Here is an Android 4.2.2 Jelly Bean rooted firmware for the PIPO M6 (3G model) tablet based on latest official update from Pipo released 2013/08/14
( update_M6_3G_20130814.img )
Build information:
Kernel:Â Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #81 SMP PREEMPT Wed Aug 14 14:33:30 CST 2013
Android 4.2.2 JB:Â rk30sdk-eng 4.2.2 JDQ39 eng.root.20130814.154159 test-keys
- root with latest SuperSU version 1.51 (free version)
- removed most Chinese and unnecessary applications, removed Certificate Center asking for product key
- increased space for applications (/data partition) to 4 GB
- NEW! kernel modules (cifs, tun, lan, serial, xpad) compiled by Oma & Crew RKTablets, thank guys!
Download:Â kasty-pipo-m6_3G-422-20130814-rooted4.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a PIPO M6 tablet to test the custom firmware. Â
shahidmufti, tzutolin, eurnun04, FloN, E_g_o_r, bafun, Peggy_zhou, Balrog, mihail nikeshin If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/08/22
I've tried to connect to server by OpenVpn, but it failed.
It seems like tun.ko doesn't works properly.
- On some ICS images the permissoions on /dev/tun might be wrong, or the tun module might be missing completely.
- Cannot open TUN
- Exiting due fatal error
It seems like tun.ko module is not loaded in kernel.
2013/08/22
mobius7 said
globula_neagra said
you can load the module yourself![]()
more details please...
oh, insmod tun.ko
but how i can do this automaticaly?
It does not working:
root@android: / # insmod /system/lib/modules/tun.ko
insmod: init_module '/system/lib/modules/tun.ko' failed (Exec format error)
root@android: / #Â
modules has wrong format!!!!
Thanks for reporting that dem.
I expected the modules to load properly on a stock Pipo kernel. Can you do a dmesg to see if it gives more details about the format error and post the results here ? I'll see if I can fix it...
2013/08/22
Thanks for reporting that dem.I expected the modules to load properly on a stock Pipo kernel. Can you do a dmesg to see if it gives more details about the format error and post the results here ? I'll see if I can fix it...
Problem in version number of kernel.
<3>[48703.918580] tun: version magic '3.0.8+ preemp mod_unload ARMv7 ' should be '3.0.36+ SMP preemp mod_unload ARMv7 '
It's hapend for all modules. By the way, if it possible, please add module usbnet.ko and axis.ko!!!
Thanks!
I have rebuilt a custom firmware with modules that should work with Linux 3.0.36+ kernel, these modules were built by Oma & Crew RKTablets as well.
New firmware download: kasty-pipo-m6_3G-422-20130814-rooted4b.zip
I can't test these firmware modifications at the moment as I don't have a RK3188 based tablet, please report how it goes, so I can update the firmware file in post #1 and add the modules on custom firmwares for other tablets as well.
usbnet.ko and axis.ko modules aren't in the package yet, I'll see what can be done.
tzutolin, Balrog If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/08/22
I have rebuilt a custom firmware with modules that should work with Linux 3.0.36+ kernel, these modules were built by Oma & Crew RKTablets as well.Â
Thank you!  Now modules are loaded correctly by hand. Module axis.ko as I understood is a part of android kernel and my dlink usb->ethernet is working correctly.Â
But, I was not able to load modules tun and etc automaticaly!!
I used:
su
touch /system/etc/init.d/01mod
chmod 755 Â /system/etc/init.d/01mod
But after reboot I did not find tun-module loaded.
Also, there is not file initd.log in /data directory.
What can be a problem?
2012/02/20
Ty for the rom, I used the link from the first post of this thread, All works well apart from one problem, the battery dosnt charge or discharge, it just stays at 90% no matter how long I charge it, Im starting to really, pulling my hair out over this, ruining my tablet (, any help would be appreciated pls.
update , have fixed it now, just calibrated battery early and it started to charge, then calibrated again at 100%.
2013/01/30
2013/08/22
Dvalin21 said
Can anyone tell me if there is a big difference in wifi performance with the 3G and non-3G models? Â
I think there is no different. Different is in power consumption 3G models.
In my 3G M6 there is some process (Radio Interface Layer for 3G), which does not allow CPU to go into a Deep Sleep state.Â
91 Guest(s)
Devices in use: Desktop (82), Phone (9)
Morris028
robertgdfdgdfss
wtf
jdani20001027
thinkappleeight
dubsiki
