver rtl8150
[ 10.069123] warning: `daemonsu' uses 32-bit capabilities (legacy support in use)
[ 10.480390] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 11.832825] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 11.845632] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 11.960344] init: untracked pid 430 exited with status 0
[ 13.579645] usbcore: registered new interface driver snd-usb-audio
[ 14.430690] USB Serial support registered for cp210x
[ 14.431740] usbcore: registered new interface driver cp210x
[ 14.431788] cp210x: v0.09:Silicon Labs CP210x RS232 serial adaptor driver
[ 14.503397] USB Serial support registered for pl2303
[ 14.503849] usbcore: registered new interface driver pl2303
[ 14.503873] pl2303: Prolific PL2303 USB to serial adaptor driver
[ 14.670444] USB Serial support registered for FTDI USB Serial Device
[ 14.671208] usbcore: registered new interface driver ftdi_sio
[ 14.671227] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[ 14.778625] flash io:189
[ 14.778644] ov5640 sensor_ioctl cmd(0x3) is unknown !
[ 14.785942] usbcore: registered new interface driver cdc_acm
[ 14.785963] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 14.880681] ov2659 sensor_ioctl cmd(0x3) is unknown !
[ 15.011861] init: untracked pid 459 exited with status 0
[ 15.013888] init: untracked pid 461 exited with status 1
[ 15.093830] init: untracked pid 169 exited with status 0
[ 15.101411] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 15.126879] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 15.162834] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 15.232150] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 15.310311] init: untracked pid 463 exited with status 1
[ 31.063423] request_suspend_state: wakeup (3->0) at 31013419879 (2011-01-03 17:22:55.021611253 UTC)
[ 61.842657] flash io:189
[ 61.842721] ov5640 sensor_ioctl cmd(0x3) is unknown !
[ 61.907276]
[ 61.907311] ov5640..sensor_set_focus_mode AF module state(0x10000000, 0x1) is error!
[ 62.125605] ov2659 sensor_ioctl cmd(0x3) is unknown !
[ 64.175373] acc_open
[ 64.175391] acc_release
[ 65.215540] Current WiFi chip is AP6476.
[ 65.364066] =======================================================
[ 65.364117] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 65.364160] =======================================================
[ 65.364196] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 65.466783] =========== WLAN placed in POWER ON ========
[ 65.467387] ANDROID-ERROR) wifi_set_power = 1
[ 65.467564] rk29sdk_wifi_power: 1
[ 65.722756] wifi turn on power
[ 65.722814] ANDROID-ERROR) wifi_set_carddetect = 1
[ 65.722909] rk29sdk_wifi_set_carddetect:1
[ 65.722971] mmc1: slot status change detected(0-1)
[ 65.920420]
[ 65.920442] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 65.966003]
[ 65.966019] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 65.982340] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 65.986047] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 65.988508] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 65.992408] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 66.082192] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 66.086534] mmc1: new high speed SDIO card at address 0001
[ 66.093048] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 66.093965] dhdsdio_probe : no mutex held. set lock
[ 66.094036] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 66.094052] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 66.094236] F1 signature read @0x18000000=0x16044330
[ 66.196831] DHD: dongle ram size is set to 294912(orig 294912)
[ 66.207128] wl_create_event_handler thr:2d0 created
[ 66.207967] wl_create_event_handler thr:2d0 started
[ 66.247609] p2p0: P2P Interface Registered
[ 66.248245] dhd_attach thr:2d2 created
[ 66.249091] dhd_attach thr:2d2 started
[ 66.249518] dhd_attach thr:2d3 created
[ 66.250204] dhd_attach thr:2d3 started
[ 66.250698] dhd_attach thr:2d4 created
[ 66.251226] dhd_attach thr:2d4 started
[ 66.259983] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 66.260430] dhdsdio_probe : the lock is released.
[ 66.260738] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 66.263555]
[ 66.263592] Dongle Host Driver, version 1.28.23.5 (r)
[ 66.263655] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 66.267315] ANDROID-ERROR) wifi_set_power = 0
[ 66.267387] rk29sdk_wifi_power: 0
[ 66.505809] wifi shut off power
[ 66.620562] =========== WLAN placed in RESET ========
[ 68.302150]
[ 68.302176] Dongle Host Driver, version 1.28.23.5 (r)
[ 68.302237] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 68.302349] wl_android_wifi_on in
[ 68.302382] ANDROID-ERROR) wifi_set_power = 1
[ 68.302425] rk29sdk_wifi_power: 1
[ 68.563060] wifi turn on power
[ 68.666697] =========== WLAN going back to live ========
[ 68.666789] sdio_reset_comm():
[ 68.666856] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 68.677786] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 68.678412]
[ 68.678419]
[ 68.678438] dhd_bus_devreset: == WLAN ON ==
[ 68.678497] dhd_bus_devreset called when dongle is not in reset
[ 68.678742] Will call dhd_bus_start instead
[ 68.678884] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 68.679085] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 68.679127] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 68.679164] Final conf_path=/system/etc/firmware/config.txt
[ 72.751856] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 73.382035] binder: 491:503 refcount change on invalid ref 37
[ 73.750161] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 73.750224] dhd_bus_init: clock state is wrong. state = 1
[ 73.750262] dhd_bus_start, dhd_bus_init failed -1
[ 73.750315] dhd_bus_devreset: dhd_bus_start fail with -1
[ 73.750362] dhd_dev_reset: dhd_bus_devreset: -1
[ 74.760278] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 74.761239] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 74.761373] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 74.761923] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 74.762072] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 74.763380] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 74.763629] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 74.764670] dhdcdc_set_ioctl: dhdcdc_msg failed w/status -5
[ 75.760180] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 75.760465] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 75.760500] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 75.760720] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 75.760755] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 75.760989] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 75.761023] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 75.761586] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4123
[ 75.761860] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 75.761894] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 75.762101] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 75.762135] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 75.762344] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 75.762378] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 75.762632] ANDROID-ERROR) wifi_set_power = 0
[ 75.762696] rk29sdk_wifi_power: 0
[ 76.050436] wifi shut off power
[ 76.198020] =========== WLAN placed in RESET ========
[ 76.198041] wl_android_wifi_on: Failed
[ 76.198057] wl_android_wifi_off in
[ 83.810142] =======================================================
[ 83.810279] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 83.810358] =======================================================
[ 83.810527] net_ratelimit: 3 callbacks suppressed
[ 83.810604] dhdsdio_disconnect : no mutex held. set lock
[ 83.810698] bcmsdh_unregister_oob_intr: Enter
[ 83.811141] dhd_detach thr:2d4 terminated OK
[ 83.880432] dhd_detach thr:2d2 terminated OK
[ 83.880616] dhd_detach thr:2d3 terminated OK
[ 83.990253] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 83.990384] wl_destroy_event_handler thr:2d0 terminated OK
[ 84.040743] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 84.041296] dhdsdio_disconnect : the lock is released.
[ 84.041474] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 84.041761] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 84.041997] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 84.042256] ANDROID-ERROR) ## wifi_remove
[ 84.042416] ANDROID-ERROR) wifi_set_power = 0
[ 84.042496] rk29sdk_wifi_power: 0
[ 84.292181] wifi shut off power
[ 84.292232] ANDROID-ERROR) wifi_set_carddetect = 0
[ 84.292283] rk29sdk_wifi_set_carddetect:0
[ 84.292342] mmc1: slot status change detected(1-0)
[ 84.293205] mmc1: card 0001 removed
[ 84.293298] =========== WLAN placed in POWER OFF ========
[ 84.293764]
[ 84.293796] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 84.310101] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 86.497317] binder: 491:503 refcount change on invalid ref 92
[ 88.612624] Current WiFi chip is AP6476.
[ 88.654362] =======================================================
[ 88.654430] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 88.654490] =======================================================
[ 88.654538] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 88.759222] =========== WLAN placed in POWER ON ========
[ 88.759393] ANDROID-ERROR) wifi_set_power = 1
[ 88.759438] rk29sdk_wifi_power: 1
[ 89.138006] wifi turn on power
[ 89.138070] ANDROID-ERROR) wifi_set_carddetect = 1
[ 89.138125] rk29sdk_wifi_set_carddetect:1
[ 89.138187] mmc1: slot status change detected(0-1)
[ 89.330109]
[ 89.330122] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 89.376208]
[ 89.376223] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 89.392890] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 89.395289] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 89.398035] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 89.401717] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 89.472508] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 89.475035] mmc1: new high speed SDIO card at address 0001
[ 89.479249] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 89.480306] dhdsdio_probe : no mutex held. set lock
[ 89.480452] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 89.480522] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 89.480855] F1 signature read @0x18000000=0x16044330
[ 89.528333] DHD: dongle ram size is set to 294912(orig 294912)
[ 89.533985] wl_create_event_handler thr:4c6 created
[ 89.534340] wl_create_event_handler thr:4c6 started
[ 89.540450] p2p0: P2P Interface Registered
[ 89.540870] dhd_attach thr:4c7 created
[ 89.541579] dhd_attach thr:4c7 started
[ 89.541975] dhd_attach thr:4c8 created
[ 89.543004] dhd_attach thr:4c8 started
[ 89.543262] dhd_attach thr:4c9 created
[ 89.543741] dhd_attach thr:4c9 started
[ 89.549641] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 89.550907] dhdsdio_probe : the lock is released.
[ 89.551827] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 89.553301]
[ 89.553343] Dongle Host Driver, version 1.28.23.5 (r)
[ 89.553400] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 89.553729] ANDROID-ERROR) wifi_set_power = 0
[ 89.553854] rk29sdk_wifi_power: 0
[ 89.775894] wifi shut off power
[ 89.886261] =========== WLAN placed in RESET ========
[ 89.951101]
[ 89.951114] Dongle Host Driver, version 1.28.23.5 (r)
[ 89.951136] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 89.951243] wl_android_wifi_on in
[ 89.951273] ANDROID-ERROR) wifi_set_power = 1
[ 89.951324] rk29sdk_wifi_power: 1
[ 90.246073] wifi turn on power
[ 90.451297] =========== WLAN going back to live ========
[ 90.451484] sdio_reset_comm():
[ 90.451655] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 90.459604] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 90.461806]
[ 90.461867]
[ 90.461901] dhd_bus_devreset: == WLAN ON ==
[ 90.462270] dhd_bus_devreset called when dongle is not in reset
[ 90.462507] Will call dhd_bus_start instead
[ 90.462980] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 90.463672] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 90.463972] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 90.464223] Final conf_path=/system/etc/firmware/config.txt
[ 90.730234] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 91.740037] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 92.740213] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 92.740238] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 92.740476] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 92.740498] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 92.740698] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 92.740713] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 93.740340] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 93.740367] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 93.740549] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 93.740575] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 93.740761] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 93.740786] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 93.741203] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 93.741220] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 93.741323] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 93.741340] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 93.741465] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 93.741482] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 93.741623] ANDROID-ERROR) wifi_set_power = 0
[ 93.741645] rk29sdk_wifi_power: 0
[ 93.952717] wifi shut off power
[ 94.086921] =========== WLAN placed in RESET ========
[ 94.086958] wl_android_wifi_on: Failed
[ 94.086984] wl_android_wifi_off in
[ 94.482891] binder: release 103:248 transaction 25879 in, still active
[ 94.482923] binder: send failed reply for transaction 25879 to 355:421
[ 94.482958] binder: release 103:250 transaction 25843 in, still active
[ 94.482982] binder: send failed reply for transaction 25843 to 844:1235
[ 94.692612] binder: release 621:621 transaction 26958 out, still active
[ 94.696998] request_suspend_state: wakeup (0->0) at 94646989137 (2011-01-03 17:23:58.655178636 UTC)
[ 94.697785] binder: release 1068:1068 transaction 25702 out, still active
[ 94.705493] binder: release 491:507 transaction 25702 in, still active
[ 94.705517] binder: send failed reply for transaction 25702, target dead
[ 94.705549] binder: release 491:758 transaction 26958 in, still active
[ 94.705570] binder: send failed reply for transaction 26958, target dead
[ 94.705599] binder: release 491:793 transaction 27063 in, still active
[ 94.705635] binder: send failed reply for transaction 27063 to 1097:1287
[ 94.730767] init: untracked pid 734 killed by signal 9
[ 94.730865] init: untracked pid 787 killed by signal 9
[ 94.741115] init: untracked pid 808 killed by signal 9
[ 94.741202] init: untracked pid 1240 killed by signal 9
[ 94.741345] init: untracked pid 1188 killed by signal 9
[ 94.843800] rk fb use 3 buffers
[ 94.981120] init: untracked pid 621 killed by signal 9
[ 94.981290] init: untracked pid 1068 killed by signal 9
[ 95.000574] init: untracked pid 1046 killed by signal 9
[ 95.010779] init: untracked pid 628 killed by signal 9
[ 95.050931] init: untracked pid 745 killed by signal 9
[ 95.051011] init: untracked pid 1122 killed by signal 9
[ 95.051146] init: untracked pid 956 killed by signal 9
[ 95.100600] init: untracked pid 864 killed by signal 9
[ 95.370420] init: untracked pid 1294 killed by signal 9
[ 95.390698] init: untracked pid 814 killed by signal 9
[ 95.441598] init: untracked pid 1097 killed by signal 9
[ 95.441793] init: untracked pid 1269 killed by signal 9
[ 95.580540] alarm_release: clear alarm, pending 0
[ 95.580566] alarm_release: clear alarm, pending 0
[ 95.941426] init: untracked pid 844 killed by signal 9
[ 96.010746] init: untracked pid 491 killed by signal 9
[ 100.042405] flash io:189
[ 100.042433] ov5640 sensor_ioctl cmd(0x3) is unknown !
[ 100.150361] ov2659 sensor_ioctl cmd(0x3) is unknown !
[ 102.691887] request_suspend_state: wakeup (0->0) at 102641870637 (2011-01-03 17:24:06.650060511 UTC)
[ 110.232949] flash io:189
[ 110.232970] ov5640 sensor_ioctl cmd(0x3) is unknown !
[ 110.294896]
[ 110.294904] ov5640..sensor_set_focus_mode AF module state(0x10000000, 0x1) is error!
[ 110.475101] ov2659 sensor_ioctl cmd(0x3) is unknown !
[ 111.969773] =======================================================
[ 111.969935] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 111.969995] =======================================================
[ 111.970247] net_ratelimit: 11 callbacks suppressed
[ 111.970338] dhdsdio_disconnect : no mutex held. set lock
[ 111.970446] bcmsdh_unregister_oob_intr: Enter
[ 111.970624] dhd_detach thr:4c9 terminated OK
[ 112.060606] dhd_detach thr:4c7 terminated OK
[ 112.060730] dhd_detach thr:4c8 terminated OK
[ 112.065454] acc_open
[ 112.065507] acc_release
[ 112.170253] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 112.170419] wl_destroy_event_handler thr:4c6 terminated OK
[ 112.211115] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 112.211593] dhdsdio_disconnect : the lock is released.
[ 112.211762] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 112.212026] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 112.212226] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 112.212625] ANDROID-ERROR) ## wifi_remove
[ 112.212678] ANDROID-ERROR) wifi_set_power = 0
[ 112.212721] rk29sdk_wifi_power: 0
[ 112.435139] wifi shut off power
[ 112.435230] ANDROID-ERROR) wifi_set_carddetect = 0
[ 112.435628] rk29sdk_wifi_set_carddetect:0
[ 112.435768] mmc1: slot status change detected(1-0)
[ 112.436835] mmc1: card 0001 removed
[ 112.437128]
[ 112.437142] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 112.437461] =========== WLAN placed in POWER OFF ========
[ 112.450249] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 113.024718] Current WiFi chip is AP6476.
[ 113.126145] =======================================================
[ 113.126273] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 113.126457] =======================================================
[ 113.126607] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 113.312469] =========== WLAN placed in POWER ON ========
[ 113.312945] ANDROID-ERROR) wifi_set_power = 1
[ 113.313032] rk29sdk_wifi_power: 1
[ 113.897228] wifi turn on power
[ 113.897342] ANDROID-ERROR) wifi_set_carddetect = 1
[ 113.897498] rk29sdk_wifi_set_carddetect:1
[ 113.897623] mmc1: slot status change detected(0-1)
[ 114.090319]
[ 114.090339] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 114.135839]
[ 114.135897] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 114.150951] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 114.154768] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 114.158607] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 114.164269] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 114.282133] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 114.289047] mmc1: new high speed SDIO card at address 0001
[ 114.299723] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 114.300952]
[ 114.300978] Dongle Host Driver, version 1.28.23.5 (r)
[ 114.301022] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 114.311785] dhdsdio_probe : no mutex held. set lock
[ 114.311987] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 114.312088] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 114.312442] F1 signature read @0x18000000=0x16044330
[ 114.403412] DHD: dongle ram size is set to 294912(orig 294912)
[ 114.412707] wl_create_event_handler thr:77c created
[ 114.412950] wl_create_event_handler thr:77c started
[ 114.421146] p2p0: P2P Interface Registered
[ 114.421630] dhd_attach thr:77d created
[ 114.421870] dhd_attach thr:77d started
[ 114.422282] dhd_attach thr:77e created
[ 114.422507] dhd_attach thr:77e started
[ 114.422892] dhd_attach thr:77f created
[ 114.423090] dhd_attach thr:77f started
[ 114.432013] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 114.432079] dhdsdio_probe : the lock is released.
[ 114.432219] ANDROID-ERROR)
[ 114.432235] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 114.432333] wifi_set_power = 0
[ 114.432364] rk29sdk_wifi_power: 0
[ 114.830809] wifi shut off power
[ 114.937832] =========== WLAN placed in RESET ========
[ 115.006502]
[ 115.006507] Dongle Host Driver, version 1.28.23.5 (r)
[ 115.006514] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 115.006554] wl_android_wifi_on in
[ 115.006566] ANDROID-ERROR) wifi_set_power = 1
[ 115.006580] rk29sdk_wifi_power: 1
[ 115.519132] wifi turn on power
[ 115.737270] =========== WLAN going back to live ========
[ 115.737417] sdio_reset_comm():
[ 115.737522] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 115.752820] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 115.754545]
[ 115.754603]
[ 115.754626] dhd_bus_devreset: == WLAN ON ==
[ 115.755166] dhd_bus_devreset called when dongle is not in reset
[ 115.755439] Will call dhd_bus_start instead
[ 115.755996] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 115.756774] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 115.757084] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 115.757406] Final conf_path=/system/etc/firmware/config.txt
[ 116.487208] binder: 1576:1587 refcount change on invalid ref 53
[ 117.925061] net_ratelimit: 6 callbacks suppressed
[ 117.925595] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 117.925962] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 117.926063] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 117.927710] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 117.927830] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 117.929872] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 117.930068] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 117.934644] dhdcdc_set_ioctl: dhdcdc_msg failed w/status -5
[ 118.950911] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 118.952943] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 118.953036] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 118.953430] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 118.953521] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 118.954104] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 118.954197] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 118.954763] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4123
[ 118.955334] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 118.955416] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 118.955859] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 118.955959] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 118.956653] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 118.956729] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 118.957360] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4143
[ 118.957590] dhd_bus_devreset: WLAN OFF DONE
[ 118.957867] ANDROID-ERROR) wifi_set_power = 0
[ 118.958039] rk29sdk_wifi_power: 0
[ 119.437237] wifi shut off power
[ 119.635379] =========== WLAN placed in RESET ========
[ 119.635686] wl_android_wifi_on: Failed
[ 119.635849] dhd_open: failed with code -1
[ 119.635986] wl_android_wifi_off in
[ 121.954308] binder: 1576:1587 refcount change on invalid ref 170
[ 130.357324] =======================================================
[ 130.357575] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 130.357791] =======================================================
[ 130.358106] dhdsdio_disconnect : no mutex held. set lock
[ 130.358266] bcmsdh_unregister_oob_intr: Enter
[ 130.359509] dhd_detach thr:77f terminated OK
[ 130.397145] modem_status_write, c(0), modem suspend
[ 130.472313] dhd_detach thr:77d terminated OK
[ 130.472863] dhd_detach thr:77e terminated OK
[ 130.580428] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 130.581045] wl_destroy_event_handler thr:77c terminated OK
[ 130.640997] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 130.641821] dhdsdio_disconnect : the lock is released.
[ 130.641912] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 130.643430] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 130.643706] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 130.644310] ANDROID-ERROR) ## wifi_remove
[ 130.644532] ANDROID-ERROR) wifi_set_power = 0
[ 130.644648] rk29sdk_wifi_power: 0
[ 130.864198] option: option_instat_callback : error -108
[ 130.929901] DWC_OTG: DWC OTG No longer connected
[ 130.929985] DWC_OTG: DWC OTG No longer connected
[ 130.930216] DWC_OTG: DWC OTG No longer connected
[ 130.930263] DWC_OTG: DWC OTG No longer connected
[ 130.930311] DWC_OTG: DWC OTG No longer connected
[ 130.930379] DWC_OTG: DWC OTG No longer connected
[ 130.930424] DWC_OTG: DWC OTG No longer connected
[ 130.930454] DWC_OTG: DWC OTG No longer connected
[ 130.930484] DWC_OTG: DWC OTG No longer connected
[ 130.930520] DWC_OTG: DWC OTG No longer connected
[ 130.930572] DWC_OTG: DWC OTG No longer connected
[ 130.930623] DWC_OTG: DWC OTG No longer connected
[ 130.930663] DWC_OTG: DWC OTG No longer connected
[ 130.930702] DWC_OTG: DWC OTG No longer connected
[ 130.930780] DWC_OTG: DWC OTG No longer connected
[ 130.930824] DWC_OTG: DWC OTG No longer connected
[ 130.950685] wifi shut off power
[ 130.950833] ANDROID-ERROR) wifi_set_carddetect = 0
[ 130.951086] rk29sdk_wifi_set_carddetect:0
[ 130.951252] mmc1: slot status change detected(1-0)
[ 130.952841] mmc1: card 0001 removed
[ 130.953414]
[ 130.953456] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 130.954240] =========== WLAN placed in POWER OFF ========
[ 130.970340] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 131.093128] usb 2-1: USB disconnect, device number 2
[ 131.094309] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 131.094648] option 2-1:1.0: device disconnected
[ 131.095702] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 131.096079] option 2-1:1.1: device disconnected
[ 131.108182] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 131.109182] option 2-1:1.2: device disconnected
[ 131.200425] DWC_OTG: dwc_otg_hcd_enable, disable host controller
[ 135.164576] Current WiFi chip is AP6476.
[ 135.280909] =======================================================
[ 135.281175] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 135.281284] =======================================================
[ 135.281382] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 135.411724] =========== WLAN placed in POWER ON ========
[ 135.412061] ANDROID-ERROR) wifi_set_power = 1
[ 135.412380] rk29sdk_wifi_power: 1
[ 135.725478] wifi turn on power
[ 135.725569] ANDROID-ERROR) wifi_set_carddetect = 1
[ 135.725702] rk29sdk_wifi_set_carddetect:1
[ 135.725890] mmc1: slot status change detected(0-1)
[ 135.920322]
[ 135.920385] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 135.964366]
[ 135.964415] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 135.982354] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 135.984543] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 135.987492] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 135.994313] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 136.064555] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 136.066713] mmc1: new high speed SDIO card at address 0001
[ 136.072995] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 136.073628] dhdsdio_probe : no mutex held. set lock
[ 136.073787] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 136.073868] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 136.074079] F1 signature read @0x18000000=0x16044330
[ 136.107391] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 136.119408] DHD: dongle ram size is set to 294912(orig 294912)
[ 136.126599] wl_create_event_handler thr:a63 created
[ 136.127383] wl_create_event_handler thr:a63 started
[ 136.136233] p2p0: P2P Interface Registered
[ 136.136632] dhd_attach thr:a64 created
[ 136.137072] dhd_attach thr:a64 started
[ 136.137263] dhd_attach thr:a65 created
[ 136.137459] dhd_attach thr:a65 started
[ 136.137796] dhd_attach thr:a66 created
[ 136.138179] dhd_attach thr:a66 started
[ 136.139913] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 136.140402] dhdsdio_probe : the lock is released.
[ 136.140706]
[ 136.140729] Dongle Host Driver, version 1.28.23.5 (r)
[ 136.140759] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 136.141822] ANDROID-ERROR) wifi_set_power = 0
[ 136.141893] rk29sdk_wifi_power: 0
[ 136.357954] wifi shut off power
[ 136.460815] =========== WLAN placed in RESET ========
[ 136.496578]
[ 136.496585] Dongle Host Driver, version 1.28.23.5 (r)
[ 136.496594] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 136.496625] wl_android_wifi_on in
[ 136.496636] ANDROID-ERROR) wifi_set_power = 1
[ 136.496650] rk29sdk_wifi_power: 1
[ 136.757521] wifi turn on power
[ 136.860273] =========== WLAN going back to live ========
[ 136.860326] sdio_reset_comm():
[ 136.860372] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 136.869616] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 136.870257]
[ 136.870269]
[ 136.870280] dhd_bus_devreset: == WLAN ON ==
[ 136.870358] dhd_bus_devreset called when dongle is not in reset
[ 136.870474] Will call dhd_bus_start instead
[ 136.870891] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 136.871047] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 136.871104] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 136.871177] Final conf_path=/system/etc/firmware/config.txt
[ 136.944285] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 137.940095] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 138.940257] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 138.940294] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 138.940627] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 138.940667] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 138.941455] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 138.941494] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 139.940637] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 139.940658] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 139.940785] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 139.940802] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 139.940961] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 139.940991] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 139.941265] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 139.941289] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 139.941436] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 139.941454] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 139.941564] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 139.941610] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 139.941806] ANDROID-ERROR) wifi_set_power = 0
[ 139.941842] rk29sdk_wifi_power: 0
[ 140.165637] wifi shut off power
[ 140.272336] =========== WLAN placed in RESET ========
[ 140.272496] wl_android_wifi_on: Failed
[ 140.272621] wl_android_wifi_off in
[ 151.724505] =======================================================
[ 151.724535] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 151.724560] =======================================================
[ 151.724620] net_ratelimit: 11 callbacks suppressed
[ 151.724640] dhdsdio_disconnect : no mutex held. set lock
[ 151.724661] bcmsdh_unregister_oob_intr: Enter
[ 151.724729] dhd_detach thr:a66 terminated OK
[ 151.910127] dhd_detach thr:a64 terminated OK
[ 151.910248] dhd_detach thr:a65 terminated OK
[ 152.050090] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 152.050138] wl_destroy_event_handler thr:a63 terminated OK
[ 152.110294] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 152.110339] dhdsdio_disconnect : the lock is released.
[ 152.110371] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 152.110412] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 152.110467] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 152.110637] ANDROID-ERROR) ## wifi_remove
[ 152.110650] ANDROID-ERROR) wifi_set_power = 0
[ 152.110662] rk29sdk_wifi_power: 0
[ 152.317809] wifi shut off power
[ 152.317825] ANDROID-ERROR) wifi_set_carddetect = 0
[ 152.317839] rk29sdk_wifi_set_carddetect:0
[ 152.317851] mmc1: slot status change detected(1-0)
[ 152.318201] mmc1: card 0001 removed
[ 152.318318] =========== WLAN placed in POWER OFF ========
[ 152.318384]
[ 152.318388] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 152.330032] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 156.530126] Current WiFi chip is AP6476.
[ 156.554538] =======================================================
[ 156.554578] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 156.554602] =======================================================
[ 156.554627] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 156.679710] =========== WLAN placed in POWER ON ========
[ 156.679820] ANDROID-ERROR) wifi_set_power = 1
[ 156.679848] rk29sdk_wifi_power: 1
[ 156.959505] wifi turn on power
[ 156.959533] ANDROID-ERROR) wifi_set_carddetect = 1
[ 156.959568] rk29sdk_wifi_set_carddetect:1
[ 156.959590] mmc1: slot status change detected(0-1)
[ 157.150169]
[ 157.150196] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 157.194801]
[ 157.194805] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 157.207888] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 157.212090] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 157.214362] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 157.218161] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 157.288368] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 157.293825] mmc1: new high speed SDIO card at address 0001
[ 157.296876] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 157.297176]
[ 157.297188] Dongle Host Driver, version 1.28.23.5 (r)
[ 157.297222] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 157.299040] dhdsdio_probe : no mutex held. set lock
[ 157.299127] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 157.299156] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 157.299513] F1 signature read @0x18000000=0x16044330
[ 157.336701] DHD: dongle ram size is set to 294912(orig 294912)
[ 157.339317] wl_create_event_handler thr:ca0 created
[ 157.339365] wl_create_event_handler thr:ca0 started
[ 157.343951] p2p0: P2P Interface Registered
[ 157.344792] dhd_attach thr:ca1 created
[ 157.344867] dhd_attach thr:ca1 started
[ 157.346305] dhd_attach thr:ca2 created
[ 157.346388] dhd_attach thr:ca2 started
[ 157.346488] dhd_attach thr:ca3 created
[ 157.346544] dhd_attach thr:ca3 started
[ 157.353090] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 157.353349] dhdsdio_probe : the lock is released.
[ 157.353505] ANDROID-ERROR) wifi_set_power = 0
[ 157.353606] rk29sdk_wifi_power: 0
[ 157.360153] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 157.603607] wifi shut off power
[ 157.715581] =========== WLAN placed in RESET ========
[ 157.789867]
[ 157.789893] Dongle Host Driver, version 1.28.23.5 (r)
[ 157.789909] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 157.790850] wl_android_wifi_on in
[ 157.790961] ANDROID-ERROR) wifi_set_power = 1
[ 157.791034] rk29sdk_wifi_power: 1
[ 158.077425] wifi turn on power
[ 158.182838] =========== WLAN going back to live ========
[ 158.182919] sdio_reset_comm():
[ 158.183018] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 158.190643] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 158.191265]
[ 158.191277]
[ 158.191282] dhd_bus_devreset: == WLAN ON ==
[ 158.191320] dhd_bus_devreset called when dongle is not in reset
[ 158.191357] Will call dhd_bus_start instead
[ 158.191465] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 158.191598] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 158.191635] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 158.191666] Final conf_path=/system/etc/firmware/config.txt
[ 158.284280] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 159.280157] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 160.280191] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 160.280208] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 160.280417] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 160.280435] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 160.280601] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 160.280617] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 161.280110] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 161.280122] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 161.280188] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 161.280198] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 161.280262] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 161.280271] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 161.280393] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 161.280403] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 161.280466] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 161.280475] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 161.280541] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 161.280550] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 161.280634] ANDROID-ERROR) wifi_set_power = 0
[ 161.280648] rk29sdk_wifi_power: 0
[ 161.484450] wifi shut off power
[ 161.585847] =========== WLAN placed in RESET ========
[ 161.585868] wl_android_wifi_on: Failed
[ 161.585880] wl_android_wifi_off in
[ 165.753535] standby rt5631
[ 173.091032] =======================================================
[ 173.091049] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 173.091063] =======================================================
[ 173.091101] net_ratelimit: 11 callbacks suppressed
[ 173.091112] dhdsdio_disconnect : no mutex held. set lock
[ 173.091127] bcmsdh_unregister_oob_intr: Enter
[ 173.091166] dhd_detach thr:ca3 terminated OK
[ 173.340355] dhd_detach thr:ca1 terminated OK
[ 173.340564] dhd_detach thr:ca2 terminated OK
[ 173.620260] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 173.620357] wl_destroy_event_handler thr:ca0 terminated OK
[ 173.781399] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 173.781578] dhdsdio_disconnect : the lock is released.
[ 173.781682] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 173.781837] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 173.782934] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 173.783636] ANDROID-ERROR) ## wifi_remove
[ 173.783679] ANDROID-ERROR) wifi_set_power = 0
[ 173.783719] rk29sdk_wifi_power: 0
[ 173.984616] wifi shut off power
[ 173.984630] ANDROID-ERROR) wifi_set_carddetect = 0
[ 173.984644] rk29sdk_wifi_set_carddetect:0
[ 173.984656] mmc1: slot status change detected(1-0)
[ 173.984815] mmc1: card 0001 removed
[ 173.984874]
[ 173.984878] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 173.985183] =========== WLAN placed in POWER OFF ========
[ 174.000052] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 177.901944] Current WiFi chip is AP6476.
[ 177.986663] =======================================================
[ 177.986780] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 177.986886] =======================================================
[ 177.986990] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 178.096622] =========== WLAN placed in POWER ON ========
[ 178.096984] ANDROID-ERROR) wifi_set_power = 1
[ 178.097050] rk29sdk_wifi_power: 1
[ 178.356501] wifi turn on power
[ 178.356516] ANDROID-ERROR) wifi_set_carddetect = 1
[ 178.356531] rk29sdk_wifi_set_carddetect:1
[ 178.356543] mmc1: slot status change detected(0-1)
[ 178.550133]
[ 178.550144] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 178.594036]
[ 178.594046] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 178.606267] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 178.608314] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 178.610395] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 178.614150] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 178.669414] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 178.671772] mmc1: new high speed SDIO card at address 0001
[ 178.672798] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 178.673193] dhdsdio_probe : no mutex held. set lock
[ 178.673225] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 178.673230] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 178.673319] F1 signature read @0x18000000=0x16044330
[ 178.696622] DHD: dongle ram size is set to 294912(orig 294912)
[ 178.697932] wl_create_event_handler thr:d3b created
[ 178.698140] wl_create_event_handler thr:d3b started
[ 178.700323] p2p0: P2P Interface Registered
[ 178.700446] dhd_attach thr:d3c created
[ 178.700731] dhd_attach thr:d3c started
[ 178.700814] dhd_attach thr:d3d created
[ 178.700922] dhd_attach thr:d3d started
[ 178.701047] dhd_attach thr:d3e created
[ 178.701192] dhd_attach thr:d3e started
[ 178.703194] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 178.703266] dhdsdio_probe : the lock is released.
[ 178.703345] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 178.703984]
[ 178.703991] Dongle Host Driver, version 1.28.23.5 (r)
[ 178.704004] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 178.704297] ANDROID-ERROR) wifi_set_power = 0
[ 178.704336] rk29sdk_wifi_power: 0
[ 178.906461] wifi shut off power
[ 179.007378] =========== WLAN placed in RESET ========
[ 179.040146]
[ 179.040154] Dongle Host Driver, version 1.28.23.5 (r)
[ 179.040165] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 179.040196] wl_android_wifi_on in
[ 179.040207] ANDROID-ERROR) wifi_set_power = 1
[ 179.040222] rk29sdk_wifi_power: 1
[ 179.292674] wifi turn on power
[ 179.393101] =========== WLAN going back to live ========
[ 179.393118] sdio_reset_comm():
[ 179.393141] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 179.398896] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 179.399179]
[ 179.399182]
[ 179.399184] dhd_bus_devreset: == WLAN ON ==
[ 179.399198] dhd_bus_devreset called when dongle is not in reset
[ 179.399211] Will call dhd_bus_start instead
[ 179.399255] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 179.399313] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 179.399326] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 179.399339] Final conf_path=/system/etc/firmware/config.txt
[ 179.440805] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 180.440071] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 180.440102] dhd_bus_init: clock state is wrong. state = 1
[ 180.440123] dhd_bus_start, dhd_bus_init failed -1
[ 180.440164] dhd_bus_devreset: dhd_bus_start fail with -1
[ 180.440185] dhd_dev_reset: dhd_bus_devreset: -1
[ 181.440356] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 181.440394] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 181.440852] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 181.440888] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 181.441266] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 181.441309] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 182.440315] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 182.440351] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 182.440563] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 182.440597] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 182.440783] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 182.440818] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 182.441151] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 182.441187] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 182.441386] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 182.441421] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 182.441596] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 182.441631] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 182.441842] ANDROID-ERROR) wifi_set_power = 0
[ 182.441885] rk29sdk_wifi_power: 0
[ 182.642313] wifi shut off power
[ 182.742517] =========== WLAN placed in RESET ========
[ 182.742532] wl_android_wifi_on: Failed
[ 182.742543] wl_android_wifi_off in
[ 186.373555] standby rt5631
[ 186.701044] binder: release 1706:1706 transaction 70076 out, still active
[ 186.712603] binder: 1576:1674 transaction failed 29189, size 316-0
[ 186.855479] binder: 1576:1576 transaction failed 29189, size 96-0
[ 187.095054] binder: 1576:1576 transaction failed 29189, size 84-0
[ 189.645807] binder: 1576:1593 transaction failed 29189, size 8-0
[ 189.645841] binder: send failed reply for transaction 70076, target dead
[ 189.846948] =======================================================
[ 189.846993] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 189.847033] =======================================================
[ 189.847103] net_ratelimit: 7 callbacks suppressed
[ 189.847133] dhdsdio_disconnect : no mutex held. set lock
[ 189.847161] bcmsdh_unregister_oob_intr: Enter
[ 189.847235] dhd_detach thr:d3e terminated OK
[ 189.970200] dhd_detach thr:d3c terminated OK
[ 189.970268] dhd_detach thr:d3d terminated OK
[ 190.080072] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 190.080110] wl_destroy_event_handler thr:d3b terminated OK
[ 190.120201] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 190.120327] dhdsdio_disconnect : the lock is released.
[ 190.120370] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 190.120423] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 190.120489] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 190.120578] ANDROID-ERROR) ## wifi_remove
[ 190.120597] ANDROID-ERROR) wifi_set_power = 0
[ 190.120618] rk29sdk_wifi_power: 0
[ 190.334926] wifi shut off power
[ 190.334971] ANDROID-ERROR) wifi_set_carddetect = 0
[ 190.335013] rk29sdk_wifi_set_carddetect:0
[ 190.335058] mmc1: slot status change detected(1-0)
[ 190.335800] mmc1: card 0001 removed
[ 190.335918]
[ 190.335923] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 190.336112] =========== WLAN placed in POWER OFF ========
[ 190.350156] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 190.489872] request_suspend_state: sleep (0->3) at 190439842522 (2011-01-03 17:25:34.448031271 UTC)
[ 190.490191] >>>>> ct36x_chip_go_sleep() called <<<<<
[ 190.536603] rk3188 lcdc0 clk disable...
[ 190.536654] ddrfreq: change auto self refresh to 1 when suspend
[ 190.537939] ddrfreq: change freq to 198 MHz when suspend
[ 191.129865] Current WiFi chip is AP6476.
[ 191.165958] =======================================================
[ 191.166046] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 191.166105] =======================================================
[ 191.166176] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 191.272280] =========== WLAN placed in POWER ON ========
[ 191.272417] ANDROID-ERROR) wifi_set_power = 1
[ 191.272446] rk29sdk_wifi_power: 1
[ 191.523196] wifi turn on power
[ 191.523216] ANDROID-ERROR) wifi_set_carddetect = 1
[ 191.523241] rk29sdk_wifi_set_carddetect:1
[ 191.523264] mmc1: slot status change detected(0-1)
[ 191.720194]
[ 191.720211] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 191.764165]
[ 191.764177] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 191.776723] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 191.778845] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 191.781025] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 191.784810] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 191.841633] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 191.845147] mmc1: new high speed SDIO card at address 0001
[ 191.852452] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 191.853208] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 191.855342] dhdsdio_probe : no mutex held. set lock
[ 191.855492] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 191.855522] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 191.855850] F1 signature read @0x18000000=0x16044330
[ 191.899426] DHD: dongle ram size is set to 294912(orig 294912)
[ 191.902734] wl_create_event_handler thr:dba created
[ 191.903092] wl_create_event_handler thr:dba started
[ 191.906944] p2p0: P2P Interface Registered
[ 191.907171] dhd_attach thr:dbb created
[ 191.907576] dhd_attach thr:dbb started
[ 191.907700] dhd_attach thr:dbc created
[ 191.907893] dhd_attach thr:dbc started
[ 191.908125] dhd_attach thr:dbd created
[ 191.908379] dhd_attach thr:dbd started
[ 191.911696] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 191.911829] dhdsdio_probe : the lock is released.
[ 191.912793]
[ 191.912805] Dongle Host Driver, version 1.28.23.5 (r)
[ 191.912820] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 191.912983] ANDROID-ERROR) wifi_set_power = 0
[ 191.913013] rk29sdk_wifi_power: 0
[ 192.117341] wifi shut off power
[ 192.218340] =========== WLAN placed in RESET ========
[ 192.420102] =======================================================
[ 192.420132] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 192.420154] =======================================================
[ 192.420216] dhdsdio_disconnect : no mutex held. set lock
[ 192.420237] bcmsdh_unregister_oob_intr: Enter
[ 192.420310] dhd_detach thr:dbd terminated OK
[ 192.570108] dhd_detach thr:dbb terminated OK
[ 192.570182] dhd_detach thr:dbc terminated OK
[ 192.820102] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 192.820144] wl_destroy_event_handler thr:dba terminated OK
[ 192.910398] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 192.910459] dhdsdio_disconnect : the lock is released.
[ 192.910496] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 192.910580] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 192.910682] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 192.910963] ANDROID-ERROR) ## wifi_remove
[ 192.910986] ANDROID-ERROR) wifi_set_power = 0
[ 192.911009] rk29sdk_wifi_power: 0
[ 193.113550] wifi shut off power
[ 193.113594] ANDROID-ERROR) wifi_set_carddetect = 0
[ 193.113647] rk29sdk_wifi_set_carddetect:0
[ 193.113680] mmc1: slot status change detected(1-0)
[ 193.114116] mmc1: card 0001 removed
[ 193.114306]
[ 193.114315] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 193.115142] =========== WLAN placed in POWER OFF ========
[ 193.130068] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 193.257528] request_suspend_state: wakeup (3->0) at 193207515024 (2011-01-03 17:25:37.215705648 UTC)
[ 193.257659] ddrfreq: change auto self refresh to 0 when normal
[ 193.257718] rk3188 lcdc0 clk enable...
[ 193.259073] ddrfreq: change freq to 576 MHz when normal
[ 193.283472] rk3188 lcdc1 clk enable...
[ 193.310514] rk3188 lcdc1 clk disable...
[ 193.350592] 000 clock detected by anx6345
[ 193.366247] HW LT Success>>:times:1
[ 193.378853] anx6345_init..lc:2--bw:10
[ 193.378886] ***anx6345_late_resume***
[ 193.486913] 123456hkw7890_resume
[ 194.649382] Current WiFi chip is AP6476.
[ 194.705659] =======================================================
[ 194.705720] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 194.705766] =======================================================
[ 194.705809] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 194.812045] =========== WLAN placed in POWER ON ========
[ 194.812137] ANDROID-ERROR) wifi_set_power = 1
[ 194.812155] rk29sdk_wifi_power: 1
[ 195.069040] wifi turn on power
[ 195.069056] ANDROID-ERROR) wifi_set_carddetect = 1
[ 195.069074] rk29sdk_wifi_set_carddetect:1
[ 195.069088] mmc1: slot status change detected(0-1)
[ 195.260085]
[ 195.260090] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 195.303948]
[ 195.303951] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 195.315283] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 195.317157] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 195.319067] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 195.322589] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 195.376325] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 195.378011] mmc1: new high speed SDIO card at address 0001
[ 195.378996] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 195.379196]
[ 195.379200] Dongle Host Driver, version 1.28.23.5 (r)
[ 195.379207] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 195.379989] dhdsdio_probe : no mutex held. set lock
[ 195.380048] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 195.380054] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 195.380152] F1 signature read @0x18000000=0x16044330
[ 195.405319] DHD: dongle ram size is set to 294912(orig 294912)
[ 195.406762] wl_create_event_handler thr:dc8 created
[ 195.406788] wl_create_event_handler thr:dc8 started
[ 195.409497] p2p0: P2P Interface Registered
[ 195.409592] dhd_attach thr:dc9 created
[ 195.409684] dhd_attach thr:dc9 started
[ 195.409731] dhd_attach thr:dca created
[ 195.410291] dhd_attach thr:dca started
[ 195.410340] dhd_attach thr:dcb created
[ 195.410358] dhd_attach thr:dcb started
[ 195.412422] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 195.412550] ANDROID-ERROR) wifi_set_power = 0
[ 195.412575] rk29sdk_wifi_power: 0
[ 195.420042] dhdsdio_probe : the lock is released.
[ 195.420075] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 195.617926] wifi shut off power
[ 195.719605] =========== WLAN placed in RESET ========
[ 195.753497]
[ 195.753503] Dongle Host Driver, version 1.28.23.5 (r)
[ 195.753509] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 195.753547] wl_android_wifi_on in
[ 195.753567] ANDROID-ERROR) wifi_set_power = 1
[ 195.753593] rk29sdk_wifi_power: 1
[ 195.951034] request_suspend_state: sleep (0->3) at 195901001649 (2011-01-03 17:25:39.909188523 UTC)
[ 195.951366] >>>>> ct36x_chip_go_sleep() called <<<<<
[ 195.997946] rk3188 lcdc0 clk disable...
[ 195.998025] ddrfreq: change auto self refresh to 1 when suspend
[ 195.999318] ddrfreq: change freq to 198 MHz when suspend
[ 196.041795] wifi turn on power
[ 196.165166] =========== WLAN going back to live ========
[ 196.165201] sdio_reset_comm():
[ 196.165259] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 196.171128] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 196.171491]
[ 196.171497]
[ 196.171503] dhd_bus_devreset: == WLAN ON ==
[ 196.171530] dhd_bus_devreset called when dongle is not in reset
[ 196.171552] Will call dhd_bus_start instead
[ 196.171634] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 196.171744] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 196.171768] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 196.171792] Final conf_path=/system/etc/firmware/config.txt
[ 196.217896] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 197.210097] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 198.210125] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 198.210141] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 198.210331] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 198.210346] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 198.210514] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 198.210527] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 198.552303] request_suspend_state: wakeup (3->0) at 198502272024 (2011-01-03 17:25:42.510461523 UTC)
[ 198.552567] ddrfreq: change auto self refresh to 0 when normal
[ 198.552863] rk3188 lcdc0 clk enable...
[ 198.578826] rk3188 lcdc1 clk enable...
[ 198.580441] ddrfreq: change freq to 576 MHz when normal
[ 198.607263] rk3188 lcdc1 clk disable...
[ 198.641741] 000 clock detected by anx6345
[ 198.660428] HW LT Success>>:times:1
[ 198.669882] anx6345_init..lc:2--bw:10
[ 198.669915] ***anx6345_late_resume***
[ 198.755347] 123456hkw7890_resume
[ 199.210326] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 199.210362] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 199.210549] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 199.210584] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 199.210762] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 199.210796] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 199.211103] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 199.211137] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 199.211314] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 199.211348] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 199.211523] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 199.211557] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 199.211767] ANDROID-ERROR) wifi_set_power = 0
[ 199.211812] rk29sdk_wifi_power: 0
[ 199.412401] wifi shut off power
[ 199.512586] =========== WLAN placed in RESET ========
[ 199.512600] wl_android_wifi_on: Failed
[ 199.512611] wl_android_wifi_off in
[ 211.092164] =======================================================
[ 211.092227] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 211.092290] =======================================================
[ 211.092374] net_ratelimit: 11 callbacks suppressed
[ 211.092403] dhdsdio_disconnect : no mutex held. set lock
[ 211.092440] bcmsdh_unregister_oob_intr: Enter
[ 211.092513] dhd_detach thr:dcb terminated OK
[ 211.210184] dhd_detach thr:dc9 terminated OK
[ 211.210293] dhd_detach thr:dca terminated OK
[ 211.360246] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 211.360338] wl_destroy_event_handler thr:dc8 terminated OK
[ 211.410564] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 211.410772] dhdsdio_disconnect : the lock is released.
[ 211.410868] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 211.411003] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 211.411177] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 211.411390] ANDROID-ERROR) ## wifi_remove
[ 211.411440] ANDROID-ERROR) wifi_set_power = 0
[ 211.411490] rk29sdk_wifi_power: 0
[ 211.621525] wifi shut off power
[ 211.621558] ANDROID-ERROR) wifi_set_carddetect = 0
[ 211.621583] rk29sdk_wifi_set_carddetect:0
[ 211.621606] mmc1: slot status change detected(1-0)
[ 211.621976] mmc1: card 0001 removed
[ 211.622141]
[ 211.622151] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 211.622513] =========== WLAN placed in POWER OFF ========
[ 211.640121] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 212.704515] standby rt5631
[ 215.897942] Current WiFi chip is AP6476.
[ 215.954403] =======================================================
[ 215.954463] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 215.954517] =======================================================
[ 215.954567] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 216.069058] =========== WLAN placed in POWER ON ========
[ 216.069199] ANDROID-ERROR) wifi_set_power = 1
[ 216.069230] rk29sdk_wifi_power: 1
[ 216.358707] wifi turn on power
[ 216.358746] ANDROID-ERROR) wifi_set_carddetect = 1
[ 216.358800] rk29sdk_wifi_set_carddetect:1
[ 216.358885] mmc1: slot status change detected(0-1)
[ 216.550204]
[ 216.550225] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 216.594286]
[ 216.594300] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 216.607336] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 216.610278] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 216.612407] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 216.616146] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 216.675883] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 216.679519] mmc1: new high speed SDIO card at address 0001
[ 216.683644] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 216.685041] dhdsdio_probe : no mutex held. set lock
[ 216.685198] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 216.685233] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 216.685582] F1 signature read @0x18000000=0x16044330
[ 216.736449] DHD: dongle ram size is set to 294912(orig 294912)
[ 216.739798] wl_create_event_handler thr:df2 created
[ 216.740925] wl_create_event_handler thr:df2 started
[ 216.751731] p2p0: P2P Interface Registered
[ 216.752284] dhd_attach thr:df3 created
[ 216.753457] dhd_attach thr:df3 started
[ 216.753883] dhd_attach thr:df4 created
[ 216.754861] dhd_attach thr:df4 started
[ 216.755286] dhd_attach thr:df5 created
[ 216.756067] dhd_attach thr:df5 started
[ 216.758257] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 216.758398] dhdsdio_probe : the lock is released.
[ 216.758574] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 216.762466]
[ 216.762497] Dongle Host Driver, version 1.28.23.5 (r)
[ 216.762556] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 216.763990] ANDROID-ERROR) wifi_set_power = 0
[ 216.764086] rk29sdk_wifi_power: 0
[ 217.008410] wifi shut off power
[ 217.112200] =========== WLAN placed in RESET ========
[ 217.154128]
[ 217.154142] Dongle Host Driver, version 1.28.23.5 (r)
[ 217.154164] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 217.154231] wl_android_wifi_on in
[ 217.154256] ANDROID-ERROR) wifi_set_power = 1
[ 217.154289] rk29sdk_wifi_power: 1
[ 217.424862] wifi turn on power
[ 217.531615] =========== WLAN going back to live ========
[ 217.531689] sdio_reset_comm():
[ 217.531740] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 217.537626] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 217.537999]
[ 217.538014]
[ 217.538025] dhd_bus_devreset: == WLAN ON ==
[ 217.538081] dhd_bus_devreset called when dongle is not in reset
[ 217.538137] Will call dhd_bus_start instead
[ 217.538221] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 217.538366] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 217.538413] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 217.538454] Final conf_path=/system/etc/firmware/config.txt
[ 217.596612] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 218.590321] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 219.590300] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 219.590414] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 219.590753] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 219.590844] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 219.591160] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 219.591264] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 220.590527] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 220.590649] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 220.591150] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 220.591276] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 220.591590] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 220.591680] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 220.592117] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 220.592240] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 220.592569] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 220.592724] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 220.593094] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 220.593250] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 220.593911] ANDROID-ERROR) wifi_set_power = 0
[ 220.594039] rk29sdk_wifi_power: 0
[ 220.816458] wifi shut off power
[ 220.922197] =========== WLAN placed in RESET ========
[ 220.922307] wl_android_wifi_on: Failed
[ 220.922352] wl_android_wifi_off in
[ 226.424091] standby rt5631
[ 232.504885] =======================================================
[ 232.505030] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 232.505119] =======================================================
[ 232.505279] net_ratelimit: 11 callbacks suppressed
[ 232.505340] dhdsdio_disconnect : no mutex held. set lock
[ 232.505424] bcmsdh_unregister_oob_intr: Enter
[ 232.505574] dhd_detach thr:df5 terminated OK
[ 232.640328] dhd_detach thr:df3 terminated OK
[ 232.640500] dhd_detach thr:df4 terminated OK
[ 232.760384] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 232.761009] wl_destroy_event_handler thr:df2 terminated OK
[ 232.872896] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 232.873203] dhdsdio_disconnect : the lock is released.
[ 232.873441] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 232.873705] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 232.874021] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 232.875248] ANDROID-ERROR) ## wifi_remove
[ 232.875341] ANDROID-ERROR) wifi_set_power = 0
[ 232.875442] rk29sdk_wifi_power: 0
[ 233.086033] wifi shut off power
[ 233.086122] ANDROID-ERROR) wifi_set_carddetect = 0
[ 233.086190] rk29sdk_wifi_set_carddetect:0
[ 233.086255] mmc1: slot status change detected(1-0)
[ 233.087230] mmc1: card 0001 removed
[ 233.087299] =========== WLAN placed in POWER OFF ========
[ 233.087606]
[ 233.087630] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 233.100284] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 233.592555] Current WiFi chip is AP6476.
[ 233.667454] =======================================================
[ 233.667583] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 233.667679] =======================================================
[ 233.667787] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 233.773767] =========== WLAN placed in POWER ON ========
[ 233.773971] ANDROID-ERROR) wifi_set_power = 1
[ 233.774022] rk29sdk_wifi_power: 1
[ 234.035566] wifi turn on power
[ 234.035626] ANDROID-ERROR) wifi_set_carddetect = 1
[ 234.035706] rk29sdk_wifi_set_carddetect:1
[ 234.035759] mmc1: slot status change detected(0-1)
[ 234.230306]
[ 234.230335] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 234.274319]
[ 234.274351] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 234.286685] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 234.289185] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 234.291305] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 234.294798] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 234.353205] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 234.355396] mmc1: new high speed SDIO card at address 0001
[ 234.362313] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 234.363759] dhdsdio_probe : no mutex held. set lock
[ 234.364092] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 234.364199] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 234.364706] F1 signature read @0x18000000=0x16044330
[ 234.406647] DHD: dongle ram size is set to 294912(orig 294912)
[ 234.416612] wl_create_event_handler thr:e1c created
[ 234.417246] wl_create_event_handler thr:e1c started
[ 234.424282] p2p0: P2P Interface Registered
[ 234.425897] dhd_attach thr:e1d created
[ 234.427543] dhd_attach thr:e1d started
[ 234.428003] dhd_attach thr:e1e created
[ 234.428338] dhd_attach thr:e1e started
[ 234.428877] dhd_attach thr:e1f created
[ 234.429300] dhd_attach thr:e1f started
[ 234.437418] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 234.437894] dhdsdio_probe : the lock is released.
[ 234.438405] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 234.440278]
[ 234.440337] Dongle Host Driver, version 1.28.23.5 (r)
[ 234.440502] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 234.440959] ANDROID-ERROR) wifi_set_power = 0
[ 234.441097] rk29sdk_wifi_power: 0
[ 234.659336] wifi shut off power
[ 234.771138] =========== WLAN placed in RESET ========
[ 234.828159]
[ 234.828181] Dongle Host Driver, version 1.28.23.5 (r)
[ 234.828228] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 234.828353] wl_android_wifi_on in
[ 234.828407] ANDROID-ERROR) wifi_set_power = 1
[ 234.828455] rk29sdk_wifi_power: 1
[ 235.101041] wifi turn on power
[ 235.208414] =========== WLAN going back to live ========
[ 235.208613] sdio_reset_comm():
[ 235.208789] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 235.217178] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 235.217592]
[ 235.217609]
[ 235.217627] dhd_bus_devreset: == WLAN ON ==
[ 235.217706] dhd_bus_devreset called when dongle is not in reset
[ 235.217779] Will call dhd_bus_start instead
[ 235.217894] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 235.218078] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 235.218168] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 235.218263] Final conf_path=/system/etc/firmware/config.txt
[ 237.270480] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 237.270589] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 237.270961] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 237.271072] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 237.271428] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 237.271660] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 238.270441] net_ratelimit: 8 callbacks suppressed
[ 238.270568] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 238.270931] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 238.271084] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 238.271443] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 238.271694] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 238.272604] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 238.272749] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 238.273039] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4123
[ 238.273368] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 238.273513] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 238.273841] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 238.274009] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 238.274330] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 238.274487] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 238.274780] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4143
[ 238.274917] dhd_bus_devreset: WLAN OFF DONE
[ 238.275081] ANDROID-ERROR) wifi_set_power = 0
[ 238.275181] rk29sdk_wifi_power: 0
[ 238.492909] wifi shut off power
[ 238.600516] =========== WLAN placed in RESET ========
[ 238.600588] wl_android_wifi_on: Failed
[ 238.600637] dhd_open: failed with code -1
[ 238.600684] wl_android_wifi_off in
[ 250.172950] =======================================================
[ 250.173086] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 250.173210] =======================================================
[ 250.173457] dhdsdio_disconnect : no mutex held. set lock
[ 250.173585] bcmsdh_unregister_oob_intr: Enter
[ 250.173825] dhd_detach thr:e1f terminated OK
[ 250.330720] dhd_detach thr:e1d terminated OK
[ 250.331124] dhd_detach thr:e1e terminated OK
[ 250.420536] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 250.420806] wl_destroy_event_handler thr:e1c terminated OK
[ 250.451421] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 250.451666] dhdsdio_disconnect : the lock is released.
[ 250.451812] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 250.452055] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 250.452332] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 250.453187] ANDROID-ERROR) ## wifi_remove
[ 250.453267] ANDROID-ERROR) wifi_set_power = 0
[ 250.453627] rk29sdk_wifi_power: 0
[ 250.678272] wifi shut off power
[ 250.678348] ANDROID-ERROR) wifi_set_carddetect = 0
[ 250.678432] rk29sdk_wifi_set_carddetect:0
[ 250.678498] mmc1: slot status change detected(1-0)
[ 250.679572] mmc1: card 0001 removed
[ 250.679750] =========== WLAN placed in POWER OFF ========
[ 250.679871]
[ 250.679886] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 250.690215] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 251.194057] Current WiFi chip is AP6476.
[ 251.271766] =======================================================
[ 251.271868] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 251.271958] =======================================================
[ 251.272052] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 251.376322] =========== WLAN placed in POWER ON ========
[ 251.376673] ANDROID-ERROR) wifi_set_power = 1
[ 251.376805] rk29sdk_wifi_power: 1
[ 251.633636] wifi turn on power
[ 251.633701] ANDROID-ERROR) wifi_set_carddetect = 1
[ 251.633770] rk29sdk_wifi_set_carddetect:1
[ 251.633830] mmc1: slot status change detected(0-1)
[ 251.830366]
[ 251.830381] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 251.874227]
[ 251.874242] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 251.886970] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 251.888946] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 251.890938] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 251.894446] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 251.950357] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 251.952760] mmc1: new high speed SDIO card at address 0001
[ 251.959727] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 251.959891] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 251.961381] dhdsdio_probe : no mutex held. set lock
[ 251.961537] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 251.961598] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 251.961995] F1 signature read @0x18000000=0x16044330
[ 252.005605] DHD: dongle ram size is set to 294912(orig 294912)
[ 252.013693] wl_create_event_handler thr:e40 created
[ 252.014373] wl_create_event_handler thr:e40 started
[ 252.020924] p2p0: P2P Interface Registered
[ 252.022123] dhd_attach thr:e41 created
[ 252.023003] dhd_attach thr:e41 started
[ 252.024835] dhd_attach thr:e42 created
[ 252.025386] dhd_attach thr:e42 started
[ 252.025821] dhd_attach thr:e43 created
[ 252.026152] dhd_attach thr:e43 started
[ 252.032078] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 252.032790] dhdsdio_probe : the lock is released.
[ 252.034229]
[ 252.034264] Dongle Host Driver, version 1.28.23.5 (r)
[ 252.034379] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 252.034816] ANDROID-ERROR) wifi_set_power = 0
[ 252.034927] rk29sdk_wifi_power: 0
[ 252.253330] wifi shut off power
[ 252.359271] =========== WLAN placed in RESET ========
[ 252.448506]
[ 252.448552] Dongle Host Driver, version 1.28.23.5 (r)
[ 252.448664] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 252.448869] wl_android_wifi_on in
[ 252.448925] ANDROID-ERROR) wifi_set_power = 1
[ 252.449034] rk29sdk_wifi_power: 1
[ 252.715503] wifi turn on power
[ 252.827716] =========== WLAN going back to live ========
[ 252.827807] sdio_reset_comm():
[ 252.827871] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 252.834945] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 252.835384]
[ 252.835416]
[ 252.835428] dhd_bus_devreset: == WLAN ON ==
[ 252.835514] dhd_bus_devreset called when dongle is not in reset
[ 252.835603] Will call dhd_bus_start instead
[ 252.835707] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 252.835881] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 252.835959] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 252.836034] Final conf_path=/system/etc/firmware/config.txt
[ 254.890167] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 254.890185] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 254.890394] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 254.890412] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 254.890586] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 254.890602] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 255.890150] net_ratelimit: 8 callbacks suppressed
[ 255.890205] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 255.890412] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 255.890447] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 255.890651] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 255.890686] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 255.890862] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 255.890897] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 255.891028] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4123
[ 255.891274] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 255.891309] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 255.891513] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 255.891551] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 255.891732] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 255.891766] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 255.891897] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4143
[ 255.891950] dhd_bus_devreset: WLAN OFF DONE
[ 255.892057] ANDROID-ERROR) wifi_set_power = 0
[ 255.892101] rk29sdk_wifi_power: 0
[ 256.093700] wifi shut off power
[ 256.200640] =========== WLAN placed in RESET ========
[ 256.200670] wl_android_wifi_on: Failed
[ 256.200692] dhd_open: failed with code -1
[ 256.200710] wl_android_wifi_off in
[ 267.647889] =======================================================
[ 267.647941] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 267.647982] =======================================================
[ 267.648081] dhdsdio_disconnect : no mutex held. set lock
[ 267.648124] bcmsdh_unregister_oob_intr: Enter
[ 267.648255] dhd_detach thr:e43 terminated OK
[ 267.910099] dhd_detach thr:e41 terminated OK
[ 267.910142] dhd_detach thr:e42 terminated OK
[ 268.200054] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 268.200118] wl_destroy_event_handler thr:e40 terminated OK
[ 268.290276] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 268.290327] dhdsdio_disconnect : the lock is released.
[ 268.290358] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 268.290398] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 268.290452] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 268.290615] ANDROID-ERROR) ## wifi_remove
[ 268.290628] ANDROID-ERROR) wifi_set_power = 0
[ 268.290640] rk29sdk_wifi_power: 0
[ 268.494808] wifi shut off power
[ 268.494821] ANDROID-ERROR) wifi_set_carddetect = 0
[ 268.494834] rk29sdk_wifi_set_carddetect:0
[ 268.494846] mmc1: slot status change detected(1-0)
[ 268.495124] mmc1: card 0001 removed
[ 268.495206]
[ 268.495209] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 268.495272] =========== WLAN placed in POWER OFF ========
[ 268.510053] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 269.002121] Current WiFi chip is AP6476.
[ 269.054377] =======================================================
[ 269.054422] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 269.054458] =======================================================
[ 269.054497] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 269.161416] =========== WLAN placed in POWER ON ========
[ 269.161554] ANDROID-ERROR) wifi_set_power = 1
[ 269.161579] rk29sdk_wifi_power: 1
[ 269.418789] wifi turn on power
[ 269.418814] ANDROID-ERROR) wifi_set_carddetect = 1
[ 269.418846] rk29sdk_wifi_set_carddetect:1
[ 269.418869] mmc1: slot status change detected(0-1)
[ 269.610028]
[ 269.610032] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 269.653864]
[ 269.653867] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 269.664986] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 269.666851] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 269.668717] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 269.672081] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 269.725375] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 269.727488] mmc1: new high speed SDIO card at address 0001
[ 269.729101] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 269.729734] dhdsdio_probe : no mutex held. set lock
[ 269.729789] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 269.729798] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 269.729932] F1 signature read @0x18000000=0x16044330
[ 269.756318] DHD: dongle ram size is set to 294912(orig 294912)
[ 269.757647] wl_create_event_handler thr:e5d created
[ 269.757833] wl_create_event_handler thr:e5d started
[ 269.760334] p2p0: P2P Interface Registered
[ 269.760466] dhd_attach thr:e5e created
[ 269.760735] dhd_attach thr:e5e started
[ 269.760805] dhd_attach thr:e5f created
[ 269.760882] dhd_attach thr:e5f started
[ 269.760982] dhd_attach thr:e60 created
[ 269.761084] dhd_attach thr:e60 started
[ 269.763537] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 269.763594] dhdsdio_probe : the lock is released.
[ 269.763662] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 269.764452]
[ 269.764461] Dongle Host Driver, version 1.28.23.5 (r)
[ 269.764473] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 269.764620] ANDROID-ERROR) wifi_set_power = 0
[ 269.764643] rk29sdk_wifi_power: 0
[ 269.966067] wifi shut off power
[ 270.067294] =========== WLAN placed in RESET ========
[ 270.106639]
[ 270.106650] Dongle Host Driver, version 1.28.23.5 (r)
[ 270.106664] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 270.106729] wl_android_wifi_on in
[ 270.106750] ANDROID-ERROR) wifi_set_power = 1
[ 270.106778] rk29sdk_wifi_power: 1
[ 270.366947] wifi turn on power
[ 270.469854] =========== WLAN going back to live ========
[ 270.469878] sdio_reset_comm():
[ 270.469903] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 270.477949] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 270.478420]
[ 270.478425]
[ 270.478429] dhd_bus_devreset: == WLAN ON ==
[ 270.478453] dhd_bus_devreset called when dongle is not in reset
[ 270.478489] Will call dhd_bus_start instead
[ 270.478585] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 270.478730] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 270.478757] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 270.478784] Final conf_path=/system/etc/firmware/config.txt
[ 272.520271] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 272.520338] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 272.520740] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 272.520811] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 272.521177] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 272.521248] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 273.520160] net_ratelimit: 8 callbacks suppressed
[ 273.520235] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 273.520484] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 273.520553] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 273.520792] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 273.520864] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 273.521103] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 273.521176] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 273.521366] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4123
[ 273.523205] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 273.523276] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 273.525114] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 273.525187] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 273.525427] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 273.525498] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 273.525726] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4143
[ 273.525817] dhd_bus_devreset: WLAN OFF DONE
[ 273.525948] ANDROID-ERROR) wifi_set_power = 0
[ 273.526011] rk29sdk_wifi_power: 0
[ 273.785684] wifi shut off power
[ 273.892450] =========== WLAN placed in RESET ========
[ 273.892485] wl_android_wifi_on: Failed
[ 273.892507] dhd_open: failed with code -1
[ 273.892530] wl_android_wifi_off in
[ 285.343581] =======================================================
[ 285.343634] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 285.343674] =======================================================
[ 285.343771] dhdsdio_disconnect : no mutex held. set lock
[ 285.343813] bcmsdh_unregister_oob_intr: Enter
[ 285.343952] dhd_detach thr:e60 terminated OK
[ 285.490191] dhd_detach thr:e5e terminated OK
[ 285.490393] dhd_detach thr:e5f terminated OK
[ 285.720155] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 285.720333] wl_destroy_event_handler thr:e5d terminated OK
[ 285.801070] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 285.801196] dhdsdio_disconnect : the lock is released.
[ 285.801276] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 285.801395] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 285.801650] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 285.802317] ANDROID-ERROR) ## wifi_remove
[ 285.802358] ANDROID-ERROR) wifi_set_power = 0
[ 285.802399] rk29sdk_wifi_power: 0
[ 286.042938] wifi shut off power
[ 286.043308] ANDROID-ERROR) wifi_set_carddetect = 0
[ 286.043678] rk29sdk_wifi_set_carddetect:0
[ 286.044078] mmc1: slot status change detected(1-0)
[ 286.045941] mmc1: card 0001 removed
[ 286.046888]
[ 286.046926] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 286.048384] =========== WLAN placed in POWER OFF ========
[ 286.060331] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 286.553648] Current WiFi chip is AP6476.
[ 286.581403] =======================================================
[ 286.581436] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 286.581460] =======================================================
[ 286.581480] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 286.690370] =========== WLAN placed in POWER ON ========
[ 286.690830] ANDROID-ERROR) wifi_set_power = 1
[ 286.690927] rk29sdk_wifi_power: 1
[ 286.956469] wifi turn on power
[ 286.956630] ANDROID-ERROR) wifi_set_carddetect = 1
[ 286.956772] rk29sdk_wifi_set_carddetect:1
[ 286.956885] mmc1: slot status change detected(0-1)
[ 287.150082]
[ 287.150088] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 287.194415]
[ 287.194477] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 287.211963] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 287.214879] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 287.217300] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 287.222512] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 287.293630] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 287.296006] mmc1: new high speed SDIO card at address 0001
[ 287.299741] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 287.301644] dhdsdio_probe : no mutex held. set lock
[ 287.302090] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 287.302191] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 287.302797] F1 signature read @0x18000000=0x16044330
[ 287.348574] DHD: dongle ram size is set to 294912(orig 294912)
[ 287.356930] wl_create_event_handler thr:eb7 created
[ 287.357762] wl_create_event_handler thr:eb7 started
[ 287.365438] p2p0: P2P Interface Registered
[ 287.366081] dhd_attach thr:eb8 created
[ 287.366590] dhd_attach thr:eb8 started
[ 287.367042] dhd_attach thr:eb9 created
[ 287.367498] dhd_attach thr:eb9 started
[ 287.367948] dhd_attach thr:eba created
[ 287.368505] dhd_attach thr:eba started
[ 287.371616] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 287.372127] dhdsdio_probe : the lock is released.
