Help rooting nextbook NX010QD8G
noyp
Forum Posts: 22
2016/09/03 - 11:04
C:\Users\Cedric\adb>adb shell
shell@android:/ $ cat /proc/partitions
major minor  #blocks  name
 179        0    3872256 mmcblk0
 179        1    3871232 mmcblk0p1
  31        0       4096 mtdblock0
  31        1       8192 mtdblock1
  31        2      16384 mtdblock2
  31        3      32768 mtdblock3
  31        4      65536 mtdblock4
  31        5     131072 mtdblock5
  31        6    1048576 mtdblock6
  31        7       4096 mtdblock7
  31        8     524288 mtdblock8
  31        9    5914624 mtdblock9
shell@android:/ $
see attached images of tablet
http://i68.tinypic.com/2qjzvvl.jpgImage Enlarger
http://i64.tinypic.com/2r3up01.jpgImage Enlarger
http://i64.tinypic.com/4sikjb.jpgImage Enlarger
http://i68.tinypic.com/243n90m.jpgImage Enlarger
2016/09/03 - 12:06
Try this:
dd if=/dev/mtd/mtdblock1 of=/mnt/sdcard/kernel.img bs=4096
dd if=/dev/mtd/mtdblock2 of=/mnt/sdcard/boot.img bs=4096
dd if=/dev/mtd/mtdblock3 of=/mnt/sdcard/recovery.img bs=4096
dd if=/dev/mtd/mtdblock8 of=/mnt/sdcard/system.img bs=4096
noyp
Forum Posts: 22
2016/09/03 - 12:35
Try this:
shell@android:/ $ dd if=/dev/mtd/mtdblock1 of=/mnt/sdcard/kernel.img bs=4096
/dev/mtd/mtdblock1: cannot open for read: No such file or directory
1|shell@android:/ $ dd if=/dev/mtd/mtdblock2 of=/mnt/sdcard/boot.img bs=4096
/dev/mtd/mtdblock2: cannot open for read: No such file or directory
it is located in /dev/block
shell@android:/ $ ls -al /dev/block
brw------- root     root       7,   0 2016-09-03 02:05 loop0
brw------- root     root       7,   1 2016-09-03 02:05 loop1
brw------- root     root       7,   2 2016-09-03 02:05 loop2
brw------- root     root       7,   3 2016-09-03 02:05 loop3
brw------- root     root       7,   4 2016-09-03 02:05 loop4
brw------- root     root       7,   5 2016-09-03 02:05 loop5
brw------- root     root       7,   6 2016-09-03 02:05 loop6
brw------- root     root       7,   7 2016-09-03 02:05 loop7
brw------- root     root     179,   0 2016-09-03 02:05 mmcblk0
brw------- root     root     179,   1 2016-09-03 02:05 mmcblk0p1
drwxr-xr-x root     root              2016-09-03 02:05 mtd
brw------- root     root      31,   0 2016-09-03 02:05 mtdblock0
brw------- root     root      31,   1 2016-09-03 02:05 mtdblock1
brw------- root     root      31,   2 2016-09-03 02:05 mtdblock2
brw------- root     root      31,   3 2016-09-03 02:05 mtdblock3
brw------- root     root      31,   4 2016-09-03 02:05 mtdblock4
brw------- root     root      31,   5 2016-09-03 02:05 mtdblock5
brw------- root     root      31,   6 2016-09-03 02:05 mtdblock6
brw------- root     root      31,   7 2016-09-03 02:05 mtdblock7
brw------- root     root      31,   8 2016-09-03 02:05 mtdblock8
brw------- root     root      31,   9 2016-09-03 02:05 mtdblock9
drwxr-xr-x root     root              2016-09-03 02:05 platform
drwx------ root     root              2016-09-03 02:05 vold
1|shell@android:/ $ dd if=/dev/block/mtdblock1 of=/mnt/sdcard/kernel.img bs=4096
/dev/block/mtdblock1: cannot open for read: Permission denied
1|shell@android:/ $dd if=/dev/block/mtdblock2 of=/mnt/sdcard/boot.img bs=4096
/dev/block/mtdblock2: cannot open for read: Permission denied
were able to dump /system without root using "/data/local/tmp/busybox tar cvf sysdump.tar /system"
http://www.mediafire.com/download/gx0yaqq91qxv1jy/sysdump.tar
2016/09/03 - 13:24
Ok, it seems ADB shell runs commends unprivileged, which means ro.secure=1 is set in default.prop. This is very untypical for tabs.
