Help rooting nextbook NX010QD8G
noyp
Forum Posts: 22
2016/08/31 - 10:18
hi guys,
 i got this tablet nextbook NX010QD8G and according to kingoroot and impactor is a yifang ebm1010fp device when connected to usb. my problem is i cant seem to root this device using every well know rooting apps including pc base application all resulted in failure. im running out of option.
 i found the specs of this device here: http://specdevice.com/showspec.php?id=0c76-ab4b-0033-c58700000000
regards,
noyp
noyp
Forum Posts: 22
2016/09/01 - 09:17
thanks oma, still it failed to root have no idea why it's so hard to root this "sob" device
see attached images
http://i63.tinypic.com/14v1g86.png
http://i63.tinypic.com/xm3bd5.pngImage Enlarger
was able to get adb shell
shell@android:/data/local/tmp $ cat /proc/cpuinfo
cat /proc/cpuinfo
Processor       : ARMv7 Processor rev 0 (v7l)
processor       : 0
BogoMIPS        : 623.79
processor       : 1
BogoMIPS        : 623.79
processor       : 2
BogoMIPS        : 623.79
processor       : 3
BogoMIPS        : 623.79
Features        : swp half thumb fastmult vfp edsp neon vfpv3
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x3
CPU part        : 0xc09
CPU revision    : 0
Hardware        : RK30board
Revision        : 0000
Serial          : 0000000000000000
127|shell@android:/data/local/tmp $ cat /proc/mtd
cat /proc/mtd
dev:    size   erasesize  name
mtd0: 00400000 00004000 "misc"
mtd1: 00800000 00004000 "kernel"
mtd2: 01000000 00004000 "boot"
mtd3: 02000000 00004000 "recovery"
mtd4: 04000000 00004000 "backup"
mtd5: 08000000 00004000 "cache"
mtd6: 40000000 00004000 "userdata"
mtd7: 00400000 00004000 "kpanic"
mtd8: 20000000 00004000 "system"
mtd9: 169000000 00004000 "user"
noyp
Forum Posts: 22
2016/09/01 - 10:06
dmesg
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.0.36+ (llshan@yf-driver) (gcc version 4.4.3 (GCC) ) #6 SMP PREEMPT Sat Sep 14 21:58:31 CST 2013
[    0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: RK30board
[    0.000000] memory reserve: Memory(base:0x91800000 size:80M) reserved for
[    0.000000] memory reserve: Memory(base:0x90c00000 size:12M) reserved for
[    0.000000] memory reserve: Memory(base:0x90400000 size:8M) reserved for
[    0.000000] memory reserve: Total reserved 100M
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] bootconsole [earlycon0] enabled
[    0.000000] CPU SRAM: copied sram code from c0c20000 to fef00100 - fef02538
[    0.000000] CPU SRAM: copied sram data from c0c22438 to fef02538 - fef02cb0
[    0.000000] sram_log:      4q ?&     :     4q ?)     !?, # 0q    *!  ! 3q   @      3q
[    0.000000] CLKDATA_MSG: pll_flag = 0x00
[    0.000000] CLKDATA_ERR:    can't get a available nume and deno
[    0.000000] CLKDATA_ERR:    clk_frac_div can't get rate=48000000,uart0_frac_div
[    0.000000] L310 cache controller enabled
[    0.000000] l2x0: 16 ways, CACHE_ID 0x4100c0c8, AUX_CTRL 0x76050001, Cache size: 524288 B
[    0.000000] DDR DEBUG: version 1.00 20130712
[    0.000000] DDR DEBUG: fix 2cs bug
[    0.000000] DDR DEBUG: DDR3 Device
[    0.000000] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[    0.000000] DDR DEBUG: init success!!! freq=300MHz
[    0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=1 extra clock, DGPS=90
[    0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x3, DGSL=1 extra clock, DGPS=90
[    0.000000] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[    0.000000] DDR DEBUG: DRV Pull-Up=0xb, DRV Pull-Dwn=0xb
[    0.000000] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[    0.000000] Boot mode: REBOOT (6) flag: NORMAL (0xc3524200)
[    0.000000] On node 0 totalpages: 236544
[    0.000000] free_area_init_node: node 0, pgdat c0c1d780, node_mem_map c16e8000
[    0.000000]   Normal zone: 1744 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 195888 pages, LIFO batch:31
[    0.000000]   HighMem zone: 304 pages used for memmap
[    0.000000]   HighMem zone: 38608 pages, LIFO batch:7
[    0.000000] PERCPU: Embedded 7 pages/cpu @c1ef0000 s6976 r8192 d13504 u32768
[    0.000000] pcpu-alloc: s6976 r8192 d13504 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 234496
[    0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x001F0000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00004000@0x00004000(kernel),0x00008000@0x00008000(boot),0x00010000@0x00010000(recovery),0x00020000@0x00020000(backup),0x00040000@0x00040000(cache),0x00200000@0x00080000(userdata),0x00002000@0x00280000(kpanic),0x00100000@0x00282000(system),-@0x00382000(user) bootver=2013-06-20#1.24 firmware_ver=1.0.5
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 772MB 152MB = 924MB total
[    0.000000] Memory: 915688k/915688k available, 132888k reserved, 155648K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xff600000 - 0xffe00000   (   8 MB)
[    0.000000]     vmalloc : 0xf7000000 - 0xfe800000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf6800000   ( 872 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .init : 0xc0408000 - 0xc052c000   (1168 kB)
[    0.000000]       .text : 0xc052c000 - 0xc0b9e034   (6601 kB)
[    0.000000]       .data : 0xc0ba0000 - 0xc0c1f5e8   ( 510 kB)
[    0.000000]        .bss : 0xc0c23024 - 0xc16e7df8   (11028 kB)
[    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:352
[    0.000000] rk30_gpio_init: 128 gpio irqs in 4 banks
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] rk_timer: version 1.2
[    0.003678] Calibrating delay loop (skipped) preset value.. 1631.46 BogoMIPS (lpj=8157341)
[    0.012726] pid_max: default: 32768 minimum: 301
[    0.018011] Mount-cache hash table entries: 512
[    0.023529] Initializing cgroup subsys debug
[    0.028266] Initializing cgroup subsys cpuacct
[    0.033200] Initializing cgroup subsys freezer
[    0.038116] CPU: Testing write buffer coherency: ok
[    0.124283] CPU1: Booted secondary processor
[    0.164274] CPU2: Booted secondary processor
[    0.204272] CPU3: Booted secondary processor
[    0.204303] Brought up 4 CPUs
[    0.221715] SMP: Total of 4 processors activated (6525.87 BogoMIPS).
