Here is an Android 4.2.2 Jelly Bean rooted firmware for the PiPO M8 PRO (3G model)
it is based on latest official update published on 2013/11/11.
( update-M8pro_3G_20130917.img )
Build information:
Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.4.3 (GCC) ) #282 SMP PREEMPT Tue Sep 17 14:38:20 CST 2013
Android 4.2.2 JB: rk30sdk-eng 4.2.2 JDQ39 eng.root.20131111.151640 test-keys
Notes:
- Certificate Center and original PiPO launchers have been kept in the firmware
- any update received thru OTA may interfere with our custom firmware, we recommend not to apply any OTA update
- root with latest SuperSU version 1.65 (free version)
- NEW! : optional ClockworkMod (CWM) Recovery easy install package
- all launchers have been kept: stock Android, Kid Launcher and PiPO launcher
Download: kasty-pipo-m8_pro_3G-422-20131111-rooted4.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a PIPO M8 Pro tablet to test the custom firmware.
cryback79, mattiesrag, Faisal Reza If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/11/26
Hello and thank you for custom ROM,
Is it possible to revert to any oficial ROM from Pipo? Partition formatting causes any problem?
Does this ROM fix the battery draining of this tablet in sleep mode?
Regards,
The following users say thank you to cryback79 for this useful post:
pan2fire, frog-poprigai
2013/07/19
Thanks for this ROM. It installs flawlessly.
Compared to my previous ROM (arcTablet M8 pro 3G from 2 iterations ago) the tablet is now faster and smoother, wifi is significantly improved.
Trying it over 2 days I have only found a very minor issue which probably comes from the base stock ROM: the speaker sound level buttons are slightly brighter than the other buttons, nothing to worry about.
The line: NEW! : optional ClockworkMod (CWM) Recovery easy install package had me think that there was an option for this during installation, but I did not see one. However since the arcTools are there, installation of CWM is a breeze.
2013/09/13
pan2fire said
Thanks for this ROM. It installs flawlessly.Compared to my previous ROM (arcTablet M8 pro 3G from 2 iterations ago) the tablet is now faster and smoother, wifi is significantly improved.
Anyone having problems with 3g? I haven't been able to connect yet - will try again tonight. Regards
2013/07/19
mattiesrag said
Used a different 3G network sim and got connected - but not a very strong signal.
The M8 pro 3G does not support the 850MHZ frequency that several networks are using, depending on your country. I got caught here in Australia where the first card I bought was for a 850MHZ network. Of course, then the tablet could not connect. You have to select a network that uses 900MHZ. You would find a good choice of suitable networks in most parts of the world, but you'd be out of luck in the US for example where you could only use 2G at that frequency.
I do not see a change in 3G signal strength after updating my ROM to this one.
Cheers
2013/09/13
pan2fire said
mattiesrag said
Used a different 3G network sim and got connected - but not a very strong signal.The M8 pro 3G does not support the 850MHZ frequency that several networks are using, depending on your country. I got caught here in Australia where the first card I bought was for a 850MHZ network. Of course, then the tablet could not connect. You have to select a network that uses 900MHZ. You would find a good choice of suitable networks in most parts of the world, but you'd be out of luck in the US for example where you could only use 2G at that frequency.
Cheers
Thanks for the info. At last I have discovered what the problem is. The 3G sim is not making a good connection when pushed in. As an interim measure I wedged a very thin piece of plastic foil behind the sim and now it works. Anyone know how to open M8 Pro ??? I would like to do a more permanent fix.
Regards
2013/07/19
Images at this Chinese site show how to open the case. However they use a small screwdriver to pry open the corner. To avoid scratches, I would suggest using strong guitar picks instead.
I personally use two plastic prying tools. A search for "Plastic phone's LCD Screen Opening Pry Tool Opener" on eBay will give you a good choice.
Also they show starting at the power switch corner, be careful that switch is fragile. I start at the opposite corner... safer.
The following users say thank you to pan2fire for this useful post:
mattiesrag
2013/09/13
Kit-Kat 4.4 (WiFi) now out. Still waiting for 3G Version
2013/09/13
Hi Admin
Found this on a Russian site. It's 4.4.2 KitKat. https://disk.yandex.com/public/?hash=anfq4cC6nLTS/qnVcYxD4UrzjU9miyYKWfEAmwctEDs%3D
Seems like this guy has been doing a re-vamp of his previous rom.
Might be worth a try.
EDIT Am running this firmware and all seems OK. Perhaps ADMIN needs to do a couple of his magical tweaks to improve it. Think sergiopoverony ported it from U8
2013/09/13
EDIT Mailed Anna again on 20/03/2013 here is her reply
Dear Friend,I am afraid I am not sure about this. (4.4 release date)Our technicians gave me that answer before, and when I asked them again after the Spring Festival, they didn't gave me answer.What I know is that they are testing the 4.4 firmware.Best regards,AnnaPiPo Technology Co,.Ltd(digisino group)金森数码产品(深圳)有限公司
website: http://www.pipo.com.cn
Skype: Anna_pipo
Mailed Anna at PIPO. This is her reply.
金森数码产品(深圳)有限公司
Skype: Anna_pipo
mattiesrag said
https://www.wetransfer.com/downloads/2d8941cd0f1a635627c3f95b358f1be620140417012139/777116a5f21c485a71c8e9db9aadda9120140417012139/3edd6d
Is that an official firmware ? Where does it come from ?
70 Guest(s)
Devices in use: Desktop (62), Phone (8)
