Here is an Android 4.2.2 Jelly Bean rooted firmware for the PIPO M6 (3G model) tablet based on latest official update from Pipo dated 2013/07/31
( update_M6_3G_chinese_20130731.img )
Build information:
Kernel:Â Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #49 SMP PREEMPT Sat Jul 27 11:25:03 CST 2013
Android 4.2.2 JB:Â rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.ljh.20130704.112304:eng/opinions-on-teclast-p90hdst-keys
Stock firmware revision history:
- Google Search Bar overlay while screen is changing to vertical position.
- 3G Network will automatically disconnected after sleep.
- Change ddr to 600MHz
- root with latest SuperSU version 1.51 (free version)
- removed most Chinese and unnecessary applications, removed Certificate Center asking for product key
- increased space for applications (/data partition) to 4 GB
Download:Â kasty-pipo-m6_3G-422-20130731-rooted4.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a PIPO M6 tablet to test the custom firmware. Â
Thanks tzutolin for the tipÂ
tzutolin, I_C_E, shahidmufti If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/07/08
lykeul said
yes, thank you.I have pipo m6 3G with kasty rom 31/07/2013.
Now let me rephrase my question:
how can I install pipo's launcher with this rom please ?
The PiPO's launcher is removed from this rom by default. So there is no way to install it with this rom.
(Unless the admin makes a rom without removing the pipo's launcher)
Actually you should be able to install it on our custom firmware, just copy the file below to /system/app directory.
update_M6_3G_chinese_20130731_StandardLauncher.pipo.family.retina_1.00.26_build_20130720.nm
To copy the file, you may need a special file explorer with "root" capabilities, such as ES File Explorer File Manager, free on Google Play Store.
Jammy007 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/07/08
 Can anyone help me installing rockchip usb driver on my sony vio win7 prof 64bit version because i have tried lot of procedures mentioned on various forums but not succeeded yet.
i am always getting pink icon while running rockchip utility and when pressing 'restore' button my tablet shutdown and nothing happened after that. any help in this regard appreciated. by the way what is the correct way to start m6 in recovery/upgrade mode
Here there are multiple tips on how to flash a rockchip based tablet
http://www.arctablet.com/blog/forum/archos-arnova-general/possible-fixes-and-repair-methods-for-your-rockchip-tablet/
lykeul said
Thank you but when I copy the file nothing happens, I can not install either.
You have to set also the permissions, basic stuff .
72 Guest(s)
2 Guest(s)
Devices in use: Desktop (60), Phone (12)
alertscam
aolmail7448
Arc123456789
forty42
samih
macsierra2