[    0.228986] devtmpfs: initialized
[    0.238447] NET: Registered protocol family 16
[    0.243409] last_log: 0xefd00000 map to 0xf7004000 and copy to 0xc0c27260 (version 2.1)
[    0.266635] mode(0xffffffff) is invalid
[    0.272381] rk_platform_add_display_devices: lvds lcd is used
[    0.278861] lcdc0 is used as primary display device contoller!
[    0.285382] lcdc1 is used as external display device controller!
[    0.392323] rk29sdk_wifi_bt_gpio_control_init: init finished
[    0.399024] rk30_i2c rk30_i2c.0: i2c-0: RK30 I2C adapter
[    0.405187] rk30_i2c rk30_i2c.1: i2c-1: RK30 I2C adapter
[    0.411342] rk30_i2c rk30_i2c.2: i2c-2: RK30 I2C adapter
[    0.417421] rk30_i2c rk30_i2c.3: i2c-3: RK30 I2C adapter
[    0.423565] rk30_i2c rk30_i2c.4: i2c-4: RK30 I2C adapter
[    0.430415] console [ttyFIQ0] enabled, bootconsole disabled
[    0.439455] Registered FIQ tty driver efc35cc0
[    0.451443] bio: create slab at 0
[    0.455857] SCSI subsystem initialized
[    0.456060] usbcore: registered new interface driver usbfs
[    0.456180] usbcore: registered new interface driver hub
[    0.470432] usbcore: registered new device driver usb
[    0.475591] rk30-adc rk30-adc: rk30 adc: driver initialized
[    0.475880] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.476315] Bluetooth: Core ver 2.16
[    0.476384] NET: Registered protocol family 31
[    0.476418] Bluetooth: HCI device and connection manager initialized
[    0.476466] Bluetooth: HCI socket layer initialized
[    0.476502] Bluetooth: L2CAP socket layer initialized
[    0.476551] Bluetooth: SCO socket layer initialized
[    0.477564] rk fb probe ok!
[    0.482434] act8846_set_init,line=17
[    0.482465] act8846_set_init:g_pmic_type=3
[    0.484260] act8846_set_init  act_dcdc1 =1200000mV end
[    0.486144] act8846_set_init  vdd_core =1000000mV end
[    0.488020] act8846_set_init  vdd_cpu =1000000mV end
[    0.489895] act8846_set_init  act_dcdc4 =3000000mV end
[    0.491139] act8846_set_init  act_ldo1 =1000000mV end
[    0.492279] act8846_set_init  act_ldo2 =1200000mV end
[    0.493419] act8846_set_init  act_ldo3 =1800000mV end
[    0.494561] act8846_set_init  act_ldo4 =3300000mV end
[    0.495703] act8846_set_init  act_ldo5 =3300000mV end
[    0.496843] act8846_set_init  act_ldo6 =1800000mV end
[    0.497983] act8846_set_init  act_ldo7 =1800000mV end
[    0.499124] act8846_set_init  act_ldo8 =2800000mV end
[    0.499168] act8846_set_init,line=78 END
[    0.499233] i2c-core: driver [act8846] using legacy suspend method
[    0.499276] i2c-core: driver [act8846] using legacy resume method
[    0.499352] ================== rk30_adc_battery_probe: pid = -1 ============
[    0.501253] status = 0, bat->bat_voltage = 8227
[    0.501416] rk30_adc_battery: driver initialized
[    0.501509] Switching to clocksource rk_timer
[    0.503658] Switched to NOHz mode on CPU #0
[    0.504312] Switched to NOHz mode on CPU #3
[    0.504328] Switched to NOHz mode on CPU #1
[    0.504340] Switched to NOHz mode on CPU #2
[    0.640641] cfg80211: Calling CRDA to update world regulatory domain
[    0.721597] RK29 Backlight Driver Initialized.
[    0.721744] lcdc0:reg_phy_base = 0x1010c000,reg_vir_base:0xf70a0000
[    0.721825] fb0:win0
[    0.721829] fb1:win1
[    0.721834] fb2:win2
[    0.721914] rk3188 lcdc0 clk enable...
[    0.746984] rk3188 lcdc0 clk disable...
[    0.771560] fb0:phy:90c00000>>vir:f8000000>>len:0xc00000
[    0.771816] rk_fb_register>>>>>fb0
[    0.780483] rk_fb_register>>>>>fb1
[    0.780533] rk3188 lcdc0 clk enable...
[    0.780624] lcdc0: dclk:72545454>>fps:63
[    0.780657] rk30-lcdc rk30-lcdc.0: rk3188_load_screen for lcdc0 ok!
[    0.780702] lcdc0 wakeup from standby!
[    0.780732] lcdc0 win0 open,atv layer:1
[    0.796508] rk3188 lcdc0 probe ok!
[    0.796595] lcdc1:reg_phy_base = 0x1010e000,reg_vir_base:0xf70a4000
[    0.796667] fb0:win0
[    0.796672] fb1:win1
[    0.796676] fb2:win2
[    0.796755] rk3188 lcdc1 clk enable...
[    0.821845] rk3188 lcdc1 clk disable...
[    0.821881] fb2:phy:90c00000>>vir:f8000000>>len:0xc00000
[    0.822118] rk_fb_register>>>>>fb2
[    0.822420] rk_fb_register>>>>>fb3
[    0.822449] rk3188 lcdc1 probe ok!
[    0.823654] input: rk_headsetdet as /devices/platform/rk_headsetdet.0/input/input0
[    0.841605] rockchip_headsetobserve_probe(): headset_det_int_level=1
[    0.841893] NET: Registered protocol family 2
[    0.842032] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.842422] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.844304] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.845405] TCP: Hash tables configured (established 131072 bind 65536)
[    0.845453] TCP reno registered
[    0.845482] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.845553] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.845891] NET: Registered protocol family 1
[    0.846057] Unpacking initramfs...
