2013/12/28
I got the m6pro 3g version and on the first day I took about four pictures with it and after that I get this error "unfortunately gallery has stopped" every time I try to use the camera. I installed a new camera app, same problem' did the pin reset at the back' same problem' did a factory reset still got the same problem,last night I flashed it with rileyrom 1.5 and am still having the same problems.
Please is this a firmaee issue or  a hardware issue. I really want the camera to work because returning it will be very costly' thanks for all the help.
2014/01/03
Hello I too have received pipo few days ago and I have the same problem with your camera! No I do not work, nor the one behind the one in front of it! I tried to install other roms and applications but I have not solved the problem! You've solved? I'm tempted to open the tablet but do not know how to do! Let me know
2014/01/31
I have the Pipo M6 Pro 32GB model and I also have the same problem with my camera. My speakers have also stopped working a couple days ago. I've emailed the website from which I purchased the tablet, http://www.spemall.com but I haven't heard anything as of yet, probably because of the Chinese New Year. Has anyone else had any problems with there speakers?
2014/01/31
I found a solution on another website forum. It's a fix for the camera.
here's where I got the info http://www.freaktab.com/showthread.php?9073-Pipo-M6-Pro-3G-Unfortunately-Gallery-has-stopped
This is what someone else posted, I've already fixed mine. You may or may not feel comfortable opening up your tablet. Here's what they posted: They posted a video in chinese of course: http://www.pipo.com/view.php?pid=54&id=70
and they posted pictures:
The problem was with the part circled in the first photo which doesn't make contact. Just push it down and then put some scotch-tape to fix. For me worked fine.
https://www.dropbox.com/s/1vv3fix8xdhglrg/cam.JPG
https://www.dropbox.com/s/0ppluzwvzrrbops/cam2.jpg
2014/01/07
Hi again.
After some tries after installing kasty ROM 4.4.2, my camera failed again. In this version, the system showed a message indicating "cannot establish connectio to camera". So, i decided to open the tablet a check camera conections (as getsome2 indicated).
I opened the tablet guided by the video that getsome2 showed. This tablet was easier to open because the speakers are no attached to rear panel, but they are in the front tablet´s panel. So you can separated rear panel from front panel withount disconnecting any wire.
Aftewards, i check the camera connections and i noticed that one of them was moved. I pressed the connection well and then i reboot de tablet and i tried the camera. So, the problem was solved.
I attach some images and i hope this be useful for anybody.
First. After open the tablet, i located the camera and its chipset and connections.
Second. I noticed that connection next to camera was not properly fixed.
Third. I pressed the bad connection and i tested the camera after rebooting the tablet. After that, the camera worked fine.
Fourth. Finally, I have fixed the connection to avoid future problems and i have closed the tablet.
The following users say thank you to dionicv for this useful post:
admin, aviatorMost Users Ever Online: 749
82 Guest(s)
Devices in use: Desktop (72), Phone (10)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
