[ ROM ] Pipo M7 pro Android 4.4.2 KitKat custom root firmware (2014/03/26)
Thanks Received: 3170
2014/06/25 - 20:40
Here is an Android 4.4.2 KitKat rooted firmware for the PiPO M7 PRO (aka Max-M7pro) for both WiFI only and 3G models. This custom firmware is based on a PiPO update dated 2014/03/26 featuring small changes on the Android system and a kernel identical to previous 2014/03/06 firmware.
(M7 pro 3G & NO 3G Chinese 4.4 20140326.rar / M7 pro 3G & NO 3G Chinese 4.4 20140326.img)
Build information:
Linux Kernel: Linux version 3.0.36+ (root@lzj-desktop) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #172 SMP PREEMPT Wed Mar 5 11:03:34 CST 2014
Android 4.4.2: rockchip/rk3188/rk3188:4.4.2/KOT49H/eng.root.20140326.162553:eng/opinions-on-teclast-p90hdst-keys
RK3188Loader(L)_V2.10.bin
  • root with latest SuperSU version 2.00 (free version)
  • increased space for applications (/data partition) to 7 GB
  • added Google Experience Launcher (GEL) in addition to PiPO's stock launcher
  • use optional package to fix broken apps (Contacts/People and Calendar sync)
  • temporary fix for multi-user support, thanks to didierm
  • optional ClockworkMod (CWM) Recovery easy install package
Notes:
- current KitKat based firmwares should be considered as beta software
Download: kasty-pipo-m7_pro-442-20140326-rooted7.zip
If you like our work, please support us to keep the site alive and contribute to our efforts.
This firmware has not yet been flashed on a PiPO M7 Pro device, feedback is welcome.
Thanks sclstore.fr for the test Pipo M7 Pro device.
slippery, 4c.app, xorex, malaslang, pietrifly
sapomme
Forum Posts: 23
2014/06/26 - 09:54
thanks !
i'll try ASAP
Pipo m7pro 3G - ainol fire (dead) - kobo touch - wiko cink - iPhone 4 - iPad 2
slippery
2014/06/26 - 13:34
Many thanks.
On holiday ATM Coolso will flash when I get back.
4c.app
2014/07/17 - 14:39
Loaded smoothly to my Pipo M7 Pro.
Thank !
Pipo M7 Pro
slippery
2014/08/06 - 18:41
Sorry for the late reply.
This ROM flashed without problems and seems to be stable so thanks.
I would like to request that any future ROM kernel be compiled with /proc/mic_level so recording level can be adjusted. At the moment it suffers from very bad clipping and distortion making recording simple videos with sound impossible. I cant see any way of using an external mic to correct this problem.
Many thanks.
naksu007
2014/09/24 - 00:00
Hi! How i open rom in rockship batch tool? I cant extract rar file...
2014/09/24 - 00:09
RAR file ? The file we offer for download is a zip archive !
naksu007
2014/09/24 - 10:49
Sorry my bad zip file. But icant open or extract zip file.
2014/09/24 - 11:21
You can try to download it again, use another mirror from the server list on the download page.
If it still doesn't work, please post the filename you are downloading and the size of the downloaded file on your computer.
naksu007
2014/09/24 - 16:36
Hi! I try download another mirrors and mirror 3 (rest of the world) it is only what works.
Mirror 1 (america) is download 0 kb zip file and mirror 2 (russian) says server error :/
Thanks for helping now i get working rom and i can install it :)
chudst
2014/11/07 - 22:54
Hi, I just downloaded "kasty-pipo-m7_pro-442-20140306-rooted7.zip". I never did the root of the Android device, so I put the unzipped file "update.img" to the MicroSD card. When I return the card back, it asked me, if I want to make an update. I chose "Yes". It started to update the device, however then the screen turned off itself, and now I'm not able to do anything with my tablet - I'm not able to turn it on. (I tried also to charge the device, however nothing happend.) Could you please a bit help me? [Yes, yes, I'm stupid, I was used to simply jailbreak my iPhone and I didn't expect this problem with Android :)  ]
slippery
2014/11/09 - 00:40
chudst, hi.
Try re-flashing it but this time use the Rockchip Batch Tool which is linked on the download. Its fairly simple to do but read the instructions as you will need to use the reset pinhole on the tablet.
Hope that helps.
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2014/11/10 - 13:44
We have NOT sanction the update of Kasty ROM through SDCard. Where did you read the instructions to update the original RK firmware through SDCard method??. We use the BatchTool (ony version BatchTool 1.7 can work on JB and KitKat version). Admin has put up a clear instructions up there and never once did he says to update through SDCard. CONGRATS You are now "softbricked". Please read in previous posting around Jan/Feb this year for how to flash in a "softbrick" situation. May be if you are lucky you can just flash it straight away using RKBatchTool (if you are lucky).
If not you will need an extra finger to press 3 buttons on the PiPo to get it to flash.Next time dont DO THIS, READ INSTRUCTIONS in PLAIN ENGLISH CAREFULLY!
You have too much customs ROM experience that can only be flashed through CWM/TWRP Recoveries??But this is the original factory "Xyz123.img" format. Even the factory instructed to use RKBatchTool.But when using RKBatchTool use "DOWNLOAD" buttons instead of "UPGRADE" button (dont tell us that you didnt get this instructions later on)
chudst
2014/12/13 - 21:02
Thanks, both of you. However still it didn't help.
Cracktech: Sorry, I've no idea what topic do you think: I tried to find it, but I didn't found this in M7 forum. I tried to connect Pipo via USB with my laptop. I hear a sound (from laptop - just like when you connect a new device), in Device Manager is displayed "Unknown device" now. But when I turn on Rockchip Batch Tool, I don't see any connected device. (I tried to press with various combination the Power & Esc & Reset button, nothing happend.) Yes, I know I'm the new one here - sorry, I really had no idea, that admin has put up a clear instructions up there: but I just don't see them in M7 forum.
Antiko
2014/12/18 - 17:32
Hello, my Pipo M7 Pro went in tilt. So trying to upgrade firmware. The official on won't download. So I tryed this one, but there is a problem with zip-file. It won't open, maybe borken. What to do?
57 Guest(s)
Devices in use: Desktop (48), Phone (9)
mongol
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