[    0.961145] Freeing initrd memory: 1984K
[    0.961258] PMU: registered new PMU device of type 0
[    0.961380] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 2
[    0.961432] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 2
[    0.984428] rk3188 cpufreq version 2.1, suspend freq 1008 MHz
[    0.985196] Loaded driver for PL330 DMAC-1 rk29-pl330
[    0.985238]     DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    0.985426] Loaded driver for PL330 DMAC-2 rk29-pl330
[    0.985467]     DBUFF-64x8bytes Num_Chans-7 Num_Peri-20 Num_Events-14
[    1.012749] highmem bounce pool size: 64 pages
[    1.012910] ashmem: initialized
[    1.021939] fuse init (API version 7.16)
[    1.026587] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.026642] io scheduler noop registered
[    1.026676] io scheduler deadline registered
[    1.026741] io scheduler cfq registered (default)
[    1.046990] rga: Driver loaded succesfully
[    1.047183] rk_serial.c v1.4 2013-04-16
[    1.047276] rk_serial.0: ttyS0 at MMIO 0x10124000 (irq = 66) is a rk29_serial.0
[    1.047441] rk_serial rk_serial.0: membase 0xf70bc000
[    1.047515] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3
[    1.047660] rk_serial rk_serial.3: membase 0xf70c0000
[    1.047870] Rockchip ion module(version: 1.0) is successfully loaded
[    1.050124] loop: module loaded
[    1.050175] Android kernel panic handler initialized (bind=kpanic)
[    1.050807] PPP generic driver version 2.4.2
[    1.050944] PPP Deflate Compression module registered
[    1.050980] PPP BSD Compression module registered
[    1.109393] PPP MPPE Compression module registered
[    1.109430] NET: Registered protocol family 24
[    1.109520] usbcore: registered new interface driver asix
[    1.109572] usbcore: registered new interface driver cdc_ether
[    1.109631] usbcore: registered new interface driver dm9620
[    1.109689] usbcore: registered new interface driver SR9700_android
[    1.109742] usbcore: registered new interface driver net1080
[    1.109794] usbcore: registered new interface driver cdc_subset
[    1.109844] usbcore: registered new interface driver zaurus
[    1.109883] cdc_ncm: 04-Aug-2011
[    1.109922] usbcore: registered new interface driver cdc_ncm
[    1.109955] Rockchip WiFi SYS interface (V1.00) ...
[    1.110007] Initializing USB Mass Storage driver...
[    1.110060] usbcore: registered new interface driver usb-storage
[    1.110093] USB Mass Storage support registered.
[    1.110183] usbcore: registered new interface driver usbserial
[    1.110235] USB Serial support registered for generic
[    1.110286] usbcore: registered new interface driver usbserial_generic
[    1.110322] usbserial: USB Serial Driver core
[    1.110364] USB Serial support registered for GSM modem (1-port)
[    1.110421] usbcore: registered new interface driver option
[    1.110455] option: v0.7.2:USB Driver for GSM modems
[    1.110498] USB Serial support registered for usi-modem
[    1.110555] usbcore: registered new interface driver usi-modem
[    1.322168] DWC_OTG: ^^^^^^^^^^^^^^^^^Device Mode
[    1.322206] usb20_otg usb20_otg: DWC OTG Controller
[    1.322307] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
[    1.322364] usb20_otg usb20_otg: irq 48, io mem 0x00000000
[    1.322395] DWC_OTG: dwc_otg_hcd_start controller in device mode,everest
[    1.322465] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.322506] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.322547] usb usb1: Product: DWC OTG Controller
[    1.322575] usb usb1: Manufacturer: Linux 3.0.36+ dwc_otg_hcd
[    1.322606] usb usb1: SerialNumber: usb20_otg
[    1.322890] hub 1-0:1.0: USB hub found
[    1.322919] hub 1-0:1.0: 1 port detected
[    1.325479] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xf7180000
[    1.535858] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
[    1.535898] usb20_host usb20_host: DWC OTG Controller
[    1.535951] usb20_host usb20_host: new USB bus registered, assigned bus number 2
[    1.536012] usb20_host usb20_host: irq 49, io mem 0x00000000
[    1.536076] DWC_OTG: Init: Port Power? op_state=1
[    1.536101] DWC_OTG: Init: Power Port (0)
[    1.536148] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.536186] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.536225] usb usb2: Product: DWC OTG Controller
[    1.536250] usb usb2: Manufacturer: Linux 3.0.36+ host20_hcd
[    1.536280] usb usb2: SerialNumber: usb20_host
[    1.536515] hub 2-0:1.0: USB hub found
[    1.536542] hub 2-0:1.0: 1 port detected
[    1.603520] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    1.603560] android_usb gadget: Number of LUNs=2
[    1.603593]  lun0: LUN: removable file: (no medium)
[    1.603620]  lun1: LUN: removable file: (no medium)
[    1.603778] android_usb gadget: android_usb ready
[    1.604019] input: rk29-keypad as /devices/platform/rk29-keypad/input/input1
[    1.604194] usbcore: registered new interface driver xpad
[    1.604249] usbcore: registered new interface driver usb_acecad
[    1.604280] acecad: v3.2:USB Acecad Flair tablet driver
[    1.604354] usbcore: registered new interface driver aiptek
[    1.604384] aiptek: v2.3 (May 2, 2007):Aiptek HyperPen USB Tablet Driver (Linux 2.6.x)
[    1.604426] aiptek: Bryan W. Headley/Chris Atenasio/Cedric Brun/Rene van Paassen
[    1.604488] usbcore: registered new interface driver gtco
[    1.604517] GTCO usb driver version: 2.00.0006
[    1.604561] usbcore: registered new interface driver hanwang
[    1.604610] usbcore: registered new interface driver kbtab
[    1.604639] kbtab: v0.0.2:USB KB Gear JamStudio Tablet driver
[    1.604695] usbcore: registered new interface driver wacom
[    1.604724] wacom: v1.52:USB Wacom tablet driver
[    1.604748] ft5x0x module init
[    1.604793] ft5x0x_probe enter
[    1.611672] Create class touchpanel is sucess
[    1.611697]
[    1.611699] ----ft_rw_iic_drv init ---
[    1.611819]
[    1.611822] ----ft_rw_iic_drv add ---
[    1.611933] MMMMMMMMMMMMMMMMMMMMMMMMMM: mma7660_i2c_init, 820: mma7660 probe ok
[    1.611984] MMMMMMMMMMMMMMMMMMMMMMMMMM: mma7660_probe, 698: mma7660 probe enter
[    1.612022] MMMMMMMMMMMMMMMMMMMMMMMMMM: mma7660_probe, 699: mma7660 probe enter
[    1.612409] input: gsensor as /devices/platform/rk30_i2c.0/i2c-0/0-004c/input/input2
[    1.612569] MMMMMMMMMMMMMMMMMMMMMMMMMM: mma7660_probe, 795: mma7660 probe ok
[    1.612626] i2c-core: driver [gs_mma7660] using legacy suspend method
[    1.612661] i2c-core: driver [gs_mma7660] using legacy resume method
[    1.612699] sensor_register_slave:mma7660,id=15
[    1.619587] using rtc device, rtc_hym8563, for alarms
[    1.619634] rtc_hym8563 1-0051: rtc core: registered rtc_hym8563 as rtc0
