Someone help me please with my Tablet
O+ 9.76
darknight21
Forum Posts: 28
31
2014/05/04 - 17:46
Update:
CM worked! CWM installed..
only problem is there is no camera app!
darknight21
Forum Posts: 28
32
2014/05/05 - 15:23
New Problem:
I cant copy files from my pc to internal memory, it says directory is corrupted and unreadable..
installed the fixes thru cwm:
int sd to nand fix
ext sd to nand fix
format nand fix
tablet ui fix
brightness setting fix
camera rotation fix
akku fix
pvz2 games fix..
and still camera doesnt work, downloaded camera zoom app, it says camera is not supported or disabled..
there's a bug, while playing movies with MX Player, there are several times that the device would hang and reboot by itself, mostly when charger is connected but it also happened even if not charging..
I need help :(
33
2014/05/06 - 17:23
The cam app is not there because the strange kernel will not support your cam. You need to accept this or find the stock firmware.
Don't install all fixes. When you start by flashing the stock recovery, you can afterwards install the CWM. Just load the recovery.img from the pack, tick parameter, misc and recovery. Reboot to bootloader via app RebootMenue and Run. Now you can install the pvz2 fix. That should be enough.
darknight21
darknight21
Forum Posts: 28
34
2014/05/07 - 09:18
Okay, hmmm i also found out that WLAN is disabled, how can I enable this?
35
2014/05/07 - 17:26
Boot tte tab fresh, open the terminal and type:
su
dmesg >/mnt/sdcard/dmesg.txt
Upload the log.
darknight21
darknight21
Forum Posts: 28
36
2014/05/08 - 06:11
Thanks for that comanc I was able to determine what type of ram my device uses, its DDR3 and running 360mhz..
BTW, i had a reboot and wifi is now enabled, I figured out that using the app "flash transfer" uses wifi adhoc connection for faster transferring, causes wifi to be disabled, hence i cannont use the app propertly and I cant transfer files from it..
Here's the log, can u also figure out other errors from this?
Thanks..
darknight21
Forum Posts: 28
37
2014/05/13 - 16:11
sir oma?
meandallp
38
2014/11/24 - 23:52
hello.i'm new here,so please be patient.....i have the same problem,but my tablet is ¨szenio 2016 dc.on the manufacturer web page isnt any firmware for this tab....only one that has the same configuration.
but when i installed it with android tool the scrreen isnt showing anything,you can see that the tablet is on but it stays that way....
and when i tried to install any other firmware,or kernel i get the same errors like darknight21
Someone can give me a hand?
i have the rk3066 dual core.
109 Guest(s)
Devices in use: Desktop (102), Phone (7)
Gereon2
leysdelacruz712
androiidtweeker
maxkra
leoleo22005
leoleo22004
