Rom Aldi Medion LIFETAB E10320
Problems of recovery with tablet medion LIFETAB E10320
Mizi4
France
Forum Posts: 13
2016/02/04 - 19:19
Hello all,
Few months ago;
I rooted my tablet « Medion LIFETAB E10320 » for enable bluetooth controller PS3 on game (Emulator PS1) and for install a rom android on my tablet, later. Some days later, i turn on my tablet and it starts loop on the recovery menu. But it is the original 'recovery' menu (3e) !
I have not had time to install the new recovery menu, so i can not install the custom rom android 4.2 (OMA).  Or ROM OMNI 4.4.4-20140817-rk31board-HOMEMADE ... In Windows 7, Windows 8.1, Windows 10: This prevents me from maintaining the detection driver with RkAndroidTool.
Topic Oma7144 here > Oma custom rom android 4.2.2 for Aldi tab Medion E10320.
My question is: Someone can provide me the original rom so that I can make the restoration with SD-card and subsequently install the custom ROM, please ?
Cordially...
2016/02/07 - 06:31
Win10 and Win8.1 are not friends of the unsigned RK drivers. Best is to use a native Win7.
Here is a driver assistant: http://crewrktablets.arctablet.com/?wpfb_dl=2766
Mizi4
France
Forum Posts: 13
2016/02/07 - 07:29
Hello Oma, thank you for your answer.
About  « Driver assistant » he's installed on Windows 8.1 - 10 & windows 7.
I also used a computer running windows 7 for manipulation before creating this topic, the results were not very good (Perhaps this is due to another problem because the computer was not mine).
I try to do the manipulation after recreating a Windows 7 environment in the day, i would say if it worked for to the tablet.
If that does not work, again... [I am disappointed because the cables are working perfectly].
Otherwise, i'll need the rom original android 4.2.2 tablet medion E10320 and i can't find this rom.
Mizi4
France
Forum Posts: 13
2016/02/07 - 19:31
Hello, Oma !
Thank you for your help.
I reinstall windows 7 x64 with full iso purely microsoft. That didn't stop the tablet detecting problems from rk driver on windows 7.
But that was more stable than the other pc windows 7 or about windows 8.1, windows 10.
The installation failed with the system checked for installation but by restarting the installation without ticked. I was able to install other parameters. Names: 'loader, parameter, misc, kernel, boot, recovery (your recovery_CWM).
Your recovery menu shows him upside down ! but he doesn't me bother for now.
I'm going to install a new android rom now, thank you again for your help.
Mizi4
France
Forum Posts: 13
2016/02/19 - 16:19
Hello Oma7144 !
sorry the number of posts as a result ...
I come confirm installation of roms custom on medion Lifetab E10320.
List of roms:
1) - Your rom: Oma_RK31_Medion_E10320_JB_4.2.2_v1.0 .
Without any problems ! ( you know his link of page)
Just make settings and deactivate the apps don't serve users, eventually.
2) - Odys Iron OmniRom edition : IRON by CrewRKTablets OmniROM 4.4.4 v1.4.1. (this rom i wanted to install when I created this topic)
No particular problems and perhaps necessary: CrewRKTablets_RKxx_160dpi Or / and CrewRKTablets KK Omni V1.4.1 Model Fix Medion E10320 . Just make settings and deactivate the apps don't serve users, eventually.
APPs: working perfectly (games and others)
3) - Odys Iron CM11 : Odys IRON – CM11 Edition .
No particular problems. Perhaps necessary: CrewRKTablets_RKxx_160dpi and CrewRKTablets KK CM11 V1.2 Model Fix Medion E10320.
4)
- RK3188 Lollipop has landed on Odys Iron : http://crewrktablets.arctablet.com/?p=4316.
Problem: The tablet maybe crashes in power off (the exact reasons is unknown). « but it she can function a little carefree without particular problems » .
Fix: CrewRKTablets_RKxx_160dpi .
5) - IRON by CrewRKTablet CM12 LP 5.0.2 V1.0 : CM12 has landed on Odys Iron.
Problem
: the tab is turned off only once it starts and it displays the selection of the starting languages. (settings tab, name account etc..) with fix 160dpi or without fix 160dpi and others fix.
6) - RK3188 CM12.1 has landed on chuwi v88 : http://crewrktablets.arctablet.com/?p=5668
Problem: At system startup, the tablet eventually reboot after few minutes and can still reboot again after logo on boot !
fix to solve the problem: unknown.
7) - RK3188 CM12.1 has landed on Odys Iron : http://crewrktablets.arctablet.com/?p=5617.
Problem: to install the tab boot but crashes on « SYSTEM-UI wurde beendet ». but is working after a moment the system-ui start correctly. Must insist...
Fix necessary maybe: CrewRKTablets_RKxx_160dpi.
Problem²: If you activate the WiFi, the tablet will turn off, directly.
And the tab reboot again and again after logo on boot. because wifi is actived.
I have not tested the bluetooth I'm afraid it's like wifi if activated .
A fix would be needed to avoid this.
 APPs: working perfectly (games and others). video included on VLC  (.avi tested).
_______
My custom rom on Medion E10320 is RK3188 CM12.1 has landed on Odys Iron.