[    1.619687] i2c /dev entries driver
[    1.620049] lirc_dev: IR Remote Control driver registered, major 250
[    1.620084] IR NEC protocol handler initialized
[    1.620108] IR RC5(x) protocol handler initialized
[    1.620133] IR RC6 protocol handler initialized
[    1.620157] IR JVC protocol handler initialized
[    1.620190] IR Sony protocol handler initialized
[    1.620215] IR RC5 (streamzap) protocol handler initialized
[    1.620243] IR LIRC bridge handler initialized
[    1.620269] Linux video capture interface: v2.00
[    1.620422] def_ref_volt: 1800mV, curr_ref_volt: 1800mV
[    1.620450] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[    1.620586] rk29-wdt rk29-wdt.0: starting watchdog timer
[    1.620872] device-mapper: uevent: version 1.0.3
[    1.621034] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[    1.621141] Bluetooth: HCI UART driver ver 2.2
[    1.621168] Bluetooth: HCI H4 protocol initialized
[    1.621193] Bluetooth: HCILL protocol initialized
[    1.621252] cpuidle: using governor ladder
[    1.621276] cpuidle: using governor menu
[    1.666603] .Line3965..The End of SDMMC-probe Ver.5.05 The last modify date is 2013-05-08.  [sd_mmc]
[    1.666767] .Line3965..The End of SDMMC-probe Ver.5.05 The last modify date is 2013-05-08.  [sdio]
[    1.667876] usbcore: registered new interface driver usbhid
[    1.667907] usbhid: USB HID core driver
[    1.668016]
[    1.668018] drivers/mmc/core/core.c...1824..  ===== mmc_rescan Begin....[mmc0]
[    1.673103] rk29_sdmmc_change_clk_div..1961..  newDiv=62, newCLK=299Khz [sd_mmc]
[    1.673329] logger: created 256K log 'log_main'
[    1.673396] logger: created 256K log 'log_events'
[    1.673469] logger: created 256K log 'log_radio'
[    1.673534] logger: created 256K log 'log_system'
[    1.673836] enter rt5616_modinit
[    1.673874] enter rt5616_i2c_probe
[    1.712929] Enter::audio_card_init----218
[    1.716132]
[    1.716135] mmc_attach_sd..1219..  ===== Begin to identify card as SD-card. [mmc0]
[    1.741198] Enter::rk29_rt5616_init----169
[    1.741220] rt5616 4-001b: Failed to add route Mic Jack->Mic Bias1
[    1.741261] rt5616 4-001b: dapm: unknown pin HP_L
[    1.741291] rt5616 4-001b: dapm: unknown pin HP_R
[    1.756884] asoc: rt5616-aif1 rk29_i2s.1 mapping ok
[    1.757239] ALSA device list:
[    1.757260]   #0: RK29_rt5616
[    1.757363] GACT probability NOT on
[    1.757390] Mirror/redirect action on
[    1.757415] u32 classifier
[    1.757432]     Actions configured
[    1.757456] Netfilter messages via NETLINK v0.30.
[    1.757540] nf_conntrack version 0.5.0 (14338 buckets, 57352 max)
[    1.757855] ctnetlink v0.93: registering with nfnetlink.
[    1.757916] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    1.757957] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    1.758244] xt_time: kernel timezone is -0000
[    1.758401] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.758551] arp_tables: (C) 2002 David S. Miller
[    1.758617] TCP cubic registered
[    1.758639] Initializing XFRM netlink socket
[    1.759063] NET: Registered protocol family 10
[    1.759669] Mobile IPv6
[    1.759707] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    1.759852] IPv6 over IPv4 tunneling driver
[    1.760473] NET: Registered protocol family 17
[    1.760522] NET: Registered protocol family 15
[    1.761641] Bluetooth: RFCOMM TTY layer initialized
[    1.761678] Bluetooth: RFCOMM socket layer initialized
[    1.761712] Bluetooth: RFCOMM ver 1.11
[    1.761737] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.761769] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.761899] NET: Registered protocol family 35
[    1.762060] [BT_RFKILL]: Enter rfkill_rk_init
[    1.762158] mode(0xffffffff) is invalid
[    1.762190] [BT_RFKILL]: Request irq for bt wakeup host
[    1.762235] [BT_RFKILL]: ** disable irq
[    1.791587] [BT_RFKILL]: bt shut off power
[    1.791615] [BT_RFKILL]: ap6210 device registered.
[    1.886903] rk29_sdmmc_change_clk_div..1961..  newDiv=0, newCLK=37125Khz [sd_mmc]
[    1.887001] mmc0: new high speed SDHC card at address e624
[    1.891634] mmcblk0: mmc0:e624 SS04G 3.69 GiB
[    1.906005]
[    1.906008] msdos_partition..461... ==== Begin to parse sdcard-partition.  [mmc0]
[    1.906061] msdos_partition..530... ==== The sdcard has MBR. [mmc0]
[    1.906099] msdos_partition..543... ==== partition-1, size=3871232KB  [mmc0]
[    1.906140] msdos_partition..571... ==== main partition-1....[mmc0]
[    1.906179]  mmcblk0: p1
[    1.906509] mmc_rescan_try_freq..1718..  ===== Initialize SD-card successfully. [mmc0]
[    1.906573]
[    1.906576] drivers/mmc/core/core.c...1824..  ===== mmc_rescan Begin....[mmc1]
[    1.921593] rk29_sdmmc_change_clk_div..1961..  newDiv=42, newCLK=294Khz [sdio]
[    2.215357] ft5406 g_vid = 0x83
[    2.215505] input: ft5x0x as /devices/platform/rk30_i2c.2/i2c-2/2-0038/input/input3
[    2.451781] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    2.451863] Registering SWP/SWPB emulation handler
[    2.452238] ddrfreq: verion 2.4 20130427
[    2.452263] ddrfreq: normal 396MHz video 300MHz dualview 0MHz idle 0MHz suspend 0MHz reboot 300MHz
[    2.453272] ddrfreq: change freq to 396 MHz when normal
[    2.453660] sensor_init: Probe name sensors
[    2.453693] sensor-dev.c v1.3 add sensor debug support 2013-3-15
[    2.454725] rtc_hym8563 1-0051: setting system clock to 2016-09-01 07:07:53 UTC (1472713673)
[    2.457219] asoc: rk-hdmi-i2s-hifi rk29_i2s.1 mapping ok
[    2.457609] Freeing init memory: 1168K
[    2.461658] rk_cam_cif(3093):rk3066b-camera version: v0.3.9  Zoom by ipp
[    2.461723] rk_cam_io(1156):sp0838_back_back_3 powerdown pin(269) init success(0x0)
[    2.461730]
[    2.461774] rk_cam_io(1156):sp2518_back_back_4 powerdown pin(269) init success(0x0)
[    2.461782]
[    2.461822] rk_cam_io(1156):ov5640_back_5 powerdown pin(269) init success(0x0)
[    2.461830]
[    2.461870] rk_cam_io(1156):sp2518_front_6 powerdown pin(268) init success(0x0)
[    2.461878]
[    2.461919] rk_cam_io(1156):sp0838_front_7 powerdown pin(268) init success(0x0)
[    2.461926]
[    2.463508] rk_cam_io(1515):SensorPwrSeq-clock: 0
[    2.463513]
[    2.463544] rk_cam_io(784):sp0838_back_back_3 PowerDownPin=269 ..PinLevel = 1
[    2.463552]
[    2.463591] rk_cam_io(1504):SensorPwrSeq-power down: 1
[    2.463596]
[    2.464047] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[    2.481646] rk_cam_io(1493):SensorPwrSeq-reset: 0
[    2.481655]
[    2.485318] keychord: using input dev rk29-keypad for fevent
[    2.501596] rk_cam_io(1480):SensorPwrSeq-power: 0
[    2.501602]
[    2.737414] gp_rknand_info = : 0xeecef300
[    2.737591] rk30_chip_set:1
[    2.737651] request IRQ_NANDC irq , ret=0.........
