Intracon FX2 Pad ???
Jaschi
Forum Posts: 23
2013/08/23 - 15:46
Hi, I'm new here and do not know if I'm right.
My problem is this:
Have a Intracon FX2 Pad 7-inch tablet and am looking for a CWM
Recovery with instructions. Perhaps a custom Rom.
Does anyone know with what is perhaps the tablet Intracon FX2 pad identical?
Model: Full AOSP on RK 29sdk
Version: 4.1.1
Kernel: 3.0.8
Processor: Rockchip Cortex ™-A8 - RK2918
Memory: 4 GB Flash iNand
512MB RAM
microSD slot (up to 32GB)
more info
http://www.intracon.eu/pad7
For help from you, I would be very grateful.
Sorry for my bad english.
greeting
Jaschi
2013/08/23 - 20:19
Build with CWM is here: http://forum.xda-developers.com/showthread.php?t=1903745
Kernel is here: http://crewrktablets.arctablet.com/?wpfb_dl=889
Just replace your kernel in folder rockdev/Image.
Jaschi
Forum Posts: 23
2013/08/23 - 20:32
Thanks for the quick help.
Maybe you could tell me how the whole install.
Tablet is rooted but without cwm.
I hope you understand my bad English, in German it would be easier for me, but it works already.
Greetings
Jaschi
Jaschi
Forum Posts: 23
2013/08/23 - 20:53
Thank you.
I had been trying to reach you at androidhilfe but had no luck.
That would have been easier for me.
'll take time to work through there, and then I try the times.
Please excuse my bad english.
Thanks again for the help
Jaschi
2013/08/23 - 20:55
If you need further support you can post here: http://www.arctablet.com/blog/forum/crewrktablets-forum/
Jaschi
Forum Posts: 23
2013/08/23 - 21:58
Could you help me again?
What Modellfix I can use because, since the orientation is wrong
Jaschi
Forum Posts: 23
2013/08/23 - 22:19
the link does not work.
cwm can not be operated.
2013/08/24 - 10:22
Files will move to a new server today. Try again in the afternoon.
SD card must be in the tab before booting into CWM.
49 Guest(s)
Devices in use: Desktop (39), Phone (10)
hellander
elousstad
relaytester
revoltown
tdomnic024
