[ ROM ] Ployer MOMO7 RK3066 901 16G rooted Android 4.1 firmware (from release 2012/12/13)
LA-DC5
2012/12/23 - 13:59
poczesaniec1 said
and what about charging time, has this changed?
No.
charging 4-5% in hour :(
And problem with touchscreen. Him go to the sleep (through 2-3s).
First touch - unsleep and go to work status.
Mate,
Try using the default (supplied) charger.
Output should be 5V @ 2,000mAh.
Most other micro-usb chargers run 5v @ 500 or 600 mAh only.
gino66
Thanks Received: 5
2012/12/25 - 03:08
Hi, thank you for your work. I load this firmware, but can not install it with windows 8!. If someone can give me managed approach to follow. Because I can not go from pink to green with RKBatchtool v1.5 ......
Thank you in advance
Thanks Received: 264
pampamtwo
2012/12/25 - 13:39
Mate,
I used  the default (supplied) charger. Output - 5V @ 2,000mAh.
gino66
Thanks Received: 5
2012/12/26 - 04:24
hello, does anyone could make a tutorial to install this new firmware with win 7 or win 8 (as you will). the tutorial from ployer.cn is not good...
Because I can not go to the green color of RKbatchtool, it is still in gray or pink, never green.
In the meantime I even managed to rooter when the tablet, remove aplications Chinese ...
But I think it's better to install your firmware with 2gb for aps ....
Perhaps i can install your custom firmware with my sd card, but i don't know the good way .
2012/12/26 - 05:03
You can get in the downloading mode, by using adb
adb reboot bootloader
then start up the rockchip tools, if the colour is green, you are good to go with the flashing.
gino66
Thanks Received: 5
2012/12/26 - 18:13
HI,  same for me
  1. The original performance after unboxing is great but now lag on only first time pressing button or tap on the screen after sometimes (something like after idle). E.g. Turn on screen from sleep takes about 6 sec and when start typing on keyboard, the first character is missed, wait a few seconds and start typing again also missed the first character. Any first swipe also the same (Something like cold start).
  2. The back camera can't be use, in the camera, the icon to switch camera back/front is missing. Other app like bar code scanner also using front camera automatically.
But i don't try the original ployer firmware from 131212 so i don't know if it's the same issues with camera back...perhaps problem come from your custom but not sure.
So for me your firmware from 031212 is better at this time.
Thank you for your job.
And if you had problem with driver for rkbatctool with win7 64 , try the AMD64- win7 driver ! ! and not the x86-win7 ! !
pampamtwo
2012/12/27 - 18:12
New original firmware MOMO7(IPS)4.1.1 20121225
LA-DC5
2012/12/28 - 07:14
Hi Guys,
New firmware released by Ployer for the Momo7 IPS.
http://pan.baidu.com/share/link?shareid=158828&uk=791224118
Among others, Ployer claims the latest firmware:
1) Solves the back camera issue
2) Shrunk the status bar buttons for vertical mode
3) Auto connect to PC.
Can we expect a new rooted version anytime soon? :)
MrWGT
2012/12/28 - 12:42
There's a new firmware available:
According to (http://translate.google.com/translate?hl=de&sl=zh-CN&tl=en&u=http%3A%2F%2Fdownload.ployer.cn%2Fdowndetail.asp%3Fid%3D758) the changes are:
1 change the charging icon displayed by the upper display, the the charging icon images replace
2 The firmware compatible the the ov2659 gc2035 sp2518 camera, replace the camera need to restart the machine will only be effective
Duplication of the status bar the return key, volume keys icon scaled down in order to avoid the vertical screen icon
Gravity apk removed, and replaced on the auxiliary function items, as follows:
Open settings ----> Accessibility -----> gravity calibration
5. Increase automatically even disk function, plug in the usb connection as soon as the computer automatically
A rooted firmware based on this would be fine :)
Thanks in advance
20121228-12:58MET: Downloaded and flashed it. Camera front/back switch is working again - but chinese as standard language is annoying. ;)
Thanks Received: 3171
2012/12/28 - 21:13
I should have a rooted/cleaned custom firmware available in a few days.
gino66
Thanks Received: 5
2012/12/29 - 00:11
Last firmware official from ployer.cn release : 20121225
I look forward to your next custom firmware and hope you made increased space for application (/data partition) to 3 GB, because 2Gb is too small for me lol...Laugh
Thank you for your work.
2012/12/29 - 19:27
cosmo
2012/12/30 - 05:59
Rooted firmware updated from 2012/12/25 release
tried this and all looks goodLaugh
ws848
2013/03/16 - 02:17
I'm using unlockroot.com * Click on Image, than UnlockRoot Pro, than Free Download. Turn USB-Debbuging in your device on (Settings, Developer options). Connect your device. Start Unlockroot and click on the green button Root. That's all and works on ALL Android 4.0 and 4.1 devices!
95 Guest(s)
Devices in use: Desktop (80), Phone (15)
heftpflaster
rk.13
