[ ROM ] E-Ceros Revolution Android 4.4.2 KitKat custom root firmware (2014/04/28)
Zedster
31
2014/10/03 - 23:13
I have tried both the 4.4.2 ROM Kasty and Oma. They both give a huge performance upgrade but they also both crash constantly. Can someone point me to a 4.2.2 ROM for this tablet please.
TIA
-Zed
Lordlucan
Forum Posts: 17
32
2014/10/03 - 23:19
http://download.chinavasion.com/Others
You need all the files for the 9470.
I must admit I have also gone back to the 4.2.
DarthJabba
Forum Posts: 551
Thanks Received: 396
33
2014/10/03 - 23:24
TIA
-Zed
I've been using 4.4.2 for a while now, and it is relatively stable. What apps are you running? The only one that seems to crash my tablet (after prolonged use) is a particular PDF reader program - and even that is a new development, and so I'm wondering whether an app update somewhere is not the real cause.
Lordlucan
Forum Posts: 17
34
2014/10/03 - 23:34
I changed back for several minor things that where happening. Could only view a video once on a number of sites.Try to re-start it always gave me an error. The stock email app would crash it as well. Changed to K@Mail and although not as often, it would still need to be forced closed to many times. Other than that it seemed to be OK. I cannot say I notice any difference in speed or functions overall. I will try another version of 4.4, if I can find one, and let you know.
Zedster
35
2014/10/03 - 23:37
I am after a rooted ROM not the factory.  Is there no such animal?
@DarthJabba I replied in the other thread.
Lordlucan
Forum Posts: 17
36
2014/10/03 - 23:44
Not that I know of.
Zedster
37
2014/10/04 - 00:00
I seem to only see KitKat ROMs for the 9740 there atm?
Lordlucan
Forum Posts: 17
38
2014/10/04 - 00:22
Try this from another post, this is rooted. The driver can be found by googling. Good luck with it.
http://www.freaktab.com/showthread.php?9842-Would-Like-help-to-ROOT-my-Tablet#15
raulgsxr10
39
2014/10/07 - 15:18
Hello! I have a problem with my tablet eceros revolution. I was modifying the developer settings and the tablet goes reset. Now when i turn it on the only thing that it does is appear and dissapear constantly the eceros logos and the tablet couldn't start android. I need to know how to do a hard reset. I tried several combination of buttons but i couldn't achieve it. Can you help me? Remember that this tablet doesn't have vokume buttons.i tried with reset and power at the same time  great thanks!!
DarthJabba
Forum Posts: 551
40
2014/10/07 - 20:06
Press Volume+ and power, and make sure that the tablet is connected to the PC with a USB cable. If it is not connected via USB, it will not enter recovery mode.
raulgsxr10
41
2014/10/07 - 20:26
This tablet does not have volume buttons
Lordlucan
Forum Posts: 17
42
2014/10/07 - 21:02
Very easy to follow but with a few slight differences. Switch off any anti virus on your PC. Open up the batch tool first. When you connect  tablet to your PC press and HOLD the button below the on/off as you push the usb home. If the box on the batch tool does not turn green then you need to install the driver that came with the rom. Go into control panel on your PC and find DEVICE MANAGER and change to the new driver by selecting the folder it is stored in. Once the batch tool turns green follow the instructions. Thee first reboot takes some time. Goog luck.
raulgsxr10
43
2014/10/07 - 23:05
Great thanks for your help but i am a bit dummy. Is there any video to see the steps to follow?
Lordlucan
Forum Posts: 17
DarthJabba
Forum Posts: 551
45
2014/10/08 - 15:34
There are two buttons. Press both of them.
cloneme
Currently Online: paul4422
112 Guest(s)
Devices in use: Desktop (102), Phone (11)
paul4422
Gereon2
leysdelacruz712
androiidtweeker
maxkra
leoleo22005
