2015/12/03
I really need help from experts! I got my Pipo m6 pro yesterday and almost everthing was fine. I could turn on wifi and connect to the internet. But stock rom was a bit laggy so i decided to flash riley rom 1.6. I thought everything was okay, did it like in instruction said and i got no error messages or such things while flashing. Then i waited until the tablet booted up and everything was just fine, expect wifi and bluetooth. I was not able to turn it on. It was saying "turning wifi on..." but nothing happened. Sometimes the button moved to the right but shortly after back to the left. I tried hard resets, wiping and even different custom roms and in the end stock rom from pipo server. Same result. Im just not able to turn wifi or bt on. I read about that problem as a generell problem on android sometimes. But nothing helped yet. I dont know what to do. Unfortenately the tablet was uses so i dont know which rom was installed when i got it. It was some kind of stock i guess, because of Pipo launcher and chinese language. But in comparison with the stock rom running now i couldnt chose between diplay modes for instance... So if anyone can help me i would be thankful!!! Oh i forgot: i flashed the costum roms with Rom_Flash_Tool_137 and stock rom with RKBatchTool unsing restore button.
Could be that there are different hardware revisions in the field. What is the running build? JB or KK?
Ok. And what is the currently running build?
Ok, you are on gen1 loader. Here is a LP build, confirmed running on M6 pro: http://crewrktablets.arctablet.com/?p=5617
Change the kernel in folder rockdev/Image and install model fix when first boot into CWM.
2015/12/03
Change the kernel.img with ?? The one from the Link under confirmed installations on...
Pipo M6 pro (AP6476 wifi), model fix ?
Yes.
2015/12/03
So something has gone wrong... What did i do? I downloaded the build v1.1 and the kernel for pipo m6 pro and the model fix. Then i changed the kernel like you said and startet RKandroidtool as administrator. Erased IDB - everthing was okay - and then clicked run to flash. But now it says ERROR: Download failed and ERROR: Run failed ... what have i done wrong?
Wrong loader or wrong partiton layout. Just to test, pls change this parameter file in folder rockdev: http://crewrktablets.arctablet.com/?wpfb_dl=2667 and try again, incl. eraseIDB.
So, the question is what hardware revision your tab is?
Open the included terminal (see developer options) and type:
cat /sys/class/rkwifi/chip
Post the result.
To enable developer options tap 5 times on build number.
60 Guest(s)
Devices in use: Desktop (51), Phone (9)
mongol
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
