No problemÂ
2013/01/11
Hi! I'm borrowing this thread a bit(my first post).
I have recently bought a TAC-7018 and i'm trying to root with the instructions in this thread.
I have installed RKbatch tool 1.5, but when i go into recovery the unit doesn't appear in the bach tool.
It appears when i start the tablet normally though, but from there i can't restore the .img file.
I have USB-debuggin switched ON.
I would be very thankful for helpful comments.
Best regards
//Benny
2012/07/28
Are you sure you are in recovery mode?
are you trying to flash it with rkbatch tool 1.5?Â
Did you download the denver package?
This is just the image file
You need the denver tools with the drivers to be able to flash this image to your tablet
edit : PDF FILE http://www.masterpiece.dk/UploadetFiles/11174/138/Opdatering_af_firmware_-_DENVER_TAC-7018.pdf
and
heres the tool
https://docs.google.com/open?id=0Byi_uA2h5KkBWE9kUDJ5dS1PTFE
2013/01/08
Hi
First I just want to thank you for the root for the tac-7018 witch worked great for me! But
I was wondering if there might be an way of rooting the denver tac-70031?
Would it work with your custom firmware? I think the tablet is based on the same firmware but i doesn't use the rkbatch tool it's using Livesuit. is there any way that you could use the Livesuit tool with your firmware or could you might make one for the tac-70031?
Link to the official denver tac-70031 firmware:
https://docs.google.com/file/d/0Byi_uA2h5KkBNE9mQ2hhenlTdlE/edit
Copying the update.img to internal storage or sdcard does the job with manufacturer's updates, but it doesn't work well (or at all) on a custom firmware. This is caused by the partitionning of the different images (system, data, kernel...) which is different between stock and custom firmwares.
May I ask how you edited the .img-file? What tools did you use? Maybe if you let me know how you did or what tools you used I can test root the same android-version but with a different boot version, this one you helped breum with is 1.xx and mine is 2.30 and every time when I try upgrade I end up with fail. Or if sumone else here can help me root the tac-7018 denver with boot version 2.30. This version are the one I need rooted:
http://www.denver-electronics.com/denver-tac-7018-firmware-upgrade/
But if no one have the time to root this version, info on the tools and how-to doesnt take that long to explain, so I can do it myself and post it here for does who need to root this version.
2012/12/29
used the guide
Are you sure you are in recovery mode? yes i think so the screen is dark, and when my computor serches for the drivers , it doesnet find any. "unknown device" iget
and thats the only mode my computor sens the tablet. exept when its on normaly,
what can i do here ?
2012/12/29
okey i found the drivers! trying to manuelly load them. and then i get error messege, drivers not right for this device it says, or someting like that?
but maby im not in the right mode on my tablet after all. its very hard to follow the steps on the link u posted. its all for difftent tablets exept the tac,
can you please help me how to enter the right mode. i would be very happy
366 Guest(s)
2 Guest(s)
Devices in use: Desktop (88), Phone (278)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
