Is a stock firmware available?
Is the tab already rooted? Then we can dump the firmware.
Can someone help here dumping his firmware?
Root & Dump Tool: http://crewrktablets.arctablet.com/?wpfb_dl=1264
Thank you very much! We have solved this meanwhile via PM.
Maybe evilchuckk can provide the stock firmware for other users here?!
You need to install the RK USB-Driver. Usually they come with the RK Flashtools.
2013/12/17
Hello, here is my img files https://mega.co.nz/#!UJNgFZJZ!O9PkqyfQDLVWtuDcQ9H-plV2OLhYD8oGOyAJuz-gjB8
2013/12/30
Thank you for this files Evilchuckk. I installed CWM recovery in the tablet (http://www.arctablet.com/blog/forum/arctools-application/clockworkmod-cwm-recovery-easy-install-on-rk3066-and-rk3188-devices/) and it works very well. I make a backup but it doesn't create a file called system.img, the file system apears but with the extension "tar". Do you know why? How dis you obtein the file system.img? And do you know if the file ".tar" is good to make a recovery?Â
Another thing is to install a custom rom. Have you installed any in your tablet aocos px 103? I have seen that the Pipo M9 has a very similar especifications so I don't know if a rom for this tablet could be use for our tablet.Â
Thank you.
Backup of the files by CWM/TWRP will produce either a *.tar or *.zip files in which the kernel files plus all systems apps and user apps will be backed up. You dont have to use "REBOOT" into Recovery before you can do backups.(like Windows System backup , it doesnt produce a Windows installer in *.exe format)
there are apps that can do the back up Nandroid Manger is one : https://play.google.com/store/apps/details?id=com.h3r3t1c.bkrestore which manges the backup version
and its twin app OBackup : https://play.google.com/store/apps/details?id=com.pommedeterresautee.twoborange3Â (I recommend this app)
Both can do Nandroid backup without REBOOT into "recovery". Our RK3xxx CWM recovery is just that "recover" from a bad software mod or update it can only do "backup" and "restore" if anthing goes wrong with our modification such as a bad "build.prop" or any additional drivers that we put into "init.d" that causes a boot loop for example.
But neither TWRP or CWM will produce a *.img file". Hope you guys understand this.
pepitogrillo697About Me  LENOVO S939 MTK6592 Vibe 2.0 - 1507,LENOVO A8-A5500 KitKat MTK8382 S029,Lenovo Tab2 A7-30HC MT8382 Lollipop,LENOVO A880 S027 MTK6582 (JB),ONDA V975m V3 AMLOGIC M802 (KitKat), PiPo M9Pro RK3188 KASTY ROM (KitKat # 407 Mod), ZENITHINK ZTPAD:C93 Duo Core AMX CM10.2_rc-3, Z102 And. 4.0.4, C91 And. 4.0.4,AIGO M60 Android 4.04 6" A13 (rooted).Lenovo A369i 4.2.2 S011 ROW
Use backup to external sdcard.
You can restore system by using advanced restore from external sdcard > system.
System is in .tar format in this case.
To flash images (.img) you need the RKAndroidTool.
The problem with custom roms is your kernel. It is much bigger then the usual convention.
Kernel and parameter is here: http://crewrktablets.arctablet.com/?wpfb_dl=1313
pepitogrillo697Per aspera ad astra, we rock the Tablets !
111 Guest(s)
Devices in use: Desktop (96), Phone (15)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