[ 287.372398] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 287.373273]
[ 287.373327] Dongle Host Driver, version 1.28.23.5 (r)
[ 287.373531] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 287.374231] ANDROID-ERROR) wifi_set_power = 0
[ 287.374467] rk29sdk_wifi_power: 0
[ 287.587563] wifi shut off power
[ 287.690840] =========== WLAN placed in RESET ========
[ 287.782208]
[ 287.782281] Dongle Host Driver, version 1.28.23.5 (r)
[ 287.782404] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 287.782990] wl_android_wifi_on in
[ 287.783230] ANDROID-ERROR) wifi_set_power = 1
[ 287.783497] rk29sdk_wifi_power: 1
[ 288.056680] wifi turn on power
[ 288.159071] =========== WLAN going back to live ========
[ 288.159119] sdio_reset_comm():
[ 288.159165] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 288.165110] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 288.165462]
[ 288.165469]
[ 288.165478] dhd_bus_devreset: == WLAN ON ==
[ 288.165516] dhd_bus_devreset called when dongle is not in reset
[ 288.165558] Will call dhd_bus_start instead
[ 288.165627] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 288.165743] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 288.165788] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 288.165833] Final conf_path=/system/etc/firmware/config.txt
[ 290.210251] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 290.210288] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 290.210598] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 290.210633] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 290.210936] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 290.210970] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 291.210275] net_ratelimit: 8 callbacks suppressed
[ 291.210333] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 291.210495] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 291.210567] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 291.210758] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 291.210842] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 291.211026] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 291.211123] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 291.211286] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4123
[ 291.211438] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 291.211505] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 291.211667] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 291.211739] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 291.211930] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 291.212030] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 291.212207] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4143
[ 291.212290] dhd_bus_devreset: WLAN OFF DONE
[ 291.212371] ANDROID-ERROR) wifi_set_power = 0
[ 291.212416] rk29sdk_wifi_power: 0
[ 291.462671] wifi shut off power
[ 291.566811] =========== WLAN placed in RESET ========
[ 291.566847] wl_android_wifi_on: Failed
[ 291.566876] dhd_open: failed with code -1
[ 291.566901] wl_android_wifi_off in
[ 298.610412] init: untracked pid 3868 exited with status 0
[ 301.746655] init: untracked pid 3934 exited with status 221
[ 301.988999] init: untracked pid 3937 exited with status 0
[ 303.059593] =======================================================
[ 303.059619] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 303.059634] =======================================================
[ 303.059682] dhdsdio_disconnect : no mutex held. set lock
[ 303.059700] bcmsdh_unregister_oob_intr: Enter
[ 303.059752] dhd_detach thr:eba terminated OK
[ 303.210121] dhd_detach thr:eb8 terminated OK
[ 303.210198] dhd_detach thr:eb9 terminated OK
[ 303.390180] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 303.390273] wl_destroy_event_handler thr:eb7 terminated OK
[ 303.450805] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 303.450953] dhdsdio_disconnect : the lock is released.
[ 303.451037] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 303.451160] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 303.451316] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 303.451931] ANDROID-ERROR) ## wifi_remove
[ 303.451973] ANDROID-ERROR) wifi_set_power = 0
[ 303.452014] rk29sdk_wifi_power: 0
[ 303.653260] wifi shut off power
[ 303.653276] ANDROID-ERROR) wifi_set_carddetect = 0
[ 303.653290] rk29sdk_wifi_set_carddetect:0
[ 303.653303] mmc1: slot status change detected(1-0)
[ 303.653598] mmc1: card 0001 removed
[ 303.653678]
[ 303.653681] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 303.653741] =========== WLAN placed in POWER OFF ========
[ 303.670038] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 304.163775] Current WiFi chip is AP6476.
[ 304.211351] =======================================================
[ 304.211394] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 304.211429] =======================================================
[ 304.211464] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 304.319149] =========== WLAN placed in POWER ON ========
[ 304.319290] ANDROID-ERROR) wifi_set_power = 1
[ 304.319341] rk29sdk_wifi_power: 1
[ 304.579672] wifi turn on power
[ 304.579696] ANDROID-ERROR) wifi_set_carddetect = 1
[ 304.579725] rk29sdk_wifi_set_carddetect:1
[ 304.579749] mmc1: slot status change detected(0-1)
[ 304.770273]
[ 304.770292] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 304.814042]
[ 304.814055] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 304.827304] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 304.829657] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 304.832059] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 304.836376] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 304.898532] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 304.902363] mmc1: new high speed SDIO card at address 0001
[ 304.906502] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 304.907824] dhdsdio_probe : no mutex held. set lock
[ 304.907974] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 304.908006] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 304.908324] F1 signature read @0x18000000=0x16044330
[ 304.955125] DHD: dongle ram size is set to 294912(orig 294912)
[ 304.958271] wl_create_event_handler thr:f76 created
[ 304.958722] wl_create_event_handler thr:f76 started
[ 304.963806] p2p0: P2P Interface Registered
[ 304.964104] dhd_attach thr:f77 created
[ 304.964680] dhd_attach thr:f77 started
[ 304.964832] dhd_attach thr:f78 created
[ 304.964978] dhd_attach thr:f78 started
[ 304.965174] dhd_attach thr:f79 created
[ 304.965347] dhd_attach thr:f79 started
[ 304.970601] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 304.970689] dhdsdio_probe : the lock is released.
[ 304.970791] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 304.972248]
[ 304.972269] Dongle Host Driver, version 1.28.23.5 (r)
[ 304.972305] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 304.972569] ANDROID-ERROR) wifi_set_power = 0
[ 304.972660] rk29sdk_wifi_power: 0
[ 305.190392] wifi shut off power
[ 305.297420] =========== WLAN placed in RESET ========
[ 305.339161]
[ 305.339170] Dongle Host Driver, version 1.28.23.5 (r)
[ 305.339181] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 305.339238] wl_android_wifi_on in
[ 305.339259] ANDROID-ERROR) wifi_set_power = 1
[ 305.339284] rk29sdk_wifi_power: 1
[ 305.602470] wifi turn on power
[ 305.709589] =========== WLAN going back to live ========
[ 305.709633] sdio_reset_comm():
[ 305.709671] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 305.715550] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 305.715873]
[ 305.715879]
[ 305.715882] dhd_bus_devreset: == WLAN ON ==
[ 305.715915] dhd_bus_devreset called when dongle is not in reset
[ 305.715940] Will call dhd_bus_start instead
[ 305.715999] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 305.716088] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 305.716115] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 305.716143] Final conf_path=/system/etc/firmware/config.txt
[ 307.760266] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 307.760303] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 307.760614] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 307.760650] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 307.760946] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 307.760980] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 308.770242] net_ratelimit: 8 callbacks suppressed
[ 308.770526] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 308.770777] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 308.770827] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 308.771048] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 308.771094] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 308.771302] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 308.771348] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 308.771506] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4123
[ 308.771776] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 308.771824] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 308.772100] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 308.772149] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 308.772360] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 308.772411] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 308.772754] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4143
[ 308.772820] dhd_bus_devreset: WLAN OFF DONE
[ 308.772943] ANDROID-ERROR) wifi_set_power = 0
[ 308.773005] rk29sdk_wifi_power: 0
[ 308.988496] wifi shut off power
[ 309.094861] =========== WLAN placed in RESET ========
[ 309.094916] wl_android_wifi_on: Failed
[ 309.094951] dhd_open: failed with code -1
[ 309.094980] wl_android_wifi_off in
[ 320.657016] =======================================================
[ 320.657043] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 320.657064] =======================================================
[ 320.657119] dhdsdio_disconnect : no mutex held. set lock
[ 320.657141] bcmsdh_unregister_oob_intr: Enter
[ 320.657281] dhd_detach thr:f79 terminated OK
[ 320.830118] dhd_detach thr:f77 terminated OK
[ 320.830168] dhd_detach thr:f78 terminated OK
[ 320.970057] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 320.970089] wl_destroy_event_handler thr:f76 terminated OK
[ 321.100254] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 321.100359] dhdsdio_disconnect : the lock is released.
[ 321.100417] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 321.100493] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 321.100584] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 321.100711] ANDROID-ERROR) ## wifi_remove
[ 321.100743] ANDROID-ERROR) wifi_set_power = 0
[ 321.100771] rk29sdk_wifi_power: 0
[ 321.300849] wifi shut off power
[ 321.300862] ANDROID-ERROR) wifi_set_carddetect = 0
[ 321.300877] rk29sdk_wifi_set_carddetect:0
[ 321.300888] mmc1: slot status change detected(1-0)
[ 321.301167] mmc1: card 0001 removed
[ 321.301262]
[ 321.301265] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 321.301337] =========== WLAN placed in POWER OFF ========
[ 321.320030] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 321.804112] Current WiFi chip is AP6476.
[ 321.847920] =======================================================
[ 321.847947] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 321.847968] =======================================================
[ 321.847991] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 321.948582] =========== WLAN placed in POWER ON ========
[ 321.948652] ANDROID-ERROR) wifi_set_power = 1
[ 321.948668] rk29sdk_wifi_power: 1
[ 322.199322] wifi turn on power
[ 322.199335] ANDROID-ERROR) wifi_set_carddetect = 1
[ 322.199348] rk29sdk_wifi_set_carddetect:1
[ 322.199359] mmc1: slot status change detected(0-1)
[ 322.390096]
[ 322.390106] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 322.434021]
[ 322.434031] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 322.445982] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 322.447917] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 322.449826] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 322.453282] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 322.505489] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 322.507093] mmc1: new high speed SDIO card at address 0001
[ 322.507965] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 322.508143]
[ 322.508146] Dongle Host Driver, version 1.28.23.5 (r)
[ 322.508152] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 322.508867] dhdsdio_probe : no mutex held. set lock
[ 322.508897] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 322.508903] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 322.508989] F1 signature read @0x18000000=0x16044330
[ 322.532103] DHD: dongle ram size is set to 294912(orig 294912)
[ 322.533327] wl_create_event_handler thr:f8a created
[ 322.533348] wl_create_event_handler thr:f8a started
[ 322.535365] p2p0: P2P Interface Registered
[ 322.535450] dhd_attach thr:f8b created
[ 322.535481] dhd_attach thr:f8b started
[ 322.535523] dhd_attach thr:f8c created
[ 322.535551] dhd_attach thr:f8c started
[ 322.535604] dhd_attach thr:f8d created
[ 322.535630] dhd_attach thr:f8d started
[ 322.537523] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 322.537685] ANDROID-ERROR) wifi_set_power = 0
[ 322.537724] rk29sdk_wifi_power: 0
[ 322.540246] dhdsdio_probe : the lock is released.
[ 322.540288] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 322.738801] wifi shut off power
[ 322.763571] standby rt5631
[ 322.846730] =========== WLAN placed in RESET ========
[ 322.875315]
[ 322.875318] Dongle Host Driver, version 1.28.23.5 (r)
[ 322.875324] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 322.875351] wl_android_wifi_on in
[ 322.875360] ANDROID-ERROR) wifi_set_power = 1
[ 322.875375] rk29sdk_wifi_power: 1
[ 323.129471] wifi turn on power
[ 323.229623] =========== WLAN going back to live ========
[ 323.229641] sdio_reset_comm():
[ 323.229664] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 323.235445] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 323.235778]
[ 323.235781]
[ 323.235784] dhd_bus_devreset: == WLAN ON ==
[ 323.235798] dhd_bus_devreset called when dongle is not in reset
[ 323.235811] Will call dhd_bus_start instead
[ 323.235858] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 323.235916] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 323.235930] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 323.235943] Final conf_path=/system/etc/firmware/config.txt
[ 325.270206] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 325.270242] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 325.270552] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 325.270587] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 325.270881] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 325.270916] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 326.270131] net_ratelimit: 8 callbacks suppressed
[ 326.270177] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 326.270387] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 326.270421] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 326.270604] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 326.270638] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 326.270822] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 326.270856] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 326.270990] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4123
[ 326.271216] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 326.271250] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 326.271428] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 326.271463] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 326.271637] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 326.271671] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 326.271799] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4143
[ 326.271855] dhd_bus_devreset: WLAN OFF DONE
[ 326.271960] ANDROID-ERROR) wifi_set_power = 0
[ 326.272003] rk29sdk_wifi_power: 0
[ 326.472309] wifi shut off power
[ 326.572507] =========== WLAN placed in RESET ========
[ 326.572522] wl_android_wifi_on: Failed
[ 326.572534] dhd_open: failed with code -1
[ 326.572544] wl_android_wifi_off in
[ 337.323563] standby rt5631
[ 338.091918] =======================================================
[ 338.091971] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 338.092026] =======================================================
[ 338.092125] dhdsdio_disconnect : no mutex held. set lock
[ 338.092167] bcmsdh_unregister_oob_intr: Enter
[ 338.092277] dhd_detach thr:f8d terminated OK
[ 338.260096] dhd_detach thr:f8b terminated OK
[ 338.260198] dhd_detach thr:f8c terminated OK
[ 338.550053] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 338.550114] wl_destroy_event_handler thr:f8a terminated OK
[ 338.640267] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 338.640319] dhdsdio_disconnect : the lock is released.
[ 338.640351] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 338.640393] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 338.640447] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 338.640609] ANDROID-ERROR) ## wifi_remove
[ 338.640621] ANDROID-ERROR) wifi_set_power = 0
[ 338.640633] rk29sdk_wifi_power: 0
[ 338.841103] wifi shut off power
[ 338.841116] ANDROID-ERROR) wifi_set_carddetect = 0
[ 338.841129] rk29sdk_wifi_set_carddetect:0
[ 338.841141] mmc1: slot status change detected(1-0)
[ 338.841421] mmc1: card 0001 removed
[ 338.841509] =========== WLAN placed in POWER OFF ========
[ 338.841565]
[ 338.841568] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 338.860222] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 339.345066] Current WiFi chip is AP6476.
[ 339.374777] =======================================================
[ 339.374803] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 339.374828] =======================================================
[ 339.374856] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 339.475563] =========== WLAN placed in POWER ON ========
[ 339.475625] ANDROID-ERROR) wifi_set_power = 1
[ 339.475638] rk29sdk_wifi_power: 1
[ 339.726218] wifi turn on power
[ 339.726230] ANDROID-ERROR) wifi_set_carddetect = 1
[ 339.726244] rk29sdk_wifi_set_carddetect:1
[ 339.726256] mmc1: slot status change detected(0-1)
[ 339.920088]
[ 339.920098] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 339.964040]
[ 339.964050] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 339.976516] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 339.978624] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 339.980744] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 339.984508] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 340.041590] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 340.045018] mmc1: new high speed SDIO card at address 0001
[ 340.047317] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 340.047577]
[ 340.047581] Dongle Host Driver, version 1.28.23.5 (r)
[ 340.047591] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 340.048708] dhdsdio_probe : no mutex held. set lock
[ 340.048761] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 340.048771] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 340.048904] F1 signature read @0x18000000=0x16044330
[ 340.081491] DHD: dongle ram size is set to 294912(orig 294912)
[ 340.083255] wl_create_event_handler thr:f9d created
[ 340.083283] wl_create_event_handler thr:f9d started
[ 340.085962] p2p0: P2P Interface Registered
[ 340.086061] dhd_attach thr:f9e created
[ 340.086127] dhd_attach thr:f9e started
[ 340.086182] dhd_attach thr:f9f created
[ 340.086213] dhd_attach thr:f9f started
[ 340.086266] dhd_attach thr:fa0 created
[ 340.086295] dhd_attach thr:fa0 started
[ 340.088713] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 340.088857] ANDROID-ERROR) wifi_set_power = 0
[ 340.088883] rk29sdk_wifi_power: 0
[ 340.095644] dhdsdio_probe : the lock is released.
[ 340.095699] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 340.289466] wifi shut off power
[ 340.389684] =========== WLAN placed in RESET ========
[ 340.416388]
[ 340.416394] Dongle Host Driver, version 1.28.23.5 (r)
[ 340.416401] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 340.416434] wl_android_wifi_on in
[ 340.416446] ANDROID-ERROR) wifi_set_power = 1
[ 340.416464] rk29sdk_wifi_power: 1
[ 340.667766] wifi turn on power
[ 340.768096] =========== WLAN going back to live ========
[ 340.768112] sdio_reset_comm():
[ 340.768135] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 340.773917] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 340.774246]
[ 340.774249]
[ 340.774251] dhd_bus_devreset: == WLAN ON ==
[ 340.774267] dhd_bus_devreset called when dongle is not in reset
[ 340.774279] Will call dhd_bus_start instead
[ 340.774327] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 340.774388] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 340.774402] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 340.774416] Final conf_path=/system/etc/firmware/config.txt
[ 342.810230] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 342.810267] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 342.810576] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 342.810612] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 342.810906] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 342.810941] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 343.810152] net_ratelimit: 8 callbacks suppressed
[ 343.810199] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 343.810410] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 343.810445] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 343.810627] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 343.810661] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 343.810838] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 343.810872] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 343.811004] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4123
[ 343.811227] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 343.811261] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 343.811436] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 343.811470] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 343.811644] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 343.811679] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 343.811808] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4143
[ 343.811905] dhd_bus_devreset: WLAN OFF DONE
[ 343.812019] ANDROID-ERROR) wifi_set_power = 0
[ 343.812063] rk29sdk_wifi_power: 0
[ 344.012285] wifi shut off power
[ 344.112509] =========== WLAN placed in RESET ========
[ 344.112525] wl_android_wifi_on: Failed
[ 344.112536] dhd_open: failed with code -1
[ 344.112546] wl_android_wifi_off in
[ 355.642259] =======================================================
[ 355.642311] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 355.642351] =======================================================
[ 355.642454] dhdsdio_disconnect : no mutex held. set lock
[ 355.642495] bcmsdh_unregister_oob_intr: Enter
[ 355.642627] dhd_detach thr:fa0 terminated OK
[ 355.920211] dhd_detach thr:f9e terminated OK
[ 355.920387] dhd_detach thr:f9f terminated OK
[ 356.200256] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 356.200354] wl_destroy_event_handler thr:f9d terminated OK
[ 356.370858] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 356.370967] dhdsdio_disconnect : the lock is released.
[ 356.371048] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 356.371169] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 356.371326] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 356.371917] ANDROID-ERROR) ## wifi_remove
[ 356.371956] ANDROID-ERROR) wifi_set_power = 0
[ 356.371998] rk29sdk_wifi_power: 0
[ 356.572545] wifi shut off power
[ 356.572559] ANDROID-ERROR) wifi_set_carddetect = 0
[ 356.572572] rk29sdk_wifi_set_carddetect:0
[ 356.572583] mmc1: slot status change detected(1-0)
[ 356.572739] mmc1: card 0001 removed
[ 356.572801]
[ 356.572804] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 356.573115] =========== WLAN placed in POWER OFF ========
[ 356.590036] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 357.077414] Current WiFi chip is AP6476.
[ 357.115618] =======================================================
[ 357.115645] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 357.115665] =======================================================
[ 357.115688] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 357.216468] =========== WLAN placed in POWER ON ========
[ 357.216529] ANDROID-ERROR) wifi_set_power = 1
[ 357.216543] rk29sdk_wifi_power: 1
[ 357.467460] wifi turn on power
[ 357.467473] ANDROID-ERROR) wifi_set_carddetect = 1
[ 357.467487] rk29sdk_wifi_set_carddetect:1
[ 357.467500] mmc1: slot status change detected(0-1)
[ 357.660078]
[ 357.660088] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 357.703982]
[ 357.703987] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 357.715420] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 357.717360] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 357.719296] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 357.722779] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 357.776478] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 357.778585] mmc1: new high speed SDIO card at address 0001
[ 357.781503] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 357.781714]
[ 357.781719] Dongle Host Driver, version 1.28.23.5 (r)
[ 357.781730] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 357.782679] dhdsdio_probe : no mutex held. set lock
[ 357.782733] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 357.782742] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 357.782874] F1 signature read @0x18000000=0x16044330
[ 357.815277] DHD: dongle ram size is set to 294912(orig 294912)
[ 357.817269] wl_create_event_handler thr:fae created
[ 357.817301] wl_create_event_handler thr:fae started
[ 357.820633] p2p0: P2P Interface Registered
[ 357.820741] dhd_attach thr:faf created
[ 357.820791] dhd_attach thr:faf started
[ 357.820856] dhd_attach thr:fb0 created
[ 357.821220] dhd_attach thr:fb0 started
[ 357.821291] dhd_attach thr:fb1 created
[ 357.821320] dhd_attach thr:fb1 started
[ 357.823778] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 357.823947] ANDROID-ERROR) wifi_set_power = 0
[ 357.823988] rk29sdk_wifi_power: 0
[ 357.830056] dhdsdio_probe : the lock is released.
[ 357.830101] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 358.024579] wifi shut off power
[ 358.124815] =========== WLAN placed in RESET ========
[ 358.149586]
[ 358.149590] Dongle Host Driver, version 1.28.23.5 (r)
[ 358.149595] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 358.149621] wl_android_wifi_on in
[ 358.149630] ANDROID-ERROR) wifi_set_power = 1
[ 358.149642] rk29sdk_wifi_power: 1
[ 358.401152] wifi turn on power
[ 358.501567] =========== WLAN going back to live ========
[ 358.501583] sdio_reset_comm():
[ 358.501606] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 358.507393] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 358.507679]
[ 358.507681]
[ 358.507684] dhd_bus_devreset: == WLAN ON ==
[ 358.507698] dhd_bus_devreset called when dongle is not in reset
[ 358.507710] Will call dhd_bus_start instead
[ 358.507754] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 358.507811] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 358.507825] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 358.507839] Final conf_path=/system/etc/firmware/config.txt
[ 360.540198] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 360.540234] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 360.540572] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 360.540607] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 360.540916] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 360.540952] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 361.540133] net_ratelimit: 8 callbacks suppressed
[ 361.540186] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 361.540396] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 361.540431] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 361.540634] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 361.540668] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 361.540848] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 361.540882] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 361.541011] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4123
[ 361.541248] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 361.541283] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 361.541481] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 361.541515] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 361.541692] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 361.541726] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 361.541857] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4143
[ 361.541909] dhd_bus_devreset: WLAN OFF DONE
[ 361.542014] ANDROID-ERROR) wifi_set_power = 0
[ 361.542056] rk29sdk_wifi_power: 0
[ 361.742341] wifi shut off power
[ 361.842542] =========== WLAN placed in RESET ========
[ 361.842557] wl_android_wifi_on: Failed
[ 361.842568] dhd_open: failed with code -1
[ 361.842578] wl_android_wifi_off in
[ 373.381936] =======================================================
[ 373.381988] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 373.382028] =======================================================
[ 373.382125] dhdsdio_disconnect : no mutex held. set lock
[ 373.382167] bcmsdh_unregister_oob_intr: Enter
[ 373.382312] dhd_detach thr:fb1 terminated OK
[ 373.550296] dhd_detach thr:faf terminated OK
[ 373.550497] dhd_detach thr:fb0 terminated OK
[ 373.700278] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 373.700394] wl_destroy_event_handler thr:fae terminated OK
[ 373.870845] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 373.870971] dhdsdio_disconnect : the lock is released.
[ 373.871053] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 373.871189] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 373.871353] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 373.871953] ANDROID-ERROR) ## wifi_remove
[ 373.871993] ANDROID-ERROR) wifi_set_power = 0
[ 373.872034] rk29sdk_wifi_power: 0
[ 374.073699] wifi shut off power
[ 374.073713] ANDROID-ERROR) wifi_set_carddetect = 0
[ 374.073760] rk29sdk_wifi_set_carddetect:0
[ 374.073772] mmc1: slot status change detected(1-0)
[ 374.073931] mmc1: card 0001 removed
[ 374.073997]
[ 374.073999] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 374.074308] =========== WLAN placed in POWER OFF ========
[ 374.090034] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 374.576946] Current WiFi chip is AP6476.
[ 374.613264] =======================================================
[ 374.613307] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 374.613344] =======================================================
[ 374.613392] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 374.717686] =========== WLAN placed in POWER ON ========
[ 374.717754] ANDROID-ERROR) wifi_set_power = 1
[ 374.717768] rk29sdk_wifi_power: 1
[ 374.969653] wifi turn on power
[ 374.969667] ANDROID-ERROR) wifi_set_carddetect = 1
[ 374.969682] rk29sdk_wifi_set_carddetect:1
[ 374.969694] mmc1: slot status change detected(0-1)
[ 375.160098]
[ 375.160108] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 375.204063]
[ 375.204072] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 375.216323] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 375.218428] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 375.220551] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 375.224336] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 375.281925] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 375.285352] mmc1: new high speed SDIO card at address 0001
[ 375.288490] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 375.289138]
[ 375.289148] Dongle Host Driver, version 1.28.23.5 (r)
[ 375.289168] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 375.291821] dhdsdio_probe : no mutex held. set lock
[ 375.291945] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 375.291964] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 375.292195] F1 signature read @0x18000000=0x16044330
[ 375.333020] DHD: dongle ram size is set to 294912(orig 294912)
[ 375.335201] wl_create_event_handler thr:fc0 created
[ 375.335272] wl_create_event_handler thr:fc0 started
[ 375.338608] p2p0: P2P Interface Registered
[ 375.338716] dhd_attach thr:fc1 created
[ 375.338785] dhd_attach thr:fc1 started
[ 375.338860] dhd_attach thr:fc2 created
[ 375.338892] dhd_attach thr:fc2 started
[ 375.338943] dhd_attach thr:fc3 created
[ 375.338968] dhd_attach thr:fc3 started
[ 375.341586] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 375.341742] ANDROID-ERROR) wifi_set_power = 0
[ 375.341770] rk29sdk_wifi_power: 0
[ 375.342567] dhdsdio_probe : the lock is released.
[ 375.342616] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 375.544172] wifi shut off power
[ 375.644784] =========== WLAN placed in RESET ========
[ 375.669647]
[ 375.669651] Dongle Host Driver, version 1.28.23.5 (r)
[ 375.669657] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 375.669681] wl_android_wifi_on in
[ 375.669691] ANDROID-ERROR) wifi_set_power = 1
[ 375.669704] rk29sdk_wifi_power: 1
[ 375.922872] wifi turn on power
[ 376.023247] =========== WLAN going back to live ========
[ 376.023263] sdio_reset_comm():
[ 376.023286] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 376.029054] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 376.029375]
[ 376.029377]
[ 376.029379] dhd_bus_devreset: == WLAN ON ==
[ 376.029393] dhd_bus_devreset called when dongle is not in reset
[ 376.029406] Will call dhd_bus_start instead
[ 376.029454] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 376.029510] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 376.029523] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 376.029537] Final conf_path=/system/etc/firmware/config.txt
[ 378.070128] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 378.070146] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 378.070340] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 378.070357] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 378.070531] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 378.070547] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 379.070134] net_ratelimit: 8 callbacks suppressed
[ 379.070180] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 379.070391] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 379.070426] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 379.070606] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 379.070640] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 379.070817] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 379.070851] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 379.070982] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4123
[ 379.071204] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 379.071238] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 379.071414] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 379.071449] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 379.071622] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 379.071657] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 379.071786] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4143
[ 379.071840] dhd_bus_devreset: WLAN OFF DONE
[ 379.071944] ANDROID-ERROR) wifi_set_power = 0
[ 379.071987] rk29sdk_wifi_power: 0
[ 379.272816] wifi shut off power
[ 379.373290] =========== WLAN placed in RESET ========
[ 379.373308] wl_android_wifi_on: Failed
[ 379.373319] dhd_open: failed with code -1
[ 379.373330] wl_android_wifi_off in
[ 390.899845] =======================================================
[ 390.899897] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 390.899937] =======================================================
[ 390.900083] dhdsdio_disconnect : no mutex held. set lock
[ 390.900132] bcmsdh_unregister_oob_intr: Enter
[ 390.900277] dhd_detach thr:fc3 terminated OK
[ 391.040343] dhd_detach thr:fc1 terminated OK
[ 391.040548] dhd_detach thr:fc2 terminated OK
[ 391.260232] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 391.260325] wl_destroy_event_handler thr:fc0 terminated OK
[ 391.431036] rk29_sdmmc_command_complete..2949...CMD52(arg=0x800), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 391.431143] dhdsdio_disconnect : the lock is released.
[ 391.431223] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 391.431364] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 391.431530] rk29_sdmmc_command_complete..2949...CMD52(arg=0x400), hoststate=1, errorTimes=1, errorStep=0x1e ! [sdio]
[ 391.432195] ANDROID-ERROR) ## wifi_remove
[ 391.432236] ANDROID-ERROR) wifi_set_power = 0
[ 391.432278] rk29sdk_wifi_power: 0
[ 391.636419] wifi shut off power
[ 391.636436] ANDROID-ERROR) wifi_set_carddetect = 0
[ 391.636451] rk29sdk_wifi_set_carddetect:0
[ 391.636462] mmc1: slot status change detected(1-0)
[ 391.636636] mmc1: card 0001 removed
[ 391.636689]
[ 391.636692] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 391.637298] =========== WLAN placed in POWER OFF ========
[ 391.650105] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 392.144243] Current WiFi chip is AP6476.
[ 392.183101] =======================================================
[ 392.183127] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 392.183149] =======================================================
[ 392.183170] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.62.WFD.OOB) init.
[ 392.289235] =========== WLAN placed in POWER ON ========
[ 392.289293] ANDROID-ERROR) wifi_set_power = 1
[ 392.289307] rk29sdk_wifi_power: 1
[ 392.540553] wifi turn on power
[ 392.540568] ANDROID-ERROR) wifi_set_carddetect = 1
[ 392.540581] rk29sdk_wifi_set_carddetect:1
[ 392.540593] mmc1: slot status change detected(0-1)
[ 392.740035]
[ 392.740038] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 392.783889]
[ 392.783891] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 392.795067] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 392.796933] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 392.798799] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 392.802150] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 392.854405] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 392.856352] mmc1: new high speed SDIO card at address 0001
[ 392.857505] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 392.857650] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 392.857975] dhdsdio_probe : no mutex held. set lock
[ 392.858007] FW_PATH = /system/etc/firmware/fw_RK901.bin
[ 392.858012] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
[ 392.858101] F1 signature read @0x18000000=0x16044330
[ 392.888588] DHD: dongle ram size is set to 294912(orig 294912)
[ 392.890506] wl_create_event_handler thr:fe0 created
[ 392.890804] wl_create_event_handler thr:fe0 started
[ 392.893169] p2p0: P2P Interface Registered
[ 392.893303] dhd_attach thr:fe1 created
[ 392.893623] dhd_attach thr:fe1 started
[ 392.893710] dhd_attach thr:fe2 created
[ 392.893834] dhd_attach thr:fe2 started
[ 392.893976] dhd_attach thr:fe3 created
[ 392.894121] dhd_attach thr:fe3 started
[ 392.896152] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 392.896215] dhdsdio_probe : the lock is released.
[ 392.896924]
[ 392.896934] Dongle Host Driver, version 1.28.23.5 (r)
[ 392.896948] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 392.897136] ANDROID-ERROR) wifi_set_power = 0
[ 392.897179] rk29sdk_wifi_power: 0
[ 393.098419] wifi shut off power
[ 393.198969] =========== WLAN placed in RESET ========
[ 393.225316]
[ 393.225321] Dongle Host Driver, version 1.28.23.5 (r)
[ 393.225326] Compiled in drivers/net/wireless/bcmdhd on Aug 29 2013 at 11:45:34
[ 393.225353] wl_android_wifi_on in
[ 393.225363] ANDROID-ERROR) wifi_set_power = 1
[ 393.225376] rk29sdk_wifi_power: 1
[ 393.476283] wifi turn on power
[ 393.576518] =========== WLAN going back to live ========
[ 393.576535] sdio_reset_comm():
[ 393.576557] rk29_sdmmc_change_clk_div..1963.. newDiv=40, newCLK=300Khz [sdio]
[ 393.582385] rk29_sdmmc_change_clk_div..1963.. newDiv=0, newCLK=24000Khz [sdio]
[ 393.582711]
[ 393.582713]
[ 393.582715] dhd_bus_devreset: == WLAN ON ==
[ 393.582729] dhd_bus_devreset called when dongle is not in reset
[ 393.582753] Will call dhd_bus_start instead
[ 393.582796] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 393.582851] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 393.582864] Final nv_path=/system/etc/firmware/nvram_AP6476.txt
[ 393.582878] Final conf_path=/system/etc/firmware/config.txt
[ 395.620401] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 395.620441] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 395.620779] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 395.620814] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 395.621127] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0xa5000080,cmdretry=0,blksize=128, blocks=1),
[ 395.621164] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 396.620154] net_ratelimit: 8 callbacks suppressed
[ 396.620185] dhdsdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 396.620664] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 396.620682] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 396.620814] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 396.620836] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 396.620955] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404804,cmdretry=0,blksize=4, blocks=1),
[ 396.620975] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 396.621058] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4123
[ 396.621196] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 396.621217] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 396.621324] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 396.621347] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 396.621450] rk29_sdmmc_request_end..2815......CMD=53 error!!!(arg=0x95404004,cmdretry=0,blksize=4, blocks=1),
[ 396.621469] statusReg=0x1a906, ctrlReg=0x10, nerrorTimes=0, errorStep=0xf6. [sdio]
[ 396.621548] dhd_bus_stop: FAILED REGISTER WRITE, LINE 4143
[ 396.621583] dhd_bus_devreset: WLAN OFF DONE
[ 396.621649] ANDROID-ERROR) wifi_set_power = 0
[ 396.621672] rk29sdk_wifi_power: 0
[ 396.838069] wifi shut off power
[ 396.939151] =========== WLAN placed in RESET ========
[ 396.939171] wl_android_wifi_on: Failed
[ 396.939182] dhd_open: failed with code -1
[ 396.939192] wl_android_wifi_off in
phil12623
Forum Posts: 16
2015/12/06 - 16:04
logcat.txt
--------- beginning of system
01-03 18:22:32.311 I/auditd ( 109): Starting up
01-03 18:22:32.311 E/auditd ( 109): Failed on audit_set_pid with error: Protocol not supported
01-03 18:22:32.311 I/auditd ( 109): Exiting
01-03 18:22:33.228 I/Vold ( 102): Vold 2.1 (the revenge) firing up
01-03 18:22:33.229 D/Vold ( 102): Volume sdcard1 state changing -1 (Initializing) -> 0 (No-Media)
01-03 18:22:33.229 D/Vold ( 102): Volume usb0 state changing -1 (Initializing) -> 0 (No-Media)
01-03 18:22:33.229 I/Cryptfs ( 102): Check if PFE is activated on Boot
01-03 18:22:33.229 E/Cryptfs ( 102): Unexpected value for crypto key location
01-03 18:22:33.229 E/Cryptfs ( 102): Error getting crypt footer and key
01-03 18:22:36.927 I/auditd ( 441): Starting up
01-03 18:22:36.927 E/auditd ( 441): Failed on audit_set_pid with error: Protocol not supported
01-03 18:22:36.927 I/auditd ( 441): Exiting
01-03 18:22:41.285 I/auditd ( 472): Starting up
01-03 18:22:41.285 E/auditd ( 472): Failed on audit_set_pid with error: Protocol not supported
01-03 18:22:41.285 I/auditd ( 472): Exiting
01-03 18:22:46.294 I/auditd ( 480): Starting up
01-03 18:22:46.294 E/auditd ( 480): Failed on audit_set_pid with error: Protocol not supported
01-03 18:22:46.294 I/auditd ( 480): Exiting
01-03 18:22:51.311 I/auditd ( 488): Starting up
01-03 18:22:51.312 E/auditd ( 488): Failed on audit_set_pid with error: Protocol not supported
01-03 18:22:51.312 I/auditd ( 488): Exiting
01-03 18:22:52.127 I/InstallerConnection( 491): disconnecting...
01-03 18:22:52.462 I/SystemServer( 491): Entered the Android system server!
01-03 18:22:54.041 I/SystemServiceManager( 491): Starting com.android.server.pm.Installer
01-03 18:22:54.123 I/Installer( 491): Waiting for installd to be ready.
01-03 18:22:54.123 I/InstallerConnection( 491): connecting...
01-03 18:22:54.126 I/SystemServiceManager( 491): Starting com.android.server.am.ActivityManagerService$Lifecycle
01-03 18:22:54.240 I/XXXXXX ( 491): choosing minFree values for 32 Bit
01-03 18:22:54.353 I/ActivityManager( 491): Memory class: 192
01-03 18:22:54.375 I/ServiceThread( 491): Enabled StrictMode logging for ActivityManager looper.
01-03 18:22:54.383 I/ServiceThread( 491): Enabled StrictMode logging for android.ui looper.
01-03 18:22:54.862 I/IntentFirewall( 491): Read new rules (A:0 B:0 S:0)
01-03 18:22:54.918 I/ServiceThread( 491): Enabled StrictMode logging for android.display looper.
01-03 18:22:54.952 D/AppOps ( 491): AppOpsService published
01-03 18:22:54.953 I/SystemServiceManager( 491): Starting com.android.server.power.PowerManagerService
01-03 18:22:54.983 I/ServiceThread( 491): Enabled StrictMode logging for PowerManagerService looper.
01-03 18:22:55.059 I/SystemServiceManager( 491): Starting com.android.server.display.DisplayManagerService
01-03 18:22:55.109 I/SystemServiceManager( 491): Starting phase 100
01-03 18:22:55.129 I/DisplayManagerService( 491): Display device added: DisplayDeviceInfo{"Integrierter Bildschirm": uniqueId="local:0", 1536 x 2048, 56.097 fps, supportedRefreshRates [56.097], density 280, 288.99554 x 240.82962 dpi, appVsyncOff 0, presDeadline 18826265, touch INTERNAL, rotation 0, type BUILT_IN, state UNKNOWN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
01-03 18:22:55.130 I/SystemServer( 491): Package Manager
01-03 18:22:55.239 W/PackageManager( 491): No security bridge jar found, using default
01-03 18:22:55.279 W/SystemConfig( 491): No directory /system/etc/sysconfig, skipping
01-03 18:22:55.526 D/SELinuxMMAC( 491): Using policy file /system/etc/security/mac_permissions.xml
01-03 18:22:56.480 I/auditd ( 524): Starting up
01-03 18:22:56.481 E/auditd ( 524): Failed on audit_set_pid with error: Protocol not supported
01-03 18:22:56.481 I/auditd ( 524): Exiting
01-03 18:22:57.577 I/PackageManager( 491): Replacing default ResolverActivity with custom activity: ComponentInfo{org.cyanogenmod.resolver/org.cyanogenmod.resolver.ResolverActivity}
01-03 18:22:59.272 W/PackageParser( 491): No actions in intent filter at /system/priv-app/Contacts/Contacts.apk Binary XML file line #362
01-03 18:23:01.494 I/auditd ( 527): Starting up
01-03 18:23:01.494 E/auditd ( 527): Failed on audit_set_pid with error: Protocol not supported
01-03 18:23:01.494 I/auditd ( 527): Exiting
01-03 18:23:03.161 W/PackageParser( 491): Unknown element under : android at /system/priv-app/Telecom/Telecom.apk Binary XML file line #236
01-03 18:23:03.161 W/PackageParser( 491): Unknown element under : android at /system/priv-app/Telecom/Telecom.apk Binary XML file line #244
01-03 18:23:06.509 I/auditd ( 530): Starting up
01-03 18:23:06.510 E/auditd ( 530): Failed on audit_set_pid with error: Protocol not supported
01-03 18:23:06.510 I/auditd ( 530): Exiting
01-03 18:23:09.517 W/PackageParser( 491): No actions in intent filter at /system/app/Bluetooth/Bluetooth.apk Binary XML file line #229
01-03 18:23:09.948 W/PackageParser( 491): No actions in intent filter at /system/app/CMFileManager/CMFileManager.apk Binary XML file line #166
01-03 18:23:11.525 I/auditd ( 533): Starting up
01-03 18:23:11.525 E/auditd ( 533): Failed on audit_set_pid with error: Protocol not supported
01-03 18:23:11.525 I/auditd ( 533): Exiting
01-03 18:23:12.501 W/PackageParser( 491): Unknown element under : permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #277
01-03 18:23:12.501 W/PackageParser( 491): Unknown element under : permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #280
01-03 18:23:16.538 I/auditd ( 536): Starting up
01-03 18:23:16.539 E/auditd ( 536): Failed on audit_set_pid with error: Protocol not supported
01-03 18:23:16.539 I/auditd ( 536): Exiting
01-03 18:23:16.773 W/PackageManager( 491): Package com.google.android.gms desires unavailable shared library com.google.android.ble; ignoring!
01-03 18:23:16.773 W/PackageManager( 491): Package com.android.calculator2 desires unavailable shared library com.sec.android.app.multiwindow; ignoring!
01-03 18:23:16.773 W/PackageManager( 491): Package com.google.android.GoogleCamera desires unavailable shared library com.google.android.gestureservice; ignoring!
01-03 18:23:16.774 I/PackageManager( 491): Adjusting ABI for : com.google.android.gsf to armeabi-v7a
01-03 18:23:16.774 I/PackageManager( 491): Adjusting ABI for : com.google.android.syncadapters.contacts to armeabi-v7a
01-03 18:23:16.775 I/PackageManager( 491): Adjusting ABI for : com.google.android.gsf.login to armeabi-v7a
01-03 18:23:16.775 I/PackageManager( 491): Adjusting ABI for : com.google.android.backuptransport to armeabi-v7a
01-03 18:23:16.776 I/PackageManager( 491): Adjusting ABI for : com.android.location.fused to armeabi-v7a
01-03 18:23:16.776 I/PackageManager( 491): Adjusting ABI for : com.android.inputdevices to armeabi-v7a
01-03 18:23:16.776 I/PackageManager( 491): Adjusting ABI for : com.android.providers.settings to armeabi-v7a
01-03 18:23:16.777 I/PackageManager( 491): Adjusting ABI for : com.android.keychain to armeabi-v7a
01-03 18:23:16.777 I/PackageManager( 491): Adjusting ABI for : org.cyanogenmod.cmsettings to armeabi-v7a
01-03 18:23:16.777 I/PackageManager( 491): Adjusting ABI for : com.android.server.telecom to armeabi-v7a
01-03 18:23:16.778 I/PackageManager( 491): Adjusting ABI for : com.android.settings to armeabi-v7a
01-03 18:23:16.778 I/PackageManager( 491): Adjusting ABI for : cyanogenmod.platform to armeabi-v7a
01-03 18:23:16.778 I/PackageManager( 491): Adjusting ABI for : org.cyanogenmod.resolver to armeabi-v7a
01-03 18:23:16.779 I/PackageManager( 491): Adjusting ABI for : com.android.development to armeabi-v7a
01-03 18:23:16.783 I/PackageManager( 491): Time to scan packages: 21.08 seconds
01-03 18:23:16.784 W/PackageManager( 491): Unknown permission com.google.android.voicesearch.SHORTCUTS_ACCESS in package com.google.android.googlequicksearchbox
01-03 18:23:16.784 W/PackageManager( 491): Unknown permission com.google.android.voicesearch.ACCESS_SETTINGS in package com.google.android.googlequicksearchbox
01-03 18:23:16.784 W/PackageManager( 491): Unknown permission com.google.android.ears.permission.WRITE in package com.google.android.googlequicksearchbox
01-03 18:23:16.784 W/PackageManager( 491): Unknown permission com.google.googlenav.friend.permission.OPT_IN in package com.google.android.googlequicksearchbox
01-03 18:23:16.784 W/PackageManager( 491): Unknown permission com.google.android.apps.maps.permission.PREFETCH in package com.google.android.googlequicksearchbox
01-03 18:23:16.784 W/PackageManager( 491): Unknown permission com.google.android.apps.googlevoice.permission.AUTO_SEND in package com.google.android.googlequicksearchbox
01-03 18:23:16.785 W/PackageManager( 491): Unknown permission com.google.android.hangouts.START_HANGOUT in package com.google.android.googlequicksearchbox
01-03 18:23:16.785 W/PackageManager( 491): Unknown permission com.android.chrome.PRERENDER_URL in package com.google.android.googlequicksearchbox
01-03 18:23:16.785 W/PackageManager( 491): Unknown permission com.google.android.launcher.permission.CONTENT_REDIRECT in package com.google.android.googlequicksearchbox
01-03 18:23:16.785 W/PackageManager( 491): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.google.android.onetimeinitializer
01-03 18:23:16.785 W/PackageManager( 491): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.google.android.onetimeinitializer
01-03 18:23:16.785 W/PackageManager( 491): Not granting permission android.permission.REAL_GET_TASKS to package org.cyanogenmod.wallpapers.photophase (protectionLevel=18 flags=0x18be45)
01-03 18:23:16.786 W/PackageManager( 491): Not granting permission android.permission.ACCESS_DOWNLOAD_MANAGER to package com.android.browser (protectionLevel=18 flags=0x49be45)
01-03 18:23:16.786 W/PackageManager( 491): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x49be45)
01-03 18:23:16.786 W/PackageManager( 491): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package com.android.soundrecorder (protectionLevel=18 flags=0x8be45)
01-03 18:23:16.786 W/PackageManager( 491): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.vending (protectionLevel=2 flags=0x400abe45)
01-03 18:23:16.786 W/PackageManager( 491): Unknown permission android.permission.SEND_SMS_NO_CONFIRMATION in package com.android.vending
01-03 18:23:16.787 W/PackageManager( 491): Unknown permission com.google.android.email.permission.READ_ATTACHMENT in package com.google.android.gm
01-03 18:23:16.787 W/PackageManager( 491): Unknown permission com.google.android.email.permission.ACCESS_PROVIDER in package com.google.android.gm
01-03 18:23:16.787 W/PackageManager( 491): Unknown permission com.google.android.gms.permission.CONTACTS_SYNC_DELEGATION in package com.google.android.syncadapters.contacts
01-03 18:23:16.787 W/PackageManager( 491): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.cyanogenmod.trebuchet
01-03 18:23:16.787 W/PackageManager( 491): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.cyanogenmod.trebuchet
01-03 18:23:16.787 W/PackageManager( 491): Unknown permission com.cyngn.stats.SEND_ANALYTICS in package com.cyanogenmod.trebuchet
01-03 18:23:16.787 W/PackageManager( 491): Unknown permission com.google.android.apps.enterprise.dmagent.permission.AutoSyncPermission in package com.google.android.gms
01-03 18:23:16.787 W/PackageManager( 491): Unknown permission com.google.android.hangouts.START_HANGOUT in package com.google.android.gms
01-03 18:23:16.787 W/PackageManager( 491): Unknown permission com.google.android.wearable.READ_SETTINGS in package com.google.android.gms
01-03 18:23:16.788 W/PackageManager( 491): Unknown permission com.android.launcher.permission.PRELOAD_WORKSPACE in package com.google.android.partnersetup
01-03 18:23:16.788 W/PackageManager( 491): Unknown permission android.permission.CANCEL_NOTIFICATIONS in package org.cyanogenmod.theme.chooser
01-03 18:23:16.788 W/PackageManager( 491): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x8be45)
01-03 18:23:16.788 W/PackageManager( 491): Unknown permission android.permission.ACCESS_SUPERUSER in package com.cyanogenmod.filemanager
01-03 18:23:16.788 W/PackageManager( 491): Unknown permission com.cyanogenmod.filemanager.permissions.READ_THEME in package com.cyanogenmod.filemanager
01-03 18:23:16.789 W/PackageManager( 491): Unknown permission com.google.android.gallery3d.permission.PICASA_STORE in package com.android.dreams.phototable
01-03 18:23:16.789 W/PackageManager( 491): Unknown permission com.android.vending.billing.IBillingAccountService.BIND2 in package com.google.android.gsf.login
01-03 18:23:16.789 W/PackageManager( 491): Unknown permission com.android.chrome.TOS_ACKED in package com.google.android.gsf.login
01-03 18:23:16.789 W/PackageManager( 491): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.settings
01-03 18:23:16.789 W/PackageManager( 491): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.settings
01-03 18:23:16.789 W/PackageManager( 491): Unknown permission com.cyanogen.permission.REQUEST_KILL_SWITCH_OP in package com.android.settings
01-03 18:23:16.789 W/PackageManager( 491): Unknown permission cyanogenmod.permission.FINISH_SETUP in package com.android.settings
01-03 18:23:16.789 W/PackageManager( 491): Unknown permission com.cyngn.stats.SEND_ANALYTICS in package com.android.settings
01-03 18:23:16.789 W/PackageManager( 491): Not granting permission android.permission.REAL_GET_TASKS to package com.cyanogenmod.eleven (protectionLevel=18 flags=0x18be65)
01-03 18:23:16.789 W/PackageManager( 491): Not granting permission android.permission.REBOOT to package eu.chainfire.supersu (protectionLevel=18 flags=0x83e05)
01-03 18:23:16.790 W/PackageManager( 491): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x48be45)
01-03 18:23:16.790 W/PackageManager( 491): Unknown permission com.android.deskclock.worldclock.permissions.WRITE_DATABASE in package com.android.deskclock
01-03 18:23:16.790 W/PackageManager( 491): Unknown permission com.cyngn.stats.SEND_ANALYTICS in package com.android.systemui
01-03 18:23:16.790 W/PackageManager( 491): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
01-03 18:23:16.790 W/PackageManager( 491): Unknown permission android.permission.MMS_SEND_OUTBOX_MSG in package com.android.bluetooth
01-03 18:23:16.791 W/PackageManager( 491): Not granting permission android.permission.HARDWARE_TEST to package android.rk.RockVideoPlayer (protectionLevel=2 flags=0x8be45)
01-03 18:23:16.791 W/PackageManager( 491): Not granting permission android.permission.DEVICE_POWER to package android.rk.RockVideoPlayer (protectionLevel=2 flags=0x8be45)
01-03 18:23:16.791 W/PackageManager( 491): Unknown permission rockchip.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
01-03 18:23:16.791 W/PackageManager( 491): Unknown permission android.permission.RAISED_THREAD_PRIORITY in package android.rk.RockVideoPlayer
01-03 18:23:16.791 W/PackageManager( 491): Unknown permission android.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
01-03 18:23:16.791 W/PackageManager( 491): Unknown permission archos.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
01-03 18:23:16.791 W/PackageManager( 491): Not granting permission android.permission.STATUS_BAR to package android.rk.RockVideoPlayer (protectionLevel=18 flags=0x8be45)
01-03 18:23:16.791 W/PackageManager( 491): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package android.rk.RockVideoPlayer (protectionLevel=18 flags=0x8be45)
01-03 18:23:16.791 W/PackageManager( 491): Not granting permission android.permission.CHANGE_CONFIGURATION to package android.rk.RockVideoPlayer (protectionLevel=50 flags=0x8be45)
01-03 18:23:16.791 W/PackageManager( 491): Not granting permission android.permission.BIND_WALLPAPER to package com.google.android.GoogleCamera (protectionLevel=18 flags=0x583c45)
01-03 18:23:16.791 W/PackageManager( 491): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.google.android.GoogleCamera
01-03 18:23:16.794 V/PackageManager( 491): Disabling com.google.android.gsf/com.google.android.gsf.update.SystemUpdateActivity
01-03 18:23:16.794 V/PackageManager( 491): Disabling com.google.android.gsf/com.google.android.gsf.update.SystemUpdateService$Receiver
01-03 18:23:16.794 V/PackageManager( 491): Disabling com.google.android.gsf/com.google.android.gsf.update.SystemUpdateService$SecretCodeReceiver
01-03 18:23:16.794 V/PackageManager( 491): Disabling com.google.android.gms/com.google.android.gms.update.SystemUpdateActivity
01-03 18:23:16.795 V/PackageManager( 491): Disabling com.google.android.gms/com.google.android.gms.update.SystemUpdateService$Receiver
01-03 18:23:16.795 V/PackageManager( 491): Disabling com.google.android.gms/com.google.android.gms.update.SystemUpdateService$ActiveReceiver
01-03 18:23:16.795 V/PackageManager( 491): Disabling com.google.android.gms/com.google.android.gms.update.SystemUpdateService$SecretCodeReceiver
01-03 18:23:16.797 V/PackageManager( 491): Enabling com.google.android.gsf/com.google.android.gsf.update.SystemUpdateService
01-03 18:23:16.797 V/PackageManager( 491): Enabling com.google.android.gms/com.google.android.gms.update.SystemUpdateService
01-03 18:23:16.907 I/SystemServer( 491): User Service
01-03 18:23:19.320 I/SystemServiceManager( 491): Starting com.android.server.lights.LightsService
01-03 18:23:19.352 I/SystemServiceManager( 491): Starting com.android.server.BatteryService
01-03 18:23:19.390 I/SystemServiceManager( 491): Starting com.android.server.usage.UsageStatsService
01-03 18:23:19.437 I/SystemServiceManager( 491): Starting com.android.server.webkit.WebViewUpdateService
01-03 18:23:19.478 I/SystemServer( 491): Reading configuration...
01-03 18:23:19.478 I/SystemServer( 491): Scheduling Policy
01-03 18:23:19.482 I/SystemServiceManager( 491): Starting com.android.server.telecom.TelecomLoaderService
01-03 18:23:19.506 I/SystemServer( 491): Telephony Registry
01-03 18:23:19.534 I/SystemServer( 491): Entropy Mixer
01-03 18:23:19.544 I/EntropyMixer( 491): Writing entropy...
01-03 18:23:19.549 I/SystemServer( 491): Account Manager
01-03 18:23:19.590 I/SystemServer( 491): Content Manager
01-03 18:23:19.622 I/SystemServer( 491): System Content Providers
01-03 18:23:19.741 I/SystemServer( 491): Vibrator Service
01-03 18:23:19.745 I/SystemServer( 491): Consumer IR Service
01-03 18:23:19.747 I/SystemServiceManager( 491): Starting com.android.server.AlarmManagerService
01-03 18:23:19.800 I/SystemServer( 491): Init Watchdog
01-03 18:23:19.801 I/SystemServer( 491): Input Manager
01-03 18:23:19.802 I/InputManager( 491): Initializing input manager, mUseDevInputEventForAudioJack=true
01-03 18:23:19.808 I/SystemServer( 491): Window Manager
01-03 18:23:20.018 I/WindowManager( 491): No existing display settings /data/system/display_settings.xml; starting empty
01-03 18:23:20.299 I/InputManager( 491): Starting input manager
01-03 18:23:20.310 I/SystemServer( 491): Bluetooth Manager Service
01-03 18:23:20.374 I/SystemServer( 491): Input Method Service
01-03 18:23:20.498 W/InputMethodManagerService( 491): Couldn't create dir.: /data/system/inputmethod
01-03 18:23:20.606 I/SystemServer( 491): Accessibility Manager
01-03 18:23:20.632 I/WindowManager( 491): FORCED DISPLAY DENSITY: 320
01-03 18:23:20.633 I/XXXXXX ( 491): choosing minFree values for 32 Bit
01-03 18:23:20.634 I/ActivityManager( 491): Config changes=1df8 {1.0 ?mcc?mnc de_DE ?layoutDir sw768dp w768dp h1024dp 320dpi xlrg port ?uimode ?night -touch -keyb/v/h -nav/h s.2 themeResource=null}
01-03 18:23:20.639 I/ActivityManager( 491): Config changes=408 {1.0 ?mcc?mnc de_DE ?layoutDir sw768dp w768dp h951dp 320dpi xlrg port ?uimode ?night finger -keyb/v/h -nav/h s.3 themeResource=null}
01-03 18:23:20.640 I/SystemServer( 491): Mount Service
01-03 18:23:20.706 D/MountService( 491): got storage path: null description: Interner Speicher primary: true removable: false emulated: true mtpReserve: 100 allowMassStorage: false maxFileSize: 0 allowMtp: true
01-03 18:23:20.708 D/MountService( 491): addVolumeLocked() StorageVolume:
01-03 18:23:20.708 D/MountService( 491): mStorageId=65537 mPath=/storage/emulated/0 mDescriptionId=17041015
01-03 18:23:20.708 D/MountService( 491): mPrimary=true mRemovable=false mEmulated=true mMtpReserveSpace=100
01-03 18:23:20.708 D/MountService( 491): mAllowMassStorage=false mMaxFileSize=0 mOwner=UserHandle{0} mUuid=null
01-03 18:23:20.708 D/MountService( 491): mUserLabel=null mState=null mAllowMtp=true
01-03 18:23:20.709 D/MountService( 491): got storage path: /storage/sdcard1 description: SD-Karte primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 4294967296 allowMtp: true
01-03 18:23:20.709 D/MountService( 491): addVolumeLocked() StorageVolume:
01-03 18:23:20.709 D/MountService( 491): mStorageId=0 mPath=/storage/sdcard1 mDescriptionId=17041016 mPrimary=false
01-03 18:23:20.709 D/MountService( 491): mRemovable=true mEmulated=false mMtpReserveSpace=0 mAllowMassStorage=false
01-03 18:23:20.709 D/MountService( 491): mMaxFileSize=4294967296 mOwner=null mUuid=null mUserLabel=null mState=null
01-03 18:23:20.709 D/MountService( 491): mAllowMtp=true
01-03 18:23:20.709 D/MountService( 491): got storage path: /storage/usb0 description: USB-Speicher primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0 allowMtp: true
01-03 18:23:20.709 D/MountService( 491): mStorageId=0 mPath=/storage/usb0 mDescriptionId=17041017 mPrimary=false
01-03 18:23:20.709 D/MountService( 491): mMaxFileSize=0 mOwner=null mUuid=null mUserLabel=null mState=null
01-03 18:23:20.733 I/SystemServer( 491): LockSettingsService
01-03 18:23:20.739 D/MountService( 491): volume state changed for /storage/sdcard1 (unmounted -> removed)
01-03 18:23:20.739 D/MountService( 491): volume state changed for /storage/usb0 (unmounted -> removed)
01-03 18:23:20.741 I/SystemServiceManager( 491): Starting com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle
01-03 18:23:20.764 I/UsageStatsService( 491): User[0] Rollover scheduled @ 2011-01-04 01:00:00(1294099200000)
01-03 18:23:20.769 I/SystemServer( 491): Status Bar
01-03 18:23:20.772 W/PackageManager( 491): Unknown permission com.google.android.voicesearch.SHORTCUTS_ACCESS in package com.google.android.googlequicksearchbox
01-03 18:23:20.772 W/PackageManager( 491): Unknown permission com.google.android.voicesearch.ACCESS_SETTINGS in package com.google.android.googlequicksearchbox
01-03 18:23:20.772 W/PackageManager( 491): Unknown permission com.google.android.ears.permission.WRITE in package com.google.android.googlequicksearchbox
01-03 18:23:20.772 W/PackageManager( 491): Unknown permission com.google.googlenav.friend.permission.OPT_IN in package com.google.android.googlequicksearchbox
01-03 18:23:20.772 W/PackageManager( 491): Unknown permission com.google.android.apps.maps.permission.PREFETCH in package com.google.android.googlequicksearchbox
01-03 18:23:20.772 W/PackageManager( 491): Unknown permission com.google.android.apps.googlevoice.permission.AUTO_SEND in package com.google.android.googlequicksearchbox
01-03 18:23:20.772 W/PackageManager( 491): Unknown permission com.google.android.hangouts.START_HANGOUT in package com.google.android.googlequicksearchbox
01-03 18:23:20.772 W/PackageManager( 491): Unknown permission com.android.chrome.PRERENDER_URL in package com.google.android.googlequicksearchbox
01-03 18:23:20.772 W/PackageManager( 491): Unknown permission com.google.android.launcher.permission.CONTENT_REDIRECT in package com.google.android.googlequicksearchbox
01-03 18:23:20.772 W/PackageManager( 491): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.google.android.onetimeinitializer
01-03 18:23:20.772 W/PackageManager( 491): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.google.android.onetimeinitializer
01-03 18:23:20.772 W/PackageManager( 491): Not granting permission android.permission.REAL_GET_TASKS to package org.cyanogenmod.wallpapers.photophase (protectionLevel=18 flags=0x18be45)
01-03 18:23:20.776 I/SystemServer( 491): Clipboard Service
01-03 18:23:20.794 W/PackageManager( 491): Not granting permission android.permission.ACCESS_DOWNLOAD_MANAGER to package com.android.browser (protectionLevel=18 flags=0x49be45)
01-03 18:23:20.795 W/PackageManager( 491): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x49be45)
01-03 18:23:20.795 W/PackageManager( 491): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package com.android.soundrecorder (protectionLevel=18 flags=0x8be45)
01-03 18:23:20.795 W/PackageManager( 491): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.vending (protectionLevel=2 flags=0x400abe45)
01-03 18:23:20.795 W/PackageManager( 491): Unknown permission android.permission.SEND_SMS_NO_CONFIRMATION in package com.android.vending
01-03 18:23:20.795 W/PackageManager( 491): Unknown permission com.google.android.email.permission.READ_ATTACHMENT in package com.google.android.gm
01-03 18:23:20.795 W/PackageManager( 491): Unknown permission com.google.android.email.permission.ACCESS_PROVIDER in package com.google.android.gm
01-03 18:23:20.795 W/PackageManager( 491): Unknown permission com.google.android.gms.permission.CONTACTS_SYNC_DELEGATION in package com.google.android.syncadapters.contacts
01-03 18:23:20.796 W/PackageManager( 491): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.cyanogenmod.trebuchet
01-03 18:23:20.796 W/PackageManager( 491): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.cyanogenmod.trebuchet
01-03 18:23:20.796 W/PackageManager( 491): Unknown permission com.cyngn.stats.SEND_ANALYTICS in package com.cyanogenmod.trebuchet
01-03 18:23:20.796 W/PackageManager( 491): Unknown permission com.google.android.apps.enterprise.dmagent.permission.AutoSyncPermission in package com.google.android.gms
01-03 18:23:20.796 W/PackageManager( 491): Unknown permission com.google.android.hangouts.START_HANGOUT in package com.google.android.gms
01-03 18:23:20.796 W/PackageManager( 491): Unknown permission com.google.android.wearable.READ_SETTINGS in package com.google.android.gms
01-03 18:23:20.797 W/PackageManager( 491): Unknown permission com.android.launcher.permission.PRELOAD_WORKSPACE in package com.google.android.partnersetup
01-03 18:23:20.797 W/PackageManager( 491): Unknown permission android.permission.CANCEL_NOTIFICATIONS in package org.cyanogenmod.theme.chooser
01-03 18:23:20.797 W/PackageManager( 491): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x8be45)
01-03 18:23:20.798 W/PackageManager( 491): Unknown permission android.permission.ACCESS_SUPERUSER in package com.cyanogenmod.filemanager
01-03 18:23:20.798 W/PackageManager( 491): Unknown permission com.cyanogenmod.filemanager.permissions.READ_THEME in package com.cyanogenmod.filemanager
01-03 18:23:20.798 W/PackageManager( 491): Unknown permission com.google.android.gallery3d.permission.PICASA_STORE in package com.android.dreams.phototable
01-03 18:23:20.798 W/PackageManager( 491): Unknown permission com.android.vending.billing.IBillingAccountService.BIND2 in package com.google.android.gsf.login
01-03 18:23:20.798 W/PackageManager( 491): Unknown permission com.android.chrome.TOS_ACKED in package com.google.android.gsf.login
01-03 18:23:20.799 W/PackageManager( 491): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.settings
01-03 18:23:20.799 W/PackageManager( 491): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.settings
01-03 18:23:20.799 W/PackageManager( 491): Unknown permission com.cyanogen.permission.REQUEST_KILL_SWITCH_OP in package com.android.settings
01-03 18:23:20.799 W/PackageManager( 491): Unknown permission cyanogenmod.permission.FINISH_SETUP in package com.android.settings
01-03 18:23:20.799 W/PackageManager( 491): Unknown permission com.cyngn.stats.SEND_ANALYTICS in package com.android.settings
01-03 18:23:20.799 W/PackageManager( 491): Not granting permission android.permission.REAL_GET_TASKS to package com.cyanogenmod.eleven (protectionLevel=18 flags=0x18be65)
01-03 18:23:20.799 W/PackageManager( 491): Not granting permission android.permission.REBOOT to package eu.chainfire.supersu (protectionLevel=18 flags=0x83e05)
01-03 18:23:20.800 W/PackageManager( 491): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x48be45)
01-03 18:23:20.800 W/PackageManager( 491): Unknown permission com.android.deskclock.worldclock.permissions.WRITE_DATABASE in package com.android.deskclock
01-03 18:23:20.800 W/PackageManager( 491): Unknown permission com.cyngn.stats.SEND_ANALYTICS in package com.android.systemui
01-03 18:23:20.801 W/PackageManager( 491): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
01-03 18:23:20.801 W/PackageManager( 491): Unknown permission android.permission.MMS_SEND_OUTBOX_MSG in package com.android.bluetooth
01-03 18:23:20.801 W/PackageManager( 491): Not granting permission android.permission.HARDWARE_TEST to package android.rk.RockVideoPlayer (protectionLevel=2 flags=0x8be45)
01-03 18:23:20.801 W/PackageManager( 491): Not granting permission android.permission.DEVICE_POWER to package android.rk.RockVideoPlayer (protectionLevel=2 flags=0x8be45)
01-03 18:23:20.801 W/PackageManager( 491): Unknown permission rockchip.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
01-03 18:23:20.801 W/PackageManager( 491): Unknown permission android.permission.RAISED_THREAD_PRIORITY in package android.rk.RockVideoPlayer
01-03 18:23:20.801 W/PackageManager( 491): Unknown permission android.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
01-03 18:23:20.801 W/PackageManager( 491): Unknown permission archos.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
01-03 18:23:20.801 W/PackageManager( 491): Not granting permission android.permission.STATUS_BAR to package android.rk.RockVideoPlayer (protectionLevel=18 flags=0x8be45)
01-03 18:23:20.801 W/PackageManager( 491): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package android.rk.RockVideoPlayer (protectionLevel=18 flags=0x8be45)
01-03 18:23:20.801 W/PackageManager( 491): Not granting permission android.permission.CHANGE_CONFIGURATION to package android.rk.RockVideoPlayer (protectionLevel=50 flags=0x8be45)
01-03 18:23:20.801 W/PackageManager( 491): Not granting permission android.permission.BIND_WALLPAPER to package com.google.android.GoogleCamera (protectionLevel=18 flags=0x583c45)
01-03 18:23:20.801 W/PackageManager( 491): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.google.android.GoogleCamera
01-03 18:23:20.830 W/ClipboardService( 491): No security bridge jar found, using default
01-03 18:23:20.895 I/SystemServer( 491): TorchService
01-03 18:23:21.646 I/auditd ( 559): Starting up
01-03 18:23:21.647 E/auditd ( 559): Failed on audit_set_pid with error: Protocol not supported
01-03 18:23:21.647 I/auditd ( 559): Exiting
01-03 18:23:26.674 I/auditd ( 575): Starting up
01-03 18:23:26.675 E/auditd ( 575): Failed on audit_set_pid with error: Protocol not supported
01-03 18:23:26.675 I/auditd ( 575): Exiting
01-03 18:23:27.019 I/SystemServer( 491): NetworkManagement Service
01-03 18:23:27.032 I/SystemServer( 491): Text Service Manager Service
01-03 18:23:27.053 I/SystemServer( 491): Network Score Service
01-03 18:23:27.058 I/SystemServer( 491): NetworkStats Service
01-03 18:23:27.096 I/SystemServer( 491): NetworkPolicy Service
01-03 18:23:27.160 I/SystemServiceManager( 491): Starting com.android.server.wifi.p2p.WifiP2pService
01-03 18:23:27.326 I/SystemServiceManager( 491): Starting com.android.server.wifi.WifiService
01-03 18:23:27.662 I/SystemServiceManager( 491): Starting com.android.server.wifi.WifiScanningService
01-03 18:23:27.664 I/SystemServiceManager( 491): Starting com.android.server.wifi.RttService
01-03 18:23:27.668 I/SystemServiceManager( 491): Starting com.android.server.ethernet.EthernetService
01-03 18:23:27.680 I/SystemServer( 491): Connectivity Service
01-03 18:23:27.690 D/ConnectivityService( 491): ConnectivityService starting up
01-03 18:23:27.695 D/ConnectivityService( 491): wifiOnly=false
01-03 18:23:27.696 E/ConnectivityService( 491): Ignoring protectedNetwork 14
01-03 18:23:27.696 E/ConnectivityService( 491): Ignoring protectedNetwork 15
01-03 18:23:27.732 I/SystemServer( 491): Network Service Discovery Service
01-03 18:23:27.736 D/NsdService( 491): Network service discovery enabled true
01-03 18:23:27.739 I/SystemServer( 491): DPM Service
01-03 18:23:27.740 I/SystemServer( 491): DPM configuration set to 0
01-03 18:23:27.740 I/SystemServer( 491): UpdateLock Service
01-03 18:23:27.803 I/SystemServiceManager( 491): Starting com.android.server.notification.NotificationManagerService
01-03 18:23:27.940 D/ZenLog ( 491): set_zen_mode: off,setting
01-03 18:23:27.950 I/SystemServiceManager( 491): Starting com.android.server.storage.DeviceStorageMonitorService
01-03 18:23:27.956 I/SystemServer( 491): Location Manager
01-03 18:23:27.966 I/SystemServer( 491): Country Detector
01-03 18:23:27.967 I/SystemServer( 491): Search Service
01-03 18:23:27.972 I/SystemServer( 491): DropBox Service
01-03 18:23:27.976 I/SystemServer( 491): Wallpaper Service
01-03 18:23:27.986 W/WallpaperManagerService( 491): no current wallpaper -- first boot?