So the only way is to flash a CWM into the tab. The tab is however very untipical for a rk30board, so I have no idea if a CWM will work or brick the tab. If you'd like we can try that later today.
noyp
Forum Posts: 22
2016/09/03 - 13:55
ok oma ill try flashing CWM, btw tab recovery has verification process that checks every update signature and mostly it failed to flash due to this.
this is what's inside default.prop
shell@android:/ $ cat default.prop
# ADDITIONAL_DEFAULT_PROPERTIES
rild.libpath1=/system/lib/libreference-ril-mt6229.so
rild.libpath2=/system/lib/libreference-ril-mu509.so
rild.libpath4=/system/lib/libreference-ril-mw100.so
rild.libpath6=/system/lib/libreference-ril-sc6610.so
rild.libpath7=/system/lib/libreference-ril-m51.so
rild.libpath8=/system/lib/libreference-ril-mt6250.so
rild.libpath9=/system/lib/libreference-ril-c66a.so
rild.libpath10=/system/lib/libreference-ril-sew290.so
rild.libpath11=/system/lib/libreference-ril-u5501.so
rild.libpath12=/system/lib/libreference-ril-u7501.so
rild.libpath14=/system/lib/libreference-ril-a85xx.so
rild1.libpath=/system/lib/libreference-ril-sc6610-1.so
rild3.libpath=/system/lib/libril-rk29-dataonly.so
ro.secure=1
ro.allow.mock.location=0
ro.debuggable=0
persist.sys.usb.config=none
2016/09/03 - 14:37
Re-read post #3 it shows 4 cores ... so should be rk31board. This tab?
noyp
Forum Posts: 22
2016/09/03 - 14:51
not so sure if it is rk30 or rk31.
shell@android:/ $ cat /proc/cpuinfo
Processor       : ARMv7 Processor rev 0 (v7l)
processor       : 0
BogoMIPS        : 623.79
processor       : 1
BogoMIPS        : 623.79
processor       : 2
BogoMIPS        : 623.79
processor       : 3
BogoMIPS        : 623.79
Features        : swp half thumb fastmult vfp edsp neon vfpv3
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x3
CPU part        : 0xc09
CPU revision    : 0
Hardware        : RK30board
Revision        : 0000
Serial          : 0000000000000000
shell@android:/mnt/external_sd $ getprop
[UserVolumeLabel]: [NX010QD8G]
[dalvik.vm.dexopt-flags]: [m=y]
[dalvik.vm.heapgrowthlimit]: [64m]
[dalvik.vm.heapmaxfree]: [8m]
[dalvik.vm.heapminfree]: [512k]
[dalvik.vm.heapsize]: [384m]
[dalvik.vm.heapstartsize]: [8m]
[dalvik.vm.heaptargetutilization]: [0.75]
[dalvik.vm.jniopts]: [warnonly]
[dalvik.vm.stack-trace-file]: [/data/anr/traces.txt]
[dev.bootcomplete]: [1]
[drm.service.enabled]: [false]
[gsm.current.phone-type]: [1]
[gsm.operator.alpha]: []
[gsm.operator.iso-country]: []
[gsm.operator.isroaming]: [false]
[gsm.operator.numeric]: []
[gsm.sim.state]: [NOT_READY]
[gsm.version.ril-impl]: [ril-rk29-dataonly v2.3.02]
[hw.hdmi.max_scale]: [96]
[hw.hdmi.min_scale]: [80]
[init.svc.adbd]: [running]
[init.svc.akmd]: [stopped]
[init.svc.bootanim]: [stopped]
[init.svc.console]: [running]
[init.svc.debuggerd]: [running]
[init.svc.drm]: [running]
[init.svc.drmservice]: [stopped]
[init.svc.flash_recovery]: [stopped]
