Build information:
Kernel: Linux version 3.0.36+ (york@mid-Porsche) (gcc version 4.4.3 (GCC) ) #159 SMP PREEMPT Fri Jan 10 15:58:30 CST 2014
- root with latest SuperSU version 1.93 (free version)
- added Google Experience Launcher (GEL) in addition to PiPO's stock launcher
- use optional package to fix broken apps (Contacts/People and Calendar sync)
- temporary fix for multi-user support, thanks to didierm
- optional ClockworkMod (CWM) Recovery easy install package
Notes:
- current KitKat based firmwares should be considered as beta software
Download: kasty-pipo-m7_pro-442-20140212-rooted4.zip
This firmware was successfully flashed on a PiPO M7 Pro, thanks sclstore.fr for the test Pipo M7 Pro device.
jamesdu31 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/10/30
are you sure GPS is supported ?
I don't see any satellite ...
Should I have to switch on something ?
(I've switched on GPS in settings->location)
modify build.prop ?
Is update_GPS_4.4_20140212.img missing ?
Pipo m7pro 3G - ainol fire (dead) - kobo touch - wiko cink - iPhone 4 - iPad 2
I am not sure of anything, I just mentioned I got 1 sat. but no fix during my test, I haven't tested any further yet.
The img file listed in post#1 is the name of the stock firmware just for reference.
2014/02/21
I am not sure of anything, I just mentioned I got 1 sat. but no fix during my test, I haven't tested any further yet.The img file listed in post#1 is the name of the stock firmware just for reference.
Hey admin,
Will this work on proline L10A1G. It also uses rk3188 chipset. If not, is there any rom that would work with it that has 3G?
2014/01/31
Здравствуйте, может Вы крутите на эту MMS прошивки, смс? это было бы очень желательно. Установленная эту прошивку, в то время как впечатления очень хорошие, гораздо быстрее, таблетки. Будет попользоваться на week'm снова.
The following users say thank you to konstbu for this useful post:
hanspipo
2013/10/30
Hi Mr Admin,
thx again for this custom firmware.
Would it be possible to have an option to get a partition of 4,8 or 16 Gb ?
I need 8 Gb to convert everything to ART (I have many apps, around 2Gb with Dalvik but the need is > 4 Gb for ART)
Thx !
Our custom firmware is already set for a 4 Gb apps (/data partition)
I already commented in our forum that this value will soon be increased in our custom firmwares, probably at least to 6 Gb, maybe 8 Gb, depending on what most users require. This should be in effect for our next custom firmware builds.
I am also thinking of a procedure to let users choose the size they want in a list of few presets, this currently require some work and I will post later when something is available for testing.
2013/10/30
New release of stock kit kat:
M7pro_rk3188_892_sdk4.4_20140306.img (526Mo)
http://pan.baidu.com/s/1dDf4xxv
I think we'll soon have a new kasty
(thanks in advance)
A custom firmware should be published later today, with bigger storage space for apps (at least 6 GB, maybe 8 GB)
57 Guest(s)