01-03 18:23:27.987 I/SystemServer( 491): Audio Service
01-03 18:23:28.085 I/SystemServiceManager( 491): Starting com.android.server.DockObserver
01-03 18:23:28.089 W/DockObserver( 491): This kernel does not have dock station support
01-03 18:23:28.090 I/SystemServer( 491): Wired Accessory Manager
01-03 18:23:28.095 I/SystemServiceManager( 491): Starting com.android.server.usb.UsbService$Lifecycle
01-03 18:23:28.135 I/SystemServer( 491): Serial Service
01-03 18:23:28.136 I/SystemServiceManager( 491): Starting com.android.server.twilight.TwilightService
01-03 18:23:28.144 I/SystemServiceManager( 491): Starting com.android.server.UiModeManagerService
01-03 18:23:28.155 I/SystemServiceManager( 491): Starting com.android.server.job.JobSchedulerService
01-03 18:23:28.173 I/SystemServiceManager( 491): Starting com.android.server.backup.BackupManagerService$Lifecycle
01-03 18:23:28.182 I/SystemServiceManager( 491): Starting com.android.server.appwidget.AppWidgetService
01-03 18:23:28.201 I/SystemServiceManager( 491): Starting com.android.server.voiceinteraction.VoiceInteractionManagerService
01-03 18:23:28.213 W/SoundTriggerHelper( 491): listModules status=0, # of modules=0
01-03 18:23:28.213 I/SystemServer( 491): DiskStats Service
01-03 18:23:28.215 I/SystemServer( 491): SamplingProfiler Service
01-03 18:23:28.222 I/SystemServer( 491): NetworkTimeUpdateService
01-03 18:23:28.224 I/SystemServer( 491): CommonTimeManagementService
01-03 18:23:28.229 I/SystemServer( 491): CertBlacklister
01-03 18:23:28.232 I/SystemServiceManager( 491): Starting com.android.server.dreams.DreamManagerService
01-03 18:23:28.238 I/SystemServer( 491): Assets Atlas Service
01-03 18:23:28.244 I/SystemServiceManager( 491): Starting com.android.server.print.PrintManagerService
01-03 18:23:28.263 I/SystemServiceManager( 491): Starting com.android.server.restrictions.RestrictionsManagerService
01-03 18:23:28.270 I/SystemServiceManager( 491): Starting com.android.server.media.MediaSessionService
01-03 18:23:28.352 I/SystemServiceManager( 491): Starting com.android.server.hdmi.HdmiControlService
01-03 18:23:28.370 I/HdmiControlService( 491): Device does not support HDMI-CEC.
01-03 18:23:28.370 I/SystemServer( 491): Theme Service
01-03 18:23:28.384 I/SystemServer( 491): KillSwitch Service
01-03 18:23:28.386 I/SystemServer( 491): Media Router Service
01-03 18:23:28.391 I/SystemServiceManager( 491): Starting com.android.server.trust.TrustManagerService
01-03 18:23:28.403 I/SystemServiceManager( 491): Starting com.android.server.fingerprint.FingerprintService
01-03 18:23:28.418 I/SystemServer( 491): BackgroundDexOptService
01-03 18:23:28.425 I/SystemServiceManager( 491): Starting com.android.server.pm.LauncherAppsService
01-03 18:23:28.429 D/SystemServer( 491): Wipower not supported
01-03 18:23:28.429 I/SystemServer( 491): EdgeGesture service
01-03 18:23:28.432 I/SystemServiceManager( 491): Starting com.android.server.media.projection.MediaProjectionManagerService
01-03 18:23:28.465 I/SystemServiceManager( 491): Starting com.android.server.MmsServiceBroker
01-03 18:23:28.468 I/SystemServer( 491): org.cyanogenmod.platform.internal.CMStatusBarManagerService
01-03 18:23:28.482 I/SystemServiceManager( 491): Starting org.cyanogenmod.platform.internal.CMStatusBarManagerService
01-03 18:23:28.497 I/SystemServer( 491): org.cyanogenmod.platform.internal.ProfileManagerService
01-03 18:23:28.511 I/SystemServiceManager( 491): Starting org.cyanogenmod.platform.internal.ProfileManagerService
01-03 18:23:28.527 D/WifiService( 491): New client listening to asynchronous messages
01-03 18:23:28.559 I/SystemServer( 491): org.cyanogenmod.platform.internal.PartnerInterfaceService
01-03 18:23:28.564 I/SystemServiceManager( 491): Starting org.cyanogenmod.platform.internal.PartnerInterfaceService
01-03 18:23:28.565 I/SystemServer( 491): org.cyanogenmod.platform.internal.CMTelephonyManagerService
01-03 18:23:28.570 I/SystemServiceManager( 491): Starting org.cyanogenmod.platform.internal.CMTelephonyManagerService
01-03 18:23:28.571 I/SystemServer( 491): org.cyanogenmod.platform.internal.CMHardwareService
01-03 18:23:28.576 I/SystemServiceManager( 491): Starting org.cyanogenmod.platform.internal.CMHardwareService
01-03 18:23:28.585 I/SystemServer( 491): org.cyanogenmod.platform.internal.AppSuggestManagerService
01-03 18:23:28.590 I/SystemServiceManager( 491): Starting org.cyanogenmod.platform.internal.AppSuggestManagerService
01-03 18:23:28.597 E/AppSgstMgrService( 491): no app suggest provider found
01-03 18:23:28.632 E/LockSettingsStorage( 491): Cannot read file java.io.FileNotFoundException: /data/system/password.key: open failed: ENOENT (No such file or directory)
01-03 18:23:28.633 E/LockSettingsStorage( 491): Cannot read file java.io.FileNotFoundException: /data/system/gesture.key: open failed: ENOENT (No such file or directory)
01-03 18:23:28.633 I/SystemServiceManager( 491): Starting phase 480
01-03 18:23:28.661 I/SystemServiceManager( 491): Starting phase 500
01-03 18:23:28.662 I/WifiService( 491): WifiService starting up with Wi-Fi enabled
01-03 18:23:28.665 D/WifiService( 491): setWifiEnabled: true pid=491, uid=1000
01-03 18:23:28.665 E/WifiService( 491): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:23:28.691 D/WifiScanningService( 491): New client, channel: null messenger: null
01-03 18:23:28.706 D/ConnectivityService( 491): Got NetworkFactory Messenger for Ethernet
01-03 18:23:28.719 I/ActivityManager( 491): Config changes=200 {1.0 ?mcc?mnc de_DE ?layoutDir sw768dp w768dp h951dp 320dpi xlrg port finger -keyb/v/h -nav/h s.4 themeResource=null}
01-03 18:23:28.744 V/BackupManagerService( 491): No ancestral data
01-03 18:23:28.751 D/BackupManagerService( 491): Now staging backup of com.android.providers.telephony
01-03 18:23:28.756 D/BackupManagerService( 491): Now staging backup of com.google.android.googlequicksearchbox
01-03 18:23:28.758 D/BackupManagerService( 491): Now staging backup of com.android.browser
01-03 18:23:28.759 D/BackupManagerService( 491): Now staging backup of com.android.vending
01-03 18:23:28.760 D/BackupManagerService( 491): Now staging backup of android
01-03 18:23:28.761 D/BackupManagerService( 491): Now staging backup of com.google.android.gm
01-03 18:23:28.763 D/BackupManagerService( 491): Now staging backup of com.android.providers.settings
01-03 18:23:28.764 D/BackupManagerService( 491): Now staging backup of com.android.sharedstoragebackup
01-03 18:23:28.765 D/BackupManagerService( 491): Now staging backup of com.cyanogenmod.trebuchet
01-03 18:23:28.766 D/BackupManagerService( 491): Now staging backup of com.google.android.calendar
01-03 18:23:28.767 D/BackupManagerService( 491): Now staging backup of com.android.providers.userdictionary
01-03 18:23:28.767 V/BackupManagerService( 491): Starting with transport com.google.android.gms/.backup.BackupTransportService
01-03 18:23:28.768 V/BackupManagerService( 491): Found transports: 2
01-03 18:23:28.768 I/BackupManagerService( 491): Binding to transport host ComponentInfo{android/com.android.internal.backup.LocalTransportService}
01-03 18:23:28.774 I/BackupManagerService( 491): Binding to transport host ComponentInfo{com.google.android.gms/com.google.android.gms.backup.BackupTransportService}
01-03 18:23:28.777 I/BackupManagerService( 491): Found stale backup journal, scheduling
01-03 18:23:28.983 D/LiveDisplay( 491): Adjust display temperature to 6500K [r=1.0 g=1.0 b=1.0]
01-03 18:23:29.035 I/AppOps ( 491): Pruning old package media/1013: new uid=-1
01-03 18:23:29.035 I/ActivityManager( 491): System now ready
01-03 18:23:29.037 I/DisplayManagerService( 491): Display device changed: DisplayDeviceInfo{"Integrierter Bildschirm": uniqueId="local:0", 1536 x 2048, 56.097 fps, supportedRefreshRates [56.097], density 280, 288.99554 x 240.82962 dpi, appVsyncOff 0, presDeadline 18826265, touch INTERNAL, rotation 0, type BUILT_IN, state ON, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
01-03 18:23:29.040 I/SystemServer( 491): Making services ready
01-03 18:23:29.040 I/SystemServiceManager( 491): Starting phase 550
01-03 18:23:29.055 D/UsbHostManager( 491): Added device UsbDevice[mName=/dev/bus/usb/002/002,mVendorId=3725,mProductId=162,mClass=239,mSubclass=2,mProtocol=1,mManufacturerName=MediaTek Inc,mProductName=MT6229 ,mSerialNumber=null,mConfigurations=[
01-03 18:23:29.055 D/UsbHostManager( 491): UsbConfiguration[mId=1,mName=null,mAttributes=128,mMaxPower=250,mInterfaces=[
01-03 18:23:29.055 D/UsbHostManager( 491): UsbInterface[mId=0,mAlternateSetting=0,mName=6238 COM(data_if),mClass=10,mSubclass=0,mProtocol=0,mEndpoints=[
01-03 18:23:29.055 D/UsbHostManager( 491): UsbEndpoint[mAddress=129,mAttributes=2,mMaxPacketSize=512,mInterval=0]
01-03 18:23:29.055 D/UsbHostManager( 491): UsbEndpoint[mAddress=1,mAttributes=2,mMaxPacketSize=512,mInterval=0]]
01-03 18:23:29.055 D/UsbHostManager( 491): UsbInterface[mId=1,mAlternateSetting=0,mName=6229 COM(comm_if),mClass=2,mSubclass=2,mProtocol=1,mEndpoints=[
01-03 18:23:29.055 D/UsbHostManager( 491): UsbEndpoint[mAddress=132,mAttributes=3,mMaxPacketSize=64,mInterval=1]]
01-03 18:23:29.055 D/UsbHostManager( 491): UsbInterface[mId=2,mAlternateSetting=0,mName=6238 COM(data_if),mClass=10,mSubclass=0,mProtocol=0,mEndpoints=[
01-03 18:23:29.055 D/UsbHostManager( 491): UsbEndpoint[mAddress=130,mAttributes=2,mMaxPacketSize=512,mInterval=0]
01-03 18:23:29.055 D/UsbHostManager( 491): UsbEndpoint[mAddress=2,mAttributes=2,mMaxPacketSize=512,mInterval=0]]]]
01-03 18:23:29.104 I/ActivityManager( 491): Start proc 621:com.android.systemui/u0a13 for service com.android.systemui/.keyguard.KeyguardService
01-03 18:23:29.105 I/SystemServer( 491): WebViewFactory preparation
01-03 18:23:29.137 I/ActivityManager( 491): Start proc 628:android.process.media/u0a7 for broadcast com.android.providers.media/.MtpReceiver
01-03 18:23:29.170 I/ActivityManager( 491): Start proc 645:WebViewLoader-armeabi-v7a/1037 [android.webkit.WebViewFactory$RelroFileCreator] for
01-03 18:23:29.175 W/MountService( 491): Duplicate state transition (mounted -> mounted) for /storage/emulated/0
01-03 18:23:29.177 D/NetworkManagementService( 491): enabling bandwidth control
01-03 18:23:30.281 I/SystemServiceManager( 491): Starting phase 600
01-03 18:23:30.300 I/BackupManagerService( 491): Backup enabled => false
01-03 18:23:30.301 I/BackupManagerService( 491): Opting out of backup
01-03 18:23:30.594 I/ActivityManager( 491): Start proc 734:com.google.android.googlequicksearchbox:interactor/u0a22 for service com.google.android.googlequicksearchbox/com.google.android.voiceinteraction.GsaVoiceInteractionService
01-03 18:23:30.601 E/InputMethodManagerService( 491): Ignoring setImeWindowStatus due to an invalid token. uid:1000 token:null
01-03 18:23:30.675 I/ActivityManager( 491): Start proc 745:com.android.inputmethod.latin/u0a40 for service com.android.inputmethod.latin/.LatinIME
01-03 18:23:30.676 V/InputMethodManagerService( 491): Adding window token: android.os.Binder@2b66e504
01-03 18:23:30.864 I/ActivityManager( 491): Start proc 787:com.android.settings/1000 for broadcast com.android.settings/.widget.SettingsAppWidgetProvider
01-03 18:23:31.049 E/LocationManagerService( 491): FLP HAL not supported
01-03 18:23:31.103 E/LocationManagerService( 491): Hardware Activity-Recognition not supported.
01-03 18:23:31.162 I/MmsServiceBroker( 491): systemRunning
01-03 18:23:31.256 I/ActivityManager( 491): Start proc 808:org.cyanogenmod.audiofx/u0a0 for added application org.cyanogenmod.audiofx
01-03 18:23:31.293 I/ActivityManager( 491): Start proc 814:com.android.phone/1001 for added application com.android.phone
01-03 18:23:31.295 I/ActivityManager( 491): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.cyanogenmod.trebuchet/com.android.launcher3.Launcher} from uid 0 on display 0
01-03 18:23:31.316 V/WindowManager( 491): addAppToken: AppWindowToken{3c050f23 token=Token{9a6c052 ActivityRecord{150eccdd u0 com.cyanogenmod.trebuchet/com.android.launcher3.Launcher t18}}} to stack=0 task=18 at 0
01-03 18:23:31.425 I/ActivityManager( 491): Start proc 844:com.cyanogenmod.trebuchet/u0a15 for activity com.cyanogenmod.trebuchet/com.android.launcher3.Launcher
01-03 18:23:31.443 I/SystemServer( 491): Enabled StrictMode for system server main thread.
01-03 18:23:31.529 I/ActivityManager( 491): Start proc 864:com.android.printspooler/u0a51 for service com.android.printspooler/.model.PrintSpoolerService
01-03 18:23:31.628 V/ActivityManager( 491): Display changed displayId=0
01-03 18:23:31.629 V/ActivityManager( 491): Display changed displayId=0
01-03 18:23:31.631 V/ActivityManager( 491): Display changed displayId=0
01-03 18:23:31.777 I/auditd ( 884): Starting up
01-03 18:23:31.791 E/auditd ( 884): Failed on audit_set_pid with error: Protocol not supported
01-03 18:23:31.791 I/auditd ( 884): Exiting
01-03 18:23:31.853 V/ActivityManager( 491): Display changed displayId=0
01-03 18:23:31.862 V/ActivityManager( 491): Display changed displayId=0
01-03 18:23:33.786 W/WindowManager( 491): Window freeze timeout expired.
01-03 18:23:33.786 W/WindowManager( 491): Force clearing orientation change: Window{34717692 u0 KeyguardScrim}
01-03 18:23:36.752 I/Telecom ( 491): TelecomGlobals: TelecomGlobals initializing
01-03 18:23:36.843 I/auditd ( 952): Starting up
01-03 18:23:36.844 E/auditd ( 952): Failed on audit_set_pid with error: Protocol not supported
01-03 18:23:36.844 I/auditd ( 952): Exiting
01-03 18:23:36.875 I/ActivityManager( 491): Start proc 956:android.process.acore/u0a5 for content provider com.android.providers.contacts/.CallLogProvider
01-03 18:23:38.725 I/Telecom ( 491): TelecomGlobals: CallsManager initialized
01-03 18:23:38.730 W/ContextImpl( 491): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1721 android.content.ContextWrapper.startService:522 com.android.server.telecom.BluetoothPhoneService.start:468 com.android.server.telecom.TelecomGlobals.initialize:104 com.android.server.telecom.TelecomService.onCreate:164
01-03 18:23:38.756 D/ZenLog ( 491): downtime: Autotrigger skipped: not in downtime
01-03 18:23:38.762 V/WiredAccessoryManager( 491): notifyWiredAccessoryChanged: when=0 bits= mask=54
01-03 18:23:38.762 V/WiredAccessoryManager( 491): newName=h2w newState=0 headsetState=0 prev headsetState=0
01-03 18:23:38.762 V/WiredAccessoryManager( 491): init()
01-03 18:23:38.941 W/ResourcesManager( 491): Asset path '/system/framework/com.google.android.media.effects.jar' does not exist or contains no resources.
01-03 18:23:39.083 I/ActivityManager( 491): Start proc 1046:com.cyanogenmod.eleven/u0a34 for broadcast com.cyanogenmod.eleven/.MediaButtonIntentReceiver
01-03 18:23:39.808 V/BackupManagerService( 491): Connected to transport ComponentInfo{android/com.android.internal.backup.LocalTransportService}
01-03 18:23:39.809 V/BackupManagerService( 491): Registering transport android/com.android.internal.backup.LocalTransportService::android/com.android.internal.backup.LocalTransport = android.app.backup.BackupTransport$TransportImpl@ece0fbe
01-03 18:23:40.152 I/ActivityManager( 491): Start proc 1068:com.google.process.location/u0a18 for broadcast com.google.android.gms/com.google.android.location.internal.NlpNetworkProviderSettingsUpdateReceiver
01-03 18:23:40.267 W/ResourcesManager( 1068): Asset path '/system/framework/com.android.media.remotedisplay.jar' does not exist or contains no resources.
01-03 18:23:40.268 W/ResourcesManager( 1068): Asset path '/system/framework/com.android.location.provider.jar' does not exist or contains no resources.
01-03 18:23:41.485 I/ActivityManager( 491): Start proc 1097:com.google.android.googlequicksearchbox:search/u0a22 for service com.google.android.googlequicksearchbox/com.google.android.hotword.service.HotwordService
01-03 18:23:41.554 W/KeyguardServiceDelegate( 491): onScreenTurnedOn(): no keyguard service!
01-03 18:23:41.778 I/auditd ( 1118): Starting up
01-03 18:23:41.779 E/auditd ( 1118): Failed on audit_set_pid with error: Protocol not supported
01-03 18:23:41.779 I/auditd ( 1118): Exiting
01-03 18:23:41.935 I/ActivityManager( 491): Start proc 1122:com.cyanogenmod.eleven:main/u0a34 for service com.cyanogenmod.eleven/.MusicPlaybackService
01-03 18:23:42.554 W/WindowManager( 491): Keyguard drawn timeout. Setting mKeyguardDrawComplete
01-03 18:23:46.389 I/auditd ( 1160): Starting up
01-03 18:23:46.390 E/auditd ( 1160): Failed on audit_set_pid with error: Protocol not supported
01-03 18:23:46.390 I/auditd ( 1160): Exiting
01-03 18:23:47.881 D/VoldCmdListener( 102): cryptfs getpw
01-03 18:23:47.888 D/VoldCmdListener( 102): cryptfs clearpw
01-03 18:23:49.321 I/StatusBarManagerService( 491): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@1ad2f260
01-03 18:23:50.757 I/ActivityManager( 491): Start proc 1188:com.android.smspush/u0a57 for service com.android.smspush/.WapPushManager
01-03 18:23:51.676 I/auditd ( 1213): Starting up
01-03 18:23:51.677 E/auditd ( 1213): Failed on audit_set_pid with error: Protocol not supported
01-03 18:23:51.677 I/auditd ( 1213): Exiting
01-03 18:23:52.864 E/ConnectivityService( 491): Failed to find Messenger in unregisterNetworkFactory
01-03 18:23:52.869 D/ConnectivityService( 491): Got NetworkFactory Messenger for Telephony
01-03 18:23:52.948 W/ActivityManager( 491): Unable to start service Intent { cmp=org.codeaurora.ims/.ImsService } U=0: not found
01-03 18:23:54.202 W/ResourcesManager( 621): Asset path '/system/framework/com.google.android.camera2.jar' does not exist or contains no resources.
01-03 18:23:54.738 V/ActivityManager( 491): Display changed displayId=0
01-03 18:23:54.851 V/WindowManager( 491): Based on layer: Adding window Window{364b8d80 u0 com.cyanogenmod.trebuchet/com.android.launcher3.Launcher} at 0 of 1
01-03 18:23:55.147 I/ActivityManager( 491): Start proc 1240:com.google.process.gapps/u0a18 for content provider com.google.android.gsf/.gservices.GservicesProvider
--------- beginning of crash
01-03 18:23:55.253 F/libc ( 103): Fatal signal 6 (SIGABRT), code -6 in tid 103 (surfaceflinger)
01-03 18:23:56.488 I/auditd ( 1261): Starting up
01-03 18:23:56.488 E/auditd ( 1261): Failed on audit_set_pid with error: Protocol not supported
01-03 18:23:56.488 I/auditd ( 1261): Exiting
01-03 18:23:56.542 D/WifiService( 491): New client listening to asynchronous messages
01-03 18:23:56.596 D/ConnectivityService( 491): listenForNetwork for NetworkRequest [ id=2, legacyType=-1, [] ]
01-03 18:23:56.631 I/DEBUG ( 111): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
01-03 18:23:56.631 I/DEBUG ( 111): Build fingerprint: 'Android/cm_rk31board/rk31board:5.1.1/LVY48F/c15a1fd43d:userdebug/test-keys'
01-03 18:23:56.631 I/DEBUG ( 111): Revision: '0'
01-03 18:23:56.631 I/DEBUG ( 111): ABI: 'arm'
01-03 18:23:56.632 I/DEBUG ( 111): pid: 103, tid: 103, name: surfaceflinger >>> /system/bin/surfaceflinger <<<
01-03 18:23:56.632 I/DEBUG ( 111): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
01-03 18:23:56.638 W/NativeCrashListener( 491): Couldn't find ProcessRecord for pid 103
01-03 18:23:56.735 I/ActivityManager( 491): Start proc 1269:com.cyanogenmod.lockclock/u0a43 for content provider com.cyanogenmod.lockclock/.weather.WeatherContentProvider
01-03 18:23:57.963 I/DEBUG ( 111): Abort message: 'eglSwapBuffers(0x1, 0x40c70100) failed with 0x0000300d'
01-03 18:23:57.963 I/DEBUG ( 111): r0 00000000 r1 00000067 r2 00000006 r3 00000000
01-03 18:23:57.963 I/DEBUG ( 111): r4 40089e38 r5 00000006 r6 0000000b r7 0000010c
01-03 18:23:57.963 I/DEBUG ( 111): r8 00000000 r9 bef3a9f0 sl 40c74110 fp bef3a9f0
01-03 18:23:57.963 I/DEBUG ( 111): ip 00000067 sp bef3a470 lr 40226789 pc 4024a0a0 cpsr 600f0010
01-03 18:23:57.963 I/DEBUG ( 111): backtrace:
01-03 18:23:57.963 I/DEBUG ( 111): #00 pc 000380a0 /system/lib/libc.so (tgkill+12)
01-03 18:23:57.963 I/DEBUG ( 111): #01 pc 00014785 /system/lib/libc.so (pthread_kill+52)
01-03 18:23:57.963 I/DEBUG ( 111): #02 pc 000154e3 /system/lib/libc.so (raise+10)
01-03 18:23:57.963 I/DEBUG ( 111): #03 pc 00011b4d /system/lib/libc.so (__libc_android_abort+36)
01-03 18:23:57.963 I/DEBUG ( 111): #04 pc 0001002c /system/lib/libc.so (abort+4)
01-03 18:23:57.963 I/DEBUG ( 111): #05 pc 00007b1d /system/lib/libcutils.so (__android_log_assert+88)
01-03 18:23:57.963 I/DEBUG ( 111): #06 pc 0000f77b /system/lib/libsurfaceflinger.so
01-03 18:23:57.963 I/DEBUG ( 111): #07 pc 0001c407 /system/lib/libsurfaceflinger.so
01-03 18:23:57.964 I/DEBUG ( 111): #08 pc 0001b5bb /system/lib/libsurfaceflinger.so
01-03 18:23:57.964 I/DEBUG ( 111): #09 pc 0001a91b /system/lib/libsurfaceflinger.so
01-03 18:23:57.964 I/DEBUG ( 111): #10 pc 0001a681 /system/lib/libsurfaceflinger.so
01-03 18:23:57.964 I/DEBUG ( 111): #11 pc 00011047 /system/lib/libutils.so (android::Looper::pollInner(int)+410)
01-03 18:23:57.964 I/DEBUG ( 111): #12 pc 00011139 /system/lib/libutils.so (android::Looper::pollOnce(int, int*, int*, void**)+92)
01-03 18:23:57.964 I/DEBUG ( 111): #13 pc 00017d85 /system/lib/libsurfaceflinger.so
01-03 18:23:57.964 I/DEBUG ( 111): #14 pc 0001a271 /system/lib/libsurfaceflinger.so (android::SurfaceFlinger::run()+8)
01-03 18:23:57.964 I/DEBUG ( 111): #15 pc 00000b4d /system/bin/surfaceflinger
01-03 18:23:57.964 I/DEBUG ( 111): #16 pc 0000fee9 /system/lib/libc.so (__libc_init+44)
01-03 18:23:57.964 I/DEBUG ( 111): #17 pc 00000c08 /system/bin/surfaceflinger
01-03 18:23:58.041 I/ActivityManager( 491): Start proc 1294:com.google.android.partnersetup/u0a19 for content provider com.google.android.partnersetup/.RlzAppProvider
01-03 18:23:58.442 F/libc ( 844): Fatal signal 6 (SIGABRT), code -6 in tid 1235 (RenderThread)
01-03 18:23:58.444 I/DEBUG ( 111): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
01-03 18:23:58.444 I/DEBUG ( 111): Build fingerprint: 'Android/cm_rk31board/rk31board:5.1.1/LVY48F/c15a1fd43d:userdebug/test-keys'
01-03 18:23:58.444 I/DEBUG ( 111): Revision: '0'
01-03 18:23:58.444 I/DEBUG ( 111): ABI: 'arm'
01-03 18:23:58.445 I/DEBUG ( 111): pid: 844, tid: 1235, name: RenderThread >>> com.cyanogenmod.trebuchet <<<
01-03 18:23:58.445 I/DEBUG ( 111): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
01-03 18:23:58.487 I/DEBUG ( 111): Abort message: 'Failed to make current on surface 0x426f2200, error=EGL_BAD_ALLOC'
01-03 18:23:58.487 I/DEBUG ( 111): r0 00000000 r1 000004d3 r2 00000006 r3 00000000
01-03 18:23:58.487 I/DEBUG ( 111): r4 6e194db8 r5 00000006 r6 00000002 r7 0000010c
01-03 18:23:58.487 I/DEBUG ( 111): r8 426a37ac r9 6e194d08 sl 401e8f51 fp 6e194db0
01-03 18:23:58.488 I/DEBUG ( 111): ip 000004d3 sp 6e194828 lr 401e9789 pc 4020d0a0 cpsr 600f0010
01-03 18:23:58.488 I/DEBUG ( 111): backtrace:
01-03 18:23:58.488 I/DEBUG ( 111): #00 pc 000380a0 /system/lib/libc.so (tgkill+12)
01-03 18:23:58.488 I/DEBUG ( 111): #01 pc 00014785 /system/lib/libc.so (pthread_kill+52)
01-03 18:23:58.489 I/DEBUG ( 111): #02 pc 000154e3 /system/lib/libc.so (raise+10)
01-03 18:23:58.489 I/DEBUG ( 111): #03 pc 00011b4d /system/lib/libc.so (__libc_android_abort+36)
01-03 18:23:58.489 I/DEBUG ( 111): #04 pc 0001002c /system/lib/libc.so (abort+4)
01-03 18:23:58.489 I/DEBUG ( 111): #05 pc 00007b1d /system/lib/libcutils.so (__android_log_assert+88)
01-03 18:23:58.489 I/DEBUG ( 111): #06 pc 0003bb87 /system/lib/libhwui.so
01-03 18:23:58.489 I/DEBUG ( 111): #07 pc 0003a8d5 /system/lib/libhwui.so
01-03 18:23:58.489 I/DEBUG ( 111): #08 pc 0003a971 /system/lib/libhwui.so
01-03 18:23:58.489 I/DEBUG ( 111): #09 pc 0003a9af /system/lib/libhwui.so
01-03 18:23:58.489 I/DEBUG ( 111): #10 pc 0003c085 /system/lib/libhwui.so
01-03 18:23:58.489 I/DEBUG ( 111): #11 pc 0003c021 /system/lib/libhwui.so
01-03 18:23:58.490 I/DEBUG ( 111): #12 pc 0003ca65 /system/lib/libhwui.so
01-03 18:23:58.490 I/DEBUG ( 111): #13 pc 0003d3ab /system/lib/libhwui.so (android::uirenderer::renderthread::RenderThread::threadLoop()+66)
01-03 18:23:58.490 I/DEBUG ( 111): #14 pc 0000f029 /system/lib/libutils.so (android::Thread::_threadLoop(void*)+112)
01-03 18:23:58.490 I/DEBUG ( 111): #15 pc 0005bc15 /system/lib/libandroid_runtime.so (android::AndroidRuntime::javaThreadShell(void*)+72)
01-03 18:23:58.490 I/DEBUG ( 111): #16 pc 0000eb81 /system/lib/libutils.so
01-03 18:23:58.490 I/DEBUG ( 111): #17 pc 00013f6f /system/lib/libc.so (__pthread_start(void*)+30)
01-03 18:23:58.490 I/DEBUG ( 111): #18 pc 00011eb7 /system/lib/libc.so (__start_thread+6)
01-03 18:23:59.309 I/DEBUG ( 111): ptrace detach from 844 failed: No such process
01-03 18:23:59.309 I/DEBUG ( 111): ptrace attach to 850 failed: No such process
01-03 18:23:59.309 I/DEBUG ( 111): ptrace attach to 851 failed: No such process
01-03 18:23:59.309 I/DEBUG ( 111): ptrace attach to 852 failed: No such process
01-03 18:23:59.309 I/DEBUG ( 111): ptrace attach to 853 failed: No such process
01-03 18:23:59.309 I/DEBUG ( 111): ptrace attach to 854 failed: No such process
01-03 18:23:59.309 I/DEBUG ( 111): ptrace attach to 855 failed: No such process
01-03 18:23:59.310 I/DEBUG ( 111): ptrace attach to 856 failed: No such process
01-03 18:23:59.310 I/DEBUG ( 111): ptrace attach to 857 failed: No such process
01-03 18:23:59.310 I/DEBUG ( 111): ptrace attach to 858 failed: No such process
01-03 18:23:59.310 I/DEBUG ( 111): ptrace attach to 859 failed: No such process
01-03 18:23:59.310 I/DEBUG ( 111): ptrace attach to 860 failed: No such process
01-03 18:23:59.310 I/DEBUG ( 111): ptrace attach to 863 failed: No such process
01-03 18:23:59.310 I/DEBUG ( 111): ptrace attach to 1092 failed: No such process
01-03 18:23:59.310 I/DEBUG ( 111): ptrace attach to 1093 failed: No such process
01-03 18:23:59.310 I/DEBUG ( 111): ptrace attach to 1153 failed: No such process
01-03 18:23:59.310 I/DEBUG ( 111): ptrace attach to 1172 failed: No such process
01-03 18:23:59.310 I/DEBUG ( 111): ptrace attach to 1231 failed: No such process
01-03 18:23:59.310 I/DEBUG ( 111): ptrace attach to 1249 failed: No such process
01-03 18:23:59.310 I/DEBUG ( 111): ptrace attach to 1250 failed: No such process
01-03 18:23:59.310 I/DEBUG ( 111): ptrace attach to 1252 failed: No such process
01-03 18:23:59.310 I/DEBUG ( 111): ptrace attach to 1289 failed: No such process
01-03 18:24:01.989 I/auditd ( 1542): Starting up
01-03 18:24:01.990 E/auditd ( 1542): Failed on audit_set_pid with error: Protocol not supported
01-03 18:24:01.990 I/auditd ( 1542): Exiting
01-03 18:24:03.814 I/InstallerConnection( 1576): disconnecting...
01-03 18:24:03.842 I/SystemServer( 1576): Entered the Android system server!
01-03 18:24:03.910 I/SystemServiceManager( 1576): Starting com.android.server.pm.Installer
01-03 18:24:03.911 I/Installer( 1576): Waiting for installd to be ready.
01-03 18:24:03.911 I/InstallerConnection( 1576): connecting...
01-03 18:24:03.912 I/SystemServiceManager( 1576): Starting com.android.server.am.ActivityManagerService$Lifecycle
01-03 18:24:03.940 I/XXXXXX ( 1576): choosing minFree values for 32 Bit
01-03 18:24:03.951 I/ActivityManager( 1576): Memory class: 192
01-03 18:24:03.953 I/ServiceThread( 1576): Enabled StrictMode logging for ActivityManager looper.
01-03 18:24:03.957 I/ServiceThread( 1576): Enabled StrictMode logging for android.ui looper.
01-03 18:24:04.092 I/IntentFirewall( 1576): Read new rules (A:0 B:0 S:0)
01-03 18:24:04.110 I/ServiceThread( 1576): Enabled StrictMode logging for android.display looper.
01-03 18:24:06.126 I/auditd ( 1612): Starting up
01-03 18:24:06.127 E/auditd ( 1612): Failed on audit_set_pid with error: Protocol not supported
01-03 18:24:06.127 I/auditd ( 1612): Exiting
01-03 18:24:06.621 F/libc ( 112): Fatal signal 13 (SIGPIPE), code 0 in tid 239 (rild)
01-03 18:24:06.632 D/AppOps ( 1576): AppOpsService published
01-03 18:24:06.635 I/SystemServiceManager( 1576): Starting com.android.server.power.PowerManagerService
01-03 18:24:06.641 I/ServiceThread( 1576): Enabled StrictMode logging for PowerManagerService looper.
01-03 18:24:06.659 I/SystemServiceManager( 1576): Starting com.android.server.display.DisplayManagerService
01-03 18:24:06.670 I/DisplayManagerService( 1576): Display device added: DisplayDeviceInfo{"Integrierter Bildschirm": uniqueId="local:0", 1536 x 2048, 56.097 fps, supportedRefreshRates [56.097], density 280, 288.99554 x 240.82962 dpi, appVsyncOff 0, presDeadline 18826265, touch INTERNAL, rotation 0, type BUILT_IN, state UNKNOWN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
01-03 18:24:06.671 I/SystemServiceManager( 1576): Starting phase 100
01-03 18:24:06.671 I/SystemServer( 1576): Package Manager
01-03 18:24:06.685 W/PackageManager( 1576): No security bridge jar found, using default
01-03 18:24:06.693 W/SystemConfig( 1576): No directory /system/etc/sysconfig, skipping
01-03 18:24:06.724 I/DEBUG ( 1433): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
01-03 18:24:06.724 I/DEBUG ( 1433): Build fingerprint: 'Android/cm_rk31board/rk31board:5.1.1/LVY48F/c15a1fd43d:userdebug/test-keys'
01-03 18:24:06.724 I/DEBUG ( 1433): Revision: '0'
01-03 18:24:06.724 I/DEBUG ( 1433): ABI: 'arm'
01-03 18:24:06.725 I/DEBUG ( 1433): pid: 112, tid: 239, name: rild >>> /system/bin/rild <<<
01-03 18:24:06.725 I/DEBUG ( 1433): signal 13 (SIGPIPE), code 0 (SI_USER), fault addr --------
01-03 18:24:06.753 I/DEBUG ( 1433): r0 ffffffe0 r1 403e5994 r2 00000004 r3 00000000
01-03 18:24:06.753 I/DEBUG ( 1433): r4 00000000 r5 00000004 r6 0000000e r7 00000004
01-03 18:24:06.753 I/DEBUG ( 1433): r8 403e5994 r9 403e5994 sl 4013e664 fp 403e5bc8
01-03 18:24:06.753 I/DEBUG ( 1433): ip 00000004 sp 403e5960 lr 401367d5 pc 400bb8c8 cpsr 200d0010
01-03 18:24:06.753 I/DEBUG ( 1433): backtrace:
01-03 18:24:06.753 I/DEBUG ( 1433): #00 pc 000388c8 /system/lib/libc.so (write+12)
01-03 18:24:06.753 I/DEBUG ( 1433): #01 pc 000037d1 /system/lib/libril.so
01-03 18:24:06.753 I/DEBUG ( 1433): #02 pc 00006675 /system/lib/libril.so
01-03 18:24:06.754 I/DEBUG ( 1433): #03 pc 00006dfb /system/lib/libril.so (RIL_onUnsolicitedResponse+426)
01-03 18:24:06.754 I/DEBUG ( 1433): #04 pc 00006d4d /system/lib/libril.so (RIL_onUnsolicitedResponse+252)
01-03 18:24:06.754 I/DEBUG ( 1433): #05 pc 0000b699 /system/lib/libril-rk29-dataonly.so
01-03 18:24:06.754 I/DEBUG ( 1433): #06 pc 0000e86d /system/lib/libril-rk29-dataonly.so
01-03 18:24:06.754 I/DEBUG ( 1433): #07 pc 00005f6b /system/lib/libril.so
01-03 18:24:06.754 I/DEBUG ( 1433): #08 pc 00006813 /system/lib/libril.so
01-03 18:24:06.754 I/DEBUG ( 1433): #09 pc 000075a7 /system/lib/libril.so (ril_event_loop()+402)
01-03 18:24:06.754 I/DEBUG ( 1433): #10 pc 0000375f /system/lib/libril.so
01-03 18:24:06.754 I/DEBUG ( 1433): #11 pc 00013f6f /system/lib/libc.so (__pthread_start(void*)+30)
01-03 18:24:06.754 I/DEBUG ( 1433): #12 pc 00011eb7 /system/lib/libc.so (__start_thread+6)
01-03 18:24:06.784 D/SELinuxMMAC( 1576): Using policy file /system/etc/security/mac_permissions.xml
01-03 18:24:07.903 I/PackageManager( 1576): Replacing default ResolverActivity with custom activity: ComponentInfo{org.cyanogenmod.resolver/org.cyanogenmod.resolver.ResolverActivity}
01-03 18:24:08.015 W/PackageParser( 1576): No actions in intent filter at /system/priv-app/Contacts/Contacts.apk Binary XML file line #362
01-03 18:24:09.332 W/PackageParser( 1576): Unknown element under : android at /system/priv-app/Telecom/Telecom.apk Binary XML file line #236
01-03 18:24:09.332 W/PackageParser( 1576): Unknown element under : android at /system/priv-app/Telecom/Telecom.apk Binary XML file line #244
01-03 18:24:10.925 W/PackageParser( 1576): No actions in intent filter at /system/app/Bluetooth/Bluetooth.apk Binary XML file line #229
01-03 18:24:11.063 W/PackageParser( 1576): No actions in intent filter at /system/app/CMFileManager/CMFileManager.apk Binary XML file line #166
01-03 18:24:11.151 I/auditd ( 1623): Starting up
01-03 18:24:11.152 E/auditd ( 1623): Failed on audit_set_pid with error: Protocol not supported
01-03 18:24:11.152 I/auditd ( 1623): Exiting
01-03 18:24:11.916 W/PackageParser( 1576): Unknown element under : permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #277
01-03 18:24:11.916 W/PackageParser( 1576): Unknown element under : permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #280
01-03 18:24:13.328 W/PackageManager( 1576): Package com.google.android.gms desires unavailable shared library com.google.android.ble; ignoring!
01-03 18:24:13.328 W/PackageManager( 1576): Package com.android.calculator2 desires unavailable shared library com.sec.android.app.multiwindow; ignoring!
01-03 18:24:13.328 W/PackageManager( 1576): Package com.google.android.GoogleCamera desires unavailable shared library com.google.android.gestureservice; ignoring!
01-03 18:24:13.328 I/PackageManager( 1576): Adjusting ABI for : com.google.android.syncadapters.contacts to armeabi-v7a
01-03 18:24:13.329 I/PackageManager( 1576): Adjusting ABI for : com.google.android.backuptransport to armeabi-v7a
01-03 18:24:13.329 I/PackageManager( 1576): Adjusting ABI for : com.google.android.gsf to armeabi-v7a
01-03 18:24:13.330 I/PackageManager( 1576): Adjusting ABI for : com.google.android.gsf.login to armeabi-v7a
01-03 18:24:13.330 I/PackageManager( 1576): Adjusting ABI for : com.android.location.fused to armeabi-v7a
01-03 18:24:13.331 I/PackageManager( 1576): Adjusting ABI for : org.cyanogenmod.resolver to armeabi-v7a
01-03 18:24:13.331 I/PackageManager( 1576): Adjusting ABI for : cyanogenmod.platform to armeabi-v7a
01-03 18:24:13.331 I/PackageManager( 1576): Adjusting ABI for : com.android.server.telecom to armeabi-v7a
01-03 18:24:13.332 I/PackageManager( 1576): Adjusting ABI for : com.android.development to armeabi-v7a
01-03 18:24:13.332 I/PackageManager( 1576): Adjusting ABI for : com.android.keychain to armeabi-v7a
01-03 18:24:13.332 I/PackageManager( 1576): Adjusting ABI for : com.android.inputdevices to armeabi-v7a
01-03 18:24:13.332 I/PackageManager( 1576): Adjusting ABI for : com.android.settings to armeabi-v7a
01-03 18:24:13.332 I/PackageManager( 1576): Adjusting ABI for : com.android.providers.settings to armeabi-v7a
01-03 18:24:13.333 I/PackageManager( 1576): Adjusting ABI for : org.cyanogenmod.cmsettings to armeabi-v7a
01-03 18:24:13.334 I/PackageManager( 1576): Time to scan packages: 6.453 seconds
01-03 18:24:13.335 W/PackageManager( 1576): Unknown permission com.google.android.voicesearch.SHORTCUTS_ACCESS in package com.google.android.googlequicksearchbox
01-03 18:24:13.335 W/PackageManager( 1576): Unknown permission com.google.android.voicesearch.ACCESS_SETTINGS in package com.google.android.googlequicksearchbox
01-03 18:24:13.335 W/PackageManager( 1576): Unknown permission com.google.android.ears.permission.WRITE in package com.google.android.googlequicksearchbox
01-03 18:24:13.335 W/PackageManager( 1576): Unknown permission com.google.googlenav.friend.permission.OPT_IN in package com.google.android.googlequicksearchbox
01-03 18:24:13.335 W/PackageManager( 1576): Unknown permission com.google.android.apps.maps.permission.PREFETCH in package com.google.android.googlequicksearchbox
01-03 18:24:13.335 W/PackageManager( 1576): Unknown permission com.google.android.apps.googlevoice.permission.AUTO_SEND in package com.google.android.googlequicksearchbox
01-03 18:24:13.335 W/PackageManager( 1576): Unknown permission com.google.android.hangouts.START_HANGOUT in package com.google.android.googlequicksearchbox
01-03 18:24:13.335 W/PackageManager( 1576): Unknown permission com.android.chrome.PRERENDER_URL in package com.google.android.googlequicksearchbox
01-03 18:24:13.335 W/PackageManager( 1576): Unknown permission com.google.android.launcher.permission.CONTENT_REDIRECT in package com.google.android.googlequicksearchbox
01-03 18:24:13.335 W/PackageManager( 1576): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.google.android.onetimeinitializer
01-03 18:24:13.335 W/PackageManager( 1576): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.google.android.onetimeinitializer
01-03 18:24:13.335 W/PackageManager( 1576): Not granting permission android.permission.REAL_GET_TASKS to package org.cyanogenmod.wallpapers.photophase (protectionLevel=18 flags=0x18be45)
01-03 18:24:13.336 W/PackageManager( 1576): Not granting permission android.permission.ACCESS_DOWNLOAD_MANAGER to package com.android.browser (protectionLevel=18 flags=0x49be45)
01-03 18:24:13.336 W/PackageManager( 1576): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x49be45)
01-03 18:24:13.336 W/PackageManager( 1576): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package com.android.soundrecorder (protectionLevel=18 flags=0x8be45)
01-03 18:24:13.336 W/PackageManager( 1576): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.vending (protectionLevel=2 flags=0x400abe45)
01-03 18:24:13.336 W/PackageManager( 1576): Unknown permission android.permission.SEND_SMS_NO_CONFIRMATION in package com.android.vending
01-03 18:24:13.337 W/PackageManager( 1576): Unknown permission com.google.android.email.permission.READ_ATTACHMENT in package com.google.android.gm
01-03 18:24:13.337 W/PackageManager( 1576): Unknown permission com.google.android.email.permission.ACCESS_PROVIDER in package com.google.android.gm
01-03 18:24:13.337 W/PackageManager( 1576): Unknown permission com.google.android.gms.permission.CONTACTS_SYNC_DELEGATION in package com.google.android.syncadapters.contacts
01-03 18:24:13.337 W/PackageManager( 1576): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.cyanogenmod.trebuchet
01-03 18:24:13.337 W/PackageManager( 1576): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.cyanogenmod.trebuchet
01-03 18:24:13.337 W/PackageManager( 1576): Unknown permission com.cyngn.stats.SEND_ANALYTICS in package com.cyanogenmod.trebuchet
01-03 18:24:13.337 W/PackageManager( 1576): Unknown permission com.google.android.apps.enterprise.dmagent.permission.AutoSyncPermission in package com.google.android.gms
01-03 18:24:13.337 W/PackageManager( 1576): Unknown permission com.google.android.hangouts.START_HANGOUT in package com.google.android.gms
01-03 18:24:13.337 W/PackageManager( 1576): Unknown permission com.google.android.wearable.READ_SETTINGS in package com.google.android.gms
01-03 18:24:13.338 W/PackageManager( 1576): Unknown permission com.android.launcher.permission.PRELOAD_WORKSPACE in package com.google.android.partnersetup
01-03 18:24:13.338 W/PackageManager( 1576): Unknown permission android.permission.CANCEL_NOTIFICATIONS in package org.cyanogenmod.theme.chooser
01-03 18:24:13.338 W/PackageManager( 1576): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x8be45)
01-03 18:24:13.339 W/PackageManager( 1576): Unknown permission android.permission.ACCESS_SUPERUSER in package com.cyanogenmod.filemanager
01-03 18:24:13.339 W/PackageManager( 1576): Unknown permission com.cyanogenmod.filemanager.permissions.READ_THEME in package com.cyanogenmod.filemanager
01-03 18:24:13.339 W/PackageManager( 1576): Unknown permission com.google.android.gallery3d.permission.PICASA_STORE in package com.android.dreams.phototable
01-03 18:24:13.339 W/PackageManager( 1576): Unknown permission com.android.vending.billing.IBillingAccountService.BIND2 in package com.google.android.gsf.login
01-03 18:24:13.339 W/PackageManager( 1576): Unknown permission com.android.chrome.TOS_ACKED in package com.google.android.gsf.login
01-03 18:24:13.340 W/PackageManager( 1576): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.settings
01-03 18:24:13.340 W/PackageManager( 1576): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.settings
01-03 18:24:13.340 W/PackageManager( 1576): Unknown permission com.cyanogen.permission.REQUEST_KILL_SWITCH_OP in package com.android.settings
01-03 18:24:13.340 W/PackageManager( 1576): Unknown permission cyanogenmod.permission.FINISH_SETUP in package com.android.settings
01-03 18:24:13.340 W/PackageManager( 1576): Unknown permission com.cyngn.stats.SEND_ANALYTICS in package com.android.settings
01-03 18:24:13.340 W/PackageManager( 1576): Not granting permission android.permission.REAL_GET_TASKS to package com.cyanogenmod.eleven (protectionLevel=18 flags=0x18be65)
01-03 18:24:13.340 W/PackageManager( 1576): Not granting permission android.permission.REBOOT to package eu.chainfire.supersu (protectionLevel=18 flags=0x83e05)
01-03 18:24:13.340 W/PackageManager( 1576): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x48be45)
01-03 18:24:13.340 W/PackageManager( 1576): Unknown permission com.android.deskclock.worldclock.permissions.WRITE_DATABASE in package com.android.deskclock
01-03 18:24:13.341 W/PackageManager( 1576): Unknown permission com.cyngn.stats.SEND_ANALYTICS in package com.android.systemui
01-03 18:24:13.341 W/PackageManager( 1576): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
01-03 18:24:13.341 W/PackageManager( 1576): Unknown permission android.permission.MMS_SEND_OUTBOX_MSG in package com.android.bluetooth
01-03 18:24:13.341 W/PackageManager( 1576): Not granting permission android.permission.HARDWARE_TEST to package android.rk.RockVideoPlayer (protectionLevel=2 flags=0x8be45)
01-03 18:24:13.341 W/PackageManager( 1576): Not granting permission android.permission.DEVICE_POWER to package android.rk.RockVideoPlayer (protectionLevel=2 flags=0x8be45)
01-03 18:24:13.341 W/PackageManager( 1576): Unknown permission rockchip.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
01-03 18:24:13.341 W/PackageManager( 1576): Unknown permission android.permission.RAISED_THREAD_PRIORITY in package android.rk.RockVideoPlayer
01-03 18:24:13.341 W/PackageManager( 1576): Unknown permission android.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
01-03 18:24:13.341 W/PackageManager( 1576): Unknown permission archos.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
01-03 18:24:13.341 W/PackageManager( 1576): Not granting permission android.permission.STATUS_BAR to package android.rk.RockVideoPlayer (protectionLevel=18 flags=0x8be45)
01-03 18:24:13.341 W/PackageManager( 1576): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package android.rk.RockVideoPlayer (protectionLevel=18 flags=0x8be45)
01-03 18:24:13.341 W/PackageManager( 1576): Not granting permission android.permission.CHANGE_CONFIGURATION to package android.rk.RockVideoPlayer (protectionLevel=50 flags=0x8be45)
01-03 18:24:13.341 W/PackageManager( 1576): Not granting permission android.permission.BIND_WALLPAPER to package com.google.android.GoogleCamera (protectionLevel=18 flags=0x583c45)
01-03 18:24:13.341 W/PackageManager( 1576): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.google.android.GoogleCamera
01-03 18:24:13.342 V/PackageManager( 1576): Disabling com.google.android.gsf/com.google.android.gsf.update.SystemUpdateActivity
01-03 18:24:13.343 V/PackageManager( 1576): Disabling com.google.android.gsf/com.google.android.gsf.update.SystemUpdateService$Receiver
01-03 18:24:13.343 V/PackageManager( 1576): Disabling com.google.android.gsf/com.google.android.gsf.update.SystemUpdateService$SecretCodeReceiver
01-03 18:24:13.343 V/PackageManager( 1576): Disabling com.google.android.gms/com.google.android.gms.update.SystemUpdateActivity
01-03 18:24:13.343 V/PackageManager( 1576): Disabling com.google.android.gms/com.google.android.gms.update.SystemUpdateService$Receiver
01-03 18:24:13.343 V/PackageManager( 1576): Disabling com.google.android.gms/com.google.android.gms.update.SystemUpdateService$ActiveReceiver
01-03 18:24:13.343 V/PackageManager( 1576): Disabling com.google.android.gms/com.google.android.gms.update.SystemUpdateService$SecretCodeReceiver
01-03 18:24:13.343 V/PackageManager( 1576): Enabling com.google.android.gsf/com.google.android.gsf.update.SystemUpdateService
01-03 18:24:13.343 V/PackageManager( 1576): Enabling com.google.android.gms/com.google.android.gms.update.SystemUpdateService
01-03 18:24:13.451 I/SystemServer( 1576): User Service
01-03 18:24:13.464 I/SystemServiceManager( 1576): Starting com.android.server.lights.LightsService
01-03 18:24:13.470 I/SystemServiceManager( 1576): Starting com.android.server.BatteryService
01-03 18:24:13.481 I/SystemServiceManager( 1576): Starting com.android.server.usage.UsageStatsService
01-03 18:24:13.493 I/SystemServiceManager( 1576): Starting com.android.server.webkit.WebViewUpdateService
01-03 18:24:13.496 I/SystemServer( 1576): Reading configuration...
01-03 18:24:13.496 I/SystemServer( 1576): Scheduling Policy
01-03 18:24:13.498 I/SystemServiceManager( 1576): Starting com.android.server.telecom.TelecomLoaderService
01-03 18:24:13.498 I/SystemServer( 1576): Telephony Registry
01-03 18:24:13.506 I/SystemServer( 1576): Entropy Mixer
01-03 18:24:13.511 I/EntropyMixer( 1576): Writing entropy...
01-03 18:24:13.514 I/SystemServer( 1576): Account Manager
01-03 18:24:13.526 I/SystemServer( 1576): Content Manager
01-03 18:24:13.532 I/SystemServer( 1576): System Content Providers
01-03 18:24:13.584 I/SystemServer( 1576): Vibrator Service
01-03 18:24:13.587 I/SystemServer( 1576): Consumer IR Service
01-03 18:24:13.589 I/SystemServiceManager( 1576): Starting com.android.server.AlarmManagerService
01-03 18:24:13.633 I/SystemServer( 1576): Init Watchdog
01-03 18:24:13.634 I/SystemServer( 1576): Input Manager
01-03 18:24:13.636 I/InputManager( 1576): Initializing input manager, mUseDevInputEventForAudioJack=true
01-03 18:24:13.638 I/SystemServer( 1576): Window Manager
01-03 18:24:13.660 I/WindowManager( 1576): No existing display settings /data/system/display_settings.xml; starting empty
01-03 18:24:13.823 I/InputManager( 1576): Starting input manager
01-03 18:24:13.831 I/SystemServer( 1576): Bluetooth Manager Service
01-03 18:24:13.843 I/SystemServer( 1576): Input Method Service
01-03 18:24:13.940 W/InputMethodManagerService( 1576): Couldn't create dir.: /data/system/inputmethod
01-03 18:24:13.974 I/SystemServer( 1576): Accessibility Manager
01-03 18:24:13.981 I/WindowManager( 1576): FORCED DISPLAY DENSITY: 320
01-03 18:24:13.981 I/XXXXXX ( 1576): choosing minFree values for 32 Bit
01-03 18:24:13.983 I/ActivityManager( 1576): Config changes=1df8 {1.0 ?mcc?mnc de_DE ?layoutDir sw768dp w768dp h1024dp 320dpi xlrg port ?uimode ?night -touch -keyb/v/h -nav/h s.2 themeResource=null}
01-03 18:24:13.991 I/ActivityManager( 1576): Config changes=408 {1.0 ?mcc?mnc de_DE ?layoutDir sw768dp w768dp h951dp 320dpi xlrg port ?uimode ?night finger -keyb/v/h -nav/h s.3 themeResource=null}
01-03 18:24:13.994 I/SystemServer( 1576): Mount Service
01-03 18:24:14.002 D/MountService( 1576): got storage path: null description: Interner Speicher primary: true removable: false emulated: true mtpReserve: 100 allowMassStorage: false maxFileSize: 0 allowMtp: true
01-03 18:24:14.004 D/MountService( 1576): addVolumeLocked() StorageVolume:
01-03 18:24:14.004 D/MountService( 1576): mStorageId=65537 mPath=/storage/emulated/0 mDescriptionId=17041015
01-03 18:24:14.004 D/MountService( 1576): mPrimary=true mRemovable=false mEmulated=true mMtpReserveSpace=100
01-03 18:24:14.004 D/MountService( 1576): mAllowMassStorage=false mMaxFileSize=0 mOwner=UserHandle{0} mUuid=null
01-03 18:24:14.004 D/MountService( 1576): mUserLabel=null mState=null mAllowMtp=true
01-03 18:24:14.005 D/MountService( 1576): got storage path: /storage/sdcard1 description: SD-Karte primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 4294967296 allowMtp: true
01-03 18:24:14.005 D/MountService( 1576): addVolumeLocked() StorageVolume:
01-03 18:24:14.005 D/MountService( 1576): mStorageId=0 mPath=/storage/sdcard1 mDescriptionId=17041016 mPrimary=false
01-03 18:24:14.005 D/MountService( 1576): mRemovable=true mEmulated=false mMtpReserveSpace=0 mAllowMassStorage=false
01-03 18:24:14.005 D/MountService( 1576): mMaxFileSize=4294967296 mOwner=null mUuid=null mUserLabel=null mState=null
01-03 18:24:14.005 D/MountService( 1576): mAllowMtp=true
01-03 18:24:14.006 D/MountService( 1576): got storage path: /storage/usb0 description: USB-Speicher primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0 allowMtp: true
01-03 18:24:14.006 D/MountService( 1576): addVolumeLocked() StorageVolume:
01-03 18:24:14.006 D/MountService( 1576): mStorageId=0 mPath=/storage/usb0 mDescriptionId=17041017 mPrimary=false
01-03 18:24:14.006 D/MountService( 1576): mRemovable=true mEmulated=false mMtpReserveSpace=0 mAllowMassStorage=false
01-03 18:24:14.006 D/MountService( 1576): mMaxFileSize=0 mOwner=null mUuid=null mUserLabel=null mState=null
01-03 18:24:14.006 D/MountService( 1576): mAllowMtp=true
01-03 18:24:14.014 I/SystemServer( 1576): LockSettingsService
01-03 18:24:14.024 D/MountService( 1576): volume state changed for /storage/sdcard1 (unmounted -> removed)
01-03 18:24:14.024 D/MountService( 1576): volume state changed for /storage/usb0 (unmounted -> removed)
01-03 18:24:14.027 I/SystemServiceManager( 1576): Starting com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle
01-03 18:24:14.030 W/PackageManager( 1576): Unknown permission com.google.android.voicesearch.SHORTCUTS_ACCESS in package com.google.android.googlequicksearchbox
01-03 18:24:14.030 W/PackageManager( 1576): Unknown permission com.google.android.voicesearch.ACCESS_SETTINGS in package com.google.android.googlequicksearchbox
01-03 18:24:14.030 W/PackageManager( 1576): Unknown permission com.google.android.ears.permission.WRITE in package com.google.android.googlequicksearchbox
01-03 18:24:14.030 W/PackageManager( 1576): Unknown permission com.google.googlenav.friend.permission.OPT_IN in package com.google.android.googlequicksearchbox
01-03 18:24:14.030 W/PackageManager( 1576): Unknown permission com.google.android.apps.maps.permission.PREFETCH in package com.google.android.googlequicksearchbox
01-03 18:24:14.030 W/PackageManager( 1576): Unknown permission com.google.android.apps.googlevoice.permission.AUTO_SEND in package com.google.android.googlequicksearchbox
01-03 18:24:14.030 W/PackageManager( 1576): Unknown permission com.google.android.hangouts.START_HANGOUT in package com.google.android.googlequicksearchbox
01-03 18:24:14.030 W/PackageManager( 1576): Unknown permission com.android.chrome.PRERENDER_URL in package com.google.android.googlequicksearchbox
01-03 18:24:14.030 W/PackageManager( 1576): Unknown permission com.google.android.launcher.permission.CONTENT_REDIRECT in package com.google.android.googlequicksearchbox
01-03 18:24:14.031 W/PackageManager( 1576): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.google.android.onetimeinitializer
01-03 18:24:14.031 W/PackageManager( 1576): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.google.android.onetimeinitializer
01-03 18:24:14.031 W/PackageManager( 1576): Not granting permission android.permission.REAL_GET_TASKS to package org.cyanogenmod.wallpapers.photophase (protectionLevel=18 flags=0x18be45)
01-03 18:24:14.032 W/PackageManager( 1576): Not granting permission android.permission.ACCESS_DOWNLOAD_MANAGER to package com.android.browser (protectionLevel=18 flags=0x49be45)
01-03 18:24:14.032 W/PackageManager( 1576): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x49be45)
01-03 18:24:14.032 W/PackageManager( 1576): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package com.android.soundrecorder (protectionLevel=18 flags=0x8be45)
01-03 18:24:14.032 W/PackageManager( 1576): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.vending (protectionLevel=2 flags=0x400abe45)
01-03 18:24:14.033 W/PackageManager( 1576): Unknown permission android.permission.SEND_SMS_NO_CONFIRMATION in package com.android.vending
01-03 18:24:14.033 W/PackageManager( 1576): Unknown permission com.google.android.email.permission.READ_ATTACHMENT in package com.google.android.gm
01-03 18:24:14.033 W/PackageManager( 1576): Unknown permission com.google.android.email.permission.ACCESS_PROVIDER in package com.google.android.gm
01-03 18:24:14.033 W/PackageManager( 1576): Unknown permission com.google.android.gms.permission.CONTACTS_SYNC_DELEGATION in package com.google.android.syncadapters.contacts
01-03 18:24:14.033 W/PackageManager( 1576): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.cyanogenmod.trebuchet
01-03 18:24:14.033 W/PackageManager( 1576): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.cyanogenmod.trebuchet
01-03 18:24:14.034 W/PackageManager( 1576): Unknown permission com.cyngn.stats.SEND_ANALYTICS in package com.cyanogenmod.trebuchet
01-03 18:24:14.034 W/PackageManager( 1576): Unknown permission com.google.android.apps.enterprise.dmagent.permission.AutoSyncPermission in package com.google.android.gms
01-03 18:24:14.034 W/PackageManager( 1576): Unknown permission com.google.android.hangouts.START_HANGOUT in package com.google.android.gms
01-03 18:24:14.034 W/PackageManager( 1576): Unknown permission com.google.android.wearable.READ_SETTINGS in package com.google.android.gms
01-03 18:24:14.035 W/PackageManager( 1576): Unknown permission com.android.launcher.permission.PRELOAD_WORKSPACE in package com.google.android.partnersetup
01-03 18:24:14.035 W/PackageManager( 1576): Unknown permission android.permission.CANCEL_NOTIFICATIONS in package org.cyanogenmod.theme.chooser
01-03 18:24:14.035 W/PackageManager( 1576): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x8be45)
01-03 18:24:14.035 W/PackageManager( 1576): Unknown permission android.permission.ACCESS_SUPERUSER in package com.cyanogenmod.filemanager
01-03 18:24:14.035 W/PackageManager( 1576): Unknown permission com.cyanogenmod.filemanager.permissions.READ_THEME in package com.cyanogenmod.filemanager
01-03 18:24:14.035 W/PackageManager( 1576): Unknown permission com.google.android.gallery3d.permission.PICASA_STORE in package com.android.dreams.phototable
01-03 18:24:14.036 W/PackageManager( 1576): Unknown permission com.android.vending.billing.IBillingAccountService.BIND2 in package com.google.android.gsf.login
01-03 18:24:14.036 W/PackageManager( 1576): Unknown permission com.android.chrome.TOS_ACKED in package com.google.android.gsf.login
01-03 18:24:14.036 I/UsageStatsService( 1576): User[0] Rollover scheduled @ 2011-01-04 01:00:00(1294099200000)
01-03 18:24:14.036 W/PackageManager( 1576): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.settings
01-03 18:24:14.036 W/PackageManager( 1576): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.settings
01-03 18:24:14.036 W/PackageManager( 1576): Unknown permission com.cyanogen.permission.REQUEST_KILL_SWITCH_OP in package com.android.settings
01-03 18:24:14.036 W/PackageManager( 1576): Unknown permission cyanogenmod.permission.FINISH_SETUP in package com.android.settings
01-03 18:24:14.036 W/PackageManager( 1576): Unknown permission com.cyngn.stats.SEND_ANALYTICS in package com.android.settings
01-03 18:24:14.036 W/PackageManager( 1576): Not granting permission android.permission.REAL_GET_TASKS to package com.cyanogenmod.eleven (protectionLevel=18 flags=0x18be65)
01-03 18:24:14.037 W/PackageManager( 1576): Not granting permission android.permission.REBOOT to package eu.chainfire.supersu (protectionLevel=18 flags=0x83e05)
01-03 18:24:14.038 W/PackageManager( 1576): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x48be45)
01-03 18:24:14.039 W/PackageManager( 1576): Unknown permission com.android.deskclock.worldclock.permissions.WRITE_DATABASE in package com.android.deskclock
01-03 18:24:14.039 W/PackageManager( 1576): Unknown permission com.cyngn.stats.SEND_ANALYTICS in package com.android.systemui
01-03 18:24:14.039 W/PackageManager( 1576): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
01-03 18:24:14.039 W/PackageManager( 1576): Unknown permission android.permission.MMS_SEND_OUTBOX_MSG in package com.android.bluetooth
01-03 18:24:14.040 W/PackageManager( 1576): Not granting permission android.permission.HARDWARE_TEST to package android.rk.RockVideoPlayer (protectionLevel=2 flags=0x8be45)
01-03 18:24:14.040 W/PackageManager( 1576): Not granting permission android.permission.DEVICE_POWER to package android.rk.RockVideoPlayer (protectionLevel=2 flags=0x8be45)
01-03 18:24:14.040 W/PackageManager( 1576): Unknown permission rockchip.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
01-03 18:24:14.040 W/PackageManager( 1576): Unknown permission android.permission.RAISED_THREAD_PRIORITY in package android.rk.RockVideoPlayer
01-03 18:24:14.040 W/PackageManager( 1576): Unknown permission android.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
01-03 18:24:14.040 W/PackageManager( 1576): Unknown permission archos.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
01-03 18:24:14.040 W/PackageManager( 1576): Not granting permission android.permission.STATUS_BAR to package android.rk.RockVideoPlayer (protectionLevel=18 flags=0x8be45)
01-03 18:24:14.040 W/PackageManager( 1576): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package android.rk.RockVideoPlayer (protectionLevel=18 flags=0x8be45)
01-03 18:24:14.040 W/PackageManager( 1576): Not granting permission android.permission.CHANGE_CONFIGURATION to package android.rk.RockVideoPlayer (protectionLevel=50 flags=0x8be45)
01-03 18:24:14.048 W/PackageManager( 1576): Not granting permission android.permission.BIND_WALLPAPER to package com.google.android.GoogleCamera (protectionLevel=18 flags=0x583c45)
01-03 18:24:14.048 W/PackageManager( 1576): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.google.android.GoogleCamera
01-03 18:24:14.097 I/SystemServer( 1576): Status Bar
01-03 18:24:14.104 I/SystemServer( 1576): Clipboard Service
01-03 18:24:14.111 W/ClipboardService( 1576): No security bridge jar found, using default
01-03 18:24:14.112 I/SystemServer( 1576): TorchService
01-03 18:24:15.384 I/SystemServer( 1576): NetworkManagement Service
01-03 18:24:15.400 I/SystemServer( 1576): Text Service Manager Service
01-03 18:24:15.425 I/SystemServer( 1576): Network Score Service
01-03 18:24:15.428 I/SystemServer( 1576): NetworkStats Service
01-03 18:24:15.438 I/SystemServer( 1576): NetworkPolicy Service
01-03 18:24:15.453 I/SystemServiceManager( 1576): Starting com.android.server.wifi.p2p.WifiP2pService
01-03 18:24:15.485 I/SystemServiceManager( 1576): Starting com.android.server.wifi.WifiService
01-03 18:24:15.748 I/SystemServiceManager( 1576): Starting com.android.server.wifi.WifiScanningService
01-03 18:24:15.751 I/SystemServiceManager( 1576): Starting com.android.server.wifi.RttService
01-03 18:24:15.755 I/SystemServiceManager( 1576): Starting com.android.server.ethernet.EthernetService
01-03 18:24:15.764 I/SystemServer( 1576): Connectivity Service
01-03 18:24:15.771 D/ConnectivityService( 1576): ConnectivityService starting up
01-03 18:24:15.775 D/ConnectivityService( 1576): wifiOnly=false
01-03 18:24:15.775 E/ConnectivityService( 1576): Ignoring protectedNetwork 14
01-03 18:24:15.775 E/ConnectivityService( 1576): Ignoring protectedNetwork 15
01-03 18:24:15.796 I/SystemServer( 1576): Network Service Discovery Service
01-03 18:24:15.803 D/NsdService( 1576): Network service discovery enabled true
01-03 18:24:15.807 I/SystemServer( 1576): DPM Service
01-03 18:24:15.807 I/SystemServer( 1576): DPM configuration set to 0
01-03 18:24:15.807 I/SystemServer( 1576): UpdateLock Service
01-03 18:24:15.843 I/SystemServiceManager( 1576): Starting com.android.server.notification.NotificationManagerService
01-03 18:24:15.911 D/ZenLog ( 1576): set_zen_mode: off,setting
01-03 18:24:15.920 I/SystemServiceManager( 1576): Starting com.android.server.storage.DeviceStorageMonitorService
01-03 18:24:15.927 I/SystemServer( 1576): Location Manager
01-03 18:24:15.934 I/SystemServer( 1576): Country Detector
01-03 18:24:15.936 I/SystemServer( 1576): Search Service
01-03 18:24:15.941 I/SystemServer( 1576): DropBox Service
01-03 18:24:15.947 I/SystemServer( 1576): Wallpaper Service
01-03 18:24:15.955 W/WallpaperManagerService( 1576): no current wallpaper -- first boot?
01-03 18:24:15.955 I/SystemServer( 1576): Audio Service
01-03 18:24:15.994 I/SystemServiceManager( 1576): Starting com.android.server.DockObserver
01-03 18:24:15.996 W/DockObserver( 1576): This kernel does not have dock station support
01-03 18:24:15.997 I/SystemServer( 1576): Wired Accessory Manager
01-03 18:24:16.001 I/SystemServiceManager( 1576): Starting com.android.server.usb.UsbService$Lifecycle
01-03 18:24:16.026 I/SystemServer( 1576): Serial Service
01-03 18:24:16.028 I/SystemServiceManager( 1576): Starting com.android.server.twilight.TwilightService
01-03 18:24:16.036 I/SystemServiceManager( 1576): Starting com.android.server.UiModeManagerService
01-03 18:24:16.043 I/SystemServiceManager( 1576): Starting com.android.server.job.JobSchedulerService
01-03 18:24:16.063 I/SystemServiceManager( 1576): Starting com.android.server.backup.BackupManagerService$Lifecycle
01-03 18:24:16.070 I/SystemServiceManager( 1576): Starting com.android.server.appwidget.AppWidgetService
01-03 18:24:16.080 I/SystemServiceManager( 1576): Starting com.android.server.voiceinteraction.VoiceInteractionManagerService
01-03 18:24:16.090 W/SoundTriggerHelper( 1576): listModules status=0, # of modules=0
01-03 18:24:16.091 I/SystemServer( 1576): DiskStats Service
01-03 18:24:16.092 I/SystemServer( 1576): SamplingProfiler Service
01-03 18:24:16.102 I/SystemServer( 1576): NetworkTimeUpdateService
01-03 18:24:16.105 I/SystemServer( 1576): CommonTimeManagementService
01-03 18:24:16.107 I/auditd ( 1681): Starting up
01-03 18:24:16.107 E/auditd ( 1681): Failed on audit_set_pid with error: Protocol not supported
01-03 18:24:16.107 I/auditd ( 1681): Exiting
01-03 18:24:16.109 I/SystemServer( 1576): CertBlacklister
01-03 18:24:16.111 I/SystemServiceManager( 1576): Starting com.android.server.dreams.DreamManagerService
01-03 18:24:16.121 I/SystemServer( 1576): Assets Atlas Service
01-03 18:24:16.130 I/SystemServiceManager( 1576): Starting com.android.server.print.PrintManagerService
01-03 18:24:16.145 I/SystemServiceManager( 1576): Starting com.android.server.restrictions.RestrictionsManagerService
01-03 18:24:16.154 I/SystemServiceManager( 1576): Starting com.android.server.media.MediaSessionService
01-03 18:24:16.168 I/SystemServiceManager( 1576): Starting com.android.server.hdmi.HdmiControlService
01-03 18:24:16.182 I/HdmiControlService( 1576): Device does not support HDMI-CEC.