[init.svc.installd]: [running]
[init.svc.keystore]: [running]
[init.svc.media]: [running]
[init.svc.netd]: [running]
[init.svc.ril-daemon3]: [stopped]
[init.svc.ril-daemon]: [running]
[init.svc.sdcard]: [stopped]
[init.svc.servicemanager]: [running]
[init.svc.surfaceflinger]: [running]
[init.svc.ueventd]: [running]
[init.svc.vold]: [running]
[init.svc.zygote]: [running]
[keyguard.no_require_sim]: [true]
[net.bt.name]: [Android]
[net.change]: [net.qtaguid_enabled]
[net.hostname]: [android-19f06cca50dd8a3b]
[net.qtaguid_enabled]: [1]
[net.tcp.buffersize.default]: [4096,87380,110208,4096,16384,110208]
[net.tcp.buffersize.edge]: [4093,26280,35040,4096,16384,35040]
[net.tcp.buffersize.evdo]: [4094,87380,262144,4096,16384,262144]
[net.tcp.buffersize.gprs]: [4092,8760,11680,4096,8760,11680]
[net.tcp.buffersize.hsdpa]: [4094,87380,262144,4096,16384,262144]
[net.tcp.buffersize.hspa]: [4094,87380,262144,4096,16384,262144]
[net.tcp.buffersize.hspap]: [4094,87380,1220608,4096,16384,1220608]
[net.tcp.buffersize.hsupa]: [4094,87380,262144,4096,16384,262144]
[net.tcp.buffersize.lte]: [524288,1048576,2097152,262144,524288,1048576]
[net.tcp.buffersize.umts]: [4094,87380,110208,4096,16384,110208]
[net.tcp.buffersize.wifi]: [524288,1048576,2097152,262144,524288,1048576]
[persist.facelock.detect_cutoff]: [5000]
[persist.facelock.recog_cutoff]: [5000]
[persist.service.bdroid.bdaddr]: [46:05:28:93:e9:73]
[persist.sys.country]: [US]
[persist.sys.language]: [en]
[persist.sys.localevar]: []
[persist.sys.profiler_ms]: [0]
[persist.sys.strictmode.visual]: [false]
[persist.sys.timezone]: [America/New_York]
[persist.sys.usb.config]: [mass_storage,adb]
[ril.function.dataonly]: [0]
[rild.libpath10]: [/system/lib/libreference-ril-sew290.so]
[rild.libpath11]: [/system/lib/libreference-ril-u5501.so]
[rild.libpath12]: [/system/lib/libreference-ril-u7501.so]
[rild.libpath14]: [/system/lib/libreference-ril-a85xx.so]
[rild.libpath1]: [/system/lib/libreference-ril-mt6229.so]
[rild.libpath2]: [/system/lib/libreference-ril-mu509.so]
[rild.libpath4]: [/system/lib/libreference-ril-mw100.so]
[rild.libpath6]: [/system/lib/libreference-ril-sc6610.so]
[rild.libpath7]: [/system/lib/libreference-ril-m51.so]
[rild.libpath8]: [/system/lib/libreference-ril-mt6250.so]
[rild.libpath9]: [/system/lib/libreference-ril-c66a.so]
[rild1.libpath]: [/system/lib/libreference-ril-sc6610-1.so]
[rild3.libpath]: [/system/lib/libril-rk29-dataonly.so]
[ro.allow.mock.location]: [0]
[ro.ap_data_only]: [0]
[ro.ap_has_alsa]: [0]
[ro.ap_has_earphone]: [0]
[ro.ap_mdm]: [0]
[ro.baseband]: [unknown]
[ro.board.platform]: [rk30xx]
[ro.boot.console]: [ttyFIQ0]
[ro.bootloader]: [unknown]
[ro.bootmode]: [unknown]
[ro.bt.bdaddr_path]: [/data/misc/bluetoothd/bt_addr]
[ro.build.characteristics]: [tablet]
[ro.build.date.utc]: [1378369169]
[ro.build.date]: [Thu Sep  5 16:19:29 CST 2013]
