Firmware for Aocos PX103
iZakaroN
2014/01/05 - 03:22
Sorry for the stupid question, but what I'm doing wrong? I copied all .img files in the root of SD card, then boot into recovery mode (-/+/PWR buttons) and choosing update rkimage from external storage say that "Cannot found firmware image or invalid image".
iZakaroN
2014/01/05 - 10:40
Finally, I managed to flash my Aocos using images supplied by evilchuckk with replaced kernel and parameters supplied by Oma7144.
I have not managed to flash with RKAndroidTools 1.35 as it do not detect my tablet, so I have done it with Finless Rom Flash Tool v1.37.
Now the tabled is running fine with only one problem: Internal memory is missing :(!!! So there is only 2G RAM, 2G ROM and no Internal SD! Any idea how to fix that?
2014/01/05 - 11:08
v1.35 is for RK3066. So it will not know RK3188.
v1.37 is for RK3188.
I guess you have flashed a CWM?
evilchuckk
2014/01/05 - 13:14
Guys i flashed oma's multi window chuwi v88 rom to my aocos and its running good and perfect rom. Only you need to change kernel.img, boot.img and the parameter with yours and than just flash it. http://crewrktablets.arctablet.com/?p=1499 download it here 5.3, change kernel boot and parameter and flash it.
pepitogrillo697
2014/01/08 - 00:39
Hello guys, I'm here again. I would like to make the same as you, Evilchuckk, but I need more information. I've download cRom v5.3 and format_Nand, and I have read the instructions , but I don't know how to use all these files. Can anybody explain the steps I have to follow to install this Rom? I have never used RKAndroidTool.
Thank you very much.
pepitogrillo697
2014/01/09 - 23:48
Hello again. I've been reading about RKAndroidtool and now I understand better how does it work, but before to flash my tablet with oma's multi window chuwi v88 rom, I want to do some questions to be more sure.
- If this rom doesn't works well and my tablet doesn't boot, can I make a recovery of my backup and repair the tablet with it from CWM?
- I don't know where to find the file "parameter" of my tablet aocos px103, I only have the parameter file that Oma7144 put in a link with a Kernel. Is this file I have to use instead of the file I have downloaded in cRom v5.3? And can anybody explain what is this file used for?
- I have read the instructions that are inside the cRom v5.3, and in this document appears a file called format_NAND fix. But do I have to use this file as is explained in the instructions? And can anybody explain what is this file used for? I have read that to flash a rom with RKAndroidtool you only have to do a eraseIDB first and after that, to choose each file of the image folder, and press Run, but nothing about format_Nand fix.
Thank you very much, and please I'm very interested in flashing my tablet, because the original rom doesn't work well.
pepitogrillo697
2014/01/27 - 01:13
Hello, finally I have flashed oma's multi window chuwi v88 rom to my aocos px103 and it's perfect. Thank you Oma. Well I have to rotate the screen, but it was the only thing I have to do. But I continue having a problem with the battery and I think it is because of the original kernel.
When I installed the Oma´s rom, I make what evilchuckk said, and I conserved my original kernel. But If this kernel is the problem, can I install another kernel? For ex. the kernel who goes with the oma's multi window chuwi v88 rom?
Thank you.
spammi
2015/04/22 - 19:15
I tried to flash my aocos PX103. The reason was a hang on boot during the animated android text. I flashed it and now I didn't even get a TExt or the android-logo. But RKAndroid-Tool is able to flash it. I'm not sure, what to do next.
Which kernel do I need? Or do I need to change some settings?
update: I heard, the original kernel is needed. Unfortunately I fear, I killed it 🙁 Can anyone help me?
spammi
2015/04/28 - 16:18
Thanks to pepitogrillo697!! Thanks for your help. My tablet is working again 🙂 I'm really happy!
spammi
2015/04/30 - 21:19
Hello again.
I'm glad, my tablet is working. But I now have one problem. The screen orientation is 90° off. With most apps it's no problem because i fix orientation and don't allow to auto-rotate the screen. But it would be nice, if this error could be fixed.
Anybody here, who can help me with that?
elic
2015/05/01 - 19:30
hi,
i brick my aocos px103.. can someone please reupload the stock frimware?
megaupload link is dead.
thanks!
pepitogrillo697
2015/05/02 - 00:17
Hello spammi, to change the screen orientation you have to go to the build.prop file (inside the system folder) and change the line "ro.sf.hwrotation=270". Save changes and reboot.
Bye.
spammi
2015/05/02 - 20:27
Bye.
That's it!! Thank you again. Now everything is perfect. You're so excellent!
81 Guest(s)
Devices in use: Desktop (63), Phone (18)
heftpflaster
rk.13