01-03 18:24:16.183 I/SystemServer( 1576): Theme Service
01-03 18:24:16.222 I/SystemServer( 1576): KillSwitch Service
01-03 18:24:16.232 I/SystemServer( 1576): Media Router Service
01-03 18:24:16.240 I/SystemServiceManager( 1576): Starting com.android.server.trust.TrustManagerService
01-03 18:24:16.246 I/SystemServiceManager( 1576): Starting com.android.server.fingerprint.FingerprintService
01-03 18:24:16.252 I/SystemServer( 1576): BackgroundDexOptService
01-03 18:24:16.260 I/SystemServiceManager( 1576): Starting com.android.server.pm.LauncherAppsService
01-03 18:24:16.267 D/SystemServer( 1576): Wipower not supported
01-03 18:24:16.267 I/SystemServer( 1576): EdgeGesture service
01-03 18:24:16.275 I/SystemServiceManager( 1576): Starting com.android.server.media.projection.MediaProjectionManagerService
01-03 18:24:16.313 I/SystemServiceManager( 1576): Starting com.android.server.MmsServiceBroker
01-03 18:24:16.317 I/SystemServer( 1576): org.cyanogenmod.platform.internal.CMStatusBarManagerService
01-03 18:24:16.333 I/SystemServiceManager( 1576): Starting org.cyanogenmod.platform.internal.CMStatusBarManagerService
01-03 18:24:16.338 I/SystemServer( 1576): org.cyanogenmod.platform.internal.ProfileManagerService
01-03 18:24:16.356 I/SystemServiceManager( 1576): Starting org.cyanogenmod.platform.internal.ProfileManagerService
01-03 18:24:16.363 D/WifiService( 1576): New client listening to asynchronous messages
01-03 18:24:16.382 I/SystemServer( 1576): org.cyanogenmod.platform.internal.PartnerInterfaceService
01-03 18:24:16.389 I/SystemServiceManager( 1576): Starting org.cyanogenmod.platform.internal.PartnerInterfaceService
01-03 18:24:16.390 I/SystemServer( 1576): org.cyanogenmod.platform.internal.CMTelephonyManagerService
01-03 18:24:16.398 I/SystemServiceManager( 1576): Starting org.cyanogenmod.platform.internal.CMTelephonyManagerService
01-03 18:24:16.399 I/SystemServer( 1576): org.cyanogenmod.platform.internal.CMHardwareService
01-03 18:24:16.404 I/SystemServiceManager( 1576): Starting org.cyanogenmod.platform.internal.CMHardwareService
01-03 18:24:16.413 I/SystemServer( 1576): org.cyanogenmod.platform.internal.AppSuggestManagerService
01-03 18:24:16.419 I/SystemServiceManager( 1576): Starting org.cyanogenmod.platform.internal.AppSuggestManagerService
01-03 18:24:16.425 E/AppSgstMgrService( 1576): no app suggest provider found
01-03 18:24:16.446 E/LockSettingsStorage( 1576): Cannot read file java.io.FileNotFoundException: /data/system/password.key: open failed: ENOENT (No such file or directory)
01-03 18:24:16.449 E/LockSettingsStorage( 1576): Cannot read file java.io.FileNotFoundException: /data/system/gesture.key: open failed: ENOENT (No such file or directory)
01-03 18:24:16.449 I/SystemServiceManager( 1576): Starting phase 480
01-03 18:24:16.470 I/SystemServiceManager( 1576): Starting phase 500
01-03 18:24:16.470 I/WifiService( 1576): WifiService starting up with Wi-Fi enabled
01-03 18:24:16.471 D/WifiService( 1576): setWifiEnabled: true pid=1576, uid=1000
01-03 18:24:16.471 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:24:16.495 D/WifiScanningService( 1576): New client, channel: null messenger: null
01-03 18:24:16.506 D/ConnectivityService( 1576): Got NetworkFactory Messenger for Ethernet
01-03 18:24:16.509 I/ActivityManager( 1576): Config changes=200 {1.0 ?mcc?mnc de_DE ?layoutDir sw768dp w768dp h951dp 320dpi xlrg port finger -keyb/v/h -nav/h s.4 themeResource=null}
01-03 18:24:16.521 V/BackupManagerService( 1576): No ancestral data
01-03 18:24:16.526 D/BackupManagerService( 1576): Now staging backup of com.android.providers.telephony
01-03 18:24:16.530 D/BackupManagerService( 1576): Now staging backup of com.google.android.googlequicksearchbox
01-03 18:24:16.532 D/BackupManagerService( 1576): Now staging backup of com.android.browser
01-03 18:24:16.533 D/BackupManagerService( 1576): Now staging backup of com.android.vending
01-03 18:24:16.534 D/BackupManagerService( 1576): Now staging backup of android
01-03 18:24:16.535 D/BackupManagerService( 1576): Now staging backup of com.google.android.gm
01-03 18:24:16.536 D/BackupManagerService( 1576): Now staging backup of com.android.providers.settings
01-03 18:24:16.537 D/BackupManagerService( 1576): Now staging backup of com.android.sharedstoragebackup
01-03 18:24:16.539 D/BackupManagerService( 1576): Now staging backup of com.cyanogenmod.trebuchet
01-03 18:24:16.540 D/BackupManagerService( 1576): Now staging backup of com.google.android.calendar
01-03 18:24:16.541 D/BackupManagerService( 1576): Now staging backup of com.android.providers.userdictionary
01-03 18:24:16.541 V/BackupManagerService( 1576): Starting with transport com.google.android.gms/.backup.BackupTransportService
01-03 18:24:16.541 V/BackupManagerService( 1576): Found transports: 2
01-03 18:24:16.541 I/BackupManagerService( 1576): Binding to transport host ComponentInfo{android/com.android.internal.backup.LocalTransportService}
01-03 18:24:16.547 I/BackupManagerService( 1576): Binding to transport host ComponentInfo{com.google.android.gms/com.google.android.gms.backup.BackupTransportService}
01-03 18:24:16.550 I/BackupManagerService( 1576): Found stale backup journal, scheduling
01-03 18:24:16.626 D/LiveDisplay( 1576): Adjust display temperature to 6500K [r=1.0 g=1.0 b=1.0]
01-03 18:24:16.667 I/AppOps ( 1576): Pruning old package media/1013: new uid=-1
01-03 18:24:16.667 I/ActivityManager( 1576): System now ready
01-03 18:24:16.672 I/DisplayManagerService( 1576): Display device changed: DisplayDeviceInfo{"Integrierter Bildschirm": uniqueId="local:0", 1536 x 2048, 56.097 fps, supportedRefreshRates [56.097], density 280, 288.99554 x 240.82962 dpi, appVsyncOff 0, presDeadline 18826265, touch INTERNAL, rotation 0, type BUILT_IN, state ON, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
01-03 18:24:16.675 I/SystemServer( 1576): Making services ready
01-03 18:24:16.675 I/SystemServiceManager( 1576): Starting phase 550
01-03 18:24:16.691 D/UsbHostManager( 1576): Added device UsbDevice[mName=/dev/bus/usb/002/002,mVendorId=3725,mProductId=162,mClass=239,mSubclass=2,mProtocol=1,mManufacturerName=MediaTek Inc,mProductName=MT6229 ,mSerialNumber=null,mConfigurations=[
01-03 18:24:16.691 D/UsbHostManager( 1576): UsbConfiguration[mId=1,mName=null,mAttributes=128,mMaxPower=250,mInterfaces=[
01-03 18:24:16.691 D/UsbHostManager( 1576): UsbInterface[mId=0,mAlternateSetting=0,mName=6238 COM(data_if),mClass=10,mSubclass=0,mProtocol=0,mEndpoints=[
01-03 18:24:16.691 D/UsbHostManager( 1576): UsbEndpoint[mAddress=129,mAttributes=2,mMaxPacketSize=512,mInterval=0]
01-03 18:24:16.691 D/UsbHostManager( 1576): UsbEndpoint[mAddress=1,mAttributes=2,mMaxPacketSize=512,mInterval=0]]
01-03 18:24:16.691 D/UsbHostManager( 1576): UsbInterface[mId=1,mAlternateSetting=0,mName=6229 COM(comm_if),mClass=2,mSubclass=2,mProtocol=1,mEndpoints=[
01-03 18:24:16.691 D/UsbHostManager( 1576): UsbEndpoint[mAddress=132,mAttributes=3,mMaxPacketSize=64,mInterval=1]]
01-03 18:24:16.691 D/UsbHostManager( 1576): UsbInterface[mId=2,mAlternateSetting=0,mName=6238 COM(data_if),mClass=10,mSubclass=0,mProtocol=0,mEndpoints=[
01-03 18:24:16.691 D/UsbHostManager( 1576): UsbEndpoint[mAddress=130,mAttributes=2,mMaxPacketSize=512,mInterval=0]
01-03 18:24:16.691 D/UsbHostManager( 1576): UsbEndpoint[mAddress=2,mAttributes=2,mMaxPacketSize=512,mInterval=0]]]]
01-03 18:24:16.742 I/ActivityManager( 1576): Start proc 1706:com.android.systemui/u0a13 for service com.android.systemui/.keyguard.KeyguardService
01-03 18:24:16.743 I/SystemServer( 1576): WebViewFactory preparation
01-03 18:24:16.770 I/ActivityManager( 1576): Start proc 1713:android.process.media/u0a7 for broadcast com.android.providers.media/.MtpReceiver
01-03 18:24:16.806 I/ActivityManager( 1576): Start proc 1719:WebViewLoader-armeabi-v7a/1037 [android.webkit.WebViewFactory$RelroFileCreator] for
01-03 18:24:16.807 W/MountService( 1576): Duplicate state transition (mounted -> mounted) for /storage/emulated/0
01-03 18:24:16.808 D/NetworkManagementService( 1576): enabling bandwidth control
01-03 18:24:17.397 E/NetdConnector( 1576): NDC Command {2 bandwidth enable} took too long (588ms)
01-03 18:24:18.211 I/SystemServiceManager( 1576): Starting phase 600
01-03 18:24:18.256 I/BackupManagerService( 1576): Backup enabled => false
01-03 18:24:18.256 I/BackupManagerService( 1576): Opting out of backup
01-03 18:24:18.354 I/ActivityManager( 1576): Start proc 1907:com.google.android.googlequicksearchbox:interactor/u0a22 for service com.google.android.googlequicksearchbox/com.google.android.voiceinteraction.GsaVoiceInteractionService
01-03 18:24:18.361 E/InputMethodManagerService( 1576): Ignoring setImeWindowStatus due to an invalid token. uid:1000 token:null
01-03 18:24:18.450 I/ActivityManager( 1576): Start proc 1926:com.android.inputmethod.latin/u0a40 for service com.android.inputmethod.latin/.LatinIME
01-03 18:24:18.450 V/InputMethodManagerService( 1576): Adding window token: android.os.Binder@fbed39a
01-03 18:24:18.546 E/LocationManagerService( 1576): FLP HAL not supported
01-03 18:24:18.576 E/LocationManagerService( 1576): Hardware Activity-Recognition not supported.
01-03 18:24:18.674 I/ActivityManager( 1576): Start proc 1966:com.google.process.location/u0a18 for broadcast com.google.android.gms/com.google.android.location.internal.NlpNetworkProviderSettingsUpdateReceiver
01-03 18:24:18.705 I/MmsServiceBroker( 1576): systemRunning
01-03 18:24:18.749 I/ActivityManager( 1576): Start proc 1978:org.cyanogenmod.audiofx/u0a0 for added application org.cyanogenmod.audiofx
01-03 18:24:18.795 I/ActivityManager( 1576): Start proc 1998:com.android.phone/1001 for added application com.android.phone
01-03 18:24:18.796 I/ActivityManager( 1576): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.cyanogenmod.trebuchet/com.android.launcher3.Launcher} from uid 0 on display 0
01-03 18:24:18.807 V/WindowManager( 1576): addAppToken: AppWindowToken{334b167d token=Token{1d1144d4 ActivityRecord{23aa6a27 u0 com.cyanogenmod.trebuchet/com.android.launcher3.Launcher t18}}} to stack=0 task=18 at 0
01-03 18:24:18.904 I/ActivityManager( 1576): Start proc 2016:com.cyanogenmod.trebuchet/u0a15 for activity com.cyanogenmod.trebuchet/com.android.launcher3.Launcher
01-03 18:24:18.976 I/SystemServer( 1576): Enabled StrictMode for system server main thread.
01-03 18:24:19.085 V/ActivityManager( 1576): Display changed displayId=0
01-03 18:24:19.086 V/ActivityManager( 1576): Display changed displayId=0
01-03 18:24:19.174 W/ResourcesManager( 1966): Asset path '/system/framework/com.android.media.remotedisplay.jar' does not exist or contains no resources.
01-03 18:24:19.175 W/ResourcesManager( 1966): Asset path '/system/framework/com.android.location.provider.jar' does not exist or contains no resources.
01-03 18:24:19.242 I/ActivityManager( 1576): Start proc 2065:com.android.printspooler/u0a51 for service com.android.printspooler/.model.PrintSpoolerService
01-03 18:24:19.454 V/ActivityManager( 1576): Display changed displayId=0
01-03 18:24:19.455 V/ActivityManager( 1576): Display changed displayId=0
01-03 18:24:19.566 I/Telecom ( 1576): TelecomGlobals: TelecomGlobals initializing
01-03 18:24:19.619 I/StatusBarManagerService( 1576): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@d1eb158
01-03 18:24:19.759 I/ActivityManager( 1576): Start proc 2096:android.process.acore/u0a5 for content provider com.android.providers.contacts/.CallLogProvider
01-03 18:24:19.805 I/Telecom ( 1576): TelecomGlobals: CallsManager initialized
01-03 18:24:19.806 W/ContextImpl( 1576): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1721 android.content.ContextWrapper.startService:522 com.android.server.telecom.BluetoothPhoneService.start:468 com.android.server.telecom.TelecomGlobals.initialize:104 com.android.server.telecom.TelecomService.onCreate:164
01-03 18:24:19.814 D/ZenLog ( 1576): downtime: Autotrigger skipped: not in downtime
01-03 18:24:19.818 V/WiredAccessoryManager( 1576): notifyWiredAccessoryChanged: when=0 bits= mask=54
01-03 18:24:19.818 V/WiredAccessoryManager( 1576): newName=h2w newState=0 headsetState=0 prev headsetState=0
01-03 18:24:19.818 V/WiredAccessoryManager( 1576): init()
01-03 18:24:20.067 I/ActivityManager( 1576): Start proc 2126:com.google.process.gapps/u0a18 for content provider com.google.android.gsf/.gservices.GservicesProvider
01-03 18:24:21.160 W/ResourcesManager( 1576): Asset path '/system/framework/com.google.android.media.effects.jar' does not exist or contains no resources.
01-03 18:24:21.203 I/auditd ( 2173): Starting up
01-03 18:24:21.206 E/auditd ( 2173): Failed on audit_set_pid with error: Protocol not supported
01-03 18:24:21.206 I/auditd ( 2173): Exiting
01-03 18:24:21.393 I/ActivityManager( 1576): Start proc 2186:com.android.smspush/u0a57 for service com.android.smspush/.WapPushManager
01-03 18:24:21.394 W/WindowManager( 1576): Window freeze timeout expired.
01-03 18:24:21.395 W/WindowManager( 1576): Force clearing orientation change: Window{17f227aa u0 KeyguardScrim}
01-03 18:24:21.599 W/ResourcesManager( 1706): Asset path '/system/framework/com.google.android.camera2.jar' does not exist or contains no resources.
01-03 18:24:21.674 I/ActivityManager( 1576): Start proc 2215:com.cyanogenmod.eleven/u0a34 for broadcast com.cyanogenmod.eleven/.MediaButtonIntentReceiver
01-03 18:24:21.843 E/ConnectivityService( 1576): Failed to find Messenger in unregisterNetworkFactory
01-03 18:24:21.850 D/ConnectivityService( 1576): Got NetworkFactory Messenger for Telephony
01-03 18:24:21.864 V/ActivityManager( 1576): Display changed displayId=0
01-03 18:24:21.864 V/BackupManagerService( 1576): Connected to transport ComponentInfo{android/com.android.internal.backup.LocalTransportService}
01-03 18:24:21.866 V/BackupManagerService( 1576): Registering transport android/com.android.internal.backup.LocalTransportService::android/com.android.internal.backup.LocalTransport = android.app.backup.BackupTransport$TransportImpl@39230350
01-03 18:24:22.020 I/ActivityManager( 1576): Start proc 2246:com.google.android.googlequicksearchbox:search/u0a22 for service com.google.android.googlequicksearchbox/com.google.android.hotword.service.HotwordService
01-03 18:24:22.581 I/ActivityManager( 1576): Start proc 2277:com.cyanogenmod.eleven:main/u0a34 for service com.cyanogenmod.eleven/.MusicPlaybackService
01-03 18:24:22.622 W/ActivityManager( 1576): Unable to start service Intent { cmp=org.codeaurora.ims/.ImsService } U=0: not found
01-03 18:24:22.939 V/BackupManagerService( 1576): Connected to transport ComponentInfo{com.google.android.gms/com.google.android.gms.backup.BackupTransportService}
01-03 18:24:22.966 V/BackupManagerService( 1576): Registering transport com.google.android.gms/.backup.BackupTransportService::com.google.android.gms/.backup.BackupTransportService = com.android.internal.backup.IBackupTransport$Stub$Proxy@3ad02da4
01-03 18:24:23.521 V/WindowManager( 1576): Based on layer: Adding window Window{3ef55d7d u0 com.cyanogenmod.trebuchet/com.android.launcher3.Launcher} at 0 of 1
01-03 18:24:23.940 D/WifiService( 1576): New client listening to asynchronous messages
01-03 18:24:24.303 D/ConnectivityService( 1576): listenForNetwork for NetworkRequest [ id=2, legacyType=-1, [] ]
01-03 18:24:24.708 I/ActivityManager( 1576): Start proc 2333:com.google.android.partnersetup/u0a19 for content provider com.google.android.partnersetup/.RlzAppProvider
01-03 18:24:25.352 I/ActivityManager( 1576): Start proc 2363:com.cyanogenmod.lockclock/u0a43 for content provider com.cyanogenmod.lockclock/.weather.WeatherContentProvider
01-03 18:24:25.654 D/WifiService( 1576): New client listening to asynchronous messages
01-03 18:24:26.104 I/auditd ( 2393): Starting up
01-03 18:24:26.128 E/auditd ( 2393): Failed on audit_set_pid with error: Protocol not supported
01-03 18:24:26.128 I/auditd ( 2393): Exiting
01-03 18:24:26.469 W/KeyphraseEnrollmentInfo( 1907): Enrollment application doesn't support keyphrases
01-03 18:24:26.911 W/ResourcesManager( 2126): Asset path '/system/framework/com.android.media.remotedisplay.jar' does not exist or contains no resources.
01-03 18:24:26.934 W/ResourcesManager( 2126): Asset path '/system/framework/com.android.location.provider.jar' does not exist or contains no resources.
01-03 18:24:26.970 I/ActivityManager( 1576): Start proc 2411:com.android.settings/1000 for broadcast com.android.settings/.widget.SettingsAppWidgetProvider
01-03 18:24:27.934 D/WifiService( 1576): New client listening to asynchronous messages
01-03 18:24:28.062 D/WifiService( 1576): New client listening to asynchronous messages
01-03 18:24:28.579 I/ActivityManager( 1576): Start proc 2491:com.google.android.gms/u0a18 for broadcast com.google.android.gms/com.google.android.libraries.social.autobackup.AutoBackupEnvironment$BatteryReceiver
01-03 18:24:28.736 W/ResourcesManager( 2491): Asset path '/system/framework/com.android.media.remotedisplay.jar' does not exist or contains no resources.
01-03 18:24:28.737 W/ResourcesManager( 2491): Asset path '/system/framework/com.android.location.provider.jar' does not exist or contains no resources.
01-03 18:24:29.315 W/KeyguardServiceDelegate( 1576): onScreenTurnedOn(): no keyguard service!
01-03 18:24:29.439 D/VoldCmdListener( 102): cryptfs getpw
01-03 18:24:29.457 D/VoldCmdListener( 102): cryptfs clearpw
01-03 18:24:30.108 I/ActivityManager( 1576): Start proc 2552:com.google.android.gms.wearable/u0a18 for service com.google.android.gms/.wearable.service.WearableService
01-03 18:24:30.315 W/WindowManager( 1576): Keyguard drawn timeout. Setting mKeyguardDrawComplete
01-03 18:24:30.394 W/ResourcesManager( 2552): Asset path '/system/framework/com.android.media.remotedisplay.jar' does not exist or contains no resources.
01-03 18:24:30.395 W/ResourcesManager( 2552): Asset path '/system/framework/com.android.location.provider.jar' does not exist or contains no resources.
01-03 18:24:31.065 D/WifiService( 1576): New client listening to asynchronous messages
01-03 18:24:31.458 I/auditd ( 2579): Starting up
01-03 18:24:31.463 E/auditd ( 2579): Failed on audit_set_pid with error: Protocol not supported
01-03 18:24:31.464 I/auditd ( 2579): Exiting
01-03 18:24:32.183 W/WindowManager( 1576): Window freeze timeout expired.
01-03 18:24:32.183 W/WindowManager( 1576): Force clearing orientation change: Window{1fabd298 u0 NavigationBar}
01-03 18:24:32.183 W/WindowManager( 1576): Force clearing orientation change: Window{2c3900fd u0 StatusBar}
01-03 18:24:34.228 W/WindowManager( 1576): Window freeze timeout expired.
01-03 18:24:34.229 W/WindowManager( 1576): Force clearing orientation change: Window{150eebc9 u0 com.android.systemui.ImageWallpaper}
01-03 18:24:34.476 D/MccTable( 1998): updateMccMncConfiguration mccmnc='' fromServiceState=false
01-03 18:24:35.025 D/WifiService( 1576): New client listening to asynchronous messages
01-03 18:24:36.099 I/auditd ( 2626): Starting up
01-03 18:24:36.104 E/auditd ( 2626): Failed on audit_set_pid with error: Protocol not supported
01-03 18:24:36.104 I/auditd ( 2626): Exiting
01-03 18:24:36.526 W/ResourcesManager( 2016): Asset path '/system/framework/com.google.android.media.effects.jar' does not exist or contains no resources.
01-03 18:24:37.104 W/ActivityManager( 1576): Unable to start service Intent { act=com.google.android.gms.analytics.service.START cmp=com.google.android.gms/.analytics.service.AnalyticsService (has extras) } U=0: not found
01-03 18:24:41.363 I/auditd ( 2669): Starting up
01-03 18:24:41.364 E/auditd ( 2669): Failed on audit_set_pid with error: Protocol not supported
01-03 18:24:41.364 I/auditd ( 2669): Exiting
01-03 18:24:41.558 I/SystemServiceManager( 1576): Starting phase 1000
01-03 18:24:42.118 I/BootReceiver( 1576): Copying /proc/last_kmsg to DropBox (SYSTEM_LAST_KMSG)
01-03 18:24:42.143 I/ActivityManager( 1576): Start proc 2680:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
01-03 18:24:42.148 I/BootReceiver( 1576): Copying audit failures to DropBox
01-03 18:24:42.155 I/BootReceiver( 1576): Copied 0 worth of audits to DropBox
01-03 18:24:42.157 I/BootReceiver( 1576): Checking for fsck errors
01-03 18:24:42.158 I/BootReceiver( 1576): Copying /data/tombstones/tombstone_00 to DropBox (SYSTEM_TOMBSTONE)
01-03 18:24:42.192 I/ActivityManager( 1576): Start proc 2686:com.android.keychain/1000 for service com.android.keychain/.KeyChainService
01-03 18:24:42.193 W/ActivityManager( 1576): Unable to start service Intent { act=com.google.android.gms.analytics.service.START cmp=com.google.android.gms/.analytics.service.AnalyticsService (has extras) } U=0: not found
01-03 18:24:42.214 I/BootReceiver( 1576): Copying /data/tombstones/tombstone_01 to DropBox (SYSTEM_TOMBSTONE)
01-03 18:24:42.240 I/BootReceiver( 1576): Copying /data/tombstones/tombstone_02 to DropBox (SYSTEM_TOMBSTONE)
01-03 18:24:42.245 I/ActivityManager( 1576): Start proc 2703:com.android.deskclock/u0a32 for broadcast com.android.deskclock/.AlarmInitReceiver
01-03 18:24:42.316 W/ResourcesManager( 2680): Asset path '/system/framework/javax.btobex.jar' does not exist or contains no resources.
01-03 18:24:43.138 I/ActivityManager( 1576): Start proc 2743:eu.chainfire.supersu/u0a59 for broadcast eu.chainfire.supersu/.BootCompleteReceiver
01-03 18:24:43.731 I/ActivityManager( 1576): Start proc 2768:com.cyanogenmod.account/u0a2 for broadcast com.cyanogenmod.account/.receiver.BootReceiver
01-03 18:24:44.168 I/Telecom ( 1576): BluetoothPhoneService: queryPhoneState
01-03 18:24:44.371 I/ActivityManager( 1576): Start proc 2850:com.cyanogenmod.updater/u0a3 for broadcast com.cyanogenmod.updater/.receiver.UpdateCheckReceiver
01-03 18:24:44.509 W/ActivityManager( 1576): Unable to start service Intent { act=com.google.android.gms.analytics.service.START cmp=com.google.android.gms/.analytics.service.AnalyticsService (has extras) } U=0: not found
01-03 18:24:44.667 I/ActivityManager( 1576): Start proc 2899:com.android.providers.calendar/u0a4 for broadcast com.android.providers.calendar/.CalendarReceiver
01-03 18:24:44.731 W/ResourcesManager( 2899): Asset path '/system/framework/android.test.runner.jar' does not exist or contains no resources.
01-03 18:24:44.914 I/ActivityManager( 1576): Start proc 2921:com.android.managedprovisioning/u0a9 for broadcast com.android.managedprovisioning/.BootReminder
01-03 18:24:45.271 I/ActivityManager( 1576): Start proc 2942:com.android.vending/u0a10 for broadcast com.android.vending/com.google.android.finsky.receivers.BootCompletedReceiver
01-03 18:24:46.247 I/auditd ( 2965): Starting up
01-03 18:24:46.248 E/auditd ( 2965): Failed on audit_set_pid with error: Protocol not supported
01-03 18:24:46.249 I/auditd ( 2965): Exiting
01-03 18:24:46.485 I/ActivityManager( 1576): Killing 2096:android.process.acore/u0a5 (adj 15): empty #17
01-03 18:24:49.511 W/ActivityManager( 1576): Unable to start service Intent { act=com.google.android.gms.analytics.service.START cmp=com.google.android.gms/.analytics.service.AnalyticsService (has extras) } U=0: not found
01-03 18:24:51.259 I/auditd ( 2995): Starting up
01-03 18:24:51.260 E/auditd ( 2995): Failed on audit_set_pid with error: Protocol not supported
01-03 18:24:51.260 I/auditd ( 2995): Exiting
01-03 18:24:52.229 I/ActivityManager( 1576): Start proc 2998:com.google.android.gms:car/u0a18 for service com.google.android.gms/.car.CarService
01-03 18:24:52.372 W/ResourcesManager( 2998): Asset path '/system/framework/com.android.media.remotedisplay.jar' does not exist or contains no resources.
01-03 18:24:52.373 W/ResourcesManager( 2998): Asset path '/system/framework/com.android.location.provider.jar' does not exist or contains no resources.
01-03 18:24:52.555 I/ActivityManager( 1576): Killing 2065:com.android.printspooler/u0a51 (adj 15): empty #17
01-03 18:24:52.580 W/InputMethodManagerService( 1576): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@ca40d35 attribute=null, token = android.os.BinderProxy@156c47d4
01-03 18:24:52.768 I/ActivityManager( 1576): Start proc 3030:com.google.android.onetimeinitializer/u0a20 for broadcast com.google.android.onetimeinitializer/.OneTimeInitializerReceiver
01-03 18:24:54.549 I/ActivityManager( 1576): Killing 2215:com.cyanogenmod.eleven/u0a34 (adj 15): empty #17
01-03 18:24:54.740 I/ActivityManager( 1576): Delay finish: com.google.android.googlequicksearchbox/.GelStubAppWatcher
01-03 18:24:54.957 D/PackageManager( 1576): Ignoring attempt to set enabled state of disabled component com.google.android.gms/com.google.android.gms.update.SystemUpdateService$ActiveReceiver
01-03 18:24:55.481 D/ConnectivityService( 1576): Got NetworkFactory Messenger for WIFI
01-03 18:24:55.481 D/ConnectivityService( 1576): Got NetworkFactory Messenger for WIFI_UT
01-03 18:24:56.269 I/auditd ( 3101): Starting up
01-03 18:24:56.270 E/auditd ( 3101): Failed on audit_set_pid with error: Protocol not supported
01-03 18:24:56.270 I/auditd ( 3101): Exiting
01-03 18:24:56.392 I/ActivityManager( 1576): Resuming delayed broadcast
01-03 18:24:56.445 I/ActivityManager( 1576): Start proc 3104:com.android.email/u0a35 for broadcast com.android.email/.service.EmailBroadcastReceiver
01-03 18:24:56.555 W/ContextImpl( 2411): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1721 android.content.ContextWrapper.startService:522 android.content.ContextWrapper.startService:522 com.android.settings.bluetooth.DockEventReceiver.beginStartingService:134 com.android.settings.bluetooth.DockEventReceiver.onReceive:115
01-03 18:24:57.343 I/ActivityManager( 1576): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.settings/.Settings (has extras)} from uid 10015 on display 0
01-03 18:24:57.360 V/WindowManager( 1576): addAppToken: AppWindowToken{33550cc0 token=Token{679ee43 ActivityRecord{30b527f2 u0 com.android.settings/.Settings t19}}} to stack=1 task=19 at 0
01-03 18:24:57.415 W/ActivityManager( 1576): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
01-03 18:24:57.439 V/WindowManager( 1576): Adding window Window{e35316d u0 Starting com.android.settings} at 2 of 7 (after Window{3ef55d7d u0 com.cyanogenmod.trebuchet/com.android.launcher3.Launcher})
01-03 18:24:58.739 D/ActivityThread( 3104): Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
01-03 18:24:58.824 W/ActivityManager( 1576): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
01-03 18:24:58.842 D/ActivityThread( 3104): Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
01-03 18:24:58.843 W/ActivityManager( 1576): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
01-03 18:24:58.847 D/ActivityThread( 3104): Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
01-03 18:24:58.848 D/ActivityThread( 3104): Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
01-03 18:24:58.849 W/ActivityManager( 1576): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
01-03 18:24:58.929 V/WindowManager( 1576): Adding window Window{1e690cd9 u0 com.android.settings/com.android.settings.Settings} at 2 of 8 (before Window{e35316d u0 Starting com.android.settings})
01-03 18:24:59.270 I/ActivityManager( 1576): Start proc 3144:com.android.gallery3d/u0a37 for broadcast com.android.gallery3d/org.codeaurora.gallery3d.video.DmReceiver
01-03 18:24:59.374 W/ActivityManager( 1576): Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
01-03 18:24:59.375 W/ActivityManager( 1576): Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
01-03 18:24:59.380 W/ActivityManager( 1576): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
01-03 18:24:59.381 W/ActivityManager( 1576): Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
01-03 18:24:59.419 W/ActivityManager( 1576): Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
01-03 18:24:59.423 W/ActivityManager( 1576): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
01-03 18:24:59.424 W/ActivityManager( 1576): Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
01-03 18:24:59.433 W/ActivityManager( 1576): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
01-03 18:24:59.433 W/ResourcesManager( 3144): Asset path '/system/framework/com.google.android.media.effects.jar' does not exist or contains no resources.
01-03 18:24:59.436 W/ActivityManager( 1576): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
01-03 18:24:59.454 W/ActivityManager( 1576): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
01-03 18:24:59.464 W/ActivityManager( 1576): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
01-03 18:24:59.474 E/ActivityThread( 3104): Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@13e91cf4 that was originally bound here
01-03 18:24:59.474 E/ActivityThread( 3104): android.app.ServiceConnectionLeaked: Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@13e91cf4 that was originally bound here
01-03 18:24:59.474 E/ActivityThread( 3104): at android.app.LoadedApk$ServiceDispatcher.(LoadedApk.java:1078)
01-03 18:24:59.474 E/ActivityThread( 3104): at android.app.LoadedApk.getServiceDispatcher(LoadedApk.java:972)
01-03 18:24:59.474 E/ActivityThread( 3104): at android.app.ContextImpl.bindServiceCommon(ContextImpl.java:1803)
01-03 18:24:59.474 E/ActivityThread( 3104): at android.app.ContextImpl.bindService(ContextImpl.java:1786)
01-03 18:24:59.474 E/ActivityThread( 3104): at android.content.ContextWrapper.bindService(ContextWrapper.java:545)
01-03 18:24:59.474 E/ActivityThread( 3104): at com.android.emailcommon.service.ServiceProxy.setTask(ServiceProxy.java:189)
01-03 18:24:59.474 E/ActivityThread( 3104): at com.android.emailcommon.service.ServiceProxy.test(ServiceProxy.java:234)
01-03 18:24:59.474 E/ActivityThread( 3104): at com.android.email.service.EmailServiceUtils.isServiceAvailable(EmailServiceUtils.java:160)
01-03 18:24:59.474 E/ActivityThread( 3104): at com.android.email.provider.AccountReconciler.reconcileAccountsInternal(AccountReconciler.java:171)
01-03 18:24:59.474 E/ActivityThread( 3104): at com.android.email.provider.AccountReconciler.reconcileAccounts(AccountReconciler.java:115)
01-03 18:24:59.474 E/ActivityThread( 3104): at com.android.email.service.EmailBroadcastProcessorService.reconcileAndStartServices(EmailBroadcastProcessorService.java:309)
01-03 18:24:59.474 E/ActivityThread( 3104): at com.android.email.service.EmailBroadcastProcessorService.onBootCompleted(EmailBroadcastProcessorService.java:295)
01-03 18:24:59.474 E/ActivityThread( 3104): at com.android.email.service.EmailBroadcastProcessorService.onHandleIntent(EmailBroadcastProcessorService.java:130)
01-03 18:24:59.474 E/ActivityThread( 3104): at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:65)
01-03 18:24:59.474 E/ActivityThread( 3104): at android.os.Handler.dispatchMessage(Handler.java:102)
01-03 18:24:59.474 E/ActivityThread( 3104): at android.os.Looper.loop(Looper.java:135)
01-03 18:24:59.474 E/ActivityThread( 3104): at android.os.HandlerThread.run(HandlerThread.java:61)
01-03 18:24:59.476 W/ActivityManager( 1576): Unbind failed: could not find connection for android.os.BinderProxy@37b0ed7c
01-03 18:24:59.515 W/ActivityManager( 1576): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
01-03 18:24:59.578 I/ActivityManager( 1576): Process com.google.android.gms:car (pid 2998) has died
01-03 18:25:00.201 I/ActivityManager( 1576): Start proc 3178:com.google.android.calendar/u0a60 for broadcast com.google.android.calendar/com.android.calendar.alerts.AlertReceiver
01-03 18:25:00.263 I/ActivityManager( 1576): Start proc 3195:android.process.acore/u0a5 for content provider com.android.providers.contacts/.ContactsProvider2
01-03 18:25:00.338 I/Telecom ( 1576): BluetoothPhoneService: queryPhoneState
--------- beginning of main
01-03 18:25:00.375 I/bluedroid( 2680): get_profile_interface hidhost
01-03 18:25:00.376 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@f329853
01-03 18:25:00.378 D/HealthService( 2680): Received start request. Starting profile...
01-03 18:25:00.384 I/Timeline( 2411): Timeline: Activity_idle id: android.os.BinderProxy@3e740448 time:156376
01-03 18:25:00.384 I/bluedroid( 2680): get_profile_interface health
01-03 18:25:00.386 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@f329853
01-03 18:25:00.387 D/HeadsetStateMachine( 2680): Disconnected process message: 10, size: 0
01-03 18:25:00.387 D/HeadsetPhoneState( 2680): sendDeviceStateChanged. mService=0 mSignal=0 mRoam=0 mBatteryCharge=3
01-03 18:25:00.387 D/HeadsetStateMachine( 2680): Disconnected process message: 11, size: 0
01-03 18:25:00.389 D/PanService( 2680): Received start request. Starting profile...
01-03 18:25:00.389 D/BluetoothPanServiceJni( 2680): initializeNative(L110): pan
01-03 18:25:00.389 I/bluedroid( 2680): get_profile_interface pan
01-03 18:25:00.390 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@f329853
01-03 18:25:00.390 D/BtGatt.DebugUtils( 2680): handleDebugAction() action=null
01-03 18:25:00.392 D/BtGatt.GattService( 2680): Received start request. Starting profile...
01-03 18:25:00.392 D/BtGatt.GattService( 2680): start()
01-03 18:25:00.392 I/bluedroid( 2680): get_profile_interface gatt
01-03 18:25:00.392 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@f329853
01-03 18:25:00.392 D/BtGatt.AdvertiseManager( 2680): advertise manager created
01-03 18:25:00.421 D/BluetoothMapService( 2680): inside BluetoothMapObexConnection
01-03 18:25:00.421 D/BluetoothMapService( 2680): supportedMessageTypes 14
01-03 18:25:00.421 D/BluetoothMapService( 2680): masId 0
01-03 18:25:00.421 D/BluetoothMapService( 2680): masId 1
01-03 18:25:00.421 D/BluetoothMapService( 2680): Inside initBinder
01-03 18:25:00.421 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@f329853
01-03 18:25:00.422 D/BluetoothMapService( 2680): Received start request. Starting profile...
01-03 18:25:00.422 D/BluetoothMapService( 2680): start()
01-03 18:25:00.423 D/BluetoothMapService( 2680): Registering observer
01-03 18:25:00.427 V/BluetoothMapService( 2680): Handler(): got msg=1
01-03 18:25:00.428 D/BluetoothAdapterState( 2680): CURRENT_STATE=PENDING, MESSAGE = STARTED, isTurningOn=true, isTurningOff=false
01-03 18:25:00.428 I/bluedroid( 2680): enable
01-03 18:25:00.428 I/bt_hci_bdroid( 2680): init
01-03 18:25:00.429 I/bt_vendor( 2680): init
01-03 18:25:00.429 D/bt_userial( 2680): userial_init
01-03 18:25:00.429 I/GKI_LINUX( 2680): gki_task_entry task_id=0 [BTU] starting
01-03 18:25:00.429 I/bt-btu ( 2680): btu_task pending for preload complete event
01-03 18:25:00.430 I/bt_vendor( 2680): userial vendor open: opening /dev/rtk_btusb
01-03 18:25:00.430 E/bt_vendor( 2680): userial vendor open: unable to open /dev/rtk_btusb: Permission denied
01-03 18:25:00.430 E/bt_userial( 2680): userial_open opened wrong number of ports: got 0, expected 1.
01-03 18:25:00.431 I/bt-btu ( 2680): btu_task received preload complete event
01-03 18:25:00.431 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x0001
01-03 18:25:00.431 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x001f
01-03 18:25:00.433 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x0003
01-03 18:25:00.433 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x1487
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_HCI
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_L2CAP
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_RFCOMM
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_AVDT
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_AVRC
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_A2D
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_BNEP
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTM
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_HID_HOST
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_GAP
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_PAN
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_SDP
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_GATT
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_SMP
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_HID_DEV
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTAPP
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTIF
01-03 18:25:00.438 I/ ( 2680): BTE_InitTraceLevels -- TRC_LATENCY_AUDIO
01-03 18:25:00.440 E/bt_userial( 2680): userial_write error writing to serial port: Bad file number
01-03 18:25:00.444 D/AuthorizationBluetoothService( 2126): Received Bluetooth event: Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x14000010 cmp=com.google.android.gms/.auth.be.proximity.authorization.bt.AuthorizationBluetoothService$BluetoothStateChangeReceiver (has extras) }.
01-03 18:25:00.451 E/BTEventHandler( 2680): A4WP is not supported
01-03 18:25:00.488 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:25:00.488 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:25:00.556 I/ContactLocale( 3195): AddressBook Labels [de-DE]: [, A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, X, Y, Z, Α, Β, Γ, Δ, Ε, Ζ, Η, Θ, Ι, Κ, Λ, Μ, Ν, Ξ, Ο, Π, Ρ, Σ, Τ, Υ, Φ, Χ, Ψ, Ω, , А, Б, В, Г, Д, Ђ, Е, Є, Ж, З, И, І, Ї, Й, Ј, К, Л, Љ, М, Н, Њ, О, П, Р, С, Т, Ћ, У, Ф, Х, Ц, Ч, Џ, Ш, Щ, Ю, Я, , א, ב, ג, ד, ה, ו, ז, ח, ט, י, כ, ל, מ, נ, ס, ע, פ, צ, ק, ר, ש, ת, , ا, ب, ت, ث, ج, ح, خ, د, ذ, ر, ز, س, ش, ص, ض, ط, ظ, ع, غ, ف, ق, ك, ل, م, ن, ه, و, ي, , ก, ข, ฃ, ค, ฅ, ฆ, ง, จ, ฉ, ช, ซ, ฌ, ญ, ฎ, ฏ, ฐ, ฑ, ฒ, ณ, ด, ต, ถ, ท, ธ, น, บ, ป, ผ, ฝ, พ, ฟ, ภ, ม, ย, ร, ฤ, ล, ฦ, ว, ศ, ษ, ส, ห, ฬ, อ, ฮ, , ㄱ, ㄴ, ㄷ, ㄹ, ㅁ, ㅂ, ㅅ, ㅇ, ㅈ, ㅊ, ㅋ, ㅌ, ㅍ, ㅎ, , あ, か, さ, た, な, は, ま, や, ら, わ, #, ]
01-03 18:25:00.882 D/TaskPersister( 1576): removeObsoleteFile: deleting file=15_task.xml
01-03 18:25:00.882 D/TaskPersister( 1576): removeObsoleteFile: deleting file=15_task_thumbnail.png
01-03 18:25:00.948 E/SQLiteLog( 3178): (283) recovered 17 frames from WAL file /data/data/com.google.android.calendar/databases/timelydata.db-wal
01-03 18:25:01.310 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:25:01.312 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:25:01.316 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:25:01.367 I/Timeline( 2411): Timeline: Activity_launch_request id:com.android.settings time:157359
01-03 18:25:01.368 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:25:01.368 I/ActivityManager( 1576): START u0 {act=android.intent.action.MAIN cmp=com.android.settings/.SubSettings (has extras)} from uid 1000 on display 0
01-03 18:25:01.372 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:25:01.374 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:25:01.374 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:25:01.374 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:25:01.374 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:25:01.374 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:25:01.378 V/WindowManager( 1576): addAppToken: AppWindowToken{24a2156a token=Token{3fac6755 ActivityRecord{10c4720c u0 com.android.settings/.SubSettings t19}}} to stack=1 task=19 at 1
01-03 18:25:01.379 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:25:01.453 W/art ( 3178): Suspending all threads took: 19.462ms
01-03 18:25:01.514 I/auditd ( 3237): Starting up
01-03 18:25:01.517 E/auditd ( 3237): Failed on audit_set_pid with error: Protocol not supported
01-03 18:25:01.517 I/auditd ( 3237): Exiting
01-03 18:25:01.607 D/SubSettings( 2411): Launching fragment com.android.settings.wifi.WifiSettings
01-03 18:25:01.675 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:25:01.677 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:25:01.677 E/SoftapController( 1322): Softap fwReload failed
01-03 18:25:01.679 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '34 softap fwreload wlan0 STA' failed with '400 34 SoftAP command has failed'
01-03 18:25:01.683 D/CommandListener( 1322): Setting iface cfg
01-03 18:25:01.683 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:25:01.685 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:25:01.693 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:25:01.715 E/TimelyPrefService( 3178): Primary account is null
01-03 18:25:01.726 V/WindowManager( 1576): Adding window Window{30f72627 u0 com.android.settings/com.android.settings.SubSettings} at 3 of 8 (after Window{1e690cd9 u0 com.android.settings/com.android.settings.Settings})
01-03 18:25:01.744 I/wpa_supplicant( 3240): Successfully initialized wpa_supplicant
01-03 18:25:01.746 I/wpa_supplicant( 3240): rfkill: Cannot open RFKILL control device
01-03 18:25:01.785 I/InputDispatcher( 1576): Dropping event because there is no touchable window at (667, 345).
01-03 18:25:01.797 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:25:01.890 I/ActivityManager( 1576): Start proc 3243:com.google.android.gm/u0a62 for broadcast com.google.android.gm/.GoogleMailDeviceStartupReceiver
01-03 18:25:02.033 I/AnalyticsLogBase( 3178): PlayLogger.onLoggerConnected
01-03 18:25:02.301 I/Choreographer( 2411): Skipped 31 frames! The application may be doing too much work on its main thread.
01-03 18:25:02.499 I/ActivityManager( 1576): Displayed com.android.settings/.SubSettings: +1s94ms
01-03 18:25:02.875 I/Timeline( 2411): Timeline: Activity_idle id: android.os.BinderProxy@3a59c794 time:158867
01-03 18:25:02.893 I/Timeline( 1576): Timeline: Activity_windows_visible id: ActivityRecord{10c4720c u0 com.android.settings/.SubSettings t19} time:158885
01-03 18:25:03.126 I/Gmail ( 3243): getAccountsCursor
01-03 18:25:03.126 D/ActivityThread( 3243): Loading provider com.google.android.gmail.provider;com.android.mail.notifier;com.google.android.gm.email.provider;com.google.android.gm.email.notifier: com.android.email.provider.EmailProvider
01-03 18:25:03.217 V/GLSActivity( 2126): AuthDelegateWrapperCreated with selected intent: Intent { cmp=com.google.android.gms/.auth.DefaultAuthDelegateService }
01-03 18:25:03.450 I/ActivityManager( 1576): Start proc 3270:com.google.android.gm.exchange/u0a61 for service com.google.android.gm.exchange/com.android.exchange.service.EasService
01-03 18:25:03.493 D/ActivityThread( 3243): Loading provider com.google.android.gmail.provider;com.android.mail.notifier;com.google.android.gm.email.provider;com.google.android.gm.email.notifier: com.android.email.provider.EmailProvider
01-03 18:25:03.494 D/ActivityThread( 3243): Loading provider com.google.android.gmail.provider;com.android.mail.notifier;com.google.android.gm.email.provider;com.google.android.gm.email.notifier: com.android.email.provider.EmailProvider
01-03 18:25:03.840 W/art ( 3243): Long monitor contention event with owner method=java.lang.String java.io.File.fixSlashes(java.lang.String) from File.java:197 waiters=1 for 339ms
01-03 18:25:03.872 W/ActivityManager( 1576): Unable to start service Intent { cmp=com.google.android.gm/com.android.email.service.AttachmentService } U=0: not found
01-03 18:25:03.873 W/ActivityManager( 1576): Unable to start service Intent { cmp=com.google.android.gm/com.android.email.service.AttachmentService } U=0: not found
01-03 18:25:03.878 W/ActivityManager( 1576): Unable to start service Intent { cmp=com.google.android.gm/com.android.email.service.AttachmentService } U=0: not found
01-03 18:25:03.969 W/art ( 3243): Long monitor contention event with owner method=boolean android.os.BinderProxy.transactNative(int, android.os.Parcel, android.os.Parcel, int) from Binder.java:4294967294 waiters=0 for 474ms
01-03 18:25:03.976 W/ActivityManager( 1576): Unable to start service Intent { cmp=com.google.android.gm/com.android.email.service.AttachmentService } U=0: not found
01-03 18:25:04.023 I/Gmail ( 3243): Observing account changes for notifications
01-03 18:25:04.164 W/art ( 3243): Long monitor contention event with owner method=void com.android.email.provider.b.F(android.content.Context) from SourceFile:113 waiters=1 for 193ms
01-03 18:25:04.174 I/Exchange( 3270): EasService.onCreate
01-03 18:25:04.203 W/GAV2 ( 3243): Thread[main,5,main]: Need to call initialize() and be in fallback mode to start dispatch.
01-03 18:25:04.214 I/Exchange( 3270): RestartPingTask
01-03 18:25:04.232 I/Exchange( 3270): RestartPingsTask did not start any pings.
01-03 18:25:04.232 I/Exchange( 3270): PSS stopIfIdle
01-03 18:25:04.232 I/Exchange( 3270): PSS has no active accounts; stopping service.
01-03 18:25:04.238 I/Icing ( 2491): Storage manager: low false usage 1,25MB avail 11,20GB capacity 11,61GB
01-03 18:25:04.271 I/ActivityManager( 1576): Delay finish: com.google.android.gm/.GoogleMailDeviceStartupReceiver
01-03 18:25:04.371 I/Gmail ( 3243): getAccountsCursor
01-03 18:25:04.372 I/Exchange( 3270): onDestroy
01-03 18:25:04.378 V/GLSActivity( 2126): AuthDelegateWrapperCreated with selected intent: Intent { cmp=com.google.android.gms/.auth.DefaultAuthDelegateService }
01-03 18:25:04.379 I/ActivityManager( 1576): Resuming delayed broadcast
01-03 18:25:04.386 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:25:04.386 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:25:04.386 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:25:04.386 D/alsa_pcm( 1321): pcm_close()
01-03 18:25:04.390 E/Gmail ( 3243): Error finding the version of the Email provider.....
01-03 18:25:04.390 E/Gmail ( 3243): android.content.pm.PackageManager$NameNotFoundException: com.google.android.email
01-03 18:25:04.390 E/Gmail ( 3243): at android.app.ApplicationPackageManager.getPackageInfo(ApplicationPackageManager.java:115)
01-03 18:25:04.390 E/Gmail ( 3243): at com.google.android.gm.EmailMigrationService.aU(SourceFile:1236)
01-03 18:25:04.390 E/Gmail ( 3243): at com.google.android.gm.EmailMigrationService.onHandleIntent(SourceFile:188)
01-03 18:25:04.390 E/Gmail ( 3243): at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:65)
01-03 18:25:04.390 E/Gmail ( 3243): at android.os.Handler.dispatchMessage(Handler.java:102)
01-03 18:25:04.390 E/Gmail ( 3243): at android.os.Looper.loop(Looper.java:135)
01-03 18:25:04.390 E/Gmail ( 3243): at android.os.HandlerThread.run(HandlerThread.java:61)
01-03 18:25:04.390 W/EmailMigration( 3243): We do not support migrating this version of the Email provider.
01-03 18:25:04.419 I/ActivityManager( 1576): Delay finish: com.google.android.gm/com.android.email.service.EmailBroadcastReceiver
01-03 18:25:04.425 V/GLSActivity( 2126): AuthDelegateWrapperCreated with selected intent: Intent { cmp=com.google.android.gms/.auth.DefaultAuthDelegateService }
01-03 18:25:04.434 V/GLSActivity( 2126): AuthDelegateWrapperCreated with selected intent: Intent { cmp=com.google.android.gms/.auth.DefaultAuthDelegateService }
01-03 18:25:04.443 I/Gmail ( 3243): getAccountsCursor
01-03 18:25:04.444 I/ActivityManager( 1576): Resuming delayed broadcast
01-03 18:25:04.454 V/GLSActivity( 2126): AuthDelegateWrapperCreated with selected intent: Intent { cmp=com.google.android.gms/.auth.DefaultAuthDelegateService }
01-03 18:25:04.459 I/Icing ( 2491): updateResources: need to parse e{com.google.android.gms}
01-03 18:25:04.462 W/ResourcesManager( 2491): Asset path '/system/framework/com.android.media.remotedisplay.jar' does not exist or contains no resources.
01-03 18:25:04.462 W/ResourcesManager( 2491): Asset path '/system/framework/com.android.location.provider.jar' does not exist or contains no resources.
01-03 18:25:04.474 I/Exchange( 3270): EasService.onCreate
01-03 18:25:04.478 I/ActivityManager( 1576): Delay finish: com.cyanogenmod.lockclock/.ClockWidgetProvider
01-03 18:25:04.482 I/ActivityManager( 1576): Resuming delayed broadcast
01-03 18:25:04.487 I/Exchange( 3270): RestartPingTask
01-03 18:25:04.487 E/ActivityThread( 3243): Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.J@6265590 that was originally bound here
01-03 18:25:04.487 E/ActivityThread( 3243): android.app.ServiceConnectionLeaked: Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.J@6265590 that was originally bound here
01-03 18:25:04.487 E/ActivityThread( 3243): at android.app.LoadedApk$ServiceDispatcher.(LoadedApk.java:1078)
01-03 18:25:04.487 E/ActivityThread( 3243): at android.app.LoadedApk.getServiceDispatcher(LoadedApk.java:972)
01-03 18:25:04.487 E/ActivityThread( 3243): at android.app.ContextImpl.bindServiceCommon(ContextImpl.java:1803)
01-03 18:25:04.487 E/ActivityThread( 3243): at android.app.ContextImpl.bindService(ContextImpl.java:1786)
01-03 18:25:04.487 E/ActivityThread( 3243): at android.content.ContextWrapper.bindService(ContextWrapper.java:545)
01-03 18:25:04.487 E/ActivityThread( 3243): at com.android.emailcommon.service.H.a(SourceFile:181)
01-03 18:25:04.487 E/ActivityThread( 3243): at com.android.emailcommon.service.H.mb(SourceFile:224)
01-03 18:25:04.487 E/ActivityThread( 3243): at com.android.email.service.n.j(SourceFile:160)
01-03 18:25:04.487 E/ActivityThread( 3243): at com.android.email.provider.b.a(SourceFile:171)
01-03 18:25:04.487 E/ActivityThread( 3243): at com.android.email.provider.b.F(SourceFile:115)
01-03 18:25:04.487 E/ActivityThread( 3243): at com.android.email.service.EmailBroadcastProcessorService.kD(SourceFile:305)
01-03 18:25:04.487 E/ActivityThread( 3243): at com.android.email.service.EmailBroadcastProcessorService.onHandleIntent(SourceFile:130)
01-03 18:25:04.487 E/ActivityThread( 3243): at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:65)
01-03 18:25:04.487 E/ActivityThread( 3243): at android.os.Handler.dispatchMessage(Handler.java:102)
01-03 18:25:04.487 E/ActivityThread( 3243): at android.os.Looper.loop(Looper.java:135)
01-03 18:25:04.487 E/ActivityThread( 3243): at android.os.HandlerThread.run(HandlerThread.java:61)
01-03 18:25:04.502 I/ActivityManager( 1576): Delay finish: com.google.android.calendar/com.android.calendar.alerts.AlertReceiver
01-03 18:25:04.509 I/ActivityManager( 1576): Resuming delayed broadcast
01-03 18:25:04.519 I/Exchange( 3270): RestartPingsTask did not start any pings.
01-03 18:25:04.519 I/Exchange( 3270): PSS stopIfIdle
01-03 18:25:04.519 I/Exchange( 3270): PSS has no active accounts; stopping service.
01-03 18:25:04.521 I/Exchange( 3270): onDestroy
01-03 18:25:04.523 I/ActivityManager( 1576): Killing 2703:com.android.deskclock/u0a32 (adj 15): empty #17
01-03 18:25:04.591 I/Icing ( 2491): Internal init done: storage state 0
01-03 18:25:04.614 I/Icing ( 2491): Post-init done
01-03 18:25:04.616 I/ActivityManager( 1576): Delay finish: com.android.providers.calendar/.CalendarProviderBroadcastReceiver
01-03 18:25:04.642 E/SQLiteLog( 2899): (284) automatic index on view_events(_id)
01-03 18:25:04.656 I/ActivityManager( 1576): Resuming delayed broadcast
01-03 18:25:04.662 D/GCM ( 2126): GcmService start Intent { act=com.google.android.gms.INITIALIZE flg=0x10 pkg=com.google.android.gms cmp=com.google.android.gms/.gcm.GcmService } com.google.android.gms.INITIALIZE
01-03 18:25:04.666 D/AuthorizationBluetoothService( 2126): Received GmsCore event: Intent { act=com.google.android.gms.INITIALIZE flg=0x10 pkg=com.google.android.gms cmp=com.google.android.gms/.auth.be.proximity.authorization.bt.AuthorizationBluetoothService$AutoStarter }.
01-03 18:25:04.666 E/AuthorizationBluetoothService( 2126): Proximity feature is not enabled.
01-03 18:25:04.669 V/GmsCoreStatsServiceLauncher( 2491): Received broadcast intent Intent { act=com.google.android.gms.INITIALIZE flg=0x10 pkg=com.google.android.gms cmp=com.google.android.gms/.common.stats.GmsCoreStatsServiceLauncher }
01-03 18:25:04.679 I/ActivityManager( 1576): Delay finish: com.google.android.gms/.init.InitializeGmsReceiver
01-03 18:25:04.686 D/LocationInitializer( 2491): Restart initialization of location
01-03 18:25:04.687 I/ActivityManager( 1576): Resuming delayed broadcast
01-03 18:25:04.696 E/MDM ( 1966): [52] b.run: Couldn't connect to Google API client: ConnectionResult{statusCode=API_UNAVAILABLE, resolution=null}
01-03 18:25:04.737 I/ActivityManager( 1576): Delay finish: com.google.android.gms/.lockbox.LockboxAlarmReceiver
01-03 18:25:04.751 D/WeatherUpdateService( 2363): Service started, but shouldn't update ... stopping
01-03 18:25:04.753 D/PackageManager( 1576): Ignoring attempt to set enabled state of disabled component com.google.android.gsf/com.google.android.gsf.update.SystemUpdateActivity
01-03 18:25:04.754 D/PackageManager( 1576): Ignoring attempt to set enabled state of disabled component com.google.android.gsf/com.google.android.gsf.update.SystemUpdateService$SecretCodeReceiver
01-03 18:25:04.755 D/PackageManager( 1576): Ignoring attempt to set enabled state of disabled component com.google.android.gsf/com.google.android.gsf.update.SystemUpdateService$Receiver
01-03 18:25:04.772 I/ActivityManager( 1576): Resuming delayed broadcast
01-03 18:25:04.775 I/ActivityManager( 1576): Delay finish: com.google.android.gms/.common.download.DownloadAlarmReceiver
01-03 18:25:04.800 I/ActivityManager( 1576): Resuming delayed broadcast
01-03 18:25:04.836 D/GCM ( 2126): GcmService start Intent { act=com.google.android.checkin.CHECKIN_COMPLETE flg=0x10 cmp=com.google.android.gms/.gcm.GcmService (has extras) } com.google.android.checkin.CHECKIN_COMPLETE
01-03 18:25:04.869 W/BroadcastQueue( 1576): Permission Denial: broadcasting Intent { act=com.android.launcher3.action.LAUNCH flg=0x10 (has extras) } from com.cyanogenmod.trebuchet (pid=2016, uid=10015) requires com.google.android.launcher.permission.RECEIVE_LAUNCH_BROADCASTS due to receiver com.google.android.googlequicksearchbox/com.google.android.search.core.icingsync.ApplicationLaunchReceiver
01-03 18:25:04.869 W/BroadcastQueue( 1576): Permission Denial: receiving Intent { act=com.android.launcher3.action.LAUNCH flg=0x10 (has extras) } to com.google.android.googlequicksearchbox/com.google.android.search.core.icingsync.ApplicationLaunchReceiver requires com.android.launcher3.permission.RECEIVE_LAUNCH_BROADCASTS due to sender com.cyanogenmod.trebuchet (uid 10015)
01-03 18:25:04.906 I/ActivityManager( 1576): Delay finish: com.google.android.gm/.widget.GmailWidgetProvider
01-03 18:25:04.912 I/ActivityManager( 1576): Resuming delayed broadcast
01-03 18:25:04.920 I/ActivityManager( 1576): Delay finish: com.google.android.gm/.MailIntentReceiver
01-03 18:25:04.924 I/ActivityManager( 1576): Resuming delayed broadcast
01-03 18:25:05.544 E/wpa_supplicant( 3240): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:25:05.544 E/wpa_supplicant( 3240): nl80211: Could not set interface 'wlan0' UP
01-03 18:25:05.544 E/wpa_supplicant( 3240): wlan0: Failed to initialize driver interface
01-03 18:25:06.302 W/ActivityManager( 1576): Unable to start service Intent { act=com.google.android.gms.analytics.service.START cmp=com.google.android.gms/.analytics.service.AnalyticsService (has extras) } U=0: not found
01-03 18:25:06.303 W/GAV2 ( 3178): Thread[GAThread,5,main]: Service unavailable (code=1), will retry.
01-03 18:25:06.325 I/GAV2 ( 3178): Thread[GAThread,5,main]: No campaign data found.
01-03 18:25:06.562 I/auditd ( 3335): Starting up
01-03 18:25:06.563 E/auditd ( 3335): Failed on audit_set_pid with error: Protocol not supported
01-03 18:25:06.563 I/auditd ( 3335): Exiting
01-03 18:25:09.168 W/ActivityManager( 1576): Unable to start service Intent { act=com.google.android.gms.analytics.service.START cmp=com.google.android.gms/.analytics.service.AnalyticsService (has extras) } U=0: not found
01-03 18:25:09.169 W/GAV2 ( 3243): Thread[GAThread,5,main]: Service unavailable (code=1), will retry.
01-03 18:25:09.173 I/GAV2 ( 3243): Thread[GAThread,5,main]: No campaign data found.
01-03 18:25:09.688 I/ActivityManager( 1576): Waited long enough for: ServiceRecord{3190faa3 u0 com.google.android.gms/.config.ConfigFetchService}
01-03 18:25:09.701 I/ActivityManager( 1576): Waited long enough for: ServiceRecord{3ef159 u0 com.google.android.googlequicksearchbox/com.google.android.search.core.service.SearchService}
01-03 18:25:09.904 I/ActivityManager( 1576): Waited long enough for: ServiceRecord{1d36f8a6 u0 com.google.android.gms/.kids.account.UserSwitchListenerService}
01-03 18:25:11.307 W/ActivityManager( 1576): Unable to start service Intent { act=com.google.android.gms.analytics.service.START cmp=com.google.android.gms/.analytics.service.AnalyticsService (has extras) } U=0: not found
01-03 18:25:11.308 W/GAV2 ( 3178): Thread[Service Reconnect,5,main]: Service unavailable (code=1), using local store.
01-03 18:25:11.418 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:25:11.420 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:25:11.423 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:25:11.423 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:25:11.423 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:25:11.423 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:25:11.423 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:25:11.427 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:25:11.582 I/auditd ( 3342): Starting up
01-03 18:25:11.583 E/auditd ( 3342): Failed on audit_set_pid with error: Protocol not supported
01-03 18:25:11.583 I/auditd ( 3342): Exiting
01-03 18:25:11.909 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:11.931 D/DashboardSummary( 2411): rebuildUI took: 201 ms
01-03 18:25:12.010 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:12.111 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:12.121 I/Timeline( 2411): Timeline: Activity_idle id: android.os.BinderProxy@3e740448 time:168112
01-03 18:25:12.211 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:12.312 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:12.412 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:12.439 D/BluetoothAdapterState( 2680): CURRENT_STATE=PENDING, MESSAGE = ENABLE_TIMEOUT, isTurningOn=true, isTurningOff=false
01-03 18:25:12.439 E/BluetoothAdapterState( 2680): Error enabling Bluetooth
01-03 18:25:12.439 E/bt-btif ( 2680): bte_ssr_cleanup
01-03 18:25:12.439 I/BluetoothServiceJni( 2680): ssrcleanupNative: return from cleanup
01-03 18:25:12.439 D/BluetoothAdapterService( 2680): mProfilesStarted : true supportedProfileServices.length : 8
01-03 18:25:12.443 D/HeadsetService( 2680): Received stop request...Stopping profile...
01-03 18:25:12.445 D/HeadsetStateMachine( 2680): Exit Disconnected: -1
01-03 18:25:12.448 D/A2dpService( 2680): Received stop request...Stopping profile...
01-03 18:25:12.448 D/A2dpStateMachine( 2680): Exit Disconnected: -1
01-03 18:25:12.455 D/HidService( 2680): Received stop request...Stopping profile...
01-03 18:25:12.455 D/BluetoothAdapterProperties( 2680): Setting state to 10
01-03 18:25:12.455 I/BluetoothAdapterState( 2680): Bluetooth adapter state changed: 11-> 10
01-03 18:25:12.456 D/BluetoothManagerService( 1576): Message: 60
01-03 18:25:12.456 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 11, newState=10
01-03 18:25:12.456 I/BluetoothAdapterState( 2680): Entering OffState
01-03 18:25:12.456 D/BluetoothManagerService( 1576): Broadcasting onBluetoothStateChange(false) to 17 receivers.
01-03 18:25:12.457 D/BluetoothPan( 2411): onBluetoothStateChange on: false
01-03 18:25:12.458 E/BluetoothPan( 2411):
01-03 18:25:12.458 E/BluetoothPan( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPan$2@14c69600
01-03 18:25:12.458 E/BluetoothPan( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:12.458 E/BluetoothPan( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:12.458 E/BluetoothPan( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:12.458 E/BluetoothPan( 2411): at android.bluetooth.BluetoothPan$1.onBluetoothStateChange(BluetoothPan.java:206)
01-03 18:25:12.458 E/BluetoothPan( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:12.458 E/BluetoothPan( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:12.459 D/BluetoothInputDevice( 1706): onBluetoothStateChange: up=false
01-03 18:25:12.460 E/BluetoothInputDevice( 1706):
01-03 18:25:12.460 E/BluetoothInputDevice( 1706): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothInputDevice$2@2a6cbc76
01-03 18:25:12.460 E/BluetoothInputDevice( 1706): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:12.460 E/BluetoothInputDevice( 1706): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:12.460 E/BluetoothInputDevice( 1706): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:12.460 E/BluetoothInputDevice( 1706): at android.bluetooth.BluetoothInputDevice$1.onBluetoothStateChange(BluetoothInputDevice.java:227)
01-03 18:25:12.460 E/BluetoothInputDevice( 1706): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:12.460 E/BluetoothInputDevice( 1706): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:12.461 D/BluetoothHeadset( 1998): onBluetoothStateChange: up=false
01-03 18:25:12.461 W/BluetoothHeadsetServiceJni( 2680): Cleaning up Bluetooth Handsfree Interface...
01-03 18:25:12.461 W/BluetoothHeadsetServiceJni( 2680): Cleaning up Bluetooth Handsfree callback object
01-03 18:25:12.461 D/BluetoothA2dp( 1576): onBluetoothStateChange: up=false
01-03 18:25:12.462 D/HealthService( 2680): Received stop request...Stopping profile...
01-03 18:25:12.462 E/BluetoothA2dp( 1576):
01-03 18:25:12.462 E/BluetoothA2dp( 1576): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dp$2@3214f02c
01-03 18:25:12.462 E/BluetoothA2dp( 1576): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:12.462 E/BluetoothA2dp( 1576): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:12.462 E/BluetoothA2dp( 1576): at android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange(BluetoothA2dp.java:126)
01-03 18:25:12.462 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.sendBluetoothStateCallback(BluetoothManagerService.java:761)
01-03 18:25:12.462 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.bluetoothStateChangeHandler(BluetoothManagerService.java:1507)
01-03 18:25:12.462 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.access$3700(BluetoothManagerService.java:68)
01-03 18:25:12.462 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:1226)
01-03 18:25:12.462 E/BluetoothA2dp( 1576): at android.os.Handler.dispatchMessage(Handler.java:102)
01-03 18:25:12.462 E/BluetoothA2dp( 1576): at android.os.Looper.loop(Looper.java:135)
01-03 18:25:12.462 E/BluetoothA2dp( 1576): at android.os.HandlerThread.run(HandlerThread.java:61)
01-03 18:25:12.462 E/BluetoothA2dp( 1576): at com.android.server.ServiceThread.run(ServiceThread.java:46)
01-03 18:25:12.462 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:25:12.463 D/BluetoothPan( 1706): onBluetoothStateChange on: false
01-03 18:25:12.464 E/BluetoothPan( 1706):
01-03 18:25:12.464 E/BluetoothPan( 1706): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPan$2@12805ee4
01-03 18:25:12.464 E/BluetoothPan( 1706): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:12.464 E/BluetoothPan( 1706): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:12.464 E/BluetoothPan( 1706): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:12.464 E/BluetoothPan( 1706): at android.bluetooth.BluetoothPan$1.onBluetoothStateChange(BluetoothPan.java:206)
01-03 18:25:12.464 E/BluetoothPan( 1706): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:12.464 E/BluetoothPan( 1706): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:12.464 D/PanService( 2680): Received stop request...Stopping profile...