[    2.737698] FTL INFO:Version = 438,Date = 20130620
[    2.737800] FlashCopyProgBuf1=0xc156c000
[    2.737851] ATime: 40 ns AHB: 148 timming: 1081
[    2.737888] No.1 FLASH INFO:98 de 84 93 72
[    2.737920] No.2 FLASH INFO:ff ff ff ff ff
[    2.737952] No.3 FLASH INFO:ff ff ff ff ff
[    2.737983] No.4 FLASH INFO:ff ff ff ff ff
[    2.738331] ATime: 32 ns AHB: 148 timming: 1061
[    2.738519] ATime: 32 ns AHB: 148 timming: 1061
[    2.738550] randomizer = 2 , EccBits = 28 pSpec->pReadRetrial = bf009fd0
[    2.805637] totalLogicBlkRaw  = 1893
[    2.805665] gBootMedia = 1 gSdmmcFwPartOffset =0!
[    2.805693] rknand_buffer.c version: 4.38 20121130!
[    2.818795] 10 cmdlinepart partitions found on MTD device rk29xxnand
[    2.818831] Creating 10 MTD partitions on "rk29xxnand":
[    2.818867] 0x000000400000-0x000000800000 : "misc"
[    2.835573] 0x000000800000-0x000001000000 : "kernel"
[    2.840944] 0x000001000000-0x000002000000 : "boot"
[    2.846128] 0x000002000000-0x000004000000 : "recovery"
[    2.851695] 0x000004000000-0x000008000000 : "backup"
[    2.857050] 0x000008000000-0x000010000000 : "cache"
[    2.862336] 0x000010000000-0x000050000000 : "userdata"
[    2.867898] 0x000050000000-0x000050400000 : "kpanic"
[    2.873905] apanic: Bound to mtd partition 'kpanic'
[    2.873932] apanic: No panic data available
[    2.874090] 0x000050400000-0x000070400000 : "system"
[    2.888327] 0x000070400000-0x0001d9400000 : "user"
[    2.893564] startBlk = 48  sysProtAddr = 47
[    3.002291] EXT4-fs (mtdblock8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[    3.011635] rk_cam_io(784):sp2518_back_back_4 PowerDownPin=269 ..PinLevel = 1
[    3.011648]
[    3.011705] rk_cam_io(784):ov5640_back_5 PowerDownPin=269 ..PinLevel = 1
[    3.011719]
[    3.011771] rk_cam_io(784):sp2518_front_6 PowerDownPin=268 ..PinLevel = 1
[    3.011781]
[    3.011829] rk_cam_io(784):sp0838_front_7 PowerDownPin=268 ..PinLevel = 1
[    3.011840]
[    3.031611] rk_cam_io(1480):SensorPwrSeq-power: 1
[    3.031621]
[    3.051618] rk_cam_io(1493):SensorPwrSeq-reset: 1
[    3.051627]
[    3.051687] rk_cam_io(787):sp0838_back_back_3 PowerDownPin= 269..PinLevel = 0
[    3.051710]
[    3.051776] rk_cam_io(1504):SensorPwrSeq-power down: 0
[    3.051785]
[    3.051835] rk_cam_io(1515):SensorPwrSeq-clock: 1
[    3.051844]
[    3.061910] min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480
[    3.082032] i2c i2c-3: No ack, Maybe slave(addr: 0x18) not exist or abnormal power-on, retry 2...
[    3.083106] i2c i2c-3: No ack, Maybe slave(addr: 0x18) not exist or abnormal power-on, retry 1...
[    3.083562] i2c i2c-3: No ack, Maybe slave(addr: 0x18) not exist or abnormal power-on, retry 0...
[    3.083604] sp0838_back_back_3(rk_cam_sensor:307): read reg(0x2 val:0x27) failed, try to read again!
[    3.083656] sp0838_back_back_3(rk_cam_sensor:650): read chip id failed
[    3.084432] rk_cam_io(1515):SensorPwrSeq-clock: 0
[    3.084437]
[    3.084466] rk_cam_io(784):sp0838_back_back_3 PowerDownPin=269 ..PinLevel = 1
[    3.084473]
[    3.084506] rk_cam_io(1504):SensorPwrSeq-power down: 1
[    3.084512]
[    3.101616] rk_cam_io(1493):SensorPwrSeq-reset: 0
[    3.101621]
[    3.121613] rk_cam_io(1480):SensorPwrSeq-power: 0
[    3.121619]
[    3.277864] EXT4-fs (mtdblock6): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[    3.423093] EXT4-fs (mtdblock5): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[    3.476606] UMP: Using OS memory backend, allocation limit: 536870912
[    3.476673] UMP: UMP device driver  loaded
[    3.514922] Mali: Mali400 inside of rk3188!