Look at the pictures for evidence (only Android ROM CM12.1 has landed on Odys Iron, sorry)
[Descending order]
Screenshot_2016-02-19-15-48-44.pngImage EnlargerScreenshot_2016-02-19-15-44-08.pngImage EnlargerScreenshot_2016-02-19-15-43-54.pngImage EnlargerScreenshot_2016-02-19-11-17-23-copie.pngImage EnlargerScreenshot_2016-02-19-11-27-44.pngImage EnlargerScreenshot_2016-02-19-11-15-53.pngImage EnlargerScreenshot_2016-02-19-11-14-54.pngImage EnlargerScreenshot_2016-02-19-11-14-41.pngImage Enlarger02-18-14-Fichiers-Utilises-Pour-Medion-E10320.pngImage Enlarger
The following users say thank you to Mizi4 for this useful post:
2016/02/19 - 19:03
Thank you for testing!
The 160 dpi fix is absolutely necessary otherwise the Iron builds (high resolution) will crash.
Open a terminal and type:
cat /sys/class/rkwifi/chip
Post the result.
Mizi4
France
Forum Posts: 13
2016/02/19 - 20:11
I don't have a terminal on my tablet actually, ( my ROM is RK3188 CM12.1 has landed on Odys Iron)
After the first boot, i don't have a terminal.
The installations of apps (.apk) from my pc windows 7 . ADB by USB is good.
The 160dpx is installed by CWM_recovery, since installation with RkAndroidTool
before first boot.
The pictures (screenshots) shows that everything passes except at the wifi .. (and bluetooth maybe)
On picture on Windows, you see the files i used in finality .. (the CWM_Recovery is just one supplied in your rom)
I activate terminal via 'options pour les developpeurs ' (settings for developpers)
I type the commands: - u0_a55@rk31board:/ $ cat /sys/class/rkwifi/chip
(just the command you say me).
the only answer is: - Rk901u0_a55@rk31board:/ $
See on picture below..
Screenshot_2016-02-19-20-00-27.pngImage Enlarger
2016/02/19 - 20:40
Ok, RK901 wifi. Pls install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2820
Mizi4
France
Forum Posts: 13
2016/02/19 - 21:05
It has not solved the problem
because
the tablet will turn off, directly, When WiFi enable again...
I reinstall the rom, now and after first boot : « I would try enable the bluetooth » and i would say if it works.
Mizi4
France
Forum Posts: 13
2016/02/19 - 22:23
Same problem, this WiFi 'driver' not working, too.
About bluetooth, there is no crash/reboot of tablet.
but, i  «click » on button for enable.. [activation message] then he's turn off, directly.
I check the camera and she works well.
For the time being:
- We must activate the wifi and use it ( without crash' )
- Enable bluetooth and use it
- To use the screen rotation (she remain in reverse landscape or other after app used
(reverse landscape from logo on boot and after too)
2016/02/20 - 08:56
Hard to understand what you trying to say.
Download again and test: http://crewrktablets.arctablet.com/?wpfb_dl=2820
Mizi4
France
Forum Posts: 13
2016/02/20 - 14:04
Hello oma,
Hard for me too.. I do not speak English (usually)
About your link: the driver It does not work when installed
The tablet reboot again.
Result: factory reset
The WiFi is really a problem here :-/
If Bluetooth is not working, no soucy .
Only the wifi is actually necessary for use correctly the tablet
Thank for your help and you made a great job =)
2016/02/20 - 15:38
The RK901 chip is one of the oldest we know on a rk30board. Unfortunately I do not have a suitable kernel module which do not crash in the LP builds. So, you may stay with the CM11 build. Sorry.
Mizi4
France
Forum Posts: 13
2016/02/25 - 21:34
Hello Oma !
To correct some of my words; I remade the list of Rom custom tested whose facilities are confirmed, on medion lifetab E10320 :
1) Your custom rom: Oma_RK31_Medion_E10320_JB_4.2.2_v1.0 .
2) Odys Iron OmniRom edition : IRON by CrewRKTablets OmniROM 4.4.4 v1.4.1.
3) Odys Iron CM11 : Odys IRON – CM11 Edition .
Working perfectly ! (with 160 dpi fix For Odys Edition)
5) RK3188 CM12.1 has landed on Chuwi v88 : http://crewrktablets.arctablet.com/?p=5668.
6) RK3188 CM12.1 has landed on Odys Iron : http://crewrktablets.arctablet.com/?p=5617.
With 160 dpi fix.
Not working:
¹) Bluetooth
²) *Wi-Fi ( *If activated, the tablet reboot always )
Currently on Medion Lifetab E10320:
4) RK3188 Lollipop has landed on Odys Iron : http://crewrktablets.arctablet.com/?p=4316, Alpha build v1.2 .
With 160 dpi fix.
- Wifi alive !
Not working:
¹) cam
²) Bluetooth
³) Sound
The sound is 'installed' but I don't hear nothing to the speaker and headphones..
( Vlc, youtube app, web navigator etc... )
Please, do you have a fix for bluetooth and Sound ?
Screenshot_2016-02-25-20-39-04.pngImage Enlarger
61 Guest(s)
Devices in use: Desktop (54), Phone (7)
alsoft75
Deaker
Gorael
WhiteD2125
Bokser
hamishduke