01-03 18:25:12.464 D/BluetoothHeadset( 1706): onBluetoothStateChange: up=false
01-03 18:25:12.465 D/BluetoothA2dp( 1706): onBluetoothStateChange: up=false
01-03 18:25:12.465 D/BtGatt.DebugUtils( 2680): handleDebugAction() action=null
01-03 18:25:12.466 D/BtGatt.GattService( 2680): Received stop request...Stopping profile...
01-03 18:25:12.466 D/BtGatt.GattService( 2680): stop()
01-03 18:25:12.466 D/BtGatt.AdvertiseManager( 2680): advertise clients cleared
01-03 18:25:12.466 E/BluetoothA2dp( 1706):
01-03 18:25:12.466 E/BluetoothA2dp( 1706): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dp$2@2fa45311
01-03 18:25:12.466 E/BluetoothA2dp( 1706): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:12.466 E/BluetoothA2dp( 1706): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:12.466 E/BluetoothA2dp( 1706): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:12.466 E/BluetoothA2dp( 1706): at android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange(BluetoothA2dp.java:126)
01-03 18:25:12.466 E/BluetoothA2dp( 1706): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:12.466 E/BluetoothA2dp( 1706): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:12.467 D/BluetoothAvrcpController( 1706): onBluetoothStateChange: up=false
01-03 18:25:12.469 E/BluetoothAvrcpController( 1706):
01-03 18:25:12.469 E/BluetoothAvrcpController( 1706): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothAvrcpController$2@1534c364
01-03 18:25:12.469 E/BluetoothAvrcpController( 1706): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:12.469 E/BluetoothAvrcpController( 1706): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:12.469 E/BluetoothAvrcpController( 1706): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:12.469 E/BluetoothAvrcpController( 1706): at android.bluetooth.BluetoothAvrcpController$1.onBluetoothStateChange(BluetoothAvrcpController.java:80)
01-03 18:25:12.469 E/BluetoothAvrcpController( 1706): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:12.469 E/BluetoothAvrcpController( 1706): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:12.469 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:25:12.469 I/GKI_LINUX( 2680): gki_task task_id=2 [A2DP-MEDIA] terminating
01-03 18:25:12.470 D/BluetoothInputDevice( 2411): onBluetoothStateChange: up=false
01-03 18:25:12.470 I/GKI_LINUX( 2680): GKI_exit_task 2 done
01-03 18:25:12.470 I/GKI_LINUX( 2680): GKI_shutdown(): task [A2DP-MEDIA] terminated
01-03 18:25:12.470 E/BluetoothInputDevice( 2411):
01-03 18:25:12.470 E/BluetoothInputDevice( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothInputDevice$2@2082d483
01-03 18:25:12.470 E/BluetoothInputDevice( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:12.470 E/BluetoothInputDevice( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:12.470 E/BluetoothInputDevice( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:12.470 E/BluetoothInputDevice( 2411): at android.bluetooth.BluetoothInputDevice$1.onBluetoothStateChange(BluetoothInputDevice.java:227)
01-03 18:25:12.470 E/BluetoothInputDevice( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:12.470 E/BluetoothInputDevice( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:12.471 D/BluetoothMap( 2411): onBluetoothStateChange: up=false
01-03 18:25:12.471 D/BluetoothMapService( 2680): Received stop request...Stopping profile...
01-03 18:25:12.471 D/BluetoothMapService( 2680): stop()
01-03 18:25:12.472 E/BluetoothMap( 2411):
01-03 18:25:12.472 E/BluetoothMap( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothMap$2@1e420e39
01-03 18:25:12.472 E/BluetoothMap( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:12.472 E/BluetoothMap( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:12.472 E/BluetoothMap( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:12.472 E/BluetoothMap( 2411): at android.bluetooth.BluetoothMap$1.onBluetoothStateChange(BluetoothMap.java:64)
01-03 18:25:12.472 E/BluetoothMap( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:12.472 E/BluetoothMap( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:12.472 D/BluetoothMapService( 2680): MAP Service closeService in
01-03 18:25:12.472 D/BluetoothMapService( 2680): Unregistering Email account observer
01-03 18:25:12.472 D/BluetoothPbap( 2411): onBluetoothStateChange: up=false
01-03 18:25:12.473 E/BluetoothPbap( 2411):
01-03 18:25:12.473 E/BluetoothPbap( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPbap$2@3b8b9c7e
01-03 18:25:12.473 E/BluetoothPbap( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:12.473 E/BluetoothPbap( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:12.473 E/BluetoothPbap( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:12.473 E/BluetoothPbap( 2411): at android.bluetooth.BluetoothPbap$1.onBluetoothStateChange(BluetoothPbap.java:121)
01-03 18:25:12.473 E/BluetoothPbap( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:12.473 E/BluetoothPbap( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:12.474 W/BluetoothHidServiceJni( 2680): Cleaning up Bluetooth HID Interface...
01-03 18:25:12.474 D/BluetoothMap( 1706): onBluetoothStateChange: up=false
01-03 18:25:12.474 W/bt-btif ( 2680): cleanup: HH disabling or disabled already, status = 0
01-03 18:25:12.474 W/BluetoothHidServiceJni( 2680): Cleaning up Bluetooth GID callback object
01-03 18:25:12.475 W/BluetoothHealthServiceJni( 2680): Cleaning up Bluetooth Health Interface...
01-03 18:25:12.475 E/BluetoothMap( 1706):
01-03 18:25:12.475 E/BluetoothMap( 1706): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothMap$2@2afc6277
01-03 18:25:12.475 E/BluetoothMap( 1706): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:12.475 E/BluetoothMap( 1706): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:12.475 E/BluetoothMap( 1706): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:12.475 E/BluetoothMap( 1706): at android.bluetooth.BluetoothMap$1.onBluetoothStateChange(BluetoothMap.java:64)
01-03 18:25:12.475 E/BluetoothMap( 1706): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:12.475 E/BluetoothMap( 1706): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:12.475 W/BluetoothHealthServiceJni( 2680): Cleaning up Bluetooth Health object
01-03 18:25:12.475 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:25:12.475 W/BluetoothPanServiceJni( 2680): Cleaning up Bluetooth PAN Interface...
01-03 18:25:12.476 W/BluetoothPanServiceJni( 2680): Cleaning up Bluetooth PAN callback object
01-03 18:25:12.476 D/BluetoothA2dpSink( 1706): onBluetoothStateChange: up=false
01-03 18:25:12.476 E/BluetoothA2dpSink( 1706):
01-03 18:25:12.476 E/BluetoothA2dpSink( 1706): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dpSink$2@1e57d9cd
01-03 18:25:12.476 E/BluetoothA2dpSink( 1706): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:12.476 E/BluetoothA2dpSink( 1706): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:12.476 E/BluetoothA2dpSink( 1706): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:12.476 E/BluetoothA2dpSink( 1706): at android.bluetooth.BluetoothA2dpSink$1.onBluetoothStateChange(BluetoothA2dpSink.java:139)
01-03 18:25:12.476 E/BluetoothA2dpSink( 1706): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:12.476 E/BluetoothA2dpSink( 1706): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:12.477 D/BluetoothHeadsetClient( 1706): onBluetoothStateChange: up=false
01-03 18:25:12.477 D/BtGatt.GattService( 2680): cleanup()
01-03 18:25:12.477 W/bt-btif ( 2680): GATTC Module not enabled/already disabled
01-03 18:25:12.477 W/bt-btif ( 2680): GATTS Module not enabled/already disabled
01-03 18:25:12.478 D/BluetoothMapService( 2680): cleanup()
01-03 18:25:12.478 E/BluetoothHeadsetClient( 1706):
01-03 18:25:12.478 E/BluetoothHeadsetClient( 1706): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothHeadsetClient$2@31526282
01-03 18:25:12.478 E/BluetoothHeadsetClient( 1706): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:12.478 E/BluetoothHeadsetClient( 1706): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:12.478 E/BluetoothHeadsetClient( 1706): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:12.478 E/BluetoothHeadsetClient( 1706): at android.bluetooth.BluetoothHeadsetClient$1.onBluetoothStateChange(BluetoothHeadsetClient.java:382)
01-03 18:25:12.478 E/BluetoothHeadsetClient( 1706): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:12.478 E/BluetoothHeadsetClient( 1706): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:12.478 D/BluetoothMapService( 2680): MAP Service closeService in
01-03 18:25:12.479 D/BluetoothManagerService( 1576): Bluetooth State Change Intent: 11 -> 10
01-03 18:25:12.480 E/BluetoothManagerService( 1576): recoverBluetoothServiceFromError
01-03 18:25:12.487 I/Timeline( 1576): Timeline: Activity_windows_visible id: ActivityRecord{30b527f2 u0 com.android.settings/.Settings t19} time:168479
01-03 18:25:12.488 W/ContextImpl( 2411): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1721 android.content.ContextWrapper.startService:522 android.content.ContextWrapper.startService:522 com.android.settings.bluetooth.DockEventReceiver.beginStartingService:134 com.android.settings.bluetooth.DockEventReceiver.onReceive:115
01-03 18:25:12.494 D/Index ( 2411): Deleting data for locale 'de_DE' took 5 millis
01-03 18:25:12.510 D/Index ( 2411): Indexing locale 'de_DE' took 16 millis
01-03 18:25:12.516 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:12.524 D/DockEventReceiver( 2411): finishStartingService: stopping service
01-03 18:25:12.535 D/AuthorizationBluetoothService( 2126): Received Bluetooth event: Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x14000010 cmp=com.google.android.gms/.auth.be.proximity.authorization.bt.AuthorizationBluetoothService$BluetoothStateChangeReceiver (has extras) }.
01-03 18:25:12.541 E/BTEventHandler( 2680): A4WP is not supported
01-03 18:25:12.616 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:12.717 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:12.818 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:12.919 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:12.981 D/BluetoothManagerService( 1576): Sending off request.
01-03 18:25:12.982 D/BluetoothAdapterState( 2680): CURRENT_STATE=OFF, MESSAGE = USER_TURN_OFF
01-03 18:25:12.983 D/BluetoothManagerService( 1576): Calling onBluetoothServiceDown callbacks
01-03 18:25:12.983 D/BluetoothManagerService( 1576): Broadcasting onBluetoothServiceDown() to 6 receivers.
01-03 18:25:12.985 D/BluetoothManagerService( 1576): Calling onQBluetoothServiceDown callbacks
01-03 18:25:12.985 D/BluetoothManagerService( 1576): Broadcasting onQBluetoothServiceDown() to 0 receivers.
01-03 18:25:12.994 W/bt_userial( 2680): userial_close_reader Already closed userial reader thread
01-03 18:25:12.995 I/GKI_LINUX( 2680): gki_task task_id=0 [BTU] terminating
01-03 18:25:12.996 I/GKI_LINUX( 2680): GKI_exit_task 0 done
01-03 18:25:12.996 I/GKI_LINUX( 2680): GKI_shutdown(): task [BTU] terminated
01-03 18:25:12.996 E/BluetoothServiceJni( 2680): Callback env check fail: env: 0x42478ac0, callback: 0x6842bac0
01-03 18:25:12.996 E/BluetoothServiceJni( 2680): Callback: 'adapter_state_change_callback' is not called on the correct thread
01-03 18:25:12.997 I/GKI_LINUX( 2680): gki_task task_id=1 [BTIF] terminating
01-03 18:25:12.997 I/GKI_LINUX( 2680): GKI_exit_task 1 done
01-03 18:25:12.997 I/GKI_LINUX( 2680): GKI_shutdown(): task [BTIF] terminated
01-03 18:25:12.998 I/BluetoothServiceJni( 2680): cleanupNative: return from cleanup
01-03 18:25:13.003 I/ActivityManager( 1576): Killing 2686:com.android.keychain/1000 (adj 15): empty #17
01-03 18:25:13.020 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:13.120 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:13.221 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:13.321 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:13.422 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:13.523 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:13.623 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:13.724 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:13.825 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:13.926 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:14.026 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:14.127 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:14.173 W/ActivityManager( 1576): Unable to start service Intent { act=com.google.android.gms.analytics.service.START cmp=com.google.android.gms/.analytics.service.AnalyticsService (has extras) } U=0: not found
01-03 18:25:14.173 W/GAV2 ( 3243): Thread[Service Reconnect,5,main]: Service unavailable (code=1), using local store.
01-03 18:25:14.228 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:14.329 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:14.430 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:14.443 I/ActivityManager( 1576): Waited long enough for: ServiceRecord{17c4c5e4 u0 com.android.email/.service.LegacyImapSyncAdapterService}
01-03 18:25:14.530 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:14.631 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:14.717 I/Timeline( 2411): Timeline: Activity_launch_request id:com.android.settings time:170709
01-03 18:25:14.719 I/ActivityManager( 1576): START u0 {act=android.intent.action.MAIN cmp=com.android.settings/.SubSettings (has extras)} from uid 1000 on display 0
01-03 18:25:14.720 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:25:14.722 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:25:14.723 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:25:14.723 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:25:14.723 D/alsa_pcm( 1321): pcm_close()
01-03 18:25:14.724 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:25:14.726 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:25:14.727 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:25:14.727 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:25:14.727 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:25:14.727 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:25:14.730 V/WindowManager( 1576): addAppToken: AppWindowToken{25a18345 token=Token{1b8dc7bc ActivityRecord{209d07af u0 com.android.settings/.SubSettings t19}}} to stack=1 task=19 at 1
01-03 18:25:14.730 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:25:14.733 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:14.774 I/CheckinService( 2491): Done disabling old GoogleServicesFramework version
01-03 18:25:14.834 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:14.838 D/SubSettings( 2411): Launching fragment com.android.settings.wifi.WifiSettings
01-03 18:25:14.886 I/InputDispatcher( 1576): Dropping event because there is no touchable window at (643, 361).
01-03 18:25:14.936 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:15.006 V/WindowManager( 1576): Adding window Window{1d0546d8 u0 com.android.settings/com.android.settings.SubSettings} at 3 of 8 (after Window{1e690cd9 u0 com.android.settings/com.android.settings.Settings})
01-03 18:25:15.036 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:15.137 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:15.238 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:15.339 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:15.440 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:15.541 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:15.592 I/ActivityManager( 1576): Displayed com.android.settings/.SubSettings: +841ms
01-03 18:25:15.642 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:15.686 I/Timeline( 2411): Timeline: Activity_idle id: android.os.BinderProxy@1295d420 time:171678
01-03 18:25:15.742 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:15.843 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:15.943 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:15.946 I/Timeline( 1576): Timeline: Activity_windows_visible id: ActivityRecord{209d07af u0 com.android.settings/.SubSettings t19} time:171938
01-03 18:25:15.992 D/BluetoothManagerService( 1576): Message: 42
01-03 18:25:15.992 D/BluetoothManagerService( 1576): MESSAGE_RESTART_BLUETOOTH_SERVICE: Restart IBluetooth service
01-03 18:25:15.996 D/BluetoothAdapterState( 2680): make
01-03 18:25:15.998 I/bluedroid( 2680): init
01-03 18:25:15.998 I/BluetoothAdapterState( 2680): Entering OffState
01-03 18:25:15.998 I/bte_conf( 2680): bte_load_conf attempt to load stack conf from /etc/bluetooth/bt_stack.conf
01-03 18:25:15.999 I/bte_conf( 2680): bte_load_ble_conf attempt to load ble stack conf from /etc/bluetooth/ble_stack.conf
01-03 18:25:15.999 E/bt_osi_config( 2680): config_new unable to open file '/etc/bluetooth/ble_stack.conf': No such file or directory
01-03 18:25:15.999 I/bte_conf( 2680): bte_load_ble_conf file >/etc/bluetooth/ble_stack.conf< not found
01-03 18:25:15.999 I/bluedroid( 2680): get_profile_interface socket
01-03 18:25:15.999 I/GKI_LINUX( 2680): gki_task_entry task_id=1 [BTIF] starting
01-03 18:25:15.999 I/bluedroid( 2680): get_profile_interface map_client
01-03 18:25:16.000 D/BluetoothAdapterProperties( 2680): Address is:22:22:DE:59:9F:D7
01-03 18:25:16.002 D/BluetoothManagerService( 1576): Bluetooth Adapter name changed to Rockchip
01-03 18:25:16.002 D/BluetoothAdapterProperties( 2680): Name is: Rockchip
01-03 18:25:16.002 D/BluetoothManagerService( 1576): Stored Bluetooth name: Rockchip
01-03 18:25:16.003 D/BluetoothManagerService( 1576): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
01-03 18:25:16.003 D/BluetoothManagerService( 1576): Message: 40
01-03 18:25:16.003 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
01-03 18:25:16.003 I/bluedroid( 2680): config_hci_snoop_log
01-03 18:25:16.004 D/BluetoothManagerService( 1576): Calling onBluetoothServiceUp callbacks
01-03 18:25:16.004 D/BluetoothManagerService( 1576): Broadcasting onBluetoothServiceUp() to 6 receivers.
01-03 18:25:16.006 D/BluetoothAdapterState( 2680): CURRENT_STATE=OFF, MESSAGE = USER_TURN_ON
01-03 18:25:16.006 D/BluetoothAdapterProperties( 2680): Setting state to 11
01-03 18:25:16.006 I/BluetoothAdapterState( 2680): Bluetooth adapter state changed: 10-> 11
01-03 18:25:16.006 D/BluetoothManagerService( 1576): Message: 60
01-03 18:25:16.006 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 10, newState=11
01-03 18:25:16.006 D/BluetoothManagerService( 1576): Bluetooth State Change Intent: 10 -> 11
01-03 18:25:16.008 D/BluetoothBondStateMachine( 2680): make
01-03 18:25:16.010 D/BluetoothAdapterService( 2680): checkA2dpState: isA2dpSinkEnabled = false
01-03 18:25:16.010 E/BluetoothAdapterService( 2680): checkA2dpState: returning
01-03 18:25:16.010 D/BluetoothAdapterService( 2680): checkHidState: isHidDev = false
01-03 18:25:16.010 E/BluetoothAdapterService( 2680): checkHidState: returning
01-03 18:25:16.010 D/BluetoothAdapterService( 2680): checkHfpState: isHfpClientEnabled = false
01-03 18:25:16.010 E/BluetoothAdapterService( 2680): checkHfpState: returning
01-03 18:25:16.011 I/BluetoothBondStateMachine( 2680): StableState(): Entering Off State
01-03 18:25:16.012 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@2e496ddd
01-03 18:25:16.013 D/HeadsetService( 2680): Received start request. Starting profile...
01-03 18:25:16.013 D/HeadsetStateMachine( 2680): make
01-03 18:25:16.017 D/HeadsetStateMachine( 2680): max_hf_connections = 1
01-03 18:25:16.017 I/bluedroid( 2680): get_profile_interface handsfree
01-03 18:25:16.023 D/HeadsetStateMachine( 2680): Enter Disconnected: -2, size: 0
01-03 18:25:16.024 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@2e496ddd
01-03 18:25:16.025 D/A2dpService( 2680): Received start request. Starting profile...
01-03 18:25:16.025 I/bluedroid( 2680): get_profile_interface avrcp
01-03 18:25:16.029 V/AudioService( 1576): updateRemoteControllerOnExistingMediaPlayers: size of Player list: 0
01-03 18:25:16.029 E/AudioService( 1576): No RCC entry present to update
01-03 18:25:16.029 E/RemoteController( 2680): Cannot set synchronization mode on an unregistered RemoteController
01-03 18:25:16.029 D/A2dpStateMachine( 2680): make
01-03 18:25:16.030 I/bluedroid( 2680): get_profile_interface a2dp
01-03 18:25:16.030 I/GKI_LINUX( 2680): gki_task_entry task_id=2 [A2DP-MEDIA] starting
01-03 18:25:16.030 D/bt-btif ( 2680): btif_av_state_idle_handler event:BTIF_SM_ENTER_EVT flags 0
01-03 18:25:16.031 D/A2dpService( 2680): setA2dpService(): set to: null
01-03 18:25:16.031 D/A2dpStateMachine( 2680): Enter Disconnected: -2
01-03 18:25:16.031 I/BluetoothAdapterService( 2680): skipping com.android.bluetooth.hid.HidDevService (disabled)
01-03 18:25:16.032 I/BluetoothAdapterState( 2680): Entering PendingCommandState State: isTurningOn()=true, isTurningOff()=false
01-03 18:25:16.033 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@2e496ddd
01-03 18:25:16.033 D/HidService( 2680): Received start request. Starting profile...
01-03 18:25:16.033 I/bluedroid( 2680): get_profile_interface hidhost
01-03 18:25:16.033 I/Telecom ( 1576): BluetoothPhoneService: queryPhoneState
01-03 18:25:16.034 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@2e496ddd
01-03 18:25:16.035 D/HealthService( 2680): Received start request. Starting profile...
01-03 18:25:16.036 I/bluedroid( 2680): get_profile_interface health
01-03 18:25:16.036 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@2e496ddd
01-03 18:25:16.037 D/PanService( 2680): Received start request. Starting profile...
01-03 18:25:16.037 D/BluetoothPanServiceJni( 2680): initializeNative(L110): pan
01-03 18:25:16.037 I/bluedroid( 2680): get_profile_interface pan
01-03 18:25:16.037 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@2e496ddd
01-03 18:25:16.037 D/HeadsetStateMachine( 2680): Disconnected process message: 10, size: 0
01-03 18:25:16.037 D/HeadsetPhoneState( 2680): sendDeviceStateChanged. mService=0 mSignal=0 mRoam=0 mBatteryCharge=3
01-03 18:25:16.037 D/BtGatt.DebugUtils( 2680): handleDebugAction() action=null
01-03 18:25:16.037 D/HeadsetStateMachine( 2680): Disconnected process message: 11, size: 0
01-03 18:25:16.038 D/BtGatt.GattService( 2680): Received start request. Starting profile...
01-03 18:25:16.038 D/BtGatt.GattService( 2680): start()
01-03 18:25:16.038 I/bluedroid( 2680): get_profile_interface gatt
01-03 18:25:16.038 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@2e496ddd
01-03 18:25:16.038 D/BtGatt.AdvertiseManager( 2680): advertise manager created
01-03 18:25:16.042 D/BluetoothMapService( 2680): inside BluetoothMapObexConnection
01-03 18:25:16.042 D/BluetoothMapService( 2680): supportedMessageTypes 14
01-03 18:25:16.042 D/BluetoothMapService( 2680): masId 0
01-03 18:25:16.042 D/BluetoothMapService( 2680): masId 1
01-03 18:25:16.042 D/BluetoothMapService( 2680): Inside initBinder
01-03 18:25:16.042 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@2e496ddd
01-03 18:25:16.043 D/BluetoothMapService( 2680): Received start request. Starting profile...
01-03 18:25:16.043 D/BluetoothMapService( 2680): start()
01-03 18:25:16.043 D/AuthorizationBluetoothService( 2126): Received Bluetooth event: Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x14000010 cmp=com.google.android.gms/.auth.be.proximity.authorization.bt.AuthorizationBluetoothService$BluetoothStateChangeReceiver (has extras) }.
01-03 18:25:16.044 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:16.046 D/BluetoothMapService( 2680): Registering observer
01-03 18:25:16.047 V/BluetoothMapService( 2680): Handler(): got msg=1
01-03 18:25:16.047 D/BluetoothAdapterState( 2680): CURRENT_STATE=PENDING, MESSAGE = STARTED, isTurningOn=true, isTurningOff=false
01-03 18:25:16.047 I/bluedroid( 2680): enable
01-03 18:25:16.047 I/bt_hci_bdroid( 2680): init
01-03 18:25:16.047 I/GKI_LINUX( 2680): gki_task_entry task_id=0 [BTU] starting
01-03 18:25:16.047 I/bt-btu ( 2680): btu_task pending for preload complete event
01-03 18:25:16.048 I/bt_vendor( 2680): init
01-03 18:25:16.048 D/bt_userial( 2680): userial_init
01-03 18:25:16.048 E/BTEventHandler( 2680): A4WP is not supported
01-03 18:25:16.049 I/bt_vendor( 2680): userial vendor open: opening /dev/rtk_btusb
01-03 18:25:16.049 E/bt_vendor( 2680): userial vendor open: unable to open /dev/rtk_btusb: Permission denied
01-03 18:25:16.049 E/bt_userial( 2680): userial_open opened wrong number of ports: got 0, expected 1.
01-03 18:25:16.049 I/bt-btu ( 2680): btu_task received preload complete event
01-03 18:25:16.049 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x0001
01-03 18:25:16.049 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x001f
01-03 18:25:16.050 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x0003
01-03 18:25:16.050 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x1487
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_HCI
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_L2CAP
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_RFCOMM
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_AVDT
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_AVRC
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_A2D
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_BNEP
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTM
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_HID_HOST
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_GAP
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_PAN
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_SDP
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_GATT
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_SMP
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_HID_DEV
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTAPP
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTIF
01-03 18:25:16.052 I/ ( 2680): BTE_InitTraceLevels -- TRC_LATENCY_AUDIO
01-03 18:25:16.052 E/bt_userial( 2680): userial_write error writing to serial port: Bad file number
01-03 18:25:16.144 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:16.245 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:16.345 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:16.446 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:16.547 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:16.594 I/auditd ( 3373): Starting up
01-03 18:25:16.595 E/auditd ( 3373): Failed on audit_set_pid with error: Protocol not supported
01-03 18:25:16.595 I/auditd ( 3373): Exiting
01-03 18:25:16.647 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:16.747 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:16.847 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:16.848 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:25:16.849 E/WifiStateMachine( 1576): Failed to setup control channel, restart supplicant
01-03 18:25:16.849 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:25:17.019 I/ActivityManager( 1576): Waited long enough for: ServiceRecord{26d1c572 u0 com.google.android.calendar/com.android.calendar.alerts.InitAlarmsService}
01-03 18:25:17.739 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:25:17.739 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:25:17.739 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:25:17.739 D/alsa_pcm( 1321): pcm_close()
01-03 18:25:18.147 D/PhoneStatusBar( 1706): disable: < expand ICONS* alerts SYSTEM_INFO* back home recent clock search >
01-03 18:25:20.495 W/Settings( 1706): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
01-03 18:25:20.496 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:25:20.500 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:25:20.504 D/WifiService( 1576): setWifiEnabled: true pid=1706, uid=10013
01-03 18:25:20.504 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:25:20.505 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:25:20.505 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:25:20.505 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:25:20.505 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:25:20.505 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:25:20.510 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:25:21.632 W/Settings( 1706): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
01-03 18:25:21.634 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:25:21.637 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:25:21.637 D/WifiService( 1576): setWifiEnabled: true pid=1706, uid=10013
01-03 18:25:21.638 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:25:21.860 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:25:21.860 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:25:21.875 I/auditd ( 3381): Starting up
01-03 18:25:21.877 E/auditd ( 3381): Failed on audit_set_pid with error: Protocol not supported
01-03 18:25:21.877 I/auditd ( 3381): Exiting
01-03 18:25:21.884 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:25:21.891 D/WifiService( 1576): setWifiEnabled: true pid=1706, uid=10013
01-03 18:25:21.892 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:25:21.900 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:25:22.662 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:25:22.662 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:25:22.664 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:25:22.966 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:25:22.966 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:25:22.966 E/SoftapController( 1322): Softap fwReload failed
01-03 18:25:22.967 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '42 softap fwreload wlan0 STA' failed with '400 42 SoftAP command has failed'
01-03 18:25:22.967 D/CommandListener( 1322): Setting iface cfg
01-03 18:25:22.968 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:25:22.968 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:25:22.969 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:25:22.971 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:25:22.995 I/wpa_supplicant( 3391): Successfully initialized wpa_supplicant
01-03 18:25:22.997 I/wpa_supplicant( 3391): rfkill: Cannot open RFKILL control device
01-03 18:25:24.828 D/BackupManagerService( 1576): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.google.android.gsf flg=0x4000010 (has extras) }
01-03 18:25:24.834 I/InputReader( 1576): Reconfiguring input devices. changes=0x00000020
01-03 18:25:24.876 W/Launcher( 2016): setApplicationContext called twice! old=com.android.launcher3.LauncherApplication@5d4bf32 new=com.android.launcher3.LauncherApplication@5d4bf32
01-03 18:25:24.892 D/PackageBroadcastService( 2491): Received broadcast action=android.intent.action.PACKAGE_CHANGED and uri=com.google.android.gsf
01-03 18:25:24.898 W/ResourcesManager( 2016): Asset path '/system/framework/com.google.android.media.effects.jar' does not exist or contains no resources.
01-03 18:25:24.899 I/UpdateIcingCorporaServi( 2246): Updating corpora: APPS=com.google.android.gsf, CONTACTS=MAYBE
01-03 18:25:24.963 I/PeopleContactsSync( 2491): CP2 sync disabled
01-03 18:25:25.005 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:25:25.005 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:25:25.005 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:25:25.005 D/alsa_pcm( 1321): pcm_close()
01-03 18:25:25.026 I/Launcher( 2016): Deferring update until onResume
01-03 18:25:25.260 I/ApplicationLogger( 2246): canRun() : Opted Out
01-03 18:25:25.261 I/UpdateIcingCorporaServi( 2246): UpdateCorporaTask done [took 360 ms] updated apps [took 360 ms]
01-03 18:25:26.700 E/wpa_supplicant( 3391): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:25:26.700 E/wpa_supplicant( 3391): nl80211: Could not set interface 'wlan0' UP
01-03 18:25:26.700 E/wpa_supplicant( 3391): wlan0: Failed to initialize driver interface
01-03 18:25:26.706 I/auditd ( 3403): Starting up
01-03 18:25:26.706 E/auditd ( 3403): Failed on audit_set_pid with error: Protocol not supported
01-03 18:25:26.706 I/auditd ( 3403): Exiting
01-03 18:25:27.486 I/InputDispatcher( 1576): Application is not responding: Window{2c3900fd u0 StatusBar}. It has been 5005.6ms since event, 5005.2ms since wait started. Reason: Waiting to send non-key event because the touched window has not finished processing certain input events that were delivered to it over 500.0ms ago. Wait queue length: 5. Wait queue head age: 5512.1ms.
01-03 18:25:27.496 I/WindowManager( 1576): Input event dispatching timed out sending to StatusBar. Reason: Waiting to send non-key event because the touched window has not finished processing certain input events that were delivered to it over 500.0ms ago. Wait queue length: 5. Wait queue head age: 5512.1ms.
01-03 18:25:27.542 I/Process ( 1576): Sending signal. PID: 1706 SIG: 3
01-03 18:25:27.543 I/art ( 1706): Thread[5,tid=1729,WaitingInMainSignalCatcherLoop,Thread*=0x42428c00,peer=0x12c000a0,"Signal Catcher"]: reacting to signal 3
01-03 18:25:27.743 I/Process ( 1576): Sending signal. PID: 1576 SIG: 3
01-03 18:25:27.743 I/art ( 1576): Thread[5,tid=1582,WaitingInMainSignalCatcherLoop,Thread*=0x4242f400,peer=0x12c020a0,"Signal Catcher"]: reacting to signal 3
01-03 18:25:27.798 I/art ( 1706): Wrote stack traces to '/data/anr/traces.txt'
01-03 18:25:27.881 E/SensorsHal( 1576): poll() failed (Interrupted system call)
01-03 18:25:28.058 D/BluetoothAdapterState( 2680): CURRENT_STATE=PENDING, MESSAGE = ENABLE_TIMEOUT, isTurningOn=true, isTurningOff=false
01-03 18:25:28.058 E/BluetoothAdapterState( 2680): Error enabling Bluetooth
01-03 18:25:28.058 E/bt-btif ( 2680): bte_ssr_cleanup
01-03 18:25:28.058 I/BluetoothServiceJni( 2680): ssrcleanupNative: return from cleanup
01-03 18:25:28.058 D/BluetoothAdapterService( 2680): mProfilesStarted : true supportedProfileServices.length : 8
01-03 18:25:28.570 I/Process ( 1576): Sending signal. PID: 1998 SIG: 3
01-03 18:25:28.570 I/art ( 1998): Thread[5,tid=2027,WaitingInMainSignalCatcherLoop,Thread*=0x4242fc00,peer=0x12c000a0,"Signal Catcher"]: reacting to signal 3
01-03 18:25:28.573 D/HeadsetService( 2680): Received stop request...Stopping profile...
01-03 18:25:28.573 D/HeadsetStateMachine( 2680): Exit Disconnected: -1
01-03 18:25:28.575 D/A2dpService( 2680): Received stop request...Stopping profile...
01-03 18:25:28.576 D/A2dpStateMachine( 2680): Exit Disconnected: -1
01-03 18:25:28.577 D/BluetoothAdapterProperties( 2680): Setting state to 10
01-03 18:25:28.577 I/BluetoothAdapterState( 2680): Bluetooth adapter state changed: 11-> 10
01-03 18:25:28.577 I/BluetoothAdapterState( 2680): Entering OffState
01-03 18:25:28.577 D/BluetoothManagerService( 1576): Message: 60
01-03 18:25:28.577 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 11, newState=10
01-03 18:25:28.577 D/BluetoothManagerService( 1576): Broadcasting onBluetoothStateChange(false) to 17 receivers.
01-03 18:25:28.578 D/BluetoothPan( 2411): onBluetoothStateChange on: false
01-03 18:25:28.578 D/HidService( 2680): Received stop request...Stopping profile...
01-03 18:25:28.578 E/BluetoothPan( 2411):
01-03 18:25:28.578 E/BluetoothPan( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPan$2@14c69600
01-03 18:25:28.578 E/BluetoothPan( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:28.578 E/BluetoothPan( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:28.578 E/BluetoothPan( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:28.578 E/BluetoothPan( 2411): at android.bluetooth.BluetoothPan$1.onBluetoothStateChange(BluetoothPan.java:206)
01-03 18:25:28.578 E/BluetoothPan( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:28.578 E/BluetoothPan( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:28.579 I/Process ( 1576): Sending signal. PID: 1978 SIG: 3
01-03 18:25:28.579 I/art ( 1978): Thread[5,tid=2008,WaitingInMainSignalCatcherLoop,Thread*=0x42428c00,peer=0x12c000a0,"Signal Catcher"]: reacting to signal 3
01-03 18:25:28.579 D/BluetoothInputDevice( 1706): onBluetoothStateChange: up=false
01-03 18:25:28.580 E/BluetoothInputDevice( 1706):
01-03 18:25:28.580 E/BluetoothInputDevice( 1706): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothInputDevice$2@2a6cbc76
01-03 18:25:28.580 E/BluetoothInputDevice( 1706): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:28.580 E/BluetoothInputDevice( 1706): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:28.580 E/BluetoothInputDevice( 1706): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:28.580 E/BluetoothInputDevice( 1706): at android.bluetooth.BluetoothInputDevice$1.onBluetoothStateChange(BluetoothInputDevice.java:227)
01-03 18:25:28.580 E/BluetoothInputDevice( 1706): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:28.580 E/BluetoothInputDevice( 1706): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:28.587 I/art ( 1576): Wrote stack traces to '/data/anr/traces.txt'
01-03 18:25:28.587 W/BluetoothHeadsetServiceJni( 2680): Cleaning up Bluetooth Handsfree Interface...
01-03 18:25:28.587 W/BluetoothHeadsetServiceJni( 2680): Cleaning up Bluetooth Handsfree callback object
01-03 18:25:28.589 D/HealthService( 2680): Received stop request...Stopping profile...
01-03 18:25:28.590 D/PanService( 2680): Received stop request...Stopping profile...
01-03 18:25:28.591 D/BtGatt.DebugUtils( 2680): handleDebugAction() action=null
01-03 18:25:28.591 D/BtGatt.GattService( 2680): Received stop request...Stopping profile...
01-03 18:25:28.591 D/BtGatt.GattService( 2680): stop()
01-03 18:25:28.591 D/BtGatt.AdvertiseManager( 2680): advertise clients cleared
01-03 18:25:28.594 D/BluetoothMapService( 2680): Received stop request...Stopping profile...
01-03 18:25:28.594 D/BluetoothMapService( 2680): stop()
01-03 18:25:28.594 D/BluetoothMapService( 2680): MAP Service closeService in
01-03 18:25:28.594 D/BluetoothMapService( 2680): Unregistering Email account observer
01-03 18:25:28.596 I/GKI_LINUX( 2680): gki_task task_id=2 [A2DP-MEDIA] terminating
01-03 18:25:28.596 I/GKI_LINUX( 2680): GKI_exit_task 2 done
01-03 18:25:28.596 I/GKI_LINUX( 2680): GKI_shutdown(): task [A2DP-MEDIA] terminated
01-03 18:25:28.597 W/BluetoothHidServiceJni( 2680): Cleaning up Bluetooth HID Interface...
01-03 18:25:28.597 W/bt-btif ( 2680): cleanup: HH disabling or disabled already, status = 0
01-03 18:25:28.597 W/BluetoothHidServiceJni( 2680): Cleaning up Bluetooth GID callback object
01-03 18:25:28.597 W/BluetoothHealthServiceJni( 2680): Cleaning up Bluetooth Health Interface...
01-03 18:25:28.597 W/BluetoothHealthServiceJni( 2680): Cleaning up Bluetooth Health object
01-03 18:25:28.597 W/BluetoothPanServiceJni( 2680): Cleaning up Bluetooth PAN Interface...
01-03 18:25:28.597 W/BluetoothPanServiceJni( 2680): Cleaning up Bluetooth PAN callback object
01-03 18:25:28.598 D/BtGatt.GattService( 2680): cleanup()
01-03 18:25:28.598 W/bt-btif ( 2680): GATTC Module not enabled/already disabled
01-03 18:25:28.598 W/bt-btif ( 2680): GATTS Module not enabled/already disabled
01-03 18:25:28.598 D/BluetoothMapService( 2680): cleanup()
01-03 18:25:28.598 D/BluetoothMapService( 2680): MAP Service closeService in
01-03 18:25:28.671 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:28.678 I/art ( 1978): Wrote stack traces to '/data/anr/traces.txt'
01-03 18:25:28.771 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:28.872 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:28.885 D/BluetoothHeadset( 1998): onBluetoothStateChange: up=false
01-03 18:25:28.885 D/BluetoothA2dp( 1576): onBluetoothStateChange: up=false
01-03 18:25:28.886 E/BluetoothA2dp( 1576):
01-03 18:25:28.886 E/BluetoothA2dp( 1576): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dp$2@3214f02c
01-03 18:25:28.886 E/BluetoothA2dp( 1576): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:28.886 E/BluetoothA2dp( 1576): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:28.886 E/BluetoothA2dp( 1576): at android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange(BluetoothA2dp.java:126)
01-03 18:25:28.886 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.sendBluetoothStateCallback(BluetoothManagerService.java:761)
01-03 18:25:28.886 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.bluetoothStateChangeHandler(BluetoothManagerService.java:1507)
01-03 18:25:28.886 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.access$3700(BluetoothManagerService.java:68)
01-03 18:25:28.886 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:1226)
01-03 18:25:28.886 E/BluetoothA2dp( 1576): at android.os.Handler.dispatchMessage(Handler.java:102)
01-03 18:25:28.886 E/BluetoothA2dp( 1576): at android.os.Looper.loop(Looper.java:135)
01-03 18:25:28.886 E/BluetoothA2dp( 1576): at android.os.HandlerThread.run(HandlerThread.java:61)
01-03 18:25:28.886 E/BluetoothA2dp( 1576): at com.android.server.ServiceThread.run(ServiceThread.java:46)
01-03 18:25:28.886 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:25:28.886 D/BluetoothPan( 1706): onBluetoothStateChange on: false
01-03 18:25:28.886 E/BluetoothPan( 1706):
01-03 18:25:28.886 E/BluetoothPan( 1706): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPan$2@12805ee4
01-03 18:25:28.886 E/BluetoothPan( 1706): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:28.886 E/BluetoothPan( 1706): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:28.886 E/BluetoothPan( 1706): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:28.886 E/BluetoothPan( 1706): at android.bluetooth.BluetoothPan$1.onBluetoothStateChange(BluetoothPan.java:206)
01-03 18:25:28.886 E/BluetoothPan( 1706): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:28.886 E/BluetoothPan( 1706): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:28.887 D/BluetoothHeadset( 1706): onBluetoothStateChange: up=false
01-03 18:25:28.887 D/BluetoothA2dp( 1706): onBluetoothStateChange: up=false
01-03 18:25:28.888 E/BluetoothA2dp( 1706):
01-03 18:25:28.888 E/BluetoothA2dp( 1706): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dp$2@2fa45311
01-03 18:25:28.888 E/BluetoothA2dp( 1706): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:28.888 E/BluetoothA2dp( 1706): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:28.888 E/BluetoothA2dp( 1706): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:28.888 E/BluetoothA2dp( 1706): at android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange(BluetoothA2dp.java:126)
01-03 18:25:28.888 E/BluetoothA2dp( 1706): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:28.888 E/BluetoothA2dp( 1706): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:28.889 D/BluetoothAvrcpController( 1706): onBluetoothStateChange: up=false
01-03 18:25:28.889 E/BluetoothAvrcpController( 1706):
01-03 18:25:28.889 E/BluetoothAvrcpController( 1706): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothAvrcpController$2@1534c364
01-03 18:25:28.889 E/BluetoothAvrcpController( 1706): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:28.889 E/BluetoothAvrcpController( 1706): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:28.889 E/BluetoothAvrcpController( 1706): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:28.889 E/BluetoothAvrcpController( 1706): at android.bluetooth.BluetoothAvrcpController$1.onBluetoothStateChange(BluetoothAvrcpController.java:80)
01-03 18:25:28.889 E/BluetoothAvrcpController( 1706): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:28.889 E/BluetoothAvrcpController( 1706): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:28.889 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:25:28.890 D/BluetoothInputDevice( 2411): onBluetoothStateChange: up=false
01-03 18:25:28.890 I/art ( 1998): Wrote stack traces to '/data/anr/traces.txt'
01-03 18:25:28.890 E/BluetoothInputDevice( 2411):
01-03 18:25:28.890 E/BluetoothInputDevice( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothInputDevice$2@2082d483
01-03 18:25:28.890 E/BluetoothInputDevice( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:28.890 E/BluetoothInputDevice( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:28.890 E/BluetoothInputDevice( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:28.890 E/BluetoothInputDevice( 2411): at android.bluetooth.BluetoothInputDevice$1.onBluetoothStateChange(BluetoothInputDevice.java:227)
01-03 18:25:28.890 E/BluetoothInputDevice( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:28.890 E/BluetoothInputDevice( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:28.891 D/BluetoothMap( 2411): onBluetoothStateChange: up=false
01-03 18:25:28.891 E/BluetoothMap( 2411):
01-03 18:25:28.891 E/BluetoothMap( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothMap$2@1e420e39
01-03 18:25:28.891 E/BluetoothMap( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:28.891 E/BluetoothMap( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:28.891 E/BluetoothMap( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:28.891 E/BluetoothMap( 2411): at android.bluetooth.BluetoothMap$1.onBluetoothStateChange(BluetoothMap.java:64)
01-03 18:25:28.891 E/BluetoothMap( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:28.891 E/BluetoothMap( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:28.891 D/BluetoothPbap( 2411): onBluetoothStateChange: up=false
01-03 18:25:28.892 E/BluetoothPbap( 2411):
01-03 18:25:28.892 E/BluetoothPbap( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPbap$2@3b8b9c7e
01-03 18:25:28.892 E/BluetoothPbap( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:28.892 E/BluetoothPbap( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:28.892 E/BluetoothPbap( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:28.892 E/BluetoothPbap( 2411): at android.bluetooth.BluetoothPbap$1.onBluetoothStateChange(BluetoothPbap.java:121)
01-03 18:25:28.892 E/BluetoothPbap( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:28.892 E/BluetoothPbap( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:28.892 D/BluetoothMap( 1706): onBluetoothStateChange: up=false
01-03 18:25:28.892 E/BluetoothMap( 1706):
01-03 18:25:28.892 E/BluetoothMap( 1706): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothMap$2@2afc6277
01-03 18:25:28.892 E/BluetoothMap( 1706): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:28.892 E/BluetoothMap( 1706): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:28.892 E/BluetoothMap( 1706): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:28.892 E/BluetoothMap( 1706): at android.bluetooth.BluetoothMap$1.onBluetoothStateChange(BluetoothMap.java:64)
01-03 18:25:28.892 E/BluetoothMap( 1706): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:28.892 E/BluetoothMap( 1706): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:28.892 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:25:28.892 D/BluetoothA2dpSink( 1706): onBluetoothStateChange: up=false
01-03 18:25:28.893 E/BluetoothA2dpSink( 1706):
01-03 18:25:28.893 E/BluetoothA2dpSink( 1706): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dpSink$2@1e57d9cd
01-03 18:25:28.893 E/BluetoothA2dpSink( 1706): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:28.893 E/BluetoothA2dpSink( 1706): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:28.893 E/BluetoothA2dpSink( 1706): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:28.893 E/BluetoothA2dpSink( 1706): at android.bluetooth.BluetoothA2dpSink$1.onBluetoothStateChange(BluetoothA2dpSink.java:139)
01-03 18:25:28.893 E/BluetoothA2dpSink( 1706): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:28.893 E/BluetoothA2dpSink( 1706): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:28.893 D/BluetoothHeadsetClient( 1706): onBluetoothStateChange: up=false
01-03 18:25:28.893 E/BluetoothHeadsetClient( 1706):
01-03 18:25:28.893 E/BluetoothHeadsetClient( 1706): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothHeadsetClient$2@31526282
01-03 18:25:28.893 E/BluetoothHeadsetClient( 1706): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:28.893 E/BluetoothHeadsetClient( 1706): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:28.893 E/BluetoothHeadsetClient( 1706): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:28.893 E/BluetoothHeadsetClient( 1706): at android.bluetooth.BluetoothHeadsetClient$1.onBluetoothStateChange(BluetoothHeadsetClient.java:382)
01-03 18:25:28.893 E/BluetoothHeadsetClient( 1706): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:28.893 E/BluetoothHeadsetClient( 1706): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:28.894 D/BluetoothManagerService( 1576): Bluetooth State Change Intent: 11 -> 10
01-03 18:25:28.894 E/BluetoothManagerService( 1576): recoverBluetoothServiceFromError
01-03 18:25:28.972 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:29.072 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:29.173 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:29.273 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:29.374 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:29.394 D/BluetoothManagerService( 1576): Sending off request.
01-03 18:25:29.395 D/BluetoothAdapterState( 2680): CURRENT_STATE=OFF, MESSAGE = USER_TURN_OFF
01-03 18:25:29.395 D/BluetoothManagerService( 1576): Calling onBluetoothServiceDown callbacks
01-03 18:25:29.395 D/BluetoothManagerService( 1576): Broadcasting onBluetoothServiceDown() to 6 receivers.
01-03 18:25:29.396 D/BluetoothManagerService( 1576): Calling onQBluetoothServiceDown callbacks
01-03 18:25:29.396 D/BluetoothManagerService( 1576): Broadcasting onQBluetoothServiceDown() to 0 receivers.
01-03 18:25:29.398 E/Lights ( 1576): write_int failed to open sys/class/leds/rk29_key_led/brightness
01-03 18:25:29.399 W/bt_userial( 2680): userial_close_reader Already closed userial reader thread
01-03 18:25:29.399 I/GKI_LINUX( 2680): gki_task task_id=0 [BTU] terminating
01-03 18:25:29.399 I/GKI_LINUX( 2680): GKI_exit_task 0 done
01-03 18:25:29.399 I/GKI_LINUX( 2680): GKI_shutdown(): task [BTU] terminated
01-03 18:25:29.399 E/BluetoothServiceJni( 2680): Callback env check fail: env: 0x42478ac0, callback: 0x6842bac0
01-03 18:25:29.399 E/BluetoothServiceJni( 2680): Callback: 'adapter_state_change_callback' is not called on the correct thread
01-03 18:25:29.400 I/GKI_LINUX( 2680): gki_task task_id=1 [BTIF] terminating
01-03 18:25:29.400 I/GKI_LINUX( 2680): GKI_exit_task 1 done
01-03 18:25:29.400 I/GKI_LINUX( 2680): GKI_shutdown(): task [BTIF] terminated
01-03 18:25:29.400 I/BluetoothServiceJni( 2680): cleanupNative: return from cleanup
01-03 18:25:29.474 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:29.576 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:29.677 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:29.777 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:29.878 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:29.978 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:30.079 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:30.114 I/art ( 1576): Explicit concurrent mark sweep GC freed 48179(2MB) AllocSpace objects, 14(936KB) LOS objects, 33% free, 9MB/14MB, paused 1.565ms total 67.581ms
01-03 18:25:30.179 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:30.279 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:30.380 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:30.480 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:30.580 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:30.642 E/ActivityManager( 1576): ANR in com.android.systemui
01-03 18:25:30.642 E/ActivityManager( 1576): PID: 1706
01-03 18:25:30.642 E/ActivityManager( 1576): Reason: Input dispatching timed out (Waiting to send non-key event because the touched window has not finished processing certain input events that were delivered to it over 500.0ms ago. Wait queue length: 5. Wait queue head age: 5512.1ms.)
01-03 18:25:30.642 E/ActivityManager( 1576): Load: 4.89 / 2.75 / 1.08
01-03 18:25:30.642 E/ActivityManager( 1576): CPU usage from 5705ms to 600ms ago:
01-03 18:25:30.642 E/ActivityManager( 1576): 26% 1576/system_server: 6.3% user + 20% kernel / faults: 4551 minor
01-03 18:25:30.642 E/ActivityManager( 1576): 1.3% 2491/com.google.android.gms: 0.8% user + 0.4% kernel / faults: 1981 minor 2 major
01-03 18:25:30.642 E/ActivityManager( 1576): 0.9% 2246/com.google.android.googlequicksearchbox:search: 0.7% user + 0.1% kernel / faults: 797 minor
01-03 18:25:30.642 E/ActivityManager( 1576): 1.7% 1706/com.android.systemui: 1.1% user + 0.5% kernel / faults: 133 minor
01-03 18:25:30.642 E/ActivityManager( 1576): 0.5% 2016/com.cyanogenmod.trebuchet: 0.3% user + 0.1% kernel / faults: 3513 minor
01-03 18:25:30.642 E/ActivityManager( 1576): 0.9% 1318/surfaceflinger: 0.7% user + 0.1% kernel / faults: 1 minor
01-03 18:25:30.642 E/ActivityManager( 1576): 0.9% 2411/com.android.settings: 0.5% user + 0.3% kernel / faults: 147 minor
01-03 18:25:30.642 E/ActivityManager( 1576): 0.7% 77/rknand_buffer: 0% user + 0.7% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 0.7% 1321/mediaserver: 0.3% user + 0.3% kernel / faults: 2 minor
01-03 18:25:30.642 E/ActivityManager( 1576): 0.1% 84/mtdblock6: 0% user + 0.1% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 0.5% 1966/com.google.process.location: 0.3% user + 0.1% kernel / faults: 107 minor
01-03 18:25:30.642 E/ActivityManager( 1576): 0.3% 67/irq/175-lis3dh: 0.3% user + 0% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 0% 2942/com.android.vending: 0% user + 0% kernel / faults: 80 minor 1 major
01-03 18:25:30.642 E/ActivityManager( 1576): 0% 3144/com.android.gallery3d: 0% user + 0% kernel / faults: 352 minor 1 major
01-03 18:25:30.642 E/ActivityManager( 1576): 0% 1//init: 0% user + 0% kernel / faults: 65 minor
01-03 18:25:30.642 E/ActivityManager( 1576): 0% 3/ksoftirqd/0: 0% user + 0% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 0.1% 30/cfinteractive: 0% user + 0.1% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 0% 93/jbd2/mtdblock6-: 0% user + 0% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 0% 98/logd: 0% user + 0% kernel / faults: 1 minor
01-03 18:25:30.642 E/ActivityManager( 1576): 0% 100/lmkd: 0% user + 0% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 0.1% 486/kworker/u:2: 0% user + 0.1% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 0% 1159/kworker/1:2: 0% user + 0% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 0% 2126/com.google.process.gapps: 0% user + 0% kernel / faults: 560 minor
01-03 18:25:30.642 E/ActivityManager( 1576): 0% 2407/kworker/3:2: 0% user + 0% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): +0% 3387/dhd_cfg80211_ev: 0% user + 0% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): +0% 3388/dhd_watchdog: 0% user + 0% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): +0% 3389/dhd_dpc: 0% user + 0% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): +0% 3390/dhd_sysioc: 0% user + 0% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 15% TOTAL: 4.1% user + 10% kernel + 0.7% iowait
01-03 18:25:30.642 E/ActivityManager( 1576): CPU usage from 2601ms to 3117ms later:
01-03 18:25:30.642 E/ActivityManager( 1576): 7.8% 1576/system_server: 5.8% user + 1.9% kernel / faults: 2 minor
01-03 18:25:30.642 E/ActivityManager( 1576): 3.9% 1587/FinalizerDaemon: 0% user + 3.9% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 1.9% 1586/ReferenceQueueD: 0% user + 1.9% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 1.9% 1598/ActivityManager: 1.9% user + 0% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 1.9% 2133/Binder_C: 1.9% user + 0% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 1.4% 4/kworker/0:0: 0% user + 1.4% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 1.4% 67/irq/175-lis3dh: 1.4% user + 0% kernel
01-03 18:25:30.642 E/ActivityManager( 1576): 2.9% TOTAL: 0.9% user + 1.9% kernel
01-03 18:25:30.643 I/ActivityManager( 1576): Killing 1706:com.android.systemui/u0a13 (adj -12): bg anr
01-03 18:25:30.659 W/InputDispatcher( 1576): channel '2c3900fd StatusBar (server)' ~ Consumer closed input channel or an error occurred. events=0xd
01-03 18:25:30.659 E/InputDispatcher( 1576): channel '2c3900fd StatusBar (server)' ~ Channel is unrecoverably broken and will be disposed!
01-03 18:25:30.659 W/InputDispatcher( 1576): channel '1ade3c75 SearchPanel (server)' ~ Consumer closed input channel or an error occurred. events=0x9
01-03 18:25:30.660 E/InputDispatcher( 1576): channel '1ade3c75 SearchPanel (server)' ~ Channel is unrecoverably broken and will be disposed!
01-03 18:25:30.660 W/InputDispatcher( 1576): channel '1fabd298 NavigationBar (server)' ~ Consumer closed input channel or an error occurred. events=0xd
01-03 18:25:30.660 E/InputDispatcher( 1576): channel '1fabd298 NavigationBar (server)' ~ Channel is unrecoverably broken and will be disposed!
01-03 18:25:30.660 W/InputDispatcher( 1576): channel '255493dc Heads Up (server)' ~ Consumer closed input channel or an error occurred. events=0x9
01-03 18:25:30.660 E/InputDispatcher( 1576): channel '255493dc Heads Up (server)' ~ Channel is unrecoverably broken and will be disposed!
01-03 18:25:30.660 W/InputDispatcher( 1576): channel '150eebc9 com.android.systemui.ImageWallpaper (server)' ~ Consumer closed input channel or an error occurred. events=0x9
01-03 18:25:30.660 E/InputDispatcher( 1576): channel '150eebc9 com.android.systemui.ImageWallpaper (server)' ~ Channel is unrecoverably broken and will be disposed!
01-03 18:25:30.660 W/AudioService( 1576): Current remote volume controller died, unregistering
01-03 18:25:30.660 D/WifiService( 1576): Client connection lost with reason: 4
01-03 18:25:30.661 I/WindowState( 1576): WIN DEATH: Window{2c3900fd u0 StatusBar}
01-03 18:25:30.661 W/InputDispatcher( 1576): Attempted to unregister already unregistered input channel '2c3900fd StatusBar (server)'
01-03 18:25:30.667 V/KeyguardServiceDelegate( 1576): *** Keyguard disconnected (boo!)
01-03 18:25:30.667 W/VolumeController( 1576): Error calling dismiss
01-03 18:25:30.667 W/VolumeController( 1576): android.os.DeadObjectException
01-03 18:25:30.667 W/VolumeController( 1576): at android.os.BinderProxy.transactNative(Native Method)
01-03 18:25:30.667 W/VolumeController( 1576): at android.os.BinderProxy.transact(Binder.java:496)
01-03 18:25:30.667 W/VolumeController( 1576): at android.media.IVolumeController$Stub$Proxy.dismiss(IVolumeController.java:182)
01-03 18:25:30.667 W/VolumeController( 1576): at android.media.AudioService$VolumeController.postDismiss(AudioService.java:6068)
01-03 18:25:30.667 W/VolumeController( 1576): at android.media.AudioService.setVolumeController(AudioService.java:5918)
01-03 18:25:30.667 W/VolumeController( 1576): at android.media.AudioService$3.binderDied(AudioService.java:5927)
01-03 18:25:30.667 W/VolumeController( 1576): at android.os.BinderProxy.sendDeathNotice(Binder.java:551)
01-03 18:25:30.669 D/ConnectivityService( 1576): ConnectivityService NetworkRequestInfo binderDied(NetworkRequest [ id=2, legacyType=-1, [] ], android.os.BinderProxy@1e321b7a)
01-03 18:25:30.669 D/WifiService( 1576): Client connection lost with reason: 4
01-03 18:25:30.670 D/ConnectivityService( 1576): releasing NetworkRequest NetworkRequest [ id=2, legacyType=-1, [] ]
01-03 18:25:30.671 E/ConnectivityService( 1576): RemoteException caught trying to send a callback msg for NetworkRequest [ id=2, legacyType=-1, [] ]
01-03 18:25:30.673 I/WindowState( 1576): WIN DEATH: Window{1ade3c75 u0 SearchPanel}
01-03 18:25:30.674 W/InputDispatcher( 1576): Attempted to unregister already unregistered input channel '1ade3c75 SearchPanel (server)'
01-03 18:25:30.675 E/Lights ( 1576): write_int failed to open sys/class/leds/rk29_key_led/brightness
01-03 18:25:30.680 I/WindowState( 1576): WIN DEATH: Window{150eebc9 u0 com.android.systemui.ImageWallpaper}
01-03 18:25:30.681 W/InputDispatcher( 1576): Attempted to unregister already unregistered input channel '150eebc9 com.android.systemui.ImageWallpaper (server)'
01-03 18:25:30.681 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:30.684 I/WindowState( 1576): WIN DEATH: Window{255493dc u0 Heads Up}
01-03 18:25:30.684 W/InputDispatcher( 1576): Attempted to unregister already unregistered input channel '255493dc Heads Up (server)'
01-03 18:25:30.687 I/WindowState( 1576): WIN DEATH: Window{1fabd298 u0 NavigationBar}
01-03 18:25:30.687 W/InputDispatcher( 1576): Attempted to unregister already unregistered input channel '1fabd298 NavigationBar (server)'
01-03 18:25:30.700 W/InputMethodManagerService( 1576): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@4367546 attribute=null, token = android.os.BinderProxy@9ace1bb
01-03 18:25:30.720 W/libprocessgroup( 1576): failed to open /acct/uid_10013/pid_1706/cgroup.procs: No such file or directory
01-03 18:25:30.721 I/ActivityManager( 1576): Process com.android.systemui (pid 1706) has died
01-03 18:25:30.722 W/ActivityManager( 1576): Scheduling restart of crashed service com.android.systemui/.SystemUIService in 0ms
01-03 18:25:30.723 W/ActivityManager( 1576): Scheduling restart of crashed service com.android.systemui/.ImageWallpaper in 0ms
01-03 18:25:30.723 W/ActivityManager( 1576): Scheduling restart of crashed service com.android.systemui/.keyguard.KeyguardService in 0ms
01-03 18:25:30.782 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:30.807 I/ActivityManager( 1576): Start proc 3417:com.android.systemui/u0a13 for restart com.android.systemui
01-03 18:25:30.812 W/art ( 1576): Long monitor contention event with owner method=void com.android.server.am.ActivityManagerService.appNotResponding(com.android.server.am.ProcessRecord, com.android.server.am.ActivityRecord, com.android.server.am.ActivityRecord, boolean, java.lang.String) from ActivityManagerService.java:5206 waiters=1 for 144ms
01-03 18:25:30.813 W/WallpaperManagerService( 1576): Wallpaper service gone: ComponentInfo{com.android.systemui/com.android.systemui.ImageWallpaper}
01-03 18:25:30.815 W/BroadcastQueue( 1576): Failure sending broadcast Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x14000010 (has extras) }
01-03 18:25:30.815 W/BroadcastQueue( 1576): android.os.RemoteException: app.thread must not be null
01-03 18:25:30.815 W/BroadcastQueue( 1576): at com.android.server.am.BroadcastQueue.performReceiveLocked(BroadcastQueue.java:437)
01-03 18:25:30.815 W/BroadcastQueue( 1576): at com.android.server.am.BroadcastQueue.deliverToRegisteredReceiverLocked(BroadcastQueue.java:523)
01-03 18:25:30.815 W/BroadcastQueue( 1576): at com.android.server.am.BroadcastQueue.processNextBroadcast(BroadcastQueue.java:576)
01-03 18:25:30.815 W/BroadcastQueue( 1576): at com.android.server.am.BroadcastQueue$BroadcastHandler.handleMessage(BroadcastQueue.java:156)
01-03 18:25:30.815 W/BroadcastQueue( 1576): at android.os.Handler.dispatchMessage(Handler.java:102)
01-03 18:25:30.815 W/BroadcastQueue( 1576): at android.os.Looper.loop(Looper.java:135)
01-03 18:25:30.815 W/BroadcastQueue( 1576): at android.os.HandlerThread.run(HandlerThread.java:61)
01-03 18:25:30.815 W/BroadcastQueue( 1576): at com.android.server.ServiceThread.run(ServiceThread.java:46)
01-03 18:25:30.816 W/BroadcastQueue( 1576): Failure sending broadcast Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x14000010 (has extras) }
01-03 18:25:30.816 W/BroadcastQueue( 1576): android.os.RemoteException: app.thread must not be null
01-03 18:25:30.816 W/BroadcastQueue( 1576): at com.android.server.am.BroadcastQueue.performReceiveLocked(BroadcastQueue.java:437)
01-03 18:25:30.816 W/BroadcastQueue( 1576): at com.android.server.am.BroadcastQueue.deliverToRegisteredReceiverLocked(BroadcastQueue.java:523)
01-03 18:25:30.816 W/BroadcastQueue( 1576): at com.android.server.am.BroadcastQueue.processNextBroadcast(BroadcastQueue.java:576)
01-03 18:25:30.816 W/BroadcastQueue( 1576): at com.android.server.am.BroadcastQueue$BroadcastHandler.handleMessage(BroadcastQueue.java:156)
01-03 18:25:30.816 W/BroadcastQueue( 1576): at android.os.Handler.dispatchMessage(Handler.java:102)
01-03 18:25:30.816 W/BroadcastQueue( 1576): at android.os.Looper.loop(Looper.java:135)
01-03 18:25:30.816 W/BroadcastQueue( 1576): at android.os.HandlerThread.run(HandlerThread.java:61)
01-03 18:25:30.816 W/BroadcastQueue( 1576): at com.android.server.ServiceThread.run(ServiceThread.java:46)
01-03 18:25:30.883 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:30.957 V/SystemUIService( 3417): Starting SystemUI services.
01-03 18:25:30.975 W/ContextImpl( 2411): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1721 android.content.ContextWrapper.startService:522 android.content.ContextWrapper.startService:522 com.android.settings.bluetooth.DockEventReceiver.beginStartingService:134 com.android.settings.bluetooth.DockEventReceiver.onReceive:115
01-03 18:25:30.984 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:31.031 D/DockEventReceiver( 2411): finishStartingService: stopping service
01-03 18:25:31.035 D/Index ( 2411): Deleting data for locale 'de_DE' took 7 millis
01-03 18:25:31.036 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:25:31.044 D/Index ( 2411): Indexing locale 'de_DE' took 8 millis
01-03 18:25:31.045 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:25:31.053 D/TrustManagerService( 1576): Removing dead TrustListener.
01-03 18:25:31.061 D/AuthorizationBluetoothService( 2126): Received Bluetooth event: Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x14000010 cmp=com.google.android.gms/.auth.be.proximity.authorization.bt.AuthorizationBluetoothService$BluetoothStateChangeReceiver (has extras) }.
01-03 18:25:31.086 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:31.088 E/BTEventHandler( 2680): A4WP is not supported
01-03 18:25:31.120 D/NuPlayerDriver( 1321): start(0x41473dc0)
01-03 18:25:31.120 I/GenericSource( 1321): start
01-03 18:25:31.122 W/Utils ( 1321): bool android::canOffloadStream(const android::sp&, bool, const android::sp&, bool, audio_stream_type_t) No sample bit depth info in meta data
01-03 18:25:31.122 E/AudioPolicyManager( 1321): isOffloadSupported: stream_type != MUSIC, returning false
01-03 18:25:31.122 I/NuPlayer( 1321): Could not offload audio decode, pcm offload decided :0
01-03 18:25:31.123 W/Utils ( 1321): bool android::canOffloadStream(const android::sp&, bool, const android::sp&, bool, audio_stream_type_t) No sample bit depth info in meta data
01-03 18:25:31.124 E/AudioPolicyManager( 1321): isOffloadSupported: stream_type != MUSIC, returning false
01-03 18:25:31.176 D/NuPlayerDriver( 1321): reset(0x41473dc0)
01-03 18:25:31.186 D/NuPlayerDriver( 1321): notifyResetComplete(0x41473dc0)
01-03 18:25:31.187 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:31.210 D/NuPlayerDriver( 1321): start(0x41473e80)
01-03 18:25:31.210 I/GenericSource( 1321): start
01-03 18:25:31.213 W/Utils ( 1321): bool android::canOffloadStream(const android::sp&, bool, const android::sp&, bool, audio_stream_type_t) No sample bit depth info in meta data
01-03 18:25:31.214 E/AudioPolicyManager( 1321): isOffloadSupported: stream_type != MUSIC, returning false
01-03 18:25:31.214 I/NuPlayer( 1321): Could not offload audio decode, pcm offload decided :0
01-03 18:25:31.217 W/Utils ( 1321): bool android::canOffloadStream(const android::sp&, bool, const android::sp&, bool, audio_stream_type_t) No sample bit depth info in meta data
01-03 18:25:31.217 E/AudioPolicyManager( 1321): isOffloadSupported: stream_type != MUSIC, returning false
01-03 18:25:31.255 D/NuPlayerDriver( 1321): reset(0x41473e80)
01-03 18:25:31.259 D/NuPlayerDriver( 1321): notifyResetComplete(0x41473e80)
01-03 18:25:31.285 D/NuPlayerDriver( 1321): start(0x41c311c0)
01-03 18:25:31.285 I/GenericSource( 1321): start
01-03 18:25:31.286 W/Utils ( 1321): bool android::canOffloadStream(const android::sp&, bool, const android::sp&, bool, audio_stream_type_t) No sample bit depth info in meta data
01-03 18:25:31.286 E/AudioPolicyManager( 1321): isOffloadSupported: stream_type != MUSIC, returning false
01-03 18:25:31.286 I/NuPlayer( 1321): Could not offload audio decode, pcm offload decided :0
01-03 18:25:31.288 W/Utils ( 1321): bool android::canOffloadStream(const android::sp&, bool, const android::sp&, bool, audio_stream_type_t) No sample bit depth info in meta data
01-03 18:25:31.288 E/AudioPolicyManager( 1321): isOffloadSupported: stream_type != MUSIC, returning false
01-03 18:25:31.288 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:31.310 D/NuPlayerDriver( 1321): reset(0x41c311c0)
01-03 18:25:31.315 D/NuPlayerDriver( 1321): notifyResetComplete(0x41c311c0)
01-03 18:25:31.377 W/ResourceType( 3417): No package identifier when getting value for resource number 0x00000000
01-03 18:25:31.377 W/PackageManager( 3417): Failure retrieving resources for com.android.browser: Resource ID #0x0
01-03 18:25:31.390 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:31.476 W/ResourceType( 3417): No package identifier when getting value for resource number 0x00000000
01-03 18:25:31.476 W/PackageManager( 3417): Failure retrieving resources for com.cyanogenmod.filemanager: Resource ID #0x0
01-03 18:25:31.491 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:31.570 W/ResourceType( 3417): No package identifier when getting value for resource number 0x00000000
01-03 18:25:31.570 W/PackageManager( 3417): Failure retrieving resources for com.android.contacts: Resource ID #0x0
01-03 18:25:31.591 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:31.618 W/ResourceType( 3417): No package identifier when getting value for resource number 0x00000000
01-03 18:25:31.618 W/PackageManager( 3417): Failure retrieving resources for com.android.terminal: Resource ID #0x0
01-03 18:25:31.666 W/ResourceType( 3417): No package identifier when getting value for resource number 0x00000000
01-03 18:25:31.666 W/PackageManager( 3417): Failure retrieving resources for org.riceknight.gs2reboot: Resource ID #0x0
01-03 18:25:31.691 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:31.712 I/auditd ( 3463): Starting up
01-03 18:25:31.713 E/auditd ( 3463): Failed on audit_set_pid with error: Protocol not supported
01-03 18:25:31.713 I/auditd ( 3463): Exiting
01-03 18:25:31.719 W/ResourceType( 3417): No package identifier when getting value for resource number 0x00000000
01-03 18:25:31.719 W/PackageManager( 3417): Failure retrieving resources for com.android.settings: Resource ID #0x0
01-03 18:25:31.792 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:31.892 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:31.992 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:32.022 I/WindowManager( 1576): Screenshot max retries 4 of Token{1b8dc7bc ActivityRecord{209d07af u0 com.android.settings/.SubSettings t19}} appWin=Window{1d0546d8 u0 com.android.settings/com.android.settings.SubSettings} drawState=4
01-03 18:25:32.058 I/ActivityManager( 1576): Killing 2921:com.android.managedprovisioning/u0a9 (adj 15): empty #17
01-03 18:25:32.093 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:32.123 D/VolumeUI( 3417): Registering volume controller
01-03 18:25:32.149 V/KeyguardServiceDelegate( 1576): *** Keyguard connected (yay!)