[ro.build.description]: [EBM1010FP-user 4.2.2 JDQ39 eng.root.20130905.161818 test-keys]
[ro.build.display.id]: [V1.0.5.JDQ39.eng.root.20130905.161818]
[ro.build.fingerprint]: [YIFANG/EBM1010FP/EBM1010FP:4.2.2/JDQ39/eng.root.20130905.161818:user/test-keys]
[ro.build.host]: [xn-desktop]
[ro.build.id]: [JDQ39]
[ro.build.product]: [EBM1010FP]
[ro.build.tags]: [test-keys]
[ro.build.type]: [user]
[ro.build.user]: [xn]
[ro.build.version.codename]: [REL]
[ro.build.version.incremental]: [eng.root.20130905.161818]
[ro.build.version.release]: [4.2.2]
[ro.build.version.sdk]: [17]
[ro.carrier]: [unknown]
[ro.com.android.dataroaming]: [false]
[ro.com.android.dateformat]: [MM-dd-yyyy]
[ro.config.alarm_alert]: [Alarm_Classic.ogg]
[ro.config.facelock]: [enable_facelock]
[ro.config.notification_sound]: [OnTheHunt.ogg]
[ro.config.ringtone]: [Ring_Synth_04.ogg]
[ro.debuggable]: [0]
[ro.default.size]: [100]
[ro.factory.midtest]: [YIFANG]
[ro.factory.storage_policy]: [0]
[ro.factory.tool]: [0]
[ro.factorytest]: [0]
[ro.hardware.version]: [1.0.0.0]
[ro.hardware]: [rk30board]
[ro.kernel.android.checkjni]: [0]
[ro.opengles.version]: [131072]
[ro.ota.version.id]: [V1.0.5]
[ro.product.board]: [rk30sdk]
[ro.product.brand]: [YIFANG]
[ro.product.cpu.abi2]: [armeabi]
[ro.product.cpu.abi]: [armeabi-v7a]
[ro.product.device]: [EBM1010FP]
[ro.product.locale.language]: [en]
[ro.product.locale.region]: [US]
[ro.product.manufacturer]: [YIFANG]
[ro.product.model]: [EBM1010FP]
[ro.product.name]: [EBM1010FP]
[ro.product.ota.host]: [www.rockchip.com:2300]
[ro.product.usbfactory]: [NX010QD8G]
[ro.product.version]: [1.0.0]
[ro.revision]: [0]
[ro.ril.ecclist]: [112,911]
[ro.rk.MassStorage]: [false]
[ro.rk.bt_enable]: [true]
[ro.rk.cpu]: [rk3188]
[ro.rk.def_brightness]: [128]
[ro.rk.homepage_base]: [http://www.nextbookusa.com/]
[ro.rk.install_non_market_apps]: [false]
[ro.rk.screenoff_time]: [60000]
[ro.rk.soc]: [rk3188]
[ro.rk.systembar.tabletUI]: [true]
[ro.rk.systembar.voiceicon]: [false]
[ro.rksdk.version]: [RK31_ANDROID4.2.2-SDK-v1.04.00]
[ro.runtime.firstboot]: [1472882743282]
[ro.secure]: [1]
[ro.serialno]: [OUGRYLR1S7]
[ro.sf.fakerotation]: [true]
[ro.sf.hwrotation]: [270]
[ro.sf.lcd_density]: [160]
[ro.sf.lcdc_composer]: [0]
[ro.sms.capable]: [false]
[ro.tether.denied]: [false]
[ro.vendor.name]: [YFMID]
[ro.voice.capable]: [false]
[ro.wifi.channels]: []
[ro.yifang.devicename]: [NX010QD8G]
[ro.yifang.ota.enable]: [0]
[ro.yifang.silence]: [1]
[ro.yifang.weather.city]: [New@York]
[ro.yifang.weather.isf]: [1]
[service.bootanim.exit]: [1]
[sf.power.control]: [2073600]
[sim.contacts.enable]: [false]
[sys.boot_completed]: [1]
[sys.display.oritation]: [0]
[sys.dump]: [false]
[sys.ggralloc.version]: [1.000]
[sys.ghwc.version]: [1.023]
[sys.ghwui.version]: [1.001]
[sys.glibui.version]: [1.000]
[sys.gmali.cores]: [2]
[sys.gmali.savedinstance]: [100]
[sys.gmali.version]: [4X_13_14]
