| Latest product reviews |
(1 votes) 03:38
Please donate to support my work |
OfflineArchos 101 XS
This is the tutorial for adb
If you get adb working than you can issue in adb
adb reboot bootloader
Which will get you in the downloading mode, you will have to install the drivers from the rockchip tools, then open the rockchip tool, if you see a green square you can flash the firmware to the tablet using the restore option.
22:46
OfflineNo Archos/Arnova device
23:37
OfflineHello if you want to flash the firmware you need to use rockchip batch tools 1.5, there are several guides in how to do it
cuttoli said
I'm trying to switch into recovery mode but impossible.
I have the P76e G6R8.
The tablet turns on with the Chinese logo.
I push on Power button and Volume – during more than 3 s.
Do you have a idea ?
Thanks.
Julien
07:48
I follow this workflow which i found on the internet.
09:37
OnlineJMI Pulse 10
You can also trying by installing adb
Then enable USB debugging, and type to enter flash mode:
09:41
15:55
Windows: echo 0xxxxx >> "%USERPROFILE%\.android\adb_usb.ini"
You add your vendor id code by using CMD
The 4 xxxx are the vendor id, so it should look something like 0x1234. Restart the pc.
After that you can try either superoneclick, or find some adb driver pack and edit some lines from android_winusb to add your device
it should look something like this
;Archos Gen8
%SingleAdbInterface% = USB_Install, USB\VID_0E79&PID_1411
%CompositeAdbInterface% = USB_Install, USB\VID_0E79&PID_1411&MI_01
%SingleAdbInterface% = USB_Install, USB\VID_0E79&PID_1569
%CompositeAdbInterface% = USB_Install, USB\VID_0E79&PID_1569&MI_01
The VID is the vendor ID amd PID = product id.
In linux you get these values by connecting the tablet to the pc, enable usb debugging and use in terminal the fallowing
lsusb
A list with all the atached usb devices will apear, but also the pid and vid for each device.
22:59
Better but not yet completed… I have now the tablet T76e recognized in the software RockChip Batch Tool.
But i'm not in recovery mode. I can't. When i push on the power button and – volume, the tablet turns on after 5 seconds.
Can i do the upgrade despite this ?
Actually, the tablet is turned on and I have the usb page displayed. I'm afraid to brick my tablet…
Thanks.
Bye.
Most Users Ever Online: 646
Currently Online: admin, makingmanrv, willy56, valerunchiks, nasca, gratton20, hashte, Mewantfirmware, milio, Lumen2003, benji059, fr-fr, tommyv, Alban1, nicco, tornicess, Original, Meewind, stef_2279, niilo, fantaz1986, geek, Bernard jackson, xadaya, mangike, sakisaka, Evdok, bunneh, trapisantander, fecnipsis, matjazz, gjeremie, Yippie, cummingsk, happyjocker59, kalas, kikoman73, giuse66, dante82
236 Guest(s)
admin: 3940
globula_neagra: 2029
Guest Posters: 39
Members: 83012
Forums: 132
Topics: 2986
Newest Members: Ambrosini, lpoarumjk, cearmacop, TaziTazi, scobo, dante82
Moderators: HaroldG (117), globula_neagra (2029), exelletor (344)
Administrators: admin (3940)
Log In
Register
Arnova and Archos support Forum
