2014/01/18
Hallo there everybody,
I'm trying to install CyanogenMod 10 for 31xx on my Alcor Zest q813IX but my efforts have been unsuccessful so far:
After installing the rom my device doesn't start in either system or recovery mode.
I've noticed that another user has successfully installed it on an Alcor Zest q813I which is basically Alcor Zest q813IX's more powerful version (Alcor Zest q813I 2GB of ram and 16GB of flash drive as opposed to 1GB of ram and 8GB of the Alcor Zest q813IX) and he's using the rom's default kernel (bob #160)
Can Anybody help me?
Thank you very much in advance!
Do you see the kernel logo?
Ok, then the kernel won't work. Do you have a link to the stock rom?
Ok, kernel bob #393 preempt 20.12.2013 - http://crewrktablets.arctablet.com/?wpfb_dl=1407
Try again.
Hm, not really. Try again incl. eraseIDB.
2014/01/18
I've tried again,
I've noticed that the issue is only with landscape...
Does it ring a bell?
I've also noticed that candy crush crashes at startup.
Netflix doesn't work either, when I load a video it goes back to the video selection screen.
Do you maybe have any fixes for these issues?
Thank you again,
P.
Is the rotate app running?
Can you pls check if Plant vs Zombies 2 also crashes?
Netflix does have problems to identify JB. There are some fixes (exposed framework) to simulate ICS identification.
2014/01/18
Good morning!
Mh, Which rotate app, I can't see any...
I've tried plant vs Zombies 2 and it also crashes, Candy crash is my the biggest issue, my girlfriend could probably kill me if I don't find a fix
I've installed Xposed framework and I'm now trying to apply the fix, so far unsuccessfully, but the old version works (Which is a good start), do you know exactly what are the settings to make it work?
Thank you very much for the support!
P.
Then you use not the latest version v1.3.5a, which fixes this two bugs.
game fix: http://crewrktablets.arctablet.com/?wpfb_dl=1320
rotation fix: http://crewrktablets.arctablet.com/?wpfb_dl=1369 (start the app once)
Attched the Xposed bit.
58 Guest(s)
Devices in use: Desktop (49), Phone (9)