[sys.grga.version]: [1.002]
[sys.gsflg.version]: [1.001]
[sys.hwc.compose_policy]: [6]
[sys.launcher.drawer]: [0]
[sys.rkadb.root]: [0]
[sys.settings_global_version]: [4]
[sys.underUmsMode.enable]: [false]
[sys.usb.config]: [mass_storage,adb]
[sys.usb.state]: [mass_storage,adb]
[sys.usb.umsavailible]: [true]
[sys.wallpaper.rgb565]: [0]
[sys.wfd.rotation]: [3]
[sys.yuv.rgb.format]: [1]
[sys_graphic.cam_driver.ver]: [0.3.9]
[sys_graphic.cam_hal.ver]: [0.4.19]
[system_init.startsurfaceflinger]: [0]
[testing.mediascanner.skiplist]: [/mnt/sdcard/Android/]
[wifi.interface]: [wlan0]
[wifi.supplicant_scan_interval]: [15]
noyp
Forum Posts: 22
2016/09/04 - 02:32
Pls check with this app: https://play.google.com/store/apps/details?id=com.arctablet.cpucheck&hl=de
http://i65.tinypic.com/es517s.pngImage Enlarger
2016/09/04 - 04:35
Ok, RK3188. Pls use this firmware pack: http://crewrktablets.arctablet.com/?p=3555
Just flash the recovery.img, which is a CWM. Untick everything other than recovery and misc. Click Run.
RKAndroidTool must show Loader Device (see video above). Typical key combination to start flash-modus is Power and Vol+ (all cable plugged).
Here is the latest Driver-Assistant: http://crewrktablets.arctablet.com/?wpfb_dl=2766
In CWM just install this SuperSU (later ones are for LP/MM): https://download.chainfire.eu/740/supersu/. Copy the zip on external sdcard before start.
noyp
Forum Posts: 22
2016/09/04 - 13:04
some improvement happened today i was able to switch the tablet into loader mode after reading this thread http://www.slatedroid.com/topic/95578-rockchip-flashing-does-not-work-with-win81/ it was just all usb issues in windows 10. run rkdumper and got 9 .img files (backup.img,boot.img,cache.img,kernel.img,kpanic.img,misc.img,recovery.img,system.img,userdata.img).
strange that rkandroidtool couldnt read in loader mode so unable to flash Odys recovery.img but rkdumper can
2016/09/04 - 14:11
Can you pls upload boot, kernel, recovery and the parameter file?
To start the tab in flashmodus pls see the video in post #21.
noyp
Forum Posts: 22
2016/09/04 - 14:26
i got green box RKBatchTool v1.6
http://www.mediafire.com/download/gy004rrv53324sd/kernel.img
http://www.mediafire.com/download/zfv1gv917cmgdr6/boot.img
http://www.mediafire.com/download/twvfkgeegb3568s/parameter
http://www.mediafire.com/download/c1xw0dt27siy451/recovery.img
2016/09/04 - 14:43
Ok, looks good. Kernel.img is empty. Kernel is included in boot.img and recovery.img.
So, if you flash CWM you need also to flash the kernel. Just copy in floder rockdev/Image and tick also kernel.
RKAndroidTool should also see a loader device when you start the flash-modus using rkDumper.
noyp
Forum Posts: 22
2016/09/04 - 15:41
should i run  Odys recovery.img plus this attached kernel.img ?
60 Guest(s)
Devices in use: Desktop (49), Phone (11)
alsoft75
Deaker
Gorael
WhiteD2125
Bokser
hamishduke
