[ ROM ] Pipo M1 pro custom root Android 4.2.2 firmware (2013/08/02)
2013/08/08 - 11:18
Here is an Android 4.2.2 Jelly Bean rooted firmware for the PiPO M1 PRO (aka PiPO Max-M1pro)  tablet. This firmware is based on latest official update dated 2013/07/31.
(update_M1pro_chinese_20130802.img)
Build information:
Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.4.3 (GCC) ) #150 SMP PREEMPT Fri Aug 2 09:34:33 CST 2013
Android 4.2.2 JB: pipo/pipo/pipo:4.2.2/JDQ39/eng.root.20130801.163658:eng/opinions-on-teclast-p90hdst-keys
  • root with latest SuperSU version 1.51 (free version)
  • removed most Chinese and unnecessary applications, removed Certificate Center asking for product key
Download: kasty-pipo-m1_pro-422-20130802-rooted4.zip
pintou, sniperal03, franceschinel
pintou
2013/09/13 - 22:53
I have this running on the pipo for about a week now. It's running flawless and feels very smooth
Thanks for your effort!
sniperal03
2013/09/18 - 11:14
Hi! Thanks for the update.
May I ask if this rom resolves the battery drain during standby mode?
May I also know the difference of this update to the old one? I'm using 4.1 for my Pipo M1 right now. Is it worth the upgrade?
Thanks in advance.
RCT
2013/09/22 - 04:11
Do i need to have root before install this rom?
Thanks Received: 268
2013/09/25 - 21:08
No, you just need to know how to get the tablet in flashing mode.
baxlife
2013/12/03 - 16:14
Hi to all of you!
First of all, sorry for my english... I've bought a Pipo M1 pro, but i don't know how can obtain the root permissions or how can I get the tablet in flashing mode? someone can explain me?
Thanks.
ahkeungpc
2013/12/11 - 07:26
hi,thank you very much for your update
egon64
2013/12/19 - 09:08
When we can expect Android 4.3 or 4.4 for PIPO M1 PRO tablet ?
Regards
egon
franklinroa
2014/04/28 - 01:31
Build information:
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=0cd806949f&post=27626&forumid=163','W4fY5kTX1u',false,'j8lwa4Umfhk');
How to obtain flashing mode on Pipo m1 pro
madlsd
2014/07/05 - 11:26
Hi
I am a bit of a novice, can anyone provide instructions on how to apply the update - I have downloaded the .zip file onto the sd card
73 Guest(s)
Devices in use: Desktop (66), Phone (7)
relaytester
revoltown
tdomnic024
otismaibe
Tsuna77