01-03 18:25:32.159 W/Settings( 3417): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
01-03 18:25:32.177 I/StatusBarManagerService( 1576): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@1ebec4f5
01-03 18:25:32.193 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:32.294 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:32.307 W/Settings( 3417): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
01-03 18:25:32.310 W/Settings( 3417): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
01-03 18:25:32.315 W/ResourcesManager( 3417): Asset path '/system/framework/com.google.android.camera2.jar' does not exist or contains no resources.
01-03 18:25:32.394 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:32.398 D/BluetoothManagerService( 1576): Message: 42
01-03 18:25:32.398 D/BluetoothManagerService( 1576): MESSAGE_RESTART_BLUETOOTH_SERVICE: Restart IBluetooth service
01-03 18:25:32.400 D/BluetoothAdapterState( 2680): make
01-03 18:25:32.405 I/bluedroid( 2680): init
01-03 18:25:32.405 I/BluetoothAdapterState( 2680): Entering OffState
01-03 18:25:32.406 I/bte_conf( 2680): bte_load_conf attempt to load stack conf from /etc/bluetooth/bt_stack.conf
01-03 18:25:32.406 I/bte_conf( 2680): bte_load_ble_conf attempt to load ble stack conf from /etc/bluetooth/ble_stack.conf
01-03 18:25:32.406 E/bt_osi_config( 2680): config_new unable to open file '/etc/bluetooth/ble_stack.conf': No such file or directory
01-03 18:25:32.406 I/bte_conf( 2680): bte_load_ble_conf file >/etc/bluetooth/ble_stack.conf< not found
01-03 18:25:32.406 I/bluedroid( 2680): get_profile_interface socket
01-03 18:25:32.406 I/bluedroid( 2680): get_profile_interface map_client
01-03 18:25:32.406 I/GKI_LINUX( 2680): gki_task_entry task_id=1 [BTIF] starting
01-03 18:25:32.407 D/BluetoothAdapterProperties( 2680): Address is:22:22:DE:59:9F:D7
01-03 18:25:32.408 D/BluetoothAdapterProperties( 2680): Name is: Rockchip
01-03 18:25:32.408 D/BluetoothManagerService( 1576): Bluetooth Adapter name changed to Rockchip
01-03 18:25:32.408 D/BluetoothManagerService( 1576): Stored Bluetooth name: Rockchip
01-03 18:25:32.408 D/BluetoothManagerService( 1576): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
01-03 18:25:32.409 D/BluetoothManagerService( 1576): Message: 40
01-03 18:25:32.409 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
01-03 18:25:32.409 I/bluedroid( 2680): config_hci_snoop_log
01-03 18:25:32.410 D/BluetoothManagerService( 1576): Calling onBluetoothServiceUp callbacks
01-03 18:25:32.410 D/BluetoothManagerService( 1576): Broadcasting onBluetoothServiceUp() to 5 receivers.
01-03 18:25:32.411 D/BluetoothAdapterState( 2680): CURRENT_STATE=OFF, MESSAGE = USER_TURN_ON
01-03 18:25:32.411 D/BluetoothAdapterProperties( 2680): Setting state to 11
01-03 18:25:32.411 I/BluetoothAdapterState( 2680): Bluetooth adapter state changed: 10-> 11
01-03 18:25:32.412 D/BluetoothManagerService( 1576): Message: 60
01-03 18:25:32.412 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 10, newState=11
01-03 18:25:32.412 D/BluetoothManagerService( 1576): Bluetooth State Change Intent: 10 -> 11
01-03 18:25:32.415 D/BluetoothBondStateMachine( 2680): make
01-03 18:25:32.419 D/BluetoothAdapterService( 2680): checkA2dpState: isA2dpSinkEnabled = false
01-03 18:25:32.419 E/BluetoothAdapterService( 2680): checkA2dpState: returning
01-03 18:25:32.419 D/BluetoothAdapterService( 2680): checkHidState: isHidDev = false
01-03 18:25:32.419 E/BluetoothAdapterService( 2680): checkHidState: returning
01-03 18:25:32.419 D/BluetoothAdapterService( 2680): checkHfpState: isHfpClientEnabled = false
01-03 18:25:32.419 E/BluetoothAdapterService( 2680): checkHfpState: returning
01-03 18:25:32.420 I/BluetoothBondStateMachine( 2680): StableState(): Entering Off State
01-03 18:25:32.421 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@22b87957
01-03 18:25:32.422 D/HeadsetService( 2680): Received start request. Starting profile...
01-03 18:25:32.422 D/HeadsetStateMachine( 2680): make
01-03 18:25:32.432 D/HeadsetStateMachine( 2680): max_hf_connections = 1
01-03 18:25:32.432 I/bluedroid( 2680): get_profile_interface handsfree
01-03 18:25:32.437 D/AuthorizationBluetoothService( 2126): Received Bluetooth event: Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x14000010 cmp=com.google.android.gms/.auth.be.proximity.authorization.bt.AuthorizationBluetoothService$BluetoothStateChangeReceiver (has extras) }.
01-03 18:25:32.439 D/HeadsetStateMachine( 2680): Enter Disconnected: -2, size: 0
01-03 18:25:32.444 I/BluetoothAdapterService( 2680): skipping com.android.bluetooth.hid.HidDevService (disabled)
01-03 18:25:32.444 I/BluetoothAdapterState( 2680): Entering PendingCommandState State: isTurningOn()=true, isTurningOff()=false
01-03 18:25:32.445 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@22b87957
01-03 18:25:32.445 D/A2dpService( 2680): Received start request. Starting profile...
01-03 18:25:32.445 I/bluedroid( 2680): get_profile_interface avrcp
01-03 18:25:32.449 V/AudioService( 1576): updateRemoteControllerOnExistingMediaPlayers: size of Player list: 0
01-03 18:25:32.449 E/AudioService( 1576): No RCC entry present to update
01-03 18:25:32.449 E/RemoteController( 2680): Cannot set synchronization mode on an unregistered RemoteController
01-03 18:25:32.449 D/A2dpStateMachine( 2680): make
01-03 18:25:32.450 I/bluedroid( 2680): get_profile_interface a2dp
01-03 18:25:32.450 I/GKI_LINUX( 2680): gki_task_entry task_id=2 [A2DP-MEDIA] starting
01-03 18:25:32.451 D/bt-btif ( 2680): btif_av_state_idle_handler event:BTIF_SM_ENTER_EVT flags 0
01-03 18:25:32.451 D/A2dpService( 2680): setA2dpService(): set to: null
01-03 18:25:32.451 D/A2dpStateMachine( 2680): Enter Disconnected: -2
01-03 18:25:32.451 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@22b87957
01-03 18:25:32.452 D/HidService( 2680): Received start request. Starting profile...
01-03 18:25:32.452 I/bluedroid( 2680): get_profile_interface hidhost
01-03 18:25:32.452 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@22b87957
01-03 18:25:32.452 D/HealthService( 2680): Received start request. Starting profile...
01-03 18:25:32.453 I/bluedroid( 2680): get_profile_interface health
01-03 18:25:32.456 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@22b87957
01-03 18:25:32.456 D/PanService( 2680): Received start request. Starting profile...
01-03 18:25:32.456 D/BluetoothPanServiceJni( 2680): initializeNative(L110): pan
01-03 18:25:32.456 I/bluedroid( 2680): get_profile_interface pan
01-03 18:25:32.457 I/Telecom ( 1576): BluetoothPhoneService: queryPhoneState
01-03 18:25:32.457 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@22b87957
01-03 18:25:32.458 D/BtGatt.DebugUtils( 2680): handleDebugAction() action=null
01-03 18:25:32.458 D/BtGatt.GattService( 2680): Received start request. Starting profile...
01-03 18:25:32.458 D/BtGatt.GattService( 2680): start()
01-03 18:25:32.458 I/bluedroid( 2680): get_profile_interface gatt
01-03 18:25:32.458 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@22b87957
01-03 18:25:32.458 D/BtGatt.AdvertiseManager( 2680): advertise manager created
01-03 18:25:32.462 D/BluetoothMapService( 2680): inside BluetoothMapObexConnection
01-03 18:25:32.462 D/BluetoothMapService( 2680): supportedMessageTypes 14
01-03 18:25:32.462 D/BluetoothMapService( 2680): masId 0
01-03 18:25:32.462 D/BluetoothMapService( 2680): masId 1
01-03 18:25:32.462 D/BluetoothMapService( 2680): Inside initBinder
01-03 18:25:32.462 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@22b87957
01-03 18:25:32.462 D/BluetoothMapService( 2680): Received start request. Starting profile...
01-03 18:25:32.463 D/BluetoothMapService( 2680): start()
01-03 18:25:32.464 D/BluetoothMapService( 2680): Registering observer
01-03 18:25:32.465 D/HeadsetStateMachine( 2680): Disconnected process message: 10, size: 0
01-03 18:25:32.465 D/HeadsetPhoneState( 2680): sendDeviceStateChanged. mService=0 mSignal=0 mRoam=0 mBatteryCharge=3
01-03 18:25:32.465 D/HeadsetStateMachine( 2680): Disconnected process message: 11, size: 0
01-03 18:25:32.465 E/BTEventHandler( 2680): A4WP is not supported
01-03 18:25:32.465 V/BluetoothMapService( 2680): Handler(): got msg=1
01-03 18:25:32.466 D/BluetoothAdapterState( 2680): CURRENT_STATE=PENDING, MESSAGE = STARTED, isTurningOn=true, isTurningOff=false
01-03 18:25:32.466 I/bluedroid( 2680): enable
01-03 18:25:32.466 I/bt_hci_bdroid( 2680): init
01-03 18:25:32.466 I/GKI_LINUX( 2680): gki_task_entry task_id=0 [BTU] starting
01-03 18:25:32.466 I/bt-btu ( 2680): btu_task pending for preload complete event
01-03 18:25:32.466 I/bt_vendor( 2680): init
01-03 18:25:32.466 D/bt_userial( 2680): userial_init
01-03 18:25:32.467 I/bt_vendor( 2680): userial vendor open: opening /dev/rtk_btusb
01-03 18:25:32.467 E/bt_vendor( 2680): userial vendor open: unable to open /dev/rtk_btusb: Permission denied
01-03 18:25:32.467 E/bt_userial( 2680): userial_open opened wrong number of ports: got 0, expected 1.
01-03 18:25:32.467 I/bt-btu ( 2680): btu_task received preload complete event
01-03 18:25:32.467 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x0001
01-03 18:25:32.467 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x001f
01-03 18:25:32.468 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x0003
01-03 18:25:32.468 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x1487
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_HCI
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_L2CAP
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_RFCOMM
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_AVDT
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_AVRC
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_A2D
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_BNEP
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTM
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_HID_HOST
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_GAP
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_PAN
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_SDP
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_GATT
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_SMP
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_HID_DEV
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTAPP
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTIF
01-03 18:25:32.470 I/ ( 2680): BTE_InitTraceLevels -- TRC_LATENCY_AUDIO
01-03 18:25:32.471 E/bt_userial( 2680): userial_write error writing to serial port: Bad file number
01-03 18:25:32.494 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:32.508 W/Settings( 3417): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
01-03 18:25:32.522 D/WifiService( 1576): New client listening to asynchronous messages
01-03 18:25:32.526 D/BluetoothManagerService( 1576): Message: 20
01-03 18:25:32.527 D/BluetoothManagerService( 1576): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@1bb476a8:true
01-03 18:25:32.536 D/BluetoothManagerService( 1576): Message: 30
01-03 18:25:32.540 D/BluetoothManagerService( 1576): Message: 30
01-03 18:25:32.541 E/BluetoothA2dpSink( 3417): Could not bind to Bluetooth A2DP Service with Intent { act=android.bluetooth.IBluetoothA2dpSink }
01-03 18:25:32.542 D/BluetoothManagerService( 1576): Message: 30
01-03 18:25:32.542 E/BluetoothAvrcpController( 3417): Could not bind to Bluetooth AVRCP Controller Service with Intent { act=android.bluetooth.IBluetoothAvrcpController }
01-03 18:25:32.544 D/BluetoothManagerService( 1576): Message: 30
01-03 18:25:32.545 D/BluetoothManagerService( 1576): Creating new ProfileServiceConnections object for profile: 1
01-03 18:25:32.548 D/BluetoothManagerService( 1576): Message: 30
01-03 18:25:32.549 E/BluetoothHeadsetClient( 3417): Could not bind to Bluetooth Headset Client Service with Intent { act=android.bluetooth.IBluetoothHeadsetClient }
01-03 18:25:32.550 D/BluetoothManagerService( 1576): Message: 30
01-03 18:25:32.553 D/BluetoothMap( 3417): Create BluetoothMap proxy object
01-03 18:25:32.553 D/BluetoothManagerService( 1576): Message: 30
01-03 18:25:32.556 D/BluetoothManagerService( 1576): Message: 30
01-03 18:25:32.561 D/ConnectivityService( 1576): listenForNetwork for NetworkRequest [ id=3, legacyType=-1, [] ]
01-03 18:25:32.595 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:32.600 D/WeatherUpdateService( 2363): Service started, but shouldn't update ... stopping
01-03 18:25:32.610 I/CameraManagerGlobal( 3417): getCameraService: Reconnecting to camera service
01-03 18:25:32.614 I/CameraService( 1321): getCameraCharacteristics: Switching to HAL1 shim implementation...
01-03 18:25:32.614 D/CameraHal_Module( 1321): camera_get_camera_info(782): camera_0 facing(0), orientation(90)
01-03 18:25:32.614 D/CameraHal_Module( 1321): camera_get_camera_info(782): camera_1 facing(1), orientation(270)
01-03 18:25:32.615 D/CameraHal_Module( 1321): camera_get_camera_info(782): camera_0 facing(0), orientation(90)
01-03 18:25:32.646 D/BluetoothManagerService( 1576): Message: 400
01-03 18:25:32.647 D/BluetoothHeadset( 3417): Proxy object connected
01-03 18:25:32.671 W/CustomTileListenerService[]( 3417): CustomTile listener service not yet bound.
01-03 18:25:32.689 D/OpenGLRenderer( 3417): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
01-03 18:25:32.691 D/Atlas ( 3417): Validating map...
01-03 18:25:32.695 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:32.695 D/PhoneStatusBar( 3417): disable: < EXPAND* icons alerts system_info BACK* HOME* RECENT* clock SEARCH* >
01-03 18:25:32.796 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:32.847 D/PhoneStatusBar( 3417): heads up is enabled
01-03 18:25:32.854 W/ContentService( 1576): Observer android.database.IContentObserver$Stub$Proxy@213d3e6b is already registered.
01-03 18:25:32.854 W/ContentService( 1576): Observer android.database.IContentObserver$Stub$Proxy@1da5dc8 is already registered.
01-03 18:25:32.857 I/Choreographer( 3417): Skipped 40 frames! The application may be doing too much work on its main thread.
01-03 18:25:32.862 D/ViewRootImpl( 3417): changeCanvasOpacity: opaque=true
01-03 18:25:32.868 W/Settings( 3417): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
01-03 18:25:32.871 W/Settings( 3417): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
01-03 18:25:32.872 W/Settings( 3417): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
01-03 18:25:32.873 W/ContentService( 1576): Observer android.database.IContentObserver$Stub$Proxy@3984b6a is already registered.
01-03 18:25:32.875 W/ContentService( 1576): Observer android.database.IContentObserver$Stub$Proxy@3167b436 is already registered.
01-03 18:25:32.875 W/Settings( 3417): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
01-03 18:25:32.879 W/Settings( 3417): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
01-03 18:25:32.895 W/ContentService( 1576): Observer android.database.IContentObserver$Stub$Proxy@3cdcd11f is already registered.
01-03 18:25:32.896 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:32.897 W/ContentService( 1576): Observer android.database.IContentObserver$Stub$Proxy@2587603b is already registered.
01-03 18:25:32.921 I/OpenGLRenderer( 3417): Initialized EGL, version 1.4
01-03 18:25:32.923 D/OpenGLRenderer( 3417): Enabling debug mode 0
01-03 18:25:32.997 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:33.098 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:33.198 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:33.299 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:33.400 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:33.501 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:33.602 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:33.602 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:25:33.604 E/WifiStateMachine( 1576): Failed to setup control channel, restart supplicant
01-03 18:25:33.604 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:25:33.638 I/PowerManagerService( 1576): Going to sleep due to power button (uid 1000)...
01-03 18:25:34.221 D/PhoneStatusBar( 3417): disable: < EXPAND ICONS* alerts SYSTEM_INFO* BACK HOME RECENT clock SEARCH >
01-03 18:25:34.231 W/ContentService( 1576): Observer android.database.IContentObserver$Stub$Proxy@bbecf34 is already registered.
01-03 18:25:34.232 W/ContentService( 1576): Observer android.database.IContentObserver$Stub$Proxy@1998415d is already registered.
01-03 18:25:34.242 W/Settings( 3417): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
01-03 18:25:34.250 W/Settings( 3417): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
01-03 18:25:34.252 D/PhoneStatusBar( 3417): disable: < EXPAND ICONS alerts SYSTEM_INFO BACK HOME RECENT clock SEARCH >
01-03 18:25:34.263 D/BluetoothA2dp( 3417): Proxy object connected
01-03 18:25:34.264 D/BluetoothInputDevice( 3417): Proxy object connected
01-03 18:25:34.265 D/BluetoothMap( 3417): Proxy object connected
01-03 18:25:34.266 D/BluetoothPan( 3417): BluetoothPAN Proxy object connected
01-03 18:25:34.270 D/WifiService( 1576): New client listening to asynchronous messages
01-03 18:25:34.370 D/PhoneStatusBarPolicy( 3417): updateSimState for subId :2147483643
01-03 18:25:34.370 D/PhoneStatusBarPolicy( 3417): updateSimState for phoneId :0
01-03 18:25:34.371 D/PhoneStatusBarPolicy( 3417): updateSimState for Slot :0
01-03 18:25:34.372 I/Choreographer( 3417): Skipped 84 frames! The application may be doing too much work on its main thread.
01-03 18:25:34.402 E/Lights ( 1576): write_int failed to open sys/class/leds/rk29_key_led/brightness
01-03 18:25:34.447 D/SurfaceFlinger( 1318): Set power mode=0, type=0 flinger=0x40c82000
01-03 18:25:34.448 I/DisplayManagerService( 1576): Display device changed: DisplayDeviceInfo{"Integrierter Bildschirm": uniqueId="local:0", 1536 x 2048, 56.097 fps, supportedRefreshRates [56.097], density 280, 288.99554 x 240.82962 dpi, appVsyncOff 0, presDeadline 18826265, touch INTERNAL, rotation 0, type BUILT_IN, state OFF, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
01-03 18:25:34.457 I/DreamManagerService( 1576): Entering dreamland.
01-03 18:25:34.458 I/PowerManagerService( 1576): Dozing...
01-03 18:25:34.554 D/OpenGLRenderer( 3417): setting property extraRasterBucket to 0.95
01-03 18:25:34.554 D/OpenGLRenderer( 3417): failed
01-03 18:25:34.554 D/OpenGLRenderer( 3417): setting property extraRasterBucket to 0.0
01-03 18:25:34.767 I/WindowManager( 1576): Screenshot max retries 4 of Token{1b8dc7bc ActivityRecord{209d07af u0 com.android.settings/.SubSettings t19}} appWin=Window{1d0546d8 u0 com.android.settings/com.android.settings.SubSettings} drawState=4
01-03 18:25:34.771 W/art ( 1576): Long monitor contention event with owner method=void com.android.server.am.ActivityManagerService.onWakefulnessChanged(int) from ActivityManagerService.java:10237 waiters=0 for 313ms
01-03 18:25:34.773 I/DreamController( 1576): Starting dream: name=ComponentInfo{com.android.systemui/com.android.systemui.doze.DozeService}, isTest=false, canDoze=true, userId=0
01-03 18:25:34.795 V/ActivityManager( 1576): Display changed displayId=0
01-03 18:25:34.807 V/KeyguardServiceDelegate( 1576): **** SHOWN CALLED ****
01-03 18:25:34.924 D/PhoneStatusBar( 3417): disable: < expand* ICONS alerts SYSTEM_INFO back* HOME RECENT clock SEARCH >
01-03 18:25:34.966 D/PhoneStatusBar( 3417): disable: < expand ICONS alerts SYSTEM_INFO back HOME RECENT clock SEARCH >
01-03 18:25:35.075 W/Settings( 3417): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
01-03 18:25:35.085 I/WifiNative-HAL( 1576): startHal
01-03 18:25:35.085 E/wifi ( 1576): getStaticLongField sWifiHalHandle 0x6e99185c
01-03 18:25:35.085 I/WifiHAL ( 1576): Initializing wifi
01-03 18:25:35.085 I/WifiHAL ( 1576): Creating socket
01-03 18:25:35.086 E/WifiHAL ( 1576): Could not find group vendor
01-03 18:25:35.088 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:25:35.088 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:25:35.871 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:25:35.871 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:25:35.874 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:25:36.095 I/auditd ( 3518): Starting up
01-03 18:25:36.095 E/auditd ( 3518): Failed on audit_set_pid with error: Protocol not supported
01-03 18:25:36.095 I/auditd ( 3518): Exiting
01-03 18:25:36.177 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:25:37.191 I/PowerManagerService( 1576): Waking up from dozing (uid 1000)...
01-03 18:25:37.192 E/Lights ( 1576): write_int failed to open sys/class/leds/rk29_key_led/brightness
01-03 18:25:37.192 V/KeyguardServiceDelegate( 1576): onScreenTurnedOn(showListener = com.android.internal.policy.impl.PhoneWindowManager$2@2860f1ef)
01-03 18:25:37.201 I/DisplayPowerController( 1576): Blocking screen on until initial contents have been drawn.
01-03 18:25:37.230 V/KeyguardServiceDelegate( 1576): **** SHOWN CALLED ****
01-03 18:25:37.269 D/SurfaceFlinger( 1318): Set power mode=2, type=0 flinger=0x40c82000
01-03 18:25:37.272 I/DisplayManagerService( 1576): Display device changed: DisplayDeviceInfo{"Integrierter Bildschirm": uniqueId="local:0", 1536 x 2048, 56.097 fps, supportedRefreshRates [56.097], density 280, 288.99554 x 240.82962 dpi, appVsyncOff 0, presDeadline 18826265, touch INTERNAL, rotation 0, type BUILT_IN, state ON, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
01-03 18:25:37.278 V/ActivityManager( 1576): Display changed displayId=0
01-03 18:25:37.291 I/DisplayPowerController( 1576): Unblocked screen on after 90 ms
01-03 18:25:37.438 E/libEGL ( 1576): call to OpenGL ES API with no current context (logged once per thread)
01-03 18:25:37.446 I/DreamManagerService( 1576): Gently waking up from dream.
01-03 18:25:37.448 I/DreamManagerService( 1576): Leaving dreamland.
01-03 18:25:37.449 I/DreamController( 1576): Stopping dream: name=ComponentInfo{com.android.systemui/com.android.systemui.doze.DozeService}, isTest=false, canDoze=true, userId=0
01-03 18:25:37.575 I/WifiHAL ( 1576): Initialized Wifi HAL Successfully; vendor cmd = 103
01-03 18:25:37.575 D/wifi ( 1576): Did set static halHandle = 0x6844f980
01-03 18:25:37.575 D/wifi ( 1576): halHandle = 0x6844f980, mVM = 0x4249d200, mCls = 0x2018c6
01-03 18:25:37.575 E/wifi ( 1576): getStaticLongField sWifiHalHandle 0x6e99180c
01-03 18:25:37.575 D/wifi ( 1576): array field set
01-03 18:25:37.575 I/WifiNative-HAL( 1576): interface[0] = p2p0
01-03 18:25:37.575 I/WifiNative-HAL( 1576): interface[1] = wlan0
01-03 18:25:37.576 E/wifi ( 1576): android_net_wifi_getLinkLayerStats: failed to get link statistics
01-03 18:25:37.577 I/WifiNative-HAL( 1576): Waiting for HAL events mWifiHalHandle=1749350784
01-03 18:25:37.577 D/wifi ( 1576): waitForHalEvents called, vm = 0x4249d200, obj = 0x2018c6, env = 0x425b9ac0
01-03 18:25:37.577 E/wifi ( 1576): getStaticLongField sWifiHalHandle 0x7f638b3c
01-03 18:25:37.578 E/WifiStateMachine( 1576): cancelDelayedScan -> 1
01-03 18:25:37.581 E/wifi ( 1576): android_net_wifi_getLinkLayerStats: failed to get link statistics
01-03 18:25:37.581 E/WifiStateMachine( 1576): cancelDelayedScan -> 2
01-03 18:25:37.585 E/wifi ( 1576): android_net_wifi_getLinkLayerStats: failed to get link statistics
01-03 18:25:37.586 E/WifiStateMachine( 1576): cancelDelayedScan -> 3
01-03 18:25:37.589 W/SurfaceFlinger( 1318): captureScreen: error creating EGL fence: 0x3004
01-03 18:25:37.591 V/ActivityManager( 1576): Display changed displayId=0
01-03 18:25:37.640 I/ActivityManager( 1576): Config changes=480 {1.0 ?mcc?mnc de_DE ?layoutDir sw768dp w1024dp h695dp 320dpi xlrg land finger -keyb/v/h -nav/h s.5 themeResource=null}
01-03 18:25:37.643 I/InputReader( 1576): Reconfiguring input devices. changes=0x00000004
01-03 18:25:37.643 I/InputReader( 1576): Device reconfigured: id=1, name='ct36x_ts', size 2048x1536, orientation 0, mode 1, display id 0
01-03 18:25:37.750 I/art ( 2411): Explicit concurrent mark sweep GC freed 3897(258KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 4MB/6MB, paused 1.859ms total 58.177ms
01-03 18:25:37.826 I/art ( 2411): Explicit concurrent mark sweep GC freed 11158(852KB) AllocSpace objects, 1(36KB) LOS objects, 40% free, 3MB/5MB, paused 2.682ms total 44.054ms
01-03 18:25:37.867 I/art ( 2411): Explicit concurrent mark sweep GC freed 3(96B) AllocSpace objects, 0(0B) LOS objects, 40% free, 3MB/5MB, paused 2.094ms total 40.462ms
01-03 18:25:38.178 W/ContentService( 1576): Observer android.database.IContentObserver$Stub$Proxy@10af2fe7 is already registered.
01-03 18:25:38.179 W/ContentService( 1576): Observer android.database.IContentObserver$Stub$Proxy@2ed9f794 is already registered.
01-03 18:25:38.181 W/ContentService( 1576): Observer android.database.IContentObserver$Stub$Proxy@2cb5b23d is already registered.
01-03 18:25:38.254 V/WindowManager( 1576): Adding window Window{15346dc4 u0 com.android.settings/com.android.settings.SubSettings} at 2 of 8 (after Window{1e690cd9 u0 com.android.settings/com.android.settings.Settings})
01-03 18:25:38.258 I/Choreographer( 2411): Skipped 32 frames! The application may be doing too much work on its main thread.
01-03 18:25:38.602 I/Timeline( 1576): Timeline: Activity_windows_visible id: ActivityRecord{209d07af u0 com.android.settings/.SubSettings t19} time:194594
01-03 18:25:38.607 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:25:38.607 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:25:38.618 I/PowerManagerService( 1576): Going to sleep due to power button (uid 1000)...
01-03 18:25:38.659 I/Timeline( 2411): Timeline: Activity_idle id: android.os.BinderProxy@1295d420 time:194651
01-03 18:25:39.088 I/Choreographer( 3417): Skipped 63 frames! The application may be doing too much work on its main thread.
01-03 18:25:39.171 I/WindowManager( 1576): Screen frozen for +1s810ms due to Window{18539bb3 u0 com.android.systemui.ImageWallpaper}
01-03 18:25:39.371 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:25:39.371 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:25:39.373 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:25:39.678 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:25:39.679 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:25:39.679 E/SoftapController( 1322): Softap fwReload failed
01-03 18:25:39.679 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '52 softap fwreload wlan0 STA' failed with '400 52 SoftAP command has failed'
01-03 18:25:39.680 D/CommandListener( 1322): Setting iface cfg
01-03 18:25:39.680 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:25:39.681 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:25:39.688 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:25:39.709 I/wpa_supplicant( 3532): Successfully initialized wpa_supplicant
01-03 18:25:39.710 I/wpa_supplicant( 3532): rfkill: Cannot open RFKILL control device
01-03 18:25:39.774 E/Lights ( 1576): write_int failed to open sys/class/leds/rk29_key_led/brightness
01-03 18:25:39.789 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:25:39.908 D/SurfaceFlinger( 1318): Set power mode=0, type=0 flinger=0x40c82000
01-03 18:25:39.908 D/SurfaceControl( 1576): Excessive delay in setPowerMode(): 134ms
01-03 18:25:39.910 I/DisplayManagerService( 1576): Display device changed: DisplayDeviceInfo{"Integrierter Bildschirm": uniqueId="local:0", 1536 x 2048, 56.097 fps, supportedRefreshRates [56.097], density 280, 288.99554 x 240.82962 dpi, appVsyncOff 0, presDeadline 18826265, touch INTERNAL, rotation 0, type BUILT_IN, state OFF, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
01-03 18:25:39.917 I/DreamManagerService( 1576): Entering dreamland.
01-03 18:25:39.917 I/PowerManagerService( 1576): Dozing...
01-03 18:25:39.918 I/DreamController( 1576): Starting dream: name=ComponentInfo{com.android.systemui/com.android.systemui.doze.DozeService}, isTest=false, canDoze=true, userId=0
01-03 18:25:39.921 V/ActivityManager( 1576): Display changed displayId=0
01-03 18:25:39.937 D/PhoneStatusBar( 3417): disable: < expand ICONS alerts SYSTEM_INFO back HOME RECENT clock SEARCH >
01-03 18:25:41.563 I/art ( 1576): Explicit concurrent mark sweep GC freed 14749(918KB) AllocSpace objects, 0(0B) LOS objects, 33% free, 9MB/13MB, paused 2.384ms total 88.648ms
01-03 18:25:41.702 I/auditd ( 3533): Starting up
01-03 18:25:41.702 E/auditd ( 3533): Failed on audit_set_pid with error: Protocol not supported
01-03 18:25:41.702 I/auditd ( 3533): Exiting
01-03 18:25:42.482 I/PowerManagerService( 1576): Waking up from dozing (uid 1000)...
01-03 18:25:42.483 E/Lights ( 1576): write_int failed to open sys/class/leds/rk29_key_led/brightness
01-03 18:25:42.483 V/KeyguardServiceDelegate( 1576): onScreenTurnedOn(showListener = com.android.internal.policy.impl.PhoneWindowManager$2@2860f1ef)
01-03 18:25:42.497 I/DisplayPowerController( 1576): Blocking screen on until initial contents have been drawn.
01-03 18:25:42.531 V/KeyguardServiceDelegate( 1576): **** SHOWN CALLED ****
01-03 18:25:42.566 D/SurfaceFlinger( 1318): Set power mode=2, type=0 flinger=0x40c82000
01-03 18:25:42.567 I/DisplayManagerService( 1576): Display device changed: DisplayDeviceInfo{"Integrierter Bildschirm": uniqueId="local:0", 1536 x 2048, 56.097 fps, supportedRefreshRates [56.097], density 280, 288.99554 x 240.82962 dpi, appVsyncOff 0, presDeadline 18826265, touch INTERNAL, rotation 0, type BUILT_IN, state ON, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
01-03 18:25:42.568 V/ActivityManager( 1576): Display changed displayId=0
01-03 18:25:42.607 I/DisplayPowerController( 1576): Unblocked screen on after 110 ms
01-03 18:25:42.715 I/DreamManagerService( 1576): Gently waking up from dream.
01-03 18:25:42.716 I/DreamManagerService( 1576): Leaving dreamland.
01-03 18:25:42.716 I/DreamController( 1576): Stopping dream: name=ComponentInfo{com.android.systemui/com.android.systemui.doze.DozeService}, isTest=false, canDoze=true, userId=0
01-03 18:25:43.470 E/wpa_supplicant( 3532): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:25:43.470 E/wpa_supplicant( 3532): nl80211: Could not set interface 'wlan0' UP
01-03 18:25:43.471 E/wpa_supplicant( 3532): wlan0: Failed to initialize driver interface
01-03 18:25:44.396 D/PhoneStatusBar( 3417): disable: < expand ICONS alerts SYSTEM_INFO back HOME RECENT clock SEARCH >
01-03 18:25:44.478 D/BluetoothAdapterState( 2680): CURRENT_STATE=PENDING, MESSAGE = ENABLE_TIMEOUT, isTurningOn=true, isTurningOff=false
01-03 18:25:44.478 E/BluetoothAdapterState( 2680): Error enabling Bluetooth
01-03 18:25:44.478 E/bt-btif ( 2680): bte_ssr_cleanup
01-03 18:25:44.478 I/BluetoothServiceJni( 2680): ssrcleanupNative: return from cleanup
01-03 18:25:44.479 D/BluetoothAdapterService( 2680): mProfilesStarted : true supportedProfileServices.length : 8
01-03 18:25:44.483 D/HeadsetService( 2680): Received stop request...Stopping profile...
01-03 18:25:44.486 D/HeadsetStateMachine( 2680): Exit Disconnected: -1
01-03 18:25:44.490 D/BluetoothHeadset( 3417): Proxy object disconnected
01-03 18:25:44.492 D/A2dpService( 2680): Received stop request...Stopping profile...
01-03 18:25:44.492 D/A2dpStateMachine( 2680): Exit Disconnected: -1
01-03 18:25:44.501 D/BluetoothAdapterProperties( 2680): Setting state to 10
01-03 18:25:44.501 I/BluetoothAdapterState( 2680): Bluetooth adapter state changed: 11-> 10
01-03 18:25:44.503 I/BluetoothAdapterState( 2680): Entering OffState
01-03 18:25:44.504 D/BluetoothManagerService( 1576): Message: 60
01-03 18:25:44.504 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 11, newState=10
01-03 18:25:44.504 D/BluetoothManagerService( 1576): Broadcasting onBluetoothStateChange(false) to 17 receivers.
01-03 18:25:44.505 D/HidService( 2680): Received stop request...Stopping profile...
01-03 18:25:44.505 D/BluetoothPan( 2411): onBluetoothStateChange on: false
01-03 18:25:44.506 E/BluetoothPan( 2411):
01-03 18:25:44.506 E/BluetoothPan( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPan$2@14c69600
01-03 18:25:44.506 E/BluetoothPan( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:44.506 E/BluetoothPan( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:44.506 E/BluetoothPan( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:44.506 E/BluetoothPan( 2411): at android.bluetooth.BluetoothPan$1.onBluetoothStateChange(BluetoothPan.java:206)
01-03 18:25:44.506 E/BluetoothPan( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:44.506 E/BluetoothPan( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:44.508 D/BluetoothInputDevice( 3417): onBluetoothStateChange: up=false
01-03 18:25:44.511 D/BluetoothHeadset( 1998): onBluetoothStateChange: up=false
01-03 18:25:44.512 D/BluetoothA2dp( 1576): onBluetoothStateChange: up=false
01-03 18:25:44.513 E/BluetoothA2dp( 1576):
01-03 18:25:44.513 E/BluetoothA2dp( 1576): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dp$2@3214f02c
01-03 18:25:44.513 E/BluetoothA2dp( 1576): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:44.513 E/BluetoothA2dp( 1576): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:44.513 E/BluetoothA2dp( 1576): at android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange(BluetoothA2dp.java:126)
01-03 18:25:44.513 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.sendBluetoothStateCallback(BluetoothManagerService.java:761)
01-03 18:25:44.513 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.bluetoothStateChangeHandler(BluetoothManagerService.java:1507)
01-03 18:25:44.513 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.access$3700(BluetoothManagerService.java:68)
01-03 18:25:44.513 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:1226)
01-03 18:25:44.513 E/BluetoothA2dp( 1576): at android.os.Handler.dispatchMessage(Handler.java:102)
01-03 18:25:44.513 E/BluetoothA2dp( 1576): at android.os.Looper.loop(Looper.java:135)
01-03 18:25:44.513 E/BluetoothA2dp( 1576): at android.os.HandlerThread.run(HandlerThread.java:61)
01-03 18:25:44.513 E/BluetoothA2dp( 1576): at com.android.server.ServiceThread.run(ServiceThread.java:46)
01-03 18:25:44.515 D/BluetoothA2dpSink( 3417): onBluetoothStateChange: up=false
01-03 18:25:44.515 W/BluetoothHeadsetServiceJni( 2680): Cleaning up Bluetooth Handsfree Interface...
01-03 18:25:44.515 W/BluetoothHeadsetServiceJni( 2680): Cleaning up Bluetooth Handsfree callback object
01-03 18:25:44.516 E/BluetoothA2dpSink( 3417):
01-03 18:25:44.516 E/BluetoothA2dpSink( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dpSink$2@3ce366d5
01-03 18:25:44.516 E/BluetoothA2dpSink( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:44.516 E/BluetoothA2dpSink( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:44.516 E/BluetoothA2dpSink( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:44.516 E/BluetoothA2dpSink( 3417): at android.bluetooth.BluetoothA2dpSink$1.onBluetoothStateChange(BluetoothA2dpSink.java:139)
01-03 18:25:44.516 E/BluetoothA2dpSink( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:44.516 E/BluetoothA2dpSink( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:44.517 D/HealthService( 2680): Received stop request...Stopping profile...
01-03 18:25:44.520 E/AudioTrack( 3417): AudioTrack::set : Exit
01-03 18:25:44.520 D/PanService( 2680): Received stop request...Stopping profile...
01-03 18:25:44.522 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:25:44.523 D/BtGatt.DebugUtils( 2680): handleDebugAction() action=null
01-03 18:25:44.523 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:25:44.523 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:25:44.523 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:25:44.524 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:25:44.524 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:25:44.524 D/BtGatt.GattService( 2680): Received stop request...Stopping profile...
01-03 18:25:44.524 D/BtGatt.GattService( 2680): stop()
01-03 18:25:44.524 D/BtGatt.AdvertiseManager( 2680): advertise clients cleared
01-03 18:25:44.524 D/BluetoothAvrcpController( 3417): onBluetoothStateChange: up=false
01-03 18:25:44.526 E/BluetoothAvrcpController( 3417):
01-03 18:25:44.526 E/BluetoothAvrcpController( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothAvrcpController$2@13e5deea
01-03 18:25:44.526 E/BluetoothAvrcpController( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:44.526 E/BluetoothAvrcpController( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:44.526 E/BluetoothAvrcpController( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:44.526 E/BluetoothAvrcpController( 3417): at android.bluetooth.BluetoothAvrcpController$1.onBluetoothStateChange(BluetoothAvrcpController.java:80)
01-03 18:25:44.526 E/BluetoothAvrcpController( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:44.526 E/BluetoothAvrcpController( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:44.528 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:25:44.528 D/PhoneStatusBar( 3417): disable: < expand icons* alerts system_info* back HOME RECENT clock SEARCH >
01-03 18:25:44.529 D/BluetoothMap( 3417): onBluetoothStateChange: up=false
01-03 18:25:44.532 D/BluetoothMapService( 2680): Received stop request...Stopping profile...
01-03 18:25:44.532 D/BluetoothMapService( 2680): stop()
01-03 18:25:44.533 D/BluetoothHeadset( 3417): onBluetoothStateChange: up=false
01-03 18:25:44.533 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:25:44.533 D/BluetoothMapService( 2680): MAP Service closeService in
01-03 18:25:44.533 D/BluetoothMapService( 2680): Unregistering Email account observer
01-03 18:25:44.534 D/BluetoothHeadsetClient( 3417): onBluetoothStateChange: up=false
01-03 18:25:44.535 E/BluetoothHeadsetClient( 3417):
01-03 18:25:44.535 E/BluetoothHeadsetClient( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothHeadsetClient$2@29514878
01-03 18:25:44.535 E/BluetoothHeadsetClient( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:44.535 E/BluetoothHeadsetClient( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:44.535 E/BluetoothHeadsetClient( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:44.535 E/BluetoothHeadsetClient( 3417): at android.bluetooth.BluetoothHeadsetClient$1.onBluetoothStateChange(BluetoothHeadsetClient.java:382)
01-03 18:25:44.535 E/BluetoothHeadsetClient( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:44.535 E/BluetoothHeadsetClient( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:44.537 D/BluetoothInputDevice( 2411): onBluetoothStateChange: up=false
01-03 18:25:44.538 E/BluetoothInputDevice( 2411):
01-03 18:25:44.538 E/BluetoothInputDevice( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothInputDevice$2@2082d483
01-03 18:25:44.538 E/BluetoothInputDevice( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:44.538 E/BluetoothInputDevice( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:44.538 E/BluetoothInputDevice( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:44.538 E/BluetoothInputDevice( 2411): at android.bluetooth.BluetoothInputDevice$1.onBluetoothStateChange(BluetoothInputDevice.java:227)
01-03 18:25:44.538 E/BluetoothInputDevice( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:44.538 E/BluetoothInputDevice( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:44.540 D/BluetoothA2dp( 3417): onBluetoothStateChange: up=false
01-03 18:25:44.540 I/GKI_LINUX( 2680): gki_task task_id=2 [A2DP-MEDIA] terminating
01-03 18:25:44.541 I/GKI_LINUX( 2680): GKI_exit_task 2 done
01-03 18:25:44.541 I/GKI_LINUX( 2680): GKI_shutdown(): task [A2DP-MEDIA] terminated
01-03 18:25:44.543 W/BluetoothHidServiceJni( 2680): Cleaning up Bluetooth HID Interface...
01-03 18:25:44.543 W/bt-btif ( 2680): cleanup: HH disabling or disabled already, status = 0
01-03 18:25:44.543 W/BluetoothHidServiceJni( 2680): Cleaning up Bluetooth GID callback object
01-03 18:25:44.543 D/BluetoothMap( 2411): onBluetoothStateChange: up=false
01-03 18:25:44.544 W/BluetoothHealthServiceJni( 2680): Cleaning up Bluetooth Health Interface...
01-03 18:25:44.544 W/BluetoothHealthServiceJni( 2680): Cleaning up Bluetooth Health object
01-03 18:25:44.544 E/BluetoothMap( 2411):
01-03 18:25:44.544 E/BluetoothMap( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothMap$2@1e420e39
01-03 18:25:44.544 E/BluetoothMap( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:44.544 E/BluetoothMap( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:44.544 E/BluetoothMap( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:44.544 E/BluetoothMap( 2411): at android.bluetooth.BluetoothMap$1.onBluetoothStateChange(BluetoothMap.java:64)
01-03 18:25:44.544 E/BluetoothMap( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:44.544 E/BluetoothMap( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:44.545 W/BluetoothPanServiceJni( 2680): Cleaning up Bluetooth PAN Interface...
01-03 18:25:44.545 W/BluetoothPanServiceJni( 2680): Cleaning up Bluetooth PAN callback object
01-03 18:25:44.547 D/BluetoothPbap( 2411): onBluetoothStateChange: up=false
01-03 18:25:44.548 D/BtGatt.GattService( 2680): cleanup()
01-03 18:25:44.548 W/bt-btif ( 2680): GATTC Module not enabled/already disabled
01-03 18:25:44.548 W/bt-btif ( 2680): GATTS Module not enabled/already disabled
01-03 18:25:44.549 E/BluetoothPbap( 2411):
01-03 18:25:44.549 E/BluetoothPbap( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPbap$2@3b8b9c7e
01-03 18:25:44.549 E/BluetoothPbap( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:25:44.549 E/BluetoothPbap( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:25:44.549 E/BluetoothPbap( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:25:44.549 E/BluetoothPbap( 2411): at android.bluetooth.BluetoothPbap$1.onBluetoothStateChange(BluetoothPbap.java:121)
01-03 18:25:44.549 E/BluetoothPbap( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:25:44.549 E/BluetoothPbap( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:25:44.549 D/BluetoothMapService( 2680): cleanup()
01-03 18:25:44.549 D/BluetoothMapService( 2680): MAP Service closeService in
01-03 18:25:44.549 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:25:44.550 D/BluetoothPan( 3417): onBluetoothStateChange on: false
01-03 18:25:44.551 D/BluetoothManagerService( 1576): Bluetooth State Change Intent: 11 -> 10
01-03 18:25:44.552 E/BluetoothManagerService( 1576): recoverBluetoothServiceFromError
01-03 18:25:44.564 W/ContextImpl( 2411): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1721 android.content.ContextWrapper.startService:522 android.content.ContextWrapper.startService:522 com.android.settings.bluetooth.DockEventReceiver.beginStartingService:134 com.android.settings.bluetooth.DockEventReceiver.onReceive:115
01-03 18:25:44.569 D/Index ( 2411): Deleting data for locale 'de_DE' took 8 millis
01-03 18:25:44.577 D/Index ( 2411): Indexing locale 'de_DE' took 8 millis
01-03 18:25:44.673 D/DockEventReceiver( 2411): finishStartingService: stopping service
01-03 18:25:44.684 D/PhoneStatusBar( 3417): disable: < expand icons alerts system_info back home* recent* clock search* >
01-03 18:25:44.703 W/IInputConnectionWrapper( 1576): showStatusIcon on inactive InputConnection
01-03 18:25:44.714 D/AuthorizationBluetoothService( 2126): Received Bluetooth event: Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x14000010 cmp=com.google.android.gms/.auth.be.proximity.authorization.bt.AuthorizationBluetoothService$BluetoothStateChangeReceiver (has extras) }.
01-03 18:25:44.722 E/BTEventHandler( 2680): A4WP is not supported
01-03 18:25:44.733 I/Timeline( 2411): Timeline: Activity_idle id: android.os.BinderProxy@1295d420 time:200725
01-03 18:25:45.053 D/BluetoothManagerService( 1576): Sending off request.
01-03 18:25:45.054 D/BluetoothAdapterState( 2680): CURRENT_STATE=OFF, MESSAGE = USER_TURN_OFF
01-03 18:25:45.055 D/BluetoothManagerService( 1576): Calling onBluetoothServiceDown callbacks
01-03 18:25:45.055 D/BluetoothManagerService( 1576): Broadcasting onBluetoothServiceDown() to 6 receivers.
01-03 18:25:45.057 D/BluetoothManagerService( 1576): Calling onQBluetoothServiceDown callbacks
01-03 18:25:45.057 D/BluetoothManagerService( 1576): Broadcasting onQBluetoothServiceDown() to 0 receivers.
01-03 18:25:45.061 W/bt_userial( 2680): userial_close_reader Already closed userial reader thread
01-03 18:25:45.062 I/GKI_LINUX( 2680): gki_task task_id=0 [BTU] terminating
01-03 18:25:45.063 I/GKI_LINUX( 2680): GKI_exit_task 0 done
01-03 18:25:45.063 I/GKI_LINUX( 2680): GKI_shutdown(): task [BTU] terminated
01-03 18:25:45.063 E/BluetoothServiceJni( 2680): Callback env check fail: env: 0x42478ac0, callback: 0x426a7940
01-03 18:25:45.063 E/BluetoothServiceJni( 2680): Callback: 'adapter_state_change_callback' is not called on the correct thread
01-03 18:25:45.064 I/GKI_LINUX( 2680): gki_task task_id=1 [BTIF] terminating
01-03 18:25:45.064 I/GKI_LINUX( 2680): GKI_exit_task 1 done
01-03 18:25:45.064 I/GKI_LINUX( 2680): GKI_shutdown(): task [BTIF] terminated
01-03 18:25:45.065 I/BluetoothServiceJni( 2680): cleanupNative: return from cleanup
01-03 18:25:46.366 D/BluetoothAdapter( 3417): 1069163452: getState() : mService = null. Returning STATE_OFF
01-03 18:25:46.373 D/BluetoothAdapter( 3417): 1069163452: getState() : mService = null. Returning STATE_OFF
01-03 18:25:46.379 D/PhoneStatusBar( 3417): disable: < expand ICONS* alerts SYSTEM_INFO* back home recent clock search >
01-03 18:25:46.382 D/BluetoothAdapter( 3417): 1069163452: getState() : mService = null. Returning STATE_OFF
01-03 18:25:46.488 I/auditd ( 3542): Starting up
01-03 18:25:46.489 E/auditd ( 3542): Failed on audit_set_pid with error: Protocol not supported
01-03 18:25:46.489 I/auditd ( 3542): Exiting
01-03 18:25:47.915 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:25:47.915 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:25:47.915 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:25:47.915 D/alsa_pcm( 1321): pcm_close()
01-03 18:25:48.062 D/BluetoothManagerService( 1576): Message: 42
01-03 18:25:48.062 D/BluetoothManagerService( 1576): MESSAGE_RESTART_BLUETOOTH_SERVICE: Restart IBluetooth service
01-03 18:25:48.065 D/BluetoothAdapterState( 2680): make
01-03 18:25:48.069 I/bluedroid( 2680): init
01-03 18:25:48.069 I/bte_conf( 2680): bte_load_conf attempt to load stack conf from /etc/bluetooth/bt_stack.conf
01-03 18:25:48.070 I/bte_conf( 2680): bte_load_ble_conf attempt to load ble stack conf from /etc/bluetooth/ble_stack.conf
01-03 18:25:48.070 E/bt_osi_config( 2680): config_new unable to open file '/etc/bluetooth/ble_stack.conf': No such file or directory
01-03 18:25:48.070 I/bte_conf( 2680): bte_load_ble_conf file >/etc/bluetooth/ble_stack.conf< not found
01-03 18:25:48.070 I/bluedroid( 2680): get_profile_interface socket
01-03 18:25:48.070 I/bluedroid( 2680): get_profile_interface map_client
01-03 18:25:48.070 I/GKI_LINUX( 2680): gki_task_entry task_id=1 [BTIF] starting
01-03 18:25:48.071 D/BluetoothAdapterProperties( 2680): Address is:22:22:DE:59:9F:D7
01-03 18:25:48.071 I/BluetoothAdapterState( 2680): Entering OffState
01-03 18:25:48.072 D/BluetoothManagerService( 1576): Bluetooth Adapter name changed to Rockchip
01-03 18:25:48.073 D/BluetoothAdapterProperties( 2680): Name is: Rockchip
01-03 18:25:48.073 D/BluetoothManagerService( 1576): Stored Bluetooth name: Rockchip
01-03 18:25:48.073 D/BluetoothManagerService( 1576): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
01-03 18:25:48.073 D/BluetoothManagerService( 1576): Message: 40
01-03 18:25:48.073 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
01-03 18:25:48.074 I/bluedroid( 2680): config_hci_snoop_log
01-03 18:25:48.074 D/BluetoothManagerService( 1576): Calling onBluetoothServiceUp callbacks
01-03 18:25:48.074 D/BluetoothManagerService( 1576): Broadcasting onBluetoothServiceUp() to 6 receivers.
01-03 18:25:48.076 D/BluetoothAdapterState( 2680): CURRENT_STATE=OFF, MESSAGE = USER_TURN_ON
01-03 18:25:48.076 D/BluetoothAdapterProperties( 2680): Setting state to 11
01-03 18:25:48.076 I/BluetoothAdapterState( 2680): Bluetooth adapter state changed: 10-> 11
01-03 18:25:48.077 D/BluetoothManagerService( 1576): Message: 60
01-03 18:25:48.077 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 10, newState=11
01-03 18:25:48.077 D/BluetoothManagerService( 1576): Bluetooth State Change Intent: 10 -> 11
01-03 18:25:48.081 D/BluetoothBondStateMachine( 2680): make
01-03 18:25:48.083 D/BluetoothAdapterService( 2680): checkA2dpState: isA2dpSinkEnabled = false
01-03 18:25:48.083 E/BluetoothAdapterService( 2680): checkA2dpState: returning
01-03 18:25:48.083 D/BluetoothAdapterService( 2680): checkHidState: isHidDev = false
01-03 18:25:48.083 I/BluetoothBondStateMachine( 2680): StableState(): Entering Off State
01-03 18:25:48.084 E/BluetoothAdapterService( 2680): checkHidState: returning
01-03 18:25:48.084 D/BluetoothAdapterService( 2680): checkHfpState: isHfpClientEnabled = false
01-03 18:25:48.084 E/BluetoothAdapterService( 2680): checkHfpState: returning
01-03 18:25:48.090 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@1c9fe141
01-03 18:25:48.093 D/HeadsetService( 2680): Received start request. Starting profile...
01-03 18:25:48.093 D/HeadsetStateMachine( 2680): make
01-03 18:25:48.096 E/BluetoothAdapterService(776564189)( 2680): cleanup() - Service already starting to cleanup, ignoring request...
01-03 18:25:48.099 D/HeadsetStateMachine( 2680): max_hf_connections = 1
01-03 18:25:48.099 I/bluedroid( 2680): get_profile_interface handsfree
01-03 18:25:48.100 E/BluetoothAdapterService(254974035)( 2680): cleanup() - Service already starting to cleanup, ignoring request...
01-03 18:25:48.107 D/HeadsetStateMachine( 2680): Enter Disconnected: -2, size: 0
01-03 18:25:48.113 D/AuthorizationBluetoothService( 2126): Received Bluetooth event: Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x14000010 cmp=com.google.android.gms/.auth.be.proximity.authorization.bt.AuthorizationBluetoothService$BluetoothStateChangeReceiver (has extras) }.
01-03 18:25:48.124 I/BluetoothAdapterService( 2680): skipping com.android.bluetooth.hid.HidDevService (disabled)
01-03 18:25:48.124 I/BluetoothAdapterState( 2680): Entering PendingCommandState State: isTurningOn()=true, isTurningOff()=false
01-03 18:25:48.124 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@1c9fe141
01-03 18:25:48.125 D/A2dpService( 2680): Received start request. Starting profile...
01-03 18:25:48.125 I/bluedroid( 2680): get_profile_interface avrcp
01-03 18:25:48.129 V/AudioService( 1576): updateRemoteControllerOnExistingMediaPlayers: size of Player list: 0
01-03 18:25:48.129 E/AudioService( 1576): No RCC entry present to update
01-03 18:25:48.129 E/RemoteController( 2680): Cannot set synchronization mode on an unregistered RemoteController
01-03 18:25:48.129 D/A2dpStateMachine( 2680): make
01-03 18:25:48.130 I/bluedroid( 2680): get_profile_interface a2dp
01-03 18:25:48.130 I/GKI_LINUX( 2680): gki_task_entry task_id=2 [A2DP-MEDIA] starting
01-03 18:25:48.130 D/bt-btif ( 2680): btif_av_state_idle_handler event:BTIF_SM_ENTER_EVT flags 0
01-03 18:25:48.131 D/A2dpService( 2680): setA2dpService(): set to: null
01-03 18:25:48.131 D/A2dpStateMachine( 2680): Enter Disconnected: -2
01-03 18:25:48.131 I/Telecom ( 1576): BluetoothPhoneService: queryPhoneState
01-03 18:25:48.132 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@1c9fe141
01-03 18:25:48.133 D/HidService( 2680): Received start request. Starting profile...
01-03 18:25:48.133 I/bluedroid( 2680): get_profile_interface hidhost
01-03 18:25:48.133 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@1c9fe141
01-03 18:25:48.134 D/HealthService( 2680): Received start request. Starting profile...
01-03 18:25:48.135 I/bluedroid( 2680): get_profile_interface health
01-03 18:25:48.135 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@1c9fe141
01-03 18:25:48.136 D/PanService( 2680): Received start request. Starting profile...
01-03 18:25:48.136 D/BluetoothPanServiceJni( 2680): initializeNative(L110): pan
01-03 18:25:48.136 I/bluedroid( 2680): get_profile_interface pan
01-03 18:25:48.137 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@1c9fe141
01-03 18:25:48.137 D/BtGatt.DebugUtils( 2680): handleDebugAction() action=null
01-03 18:25:48.137 D/BtGatt.GattService( 2680): Received start request. Starting profile...
01-03 18:25:48.137 D/BtGatt.GattService( 2680): start()
01-03 18:25:48.137 I/bluedroid( 2680): get_profile_interface gatt
01-03 18:25:48.137 D/BtGatt.AdvertiseManager( 2680): advertise manager created
01-03 18:25:48.141 D/HeadsetStateMachine( 2680): Disconnected process message: 10, size: 0
01-03 18:25:48.141 D/HeadsetPhoneState( 2680): sendDeviceStateChanged. mService=0 mSignal=0 mRoam=0 mBatteryCharge=3
01-03 18:25:48.141 D/HeadsetStateMachine( 2680): Disconnected process message: 11, size: 0
01-03 18:25:48.142 D/BluetoothMapService( 2680): inside BluetoothMapObexConnection
01-03 18:25:48.142 D/BluetoothMapService( 2680): supportedMessageTypes 14
01-03 18:25:48.142 D/BluetoothMapService( 2680): masId 0
01-03 18:25:48.142 D/BluetoothMapService( 2680): masId 1
01-03 18:25:48.142 D/BluetoothMapService( 2680): Inside initBinder
01-03 18:25:48.142 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@1c9fe141
01-03 18:25:48.143 D/BluetoothMapService( 2680): Received start request. Starting profile...
01-03 18:25:48.143 D/BluetoothMapService( 2680): start()
01-03 18:25:48.144 D/BluetoothMapService( 2680): Registering observer
01-03 18:25:48.145 E/BTEventHandler( 2680): A4WP is not supported
01-03 18:25:48.145 V/BluetoothMapService( 2680): Handler(): got msg=1
01-03 18:25:48.146 D/BluetoothAdapterState( 2680): CURRENT_STATE=PENDING, MESSAGE = STARTED, isTurningOn=true, isTurningOff=false
01-03 18:25:48.146 I/bluedroid( 2680): enable
01-03 18:25:48.146 I/bt_hci_bdroid( 2680): init
01-03 18:25:48.146 I/GKI_LINUX( 2680): gki_task_entry task_id=0 [BTU] starting
01-03 18:25:48.146 I/bt-btu ( 2680): btu_task pending for preload complete event
01-03 18:25:48.147 I/bt_vendor( 2680): init
01-03 18:25:48.147 D/bt_userial( 2680): userial_init
01-03 18:25:48.147 I/bt_vendor( 2680): userial vendor open: opening /dev/rtk_btusb
01-03 18:25:48.147 E/bt_vendor( 2680): userial vendor open: unable to open /dev/rtk_btusb: Permission denied
01-03 18:25:48.147 E/bt_userial( 2680): userial_open opened wrong number of ports: got 0, expected 1.
01-03 18:25:48.148 I/bt-btu ( 2680): btu_task received preload complete event
01-03 18:25:48.148 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x0001
01-03 18:25:48.148 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x001f
01-03 18:25:48.150 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x0003
01-03 18:25:48.150 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x1487
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_HCI
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_L2CAP
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_RFCOMM
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_AVDT
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_AVRC
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_A2D
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_BNEP
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTM
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_HID_HOST
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_GAP
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_PAN
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_SDP
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_GATT
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_SMP
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_HID_DEV
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTAPP
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTIF
01-03 18:25:48.152 I/ ( 2680): BTE_InitTraceLevels -- TRC_LATENCY_AUDIO
01-03 18:25:48.152 E/bt_userial( 2680): userial_write error writing to serial port: Bad file number
01-03 18:25:48.317 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:25:48.320 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:25:48.322 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:25:48.323 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:25:48.323 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:25:48.323 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:25:48.323 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:25:48.325 D/WifiService( 1576): setWifiEnabled: true pid=3417, uid=10013
01-03 18:25:48.325 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:25:48.326 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:25:49.901 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:50.001 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:50.101 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:50.202 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:50.302 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:50.402 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:50.503 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:50.603 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:50.704 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:50.805 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:50.905 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:51.006 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:51.107 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:51.207 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:51.308 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:51.333 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:25:51.334 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:25:51.334 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:25:51.334 D/alsa_pcm( 1321): pcm_close()
01-03 18:25:51.409 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:51.509 I/auditd ( 3563): Starting up
01-03 18:25:51.510 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:51.510 E/auditd ( 3563): Failed on audit_set_pid with error: Protocol not supported
01-03 18:25:51.510 I/auditd ( 3563): Exiting
01-03 18:25:51.610 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:51.711 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:51.812 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:51.912 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:52.013 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:52.113 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:52.214 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:52.315 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:52.415 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:52.516 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:52.617 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:52.717 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:52.818 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:52.918 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:53.019 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:53.120 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:53.220 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:53.321 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:53.422 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:53.522 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:53.623 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:53.723 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:53.824 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:53.925 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:54.025 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:54.126 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:54.226 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:54.327 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:54.428 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:54.528 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:54.629 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:54.730 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:54.830 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:25:54.830 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:25:54.838 E/wifi ( 1576): android_net_wifi_getLinkLayerStats: failed to get link statistics
01-03 18:25:54.839 E/WifiStateMachine( 1576): cancelDelayedScan -> 4
01-03 18:25:54.844 E/WifiStateMachine( 1576): cancelDelayedScan -> 5
01-03 18:25:54.849 E/WifiStateMachine( 1576): Failed to setup control channel, restart supplicant
01-03 18:25:54.849 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:25:54.873 I/InputDispatcher( 1576): Window 'Window{1c4612d6 u0 NavigationBar}' spent 5361.3ms processing the last input event: MotionEvent(deviceId=1, source=0x00001002, action=0, flags=0x00000000, metaState=0x00000000, buttonState=0x00000000, edgeFlags=0x00000000, xPrecision=0.5, yPrecision=0.5, displayId=0, pointers=[0: (905.1, 533.3)]), policyFlags=0x67000000
01-03 18:25:54.876 I/InputDispatcher( 1576): Window 'Window{12aa5426 u0 StatusBar}' spent 5363.6ms processing the last input event: MotionEvent(deviceId=1, source=0x00001002, action=0, flags=0x00000000, metaState=0x00000000, buttonState=0x00000000, edgeFlags=0x00000000, xPrecision=0.5, yPrecision=0.5, displayId=0, pointers=[0: (905.1, 533.3)]), policyFlags=0x67000000
01-03 18:25:54.877 I/InputDispatcher( 1576): Window 'Window{12aa5426 u0 StatusBar}' spent 5223.2ms processing the last input event: MotionEvent(deviceId=1, source=0x00001002, action=1, flags=0x00000000, metaState=0x00000000, buttonState=0x00000000, edgeFlags=0x00000000, xPrecision=0.5, yPrecision=0.5, displayId=0, pointers=[0: (905.1, 533.3)]), policyFlags=0x67000000
01-03 18:25:56.589 I/auditd ( 3567): Starting up
01-03 18:25:56.590 E/auditd ( 3567): Failed on audit_set_pid with error: Protocol not supported
01-03 18:25:56.590 I/auditd ( 3567): Exiting
01-03 18:25:59.856 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:25:59.856 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:26:00.000 E/Lights ( 1576): write_int failed to open sys/class/leds/rk29_key_led/brightness
01-03 18:26:00.158 D/BluetoothAdapterState( 2680): CURRENT_STATE=PENDING, MESSAGE = ENABLE_TIMEOUT, isTurningOn=true, isTurningOff=false
01-03 18:26:00.158 E/BluetoothAdapterState( 2680): Error enabling Bluetooth
01-03 18:26:00.158 E/bt-btif ( 2680): bte_ssr_cleanup
01-03 18:26:00.158 I/BluetoothServiceJni( 2680): ssrcleanupNative: return from cleanup
01-03 18:26:00.158 D/BluetoothAdapterService( 2680): mProfilesStarted : true supportedProfileServices.length : 8
01-03 18:26:00.161 D/HeadsetService( 2680): Received stop request...Stopping profile...
01-03 18:26:00.162 D/HeadsetStateMachine( 2680): Exit Disconnected: -1
01-03 18:26:00.165 D/A2dpService( 2680): Received stop request...Stopping profile...
01-03 18:26:00.166 D/A2dpStateMachine( 2680): Exit Disconnected: -1
01-03 18:26:00.170 D/BluetoothAdapterProperties( 2680): Setting state to 10
01-03 18:26:00.170 I/BluetoothAdapterState( 2680): Bluetooth adapter state changed: 11-> 10
01-03 18:26:00.170 D/BluetoothManagerService( 1576): Message: 60
01-03 18:26:00.170 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 11, newState=10
01-03 18:26:00.170 D/BluetoothManagerService( 1576): Broadcasting onBluetoothStateChange(false) to 17 receivers.
01-03 18:26:00.171 I/BluetoothAdapterState( 2680): Entering OffState
01-03 18:26:00.171 D/HidService( 2680): Received stop request...Stopping profile...
01-03 18:26:00.171 D/BluetoothPan( 2411): onBluetoothStateChange on: false
01-03 18:26:00.172 E/BluetoothPan( 2411):
01-03 18:26:00.172 E/BluetoothPan( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPan$2@14c69600
01-03 18:26:00.172 E/BluetoothPan( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:00.172 E/BluetoothPan( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:00.172 E/BluetoothPan( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:00.172 E/BluetoothPan( 2411): at android.bluetooth.BluetoothPan$1.onBluetoothStateChange(BluetoothPan.java:206)
01-03 18:26:00.172 E/BluetoothPan( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:00.172 E/BluetoothPan( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:00.172 D/BluetoothInputDevice( 3417): onBluetoothStateChange: up=false
01-03 18:26:00.173 E/BluetoothInputDevice( 3417):
01-03 18:26:00.173 E/BluetoothInputDevice( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothInputDevice$2@2754f75a
01-03 18:26:00.173 E/BluetoothInputDevice( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:00.173 E/BluetoothInputDevice( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:00.173 E/BluetoothInputDevice( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:00.173 E/BluetoothInputDevice( 3417): at android.bluetooth.BluetoothInputDevice$1.onBluetoothStateChange(BluetoothInputDevice.java:227)
01-03 18:26:00.173 E/BluetoothInputDevice( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:00.173 E/BluetoothInputDevice( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:00.174 D/BluetoothHeadset( 1998): onBluetoothStateChange: up=false
01-03 18:26:00.174 W/BluetoothHeadsetServiceJni( 2680): Cleaning up Bluetooth Handsfree Interface...
01-03 18:26:00.174 D/BluetoothA2dp( 1576): onBluetoothStateChange: up=false
01-03 18:26:00.174 W/BluetoothHeadsetServiceJni( 2680): Cleaning up Bluetooth Handsfree callback object
01-03 18:26:00.175 E/BluetoothA2dp( 1576):
01-03 18:26:00.175 E/BluetoothA2dp( 1576): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dp$2@3214f02c
01-03 18:26:00.175 E/BluetoothA2dp( 1576): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:00.175 E/BluetoothA2dp( 1576): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:00.175 E/BluetoothA2dp( 1576): at android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange(BluetoothA2dp.java:126)
01-03 18:26:00.175 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.sendBluetoothStateCallback(BluetoothManagerService.java:761)
01-03 18:26:00.175 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.bluetoothStateChangeHandler(BluetoothManagerService.java:1507)
01-03 18:26:00.175 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.access$3700(BluetoothManagerService.java:68)
01-03 18:26:00.175 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:1226)
01-03 18:26:00.175 E/BluetoothA2dp( 1576): at android.os.Handler.dispatchMessage(Handler.java:102)
01-03 18:26:00.175 E/BluetoothA2dp( 1576): at android.os.Looper.loop(Looper.java:135)
01-03 18:26:00.175 E/BluetoothA2dp( 1576): at android.os.HandlerThread.run(HandlerThread.java:61)
01-03 18:26:00.175 E/BluetoothA2dp( 1576): at com.android.server.ServiceThread.run(ServiceThread.java:46)
01-03 18:26:00.175 D/BluetoothA2dpSink( 3417): onBluetoothStateChange: up=false
01-03 18:26:00.175 D/HealthService( 2680): Received stop request...Stopping profile...
01-03 18:26:00.177 E/BluetoothA2dpSink( 3417):
01-03 18:26:00.177 E/BluetoothA2dpSink( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dpSink$2@3ce366d5
01-03 18:26:00.177 E/BluetoothA2dpSink( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:00.177 E/BluetoothA2dpSink( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:00.177 E/BluetoothA2dpSink( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:00.177 E/BluetoothA2dpSink( 3417): at android.bluetooth.BluetoothA2dpSink$1.onBluetoothStateChange(BluetoothA2dpSink.java:139)
01-03 18:26:00.177 E/BluetoothA2dpSink( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:00.177 E/BluetoothA2dpSink( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:00.177 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:26:00.177 D/BluetoothAvrcpController( 3417): onBluetoothStateChange: up=false
01-03 18:26:00.178 D/PanService( 2680): Received stop request...Stopping profile...
01-03 18:26:00.178 E/BluetoothAvrcpController( 3417):
01-03 18:26:00.178 E/BluetoothAvrcpController( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothAvrcpController$2@13e5deea
01-03 18:26:00.178 E/BluetoothAvrcpController( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:00.178 E/BluetoothAvrcpController( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:00.178 E/BluetoothAvrcpController( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:00.178 E/BluetoothAvrcpController( 3417): at android.bluetooth.BluetoothAvrcpController$1.onBluetoothStateChange(BluetoothAvrcpController.java:80)
01-03 18:26:00.178 E/BluetoothAvrcpController( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:00.178 E/BluetoothAvrcpController( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:00.179 D/BluetoothMap( 3417): onBluetoothStateChange: up=false
01-03 18:26:00.180 D/BtGatt.DebugUtils( 2680): handleDebugAction() action=null
01-03 18:26:00.180 E/BluetoothMap( 3417):
01-03 18:26:00.180 E/BluetoothMap( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothMap$2@c26ed8b
01-03 18:26:00.180 E/BluetoothMap( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:00.180 E/BluetoothMap( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:00.180 E/BluetoothMap( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:00.180 E/BluetoothMap( 3417): at android.bluetooth.BluetoothMap$1.onBluetoothStateChange(BluetoothMap.java:64)
01-03 18:26:00.180 E/BluetoothMap( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:00.180 E/BluetoothMap( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:00.181 D/BluetoothHeadset( 3417): onBluetoothStateChange: up=false
01-03 18:26:00.181 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:26:00.181 D/BtGatt.GattService( 2680): Received stop request...Stopping profile...
