dopo problem td1010
jcolon
Forum Posts: 19
2015/06/29 - 21:43
if I refer to the stock firmware 4.0.4 td1010 dopo ics. copy exists
2015/06/29 - 21:44
Ok. Where can I find it?
jcolon
Forum Posts: 19
2015/06/29 - 22:15
sorry I wonder if any? in another post talked of a stock firmware dopo td-1010. is Bigl post. double power dopo td-1010
jcolon
Forum Posts: 19
2015/06/29 - 22:45
install step as the wing rom.rar put sd card in the tablet and go into recovery mode and install
jcolon
Forum Posts: 19
2015/06/30 - 16:13
greetings oma7144 which of the img I flash. And as the charge at 1.5 Rockchip batch tool or 3.09 phoenixcard. I am not an expert I just want to learn thanks
2015/06/30 - 16:19
Everyting you need is included in the download pack. Here is a good instruction: http://www.arctablet.com/blog/forum/other-android-tablet-manufacturers/double-power-dopo-td-1010/#p40152
jcolon
Forum Posts: 19
2015/07/01 - 17:43
greetings touch install the package does not work I do to work
2015/07/01 - 18:08
What does not work?
jcolon
Forum Posts: 19
2015/07/01 - 18:20
greetings install the package and the touchscreen does not work I do to work
2015/07/01 - 18:23
Did you change the dopo kernel?
jcolon
Forum Posts: 19
2015/07/01 - 18:35
download the package and change the image folder
2015/07/01 - 20:34
No idea. Try again, incl. eraseIDB.
jcolon
Forum Posts: 19
2015/07/02 - 04:04
greetings and work the touch screen is bad. use the mouse and ready works well.thanks
2015/07/02 - 06:34
Let me have a dmesg log.
71 Guest(s)
Devices in use: Desktop (66), Phone (5)
Bokser
hamishduke
squal
squalangel
anqilan456
havetoregister
