2014/01/30
I mistakenly installed a Pipo M1 Max Pro (Ryley's 1.2) firmware into my brand new Pipo M1 max.
Now it's a complete brick. It does not turn on, reset switch does nothing, vol+/reset or Vol-/reset also does nothing, and PC does not recognize it. Also tried esc+reset+vol+, but nothing happened, and PC still does not recognize it.
I'm desperated!!!
Any help will be MUCH APPRECIATED!!!.
Thanks.
David.-
You need to start the tab in mask-rom modus.
In principle like this:
2014/01/30
You need to start the tab in mask-rom modus.In principle like this:
Hi again. I managed to open the tablet, and the took off the soldered tin Rf shield over the CPU, memory banks and NAND. My Nand is a 64G08c. I tried shorting pins 7 & 8, 8 & 9, some Russian guy suggested 29&30 so I've also tried it. I did it both before connecting USB and after doing so, with or without power supply connected, but no "gong" sound from the PC, nor the flashing tool recognizing anything. Any suggestion?
Thanks.
David.-
2014/01/30
Hi again. I managed to put it in MaskRom Mode, and the RK Android Tool recognizes it as a MaskRom Rock USB. I can then erase the IDB.
However, when trying to flash the ROM, it goes a few steps and fails as follows:
"Start to run
Download USBData OK
Download USBBoot OK
Download boot OK
Start to test device
Test device OK
Start to download IDB
Error:Download IDB failed"
If I go to the Error Log, I get:
"INFO:Start to download boot
18:47:34 970Â INFO:Start to run
18:47:35 392Â INFO:Download USBData OK
18:47:36 497Â INFO:Download USBBoot OK
18:47:36 497Â INFO:Download boot OK
18:47:38 502Â INFO:Start to test device
18:47:38 506Â INFO:Test device OK
18:47:38 511Â INFO:Start to download IDB
18:47:38 515Â Flash Chip Information:
18:47:38 516Â NOÂ Â SIZE(MB)Â Manufacturer
18:47:38 516Â ----------------------------------------------
18:47:38 518Â ----------------------------------------------
18:47:38 518Â ERROR: No Found 1th chip
18:47:38 519Â Error:Download IDB failed
18:47:38 523Â ERROR:MaskRomThread failed
18:47:38 529Â ERROR:Run failed"
Any Hint?
Thanks again.
 David.-
66 Guest(s)
Devices in use: Desktop (62), Phone (4)
kalkpits
m12k
StatusQ
helloyuen
melcis
nelcis