01-03 18:26:00.181 D/BtGatt.GattService( 2680): stop()
01-03 18:26:00.181 D/BtGatt.AdvertiseManager( 2680): advertise clients cleared
01-03 18:26:00.181 D/BluetoothHeadsetClient( 3417): onBluetoothStateChange: up=false
01-03 18:26:00.184 E/BluetoothHeadsetClient( 3417):
01-03 18:26:00.184 E/BluetoothHeadsetClient( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothHeadsetClient$2@29514878
01-03 18:26:00.184 E/BluetoothHeadsetClient( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:00.184 E/BluetoothHeadsetClient( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:00.184 E/BluetoothHeadsetClient( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:00.184 E/BluetoothHeadsetClient( 3417): at android.bluetooth.BluetoothHeadsetClient$1.onBluetoothStateChange(BluetoothHeadsetClient.java:382)
01-03 18:26:00.184 E/BluetoothHeadsetClient( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:00.184 E/BluetoothHeadsetClient( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:00.185 I/GKI_LINUX( 2680): gki_task task_id=2 [A2DP-MEDIA] terminating
01-03 18:26:00.186 D/BluetoothInputDevice( 2411): onBluetoothStateChange: up=false
01-03 18:26:00.186 I/GKI_LINUX( 2680): GKI_exit_task 2 done
01-03 18:26:00.186 I/GKI_LINUX( 2680): GKI_shutdown(): task [A2DP-MEDIA] terminated
01-03 18:26:00.187 E/BluetoothInputDevice( 2411):
01-03 18:26:00.187 E/BluetoothInputDevice( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothInputDevice$2@2082d483
01-03 18:26:00.187 E/BluetoothInputDevice( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:00.187 E/BluetoothInputDevice( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:00.187 E/BluetoothInputDevice( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:00.187 E/BluetoothInputDevice( 2411): at android.bluetooth.BluetoothInputDevice$1.onBluetoothStateChange(BluetoothInputDevice.java:227)
01-03 18:26:00.187 E/BluetoothInputDevice( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:00.187 E/BluetoothInputDevice( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:00.187 D/BluetoothMapService( 2680): Received stop request...Stopping profile...
01-03 18:26:00.187 D/BluetoothA2dp( 3417): onBluetoothStateChange: up=false
01-03 18:26:00.187 D/BluetoothMapService( 2680): stop()
01-03 18:26:00.188 D/BluetoothMapService( 2680): MAP Service closeService in
01-03 18:26:00.188 D/BluetoothMapService( 2680): Unregistering Email account observer
01-03 18:26:00.189 E/BluetoothA2dp( 3417):
01-03 18:26:00.189 E/BluetoothA2dp( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dp$2@2c16db05
01-03 18:26:00.189 E/BluetoothA2dp( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:00.189 E/BluetoothA2dp( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:00.189 E/BluetoothA2dp( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:00.189 E/BluetoothA2dp( 3417): at android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange(BluetoothA2dp.java:126)
01-03 18:26:00.189 E/BluetoothA2dp( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:00.189 E/BluetoothA2dp( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:00.190 D/BluetoothMap( 2411): onBluetoothStateChange: up=false
01-03 18:26:00.191 E/BluetoothMap( 2411):
01-03 18:26:00.191 E/BluetoothMap( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothMap$2@1e420e39
01-03 18:26:00.191 E/BluetoothMap( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:00.191 E/BluetoothMap( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:00.191 E/BluetoothMap( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:00.191 E/BluetoothMap( 2411): at android.bluetooth.BluetoothMap$1.onBluetoothStateChange(BluetoothMap.java:64)
01-03 18:26:00.191 E/BluetoothMap( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:00.191 E/BluetoothMap( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:00.191 D/BluetoothPbap( 2411): onBluetoothStateChange: up=false
01-03 18:26:00.191 W/BluetoothHidServiceJni( 2680): Cleaning up Bluetooth HID Interface...
01-03 18:26:00.191 W/bt-btif ( 2680): cleanup: HH disabling or disabled already, status = 0
01-03 18:26:00.191 W/BluetoothHidServiceJni( 2680): Cleaning up Bluetooth GID callback object
01-03 18:26:00.192 W/BluetoothHealthServiceJni( 2680): Cleaning up Bluetooth Health Interface...
01-03 18:26:00.192 W/BluetoothHealthServiceJni( 2680): Cleaning up Bluetooth Health object
01-03 18:26:00.192 E/BluetoothPbap( 2411):
01-03 18:26:00.192 E/BluetoothPbap( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPbap$2@3b8b9c7e
01-03 18:26:00.192 E/BluetoothPbap( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:00.192 E/BluetoothPbap( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:00.192 E/BluetoothPbap( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:00.192 E/BluetoothPbap( 2411): at android.bluetooth.BluetoothPbap$1.onBluetoothStateChange(BluetoothPbap.java:121)
01-03 18:26:00.192 E/BluetoothPbap( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:00.192 E/BluetoothPbap( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:00.193 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:26:00.193 W/BluetoothPanServiceJni( 2680): Cleaning up Bluetooth PAN Interface...
01-03 18:26:00.193 W/BluetoothPanServiceJni( 2680): Cleaning up Bluetooth PAN callback object
01-03 18:26:00.193 D/BluetoothPan( 3417): onBluetoothStateChange on: false
01-03 18:26:00.194 E/BluetoothPan( 3417):
01-03 18:26:00.194 E/BluetoothPan( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPan$2@d75ae68
01-03 18:26:00.194 E/BluetoothPan( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:00.194 E/BluetoothPan( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:00.194 E/BluetoothPan( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:00.194 E/BluetoothPan( 3417): at android.bluetooth.BluetoothPan$1.onBluetoothStateChange(BluetoothPan.java:206)
01-03 18:26:00.194 E/BluetoothPan( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:00.194 E/BluetoothPan( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:00.194 D/BtGatt.GattService( 2680): cleanup()
01-03 18:26:00.195 W/bt-btif ( 2680): GATTC Module not enabled/already disabled
01-03 18:26:00.195 W/bt-btif ( 2680): GATTS Module not enabled/already disabled
01-03 18:26:00.195 D/BluetoothManagerService( 1576): Bluetooth State Change Intent: 11 -> 10
01-03 18:26:00.195 D/BluetoothMapService( 2680): cleanup()
01-03 18:26:00.195 D/BluetoothMapService( 2680): MAP Service closeService in
01-03 18:26:00.196 E/BluetoothManagerService( 1576): recoverBluetoothServiceFromError
01-03 18:26:00.204 D/Index ( 2411): Deleting data for locale 'de_DE' took 4 millis
01-03 18:26:00.211 D/Index ( 2411): Indexing locale 'de_DE' took 7 millis
01-03 18:26:00.539 E/Lights ( 1576): write_int failed to open sys/class/leds/rk29_key_led/brightness
01-03 18:26:00.698 D/BluetoothManagerService( 1576): Sending off request.
01-03 18:26:00.700 D/BluetoothAdapterState( 2680): CURRENT_STATE=OFF, MESSAGE = USER_TURN_OFF
01-03 18:26:00.701 D/BluetoothManagerService( 1576): Calling onBluetoothServiceDown callbacks
01-03 18:26:00.702 D/BluetoothManagerService( 1576): Broadcasting onBluetoothServiceDown() to 6 receivers.
01-03 18:26:00.706 D/BluetoothManagerService( 1576): Calling onQBluetoothServiceDown callbacks
01-03 18:26:00.706 D/BluetoothManagerService( 1576): Broadcasting onQBluetoothServiceDown() to 0 receivers.
01-03 18:26:00.732 W/bt_userial( 2680): userial_close_reader Already closed userial reader thread
01-03 18:26:00.734 I/GKI_LINUX( 2680): gki_task task_id=0 [BTU] terminating
01-03 18:26:00.739 I/GKI_LINUX( 2680): GKI_exit_task 0 done
01-03 18:26:00.739 I/GKI_LINUX( 2680): GKI_shutdown(): task [BTU] terminated
01-03 18:26:00.739 E/BluetoothServiceJni( 2680): Callback env check fail: env: 0x42478ac0, callback: 0x426a7940
01-03 18:26:00.739 E/BluetoothServiceJni( 2680): Callback: 'adapter_state_change_callback' is not called on the correct thread
01-03 18:26:00.740 I/GKI_LINUX( 2680): gki_task task_id=1 [BTIF] terminating
01-03 18:26:00.741 I/GKI_LINUX( 2680): GKI_exit_task 1 done
01-03 18:26:00.741 I/GKI_LINUX( 2680): GKI_shutdown(): task [BTIF] terminated
01-03 18:26:00.741 D/WifiService( 1576): setWifiEnabled: false pid=3417, uid=10013
01-03 18:26:00.741 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:26:00.743 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:26:00.743 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:26:00.745 W/ContextImpl( 2411): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1721 android.content.ContextWrapper.startService:522 android.content.ContextWrapper.startService:522 com.android.settings.bluetooth.DockEventReceiver.beginStartingService:134 com.android.settings.bluetooth.DockEventReceiver.onReceive:115
01-03 18:26:00.746 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:26:00.749 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:26:00.750 I/BluetoothServiceJni( 2680): cleanupNative: return from cleanup
01-03 18:26:00.752 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:26:00.752 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:26:00.752 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:26:00.752 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:26:00.752 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:26:00.756 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:26:00.758 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:26:00.784 D/DockEventReceiver( 2411): finishStartingService: stopping service
01-03 18:26:00.802 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:26:00.809 D/AuthorizationBluetoothService( 2126): Received Bluetooth event: Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x14000010 cmp=com.google.android.gms/.auth.be.proximity.authorization.bt.AuthorizationBluetoothService$BluetoothStateChangeReceiver (has extras) }.
01-03 18:26:00.814 E/BTEventHandler( 2680): A4WP is not supported
01-03 18:26:01.073 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:26:01.075 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:26:01.075 E/SoftapController( 1322): Softap fwReload failed
01-03 18:26:01.076 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '60 softap fwreload wlan0 STA' failed with '400 60 SoftAP command has failed'
01-03 18:26:01.078 D/CommandListener( 1322): Setting iface cfg
01-03 18:26:01.079 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:26:01.080 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:26:01.084 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:26:01.086 I/auditd ( 3578): Starting up
01-03 18:26:01.087 E/auditd ( 3578): Failed on audit_set_pid with error: Protocol not supported
01-03 18:26:01.087 I/auditd ( 3578): Exiting
01-03 18:26:01.109 I/wpa_supplicant( 3579): Successfully initialized wpa_supplicant
01-03 18:26:01.111 I/wpa_supplicant( 3579): rfkill: Cannot open RFKILL control device
01-03 18:26:01.186 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:26:01.223 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:26:01.947 D/WifiService( 1576): setWifiEnabled: true pid=3417, uid=10013
01-03 18:26:01.947 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:26:01.948 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:26:01.955 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:26:03.728 D/BluetoothManagerService( 1576): Message: 42
01-03 18:26:03.728 D/BluetoothManagerService( 1576): MESSAGE_RESTART_BLUETOOTH_SERVICE: Restart IBluetooth service
01-03 18:26:03.739 D/BluetoothAdapterState( 2680): make
01-03 18:26:03.743 I/bluedroid( 2680): init
01-03 18:26:03.744 I/bte_conf( 2680): bte_load_conf attempt to load stack conf from /etc/bluetooth/bt_stack.conf
01-03 18:26:03.745 I/bte_conf( 2680): bte_load_ble_conf attempt to load ble stack conf from /etc/bluetooth/ble_stack.conf
01-03 18:26:03.746 E/bt_osi_config( 2680): config_new unable to open file '/etc/bluetooth/ble_stack.conf': No such file or directory
01-03 18:26:03.746 I/bte_conf( 2680): bte_load_ble_conf file >/etc/bluetooth/ble_stack.conf< not found
01-03 18:26:03.746 I/bluedroid( 2680): get_profile_interface socket
01-03 18:26:03.747 I/bluedroid( 2680): get_profile_interface map_client
01-03 18:26:03.747 I/GKI_LINUX( 2680): gki_task_entry task_id=1 [BTIF] starting
01-03 18:26:03.748 I/BluetoothAdapterState( 2680): Entering OffState
01-03 18:26:03.750 D/BluetoothAdapterProperties( 2680): Address is:22:22:DE:59:9F:D7
01-03 18:26:03.755 D/BluetoothManagerService( 1576): Bluetooth Adapter name changed to Rockchip
01-03 18:26:03.756 D/BluetoothManagerService( 1576): Stored Bluetooth name: Rockchip
01-03 18:26:03.757 D/BluetoothManagerService( 1576): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
01-03 18:26:03.758 D/BluetoothManagerService( 1576): Message: 40
01-03 18:26:03.758 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
01-03 18:26:03.759 D/BluetoothAdapterProperties( 2680): Name is: Rockchip
01-03 18:26:03.760 I/bluedroid( 2680): config_hci_snoop_log
01-03 18:26:03.762 D/BluetoothManagerService( 1576): Calling onBluetoothServiceUp callbacks
01-03 18:26:03.762 D/BluetoothManagerService( 1576): Broadcasting onBluetoothServiceUp() to 6 receivers.
01-03 18:26:03.770 D/BluetoothAdapterState( 2680): CURRENT_STATE=OFF, MESSAGE = USER_TURN_ON
01-03 18:26:03.770 D/BluetoothAdapterProperties( 2680): Setting state to 11
01-03 18:26:03.771 I/BluetoothAdapterState( 2680): Bluetooth adapter state changed: 10-> 11
01-03 18:26:03.771 D/BluetoothManagerService( 1576): Message: 60
01-03 18:26:03.771 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 10, newState=11
01-03 18:26:03.772 D/BluetoothManagerService( 1576): Bluetooth State Change Intent: 10 -> 11
01-03 18:26:03.774 D/BluetoothBondStateMachine( 2680): make
01-03 18:26:03.780 D/BluetoothAdapterService( 2680): checkA2dpState: isA2dpSinkEnabled = false
01-03 18:26:03.780 I/BluetoothBondStateMachine( 2680): StableState(): Entering Off State
01-03 18:26:03.780 E/BluetoothAdapterService( 2680): checkA2dpState: returning
01-03 18:26:03.782 D/BluetoothAdapterService( 2680): checkHidState: isHidDev = false
01-03 18:26:03.782 E/BluetoothAdapterService( 2680): checkHidState: returning
01-03 18:26:03.782 D/BluetoothAdapterService( 2680): checkHfpState: isHfpClientEnabled = false
01-03 18:26:03.782 E/BluetoothAdapterService( 2680): checkHfpState: returning
01-03 18:26:03.788 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@236fdb8
01-03 18:26:03.796 D/HeadsetService( 2680): Received start request. Starting profile...
01-03 18:26:03.796 D/HeadsetStateMachine( 2680): make
01-03 18:26:03.805 D/HeadsetStateMachine( 2680): max_hf_connections = 1
01-03 18:26:03.805 I/bluedroid( 2680): get_profile_interface handsfree
01-03 18:26:03.818 D/HeadsetStateMachine( 2680): Enter Disconnected: -2, size: 0
01-03 18:26:03.836 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@236fdb8
01-03 18:26:03.838 D/A2dpService( 2680): Received start request. Starting profile...
01-03 18:26:03.838 I/bluedroid( 2680): get_profile_interface avrcp
01-03 18:26:03.841 I/BluetoothAdapterService( 2680): skipping com.android.bluetooth.hid.HidDevService (disabled)
01-03 18:26:03.841 I/BluetoothAdapterState( 2680): Entering PendingCommandState State: isTurningOn()=true, isTurningOff()=false
01-03 18:26:03.853 V/AudioService( 1576): updateRemoteControllerOnExistingMediaPlayers: size of Player list: 0
01-03 18:26:03.853 E/AudioService( 1576): No RCC entry present to update
01-03 18:26:03.853 E/RemoteController( 2680): Cannot set synchronization mode on an unregistered RemoteController
01-03 18:26:03.854 D/A2dpStateMachine( 2680): make
01-03 18:26:03.857 I/bluedroid( 2680): get_profile_interface a2dp
01-03 18:26:03.859 I/GKI_LINUX( 2680): gki_task_entry task_id=2 [A2DP-MEDIA] starting
01-03 18:26:03.861 D/bt-btif ( 2680): btif_av_state_idle_handler event:BTIF_SM_ENTER_EVT flags 0
01-03 18:26:03.863 D/A2dpService( 2680): setA2dpService(): set to: null
01-03 18:26:03.863 D/A2dpStateMachine( 2680): Enter Disconnected: -2
01-03 18:26:03.865 I/Telecom ( 1576): BluetoothPhoneService: queryPhoneState
01-03 18:26:03.867 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@236fdb8
01-03 18:26:03.869 D/AuthorizationBluetoothService( 2126): Received Bluetooth event: Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x14000010 cmp=com.google.android.gms/.auth.be.proximity.authorization.bt.AuthorizationBluetoothService$BluetoothStateChangeReceiver (has extras) }.
01-03 18:26:03.870 D/HidService( 2680): Received start request. Starting profile...
01-03 18:26:03.870 I/bluedroid( 2680): get_profile_interface hidhost
01-03 18:26:03.871 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@236fdb8
01-03 18:26:03.873 D/HealthService( 2680): Received start request. Starting profile...
01-03 18:26:03.878 I/bluedroid( 2680): get_profile_interface health
01-03 18:26:03.881 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@236fdb8
01-03 18:26:03.883 D/PanService( 2680): Received start request. Starting profile...
01-03 18:26:03.883 D/BluetoothPanServiceJni( 2680): initializeNative(L110): pan
01-03 18:26:03.883 I/bluedroid( 2680): get_profile_interface pan
01-03 18:26:03.885 D/HeadsetStateMachine( 2680): Disconnected process message: 10, size: 0
01-03 18:26:03.885 D/HeadsetPhoneState( 2680): sendDeviceStateChanged. mService=0 mSignal=0 mRoam=0 mBatteryCharge=3
01-03 18:26:03.885 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@236fdb8
01-03 18:26:03.885 D/HeadsetStateMachine( 2680): Disconnected process message: 11, size: 0
01-03 18:26:03.886 D/BtGatt.DebugUtils( 2680): handleDebugAction() action=null
01-03 18:26:03.887 D/BtGatt.GattService( 2680): Received start request. Starting profile...
01-03 18:26:03.887 D/BtGatt.GattService( 2680): start()
01-03 18:26:03.887 I/bluedroid( 2680): get_profile_interface gatt
01-03 18:26:03.888 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@236fdb8
01-03 18:26:03.888 D/BtGatt.AdvertiseManager( 2680): advertise manager created
01-03 18:26:03.899 D/BluetoothMapService( 2680): inside BluetoothMapObexConnection
01-03 18:26:03.900 D/BluetoothMapService( 2680): supportedMessageTypes 14
01-03 18:26:03.900 D/BluetoothMapService( 2680): masId 0
01-03 18:26:03.900 D/BluetoothMapService( 2680): inside BluetoothMapObexConnection
01-03 18:26:03.900 D/BluetoothMapService( 2680): masId 1
01-03 18:26:03.900 D/BluetoothMapService( 2680): Inside initBinder
01-03 18:26:03.900 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@236fdb8
01-03 18:26:03.902 D/BluetoothMapService( 2680): Received start request. Starting profile...
01-03 18:26:03.902 D/BluetoothMapService( 2680): start()
01-03 18:26:03.905 D/BluetoothMapService( 2680): Registering observer
01-03 18:26:03.911 V/BluetoothMapService( 2680): Handler(): got msg=1
01-03 18:26:03.913 D/BluetoothAdapterState( 2680): CURRENT_STATE=PENDING, MESSAGE = STARTED, isTurningOn=true, isTurningOff=false
01-03 18:26:03.913 I/bluedroid( 2680): enable
01-03 18:26:03.914 I/bt_hci_bdroid( 2680): init
01-03 18:26:03.917 I/bt_vendor( 2680): init
01-03 18:26:03.917 E/BTEventHandler( 2680): A4WP is not supported
01-03 18:26:03.917 D/bt_userial( 2680): userial_init
01-03 18:26:03.918 I/GKI_LINUX( 2680): gki_task_entry task_id=0 [BTU] starting
01-03 18:26:03.918 I/bt-btu ( 2680): btu_task pending for preload complete event
01-03 18:26:03.920 I/bt_vendor( 2680): userial vendor open: opening /dev/rtk_btusb
01-03 18:26:03.920 E/bt_vendor( 2680): userial vendor open: unable to open /dev/rtk_btusb: Permission denied
01-03 18:26:03.921 E/bt_userial( 2680): userial_open opened wrong number of ports: got 0, expected 1.
01-03 18:26:03.921 I/bt-btu ( 2680): btu_task received preload complete event
01-03 18:26:03.923 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x0001
01-03 18:26:03.923 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x001f
01-03 18:26:03.937 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x0003
01-03 18:26:03.937 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x1487
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_HCI
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_L2CAP
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_RFCOMM
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_AVDT
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_AVRC
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_A2D
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_BNEP
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTM
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_HID_HOST
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_GAP
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_PAN
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_SDP
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_GATT
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_SMP
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_HID_DEV
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTAPP
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTIF
01-03 18:26:03.941 I/ ( 2680): BTE_InitTraceLevels -- TRC_LATENCY_AUDIO
01-03 18:26:03.945 E/bt_userial( 2680): userial_write error writing to serial port: Bad file number
01-03 18:26:04.880 E/wpa_supplicant( 3579): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:26:04.880 E/wpa_supplicant( 3579): nl80211: Could not set interface 'wlan0' UP
01-03 18:26:04.881 E/wpa_supplicant( 3579): wlan0: Failed to initialize driver interface
01-03 18:26:05.051 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:26:05.051 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:26:05.051 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:26:05.051 D/alsa_pcm( 1321): pcm_close()
01-03 18:26:06.909 I/auditd ( 3600): Starting up
01-03 18:26:06.911 E/auditd ( 3600): Failed on audit_set_pid with error: Protocol not supported
01-03 18:26:06.911 I/auditd ( 3600): Exiting
01-03 18:26:10.059 E/Lights ( 1576): write_int failed to open sys/class/leds/rk29_key_led/brightness
01-03 18:26:11.291 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:11.392 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:11.493 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:11.594 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:11.696 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:11.797 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:11.898 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:11.945 I/auditd ( 3604): Starting up
01-03 18:26:11.946 E/auditd ( 3604): Failed on audit_set_pid with error: Protocol not supported
01-03 18:26:11.946 I/auditd ( 3604): Exiting
01-03 18:26:11.999 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:12.100 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:12.201 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:12.302 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:12.403 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:12.504 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:12.605 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:12.706 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:12.807 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:12.909 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:13.010 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:13.111 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:13.212 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:13.313 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:13.414 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:13.515 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:13.617 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:13.718 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:13.820 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:13.921 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:14.022 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:14.123 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:14.224 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:14.325 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:14.426 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:14.527 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:14.628 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:14.729 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:14.831 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:14.932 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:15.033 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:15.134 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:15.235 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:15.336 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:15.437 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:15.538 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:15.639 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:15.740 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:15.842 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:15.928 D/BluetoothAdapterState( 2680): CURRENT_STATE=PENDING, MESSAGE = ENABLE_TIMEOUT, isTurningOn=true, isTurningOff=false
01-03 18:26:15.928 E/BluetoothAdapterState( 2680): Error enabling Bluetooth
01-03 18:26:15.928 E/bt-btif ( 2680): bte_ssr_cleanup
01-03 18:26:15.929 I/BluetoothServiceJni( 2680): ssrcleanupNative: return from cleanup
01-03 18:26:15.929 D/BluetoothAdapterService( 2680): mProfilesStarted : true supportedProfileServices.length : 8
01-03 18:26:15.933 D/HeadsetService( 2680): Received stop request...Stopping profile...
01-03 18:26:15.936 D/HeadsetStateMachine( 2680): Exit Disconnected: -1
01-03 18:26:15.940 D/A2dpService( 2680): Received stop request...Stopping profile...
01-03 18:26:15.940 D/A2dpStateMachine( 2680): Exit Disconnected: -1
01-03 18:26:15.943 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:15.958 D/BluetoothAdapterProperties( 2680): Setting state to 10
01-03 18:26:15.958 I/BluetoothAdapterState( 2680): Bluetooth adapter state changed: 11-> 10
01-03 18:26:15.960 D/BluetoothManagerService( 1576): Message: 60
01-03 18:26:15.961 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 11, newState=10
01-03 18:26:15.961 D/BluetoothManagerService( 1576): Broadcasting onBluetoothStateChange(false) to 17 receivers.
01-03 18:26:15.962 I/BluetoothAdapterState( 2680): Entering OffState
01-03 18:26:15.963 W/BluetoothHeadsetServiceJni( 2680): Cleaning up Bluetooth Handsfree Interface...
01-03 18:26:15.963 W/BluetoothHeadsetServiceJni( 2680): Cleaning up Bluetooth Handsfree callback object
01-03 18:26:15.963 D/BluetoothPan( 2411): onBluetoothStateChange on: false
01-03 18:26:15.966 D/HidService( 2680): Received stop request...Stopping profile...
01-03 18:26:15.968 E/BluetoothPan( 2411):
01-03 18:26:15.968 E/BluetoothPan( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPan$2@14c69600
01-03 18:26:15.968 E/BluetoothPan( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:15.968 E/BluetoothPan( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:15.968 E/BluetoothPan( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:15.968 E/BluetoothPan( 2411): at android.bluetooth.BluetoothPan$1.onBluetoothStateChange(BluetoothPan.java:206)
01-03 18:26:15.968 E/BluetoothPan( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:15.968 E/BluetoothPan( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:15.972 D/BluetoothInputDevice( 3417): onBluetoothStateChange: up=false
01-03 18:26:15.973 D/HealthService( 2680): Received stop request...Stopping profile...
01-03 18:26:15.977 E/BluetoothInputDevice( 3417):
01-03 18:26:15.977 E/BluetoothInputDevice( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothInputDevice$2@2754f75a
01-03 18:26:15.977 E/BluetoothInputDevice( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:15.977 E/BluetoothInputDevice( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:15.977 E/BluetoothInputDevice( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:15.977 E/BluetoothInputDevice( 3417): at android.bluetooth.BluetoothInputDevice$1.onBluetoothStateChange(BluetoothInputDevice.java:227)
01-03 18:26:15.977 E/BluetoothInputDevice( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:15.977 E/BluetoothInputDevice( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:15.978 I/GKI_LINUX( 2680): gki_task task_id=2 [A2DP-MEDIA] terminating
01-03 18:26:15.979 D/BluetoothHeadset( 1998): onBluetoothStateChange: up=false
01-03 18:26:15.979 I/GKI_LINUX( 2680): GKI_exit_task 2 done
01-03 18:26:15.979 I/GKI_LINUX( 2680): GKI_shutdown(): task [A2DP-MEDIA] terminated
01-03 18:26:15.979 D/BluetoothA2dp( 1576): onBluetoothStateChange: up=false
01-03 18:26:15.982 D/PanService( 2680): Received stop request...Stopping profile...
01-03 18:26:15.982 E/BluetoothA2dp( 1576):
01-03 18:26:15.982 E/BluetoothA2dp( 1576): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dp$2@3214f02c
01-03 18:26:15.982 E/BluetoothA2dp( 1576): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:15.982 E/BluetoothA2dp( 1576): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:15.982 E/BluetoothA2dp( 1576): at android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange(BluetoothA2dp.java:126)
01-03 18:26:15.982 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.sendBluetoothStateCallback(BluetoothManagerService.java:761)
01-03 18:26:15.982 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.bluetoothStateChangeHandler(BluetoothManagerService.java:1507)
01-03 18:26:15.982 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.access$3700(BluetoothManagerService.java:68)
01-03 18:26:15.982 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:1226)
01-03 18:26:15.982 E/BluetoothA2dp( 1576): at android.os.Handler.dispatchMessage(Handler.java:102)
01-03 18:26:15.982 E/BluetoothA2dp( 1576): at android.os.Looper.loop(Looper.java:135)
01-03 18:26:15.982 E/BluetoothA2dp( 1576): at android.os.HandlerThread.run(HandlerThread.java:61)
01-03 18:26:15.982 E/BluetoothA2dp( 1576): at com.android.server.ServiceThread.run(ServiceThread.java:46)
01-03 18:26:15.983 D/BluetoothA2dpSink( 3417): onBluetoothStateChange: up=false
01-03 18:26:15.985 E/BluetoothA2dpSink( 3417):
01-03 18:26:15.985 E/BluetoothA2dpSink( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dpSink$2@3ce366d5
01-03 18:26:15.985 E/BluetoothA2dpSink( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:15.985 E/BluetoothA2dpSink( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:15.985 E/BluetoothA2dpSink( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:15.985 E/BluetoothA2dpSink( 3417): at android.bluetooth.BluetoothA2dpSink$1.onBluetoothStateChange(BluetoothA2dpSink.java:139)
01-03 18:26:15.985 E/BluetoothA2dpSink( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:15.985 E/BluetoothA2dpSink( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:15.987 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:26:15.987 D/BtGatt.DebugUtils( 2680): handleDebugAction() action=null
01-03 18:26:15.988 D/BluetoothAvrcpController( 3417): onBluetoothStateChange: up=false
01-03 18:26:15.989 D/BtGatt.GattService( 2680): Received stop request...Stopping profile...
01-03 18:26:15.989 D/BtGatt.GattService( 2680): stop()
01-03 18:26:15.990 D/BtGatt.AdvertiseManager( 2680): advertise clients cleared
01-03 18:26:15.994 E/BluetoothAvrcpController( 3417):
01-03 18:26:15.994 E/BluetoothAvrcpController( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothAvrcpController$2@13e5deea
01-03 18:26:15.994 E/BluetoothAvrcpController( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:15.994 E/BluetoothAvrcpController( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:15.994 E/BluetoothAvrcpController( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:15.994 E/BluetoothAvrcpController( 3417): at android.bluetooth.BluetoothAvrcpController$1.onBluetoothStateChange(BluetoothAvrcpController.java:80)
01-03 18:26:15.994 E/BluetoothAvrcpController( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:15.994 E/BluetoothAvrcpController( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:15.997 D/BluetoothMap( 3417): onBluetoothStateChange: up=false
01-03 18:26:15.998 D/BluetoothMapService( 2680): Received stop request...Stopping profile...
01-03 18:26:15.998 D/BluetoothMapService( 2680): stop()
01-03 18:26:16.000 D/BluetoothMapService( 2680): MAP Service closeService in
01-03 18:26:16.000 E/BluetoothMap( 3417):
01-03 18:26:16.000 E/BluetoothMap( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothMap$2@c26ed8b
01-03 18:26:16.000 E/BluetoothMap( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:16.000 E/BluetoothMap( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:16.000 E/BluetoothMap( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:16.000 E/BluetoothMap( 3417): at android.bluetooth.BluetoothMap$1.onBluetoothStateChange(BluetoothMap.java:64)
01-03 18:26:16.000 E/BluetoothMap( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:16.000 E/BluetoothMap( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:16.000 D/BluetoothMapService( 2680): Unregistering Email account observer
01-03 18:26:16.001 D/BluetoothHeadset( 3417): onBluetoothStateChange: up=false
01-03 18:26:16.002 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:26:16.003 D/BluetoothHeadsetClient( 3417): onBluetoothStateChange: up=false
01-03 18:26:16.005 E/BluetoothHeadsetClient( 3417):
01-03 18:26:16.005 E/BluetoothHeadsetClient( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothHeadsetClient$2@29514878
01-03 18:26:16.005 E/BluetoothHeadsetClient( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:16.005 E/BluetoothHeadsetClient( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:16.005 E/BluetoothHeadsetClient( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:16.005 E/BluetoothHeadsetClient( 3417): at android.bluetooth.BluetoothHeadsetClient$1.onBluetoothStateChange(BluetoothHeadsetClient.java:382)
01-03 18:26:16.005 E/BluetoothHeadsetClient( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:16.005 E/BluetoothHeadsetClient( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:16.006 W/BluetoothHidServiceJni( 2680): Cleaning up Bluetooth HID Interface...
01-03 18:26:16.007 W/bt-btif ( 2680): cleanup: HH disabling or disabled already, status = 0
01-03 18:26:16.007 W/BluetoothHidServiceJni( 2680): Cleaning up Bluetooth GID callback object
01-03 18:26:16.007 D/BluetoothInputDevice( 2411): onBluetoothStateChange: up=false
01-03 18:26:16.007 W/BluetoothHealthServiceJni( 2680): Cleaning up Bluetooth Health Interface...
01-03 18:26:16.008 W/BluetoothHealthServiceJni( 2680): Cleaning up Bluetooth Health object
01-03 18:26:16.010 W/BluetoothPanServiceJni( 2680): Cleaning up Bluetooth PAN Interface...
01-03 18:26:16.010 W/BluetoothPanServiceJni( 2680): Cleaning up Bluetooth PAN callback object
01-03 18:26:16.012 E/BluetoothInputDevice( 2411):
01-03 18:26:16.012 E/BluetoothInputDevice( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothInputDevice$2@2082d483
01-03 18:26:16.012 E/BluetoothInputDevice( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:16.012 E/BluetoothInputDevice( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:16.012 E/BluetoothInputDevice( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:16.012 E/BluetoothInputDevice( 2411): at android.bluetooth.BluetoothInputDevice$1.onBluetoothStateChange(BluetoothInputDevice.java:227)
01-03 18:26:16.012 E/BluetoothInputDevice( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:16.012 E/BluetoothInputDevice( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:16.013 D/BluetoothA2dp( 3417): onBluetoothStateChange: up=false
01-03 18:26:16.013 D/BtGatt.GattService( 2680): cleanup()
01-03 18:26:16.014 W/bt-btif ( 2680): GATTC Module not enabled/already disabled
01-03 18:26:16.014 W/bt-btif ( 2680): GATTS Module not enabled/already disabled
01-03 18:26:16.014 D/BluetoothMapService( 2680): cleanup()
01-03 18:26:16.015 D/BluetoothMapService( 2680): MAP Service closeService in
01-03 18:26:16.015 E/BluetoothA2dp( 3417):
01-03 18:26:16.015 E/BluetoothA2dp( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dp$2@2c16db05
01-03 18:26:16.015 E/BluetoothA2dp( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:16.015 E/BluetoothA2dp( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:16.015 E/BluetoothA2dp( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:16.015 E/BluetoothA2dp( 3417): at android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange(BluetoothA2dp.java:126)
01-03 18:26:16.015 E/BluetoothA2dp( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:16.015 E/BluetoothA2dp( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:16.016 D/BluetoothMap( 2411): onBluetoothStateChange: up=false
01-03 18:26:16.017 E/BluetoothMap( 2411):
01-03 18:26:16.017 E/BluetoothMap( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothMap$2@1e420e39
01-03 18:26:16.017 E/BluetoothMap( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:16.017 E/BluetoothMap( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:16.017 E/BluetoothMap( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:16.017 E/BluetoothMap( 2411): at android.bluetooth.BluetoothMap$1.onBluetoothStateChange(BluetoothMap.java:64)
01-03 18:26:16.017 E/BluetoothMap( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:16.017 E/BluetoothMap( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:16.018 D/BluetoothPbap( 2411): onBluetoothStateChange: up=false
01-03 18:26:16.019 E/BluetoothPbap( 2411):
01-03 18:26:16.019 E/BluetoothPbap( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPbap$2@3b8b9c7e
01-03 18:26:16.019 E/BluetoothPbap( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:16.019 E/BluetoothPbap( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:16.019 E/BluetoothPbap( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:16.019 E/BluetoothPbap( 2411): at android.bluetooth.BluetoothPbap$1.onBluetoothStateChange(BluetoothPbap.java:121)
01-03 18:26:16.019 E/BluetoothPbap( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:16.019 E/BluetoothPbap( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:16.019 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:26:16.020 D/BluetoothPan( 3417): onBluetoothStateChange on: false
01-03 18:26:16.020 E/BluetoothPan( 3417):
01-03 18:26:16.020 E/BluetoothPan( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPan$2@d75ae68
01-03 18:26:16.020 E/BluetoothPan( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:16.020 E/BluetoothPan( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:16.020 E/BluetoothPan( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:16.020 E/BluetoothPan( 3417): at android.bluetooth.BluetoothPan$1.onBluetoothStateChange(BluetoothPan.java:206)
01-03 18:26:16.020 E/BluetoothPan( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:16.020 E/BluetoothPan( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:16.021 D/BluetoothManagerService( 1576): Bluetooth State Change Intent: 11 -> 10
01-03 18:26:16.027 E/BluetoothManagerService( 1576): recoverBluetoothServiceFromError
01-03 18:26:16.040 W/ContextImpl( 2411): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1721 android.content.ContextWrapper.startService:522 android.content.ContextWrapper.startService:522 com.android.settings.bluetooth.DockEventReceiver.beginStartingService:134 com.android.settings.bluetooth.DockEventReceiver.onReceive:115
01-03 18:26:16.041 D/Index ( 2411): Deleting data for locale 'de_DE' took 9 millis
01-03 18:26:16.045 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:16.050 D/Index ( 2411): Indexing locale 'de_DE' took 9 millis
01-03 18:26:16.068 D/DockEventReceiver( 2411): finishStartingService: stopping service
01-03 18:26:16.098 D/AuthorizationBluetoothService( 2126): Received Bluetooth event: Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x14000010 cmp=com.google.android.gms/.auth.be.proximity.authorization.bt.AuthorizationBluetoothService$BluetoothStateChangeReceiver (has extras) }.
01-03 18:26:16.110 E/BTEventHandler( 2680): A4WP is not supported
01-03 18:26:16.146 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:16.247 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:16.247 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:26:16.255 E/WifiStateMachine( 1576): Failed 6 times to start supplicant, unload driver
01-03 18:26:16.307 D/Index ( 2411): Deleting data for locale 'de_DE' took 7 millis
01-03 18:26:16.538 D/BluetoothManagerService( 1576): Sending off request.
01-03 18:26:16.539 D/BluetoothAdapterState( 2680): CURRENT_STATE=OFF, MESSAGE = USER_TURN_OFF
01-03 18:26:16.540 D/BluetoothManagerService( 1576): Calling onBluetoothServiceDown callbacks
01-03 18:26:16.540 D/BluetoothManagerService( 1576): Broadcasting onBluetoothServiceDown() to 6 receivers.
01-03 18:26:16.542 D/BluetoothManagerService( 1576): Calling onQBluetoothServiceDown callbacks
01-03 18:26:16.542 D/BluetoothManagerService( 1576): Broadcasting onQBluetoothServiceDown() to 0 receivers.
01-03 18:26:16.551 W/bt_userial( 2680): userial_close_reader Already closed userial reader thread
01-03 18:26:16.553 I/GKI_LINUX( 2680): gki_task task_id=0 [BTU] terminating
01-03 18:26:16.554 I/GKI_LINUX( 2680): GKI_exit_task 0 done
01-03 18:26:16.554 I/GKI_LINUX( 2680): GKI_shutdown(): task [BTU] terminated
01-03 18:26:16.554 E/BluetoothServiceJni( 2680): Callback env check fail: env: 0x42478ac0, callback: 0x426a7940
01-03 18:26:16.554 E/BluetoothServiceJni( 2680): Callback: 'adapter_state_change_callback' is not called on the correct thread
01-03 18:26:16.555 I/GKI_LINUX( 2680): gki_task task_id=1 [BTIF] terminating
01-03 18:26:16.556 I/GKI_LINUX( 2680): GKI_exit_task 1 done
01-03 18:26:16.556 I/GKI_LINUX( 2680): GKI_shutdown(): task [BTIF] terminated
01-03 18:26:16.557 I/BluetoothServiceJni( 2680): cleanupNative: return from cleanup
01-03 18:26:16.963 I/auditd ( 3609): Starting up
01-03 18:26:16.963 E/auditd ( 3609): Failed on audit_set_pid with error: Protocol not supported
01-03 18:26:16.963 I/auditd ( 3609): Exiting
01-03 18:26:17.550 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:26:17.551 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:26:18.401 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:26:18.401 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:26:18.406 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:26:18.731 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:26:18.733 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:26:18.733 E/SoftapController( 1322): Softap fwReload failed
01-03 18:26:18.736 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '68 softap fwreload wlan0 STA' failed with '400 68 SoftAP command has failed'
01-03 18:26:18.738 D/CommandListener( 1322): Setting iface cfg
01-03 18:26:18.738 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:26:18.739 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:26:18.743 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:26:18.780 I/wpa_supplicant( 3616): Successfully initialized wpa_supplicant
01-03 18:26:18.785 I/wpa_supplicant( 3616): rfkill: Cannot open RFKILL control device
01-03 18:26:18.844 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:26:18.855 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:26:19.547 D/BluetoothManagerService( 1576): Message: 42
01-03 18:26:19.547 D/BluetoothManagerService( 1576): MESSAGE_RESTART_BLUETOOTH_SERVICE: Restart IBluetooth service
01-03 18:26:19.555 D/BluetoothAdapterState( 2680): make
01-03 18:26:19.557 I/bluedroid( 2680): init
01-03 18:26:19.557 I/BluetoothAdapterState( 2680): Entering OffState
01-03 18:26:19.558 I/bte_conf( 2680): bte_load_conf attempt to load stack conf from /etc/bluetooth/bt_stack.conf
01-03 18:26:19.559 I/bte_conf( 2680): bte_load_ble_conf attempt to load ble stack conf from /etc/bluetooth/ble_stack.conf
01-03 18:26:19.559 E/bt_osi_config( 2680): config_new unable to open file '/etc/bluetooth/ble_stack.conf': No such file or directory
01-03 18:26:19.559 I/bte_conf( 2680): bte_load_ble_conf file >/etc/bluetooth/ble_stack.conf< not found
01-03 18:26:19.559 I/bluedroid( 2680): get_profile_interface socket
01-03 18:26:19.559 I/bluedroid( 2680): get_profile_interface map_client
01-03 18:26:19.559 I/GKI_LINUX( 2680): gki_task_entry task_id=1 [BTIF] starting
01-03 18:26:19.561 D/BluetoothAdapterProperties( 2680): Address is:22:22:DE:59:9F:D7
01-03 18:26:19.565 D/BluetoothAdapterProperties( 2680): Name is: Rockchip
01-03 18:26:19.565 D/BluetoothManagerService( 1576): Bluetooth Adapter name changed to Rockchip
01-03 18:26:19.566 D/BluetoothManagerService( 1576): Stored Bluetooth name: Rockchip
01-03 18:26:19.566 D/BluetoothManagerService( 1576): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
01-03 18:26:19.566 D/BluetoothManagerService( 1576): Message: 40
01-03 18:26:19.567 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
01-03 18:26:19.568 I/bluedroid( 2680): config_hci_snoop_log
01-03 18:26:19.569 D/BluetoothManagerService( 1576): Calling onBluetoothServiceUp callbacks
01-03 18:26:19.569 D/BluetoothManagerService( 1576): Broadcasting onBluetoothServiceUp() to 6 receivers.
01-03 18:26:19.579 D/BluetoothAdapterState( 2680): CURRENT_STATE=OFF, MESSAGE = USER_TURN_ON
01-03 18:26:19.579 D/BluetoothAdapterProperties( 2680): Setting state to 11
01-03 18:26:19.579 I/BluetoothAdapterState( 2680): Bluetooth adapter state changed: 10-> 11
01-03 18:26:19.581 D/BluetoothManagerService( 1576): Message: 60
01-03 18:26:19.581 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 10, newState=11
01-03 18:26:19.581 D/BluetoothManagerService( 1576): Bluetooth State Change Intent: 10 -> 11
01-03 18:26:19.593 D/BluetoothBondStateMachine( 2680): make
01-03 18:26:19.599 I/BluetoothBondStateMachine( 2680): StableState(): Entering Off State
01-03 18:26:19.599 D/BluetoothAdapterService( 2680): checkA2dpState: isA2dpSinkEnabled = false
01-03 18:26:19.599 E/BluetoothAdapterService( 2680): checkA2dpState: returning
01-03 18:26:19.599 D/BluetoothAdapterService( 2680): checkHidState: isHidDev = false
01-03 18:26:19.599 E/BluetoothAdapterService( 2680): checkHidState: returning
01-03 18:26:19.599 D/BluetoothAdapterService( 2680): checkHfpState: isHfpClientEnabled = false
01-03 18:26:19.599 E/BluetoothAdapterService( 2680): checkHfpState: returning
01-03 18:26:19.606 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@33a17d3a
01-03 18:26:19.608 D/HeadsetService( 2680): Received start request. Starting profile...
01-03 18:26:19.609 D/HeadsetStateMachine( 2680): make
01-03 18:26:19.621 D/HeadsetStateMachine( 2680): max_hf_connections = 1
01-03 18:26:19.621 I/bluedroid( 2680): get_profile_interface handsfree
01-03 18:26:19.641 D/HeadsetStateMachine( 2680): Enter Disconnected: -2, size: 0
01-03 18:26:19.642 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@33a17d3a
01-03 18:26:19.645 D/A2dpService( 2680): Received start request. Starting profile...
01-03 18:26:19.645 I/bluedroid( 2680): get_profile_interface avrcp
01-03 18:26:19.662 V/AudioService( 1576): updateRemoteControllerOnExistingMediaPlayers: size of Player list: 0
01-03 18:26:19.662 E/AudioService( 1576): No RCC entry present to update
01-03 18:26:19.663 E/RemoteController( 2680): Cannot set synchronization mode on an unregistered RemoteController
01-03 18:26:19.663 D/A2dpStateMachine( 2680): make
01-03 18:26:19.666 I/bluedroid( 2680): get_profile_interface a2dp
01-03 18:26:19.667 I/GKI_LINUX( 2680): gki_task_entry task_id=2 [A2DP-MEDIA] starting
01-03 18:26:19.668 D/bt-btif ( 2680): btif_av_state_idle_handler event:BTIF_SM_ENTER_EVT flags 0
01-03 18:26:19.670 D/A2dpService( 2680): setA2dpService(): set to: null
01-03 18:26:19.674 D/A2dpStateMachine( 2680): Enter Disconnected: -2
01-03 18:26:19.682 I/Telecom ( 1576): BluetoothPhoneService: queryPhoneState
01-03 18:26:19.685 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@33a17d3a
01-03 18:26:19.687 D/HidService( 2680): Received start request. Starting profile...
01-03 18:26:19.687 I/bluedroid( 2680): get_profile_interface hidhost
01-03 18:26:19.701 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@33a17d3a
01-03 18:26:19.703 D/HeadsetStateMachine( 2680): Disconnected process message: 10, size: 0
01-03 18:26:19.703 D/HealthService( 2680): Received start request. Starting profile...
01-03 18:26:19.705 I/BluetoothAdapterService( 2680): skipping com.android.bluetooth.hid.HidDevService (disabled)
01-03 18:26:19.705 I/BluetoothAdapterState( 2680): Entering PendingCommandState State: isTurningOn()=true, isTurningOff()=false
01-03 18:26:19.707 D/HeadsetPhoneState( 2680): sendDeviceStateChanged. mService=0 mSignal=0 mRoam=0 mBatteryCharge=3
01-03 18:26:19.707 D/HeadsetStateMachine( 2680): Disconnected process message: 11, size: 0
01-03 18:26:19.710 I/bluedroid( 2680): get_profile_interface health
01-03 18:26:19.713 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@33a17d3a
01-03 18:26:19.716 D/PanService( 2680): Received start request. Starting profile...
01-03 18:26:19.716 D/BluetoothPanServiceJni( 2680): initializeNative(L110): pan
01-03 18:26:19.716 I/bluedroid( 2680): get_profile_interface pan
01-03 18:26:19.720 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@33a17d3a
01-03 18:26:19.721 D/BtGatt.DebugUtils( 2680): handleDebugAction() action=null
01-03 18:26:19.721 D/AuthorizationBluetoothService( 2126): Received Bluetooth event: Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x14000010 cmp=com.google.android.gms/.auth.be.proximity.authorization.bt.AuthorizationBluetoothService$BluetoothStateChangeReceiver (has extras) }.
01-03 18:26:19.723 D/BtGatt.GattService( 2680): Received start request. Starting profile...
01-03 18:26:19.723 D/BtGatt.GattService( 2680): start()
01-03 18:26:19.723 I/bluedroid( 2680): get_profile_interface gatt
01-03 18:26:19.723 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@33a17d3a
01-03 18:26:19.723 D/BtGatt.AdvertiseManager( 2680): advertise manager created
01-03 18:26:19.741 D/BluetoothMapService( 2680): inside BluetoothMapObexConnection
01-03 18:26:19.741 D/BluetoothMapService( 2680): supportedMessageTypes 14
01-03 18:26:19.741 D/BluetoothMapService( 2680): masId 0
01-03 18:26:19.741 D/BluetoothMapService( 2680): masId 1
01-03 18:26:19.742 D/BluetoothMapService( 2680): Inside initBinder
01-03 18:26:19.742 D/BluetoothAdapterService( 2680): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@33a17d3a
01-03 18:26:19.745 D/BluetoothMapService( 2680): Received start request. Starting profile...
01-03 18:26:19.745 D/BluetoothMapService( 2680): start()
01-03 18:26:19.749 D/BluetoothMapService( 2680): Registering observer
01-03 18:26:19.754 V/BluetoothMapService( 2680): Handler(): got msg=1
01-03 18:26:19.757 D/BluetoothAdapterState( 2680): CURRENT_STATE=PENDING, MESSAGE = STARTED, isTurningOn=true, isTurningOff=false
01-03 18:26:19.757 I/bluedroid( 2680): enable
01-03 18:26:19.758 I/bt_hci_bdroid( 2680): init
01-03 18:26:19.759 I/GKI_LINUX( 2680): gki_task_entry task_id=0 [BTU] starting
01-03 18:26:19.760 I/bt-btu ( 2680): btu_task pending for preload complete event
01-03 18:26:19.762 E/BTEventHandler( 2680): A4WP is not supported
01-03 18:26:19.763 I/bt_vendor( 2680): init
01-03 18:26:19.763 D/bt_userial( 2680): userial_init
01-03 18:26:19.765 I/bt_vendor( 2680): userial vendor open: opening /dev/rtk_btusb
01-03 18:26:19.765 E/bt_vendor( 2680): userial vendor open: unable to open /dev/rtk_btusb: Permission denied
01-03 18:26:19.765 E/bt_userial( 2680): userial_open opened wrong number of ports: got 0, expected 1.
01-03 18:26:19.765 I/bt-btu ( 2680): btu_task received preload complete event
01-03 18:26:19.767 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x0001
01-03 18:26:19.767 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x001f
01-03 18:26:19.780 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x0003
01-03 18:26:19.780 W/bt-l2cap( 2680): L2CAP - L2CA_Register() called for PSM: 0x1487
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_HCI
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_L2CAP
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_RFCOMM
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_AVDT
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_AVRC
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_A2D
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_BNEP
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTM
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_HID_HOST
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_GAP
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_PAN
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_SDP
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_GATT
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_SMP
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_HID_DEV
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTAPP
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_BTIF
01-03 18:26:19.787 I/ ( 2680): BTE_InitTraceLevels -- TRC_LATENCY_AUDIO
01-03 18:26:19.789 E/bt_userial( 2680): userial_write error writing to serial port: Bad file number
01-03 18:26:21.778 I/auditd ( 3633): Starting up
01-03 18:26:21.779 E/auditd ( 3633): Failed on audit_set_pid with error: Protocol not supported
01-03 18:26:21.779 I/auditd ( 3633): Exiting
01-03 18:26:22.559 E/wpa_supplicant( 3616): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:26:22.559 E/wpa_supplicant( 3616): nl80211: Could not set interface 'wlan0' UP
01-03 18:26:22.559 E/wpa_supplicant( 3616): wlan0: Failed to initialize driver interface
01-03 18:26:26.592 I/auditd ( 3636): Starting up
01-03 18:26:26.594 E/auditd ( 3636): Failed on audit_set_pid with error: Protocol not supported
01-03 18:26:26.594 I/auditd ( 3636): Exiting
01-03 18:26:28.954 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:29.055 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:29.156 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:29.257 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:29.359 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:29.460 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:29.561 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:29.662 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:29.763 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:29.864 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:29.965 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:30.066 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:30.167 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:30.270 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:30.371 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:30.472 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:30.573 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:30.674 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:30.775 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:30.876 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:30.978 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:31.079 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:31.180 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:31.282 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:31.383 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:31.484 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:31.582 E/Lights ( 1576): write_int failed to open sys/class/leds/rk29_key_led/brightness
01-03 18:26:31.585 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:31.625 I/auditd ( 3639): Starting up
01-03 18:26:31.626 E/auditd ( 3639): Failed on audit_set_pid with error: Protocol not supported
01-03 18:26:31.626 I/auditd ( 3639): Exiting
01-03 18:26:31.687 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:31.744 D/WifiService( 1576): setWifiEnabled: false pid=3417, uid=10013
01-03 18:26:31.744 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:26:31.748 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:26:31.756 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:26:31.761 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:26:31.761 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:26:31.761 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:26:31.761 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:26:31.761 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:26:31.767 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:26:31.776 D/BluetoothAdapterState( 2680): CURRENT_STATE=PENDING, MESSAGE = ENABLE_TIMEOUT, isTurningOn=true, isTurningOff=false
01-03 18:26:31.776 E/BluetoothAdapterState( 2680): Error enabling Bluetooth
01-03 18:26:31.776 E/bt-btif ( 2680): bte_ssr_cleanup
01-03 18:26:31.776 I/BluetoothServiceJni( 2680): ssrcleanupNative: return from cleanup
01-03 18:26:31.776 D/BluetoothAdapterService( 2680): mProfilesStarted : true supportedProfileServices.length : 8
01-03 18:26:31.780 D/HeadsetService( 2680): Received stop request...Stopping profile...
01-03 18:26:31.782 D/HeadsetStateMachine( 2680): Exit Disconnected: -1
01-03 18:26:31.790 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:31.792 D/A2dpService( 2680): Received stop request...Stopping profile...
01-03 18:26:31.794 D/A2dpStateMachine( 2680): Exit Disconnected: -1
01-03 18:26:31.803 D/BluetoothAdapterProperties( 2680): Setting state to 10
01-03 18:26:31.803 I/BluetoothAdapterState( 2680): Bluetooth adapter state changed: 11-> 10
01-03 18:26:31.804 D/BluetoothManagerService( 1576): Message: 60
01-03 18:26:31.804 D/HidService( 2680): Received stop request...Stopping profile...
01-03 18:26:31.804 D/BluetoothManagerService( 1576): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 11, newState=10
01-03 18:26:31.805 D/BluetoothManagerService( 1576): Broadcasting onBluetoothStateChange(false) to 17 receivers.
01-03 18:26:31.805 I/BluetoothAdapterState( 2680): Entering OffState
01-03 18:26:31.806 D/BluetoothPan( 2411): onBluetoothStateChange on: false
01-03 18:26:31.810 E/BluetoothPan( 2411):
01-03 18:26:31.810 E/BluetoothPan( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPan$2@14c69600
01-03 18:26:31.810 E/BluetoothPan( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:31.810 E/BluetoothPan( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:31.810 E/BluetoothPan( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:31.810 E/BluetoothPan( 2411): at android.bluetooth.BluetoothPan$1.onBluetoothStateChange(BluetoothPan.java:206)
01-03 18:26:31.810 E/BluetoothPan( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:31.810 E/BluetoothPan( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:31.815 D/BluetoothInputDevice( 3417): onBluetoothStateChange: up=false
01-03 18:26:31.819 W/BluetoothHeadsetServiceJni( 2680): Cleaning up Bluetooth Handsfree Interface...
01-03 18:26:31.819 E/BluetoothInputDevice( 3417):
01-03 18:26:31.819 E/BluetoothInputDevice( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothInputDevice$2@2754f75a
01-03 18:26:31.819 E/BluetoothInputDevice( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:31.819 E/BluetoothInputDevice( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:31.819 E/BluetoothInputDevice( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:31.819 E/BluetoothInputDevice( 3417): at android.bluetooth.BluetoothInputDevice$1.onBluetoothStateChange(BluetoothInputDevice.java:227)
01-03 18:26:31.819 E/BluetoothInputDevice( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:31.819 E/BluetoothInputDevice( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:31.819 W/BluetoothHeadsetServiceJni( 2680): Cleaning up Bluetooth Handsfree callback object
01-03 18:26:31.821 D/HealthService( 2680): Received stop request...Stopping profile...
01-03 18:26:31.821 D/BluetoothHeadset( 1998): onBluetoothStateChange: up=false
01-03 18:26:31.821 D/BluetoothA2dp( 1576): onBluetoothStateChange: up=false
01-03 18:26:31.823 E/BluetoothA2dp( 1576):
01-03 18:26:31.823 E/BluetoothA2dp( 1576): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dp$2@3214f02c
01-03 18:26:31.823 E/BluetoothA2dp( 1576): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:31.823 E/BluetoothA2dp( 1576): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:31.823 E/BluetoothA2dp( 1576): at android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange(BluetoothA2dp.java:126)
01-03 18:26:31.823 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.sendBluetoothStateCallback(BluetoothManagerService.java:761)
01-03 18:26:31.823 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.bluetoothStateChangeHandler(BluetoothManagerService.java:1507)
01-03 18:26:31.823 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService.access$3700(BluetoothManagerService.java:68)
01-03 18:26:31.823 E/BluetoothA2dp( 1576): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:1226)
01-03 18:26:31.823 E/BluetoothA2dp( 1576): at android.os.Handler.dispatchMessage(Handler.java:102)
01-03 18:26:31.823 E/BluetoothA2dp( 1576): at android.os.Looper.loop(Looper.java:135)
01-03 18:26:31.823 E/BluetoothA2dp( 1576): at android.os.HandlerThread.run(HandlerThread.java:61)
01-03 18:26:31.823 E/BluetoothA2dp( 1576): at com.android.server.ServiceThread.run(ServiceThread.java:46)
01-03 18:26:31.824 D/BluetoothA2dpSink( 3417): onBluetoothStateChange: up=false
01-03 18:26:31.825 D/PanService( 2680): Received stop request...Stopping profile...
01-03 18:26:31.825 E/BluetoothA2dpSink( 3417):
01-03 18:26:31.825 E/BluetoothA2dpSink( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dpSink$2@3ce366d5
01-03 18:26:31.825 E/BluetoothA2dpSink( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:31.825 E/BluetoothA2dpSink( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:31.825 E/BluetoothA2dpSink( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:31.825 E/BluetoothA2dpSink( 3417): at android.bluetooth.BluetoothA2dpSink$1.onBluetoothStateChange(BluetoothA2dpSink.java:139)
01-03 18:26:31.825 E/BluetoothA2dpSink( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:31.825 E/BluetoothA2dpSink( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:31.826 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:26:31.827 D/BluetoothAvrcpController( 3417): onBluetoothStateChange: up=false
01-03 18:26:31.827 D/BtGatt.DebugUtils( 2680): handleDebugAction() action=null
01-03 18:26:31.828 E/BluetoothAvrcpController( 3417):
01-03 18:26:31.828 E/BluetoothAvrcpController( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothAvrcpController$2@13e5deea
01-03 18:26:31.828 E/BluetoothAvrcpController( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:31.828 E/BluetoothAvrcpController( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:31.828 E/BluetoothAvrcpController( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:31.828 E/BluetoothAvrcpController( 3417): at android.bluetooth.BluetoothAvrcpController$1.onBluetoothStateChange(BluetoothAvrcpController.java:80)
01-03 18:26:31.828 E/BluetoothAvrcpController( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:31.828 E/BluetoothAvrcpController( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:31.828 D/BtGatt.GattService( 2680): Received stop request...Stopping profile...
01-03 18:26:31.828 D/BtGatt.GattService( 2680): stop()
01-03 18:26:31.828 D/BtGatt.AdvertiseManager( 2680): advertise clients cleared
01-03 18:26:31.830 D/BluetoothMap( 3417): onBluetoothStateChange: up=false
01-03 18:26:31.832 E/BluetoothMap( 3417):
01-03 18:26:31.832 E/BluetoothMap( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothMap$2@c26ed8b
01-03 18:26:31.832 E/BluetoothMap( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:31.832 E/BluetoothMap( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:31.832 E/BluetoothMap( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:31.832 E/BluetoothMap( 3417): at android.bluetooth.BluetoothMap$1.onBluetoothStateChange(BluetoothMap.java:64)
01-03 18:26:31.832 E/BluetoothMap( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:31.832 E/BluetoothMap( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:31.834 D/BluetoothHeadset( 3417): onBluetoothStateChange: up=false
01-03 18:26:31.837 D/BluetoothMapService( 2680): Received stop request...Stopping profile...
01-03 18:26:31.837 D/BluetoothMapService( 2680): stop()
01-03 18:26:31.837 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:26:31.838 D/BluetoothMapService( 2680): MAP Service closeService in
01-03 18:26:31.838 D/BluetoothHeadsetClient( 3417): onBluetoothStateChange: up=false
01-03 18:26:31.838 D/BluetoothMapService( 2680): Unregistering Email account observer
01-03 18:26:31.840 E/BluetoothHeadsetClient( 3417):
01-03 18:26:31.840 E/BluetoothHeadsetClient( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothHeadsetClient$2@29514878
01-03 18:26:31.840 E/BluetoothHeadsetClient( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:31.840 E/BluetoothHeadsetClient( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:31.840 E/BluetoothHeadsetClient( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:31.840 E/BluetoothHeadsetClient( 3417): at android.bluetooth.BluetoothHeadsetClient$1.onBluetoothStateChange(BluetoothHeadsetClient.java:382)
01-03 18:26:31.840 E/BluetoothHeadsetClient( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:31.840 E/BluetoothHeadsetClient( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:31.841 D/BluetoothInputDevice( 2411): onBluetoothStateChange: up=false
01-03 18:26:31.842 E/BluetoothInputDevice( 2411):
01-03 18:26:31.842 E/BluetoothInputDevice( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothInputDevice$2@2082d483
01-03 18:26:31.842 E/BluetoothInputDevice( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:31.842 E/BluetoothInputDevice( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:31.842 E/BluetoothInputDevice( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:31.842 E/BluetoothInputDevice( 2411): at android.bluetooth.BluetoothInputDevice$1.onBluetoothStateChange(BluetoothInputDevice.java:227)
01-03 18:26:31.842 E/BluetoothInputDevice( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:31.842 E/BluetoothInputDevice( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:31.845 I/GKI_LINUX( 2680): gki_task task_id=2 [A2DP-MEDIA] terminating
01-03 18:26:31.846 I/GKI_LINUX( 2680): GKI_exit_task 2 done
01-03 18:26:31.846 I/GKI_LINUX( 2680): GKI_shutdown(): task [A2DP-MEDIA] terminated
01-03 18:26:31.847 W/BluetoothHidServiceJni( 2680): Cleaning up Bluetooth HID Interface...
01-03 18:26:31.847 W/bt-btif ( 2680): cleanup: HH disabling or disabled already, status = 0
01-03 18:26:31.847 D/BluetoothA2dp( 3417): onBluetoothStateChange: up=false
01-03 18:26:31.847 W/BluetoothHidServiceJni( 2680): Cleaning up Bluetooth GID callback object
01-03 18:26:31.849 W/BluetoothHealthServiceJni( 2680): Cleaning up Bluetooth Health Interface...
01-03 18:26:31.851 W/BluetoothHealthServiceJni( 2680): Cleaning up Bluetooth Health object
01-03 18:26:31.851 E/BluetoothA2dp( 3417):
01-03 18:26:31.851 E/BluetoothA2dp( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dp$2@2c16db05
01-03 18:26:31.851 E/BluetoothA2dp( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:31.851 E/BluetoothA2dp( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:31.851 E/BluetoothA2dp( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:31.851 E/BluetoothA2dp( 3417): at android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange(BluetoothA2dp.java:126)
01-03 18:26:31.851 E/BluetoothA2dp( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:31.851 E/BluetoothA2dp( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:31.852 W/BluetoothPanServiceJni( 2680): Cleaning up Bluetooth PAN Interface...
01-03 18:26:31.852 W/BluetoothPanServiceJni( 2680): Cleaning up Bluetooth PAN callback object
01-03 18:26:31.852 D/BluetoothMap( 2411): onBluetoothStateChange: up=false
01-03 18:26:31.855 E/BluetoothMap( 2411):
01-03 18:26:31.855 E/BluetoothMap( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothMap$2@1e420e39
01-03 18:26:31.855 E/BluetoothMap( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:31.855 E/BluetoothMap( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:31.855 E/BluetoothMap( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:31.855 E/BluetoothMap( 2411): at android.bluetooth.BluetoothMap$1.onBluetoothStateChange(BluetoothMap.java:64)
01-03 18:26:31.855 E/BluetoothMap( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:31.855 E/BluetoothMap( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:31.855 D/BtGatt.GattService( 2680): cleanup()
01-03 18:26:31.856 W/bt-btif ( 2680): GATTC Module not enabled/already disabled
01-03 18:26:31.856 W/bt-btif ( 2680): GATTS Module not enabled/already disabled
01-03 18:26:31.856 D/BluetoothMapService( 2680): cleanup()
01-03 18:26:31.857 D/BluetoothMapService( 2680): MAP Service closeService in
01-03 18:26:31.859 D/BluetoothPbap( 2411): onBluetoothStateChange: up=false
01-03 18:26:31.862 E/BluetoothPbap( 2411):
01-03 18:26:31.862 E/BluetoothPbap( 2411): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPbap$2@3b8b9c7e
01-03 18:26:31.862 E/BluetoothPbap( 2411): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:31.862 E/BluetoothPbap( 2411): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:31.862 E/BluetoothPbap( 2411): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:31.862 E/BluetoothPbap( 2411): at android.bluetooth.BluetoothPbap$1.onBluetoothStateChange(BluetoothPbap.java:121)
01-03 18:26:31.862 E/BluetoothPbap( 2411): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:31.862 E/BluetoothPbap( 2411): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:31.862 D/BluetoothHeadset( 1576): onBluetoothStateChange: up=false
01-03 18:26:31.863 D/BluetoothPan( 3417): onBluetoothStateChange on: false
01-03 18:26:31.865 E/BluetoothPan( 3417):
01-03 18:26:31.865 E/BluetoothPan( 3417): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPan$2@d75ae68
01-03 18:26:31.865 E/BluetoothPan( 3417): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1030)
01-03 18:26:31.865 E/BluetoothPan( 3417): at android.app.ContextImpl.unbindService(ContextImpl.java:1837)
01-03 18:26:31.865 E/BluetoothPan( 3417): at android.content.ContextWrapper.unbindService(ContextWrapper.java:557)
01-03 18:26:31.865 E/BluetoothPan( 3417): at android.bluetooth.BluetoothPan$1.onBluetoothStateChange(BluetoothPan.java:206)
01-03 18:26:31.865 E/BluetoothPan( 3417): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
01-03 18:26:31.865 E/BluetoothPan( 3417): at android.os.Binder.execTransact(Binder.java:446)
01-03 18:26:31.866 D/BluetoothManagerService( 1576): Bluetooth State Change Intent: 11 -> 10
01-03 18:26:31.867 E/BluetoothManagerService( 1576): recoverBluetoothServiceFromError
01-03 18:26:31.879 W/ContextImpl( 2411): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1721 android.content.ContextWrapper.startService:522 android.content.ContextWrapper.startService:522 com.android.settings.bluetooth.DockEventReceiver.beginStartingService:134 com.android.settings.bluetooth.DockEventReceiver.onReceive:115
01-03 18:26:31.891 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:31.895 D/DockEventReceiver( 2411): finishStartingService: stopping service
01-03 18:26:31.920 D/AuthorizationBluetoothService( 2126): Received Bluetooth event: Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x14000010 cmp=com.google.android.gms/.auth.be.proximity.authorization.bt.AuthorizationBluetoothService$BluetoothStateChangeReceiver (has extras) }.
01-03 18:26:31.927 E/BTEventHandler( 2680): A4WP is not supported
01-03 18:26:31.996 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:32.097 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:32.197 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:32.298 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:32.369 D/BluetoothManagerService( 1576): Sending off request.
01-03 18:26:32.370 D/BluetoothAdapterState( 2680): CURRENT_STATE=OFF, MESSAGE = USER_TURN_OFF
01-03 18:26:32.371 D/BluetoothManagerService( 1576): Calling onBluetoothServiceDown callbacks
01-03 18:26:32.371 D/BluetoothManagerService( 1576): Broadcasting onBluetoothServiceDown() to 6 receivers.
01-03 18:26:32.375 D/BluetoothManagerService( 1576): Calling onQBluetoothServiceDown callbacks
01-03 18:26:32.375 D/BluetoothManagerService( 1576): Broadcasting onQBluetoothServiceDown() to 0 receivers.