[    3.514955] Mali: mali freq table num : 7
[    3.514982] Mali: mali freq table :Mali: 100,Mali: 149,Mali: 200,Mali: 200,Mali: 297,Mali: 399,Mali: 594,Mali:
[    3.515047] Mali: init mali clock success
[    3.631581] camera 33-0-sp0838_back_back_3: Probe sp0838_back_back_3 failed
[    3.632170] rk_cam_io(1515):SensorPwrSeq-clock: 0
[    3.632189]
[    3.632322] rk_cam_io(784):sp2518_back_back_4 PowerDownPin=269 ..PinLevel = 1
[    3.632346]
[    3.632429] rk_cam_io(1504):SensorPwrSeq-power down: 1
[    3.632447]
[    3.651596] rk_cam_io(1493):SensorPwrSeq-reset: 0
[    3.651623]
[    3.671589] rk_cam_io(1480):SensorPwrSeq-power: 0
[    3.671597]
[    4.181724] rk_cam_io(784):sp0838_back_back_3 PowerDownPin=269 ..PinLevel = 1
[    4.181749]
[    4.181851] rk_cam_io(784):ov5640_back_5 PowerDownPin=269 ..PinLevel = 1
[    4.181876]
[    4.182034] rk_cam_io(784):sp2518_front_6 PowerDownPin=268 ..PinLevel = 1
[    4.182057]
[    4.182144] rk_cam_io(784):sp0838_front_7 PowerDownPin=268 ..PinLevel = 1
[    4.182166]
[    4.201617] rk_cam_io(1480):SensorPwrSeq-power: 1
[    4.201625]
[    4.221626] rk_cam_io(1493):SensorPwrSeq-reset: 1
[    4.221635]
[    4.221677] rk_cam_io(787):sp2518_back_back_4 PowerDownPin= 269..PinLevel = 0
[    4.221692]
[    4.221737] rk_cam_io(1504):SensorPwrSeq-power down: 0
[    4.221745]
[    4.221789] rk_cam_io(1515):SensorPwrSeq-clock: 1
[    4.221797]
[    4.249658] min_w = 800,min_h = 600 ,max_real_w = 1600,max_real_h = 1200,max_w = 1600,max_h =1200
[    4.262243] rk_cam_io(1515):SensorPwrSeq-clock: 0
[    4.262248]
[    4.262281] rk_cam_io(784):sp2518_back_back_4 PowerDownPin=269 ..PinLevel = 1
[    4.262290]
[    4.262325] rk_cam_io(1504):SensorPwrSeq-power down: 1
[    4.262330]
[    4.281586] rk_cam_io(1493):SensorPwrSeq-reset: 0
[    4.281591]
[    4.301616] rk_cam_io(1480):SensorPwrSeq-power: 0
[    4.301622]
[    4.811667] Probe sp2518_back_back_4 success
[    4.812063] rk_cam_io(1515):SensorPwrSeq-clock: 0
[    4.812081]
[    4.812158] rk_cam_io(784):ov5640_back_5 PowerDownPin=269 ..PinLevel = 1
[    4.812180]
[    4.812259] rk_cam_io(1504):SensorPwrSeq-power down: 1
[    4.812277]
[    4.831672] rk_cam_io(1493):SensorPwrSeq-reset: 0
[    4.831691]
[    4.851597] rk_cam_io(1480):SensorPwrSeq-power: 0
[    4.851606]
[    5.361656] rk_cam_io(784):sp0838_back_back_3 PowerDownPin=269 ..PinLevel = 1
[    5.361681]
[    5.361778] rk_cam_io(784):sp2518_back_back_4 PowerDownPin=269 ..PinLevel = 1
[    5.361804]
[    5.361897] rk_cam_io(784):sp2518_front_6 PowerDownPin=268 ..PinLevel = 1
[    5.361919]
[    5.362003] rk_cam_io(784):sp0838_front_7 PowerDownPin=268 ..PinLevel = 1
[    5.362025]
[    5.381652] rk_cam_io(1480):SensorPwrSeq-power: 1
[    5.381671]
[    5.401639] rk_cam_io(1493):SensorPwrSeq-reset: 1
[    5.401647]
[    5.401686] rk_cam_io(787):ov5640_back_5 PowerDownPin= 269..PinLevel = 0
[    5.401697]
[    5.401741] rk_cam_io(1504):SensorPwrSeq-power down: 0
[    5.401749]
[    5.401792] rk_cam_io(1515):SensorPwrSeq-clock: 1
[    5.401800]
[    5.402254] min_w = 800,min_h = 600 ,max_real_w = 2592,max_real_h = 1944,max_w = 2592,max_h =1944
[    5.402745] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
[    5.403183] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
[    5.403621] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
[    5.403662] ov5640_back_5(rk_cam_sensor:141): write reg(0x3008, val:0x80) failed, try to write again!
[    5.404111] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
[    5.404548] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
[    5.404984] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
[    5.405024] ov5640_back_5(rk_cam_sensor:141): write reg(0x3008, val:0x80) failed, try to write again!
[    5.405473] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
[    5.405909] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
[    5.406345] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
[    5.406385] ov5640_back_5(rk_cam_sensor:141): write reg(0x3008, val:0x80) failed, try to write again!
[    5.406435] ov5640_back_5(rk_cam_sensor:357): write array failed!
[    5.406462] ov5640_back_5(rk_cam_sensor:623): soft reset failed
[    5.406468]
[    5.422094] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
[    5.422645] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
[    5.423194] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
[    5.423235] ov5640_back_5(rk_cam_sensor:307): read reg(0x300a val:0x56) failed, try to read again!
[    5.423284] ov5640_back_5(rk_cam_sensor:650): read chip id failed
[    5.423378] rk_cam_io(1515):SensorPwrSeq-clock: 0
[    5.423383]
[    5.423411] rk_cam_io(784):ov5640_back_5 PowerDownPin=269 ..PinLevel = 1
[    5.423417]
[    5.423448] rk_cam_io(1504):SensorPwrSeq-power down: 1
[    5.423454]
[    5.441581] rk_cam_io(1493):SensorPwrSeq-reset: 0
[    5.441586]
[    5.461580] rk_cam_io(1480):SensorPwrSeq-power: 0
[    5.461586]
[    5.971586] camera 33-2-ov5640_back_5: Probe ov5640_back_5 failed
[    5.971679] rk_cam_io(1515):SensorPwrSeq-clock: 0
[    5.971685]
[    5.971714] rk_cam_io(784):sp2518_front_6 PowerDownPin=268 ..PinLevel = 1
[    5.971720]
[    5.971752] rk_cam_io(1504):SensorPwrSeq-power down: 1
[    5.971757]
[    5.991585] rk_cam_io(1493):SensorPwrSeq-reset: 0
[    5.991591]
[    6.011589] rk_cam_io(1480):SensorPwrSeq-power: 0
[    6.011593]
[    6.521584] rk_cam_io(784):sp0838_back_back_3 PowerDownPin=269 ..PinLevel = 1
[    6.521592]
[    6.521630] rk_cam_io(784):sp2518_back_back_4 PowerDownPin=269 ..PinLevel = 1
[    6.521641]
[    6.521677] rk_cam_io(784):ov5640_back_5 PowerDownPin=269 ..PinLevel = 1
[    6.521683]
[    6.521719] rk_cam_io(784):sp0838_front_7 PowerDownPin=268 ..PinLevel = 1
[    6.521726]
[    6.541582] rk_cam_io(1480):SensorPwrSeq-power: 1
[    6.541588]
[    6.561583] rk_cam_io(1493):SensorPwrSeq-reset: 1
[    6.561588]
[    6.561616] rk_cam_io(787):sp2518_front_6 PowerDownPin= 268..PinLevel = 0
[    6.561622]
[    6.561655] rk_cam_io(1504):SensorPwrSeq-power down: 0
[    6.561660]
[    6.561698] rk_cam_io(1515):SensorPwrSeq-clock: 1
[    6.561703]
[    6.589230] i2c i2c-3: 1 i2c clients have been registered at 0x30min_w = 800,min_h = 600 ,max_real_w = 1600,max_real_h = 1200,max_w = 1600,max_h =1200
[    6.602032] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2...
