[ ROM ] Pipo M7 pro Android 4.4.2 KitKat custom root firmware (2014/02/12)
2014/03/13 - 18:55
r19m3
2015/01/26 - 17:46
Hi, i have never upgrade adnroid on tablet or smartphone, can you help me, how to upgrade android 4.4.2 on pipo m7 pro? I have downloaded android from the forum, Rockchip batch tool too, i started batch tool, loaded update.img, pressed restore, but there is an error, thats the operation is not suported. What I´m doing wrong? Thankś for help me.
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2015/01/27 - 07:35
Seriously?? Have you installed the Rockchip drivers too?
Here try and install this but I recommend using win7 (although Win8 is workable but you'll have less drivers and flashing errors or unless you are PC expert) >>RockChip Driver Installer : https://mega.co.nz/#!yxYDjYDS!5M7P5lBchBdTcPIiKevmGY8IKeCLLa9ZpQu8o4Sm8sQ
r19m3
2015/02/06 - 19:53
Thanks for drivers, but still it doesn’t work :-(. Maybe I’m doing something wrong. I installed drivers you sent me. Then I started Batch Tool 1.7, loaded file "update", pressed "restore", but still I have error message "the operation didn’t do, because of not supporting". Will you be so nice and send me step by step instruction how to do it? Or send me link, where I find it. Thank you again for help and your patience.
cracktech
Malaysia
Forum Posts: 432
2015/02/06 - 22:31
Lets go back to basic when in this situation : (checklist)
1. Uninstall all USB drivers related to Android ADB / other phone USB USB drivers/  Tablet USB Drivers by using this "USB DeView": http://www.nirsoft.net/utils/usb_devices_view.html  that means you are going to have to fresh install only (for now) USB drivers related to RK USB device i.e. "Rockchip USB" drivers only. (DO NOT UNINSTALL OTHER USB DRIVERS only the ones related to phones/tablet drivers)
2. Install the Rockchip Driver Installer again after completing No.1
2. Try to use Win7 -32 bit OS (64bit can do also but most Chinese drivers works best on 32bit Win7/XP/Vista OS).
3. USB USB 2.0 ports only not USB 3.0 (USB 3.0 are blue plastic connectors) Change USB ports, maybe you'll get lucky.
4. Install ALL necessary drivers - enable USB debugging on tablet. (Enable USB debugging?? Attach Tablet in "ON" condition to PC and let the PC installed the basic ADB drivers first it might take 10-15 minutes to complete)
5. Run RK Batch Tool first on PC,ONLY then attach the USB cable to Tablet and press "restore".
I am using M9Pro and it no different process to flash the ROM. Do not worry it is difficult to "hardbrick" this RK3188 devices.
r19m3
2015/02/07 - 07:55
Thanks for help. I’m going to test it.
JEssicannn
Forum Posts: 252
2019/10/23 - 01:55
138 Guest(s)
Devices in use: Desktop (130), Phone (8)