01-03 18:26:32.382 W/bt_userial( 2680): userial_close_reader Already closed userial reader thread
01-03 18:26:32.384 I/GKI_LINUX( 2680): gki_task task_id=0 [BTU] terminating
01-03 18:26:32.385 I/GKI_LINUX( 2680): GKI_exit_task 0 done
01-03 18:26:32.385 I/GKI_LINUX( 2680): GKI_shutdown(): task [BTU] terminated
01-03 18:26:32.385 E/BluetoothServiceJni( 2680): Callback env check fail: env: 0x42478ac0, callback: 0x426a7940
01-03 18:26:32.385 E/BluetoothServiceJni( 2680): Callback: 'adapter_state_change_callback' is not called on the correct thread
01-03 18:26:32.386 I/GKI_LINUX( 2680): gki_task task_id=1 [BTIF] terminating
01-03 18:26:32.386 I/GKI_LINUX( 2680): GKI_exit_task 1 done
01-03 18:26:32.386 I/GKI_LINUX( 2680): GKI_shutdown(): task [BTIF] terminated
01-03 18:26:32.387 I/BluetoothServiceJni( 2680): cleanupNative: return from cleanup
01-03 18:26:32.400 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:32.501 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:32.601 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:32.702 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:32.803 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:32.905 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:33.006 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:33.107 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:33.209 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:33.310 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:33.411 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:33.512 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:33.613 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:33.714 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:33.816 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:33.917 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:33.918 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:26:33.930 E/WifiStateMachine( 1576): Failed to setup control channel, restart supplicant
01-03 18:26:33.930 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:26:34.472 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:26:34.474 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:26:34.478 D/WifiService( 1576): setWifiEnabled: true pid=3417, uid=10013
01-03 18:26:34.478 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:26:35.152 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:26:35.152 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:26:35.994 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:26:35.996 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:26:36.001 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:26:36.162 I/auditd ( 3652): Starting up
01-03 18:26:36.163 E/auditd ( 3652): Failed on audit_set_pid with error: Protocol not supported
01-03 18:26:36.163 I/auditd ( 3652): Exiting
01-03 18:26:36.319 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:26:36.320 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:26:36.320 E/SoftapController( 1322): Softap fwReload failed
01-03 18:26:36.321 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '76 softap fwreload wlan0 STA' failed with '400 76 SoftAP command has failed'
01-03 18:26:36.323 D/CommandListener( 1322): Setting iface cfg
01-03 18:26:36.323 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:26:36.324 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:26:36.334 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:26:36.340 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:26:36.397 I/wpa_supplicant( 3655): Successfully initialized wpa_supplicant
01-03 18:26:36.402 I/wpa_supplicant( 3655): rfkill: Cannot open RFKILL control device
01-03 18:26:36.407 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:26:37.049 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:26:37.053 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:26:37.101 I/ActivityManager( 1576): START u0 {act=android.settings.WIFI_SETTINGS flg=0x14000000 cmp=com.android.settings/.Settings$WifiSettingsActivity} from uid 10013 on display 0
01-03 18:26:37.125 V/WindowManager( 1576): addAppToken: AppWindowToken{3ea516d3 token=Token{280858c2 ActivityRecord{316ec10d u0 com.android.settings/.Settings$WifiSettingsActivity t20}}} to stack=1 task=20 at 0
01-03 18:26:37.222 V/WindowManager( 1576): Adding window Window{34ea59d4 u0 Starting com.android.settings} at 4 of 9 (after Window{15346dc4 u0 com.android.settings/com.android.settings.SubSettings})
01-03 18:26:37.457 I/art ( 1576): Background sticky concurrent mark sweep GC freed 34882(1877KB) AllocSpace objects, 0(0B) LOS objects, 11% free, 12MB/13MB, paused 15.034ms total 235.597ms
01-03 18:26:37.754 E/BluetoothAdapterService(545444995)( 2680): cleanup() - Service already starting to cleanup, ignoring request...
01-03 18:26:37.764 D/BluetoothAdapter( 3417): 1069163452: getState() : mService = null. Returning STATE_OFF
01-03 18:26:37.865 W/OpenGLRenderer( 3417): Incorrectly called buildLayer on View: TextView, destroying layer...
01-03 18:26:37.878 D/PhoneStatusBar( 3417): disable: < expand icons* alerts system_info* back home recent clock search >
01-03 18:26:37.907 V/WindowManager( 1576): Adding window Window{d332b9c u0 com.android.settings/com.android.settings.Settings$WifiSettingsActivity} at 4 of 10 (before Window{34ea59d4 u0 Starting com.android.settings})
01-03 18:26:38.025 W/OpenGLRenderer( 3417): Incorrectly called buildLayer on View: FrameLayout, destroying layer...
01-03 18:26:38.026 W/OpenGLRenderer( 3417): Incorrectly called buildLayer on View: FrameLayout, destroying layer...
01-03 18:26:38.026 W/OpenGLRenderer( 3417): Incorrectly called buildLayer on View: LinearLayout, destroying layer...
01-03 18:26:38.026 W/OpenGLRenderer( 3417): Incorrectly called buildLayer on View: AlphaOptimizedLinearLayout, destroying layer...
01-03 18:26:38.416 W/ResourceType( 3417): No package identifier when getting value for resource number 0x00000000
01-03 18:26:38.417 W/PackageManager( 3417): Failure retrieving resources for com.android.settings: Resource ID #0x0
01-03 18:26:38.539 I/ActivityManager( 1576): Displayed com.android.settings/.Settings$WifiSettingsActivity: +1s182ms
01-03 18:26:38.625 I/Timeline( 1576): Timeline: Activity_windows_visible id: ActivityRecord{316ec10d u0 com.android.settings/.Settings$WifiSettingsActivity t20} time:254617
01-03 18:26:38.677 I/Timeline( 2411): Timeline: Activity_idle id: android.os.BinderProxy@22a680bc time:254669
01-03 18:26:40.158 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:26:40.158 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:26:40.158 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:26:40.158 D/alsa_pcm( 1321): pcm_close()
01-03 18:26:40.158 E/wpa_supplicant( 3655): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:26:40.159 E/wpa_supplicant( 3655): nl80211: Could not set interface 'wlan0' UP
01-03 18:26:40.159 E/wpa_supplicant( 3655): wlan0: Failed to initialize driver interface
01-03 18:26:41.013 D/BluetoothAdapter( 3417): 1069163452: getState() : mService = null. Returning STATE_OFF
01-03 18:26:41.017 D/BluetoothAdapter( 3417): 1069163452: getState() : mService = null. Returning STATE_OFF
01-03 18:26:41.020 D/PhoneStatusBar( 3417): disable: < expand ICONS* alerts SYSTEM_INFO* back home recent clock search >
01-03 18:26:41.022 D/BluetoothAdapter( 3417): 1069163452: getState() : mService = null. Returning STATE_OFF
01-03 18:26:41.174 I/auditd ( 3659): Starting up
01-03 18:26:41.175 E/auditd ( 3659): Failed on audit_set_pid with error: Protocol not supported
01-03 18:26:41.175 I/auditd ( 3659): Exiting
01-03 18:26:43.071 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:26:43.073 D/WifiService( 1576): setWifiEnabled: true pid=3417, uid=10013
01-03 18:26:43.074 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:26:43.075 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:26:43.080 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:26:43.081 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:26:43.081 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:26:43.081 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:26:43.081 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:26:43.085 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:26:43.622 D/BluetoothAdapter( 3417): 1069163452: getState() : mService = null. Returning STATE_OFF
01-03 18:26:45.229 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:26:45.230 D/WifiService( 1576): setWifiEnabled: false pid=3417, uid=10013
01-03 18:26:45.230 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:26:45.233 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:26:46.251 I/auditd ( 3665): Starting up
01-03 18:26:46.252 E/auditd ( 3665): Failed on audit_set_pid with error: Protocol not supported
01-03 18:26:46.252 I/auditd ( 3665): Exiting
01-03 18:26:46.459 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:46.560 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:46.661 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:46.763 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:46.864 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:46.964 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:47.051 D/WifiService( 1576): setWifiEnabled: true pid=3417, uid=10013
01-03 18:26:47.051 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:26:47.054 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:26:47.058 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:26:47.066 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:47.167 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:47.268 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:47.369 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:47.470 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:47.571 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:47.672 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:47.773 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:47.874 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:47.975 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:48.076 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:48.176 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:48.277 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:48.378 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:48.479 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:48.580 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:48.680 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:48.781 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:48.881 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:48.982 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:49.083 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:49.184 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:49.285 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:49.386 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:49.486 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:49.587 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:49.690 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:49.791 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:49.892 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:49.993 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:50.025 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:26:50.027 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:26:50.080 D/BluetoothAdapter( 3417): 1069163452: getState() : mService = null. Returning STATE_OFF
01-03 18:26:50.094 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:50.195 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:50.296 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:50.396 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:50.497 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:50.597 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:50.698 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:50.798 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:50.899 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:50.999 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:51.071 I/auditd ( 3672): Starting up
01-03 18:26:51.071 E/auditd ( 3672): Failed on audit_set_pid with error: Protocol not supported
01-03 18:26:51.071 I/auditd ( 3672): Exiting
01-03 18:26:51.100 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:51.201 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:51.301 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:51.401 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:26:51.401 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:26:51.405 E/WifiStateMachine( 1576): Failed to setup control channel, restart supplicant
01-03 18:26:51.405 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:26:51.405 D/Index ( 2411): Indexing locale 'de_DE' took 35098 millis
01-03 18:26:51.414 D/Index ( 2411): Deleting data for locale 'de_DE' took 2 millis
01-03 18:26:52.785 W/Settings( 3417): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
01-03 18:26:52.788 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:26:52.790 D/WifiService( 1576): setWifiEnabled: true pid=3417, uid=10013
01-03 18:26:52.790 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:26:52.798 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:26:52.960 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:26:52.960 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:26:53.721 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:26:53.722 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:26:53.724 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:26:54.026 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:26:54.026 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:26:54.026 E/SoftapController( 1322): Softap fwReload failed
01-03 18:26:54.027 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '84 softap fwreload wlan0 STA' failed with '400 84 SoftAP command has failed'
01-03 18:26:54.027 D/CommandListener( 1322): Setting iface cfg
01-03 18:26:54.027 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:26:54.028 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:26:54.029 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:26:54.030 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:26:54.050 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:26:54.062 I/wpa_supplicant( 3681): Successfully initialized wpa_supplicant
01-03 18:26:54.063 I/wpa_supplicant( 3681): rfkill: Cannot open RFKILL control device
01-03 18:26:54.104 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:26:54.104 D/WifiService( 1576): setWifiEnabled: true pid=3417, uid=10013
01-03 18:26:54.105 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:26:54.106 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:26:54.647 D/BluetoothAdapter( 3417): 1069163452: getState() : mService = null. Returning STATE_OFF
01-03 18:26:56.048 I/auditd ( 3683): Starting up
01-03 18:26:56.049 E/auditd ( 3683): Failed on audit_set_pid with error: Protocol not supported
01-03 18:26:56.049 I/auditd ( 3683): Exiting
01-03 18:26:56.067 D/WifiService( 1576): setWifiEnabled: false pid=3417, uid=10013
01-03 18:26:56.067 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:26:56.068 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:26:56.072 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:26:57.504 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:26:57.508 D/WifiService( 1576): setWifiEnabled: true pid=3417, uid=10013
01-03 18:26:57.508 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:26:57.511 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:26:57.850 E/wpa_supplicant( 3681): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:26:57.850 E/wpa_supplicant( 3681): nl80211: Could not set interface 'wlan0' UP
01-03 18:26:57.851 E/wpa_supplicant( 3681): wlan0: Failed to initialize driver interface
01-03 18:26:59.702 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:26:59.704 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:26:59.759 D/BluetoothAdapter( 3417): 1069163452: getState() : mService = null. Returning STATE_OFF
01-03 18:27:01.861 I/auditd ( 3691): Starting up
01-03 18:27:01.862 E/auditd ( 3691): Failed on audit_set_pid with error: Protocol not supported
01-03 18:27:01.862 I/auditd ( 3691): Exiting
01-03 18:27:02.479 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:02.480 D/WifiService( 1576): setWifiEnabled: true pid=3417, uid=10013
01-03 18:27:02.480 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:27:02.482 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:03.114 D/BluetoothAdapter( 3417): 1069163452: getState() : mService = null. Returning STATE_OFF
01-03 18:27:04.143 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:04.244 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:04.296 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:04.299 D/WifiService( 1576): setWifiEnabled: false pid=3417, uid=10013
01-03 18:27:04.299 E/WifiService( 1576): Invoking mWifiStateMachine.setWifiEnabled
01-03 18:27:04.304 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:04.345 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:04.448 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:04.549 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:04.650 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:04.751 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:04.852 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:04.952 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:05.053 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:05.154 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:05.255 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:05.356 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:05.456 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:05.557 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:05.659 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:05.760 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:05.853 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:05.856 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:05.862 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:05.903 D/BluetoothAdapter( 3417): 1069163452: getState() : mService = null. Returning STATE_OFF
01-03 18:27:05.963 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:06.063 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:06.165 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:06.265 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:06.330 I/auditd ( 3698): Starting up
01-03 18:27:06.331 E/auditd ( 3698): Failed on audit_set_pid with error: Protocol not supported
01-03 18:27:06.331 I/auditd ( 3698): Exiting
01-03 18:27:06.366 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:06.467 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:06.567 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:06.668 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:06.769 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:06.869 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:06.970 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:07.070 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:07.171 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:07.272 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:07.372 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:07.473 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:07.574 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:07.675 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:07.776 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:07.865 W/OpenGLRenderer( 3417): Incorrectly called buildLayer on View: TextView, destroying layer...
01-03 18:27:07.869 D/PhoneStatusBar( 3417): disable: < expand icons* alerts system_info* back home recent clock search >
01-03 18:27:07.877 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:07.898 W/InputMethodManagerService( 1576): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@15c7171b attribute=null, token = android.os.BinderProxy@366c0f0f
01-03 18:27:07.978 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:08.079 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:08.180 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:08.281 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:08.382 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:08.483 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:08.583 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:08.684 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:08.785 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:08.885 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:08.967 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:27:08.967 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:27:08.967 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:27:08.967 D/alsa_pcm( 1321): pcm_close()
01-03 18:27:08.986 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:09.086 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:09.087 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:27:09.101 E/WifiStateMachine( 1576): Failed to setup control channel, restart supplicant
01-03 18:27:09.101 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:27:09.855 I/ActivityManager( 1576): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.cyanogenmod.trebuchet/com.android.launcher3.Launcher} from uid 1000 on display 0
01-03 18:27:09.862 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:09.865 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:09.869 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:27:09.869 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:27:09.869 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:27:09.869 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:27:09.869 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:27:09.874 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:27:10.011 W/art ( 1576): Long monitor contention event with owner method=int com.android.server.am.ActivityStackSupervisor.startActivityMayWait(android.app.IApplicationThread, int, java.lang.String, android.content.Intent, java.lang.String, android.service.voice.IVoiceInteractionSession, com.android.internal.app.IVoiceInteractor, android.os.IBinder, java.lang.String, int, int, android.app.ProfilerInfo, android.app.IActivityManager$WaitResult, android.content.res.Configuration, android.os.Bundle, int, android.app.IActivityContainer, com.android.server.am.TaskRecord) from ActivityStackSupervisor.java:882 waiters=0 for 128ms
01-03 18:27:10.115 W/Launcher( 2016): setApplicationContext called twice! old=com.android.launcher3.LauncherApplication@5d4bf32 new=com.android.launcher3.LauncherApplication@5d4bf32
01-03 18:27:10.220 I/art ( 1576): Background partial concurrent mark sweep GC freed 21154(1042KB) AllocSpace objects, 2(32KB) LOS objects, 33% free, 14MB/21MB, paused 14.919ms total 271.479ms
01-03 18:27:10.343 E/AppsCustomizePagedView( 2016): Create Res Apk Failed
01-03 18:27:10.364 D/LocaleSetManager( 2016): Locale Changed from: null to de-DE
01-03 18:27:10.391 D/Launcher( 2016): 11683562 - bindAddScreens()
01-03 18:27:10.391 D/Launcher( 2016): 11683562 - orderedScreenIds: 1, 2
01-03 18:27:10.391 D/Launcher.Workspace( 2016): 11683562 - insertNewWorkspaceScreen(): 1 at index: 0
01-03 18:27:10.393 D/Launcher.Workspace( 2016): 11683562 - insertNewWorkspaceScreen(): 2 at index: 1
01-03 18:27:10.511 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:27:10.511 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:27:10.555 V/WindowManager( 1576): Adding window Window{1a2f6ed0 u0 com.cyanogenmod.trebuchet/com.android.launcher3.Launcher} at 4 of 9 (after Window{d332b9c u0 com.android.settings/com.android.settings.Settings$WifiSettingsActivity})
01-03 18:27:11.048 W/ResourceType( 3417): No package identifier when getting value for resource number 0x00000000
01-03 18:27:11.048 W/PackageManager( 3417): Failure retrieving resources for com.android.settings: Resource ID #0x0
01-03 18:27:11.230 I/Choreographer( 2016): Skipped 37 frames! The application may be doing too much work on its main thread.
01-03 18:27:11.337 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:27:11.341 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:27:11.348 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:27:11.548 I/auditd ( 3771): Starting up
01-03 18:27:11.549 E/auditd ( 3771): Failed on audit_set_pid with error: Protocol not supported
01-03 18:27:11.549 I/auditd ( 3771): Exiting
01-03 18:27:11.650 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:27:11.651 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:27:11.651 E/SoftapController( 1322): Softap fwReload failed
01-03 18:27:11.653 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '92 softap fwreload wlan0 STA' failed with '400 92 SoftAP command has failed'
01-03 18:27:11.655 D/CommandListener( 1322): Setting iface cfg
01-03 18:27:11.655 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:27:11.656 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:27:11.663 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:27:11.732 I/wpa_supplicant( 3775): Successfully initialized wpa_supplicant
01-03 18:27:11.736 I/wpa_supplicant( 3775): rfkill: Cannot open RFKILL control device
01-03 18:27:11.765 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:27:11.779 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:27:11.826 I/Timeline( 1576): Timeline: Activity_windows_visible id: ActivityRecord{23aa6a27 u0 com.cyanogenmod.trebuchet/com.android.launcher3.Launcher t18} time:287818
01-03 18:27:11.897 D/android.widget.GridLayout( 2016): vertical constraints: y3-y0>=264, y3-y0<=248, y3-y2<=104, y2-y1<=2 are inconsistent; permanently removing: y3-y0<=248.
01-03 18:27:11.900 D/Launcher.Workspace( 2016): 11683562 - stripEmptyScreens()
01-03 18:27:11.903 I/Timeline( 2016): Timeline: Activity_idle id: android.os.BinderProxy@155b3c11 time:287895
01-03 18:27:12.852 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:12.855 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:14.493 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:14.495 I/Timeline( 2016): Timeline: Activity_launch_request id:com.android.terminal time:290486
01-03 18:27:14.495 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:14.496 I/ActivityManager( 1576): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.terminal/.TerminalActivity (has extras)} from uid 10015 on display 0
01-03 18:27:14.513 V/WindowManager( 1576): addAppToken: AppWindowToken{2ded883a token=Token{525a365 ActivityRecord{b4bd45c u0 com.android.terminal/.TerminalActivity t21}}} to stack=1 task=21 at 0
01-03 18:27:14.527 V/WindowManager( 1576): Adding window Window{397dda1d u0 Starting com.android.terminal} at 5 of 10 (after Window{d332b9c u0 com.android.settings/com.android.settings.Settings$WifiSettingsActivity})
01-03 18:27:14.527 W/BroadcastQueue( 1576): Permission Denial: broadcasting Intent { act=com.android.launcher3.action.LAUNCH flg=0x10 (has extras) } from com.cyanogenmod.trebuchet (pid=2016, uid=10015) requires com.google.android.launcher.permission.RECEIVE_LAUNCH_BROADCASTS due to receiver com.google.android.googlequicksearchbox/com.google.android.search.core.icingsync.ApplicationLaunchReceiver
01-03 18:27:14.527 W/BroadcastQueue( 1576): Permission Denial: receiving Intent { act=com.android.launcher3.action.LAUNCH flg=0x10 (has extras) } to com.google.android.googlequicksearchbox/com.google.android.search.core.icingsync.ApplicationLaunchReceiver requires com.android.launcher3.permission.RECEIVE_LAUNCH_BROADCASTS due to sender com.cyanogenmod.trebuchet (uid 10015)
01-03 18:27:14.656 I/ActivityManager( 1576): Start proc 3808:com.android.terminal/u0a55 for activity com.android.terminal/.TerminalActivity
01-03 18:27:15.377 D/OpenGLRenderer( 3808): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
01-03 18:27:15.384 D/Atlas ( 3808): Validating map...
01-03 18:27:15.396 V/WindowManager( 1576): Adding window Window{6c1e4b6 u0 com.android.terminal/com.android.terminal.TerminalActivity} at 5 of 11 (before Window{397dda1d u0 Starting com.android.terminal})
01-03 18:27:15.458 I/OpenGLRenderer( 3808): Initialized EGL, version 1.4
01-03 18:27:15.462 D/OpenGLRenderer( 3808): Enabling debug mode 0
01-03 18:27:15.525 E/wpa_supplicant( 3775): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:27:15.525 E/wpa_supplicant( 3775): nl80211: Could not set interface 'wlan0' UP
01-03 18:27:15.525 E/wpa_supplicant( 3775): wlan0: Failed to initialize driver interface
01-03 18:27:15.638 D/Terminal( 3808): Bound to service with 0 active terminals
01-03 18:27:15.663 D/Terminal( 3808): entering read() loop
01-03 18:27:15.672 D/Terminal( 3808): setColors(0xffffffff, 0xff000000)
01-03 18:27:15.706 D/Terminal( 3808): resize(34, 128, 100)
01-03 18:27:15.816 W/SubtypeLocaleUtils( 1926): KeyboardLayoutSet not found, use QWERTY: locale=en_AU extraValue=TrySuppressingImeSwitcher,AsciiCapable,SupportTouchPositionCorrection,EmojiCapable
01-03 18:27:15.816 W/SubtypeSwitcher( 1926): Can't find emoji subtype
01-03 18:27:15.817 W/SubtypeSwitcher( 1926): No input method subtype found; returning dummy subtype: android.view.inputmethod.InputMethodSubtype@d78b2ed0
01-03 18:27:15.852 I/ActivityManager( 1576): Displayed com.android.terminal/.TerminalActivity: +1s283ms
01-03 18:27:15.852 I/Timeline( 1576): Timeline: Activity_windows_visible id: ActivityRecord{b4bd45c u0 com.android.terminal/.TerminalActivity t21} time:291844
01-03 18:27:16.097 I/Timeline( 3808): Timeline: Activity_idle id: android.os.BinderProxy@2b9435df time:292089
01-03 18:27:16.179 W/ViewPager( 1926): Requested offscreen page limit 0 too small; defaulting to 1
01-03 18:27:16.184 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:16.187 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:16.198 I/LatinIME( 1926): Starting input. Cursor position = -1,-1
01-03 18:27:16.206 E/RichInputConnection( 1926): Unable to connect to the editor to retrieve text.
01-03 18:27:16.206 D/RichInputConnection( 1926): Will try to retrieve text later.
01-03 18:27:16.207 I/InputAttributes( 1926): InputType.TYPE_NULL is specified
01-03 18:27:16.281 D/OpenGLRenderer( 1926): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
01-03 18:27:16.285 D/Atlas ( 1926): Validating map...
01-03 18:27:16.309 I/LatinIME( 1926): Starting input. Cursor position = -1,-1
01-03 18:27:16.540 I/auditd ( 3845): Starting up
01-03 18:27:16.541 E/auditd ( 3845): Failed on audit_set_pid with error: Protocol not supported
01-03 18:27:16.541 I/auditd ( 3845): Exiting
01-03 18:27:16.630 I/InputAttributes( 1926): InputType.TYPE_NULL is specified
01-03 18:27:16.744 I/OpenGLRenderer( 1926): Initialized EGL, version 1.4
01-03 18:27:16.747 D/OpenGLRenderer( 1926): Enabling debug mode 0
01-03 18:27:17.250 D/Terminal( 3808): resize(16, 128, 100)
01-03 18:27:17.389 I/art ( 1926): Background partial concurrent mark sweep GC freed 9451(402KB) AllocSpace objects, 1(14KB) LOS objects, 40% free, 8MB/14MB, paused 5.979ms total 38.001ms
01-03 18:27:18.019 D/TaskPersister( 1576): removeObsoleteFile: deleting file=16_task.xml
01-03 18:27:18.020 D/TaskPersister( 1576): removeObsoleteFile: deleting file=16_task_thumbnail.png
01-03 18:27:19.292 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:27:19.292 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:27:19.292 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:27:19.292 D/alsa_pcm( 1321): pcm_close()
01-03 18:27:19.319 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:19.321 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:19.325 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:27:19.325 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:27:19.325 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:27:19.325 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:27:19.326 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:27:19.329 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:27:19.880 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:19.883 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:21.530 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:21.533 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:21.553 I/auditd ( 3857): Starting up
01-03 18:27:21.554 E/auditd ( 3857): Failed on audit_set_pid with error: Protocol not supported
01-03 18:27:21.554 I/auditd ( 3857): Exiting
01-03 18:27:21.880 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:21.980 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:21.981 D/AndroidRuntime( 3868): >>>>>> START com.android.internal.os.RuntimeInit uid 0 <<<<<<
01-03 18:27:21.984 D/AndroidRuntime( 3868): CheckJNI is OFF
01-03 18:27:22.065 E/memtrack( 3868): Couldn't load memtrack module (No such file or directory)
01-03 18:27:22.065 E/android.os.Debug( 3868): failed to load memtrack module: -2
01-03 18:27:22.081 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:22.125 D/AndroidRuntime( 3868): Calling main entry com.android.commands.am.Am
01-03 18:27:22.157 I/Timeline( 2743): Timeline: Activity_launch_request id:eu.chainfire.supersu time:298148
01-03 18:27:22.157 I/ActivityManager( 1576): START u0 {act=android.intent.action.MAIN flg=0x50840000 cmp=eu.chainfire.supersu/.PromptActivity (has extras)} from uid 10059 on display 0
01-03 18:27:22.162 V/WindowManager( 1576): addAppToken: AppWindowToken{21d6aafd token=Token{2bf45b54 ActivityRecord{3b69caa7 u0 eu.chainfire.supersu/.PromptActivity t22}}} to stack=1 task=22 at 0
01-03 18:27:22.181 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:22.244 D/AndroidRuntime( 3868): Shutting down VM
01-03 18:27:22.282 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:22.382 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:22.386 D/OpenGLRenderer( 2743): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
01-03 18:27:22.387 D/Atlas ( 2743): Validating map...
01-03 18:27:22.389 V/WindowManager( 1576): Adding window Window{6057d3e u0 eu.chainfire.supersu/eu.chainfire.supersu.PromptActivity} at 6 of 12 (after Window{6c1e4b6 u0 com.android.terminal/com.android.terminal.TerminalActivity})
01-03 18:27:22.450 I/OpenGLRenderer( 2743): Initialized EGL, version 1.4
01-03 18:27:22.453 D/OpenGLRenderer( 2743): Enabling debug mode 0
01-03 18:27:22.483 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:22.583 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:22.684 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:22.731 W/IInputConnectionWrapper( 3808): showStatusIcon on inactive InputConnection
01-03 18:27:22.739 I/ActivityManager( 1576): Displayed eu.chainfire.supersu/.PromptActivity: +505ms
01-03 18:27:22.784 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:22.868 I/Timeline( 2743): Timeline: Activity_idle id: android.os.BinderProxy@a892166 time:298860
01-03 18:27:22.885 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:22.981 D/Terminal( 3808): resize(34, 128, 100)
01-03 18:27:22.986 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:23.086 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:23.187 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:23.255 W/ResourceType( 3417): No package identifier when getting value for resource number 0x00000000
01-03 18:27:23.255 W/PackageManager( 3417): Failure retrieving resources for com.android.terminal: Resource ID #0x0
01-03 18:27:23.288 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:23.389 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:23.439 I/Timeline( 1576): Timeline: Activity_windows_visible id: ActivityRecord{3b69caa7 u0 eu.chainfire.supersu/.PromptActivity t22} time:299431
01-03 18:27:23.489 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:23.590 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:23.690 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:23.791 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:23.891 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:23.992 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:24.092 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:24.193 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:24.293 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:24.394 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:24.495 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:24.567 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:24.569 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:24.595 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:24.696 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:24.796 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:24.897 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:24.907 W/ProcessCpuTracker( 1576): Skipping unknown process pid 3916
01-03 18:27:24.997 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:25.098 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:25.145 I/Choreographer( 2743): Skipped 34 frames! The application may be doing too much work on its main thread.
01-03 18:27:25.198 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:25.208 D/OpenGLRenderer( 2743): endAllStagingAnimators on 0x42745780 (RippleDrawable) with handle 0x42662140
01-03 18:27:25.252 D/Terminal( 3808): setColors(0xffffffff, 0xff000000)
01-03 18:27:25.299 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:25.352 D/AndroidRuntime( 3937): >>>>>> START com.android.internal.os.RuntimeInit uid 0 <<<<<<
01-03 18:27:25.356 D/AndroidRuntime( 3937): CheckJNI is OFF
01-03 18:27:25.400 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:25.433 I/LatinIME( 1926): Starting input. Cursor position = -1,-1
01-03 18:27:25.503 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:25.561 E/memtrack( 3937): Couldn't load memtrack module (No such file or directory)
01-03 18:27:25.561 E/android.os.Debug( 3937): failed to load memtrack module: -2
01-03 18:27:25.603 I/Timeline( 3808): Timeline: Activity_idle id: android.os.BinderProxy@2b9435df time:301595
01-03 18:27:25.603 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:25.618 I/InputAttributes( 1926): InputType.TYPE_NULL is specified
01-03 18:27:25.670 D/AndroidRuntime( 3937): Calling main entry com.android.commands.am.Am
01-03 18:27:25.698 D/AndroidRuntime( 3937): Shutting down VM
01-03 18:27:25.705 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:25.798 I/art ( 2743): Background sticky concurrent mark sweep GC freed 1338(78KB) AllocSpace objects, 0(0B) LOS objects, 6% free, 1667KB/1784KB, paused 6.009ms total 63.716ms
01-03 18:27:25.806 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:25.899 I/art ( 2743): Background partial concurrent mark sweep GC freed 972(116KB) AllocSpace objects, 3(176KB) LOS objects, 42% free, 1376KB/2MB, paused 5.293ms total 51.051ms
01-03 18:27:25.907 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:26.007 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:26.055 D/Terminal( 3808): resize(16, 128, 100)
01-03 18:27:26.068 I/art ( 1926): Background sticky concurrent mark sweep GC freed 916(68KB) AllocSpace objects, 0(0B) LOS objects, 0% free, 15MB/15MB, paused 6.613ms total 18.264ms
01-03 18:27:26.079 V/RenderScript( 2743): 0x68409200 Launching thread(s), CPUs 4
01-03 18:27:26.108 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:26.209 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:26.309 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:26.410 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:26.510 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:26.611 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:26.711 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:26.812 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:26.812 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:27:26.817 E/WifiStateMachine( 1576): Failed to setup control channel, restart supplicant
01-03 18:27:26.817 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:27:26.952 I/auditd ( 3954): Starting up
01-03 18:27:26.952 E/auditd ( 3954): Failed on audit_set_pid with error: Protocol not supported
01-03 18:27:26.952 I/auditd ( 3954): Exiting
01-03 18:27:27.678 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:27:27.678 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:27:27.678 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:27:27.678 D/alsa_pcm( 1321): pcm_close()
01-03 18:27:28.122 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:27:28.122 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:27:28.240 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:28.241 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:28.243 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:27:28.243 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:27:28.243 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:27:28.243 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:27:28.243 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:27:28.246 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:27:28.929 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:27:28.931 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:27:28.933 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:27:29.174 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:29.175 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:29.256 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:27:29.257 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:27:29.257 E/SoftapController( 1322): Softap fwReload failed
01-03 18:27:29.258 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '100 softap fwreload wlan0 STA' failed with '400 100 SoftAP command has failed'
01-03 18:27:29.259 D/CommandListener( 1322): Setting iface cfg
01-03 18:27:29.259 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:27:29.260 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:27:29.266 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:27:29.295 I/wpa_supplicant( 3963): Successfully initialized wpa_supplicant
01-03 18:27:29.296 I/wpa_supplicant( 3963): rfkill: Cannot open RFKILL control device
01-03 18:27:29.368 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:27:29.375 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:27:31.284 I/auditd ( 3964): Starting up
01-03 18:27:31.285 E/auditd ( 3964): Failed on audit_set_pid with error: Protocol not supported
01-03 18:27:31.285 I/auditd ( 3964): Exiting
01-03 18:27:32.275 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:27:32.275 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:27:32.275 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:27:32.275 D/alsa_pcm( 1321): pcm_close()
01-03 18:27:32.634 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:32.637 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:32.641 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:27:32.642 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:27:32.642 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:27:32.642 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:27:32.642 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:27:32.645 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:27:32.925 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:32.925 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:33.053 E/wpa_supplicant( 3963): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:27:33.053 E/wpa_supplicant( 3963): nl80211: Could not set interface 'wlan0' UP
01-03 18:27:33.054 E/wpa_supplicant( 3963): wlan0: Failed to initialize driver interface
01-03 18:27:33.597 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:33.598 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:36.075 I/auditd ( 3970): Starting up
01-03 18:27:36.076 E/auditd ( 3970): Failed on audit_set_pid with error: Protocol not supported
01-03 18:27:36.076 I/auditd ( 3970): Exiting
01-03 18:27:36.357 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:36.360 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:38.295 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:38.296 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:39.480 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:39.580 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:39.681 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:39.781 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:39.882 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:39.982 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:40.082 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:40.183 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:40.283 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:40.383 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:40.484 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:40.584 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:40.684 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:40.785 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:40.885 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:40.985 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:41.085 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:41.086 I/auditd ( 3975): Starting up
01-03 18:27:41.086 E/auditd ( 3975): Failed on audit_set_pid with error: Protocol not supported
01-03 18:27:41.086 I/auditd ( 3975): Exiting
01-03 18:27:41.186 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:41.286 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:41.387 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:41.389 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:27:41.389 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:27:41.389 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:27:41.389 D/alsa_pcm( 1321): pcm_close()
01-03 18:27:41.487 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:41.588 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:41.688 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:41.789 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:41.890 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:41.990 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:42.091 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:42.191 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:42.292 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:42.393 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:42.493 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:42.594 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:42.694 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:42.795 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:42.896 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:42.996 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:43.097 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:43.198 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:43.298 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:43.399 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:43.499 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:43.599 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:43.699 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:43.800 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:43.900 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:44.001 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:44.101 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:44.202 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:44.302 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:44.403 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:44.403 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:27:44.414 E/WifiStateMachine( 1576): Failed to setup control channel, restart supplicant
01-03 18:27:44.414 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:27:44.415 D/Index ( 2411): Indexing locale 'de_DE' took 53001 millis
01-03 18:27:44.431 D/Index ( 2411): Deleting data for locale 'de_DE' took 10 millis
01-03 18:27:44.431 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:27:44.434 D/Index ( 2411): Indexing locale 'de_DE' took 3 millis
01-03 18:27:45.762 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:27:45.762 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:27:46.396 E/Lights ( 1576): write_int failed to open sys/class/leds/rk29_key_led/brightness
01-03 18:27:46.496 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:27:46.496 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:27:46.498 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:27:46.703 E/Lights ( 1576): write_int failed to open sys/class/leds/rk29_key_led/brightness
01-03 18:27:46.720 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:46.721 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:46.723 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:27:46.723 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:27:46.723 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:27:46.723 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:27:46.723 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:27:46.727 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:27:46.768 I/auditd ( 3983): Starting up
01-03 18:27:46.768 E/auditd ( 3983): Failed on audit_set_pid with error: Protocol not supported
01-03 18:27:46.768 I/auditd ( 3983): Exiting
01-03 18:27:46.805 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:27:46.806 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:27:46.806 E/SoftapController( 1322): Softap fwReload failed
01-03 18:27:46.806 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '108 softap fwreload wlan0 STA' failed with '400 108 SoftAP command has failed'
01-03 18:27:46.807 D/CommandListener( 1322): Setting iface cfg
01-03 18:27:46.807 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:27:46.808 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:27:46.809 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:27:46.810 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:27:46.816 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:27:46.832 I/wpa_supplicant( 3986): Successfully initialized wpa_supplicant
01-03 18:27:46.832 I/wpa_supplicant( 3986): rfkill: Cannot open RFKILL control device
01-03 18:27:50.022 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:27:50.022 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:27:50.022 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:27:50.022 D/alsa_pcm( 1321): pcm_close()
01-03 18:27:50.530 E/wpa_supplicant( 3986): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:27:50.530 E/wpa_supplicant( 3986): nl80211: Could not set interface 'wlan0' UP
01-03 18:27:50.530 E/wpa_supplicant( 3986): wlan0: Failed to initialize driver interface
01-03 18:27:51.538 I/auditd ( 3987): Starting up
01-03 18:27:51.539 E/auditd ( 3987): Failed on audit_set_pid with error: Protocol not supported
01-03 18:27:51.539 I/auditd ( 3987): Exiting
01-03 18:27:52.930 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:27:52.932 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:27:52.938 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:27:52.938 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:27:52.938 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:27:52.938 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:27:52.938 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:27:52.942 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:27:55.950 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:27:55.951 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:27:55.951 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:27:55.951 D/alsa_pcm( 1321): pcm_close()
01-03 18:27:56.557 I/auditd ( 3991): Starting up
01-03 18:27:56.558 E/auditd ( 3991): Failed on audit_set_pid with error: Protocol not supported
01-03 18:27:56.558 I/auditd ( 3991): Exiting
01-03 18:27:56.919 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:57.020 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:57.120 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:57.221 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:57.321 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:57.422 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:57.523 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:57.623 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:57.724 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:57.825 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:57.925 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:58.026 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:58.126 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:58.226 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:58.327 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:58.428 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:58.528 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:58.629 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:58.730 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:58.830 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:58.931 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:59.031 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:59.132 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:59.233 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:59.333 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:59.434 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:59.535 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:59.635 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:59.736 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:59.837 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:27:59.937 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:00.002 E/Lights ( 1576): write_int failed to open sys/class/leds/rk29_key_led/brightness
01-03 18:28:00.038 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:00.138 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:00.238 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:00.339 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:00.440 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:00.540 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:00.641 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:00.741 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:00.842 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:00.942 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:01.042 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:01.142 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:01.243 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:01.343 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:01.443 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:01.544 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:01.577 I/auditd ( 3994): Starting up
01-03 18:28:01.578 E/auditd ( 3994): Failed on audit_set_pid with error: Protocol not supported
01-03 18:28:01.578 I/auditd ( 3994): Exiting
01-03 18:28:01.645 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:01.745 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:01.845 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:01.845 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:28:01.849 E/WifiStateMachine( 1576): Failed 6 times to start supplicant, unload driver
01-03 18:28:01.854 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:28:01.856 D/Index ( 2411): Deleting data for locale 'de_DE' took 4 millis
01-03 18:28:03.303 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:28:03.303 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:28:04.047 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:28:04.048 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:28:04.050 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:28:04.348 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:28:04.349 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:28:04.349 E/SoftapController( 1322): Softap fwReload failed
01-03 18:28:04.349 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '116 softap fwreload wlan0 STA' failed with '400 116 SoftAP command has failed'
01-03 18:28:04.350 D/CommandListener( 1322): Setting iface cfg
01-03 18:28:04.350 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:28:04.350 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:28:04.352 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:28:04.353 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:28:04.358 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:28:04.372 I/wpa_supplicant( 4001): Successfully initialized wpa_supplicant
01-03 18:28:04.373 I/wpa_supplicant( 4001): rfkill: Cannot open RFKILL control device
01-03 18:28:06.368 I/auditd ( 4002): Starting up
01-03 18:28:06.369 E/auditd ( 4002): Failed on audit_set_pid with error: Protocol not supported
01-03 18:28:06.369 I/auditd ( 4002): Exiting
01-03 18:28:08.070 E/wpa_supplicant( 4001): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:28:08.070 E/wpa_supplicant( 4001): nl80211: Could not set interface 'wlan0' UP
01-03 18:28:08.070 E/wpa_supplicant( 4001): wlan0: Failed to initialize driver interface
01-03 18:28:11.090 I/auditd ( 4005): Starting up
01-03 18:28:11.090 E/auditd ( 4005): Failed on audit_set_pid with error: Protocol not supported
01-03 18:28:11.090 I/auditd ( 4005): Exiting
01-03 18:28:14.459 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:14.560 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:14.660 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:14.761 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:14.862 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:14.962 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:15.063 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:15.163 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:15.264 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:15.365 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:15.465 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:15.566 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:15.666 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:15.767 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:15.868 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:15.968 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:16.069 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:16.110 I/auditd ( 4008): Starting up
01-03 18:28:16.110 E/auditd ( 4008): Failed on audit_set_pid with error: Protocol not supported
01-03 18:28:16.110 I/auditd ( 4008): Exiting
01-03 18:28:16.170 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:16.270 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:16.371 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:16.472 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:16.573 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:16.673 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:16.774 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:16.874 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:16.975 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:17.076 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:17.176 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:17.277 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:17.378 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:17.478 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:17.579 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:17.680 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:17.781 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:17.882 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:17.982 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:18.083 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:18.184 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:18.284 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:18.385 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:18.486 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:18.586 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:18.687 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:18.788 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:18.889 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:18.989 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:19.090 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:19.191 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:19.291 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:19.392 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:19.392 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:28:19.399 E/WifiStateMachine( 1576): Failed to setup control channel, restart supplicant
01-03 18:28:19.400 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:28:21.035 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:28:21.035 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:28:21.049 I/auditd ( 4011): Starting up
01-03 18:28:21.050 E/auditd ( 4011): Failed on audit_set_pid with error: Protocol not supported
01-03 18:28:21.050 I/auditd ( 4011): Exiting
01-03 18:28:21.783 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:28:21.783 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:28:21.785 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:28:22.083 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:28:22.084 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:28:22.084 E/SoftapController( 1322): Softap fwReload failed
01-03 18:28:22.084 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '124 softap fwreload wlan0 STA' failed with '400 124 SoftAP command has failed'
01-03 18:28:22.085 D/CommandListener( 1322): Setting iface cfg
01-03 18:28:22.085 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:28:22.085 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:28:22.087 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:28:22.088 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:28:22.093 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:28:22.106 I/wpa_supplicant( 4018): Successfully initialized wpa_supplicant
01-03 18:28:22.107 I/wpa_supplicant( 4018): rfkill: Cannot open RFKILL control device
01-03 18:28:25.800 E/wpa_supplicant( 4018): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:28:25.800 E/wpa_supplicant( 4018): nl80211: Could not set interface 'wlan0' UP
01-03 18:28:25.800 E/wpa_supplicant( 4018): wlan0: Failed to initialize driver interface
01-03 18:28:26.813 I/auditd ( 4019): Starting up
01-03 18:28:26.813 E/auditd ( 4019): Failed on audit_set_pid with error: Protocol not supported
01-03 18:28:26.813 I/auditd ( 4019): Exiting
01-03 18:28:31.195 E/Lights ( 1576): write_int failed to open sys/class/leds/rk29_key_led/brightness
01-03 18:28:31.205 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:31.207 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:31.211 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:28:31.211 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:28:31.211 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:28:31.211 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:28:31.211 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:28:31.215 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:28:31.832 I/auditd ( 4023): Starting up
01-03 18:28:31.833 E/auditd ( 4023): Failed on audit_set_pid with error: Protocol not supported
01-03 18:28:31.833 I/auditd ( 4023): Exiting
01-03 18:28:32.200 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:32.301 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:32.401 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:32.502 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:32.603 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:32.703 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:32.804 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:32.905 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:33.005 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:33.106 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:33.207 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:33.307 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:33.408 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:33.509 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:33.609 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:33.710 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:33.811 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:33.911 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:34.012 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:34.113 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:34.185 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:34.187 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:34.213 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:34.314 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:34.415 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:34.516 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:34.616 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:34.717 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:34.818 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:34.918 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:35.019 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:35.120 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:35.221 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:35.321 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:35.422 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:35.522 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:35.623 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:35.724 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:35.824 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:35.925 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:36.026 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:36.126 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:36.227 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:36.328 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:36.428 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:36.528 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:36.629 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:36.730 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:36.790 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:36.793 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:36.831 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:36.854 I/auditd ( 4028): Starting up
01-03 18:28:36.855 E/auditd ( 4028): Failed on audit_set_pid with error: Protocol not supported
01-03 18:28:36.855 I/auditd ( 4028): Exiting
01-03 18:28:36.931 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:37.032 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:37.133 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:37.133 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:28:37.139 E/WifiStateMachine( 1576): Failed to setup control channel, restart supplicant
01-03 18:28:37.139 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:28:38.469 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:38.470 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:38.535 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:28:38.535 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:28:39.300 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:28:39.300 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:28:39.302 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:28:39.603 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:28:39.604 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:28:39.604 E/SoftapController( 1322): Softap fwReload failed
01-03 18:28:39.604 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '132 softap fwreload wlan0 STA' failed with '400 132 SoftAP command has failed'
01-03 18:28:39.605 D/CommandListener( 1322): Setting iface cfg
01-03 18:28:39.605 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:28:39.605 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:28:39.607 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:28:39.608 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:28:39.613 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:28:39.626 I/wpa_supplicant( 4036): Successfully initialized wpa_supplicant
01-03 18:28:39.627 I/wpa_supplicant( 4036): rfkill: Cannot open RFKILL control device
01-03 18:28:40.721 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:40.722 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:41.037 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:41.039 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:41.563 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:41.564 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:41.616 I/auditd ( 4040): Starting up
01-03 18:28:41.617 E/auditd ( 4040): Failed on audit_set_pid with error: Protocol not supported
01-03 18:28:41.617 I/auditd ( 4040): Exiting
01-03 18:28:43.331 E/wpa_supplicant( 4036): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:28:43.331 E/wpa_supplicant( 4036): nl80211: Could not set interface 'wlan0' UP
01-03 18:28:43.331 E/wpa_supplicant( 4036): wlan0: Failed to initialize driver interface
01-03 18:28:43.772 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:43.774 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:44.616 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:44.619 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:46.351 I/auditd ( 4045): Starting up
01-03 18:28:46.352 E/auditd ( 4045): Failed on audit_set_pid with error: Protocol not supported
01-03 18:28:46.352 I/auditd ( 4045): Exiting
01-03 18:28:47.715 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:47.717 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:48.313 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:48.315 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:48.604 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:48.605 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:49.313 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:49.314 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:49.721 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:49.760 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:49.760 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:49.821 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:49.922 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:50.022 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:50.123 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:50.177 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:50.177 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:50.223 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:50.325 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:50.425 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:50.493 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:50.493 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:50.525 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:50.626 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:50.727 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:50.827 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:50.927 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:51.028 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:51.128 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:51.229 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:51.329 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:51.361 I/auditd ( 4055): Starting up
01-03 18:28:51.362 E/auditd ( 4055): Failed on audit_set_pid with error: Protocol not supported
01-03 18:28:51.362 I/auditd ( 4055): Exiting
01-03 18:28:51.430 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:51.530 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:51.631 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:51.732 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:51.832 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:51.933 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:52.034 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:52.134 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:52.235 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:52.336 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:52.436 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:52.537 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:52.638 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:52.725 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:52.727 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:52.738 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:52.839 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:52.940 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:53.041 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:53.141 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:53.242 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:53.343 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:53.443 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:53.536 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:53.538 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:53.544 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:53.645 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:53.745 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:53.846 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:53.947 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:54.047 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:54.147 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:54.248 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:54.349 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:54.449 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:54.550 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:54.651 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:28:54.651 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:28:54.657 E/WifiStateMachine( 1576): Failed to setup control channel, restart supplicant
01-03 18:28:54.657 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:28:55.545 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:55.546 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:56.102 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:28:56.102 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:28:56.116 I/auditd ( 4061): Starting up
01-03 18:28:56.117 E/auditd ( 4061): Failed on audit_set_pid with error: Protocol not supported
01-03 18:28:56.117 I/auditd ( 4061): Exiting
01-03 18:28:56.854 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:28:56.855 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:28:56.856 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:28:57.157 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:28:57.158 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:28:57.158 E/SoftapController( 1322): Softap fwReload failed
01-03 18:28:57.158 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '140 softap fwreload wlan0 STA' failed with '400 140 SoftAP command has failed'
01-03 18:28:57.159 D/CommandListener( 1322): Setting iface cfg
01-03 18:28:57.159 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:28:57.160 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:28:57.161 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:28:57.162 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:28:57.167 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:28:57.182 I/wpa_supplicant( 4068): Successfully initialized wpa_supplicant
01-03 18:28:57.182 I/wpa_supplicant( 4068): rfkill: Cannot open RFKILL control device
01-03 18:28:57.923 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:57.925 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:28:58.953 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:28:58.955 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:00.306 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:00.309 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:00.542 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:00.543 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:00.897 E/wpa_supplicant( 4068): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:29:00.897 E/wpa_supplicant( 4068): nl80211: Could not set interface 'wlan0' UP
01-03 18:29:00.897 E/wpa_supplicant( 4068): wlan0: Failed to initialize driver interface
01-03 18:29:01.339 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:01.341 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:01.904 I/auditd ( 4074): Starting up
01-03 18:29:01.904 E/auditd ( 4074): Failed on audit_set_pid with error: Protocol not supported
01-03 18:29:01.904 I/auditd ( 4074): Exiting
01-03 18:29:03.783 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:03.784 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:04.399 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:04.400 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:04.839 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:04.840 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:05.313 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:05.316 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:06.909 I/auditd ( 4081): Starting up
01-03 18:29:06.910 E/auditd ( 4081): Failed on audit_set_pid with error: Protocol not supported
01-03 18:29:06.910 I/auditd ( 4081): Exiting
01-03 18:29:07.269 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:07.370 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:07.470 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:07.571 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:07.671 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:07.771 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:07.871 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:07.972 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:08.072 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:08.172 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:08.273 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:08.374 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:08.415 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:29:08.415 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:29:08.415 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:29:08.415 D/alsa_pcm( 1321): pcm_close()
01-03 18:29:08.474 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:08.575 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:08.676 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:08.776 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:08.877 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:08.978 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:09.078 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:09.179 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:09.279 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:09.380 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:09.481 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:09.581 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:09.682 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:09.782 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:09.883 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:09.984 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:10.084 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:10.185 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:10.286 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:10.386 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:10.487 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:10.587 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:10.688 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:10.789 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:10.889 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:10.990 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:11.091 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:11.191 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:11.292 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:11.313 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:11.316 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:11.320 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:29:11.320 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:29:11.320 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:29:11.320 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:29:11.320 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:29:11.324 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:29:11.393 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:11.493 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:11.594 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:11.695 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:11.796 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:11.896 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:11.928 I/auditd ( 4086): Starting up
01-03 18:29:11.929 E/auditd ( 4086): Failed on audit_set_pid with error: Protocol not supported
01-03 18:29:11.929 I/auditd ( 4086): Exiting
01-03 18:29:11.997 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:12.098 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:12.198 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:12.198 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:29:12.207 D/Index ( 2411): Indexing locale 'de_DE' took 70351 millis
01-03 18:29:12.207 E/WifiStateMachine( 1576): Failed to setup control channel, restart supplicant
01-03 18:29:12.207 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:29:13.565 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:29:13.565 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:29:14.332 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:29:14.332 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:29:14.332 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:29:14.332 D/alsa_pcm( 1321): pcm_close()
01-03 18:29:14.335 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:29:14.335 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:29:14.337 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:29:14.636 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:29:14.637 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:29:14.637 E/SoftapController( 1322): Softap fwReload failed
01-03 18:29:14.637 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '148 softap fwreload wlan0 STA' failed with '400 148 SoftAP command has failed'
01-03 18:29:14.638 D/CommandListener( 1322): Setting iface cfg
01-03 18:29:14.638 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:29:14.639 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:29:14.640 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:29:14.642 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:29:14.650 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:29:14.670 I/wpa_supplicant( 4093): Successfully initialized wpa_supplicant
01-03 18:29:14.671 I/wpa_supplicant( 4093): rfkill: Cannot open RFKILL control device
01-03 18:29:15.273 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:15.275 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:15.279 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:29:15.279 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:29:15.279 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:29:15.279 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:29:15.279 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:29:15.283 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:29:15.543 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:15.544 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:16.036 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:16.037 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:16.658 I/auditd ( 4097): Starting up
01-03 18:29:16.659 E/auditd ( 4097): Failed on audit_set_pid with error: Protocol not supported
01-03 18:29:16.659 I/auditd ( 4097): Exiting
01-03 18:29:17.771 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:17.774 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:18.218 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:18.218 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:18.384 E/wpa_supplicant( 4093): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:29:18.384 E/wpa_supplicant( 4093): nl80211: Could not set interface 'wlan0' UP
01-03 18:29:18.385 E/wpa_supplicant( 4093): wlan0: Failed to initialize driver interface
01-03 18:29:18.771 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:18.773 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:21.404 I/auditd ( 4103): Starting up
01-03 18:29:21.405 E/auditd ( 4103): Failed on audit_set_pid with error: Protocol not supported
01-03 18:29:21.405 I/auditd ( 4103): Exiting
01-03 18:29:21.867 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:29:21.867 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:29:21.867 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:29:21.868 D/alsa_pcm( 1321): pcm_close()
01-03 18:29:24.754 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:24.855 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:24.956 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:25.056 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:25.157 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:25.258 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:25.358 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:25.459 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:25.560 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:25.660 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:25.761 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:25.862 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:25.962 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:26.063 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:26.164 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:26.176 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:26.179 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:26.183 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:29:26.183 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:29:26.183 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:29:26.183 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:29:26.183 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:29:26.187 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:29:26.265 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:26.365 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:26.416 I/auditd ( 4107): Starting up
01-03 18:29:26.417 E/auditd ( 4107): Failed on audit_set_pid with error: Protocol not supported
01-03 18:29:26.417 I/auditd ( 4107): Exiting
01-03 18:29:26.466 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:26.566 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:26.667 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:26.768 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:26.869 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:26.969 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:27.069 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:27.170 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:27.270 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:27.371 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:27.472 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:27.572 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:27.673 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:27.774 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:27.874 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:27.975 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:28.076 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:28.176 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:28.277 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:28.378 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:28.478 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:28.579 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:28.680 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:28.780 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:28.881 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:28.982 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:29.082 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:29.183 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:29.195 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:29:29.195 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:29:29.195 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:29:29.196 D/alsa_pcm( 1321): pcm_close()
01-03 18:29:29.230 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:29.232 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:29.236 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:29:29.236 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:29:29.236 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:29:29.236 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:29:29.236 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:29:29.240 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:29:29.284 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:29.385 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:29.486 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:29.587 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:29.688 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:29.688 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:29:29.694 E/WifiStateMachine( 1576): Failed to setup control channel, restart supplicant
01-03 18:29:29.694 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:29:31.163 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:29:31.163 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:29:31.167 I/auditd ( 4111): Starting up
01-03 18:29:31.168 E/auditd ( 4111): Failed on audit_set_pid with error: Protocol not supported
01-03 18:29:31.168 I/auditd ( 4111): Exiting
01-03 18:29:31.835 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:31.837 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:31.932 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:29:31.933 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:29:31.935 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:29:32.238 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:29:32.238 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:29:32.238 E/SoftapController( 1322): Softap fwReload failed
01-03 18:29:32.239 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '156 softap fwreload wlan0 STA' failed with '400 156 SoftAP command has failed'
01-03 18:29:32.240 D/CommandListener( 1322): Setting iface cfg
01-03 18:29:32.240 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:29:32.240 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:29:32.241 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:29:32.243 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:29:32.248 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:29:32.262 I/wpa_supplicant( 4119): Successfully initialized wpa_supplicant
01-03 18:29:32.263 I/wpa_supplicant( 4119): rfkill: Cannot open RFKILL control device
01-03 18:29:32.507 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:32.508 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:33.222 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:33.223 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:34.177 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:34.180 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:35.971 E/wpa_supplicant( 4119): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:29:35.971 E/wpa_supplicant( 4119): nl80211: Could not set interface 'wlan0' UP
01-03 18:29:35.971 E/wpa_supplicant( 4119): wlan0: Failed to initialize driver interface
01-03 18:29:36.629 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:36.631 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:36.989 I/auditd ( 4124): Starting up
01-03 18:29:36.990 E/auditd ( 4124): Failed on audit_set_pid with error: Protocol not supported
01-03 18:29:36.990 I/auditd ( 4124): Exiting
01-03 18:29:38.321 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:38.323 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:38.821 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:38.823 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:39.742 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:39.743 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:41.899 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:41.901 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:42.012 I/auditd ( 4131): Starting up
01-03 18:29:42.013 E/auditd ( 4131): Failed on audit_set_pid with error: Protocol not supported
01-03 18:29:42.013 I/auditd ( 4131): Exiting
01-03 18:29:42.350 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:42.450 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:42.551 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:42.652 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:42.671 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:42.673 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:42.753 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:42.854 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:42.954 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:43.054 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:43.097 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:43.098 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:43.155 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:43.255 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:43.356 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:43.456 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:43.493 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:43.495 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:43.557 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:43.657 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:43.757 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:43.787 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:43.789 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:43.858 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:43.959 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:44.059 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:44.160 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:44.261 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:44.361 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:44.462 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:44.563 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:44.663 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:44.764 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:44.865 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:44.965 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:45.065 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:45.165 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:45.266 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:45.367 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:45.467 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:45.568 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:45.669 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:45.770 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:45.870 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:45.971 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:46.032 I/auditd ( 4138): Starting up
01-03 18:29:46.032 E/auditd ( 4138): Failed on audit_set_pid with error: Protocol not supported
01-03 18:29:46.032 I/auditd ( 4138): Exiting
01-03 18:29:46.072 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:46.172 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:46.273 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:46.374 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:46.475 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:46.575 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:46.676 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:46.722 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:46.725 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:46.777 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:46.878 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:46.979 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:47.079 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:47.179 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:47.280 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:47.280 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:29:47.281 E/WifiStateMachine( 1576): Failed 6 times to start supplicant, unload driver
01-03 18:29:47.285 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:29:47.293 D/Index ( 2411): Deleting data for locale 'de_DE' took 10 millis
01-03 18:29:47.352 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:47.354 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:48.733 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:29:48.733 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:29:48.914 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:48.915 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:49.476 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:29:49.477 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:29:49.479 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:29:49.779 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:29:49.780 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:29:49.780 E/SoftapController( 1322): Softap fwReload failed
01-03 18:29:49.780 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '164 softap fwreload wlan0 STA' failed with '400 164 SoftAP command has failed'
01-03 18:29:49.781 D/CommandListener( 1322): Setting iface cfg
01-03 18:29:49.781 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:29:49.781 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:29:49.783 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:29:49.784 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:29:49.789 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:29:49.802 I/wpa_supplicant( 4148): Successfully initialized wpa_supplicant
01-03 18:29:49.803 I/wpa_supplicant( 4148): rfkill: Cannot open RFKILL control device
01-03 18:29:51.792 I/auditd ( 4149): Starting up
01-03 18:29:51.793 E/auditd ( 4149): Failed on audit_set_pid with error: Protocol not supported
01-03 18:29:51.793 I/auditd ( 4149): Exiting
01-03 18:29:52.008 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:29:52.008 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:29:52.008 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:29:52.009 D/alsa_pcm( 1321): pcm_close()
01-03 18:29:52.317 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:52.318 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:52.320 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:29:52.320 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:29:52.320 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:29:52.320 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:29:52.320 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:29:52.323 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:29:53.501 E/wpa_supplicant( 4148): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:29:53.501 E/wpa_supplicant( 4148): nl80211: Could not set interface 'wlan0' UP
01-03 18:29:53.501 E/wpa_supplicant( 4148): wlan0: Failed to initialize driver interface
01-03 18:29:55.201 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:55.202 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:56.521 I/auditd ( 4154): Starting up
01-03 18:29:56.521 E/auditd ( 4154): Failed on audit_set_pid with error: Protocol not supported
01-03 18:29:56.521 I/auditd ( 4154): Exiting
01-03 18:29:57.435 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:57.435 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:58.168 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:29:58.169 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:29:59.890 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:29:59.990 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:00.091 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:00.192 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:00.292 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:00.393 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:00.494 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:00.594 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:00.695 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:00.796 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:00.896 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:00.997 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:01.098 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:01.198 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:01.274 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:30:01.274 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:30:01.275 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:30:01.275 D/alsa_pcm( 1321): pcm_close()
01-03 18:30:01.299 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:01.400 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:01.500 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:01.541 I/auditd ( 4159): Starting up
01-03 18:30:01.542 E/auditd ( 4159): Failed on audit_set_pid with error: Protocol not supported
01-03 18:30:01.542 I/auditd ( 4159): Exiting
01-03 18:30:01.601 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:01.702 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:01.802 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:01.903 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:02.003 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:02.104 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:02.205 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:02.305 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:02.406 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:02.506 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:02.607 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:02.707 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:02.807 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:02.908 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:03.008 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:03.070 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:03.071 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:03.073 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:30:03.073 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:30:03.073 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:30:03.073 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:30:03.073 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:30:03.076 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:30:03.109 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:03.209 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:03.310 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:03.410 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:03.510 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:03.611 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:03.711 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:03.811 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:03.911 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:04.012 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:04.112 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:04.212 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:04.312 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:04.317 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:04.318 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:04.413 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:04.513 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:04.613 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:04.636 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:04.638 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:04.714 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:04.814 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:04.815 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:30:04.816 E/WifiStateMachine( 1576): Failed to setup control channel, restart supplicant
01-03 18:30:04.816 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:30:05.243 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:05.245 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:06.127 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:30:06.127 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:30:06.141 I/auditd ( 4167): Starting up
01-03 18:30:06.142 E/auditd ( 4167): Failed on audit_set_pid with error: Protocol not supported
01-03 18:30:06.142 I/auditd ( 4167): Exiting
01-03 18:30:06.870 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:30:06.870 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:30:06.872 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:30:07.174 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:30:07.174 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:30:07.174 E/SoftapController( 1322): Softap fwReload failed
01-03 18:30:07.175 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '172 softap fwreload wlan0 STA' failed with '400 172 SoftAP command has failed'
01-03 18:30:07.177 D/CommandListener( 1322): Setting iface cfg
01-03 18:30:07.177 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:30:07.177 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:30:07.179 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:30:07.180 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:30:07.185 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:30:07.198 I/wpa_supplicant( 4174): Successfully initialized wpa_supplicant
01-03 18:30:07.199 I/wpa_supplicant( 4174): rfkill: Cannot open RFKILL control device
01-03 18:30:08.093 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:08.094 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:08.829 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:08.832 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:10.901 E/wpa_supplicant( 4174): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:30:10.901 E/wpa_supplicant( 4174): nl80211: Could not set interface 'wlan0' UP
01-03 18:30:10.902 E/wpa_supplicant( 4174): wlan0: Failed to initialize driver interface
01-03 18:30:10.994 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:10.994 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:11.557 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:11.559 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:11.905 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:11.908 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:11.916 I/auditd ( 4180): Starting up
01-03 18:30:11.916 E/auditd ( 4180): Failed on audit_set_pid with error: Protocol not supported
01-03 18:30:11.916 I/auditd ( 4180): Exiting
01-03 18:30:12.320 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:12.321 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:12.714 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:12.715 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:13.233 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:13.236 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:13.691 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:13.691 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:16.788 D/AudioHardware( 1321): AudioHardware pcm playback is going to standby.
01-03 18:30:16.788 D/AudioHardware( 1321): closePcmOut_l() mPcmOpenCnt: 1
01-03 18:30:16.788 D/alsa_route( 1321): route_set_controls() set route 24
01-03 18:30:16.788 D/alsa_pcm( 1321): pcm_close()
01-03 18:30:16.935 I/auditd ( 4187): Starting up
01-03 18:30:16.936 E/auditd ( 4187): Failed on audit_set_pid with error: Protocol not supported
01-03 18:30:16.936 I/auditd ( 4187): Exiting
01-03 18:30:17.289 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:17.390 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:17.490 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:17.591 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:17.691 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:17.792 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:17.893 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:17.907 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:17.910 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:17.914 D/AudioHardware( 1321): AudioHardware pcm playback is exiting standby.
01-03 18:30:17.914 D/AudioHardware( 1321): openPcmOut_l() mPcmOpenCnt: 0
01-03 18:30:17.914 D/alsa_route( 1321): route_info->sound_card 0, route_info->devices 0
01-03 18:30:17.914 D/alsa_pcm( 1321): pcm_open(0x0001f000)
01-03 18:30:17.914 D/alsa_pcm( 1321): pcm_open() card 0, device 0, Playback
01-03 18:30:17.918 D/alsa_route( 1321): route_set_controls() set route 0
01-03 18:30:17.993 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:18.095 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:18.195 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:18.296 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:18.396 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:18.496 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:18.597 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:18.614 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:18.615 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:18.697 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:18.798 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:18.899 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:18.999 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:19.100 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:19.201 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:19.301 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:19.402 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:19.503 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:19.603 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:19.704 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:19.805 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:19.905 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:20.005 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:20.106 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:20.206 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:20.306 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:20.406 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:20.507 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:20.607 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:20.708 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:20.809 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:20.909 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:21.010 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:21.111 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:21.212 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:21.312 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:21.371 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:21.373 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:21.413 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:21.514 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:21.615 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:21.716 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:21.817 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:21.917 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:21.956 I/auditd ( 4193): Starting up
01-03 18:30:21.957 E/auditd ( 4193): Failed on audit_set_pid with error: Protocol not supported
01-03 18:30:21.957 I/auditd ( 4193): Exiting
01-03 18:30:22.018 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:22.103 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:22.105 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:22.119 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:22.220 E/WifiHW ( 1576): Supplicant not running, cannot connect
01-03 18:30:22.220 E/WifiMonitor( 1576): startMonitoring(wlan0) failed!
01-03 18:30:22.227 E/WifiStateMachine( 1576): Failed to setup control channel, restart supplicant
01-03 18:30:22.227 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:30:22.427 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:22.428 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:23.012 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:23.013 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:23.462 D/WifiHW ( 1576): Read wifi chip type OK ! wifi_chip_type = RK901
01-03 18:30:23.462 D/WifiHW ( 1576): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-03 18:30:23.951 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:23.952 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:24.203 D/Tethering( 1576): sendTetherStateChangedBroadcast 1, 0, 0
01-03 18:30:24.203 D/Tethering( 1576): InitialState.processMessage what=4
01-03 18:30:24.205 D/Tethering( 1576): sendTetherStateChangedBroadcast 0, 0, 0
01-03 18:30:24.356 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:24.357 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:24.507 D/WifiHW ( 1576): Wifi driver is ready for now. timeout=149
01-03 18:30:24.507 E/WifiHW ( 1322): Failed to open wlan fw path param (No such file or directory)
01-03 18:30:24.507 E/SoftapController( 1322): Softap fwReload failed
01-03 18:30:24.508 E/WifiStateMachine( 1576): Failed to reload STA firmware java.lang.IllegalStateException: command '180 softap fwreload wlan0 STA' failed with '400 180 SoftAP command has failed'
01-03 18:30:24.509 D/CommandListener( 1322): Setting iface cfg
01-03 18:30:24.509 D/CommandListener( 1322): Trying to bring down wlan0
01-03 18:30:24.509 D/CommandListener( 1322): Clearing all IP addresses on wlan0
01-03 18:30:24.511 E/WifiMonitor( 1576): killSupplicant p2ptrue init.svc.wpa_supplicant=unknown init.svc.p2p_supplicant=unknown
01-03 18:30:24.512 D/WifiMonitor( 1576): startMonitoring(wlan0) with mConnected = false
01-03 18:30:24.519 D/BluetoothAdapter( 2411): 97828658: getState() : mService = null. Returning STATE_OFF
01-03 18:30:24.544 I/wpa_supplicant( 4206): Successfully initialized wpa_supplicant
01-03 18:30:24.545 I/wpa_supplicant( 4206): rfkill: Cannot open RFKILL control device
01-03 18:30:25.110 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:25.112 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:26.527 I/auditd ( 4208): Starting up
01-03 18:30:26.528 E/auditd ( 4208): Failed on audit_set_pid with error: Protocol not supported
01-03 18:30:26.528 I/auditd ( 4208): Exiting
01-03 18:30:28.143 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:28.143 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:28.256 E/wpa_supplicant( 4206): Could not set interface wlan0 flags (UP): Operation not permitted
01-03 18:30:28.256 E/wpa_supplicant( 4206): nl80211: Could not set interface 'wlan0' UP
01-03 18:30:28.256 E/wpa_supplicant( 4206): wlan0: Failed to initialize driver interface
01-03 18:30:28.852 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:28.854 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:29.444 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:29.444 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:30.061 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:30.062 E/AudioTrack( 1576): AudioTrack::set : Exit
01-03 18:30:31.273 I/auditd ( 4215): Starting up
01-03 18:30:31.274 E/auditd ( 4215): Failed on audit_set_pid with error: Protocol not supported
01-03 18:30:31.274 I/auditd ( 4215): Exiting
01-03 18:30:32.420 W/AudioTrack( 1576): AUDIO_OUTPUT_FLAG_FAST denied by client
01-03 18:30:32.422 E/AudioTrack( 1576): AudioTrack::set : Exit
2015/12/06 - 16:25
Wifi chip is AP6476. However it will not start. So, what has happen? Did you try to flash a strange kernel (with another firmware) into the tab?
phil12623
Forum Posts: 16
2015/12/06 - 16:32
I flashed riley 1.6 first, with the .img files included (kernel, misc, system, loader, paramter, boot, recovery). i also tried other riley roms and kasyt kitkat rom, always with included files via rom_flash_tool. Stock roms which where alwyas just one .img file i flashed with rk_batch_tool via restore button. last i flashed was your rom with replaced kernel.img you said (für pipo m6 pro). i forgot to say i have the pipo m6 pro with 3g function. 3g and gps seem to work. wifi and bt not. before i flashed anything everything was working as i said... is there any chance to get it working again?
2015/12/06 - 16:41
Yes, the Chip is also good for GPS.
AP6476 --- 2.4G WIFI + BT4.0 + FM (rx) + GPS
For me this looks like a hardware malefunction. Could be a strange kernel flashed it's firmware into the chip. Unfortunately I see no way out. Sorry.
phil12623
Forum Posts: 16
2015/12/06 - 17:29
Is this helping somehow? https://github.com/linuxium/3188-SRC-ORIG/blob/master/kernel/drivers/net/wireless/Kconfig is this original driver that can fix the problem? Or what is that stuff good for? I just found it by googling my wifi chip
2015/12/06 - 17:42
We do not have Pipo kernel sources and defconfig ...
You can try to flash other 3G builds from this forum. Maybe one of the older kernel will work.
60 Guest(s)
Devices in use: Desktop (55), Phone (5)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