[    6.602488] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1...
[    6.602942] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 0...
[    6.602983] sp2518_front_6(rk_cam_sensor:307): read reg(0x2 val:0x53) failed, try to read again!
[    6.603039] sp2518_front_6(rk_cam_sensor:650): read chip id failed
[    6.603123] rk_cam_io(1515):SensorPwrSeq-clock: 0
[    6.603128]
[    6.603156] rk_cam_io(784):sp2518_front_6 PowerDownPin=268 ..PinLevel = 1
[    6.603162]
[    6.603194] rk_cam_io(1504):SensorPwrSeq-power down: 1
[    6.603199]
[    6.621581] rk_cam_io(1493):SensorPwrSeq-reset: 0
[    6.621587]
[    6.641588] rk_cam_io(1480):SensorPwrSeq-power: 0
[    6.641593]
[    7.151638] camera 33-3-sp2518_front_6: Probe sp2518_front_6 failed
[    7.151964] rk_cam_io(1515):SensorPwrSeq-clock: 0
[    7.151983]
[    7.152061] rk_cam_io(784):sp0838_front_7 PowerDownPin=268 ..PinLevel = 1
[    7.152084]
[    7.152161] rk_cam_io(1504):SensorPwrSeq-power down: 1
[    7.152179]
[    7.171650] rk_cam_io(1493):SensorPwrSeq-reset: 0
[    7.171670]
[    7.191600] rk_cam_io(1480):SensorPwrSeq-power: 0
[    7.191609]
[    7.701724] rk_cam_io(784):sp0838_back_back_3 PowerDownPin=269 ..PinLevel = 1
[    7.701750]
[    7.701846] rk_cam_io(784):sp2518_back_back_4 PowerDownPin=269 ..PinLevel = 1
[    7.701871]
[    7.701960] rk_cam_io(784):ov5640_back_5 PowerDownPin=269 ..PinLevel = 1
[    7.701982]
[    7.702066] rk_cam_io(784):sp2518_front_6 PowerDownPin=268 ..PinLevel = 1
[    7.702088]
[    7.721638] rk_cam_io(1480):SensorPwrSeq-power: 1
[    7.721656]
[    7.741596] rk_cam_io(1493):SensorPwrSeq-reset: 1
[    7.741605]
[    7.741645] rk_cam_io(787):sp0838_front_7 PowerDownPin= 268..PinLevel = 0
[    7.741656]
[    7.741700] rk_cam_io(1504):SensorPwrSeq-power down: 0
[    7.741708]
[    7.741750] rk_cam_io(1515):SensorPwrSeq-clock: 1
[    7.741757]
[    7.742126] min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480
[    7.762214] rk_cam_io(1515):SensorPwrSeq-clock: 0
[    7.762219]
[    7.762249] rk_cam_io(784):sp0838_front_7 PowerDownPin=268 ..PinLevel = 1
[    7.762255]
[    7.762287] rk_cam_io(1504):SensorPwrSeq-power down: 1
[    7.762293]
[    7.781584] rk_cam_io(1493):SensorPwrSeq-reset: 0
[    7.781590]
[    7.801582] rk_cam_io(1480):SensorPwrSeq-power: 0
[    7.801586]
[    8.311584] Probe sp0838_front_7 success
[    8.316080] Mali: @@@@@@@Mali device driver loaded success@@@@@@@@
[    8.318248] mirroring: Unknown symbol video_data_to_mirroring (err 0)
[    8.318309] mirroring: Unknown symbol audio_data_to_mirroring (err 0)
[    8.323240] rk29_ipp: module is from the staging directory, the quality is unknown, you have been warned.
[    8.324049] ipp irq 47
[    8.324305] IPP init, version rk30-ipp 1.003
[    8.368848] write_axis: buf[]=fb=-y
[    8.368871] auto gs f:
[    8.368892] id1=2 id2=-2 id3=1
[    8.368935] write_axis: buf[]=leftright=z
[    8.368955] auto gs l:
[    8.368967] id1=3 id2=-2 id3=1
[    8.369001] write_axis: buf[]=updown=-x
[    8.369019] auto gs u:
[    8.369032] id1=3 id2=-2 id3=-1
[    8.379997] init: cannot find '/system/vendor/bin/pvrsrvctl', disabling 'pvrsrvctl'
[    8.584257] init: cannot find '/system/bin/bplus_helper', disabling 'bplus_helper'
[    8.743416] VPU_SERVICE: failed on clk_get pd_video
[    8.743494] vpu: power on
[    8.743555] VPU_SERVICE: checking hw id 4831
[    8.744228] vpu: power off...done
[    8.744273] VPU_SERVICE: init success
[    8.748709] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[    8.748772] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial'
[    8.749206] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
[    8.842208] android_usb: already disabled
[    8.847260] warning: `adbd' uses 32-bit capabilities (legacy support in use)
[    8.854525] adb_open
[    8.911795] [rknand_sys_storage_ioctl:90] rknand_sys_storage_ioctl in
[    8.920140] [rknand_sys_storage_ioctl:103] RKNAND_GET_DRM_KEY
[    8.925952] [rknand_sys_storage_ioctl:365] return ret = 0
[    8.977782] .428.. MMC0 receive the message sd-No-Media from VOLD.[sd_mmc]
[    8.977827] .459.. MMC0 receive the message No-Media from VOLD. waitTimes=0 [sd_mmc]
[    8.999492] .428.. MMC0 receive the message sd-Pending from VOLD.[sd_mmc]
[    8.999694] .428.. MMC0 receive the message sd-Idle-Unmounted from VOLD.[sd_mmc]
[    9.392491] rk fb use 3 buffers
[    9.406952] lcdc0 win1 open,atv layer:2
[    9.407000] lcdc0 win1 closed,atv layer:1
[    9.440025] rk30-lcdc rk30-lcdc.0: blank mode:0
[    9.561627] DWC_OTG: dwc_otg_hcd_enable, disable host controller
[    9.828465] sp2518_back_back_4(rk_cam_sensor:1160): generic_sensor_ioctl cmd(0x3) is unknown !
[    9.828474]
[    9.828754] sp0838_front_7(rk_cam_sensor:1160): generic_sensor_ioctl cmd(0x3) is unknown !
