2014/04/12
Hello, im back again with another problem.. My O+ 9.76 pad again..
I tried flashing this LINK following the instructions included.. (it says it works on stock 3.0.38+ kernel so I tried it). After applying the patch format_nand_fix and rebooted, it still loops back to cwm recovery no matter what I do.. (I considered this a fail)
I hard shutted it down and tried flashing a 4.4.2 rom LINK HERE I found on a post HERE.. It faiiled just after I flashed it, (device started and just a blank black screen appears) so I considered it a fail too..
Then I started to return to its working rom Starway Andromeda S910 rom.. (if u remember me sir oma) from my past thread HERE..
The problem is when it started downloading the firmware(I was using the RKBatchtool), it finished 100% but turned red and says it failed to download.. (see attachment photo)
I tried using rkandroidtool but it also fails whatever I try to flash (either recovery.img/kernel.img,etc)
I badly needed help for this..
2014/04/12
update..
I found a solution, HERE..
It requires opening the back of the tab and shorting the nand chip..
is there any other way for me to fix this without opening my tablet?
Hm, you flashed a lot into your tab. Strange kernel, strange loader and as far as I can see one of the above builds was for a MTK architecture ...
To recover the tab you need to boot it into mask-rom mode. Should be similar as shown here:
darknight21Per aspera ad astra, we rock the Tablets !
No.
Great to hear you could managed it.
107 Guest(s)
Devices in use: Desktop (88), Phone (19)
hans41
rickybk
soniya07
ironmangitar
