2015/05/26
greetings I am new to this forum I have a problem delete an application from my tablet video player if I could provide this through my tablet is a td1010 ics 4.0.4 3.0.8 dopo kener number decompilation rk30_ics_v2.23.00 lianmaoxi_v2_40.20120927.5f56e2 cpu RK3066 bnch5311231 thanks
And now the tab is not booting any longer?
2015/05/26
greetings friend tablet works the problem is to install an application from the store and accidentally i was looking through the tablet as delete the tablet and root and I was wrong and delete the video player system and wanted to recover the look but not the I found if you could copy a td1010 dopo for me thanks
Attached pls find the RKVideoPlayer from an ICS image.
2015/05/26
thanks friend now I have a problem installing the application but stops when playing you ask open that Asher change to work or if I move to systematic work well only thing I see different is that mine was saying in Spanish video player in English I do not remember if Always thought this video and reproductor de video designed but never mind after working thanks for the help I'll have to ask you to change the permissions of imtalacion
2015/05/26
hello friends was weeks since the visit oma7144 ask you something and not as answered me not if asked correctly thanks for the application but have a problem when recording with my tablet and video use player for recording this starts to look out a message the video player application is stopped as I solve this problem I hope your answer thanks much of this do not ask excuses use google translator
Can you please try to make short sentences with one mesage in it and a full stop between? This might help to understand what you want.
Do you have the same effect when using n other video player from the Play Store?
Could be that the app needs to run as a system app. Why are you so interested in the RK Videoplayer. There are a lot of others you can use.
You mean the stock firmware is not available?
57 Guest(s)
Devices in use: Desktop (48), Phone (9)