[    9.828763]
[   11.621686] ========= rk30_adc_battery_check:bat adc 819---> vol 8219 ---> level 0 ===========
[   11.621804] capacity = 99, new_capacity = 100, old_capacity = 99
[   11.621951] capacity = 99, new_capacity = 100, old_capacity = 99
[   17.331591] DWC_OTG: ********vbus detect*********************************************
[   17.568586] DWC_OTG: ********soft connect!!!*****************************************
[   17.574585] DWC_OTG: USB SUSPEND
[   17.671109] DWC_OTG: USB RESET
[   17.787770] android_work: sent uevent USB_STATE=CONNECTED
[   17.822600] android_usb gadget: high speed config #1: android
[   17.823196] android_work: sent uevent USB_STATE=CONFIGURED
[   17.896772] request_suspend_state: wakeup (3->0) at 17845197962 (2016-09-01 07:08:08.931292752 UTC)
[   18.381146] acc_open
[   18.381195] acc_release
[   18.544567] .428.. MMC0 receive the message sd-Checking from VOLD.[sd_mmc]
[   18.554709] .428.. MMC0 receive the message sd-Mounted from VOLD.[sd_mmc]
[   21.606288] Enter::rk29_hw_params----43
[   21.606350] Enter:rk29_hw_params, 97, rate=44100
[   21.606397] Enter:rk29_hw_params, 134, LRCK=64
[   21.606970] *** YF_HEADSET_IN_LEVEL==GPIO_LOW
[   21.607095] *** rt5616_headset_process(): on_off_hp=4, on_off_spk=2
[   21.825251] i2s dma info:periodsize(4096),limit(6),buffersize(24576),over(0)
[   27.212288] Enter::rk29_hw_params----43
[   27.212344] Enter:rk29_hw_params, 97, rate=44100
[   27.212373] Enter:rk29_hw_params, 134, LRCK=64
[   27.212414] *** YF_HEADSET_IN_LEVEL==GPIO_LOW
[   27.217028] *** rt5616_headset_process(): on_off_hp=4, on_off_spk=2
[   27.424795] i2s dma info:periodsize(4096),limit(6),buffersize(24576),over(0)
[   83.999600] rk30-lcdc rk30-lcdc.0: blank mode:4
[   84.000433] request_suspend_state: sleep (0->3) at 83948840096 (2016-09-01 07:09:15.034933719 UTC)
[   84.005092] ==ft5x0x_ts_suspend=
[   84.031393] rk3188 lcdc0 clk disable...
[   84.321789] ======= adc_to_voltage: resume_adc_val = 824, suspend_adc_val = 828, offset = 40 ======
[  924.035243] request_suspend_state: wakeup (3->0) at 923983665731 (2016-09-01 07:23:15.069760521 UTC)
[  924.051710] rk3188 lcdc0 clk enable...
[  924.051764] rk3188 lcdc1 clk enable...
[  924.078349] rk3188 lcdc1 clk disable...
[  924.078400] ==ft5x0x_ts_resume=
[  924.391700] func rk_hdmi_power_init, line 956: request gpio fail
[  924.472545] rk30-lcdc rk30-lcdc.0: blank mode:0
[  924.482191] rt5616_ctl_hp_spk_for_hdmi , on = 1 hdmi = 0
[  984.510594] rk30-lcdc rk30-lcdc.0: blank mode:4
[  984.511375] request_suspend_state: sleep (0->3) at 984459784278 (2016-09-01 07:24:15.545877901 UTC)
[  984.515109] ==ft5x0x_ts_suspend=
[  984.541203] rk3188 lcdc0 clk disable...
[  985.321783] ======= adc_to_voltage: resume_adc_val = 822, suspend_adc_val = 826, offset = 40 ======
[ 1461.445809] request_suspend_state: wakeup (3->0) at 1461394215164 (2016-09-01 07:32:12.480309079 UTC)
[ 1461.461745] rk3188 lcdc0 clk enable...
[ 1461.461821] rk3188 lcdc1 clk enable...
[ 1461.492479] rk3188 lcdc1 clk disable...
[ 1461.492524] ==ft5x0x_ts_resume=
[ 1461.811682] func rk_hdmi_power_init, line 956: request gpio fail
[ 1461.892541] rk30-lcdc rk30-lcdc.0: blank mode:0
[ 1461.902331] rt5616_ctl_hp_spk_for_hdmi , on = 1 hdmi = 0
[ 1521.918837] rk30-lcdc rk30-lcdc.0: blank mode:4
[ 1521.925042] request_suspend_state: sleep (0->3) at 1521873436889 (2016-09-01 07:33:12.959530804 UTC)
[ 1521.928819] ==ft5x0x_ts_suspend=
[ 1521.955541] rk3188 lcdc0 clk disable...
[ 1522.321675] ======= adc_to_voltage: resume_adc_val = 822, suspend_adc_val = 824, offset = 20 ======
[ 1670.935245] init: untracked pid 1270 exited
2016/09/01 - 13:56
Pls run the dump part and upload the stuff. I will check.
noyp
Forum Posts: 22
2016/09/01 - 14:02
got permission denied when dumping images and then device rebooted, looks like i cant even dump  images while it is not rooted
http://i64.tinypic.com/1498oe8.pngImage Enlarger
2016/09/01 - 14:21
Open a terminal on the tab:
cat proc/cmdline >/mnt/sdcard/cmdline.txt
dd if=/dev/mtd/mtd1 of=/sdcard/kernel.img bs=4096
dd if=/dev/mtd/mtd2 of=/sdcard/boot.img bs=4096
dd if=/dev/mtd/mtd3 of=/sdcard/recovery.img bs=4096
dd if=/dev/mtd/mtd8 of=/sdcard/system.img bs=4096
noyp
Forum Posts: 22
2016/09/01 - 14:52
same result oma
http://i63.tinypic.com/4hxyz8.pngImage Enlarger
noyp
Forum Posts: 22
2016/09/01 - 16:49
device shuts down when switching to loader mode,
http://i64.tinypic.com/2q3qgdl.pngImage Enlarger
http://i68.tinypic.com/1zdyhqu.pngImage Enlarger
2016/09/01 - 18:15
That's ok. Now rkDumper dump.
noyp
Forum Posts: 22
2016/09/02 - 04:59
it stop after device shuts down and i got usb not recognized error, checking device manager i see a yellow exclamation point that says Unknown USB device. it might be looking for bootloader usb driver or its bootloader is locked, looks like its a dead end for this device
http://i66.tinypic.com/2i23bwo.pngImage Enlarger
2016/09/03 - 05:08
Which Windows? Pls try to re-install the USB-driver: http://crewrktablets.arctablet.com/?wpfb_dl=2766
noyp
Forum Posts: 22
2016/09/03 - 08:26
i already installed that usb driver on my windows 10 pc and the result is the same. btw i have dumped the system folder as per this thread http://forum.xda-developers.com/showthread.php?t=1578099 please advise if u need me to upload it.
2016/09/03 - 09:40
??? Does this tab have eMMC? Let me see that:
cat /proc/partitons
68 Guest(s)
Devices in use: Desktop (61), Phone (7)
