Oma has just released a custom Android 4.4 KitKat firmware for the CEROS Revolution (CT9716), you may want to give it a try and give feedback in the following thread:
Custom firmwares from Oma and Crew RKTablets are known to be efficient, stable and well supported.
pargas If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
As for the different apps storage size, there should be no problem as Oma package should reformat the whole tablet and repartition it. To be safe, you may ask in Oma's topic just for double checking. Also, the "parameter" file can be rebuilt to have 7 GB again for apps if needed.
Oma and Crew RKTablets firmwares do make their own firmwares and usually provide better tuned firmwares than the ones we publish here (kasty ones) which are modifications of existing firmwares from the manufacturer. It may depends between one device and another, but as I mentioned, Oma firmwares are efficient, stable and well supported. Doesn't hurt to try and post feedback !
2014/05/28
Lordlucan said
Very easy to follow but with a few slight differences. Switch off any anti virus on your PC. Open up the batch tool first. When you connect  tablet to your PC press and HOLD the button below the on/off as you push the usb home. If the box on the batch tool does not turn green then you need to install the driver that came with the rom. Go into control panel on your PC and find DEVICE MANAGER and change to the new driver by selecting the folder it is stored in. Once the batch tool turns green follow the instructions. Thee first reboot takes some time. I am online for a while if I can help.
I tried many time but cannot get the green button (connected device). I tried to connect to tablet pressing the reset or the back button (between on/off and reset), or both together. I installed the correct drivers from the driver folder.
So could you please detail a bit more? If I get it right, when the tablet is on, I push the "back" button and plug the USB at the same time and wait until the green appears. Am I right ?
Is there a specific parameter to use in the SUB to computer connexion ?
Thanks for your help...
2013/04/23
This app will do it for you: http://www.freaktab.com/showthread.php?1050-Reboot-App
(as will ArcTools).
2013/04/23
Yes, it requires a rooted ROM. Well. you're stuck with the buttons then. The device must be connected to the PC via USB when you press both buttons. The flash tool must be running as well. Hold the two buttons down for about 3 to 5 seconds, then release the power button. The flash tool should detect the device then. If it doesn't, then you might need to use the reset hole (pin inside to reset the tablet) while also holding down both buttons, with the USB cable connected, etc.
2013/04/23
I wouldn't worry too much about Antutu score - much depends on the state of the cached data at the time of the test - and if you look closely, you will find that it is the SD card I/O scores that often make the difference. Of course having an overclocked kernel helps - but this device (or, at least, mine) doesn't overclock very well - the best I've got out of it is 1680mhz for the CPU. The Cube U30GT2 on the other hand overclocks extremely well (1800mhz cpu).
Currently Online: avv2011
84 Guest(s)
Devices in use: Desktop (72), Phone (12), Tablet (1)
avv2011
leadpan101
jumbo65
kalkpits
m12k
StatusQ
