2015/09/10
Could need some help with my device.
I am the proud owner of a medion lifetab e7332 🙂
Was trying to flash CrewRKTablets_Odys_Iron_LP_5.0_v1.2 on it.
Which is probably a dumb thing to do, so things went wrong
and the device will not boot, blackscreen, my bad.
I did make a backup with cwm based recovery, so i thought that
somehow i would get it up and running again, but i can't.
I have no stockrom or any other kind of backup from this device.
I can go in cwm based recovery v6.0.3.1 by oma, but with errors.
and if i try to restore the backup it gives a error while restoring the system.
It does mount the external sdcard.
I get errors like these::.
can't mount backup path
can't mount sdcard
W:failed to mount /dev/block/mtd/by-name/cache (No such file or directory)
E:Can't mount /cache/recovery/log
E:Can't open /cache/recovery/log
E:Can't mount /cache/recovery/last_log
E:Can't open /cache/recovery/last_log
W:Can't unlink /cache/recovery/command
I:can't format unknown volume: /emmc
for flashing 1 seem to need at least 7 things and i can only find
a few of them in the cwm backup i make.
I do not have the original loader.bin file, no parameter file, no misc.img and no system.img.
I think that i have a problem with the nand.. but i do not really understand what this is.
It seems some kind of way of how my device uses the flash memory?
Now original ik had 16 gb of flash and a 3.0.36+ kernel and maybe me trying to flash made some kind of change in this?
Can i undo this?
Is there another way to solve my problem?
any other thoughts on the problems i face?
I don mind reading and trying.. and i did.. but am a bit stuck on this one.
thank you for your time.
2015/09/10
i put this rom on my device: Oma_RK31_Chuwi_V17HD_KK_4.4.2_v3.5_gen2 loader.7z with rkflashtool
made some change in the parameter file to size@offset
flashed the rom again
let the recovery from the rom do the formatting
flashed the cwm from the rom
and now i was able to restore the cwm backup.
so am good..back on kitkat 4.4.4 and going too change it again 🙂
found out that lots of the: Oma_RK31_XXXX stuff that you can find here on the forum
will work in someway on this device.
also lollipop 5 rom did work on some jb kernel but with ui and bluetooth crash.
cheers
Fine. Can you pls provide the e7332 kernel for the archive?
The Iron builds are for high resolution tabs. To make it run on a 7" device one need to install the 160dpi fix.
You can also try this build: http://crewrktablets.arctablet.com/?p=5577
2015/09/10
thanks for the reply, will upload the kernel, try fix and rom.
CM12 says again no se linux kernel(i do not understand this.. i need reading). I think my device has got a se linux kernel.
Kit kat 4.4.4 is able of changing the way ART works.. so i do not understand why i have to use a jb kernel.. Then all i get is a lollipop feeling?
Not that is really matters.. just wanna play and learn.
best regards
Ok, that's your problem. Tab has gen2 loader and a selinux kernel. Flashing gen1 loader stuff into it will end up into nowhere or a bricked tab.
For the moment we can try to find a suitable KK custom build. Can I have a dmesg log to see the hardware?
2015/09/10
I did have two problems.
First one was that i did not find any good rom.
for my device whitout me being able to compile a kernel myself
or to make some kind of hardware patch. I thougt i wanna learn
that and in the meantime i will put back the backup.
So i tried to get back in time and reinstall kitkat 4.4.4
from the CWM backup that i make.
But it gives me errors.. The errors disapear when i edit the size and offset in the parameter file.
But still when i start my device the first time .. I loose my user settings.
This is not a big thing.. but somethings did not backup or restore quit right because cwm should bring me back exactly where i left it.
I am wondering what this is .. and how i could change this.
So i was thinking that maybe i need the original parameter settings.. But then again i have no parameter file.
So maybe i get this info from somewhere else. And i think i read on the net that /dev/block/dw_mmc/by-name
should be the place to get this. But i cant find this info nowhere in the backup.
Or do i have to learn to get the recovery.fstab from the boot.img and i find my answer there?
or Is this problem related to the bootloader.bin file, or bootloader version? so maybe when i use the exact version of the bootloader file
the backup wil restore the way it was intended?
-----------thank you for your time------------
This build should work for you as a basis: http://crewrktablets.arctablet.com/?p=3175
Just change the kernel before flash: http://crewrktablets.arctablet.com/?wpfb_dl=2657
In CWM you can restore your firmware.
2016/05/17
I have a tablet MEDION E7316 installed ROM http://crewrktablets.arctablet.com/?p=3175.
I have uploaded kernel http://crewrktablets.arctablet.com/?wpfb_dl=2657
It does not work wi-fi and Bluetooth
In Attachments I only recovery.img the old ROM E7316.
Is impossible to somehow adapt the kernel?
chipset wi-fi AP6210
OK I Found http://crewrktablets.arctablet.com/?p=5617
Kernel E7316 already in the archive: joerg #37 preempt 10 Jan 2014
Kernel E7316 from the uploaded recovery.img: christian #11 preempt 9 Jan 2015
48 Guest(s)
Devices in use: Desktop (45), Phone (3)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
